RCD330
Locoelectrician
USA Canton Ohio
C?ID=235721
I don’t have a lot to offer the thread, but I’ll give what I have and maybe some of it will help someone.
2015 Passat TDI SEL Premium. Replaced the RNS510 with the RCD330 187b. Pretty much plug and play other than the reverse camera which I am currently working on. Disabled NAV in VCDS which cleared most of the errors but there was no sound. Box 2 was set to 00 which is “no audio system”, trying to change it to anything gives error 31. Per other forums, unhooked battery and reconnected and now I have sound. Box 2 still says 00 which I find strange, but I’m not nearly as involved with VCDS as most of you. Was able to change box 4 to 40 which enables rear view camera and was able to disable treble monitoring. I read somewhere else that I had to put it in development mode to be able to mess with box 2, which I think I did, but it still wouldn’t accept anything other than 00, no audio system. Oh well, it works.
Couldn’t stand the USB being on the front so I tore it apart, cut the end off of a female USB cable and soldered it to the PCB and ran it out the back. Works perfectly and the new cable now comes out between the seat and center console which is perfect for me.
Having a few issues that I’m figuring are with the RCD firmware, and unfortunately, the buyer I got it from says the developer hasn’t updated it in quite a while and he doubts they will anymore. In fact, his supplier doesn’t even offer this system anymore so my guess is that the ones for sale are what’s left. I’ve been wrong before though.
So if you’re not completely bored yet, and not writing a flaming response to my ignorance, I’ll talk about the “non”VCDS issues I’m having with it.
Volume... It doesn’t seem to remember volume settings. You can set it as low as you want and the next time you start the car it is at about 1/4 volume, which is kind of loud at 6am. There are settings in the RCD to set maximum startup volume, but they seem to be ignored. I set it to minimum, and it still starts at 1/4.
Volume -2... any time you use Siri, when you are done and go back to music, the volume basically doubles up to a finite point. If the volume is up high, it doesn’t seem to do it. Sometimes I feel like it’s going back to startup volume and sometimes it seems louder. Siri works great though.
Volume-3... the sound is pretty good for the first 1/3 of the range, but starts to distort and not sound nearly as clear as it increases. This is what originally got me digging in VCDS to try to set it up correctly (as in fender). I believe from a pinout I saw that this has 4 speaker outputs and after looking at the boards inside, it doesn’t really surprise me that it distorts. My uneducated guess is that somehow the speaker level outputs are being used as the amps inputs (not uncommon)but then any distortion is of course being amplified. The RNS510 definitely sounded better cranked up.
Phone... whether tethered via lightning cable or via Bluetooth, the calls are not quite as clear on the other end. Not bad, but not as good as the RNS. The ringer volume is always way too loud and seems to be based off of the volume of the last call you made. Meaning if I’m on the highway at 70, and have the phone volume up, the next call I get will ring so loud I about jump out of the seat. My quick fix for this was to pick a very mild ringtone. Another annoying issue is that while we all know the mic will block out background noise, the beeps that occur when you push any button on the radio go through to the person on the other end quite loud.
Overall, even with the quirks, I’m quite impressed for 235 bucks. CarPlay works perfectly, capacitive touch screen is lightning fast, and it looks great in the dash, especially with no USB cord hanging out of the front.
   #42
sasha
Australia
C?ID=287611
Good writeup.
I've given up on my RCD330 as rely heavily on in-car handsfree calling. I've gone back to RSN510 with Telephone (J412) 5N0 035 729 unit. Apart from the good looks of the RCD330 there is nothing I miss to be honest.
   #43
Locoelectrician
USA Canton Ohio
C?ID=235721
Discovered a huge sound quality increase today by increasing the mbps of the Spotify and pandora streams. They were on standard (I’m sure to preserve data)and switching them to the highest setting made a huge difference. Having a love hate relationship with this thing right now. Price was right, but I would have gladly paid more to have the few minor issues sorted.
@Sasha, I’m kind of opposite of your situation. I use navigation quite a bit and as we all know, entering an address into the RNS is about as much fun as licking a hot soldering iron. I’m also absolutely in love with the CarPlay interface.
   #44
iichel
Netherlands, eastern part
C?ID=284912
I like this attitude.
   #45
komin.mm
Myanmar
C?ID=316464
Hi guys,
First, I am pretty new here. Nice meeting you all.
Recently I upgraded to this RCD330+ 187B and I am having huge problem. My back cam and OPS are not showing on the screen. I am aware that back cam needs converter or change to compatible one. But for OPS I have no idea what to do next.
I have received VAG cable today and tried to activate 56.Radio but VCDS is not able to reach to this RCD330. I tried to unplug battery and reboot the head unit but still no hope. I believe CAN gateway is already talking to head unit since head unit is showing temperature and time correctly. Apart from that when I put gear in reserve, audio volumn is lowered as well.
What should I do? I need your guys help. Thanks in advance!
   #46
Hi guys,
komin.mm
Myanmar
C?ID=316464
Sunday,24,September,2017,22:16:17:20127
VCDS Version: 17.8.0.1  HEX-V2 CB: 0.4401.4
VIN: WVWZZZ1KZDW002641   License Plate: 7712
Mileage: 43930km-27296mi   Repair Order:
Chassis Type: 1K-VW36 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 52 56 61 62 72
VIN: WVWZZZ1KZDW002641   Mileage: 43930km-27296miles
Address 01: Engine (J623-CBZB)       Labels:. 03F-906-070-CBZ.clb
  Part No SW: 03F 906 070 JK    HW: 03F 907 309 S
  Component: SIMOS10.13AH10 2682
  Revision: --H10---    Serial number: 00000000000000
  Coding: 002500B6232401080000
  ASAM Dataset: EV_ECM12TFS02103F906070JK 004005
  ROD: EV_ECM12TFS021.rod
  VCID: 74B2D4271E3FC6574F2-8020
Readiness: 0110 0101
  Part No SW: 0AM 300 060 D    HW: 0AM 927 769 D
  Component: GSG DSG AG7     431 3656
  Revision: 00043014    Serial number: CU501205055322
  Shop #: WSC 73360 981 89128
  VCID: 2B000F5B8F01D9AFDE8-807E
  Revision: 00H31001
  Coding: 133B400D212200FCC81102E8841A0090310000
  VCID: 7DA4F1032DF5871F30C-8028
  Part No SW: 7N0 907 426 BG    HW: 7N0 907 426 BG
  Component: AC Manuell    H20 0505
  Revision: 00001018
  Coding: 0010004003
  VCID: 7AAEFA1F3C5BB02715E-802E
  Part No SW: 1K0 937 084 J    HW: 1K0 937 084 J
  Component: BCM PQ35  B   111 0709
  Revision: AB111709
  Coding: 46180A38E8251AC0408800C0340000244F510288436D8960648087200041
  VCID: 3534292355459F5FB8C-8060
  Subsystem 1 - Part No: 5K2 955 119
  Component: Wischer 14051  26  0512
  Coding: 009795
  Component: RLS 160512 05  54  0403
  Coding: 0F30AD
Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
  Part No SW: 56D 919 475 A    HW: 56D 919 475
  Component: PARKHILFE 8K  H02 0006
  Revision: --------    Serial number: 35811401500962
  Coding: 300101
  ASAM Dataset: EV_EPHVA18VW4110000 001007
  ROD: EV_EPHVA18VW4110000.rod
  VCID: 3330173B5BB1816F968-8066
12658720 - Databus
                   Reset counter: 168
                   Mileage: 43938 km
                   Date: 2017.09.24
                   Time: 11:43:39
  Part No SW: 5C0 959 655 D    HW: 5C0 959 655 D
  Component: AirbagVW10G   013 0613
  Serial number: 003G7RA1KCJT
  Coding: 00004431
  ROD: EV_AirbaVW10SMEVW360.rod
  Serial number: 3572MSME1C215166ZZZR
  Serial number: 3582MSME6F085566ZZZ2
  Serial number: 3512QSME782E1142ZZZU
  Serial number: 3522QSME6405114CZZZP
  Part No SW: 5K0 953 507 AJ    HW: 5K0 953 549 B
  Component: Lenks.Modul   008 0090
  Revision: --------    Serial number: WHRPIÄiÄHHHHS
  Coding: 5880100000
  ROD: EV_SMLSNGKUDS_A05.rod
  VCID: 78AAE0170257A23763A-802C
  Part No SW: 5K0 920 873     HW: 5K0 920 873
  Coding: 570B00
  VCID: 6D84C1437D15179F80C-8038
  Part No SW: 7N0 907 530 AH    HW: 7N0 907 530 AH
  Component: J533  Gateway H50 1634
  Revision:   H50       Serial number: 26031400F13662
  Coding: 350003
  VCID: 76B6EE2F08C3D447716-8022
                   Reset counter: 168
                   Mileage: 43938 km
                   Date: 2017.09.24
                   Time: 11:43:38
  VCID: 6A8ECA5F4CFB00A7E5E-803E
  Part No SW: 5K0 959 701 J    HW: 5K0 959 701 J
  Component: Tuer-SG         009 2106
  Coding: 0135862
  Shop #: WSC 14898 001 1048576
  VCID: 392C2513755D7B3F5C4-806C
  Part No: 1K0 909 144 P
  Component: EPS_ZFLS Kl. 68     3305
  Revision: 00H22000
  VCID: 3728232B43496D4FAA0-8062
  Part No SW: 5K0 959 702 C    HW: 5K0 959 702 C
  Component: Tuer-SG         009 2120
  Coding: 0136118
  VCID: 3330173B5731816F968-8066
Address 56: Radio
  Part No SW: 7N0 907 534     HW: 7N0 907 530 AH
  Component: Batt.regelung H50 1634
  Coding: F300185A
  VCID: 71BCDD3361ADF37FA44-8024
  Component: J367-BDM  H07 0180
  Serial number: 00000000008900316113
  Coding: 0131216
  Shop #: WSC 01357 011 1012552
  VCID: 3534292359459F5FB8C-8060
  Coding: 0131216
  VCID: 36362E2F44439447B16-8062
End----(Elapsed Time: 01:03, VBatt start/end: 11.9V/11.8V. VIgn 11.9V)-----
Maybe this fault code in the Gateway explain things?
komin.mm
Myanmar
C?ID=316464
What should I fix? Maybe try swapping can high and low from head unit? Or my CAN gateway version is low? Thanks!
   #50
komin.mm
Myanmar
C?ID=316464
I have tried to change back to original can gateway and still the same. If I unchecked 56.Radio from can gateway, there is any error on can gateway.
Now I have no idea why gateway is not talking to Radio if checked in gateway installation list. From other hand, time and temperature are showing correctly on head unit which mean there is communication from gateway to radio. I am very confused.
Do I need canbus decoder?
   #51
iceorbital
C?ID=172897
I once wanted to buy this, but seller said it didn't have support for Dynaudio.
Been messing around with vcds settings with a rcd330g (aka plus) 187b unit installed in a mk6 golf r that had Dynaudio sound system and rns315 factory installed.
Looks like the way amps work, you do need to select a sound system in byte 1, or eventually things will crap out. The explanation is here http://www.vwgolf.net.au/showthread.php?2979-RNS510-Sat-Nav-Golf-R&p=79167&viewfull=1#post79167
Because the radio uses the same physical output wires (the speaker wires) for low level and high level output internally there is an electronic switch that switches the preamp to output to the speakers wires to go to the Dynaudio amp or the main Amp power amp output to the speaker wires (no Dynaudio).
So you can see if you leave it coded to Dynaudio the pre amps are driving their little transistors off to drive your huge speakers and eventually they will give up the ghost.
Apparently if an amp is fitted (dynaudio) the output stage power is 12db (which i am guessing the unit is set to now as the volume levels are greatly reduced compared to the RCD510). The output level needs to be changed to 26db via VCDS as shown in http://www.my-gti.com/1411
Now the interesting thing is of all the options available in byte 1, vcds won't accept (will through an out of range error) dynaudio or vokswagen sound systems. It does accept skoda sound system, but i still think the sound is worse than with the rns 315.
Question is, is the out of range error result of vcds lack of knowledge on the rcd330g unit, or does indeed mean that the rcd330g radio does not support any amp except skoda's ? And are the skoda and dynaudio amps any different? Will something break if setup one way (skoda sound system) or the other (sound system not installed?)
   #52
iceorbital
C?ID=172897
read in other forums that obdeleven will let coding byte 1 with 01 or 05. Is there a way to enable experimental mode or to force coding that byte on 56 radio?
   #53
Sure, you can change any byte you wish, whether it's documented or not.
iichel
C?ID=284912
before you go into the long code helper, there will be the long code string.
let's take the long code 01FF02A0
isolate the byte you need changing (i.e. FF in hexadecimal, so that is binary 11111111) you can find any hex/dec/bin converter of your liking. my personal favourite is microsoft excel, commands HEX2BIN() and BIN2HEX(). remember to always add an 8 and 2 in the parameters to have 8 decimal digits and 2 hexadecimal numbers.
then obey the order of bits to be 76543210. i.e. we need changing byte 5. then we'll have 11011111. convert back to HEX gives DF.
so the new long code is
01DF02A0
paste it back in the coding screen of vcds... and we're there. fingers crossed for the coding to be accepted.
   #55
iceorbital
C?ID=172897
thanks iichel and uwe. turns out odbeleven also won't code byte 1 to 01 or 05, so i guess i'm back where i was :S
   #56
Locoelectrician
USA Canton Ohio
C?ID=235721
This is disappointing as the audio levels with fender is the only reason I pulled this unit from my car. If anyone ever figures it out I will put it back in as I was quite happy with every other aspect of it.
