2016 Skoda Octavia III break - 1.6 TDI 77 kW / 105 HP / VCDS 16.8.4
Hello.
Below a fresh & untouched scan for a Skoda Octavia.
Last 5 digit of VIN are hidden, not being my car. Errors included
AutoScan:
Untouched configuration
Adpmap, advanced
Hello.
AutoScan:
Thursday,22,December,2016,12:31:35:57018
VCDS Version: 16.8.4.2 (x64)
Data version: 20161129 DS267.0
Dealer/Shop Name:
VIN: TMBJG7NE0G01XXXXX
Mileage: 29071km-18063mi Repair Order:
Chassis Type: NE (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 5F
VIN: TMBJG7NE0G01XXXXX Mileage: 29071km-18063miles
Address 01: Engine (2D2D2-CXXB) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 056 CL HW: 04L 907 445 B
Component: R4 1.6l TDI H06 2506
Revision: 22004001
Coding: 01114012432419090000
Shop #: WSC 73430 031 00000
ASAM Dataset: EV_ECM16TDI03004L906056CL 002006
ROD: EV_ECM16TDI03004L906056CL_VW37.rod
VCID: F9F3A8E87807688A0E-80AC
25126 - Databus
27168 - Heater Support Pump
P16C6 00 [032] - Running Dry
Readiness: N/A
Part No SW: 3Q0 907 379 T HW: 3Q0 907 379 C
Component: ESC H32 0393
Revision: 00000000 Serial number: 60256000000588
Coding: 1C07629114290970007D060241C3243846289000608224F200400070C002
Shop #: WSC 73430 031 00063
ROD: EV_Brake1UDSContiMK100ESP_034_SK37.rod
VCID: CB9F2220621B2A1AEC-809E
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5E0 907 044 Q HW: 5E0 907 044 Q
Component: Climatronic H04 1002
Revision: 00001K07
Coding: 02010104002100011005000000101000
ROD: EV_ACClimaBHBVW37X_004_VW48.rod
VCID: B36F5AC01AEB52DA84-80E6
P1719 00 [008] - -
Reset counter: 100
Mileage: 28672 km
Date: 2016.12.19
Time: 22:11:31
Voltage terminal 30: 13.4 V
Auxiliary heater: in stages-Act.value: 3
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 086 AH HW: 5Q0 937 086 AH
Revision: -------- Serial number: 865823011601MN
Coding: 0C000842424702FB47E04000000407080000000000000000000000000000
Shop #: WSC 73430 790 00000
ROD: EV_BCMBOSCH_016_AU37.rod
VCID: 8005C50C1BDD394249-80D4
Subsystem 1 - Part No SW: 5E1 955 119 HW: 5E1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS371 160106 041 0570
Serial number: 160126211656
Coding: 065DDD
Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S5Y16M02D01H19M47S16
Coding: 00885D
Part No SW: 3Q0 959 655 AS HW: 3Q0 959 655 AS
Component: Airbag VW20 013 0200
Revision: -------- Serial number: 003SQP1ULJ1P
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 8F27F6305683563AC0-80DA
Subsystem 1 - Part No SW: ----------- HW: 454 002 101 16
Serial number: 3576U000000AAA5C281N
Subsystem 2 - Part No SW: ----------- HW: 454 001 901 16
Serial number: 3586U0000005C84C281I
Subsystem 3 - Part No SW: ----------- HW: 454 800 701 16
Component: SideSensor_Dr 301 0148
Serial number: 3516R3662BF090000008
Subsystem 4 - Part No SW: ----------- HW: 454 800 601 16
Component: SideSensor_Pr 301 0148
Serial number: 3526RCDB17C09000000M
Subsystem 5 - Part No SW: ----------- HW: 454 801 512 15
Component: FrontSensor_D 304 0149
Serial number: 3556V6C425F09000000H
Address 16: Steering wheel (J524) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 521 M HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0195
Revision: FF033033 Serial number: 20160207400241
Coding: 1400
ROD: EV_SMLSVALEOMQB.rod
VCID: BC7D71FC37B59DA255-80E8
Part No SW: 5E0 920 781 B HW: 5E0 920 781 B
Component: KOMBI 206 7652
Coding: 07A40A002180000801082A001000000000000000
ASAM Dataset: EV_DashBoardJCIMQBAB 009005
ROD: EV_DashBoardJCIMQBAB_VW48.rod
VCID: A757BE90DE332E7A28-80F2
9456681 - Key
B104C 29 [008] - Implausible Signal
Mileage: 1048574 km
Time: 00:00:00
Part No SW: 5Q0 907 530 AH HW: 5Q0 907 530 E
Component: GW MQB Mid 127 1244
Revision: -------- Serial number: 0004436045
Coding: 030100045F087300EB000248080F00010001050000000000000000000000
ROD: EV_GatewLear_013.rod
VCID: F7F7AED04E137EFA78-80A2
Subsystem 2 - Part No SW: 3V0 919 719 A HW: 3V0 919 719 A
Component: E221__MFL-PR6 H02 0150
Serial number: 000000000B1820290116
Subsystem 3 - Part No SW: 5Q0 915 181 H HW: 5Q0 915 181 H
Component: J367-BDMConti H02 1011
Serial number: 74185704001601261210
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 010 0031
Serial number: 0000184913915
Coding: 00150120D000040000001100
VCID: C7971E107E73CE7AC8-8092
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A
Serial number: 00000000000008741880
Coding: 010200
65639 - Motor for Window Regulator
B1487 29 [008] - Signal Implausible
Reset counter: 89
Mileage: 24428 km
Date: 2016.11.06
Time: 18:10:25
B1487 54 [008] - Missing Calibration / Basic Setting
Reset counter: 89
Mileage: 27765 km
Date: 2016.12.14
Time: 09:56:34
Part No SW: 5Q0 909 144 S HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1063
Coding: 0103
ROD: EV_SteerAssisMQB_VW31.rod
VCID: C48D091C4F45E5622D-8090
19716 - Databus
Reset counter: 67
Mileage: 1011 km
Date: 2016.04.01
Time: 07:53:18
Motor status: 02
System status: Driving mode
Supply voltage: 14.75 V
Temperature: 16.0 °C
KFC: 4D
KFA: 00 04
Environmental conditions: 20
uioUdNotFilt_xdu16: 14.91 V
uAdSensI_SwitchedKl30_xdu16: 14.91 V
20228 - Databus
Reset counter: 67
Mileage: 1011 km
Date: 2016.04.01
Time: 07:53:18
Motor status: 02
KFC: 4F
KFA: 00 04
uioUdNotFilt_xdu16: 14.78 V
uAdSensI_SwitchedKl30_xdu16: 14.78 V
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 010 0031
Serial number: 0000185632144
VCID: C68913147979D77233-8092
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A
Serial number: 00000000000008770786
Coding: 190200
Part No SW: 5E0 035 871 A HW: 5E0 035 871 A
Component: MU-E--ER 852 6490
Serial number: 04021600013261
Coding: 03730200FF00000011110001000000002F0000C40000010000
Shop #: WSC 73430 790 00063
ASAM Dataset: EV_MUEnt4CGen2LGE 001025
ROD: EV_MUEnt4CGen2LGE_SK26.rod
VCID: A34FAA80AA0BC25A74-80F6
End-------------------------(Elapsed Time: 03:32)--------------------------
adpmap-01-04L-906-056-CL.CSV
;SW:04L-906-056-CL HW:04L-907-445-B --- Engine
;Component:R4 1.6l TDI H06 2506, Coding:01114012432419090000
;EV_ECM16TDI03004L906056CL,002006,EV_ECM16TDI03004L906056CL_VW37.rod
;Thursday,22,December,2016,12:32:45:57018
;VCDS Version: Release 16.8.4 (x64) Data version: 20161129 DS267.0
;VCID: F9F3A8E87807688A0E-80AC
IDE00001-Production mode,00 00 00
IDE00259-Idle RPM correction,0 /min
IDE00263-Injector 1 correction value,R8R0XUPC3KJXUNJ4TRZ7
IDE00264-Injector 2 correction value,0RW0XWPWBUGSU8A4YYYU
IDE00265-Injector 3 correction value,RS00XUPC3LK1JPMWYTYZ
IDE00266-Injector 4 correction value,1RR0XWPC3KGXUNY2NYZ2
IDE01096-Particulate Filter Statistics,0
IDE01711-Blocking of particle filter regeneration,not active
IDE01945-Engine run-in oil pressure,not active
IDE02248-Individually adjustable maximum speed limit,300.0 km/h
IDE02332-Deactivate production mode,00 00 00
IDE04158-Activation of start-stop function,active
IDE04617-Protective function,Enabled
IDE06425-Roller test bench mode: functional,not activated
IDE07232-Initialization of NOx catalyst accumulator,2.21888e+006 s
IDE07903-Adaptation of ash mass,7.94 g
IDE08287-Bleeding of coolant circuit,not active
ENG105853-MAS04051-Disable_Adaption_Of_Turbo_Charger_Management-Adaptation for precontrol and damping,Not blocked
ENG105853-MAS04052-Disable_Adaption_Of_Turbo_Charger_Management-Adaptation of pressure sensor,Not blocked
adpmap-03-3Q0-907-379-T.CSV
;SW:3Q0-907-379-T HW:3Q0-907-379-C --- ABS Brakes
;Component:ESC H32 0393, Coding:1C07629114290970007D060241C3243846289000608224F200400070C002
;EV_Brake1UDSContiMK100ESP,034033,EV_Brake1UDSContiMK100ESP_034_SK37.rod
;Thursday,22,December,2016,12:33:05:57018
;VCID: CB9F2220621B2A1AEC-809E
IDE00001-Production mode,not active
IDE00252-Brake system vacuum pump,5
IDE00820-Activating and deactivating all development messages,0
IDE02332-Deactivate production mode,Deactivating
IDE03659-Roller test bench mode,Manual activation: possible
IDE04456-Brake disk drying,Medium
IDE04508-Hydraulic brake booster,8
IDE04643-Overboost in brake system,activated
IDE04765-Counter steer support,Strong
IDE04774-Vehicle and trailer stabilization,not activated
IDE04939-Tire pressure monitoring display,2
IDE04949-Engine drag torque control,activated
IDE04951-Brake booster,4
IDE04952-Braking torque boost for distance regulation,3
IDE05055-Hydraulic brake assistant,normal
IDE05057-Brake prefill,activated
IDE05161-Straight ahead brake stabilization,activated
IDE05337-IDE05337-Starting vibration reduction-,Strong
IDE05337-MAS02653-Starting vibration reduction-Torque limitation,Deactivated
IDE07006-Tire pressure monitoring display: tire selection,2
IDE07565-ABS in lower speed range,activated
IDE07848-Thresholds for brake performance,activated
MAS00122-Electronic Stability Program,not activated
MAS00194-tbd,Standard
MAS00970-Running manufacturer number,activated
MAS01299-Offroad,0
MAS02080-XCP calibration protocol,not activated
MAS02138-Hill-start assistant,normal
MAS08145-Hill-start assistant: increase threshold,3 %
ENG118148-Developer_Function_1,0
ENG130301-Developer_Function_121,not activated
adpmap-5F-5E0-035-871-A.CSV
;SW:5E0-035-871-A HW:5E0-035-871-A --- Information Electr.
;Component:MU-E--ER 852 6490, Coding:03730200FF00000011110001000000002F0000C40000010000
;EV_MUEnt4CGen2LGE,001025,EV_MUEnt4CGen2LGE_SK26.rod
;Thursday,22,December,2016,12:40:20:57018
;VCID: A34FAA80AA0BC25A74-80F6
IDE00346-Summertime-automatic,manual
IDE00758-Base volume of telephone,50 %
IDE00760-Microphone sensitivity,0 dB
IDE00769-Number 1 for Info call,5E 05 A1 20 21 30 82 88 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
IDE00770-Number 1 for roadside assistance,5E 05 A1 20 41 50 45 25 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
IDE00820-ENG117828-Activating and deactivating all development messages-Infotainment_CAN_Messages,OFF
IDE00820-ENG117829-Activating and deactivating all development messages-MIB_CAN_Messages,OFF
IDE02063-Time display for start screen,2.0 s
IDE02122-Developer mode,not activated
IDE02330-Number 2 for Info call,5E 06 91 04 12 02 23 88 F8 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
IDE02331-Number 2 for roadside assistance,5E 06 91 04 12 04 55 54 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
IDE02476-MAS03001-Electrical test of loudspeakers-Mode,automatic
IDE02476-ENG117360-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000 Hz
IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,30
IDE02476-ENG117378-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency,19000 Hz
IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,30
IDE02476-ENG117380-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency,19000 Hz
IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,30
IDE02476-ENG117382-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency,19000 Hz
IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,30
IDE02476-ENG117384-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency,19000 Hz
IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,30
IDE02476-ENG117386-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency,19000 Hz
IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,30
IDE02476-ENG117388-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency,19000 Hz
IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,30
IDE02476-ENG117390-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency,19000 Hz
IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,30
IDE02476-ENG117362-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000 Hz
IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,30
IDE02476-ENG117364-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000 Hz
IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,30
IDE02476-ENG117366-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000 Hz
IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,30
IDE02476-ENG117368-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000 Hz
IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,30
IDE02476-ENG117370-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000 Hz
IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,30
IDE02476-ENG117372-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency,19000 Hz
IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,30
IDE02476-ENG117374-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency,19000 Hz
IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,30
IDE02476-ENG117376-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency,19000 Hz
IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,30
IDE02502-Confirmation of installation change,3A E1
IDE02699-Number 1 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE02701-Number 1 (roaming) for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE04295-Bluetooth: Preferred connection profile for phone book data,PBAP
IDE04550-Bluetooth: Sniff mode,On
IDE10221-MAS00839-Audio Management Input Gain Generation 2-TV Tuner,-128
IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio,-128
IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM),-128
IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM),-128
IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB),-128
IDE10221-ENG125854-Audio Management Input Gain Generation 2-Exbox_DMB,-128
IDE10221-ENG117430-Audio Management Input Gain Generation 2-HFP,-128
IDE10221-ENG125846-Audio Management Input Gain Generation 2-Media_Airplay,-128
IDE10221-ENG125837-Audio Management Input Gain Generation 2-Media_AUX_Adapter,-128
IDE10221-ENG125836-Audio Management Input Gain Generation 2-Media_AUXIN,-128
IDE10221-ENG125843-Audio Management Input Gain Generation 2-Media_Bluray,-128
IDE10221-ENG125841-Audio Management Input Gain Generation 2-Media_BTDevice,-128
IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA,-128
IDE10221-ENG125848-Audio Management Input Gain Generation 2-Media_Cloud,-128
IDE10221-ENG125839-Audio Management Input Gain Generation 2-Media_DVD,-128
IDE10221-ENG125844-Audio Management Input Gain Generation 2-Media_HDMI,-128
IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP,-128
IDE10221-ENG125847-Audio Management Input Gain Generation 2-Media_UPNP,-128
IDE10221-ENG125855-Audio Management Input Gain Generation 2-Mirrorlink,-128
IDE10221-ENG125859-Audio Management Input Gain Generation 2-Phone_Ringer_MFP,-128
IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-128
IDE10221-ENG125858-Audio Management Input Gain Generation 2-Phone_Voice,-128
IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM,-128
IDE10221-ENG125850-Audio Management Input Gain Generation 2-Tone_Beep,-128
IDE10221-ENG125853-Audio Management Input Gain Generation 2-Tone_Messaging,-128
IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen,-128
IDE10221-ENG125851-Audio Management Input Gain Generation 2-Tone_Warning,-128
IDE10221-ENG125856-Audio Management Input Gain Generation 2-TTS_Nav,-128
IDE10221-ENG125857-Audio Management Input Gain Generation 2-TTS_SDS,-128
IDE10221-ENG125845-Audio Management Input Gain Generation 2-Tuner_Online,-128
IDE10221-ENG125849-Audio Management Input Gain Generation 2-Tuner_Personal,-128
IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI,-128
IDE10221-ENG125861-Audio Management Input Gain Generation 2-TV_AV_IN,-128
IDE11502-ENG127601-Locked menu contents-FB_CAR_0,non_blocked
IDE11502-ENG127602-Locked menu contents-FB_CAR_1,non_blocked
IDE11502-ENG127611-Locked menu contents-FB_CAR_10,non_blocked
IDE11502-ENG127612-Locked menu contents-FB_CAR_11,non_blocked
IDE11502-ENG127613-Locked menu contents-FB_CAR_12,non_blocked
IDE11502-ENG127614-Locked menu contents-FB_CAR_13,non_blocked
IDE11502-ENG127615-Locked menu contents-FB_CAR_14,non_blocked
IDE11502-ENG127616-Locked menu contents-FB_CAR_15,non_blocked
IDE11502-ENG127617-Locked menu contents-FB_CAR_16,non_blocked
IDE11502-ENG127618-Locked menu contents-FB_CAR_17,non_blocked
IDE11502-ENG127619-Locked menu contents-FB_CAR_18,non_blocked
IDE11502-ENG127620-Locked menu contents-FB_CAR_19,non_blocked
IDE11502-ENG127603-Locked menu contents-FB_CAR_2,non_blocked
IDE11502-ENG127621-Locked menu contents-FB_CAR_20,non_blocked
IDE11502-ENG127622-Locked menu contents-FB_CAR_21,non_blocked
IDE11502-ENG127623-Locked menu contents-FB_CAR_22,non_blocked
IDE11502-ENG127624-Locked menu contents-FB_CAR_23,non_blocked
IDE11502-ENG127604-Locked menu contents-FB_CAR_3,non_blocked
IDE11502-ENG127605-Locked menu contents-FB_CAR_4,non_blocked
IDE11502-ENG127606-Locked menu contents-FB_CAR_5,non_blocked
IDE11502-ENG127607-Locked menu contents-FB_CAR_6,non_blocked
IDE11502-ENG127608-Locked menu contents-FB_CAR_7,non_blocked
IDE11502-ENG127609-Locked menu contents-FB_CAR_8,non_blocked
IDE11502-ENG127610-Locked menu contents-FB_CAR_9,non_blocked
IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0,non_blocked
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,non_blocked
IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10,non_blocked
IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11,non_blocked
IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12,non_blocked
IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13,non_blocked
IDE11502-ENG127535-Locked menu contents-FB_MEDIA_14,non_blocked
IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15,non_blocked
IDE11502-ENG127537-Locked menu contents-FB_MEDIA_16,non_blocked
IDE11502-ENG127538-Locked menu contents-FB_MEDIA_17,non_blocked
IDE11502-ENG127539-Locked menu contents-FB_MEDIA_18,non_blocked
IDE11502-ENG127540-Locked menu contents-FB_MEDIA_19,non_blocked
IDE11502-ENG127523-Locked menu contents-FB_MEDIA_2,non_blocked
IDE11502-ENG127541-Locked menu contents-FB_MEDIA_20,non_blocked
IDE11502-ENG127542-Locked menu contents-FB_MEDIA_21,non_blocked
IDE11502-ENG127543-Locked menu contents-FB_MEDIA_22,non_blocked
IDE11502-ENG127544-Locked menu contents-FB_MEDIA_23,non_blocked
IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3,non_blocked
IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4,non_blocked
IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5,non_blocked
IDE11502-ENG127527-Locked menu contents-FB_MEDIA_6,non_blocked
IDE11502-ENG127528-Locked menu contents-FB_MEDIA_7,non_blocked
IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8,non_blocked
IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9,non_blocked
IDE11502-ENG127625-Locked menu contents-FB_MISC_0,non_blocked
IDE11502-ENG127626-Locked menu contents-FB_MISC_1,non_blocked
IDE11502-ENG127635-Locked menu contents-FB_MISC_10,non_blocked
IDE11502-ENG127636-Locked menu contents-FB_MISC_11,non_blocked
IDE11502-ENG127637-Locked menu contents-FB_MISC_12,non_blocked
IDE11502-ENG127638-Locked menu contents-FB_MISC_13,non_blocked
IDE11502-ENG127639-Locked menu contents-FB_MISC_14,non_blocked
IDE11502-ENG127640-Locked menu contents-FB_MISC_15,non_blocked
IDE11502-ENG127641-Locked menu contents-FB_MISC_16,non_blocked
IDE11502-ENG127642-Locked menu contents-FB_MISC_17,non_blocked
IDE11502-ENG127643-Locked menu contents-FB_MISC_18,non_blocked
IDE11502-ENG127644-Locked menu contents-FB_MISC_19,non_blocked
IDE11502-ENG127627-Locked menu contents-FB_MISC_2,non_blocked
IDE11502-ENG127645-Locked menu contents-FB_MISC_20,non_blocked
IDE11502-ENG127646-Locked menu contents-FB_MISC_21,non_blocked
IDE11502-ENG127647-Locked menu contents-FB_MISC_22,non_blocked
IDE11502-ENG127648-Locked menu contents-FB_MISC_23,non_blocked
IDE11502-ENG127649-Locked menu contents-FB_MISC_24,non_blocked
IDE11502-ENG127650-Locked menu contents-FB_MISC_25,non_blocked
IDE11502-ENG127651-Locked menu contents-FB_MISC_26,non_blocked
IDE11502-ENG127652-Locked menu contents-FB_MISC_27,non_blocked
IDE11502-ENG127653-Locked menu contents-FB_MISC_28,non_blocked
IDE11502-ENG127654-Locked menu contents-FB_MISC_29,non_blocked
IDE11502-ENG127628-Locked menu contents-FB_MISC_3,non_blocked
IDE11502-ENG127655-Locked menu contents-FB_MISC_30,non_blocked
IDE11502-ENG127656-Locked menu contents-FB_MISC_31,non_blocked
IDE11502-ENG127657-Locked menu contents-FB_MISC_32,non_blocked
IDE11502-ENG127658-Locked menu contents-FB_MISC_33,non_blocked
IDE11502-ENG127659-Locked menu contents-FB_MISC_34,non_blocked
IDE11502-ENG127660-Locked menu contents-FB_MISC_35,non_blocked
IDE11502-ENG127661-Locked menu contents-FB_MISC_36,non_blocked
IDE11502-ENG127662-Locked menu contents-FB_MISC_37,non_blocked
IDE11502-ENG127663-Locked menu contents-FB_MISC_38,non_blocked
IDE11502-ENG127664-Locked menu contents-FB_MISC_39,non_blocked
IDE11502-ENG127629-Locked menu contents-FB_MISC_4,non_blocked
IDE11502-ENG127665-Locked menu contents-FB_MISC_40,non_blocked
IDE11502-ENG127666-Locked menu contents-FB_MISC_41,non_blocked
IDE11502-ENG127667-Locked menu contents-FB_MISC_42,non_blocked
IDE11502-ENG127668-Locked menu contents-FB_MISC_43,non_blocked
IDE11502-ENG127669-Locked menu contents-FB_MISC_44,non_blocked
IDE11502-ENG127670-Locked menu contents-FB_MISC_45,non_blocked
IDE11502-ENG127671-Locked menu contents-FB_MISC_46,non_blocked
IDE11502-ENG127672-Locked menu contents-FB_MISC_47,non_blocked
IDE11502-ENG127630-Locked menu contents-FB_MISC_5,non_blocked
IDE11502-ENG127631-Locked menu contents-FB_MISC_6,non_blocked
IDE11502-ENG127632-Locked menu contents-FB_MISC_7,non_blocked
IDE11502-ENG127633-Locked menu contents-FB_MISC_8,non_blocked
IDE11502-ENG127634-Locked menu contents-FB_MISC_9,non_blocked
IDE11502-ENG127561-Locked menu contents-FB_NAV_0,non_blocked
IDE11502-ENG127562-Locked menu contents-FB_NAV_1,non_blocked
IDE11502-ENG127571-Locked menu contents-FB_NAV_10,non_blocked
IDE11502-ENG127572-Locked menu contents-FB_NAV_11,non_blocked
IDE11502-ENG127573-Locked menu contents-FB_NAV_12,non_blocked
IDE11502-ENG127574-Locked menu contents-FB_NAV_13,non_blocked
IDE11502-ENG127575-Locked menu contents-FB_NAV_14,non_blocked
IDE11502-ENG127576-Locked menu contents-FB_NAV_15,non_blocked
IDE11502-ENG127577-Locked menu contents-FB_NAV_16,non_blocked
IDE11502-ENG127578-Locked menu contents-FB_NAV_17,non_blocked
IDE11502-ENG127579-Locked menu contents-FB_NAV_18,non_blocked
IDE11502-ENG127580-Locked menu contents-FB_NAV_19,non_blocked
IDE11502-ENG127563-Locked menu contents-FB_NAV_2,non_blocked
IDE11502-ENG127581-Locked menu contents-FB_NAV_20,non_blocked
IDE11502-ENG127582-Locked menu contents-FB_NAV_21,non_blocked
IDE11502-ENG127583-Locked menu contents-FB_NAV_22,non_blocked
IDE11502-ENG127584-Locked menu contents-FB_NAV_23,non_blocked
IDE11502-ENG127585-Locked menu contents-FB_NAV_24,non_blocked
IDE11502-ENG127586-Locked menu contents-FB_NAV_25,non_blocked
IDE11502-ENG127587-Locked menu contents-FB_NAV_26,non_blocked
IDE11502-ENG127588-Locked menu contents-FB_NAV_27,non_blocked
IDE11502-ENG127589-Locked menu contents-FB_NAV_28,non_blocked
IDE11502-ENG127590-Locked menu contents-FB_NAV_29,non_blocked
IDE11502-ENG127564-Locked menu contents-FB_NAV_3,non_blocked
IDE11502-ENG127591-Locked menu contents-FB_NAV_30,non_blocked
IDE11502-ENG127592-Locked menu contents-FB_NAV_31,non_blocked
IDE11502-ENG127593-Locked menu contents-FB_NAV_32,non_blocked
IDE11502-ENG127594-Locked menu contents-FB_NAV_33,non_blocked
IDE11502-ENG127595-Locked menu contents-FB_NAV_34,non_blocked
IDE11502-ENG127596-Locked menu contents-FB_NAV_35,non_blocked
IDE11502-ENG127597-Locked menu contents-FB_NAV_36,non_blocked
IDE11502-ENG127598-Locked menu contents-FB_NAV_37,non_blocked
IDE11502-ENG127599-Locked menu contents-FB_NAV_38,non_blocked
IDE11502-ENG127600-Locked menu contents-FB_NAV_39,non_blocked
IDE11502-ENG127565-Locked menu contents-FB_NAV_4,non_blocked
IDE11502-ENG127566-Locked menu contents-FB_NAV_5,non_blocked
IDE11502-ENG127567-Locked menu contents-FB_NAV_6,non_blocked
IDE11502-ENG127568-Locked menu contents-FB_NAV_7,non_blocked
IDE11502-ENG127569-Locked menu contents-FB_NAV_8,non_blocked
IDE11502-ENG127570-Locked menu contents-FB_NAV_9,non_blocked
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,non_blocked
IDE11502-ENG127546-Locked menu contents-FB_PHONE_1,non_blocked
IDE11502-ENG127555-Locked menu contents-FB_PHONE_10,non_blocked
IDE11502-ENG127556-Locked menu contents-FB_PHONE_11,non_blocked
IDE11502-ENG127557-Locked menu contents-FB_PHONE_12,non_blocked
IDE11502-ENG127558-Locked menu contents-FB_PHONE_13,non_blocked
IDE11502-ENG127559-Locked menu contents-FB_PHONE_14,non_blocked
IDE11502-ENG127560-Locked menu contents-FB_PHONE_15,non_blocked
IDE11502-ENG127547-Locked menu contents-FB_PHONE_2,non_blocked
IDE11502-ENG127548-Locked menu contents-FB_PHONE_3,non_blocked
IDE11502-ENG127549-Locked menu contents-FB_PHONE_4,non_blocked
IDE11502-ENG127550-Locked menu contents-FB_PHONE_5,non_blocked
IDE11502-ENG127551-Locked menu contents-FB_PHONE_6,non_blocked
IDE11502-ENG127552-Locked menu contents-FB_PHONE_7,non_blocked
IDE11502-ENG127553-Locked menu contents-FB_PHONE_8,non_blocked
IDE11502-ENG127554-Locked menu contents-FB_PHONE_9,non_blocked
IDE11502-ENG127505-Locked menu contents-FB_TUNER_0,non_blocked
IDE11502-ENG127506-Locked menu contents-FB_TUNER_1,non_blocked
IDE11502-ENG127515-Locked menu contents-FB_TUNER_10,non_blocked
IDE11502-ENG127516-Locked menu contents-FB_TUNER_11,non_blocked
IDE11502-ENG127517-Locked menu contents-FB_TUNER_12,non_blocked
IDE11502-ENG127518-Locked menu contents-FB_TUNER_13,non_blocked
IDE11502-ENG127519-Locked menu contents-FB_TUNER_14,non_blocked
IDE11502-ENG127520-Locked menu contents-FB_TUNER_15,non_blocked
IDE11502-ENG127507-Locked menu contents-FB_TUNER_2,non_blocked
IDE11502-ENG127508-Locked menu contents-FB_TUNER_3,non_blocked
IDE11502-ENG127509-Locked menu contents-FB_TUNER_4,non_blocked
IDE11502-ENG127510-Locked menu contents-FB_TUNER_5,non_blocked
IDE11502-ENG127511-Locked menu contents-FB_TUNER_6,non_blocked
IDE11502-ENG127512-Locked menu contents-FB_TUNER_7,non_blocked
IDE11502-ENG127513-Locked menu contents-FB_TUNER_8,non_blocked
IDE11502-ENG127514-Locked menu contents-FB_TUNER_9,non_blocked
MAS00951-Bluetooth,On
MAS02809-MAS02870-Check tone frequency-High note frequency range,4000 Hz
MAS02809-MAS02871-Check tone frequency-Medium note frequency range,1000 Hz
MAS02809-MAS02872-Check tone frequency-Low note frequency range,100 Hz
ENG117917-BAP_Debug_Mode_Release,not_released
ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization,not activated
ENG122227-ENG125814-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer,not activated
ENG122227-ENG126995-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off,not activated
ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high,activated
ENG122227-ENG125813-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill,not activated
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,not activated
ENG122227-ENG117490-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer,not activated
ENG122227-ENG117487-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off,not activated
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,activated
ENG122227-ENG117489-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill,not activated
ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key,not activated
ENG122227-ENG117650-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer,not activated
ENG122227-ENG117647-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off,not activated
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,activated
ENG122227-ENG117649-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill,not activated
ENG122227-ENG126152-Car_Function_Adaptations_Gen2-menu_display_Adblue,not activated
ENG122227-ENG126155-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer,not activated
ENG122227-ENG127002-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off,not activated
ENG122227-ENG126153-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high,not activated
ENG122227-ENG126154-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill,not activated
ENG122227-ENG117591-Car_Function_Adaptations_Gen2-menu_display_air_damper,not activated
ENG122227-ENG117595-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer,not activated
ENG122227-ENG117592-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off,not activated
ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high,activated
ENG122227-ENG117594-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill,not activated
ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination,activated
ENG122227-ENG117495-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer,not activated
ENG122227-ENG117492-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off,not activated
ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high,activated
ENG122227-ENG117494-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill,not activated
ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope,not activated
ENG122227-ENG122300-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer,not activated
ENG122227-ENG122297-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off,not activated
ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high,activated
ENG122227-ENG122299-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill,not activated
ENG122227-ENG117641-Car_Function_Adaptations_Gen2-menu_display_attention_identification,not activated
ENG122227-ENG117645-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_disclaimer,not activated
ENG122227-ENG117642-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off,not activated
ENG122227-ENG117643-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_high,activated
ENG122227-ENG117644-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill,not activated
ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating,not activated
ENG122227-ENG117535-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer,not activated
ENG122227-ENG117532-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off,not activated
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high,activated
ENG122227-ENG117534-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill,not activated
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,not activated
ENG122227-ENG117505-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer,not activated
ENG122227-ENG117502-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off,not activated
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,activated
ENG122227-ENG117504-Car_Function_Adaptations_Gen2-menu_display_awv_standstill,not activated
ENG122227-ENG122301-Car_Function_Adaptations_Gen2-menu_display_battery_management,not activated
ENG122227-ENG122305-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer,not activated
ENG122227-ENG122302-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off,not activated
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high,activated
ENG122227-ENG122304-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill,not activated
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,activated
ENG122227-ENG117670-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer,not activated
ENG122227-ENG117667-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off,not activated
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,activated
ENG122227-ENG117669-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill,not activated
ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer,activated
ENG122227-ENG117540-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer,not activated
ENG122227-ENG117537-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off,not activated
ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high,activated
ENG122227-ENG117539-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill,not activated
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,activated
ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer,not activated
ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off,not activated
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,activated
ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill,not activated
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,activated
ENG122227-ENG117655-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer,not activated
ENG122227-ENG117652-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off,not activated
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,activated
ENG122227-ENG117654-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill,not activated
ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking,activated
ENG122227-ENG117565-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer,not activated
ENG122227-ENG117562-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off,not activated
ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high,activated
ENG122227-ENG117564-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill,not activated
ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master,activated
ENG122227-ENG117605-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer,not activated
ENG122227-ENG117602-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off,not activated
ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high,activated
ENG122227-ENG117604-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill,not activated
ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma,not activated
ENG122227-ENG117575-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer,not activated
ENG122227-ENG117572-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off,not activated
ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high,activated
ENG122227-ENG117574-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill,not activated
ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration,activated
ENG122227-ENG117530-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer,not activated
ENG122227-ENG117527-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off,not activated
ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high,activated
ENG122227-ENG117529-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill,not activated
ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock,activated
ENG122227-ENG117590-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer,not activated
ENG122227-ENG117587-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off,not activated
ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high,activated
ENG122227-ENG117589-Car_Function_Adaptations_Gen2-menu_display_clock_standstill,not activated
ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass,not activated
ENG122227-ENG117570-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer,not activated
ENG122227-ENG117567-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off,not activated
ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,activated
ENG122227-ENG117569-Car_Function_Adaptations_Gen2-menu_display_compass_standstill,not activated
ENG122227-ENG125823-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist,not activated
ENG122227-ENG125826-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer,not activated
ENG122227-ENG126998-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off,not activated
ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high,activated
ENG122227-ENG125825-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill,not activated
ENG122227-ENG11015-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration,not activated
ENG122227-ENG11019-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_after_disclaimer,not activated
ENG122227-ENG11016-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_clamp_15_off,not activated
ENG122227-ENG11017-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_over_threshold_high,not activated
ENG122227-ENG11018-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_standstill,not activated
ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school,not activated
ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer,not activated
ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off,not activated
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high,activated
ENG122227-ENG117659-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill,not activated
ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall,not activated
ENG122227-ENG125038-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer,not activated
ENG122227-ENG126999-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off,not activated
ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,not activated
ENG122227-ENG125037-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill,not activated
ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist,not activated
ENG122227-ENG126163-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer,not activated
ENG122227-ENG127004-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off,not activated
ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high,not activated
ENG122227-ENG126162-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill,not activated
ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI,not activated
ENG122227-ENG126147-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer,not activated
ENG122227-ENG127000-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off,not activated
ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,not activated
ENG122227-ENG126146-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill,not activated
ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination,activated
ENG122227-ENG117520-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaimer,not activated
ENG122227-ENG117517-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off,not activated
ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high,activated
ENG122227-ENG117519-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill,not activated
ENG122227-ENG117596-Car_Function_Adaptations_Gen2-menu_display_headup_display,not activated
ENG122227-ENG117600-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer,not activated
ENG122227-ENG117597-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off,not activated
ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high,activated
ENG122227-ENG117599-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill,not activated
ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybrid,not activated
ENG122227-ENG117610-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer,not activated
ENG122227-ENG117607-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off,not activated
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high,activated
ENG122227-ENG117609-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill,not activated
ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant,not activated
ENG122227-ENG125809-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer,not activated
ENG122227-ENG125806-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off,not activated
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,activated
ENG122227-ENG125808-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill,not activated
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,not activated
ENG122227-ENG117510-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaimer,not activated
ENG122227-ENG117507-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off,not activated
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,activated
ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill,not activated
ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker,not activated
ENG122227-ENG117635-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer,not activated
ENG122227-ENG117632-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off,not activated
ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high,activated
ENG122227-ENG117634-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill,not activated
ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_vision,not activated
ENG122227-ENG117620-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer,not activated
ENG122227-ENG117617-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off,not activated
ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high,activated
ENG122227-ENG117619-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill,not activated
ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level,not activated
ENG122227-ENG117580-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer,not activated
ENG122227-ENG117577-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off,not activated
ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high,activated
ENG122227-ENG117579-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill,not activated
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc,not activated
ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer,not activated
ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off,not activated
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,activated
ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill,not activated
ENG122227-ENG125815-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist,not activated
ENG122227-ENG125818-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer,not activated
ENG122227-ENG126996-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off,not activated
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high,activated
ENG122227-ENG125817-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill,not activated
ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk,activated
ENG122227-ENG117545-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimer,not activated
ENG122227-ENG117542-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off,not activated
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,activated
ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill,not activated
ENG122227-ENG122306-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment,not activated
ENG122227-ENG122310-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaimer,not activated
ENG122227-ENG122307-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off,not activated
ENG122227-ENG122308-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_high,activated
ENG122227-ENG122309-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill,not activated
ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load,not activated
ENG122227-ENG117630-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_disclaimer,not activated
ENG122227-ENG117627-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off,not activated
ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high,activated
ENG122227-ENG117629-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill,not activated
ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification,not activated
ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimer,not activated
ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off,not activated
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,activated
ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill,not activated
ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration,not activated
ENG122227-ENG117560-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer,not activated
ENG122227-ENG117557-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off,not activated
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high,activated
ENG122227-ENG117559-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill,not activated
ENG122227-ENG125819-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic,not activated
ENG122227-ENG125822-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer,not activated
ENG122227-ENG126997-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off,not activated
ENG122227-ENG125820-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high,activated
ENG122227-ENG125821-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill,not activated
ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia,activated
ENG122227-ENG117555-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer,not activated
ENG122227-ENG117552-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off,not activated
ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high,activated
ENG122227-ENG117554-Car_Function_Adaptations_Gen2-menu_display_sia_standstill,not activated
ENG122227-ENG117621-Car_Function_Adaptations_Gen2-menu_display_side_view,not activated
ENG122227-ENG117625-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer,not activated
ENG122227-ENG117622-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off,not activated
ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high,activated
ENG122227-ENG117624-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill,not activated
ENG122227-ENG122311-Car_Function_Adaptations_Gen2-menu_display_special_functions,not activated
ENG122227-ENG122314-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer,not activated
ENG122227-ENG125810-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off,not activated
ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high,activated
ENG122227-ENG122313-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill,not activated
ENG122227-ENG11010-Car_Function_Adaptations_Gen2-menu_display_Spoiler,not activated
ENG122227-ENG11014-Car_Function_Adaptations_Gen2-menu_display_Spoiler_after_disclaimer,not activated
ENG122227-ENG11011-Car_Function_Adaptations_Gen2-menu_display_Spoiler_clamp_15_off,not activated
ENG122227-ENG11012-Car_Function_Adaptations_Gen2-menu_display_Spoiler_over_threshold_high,not activated
ENG122227-ENG11013-Car_Function_Adaptations_Gen2-menu_display_Spoiler_standstill,not activated
ENG122227-ENG126148-Car_Function_Adaptations_Gen2-menu_display_SportHMI,not activated
ENG122227-ENG126151-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer,not activated
ENG122227-ENG127001-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off,not activated
ENG122227-ENG126149-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high,not activated
ENG122227-ENG126150-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill,not activated
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,activated
ENG122227-ENG117680-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer,not activated
ENG122227-ENG117677-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off,not activated
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,activated
ENG122227-ENG117679-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill,not activated
ENG122227-ENG122315-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant,not activated
ENG122227-ENG122319-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer,not activated
ENG122227-ENG122316-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off,not activated
ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high,activated
ENG122227-ENG122318-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill,not activated
ENG122227-ENG122320-Car_Function_Adaptations_Gen2-menu_display_TV_tuner,not activated
ENG122227-ENG122324-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer,not activated
ENG122227-ENG122321-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off,not activated
ENG122227-ENG122322-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high,activated
ENG122227-ENG122323-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill,not activated
ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdo,not activated
ENG122227-ENG117615-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer,not activated
ENG122227-ENG117612-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off,not activated
ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high,activated
ENG122227-ENG117614-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill,not activated
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,activated
ENG122227-ENG122295-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer,not activated
ENG122227-ENG122292-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off,not activated
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,activated
ENG122227-ENG122294-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill,not activated
ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin,activated
ENG122227-ENG117585-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer,not activated
ENG122227-ENG117582-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off,not activated
ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high,activated
ENG122227-ENG117584-Car_Function_Adaptations_Gen2-menu_display_vin_standstill,not activated
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,not activated
ENG122227-ENG117665-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaimer,not activated
ENG122227-ENG117662-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off,not activated
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,activated
ENG122227-ENG117664-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill,not activated
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,activated
ENG122227-ENG117525-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer,not activated
ENG122227-ENG117522-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off,not activated
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,activated
ENG122227-ENG117524-Car_Function_Adaptations_Gen2-menu_display_windows_standstill,not activated
ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper,activated
ENG122227-ENG117550-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer,not activated
ENG122227-ENG117547-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off,not activated
ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high,activated
ENG122227-ENG117549-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill,not activated
ENG122227-ENG11020-Car_Function_Adaptations_Gen2-menu_soundcontrol,not activated
ENG122227-ENG11024-Car_Function_Adaptations_Gen2-menu_soundcontrol_after_disclaimer,not activated
ENG122227-ENG11021-Car_Function_Adaptations_Gen2-menu_soundcontrol_clamp_15_off,not activated
ENG122227-ENG11022-Car_Function_Adaptations_Gen2-menu_soundcontrol_over_threshold_high,not activated
ENG122227-ENG11023-Car_Function_Adaptations_Gen2-menu_soundcontrol_standstill,not activated
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,not activated
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,Databus extended
ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06,not activated
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,Suspension data bus
ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D,not activated
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,CAB_9
ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24,not activated
ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus,Comfort data bus
ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03,not activated
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,Comfort data bus
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,not activated
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,Terminal 15
ENG122229-ENG122336-Car_Function_List_BAP_Gen2-Battery_Management_0x25,not activated
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,Comfort data bus
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,activated
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,Databus Infotainment
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,activated
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,Suspension data bus
ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D,activated
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,Comfort data bus
ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17,not activated
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,Databus Infotainment
ENG122229-ENG117734-Car_Function_List_BAP_Gen2-clima_slave_2_0x16,not activated
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,Comfort data bus
ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01,activated
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Comfort data bus
ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02,not activated
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,Comfort data bus
ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11,activated
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,Comfort data bus
ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15,not activated
ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus,Databus Infotainment
ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10,not activated
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,Comfort data bus
ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33,not activated
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,Comfort data bus
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,Databus extended
ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C,not activated
ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37,not activated
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,Comfort data bus
ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09,activated
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,Comfort data bus
ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04,not activated
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,Comfort data bus
ENG122229-ENG117746-Car_Function_List_BAP_Gen2-Hybrid_0x1D,not activated
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,Databus drivetrain
ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08,activated
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,Comfort data bus
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,not activated
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,Databus extended
ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F,activated
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Comfort data bus
ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34,not activated
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,CAB_9
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,activated
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,Comfort data bus
ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18,not activated
ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus,CAB_9
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A,not activated
ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus,Terminal 15
ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20,not activated
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,Comfort data bus
ENG122229-ENG125831-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3A,not activated
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,Databus extended
ENG122229-ENG122333-Car_Function_List_BAP_Gen2-Range_Data_0x39,not activated
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,Databus Infotainment
ENG122229-ENG122327-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E,not activated
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,Comfort data bus
ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F,not activated
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Databus drivetrain
ENG122229-ENG125833-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3B,not activated
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,Comfort data bus
ENG122229-ENG08128-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F,not activated
ENG122229-ENG08129-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,Comfort data bus
ENG122229-ENG08126-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E,not activated
ENG122229-ENG08127-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,Comfort data bus
ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12,activated
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Comfort data bus
ENG122229-ENG117748-Car_Function_List_BAP_Gen2-SideView_0x1E,not activated
ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus,CAB_9
ENG122229-ENG122329-Car_Function_List_BAP_Gen2-Special_Functions_0x35,not activated
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,Databus Infotainment
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,activated
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,Databus Infotainment
ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A,not activated
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,Databus extended
ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07,activated
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Suspension data bus
ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21,not activated
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Databus extended
ENG122229-ENG122331-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36,not activated
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,Terminal 15
ENG122229-ENG122325-Car_Function_List_BAP_Gen2-TV_tuner_0x2C,not activated
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,Comfort data bus
ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14,not activated
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,Terminal 15
ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13,activated
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,Comfort data bus
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,not activated
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Databus Infotainment
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,not activated
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,Databus Infotainment
ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C,activated
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,Comfort data bus
ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key,Not available
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Comfort data bus
ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school,Not available
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Not available
ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL,Available
ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus,Databus Infotainment
ENG122228-ENG117683-Car_Function_List_CAN_Gen2-Oil_level,Not available
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Databus drivetrain
ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering,Not available
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Terminal 15
ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN,Available
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Comfort data bus
ENG117913-ENG101574-Dimming_Ambient_Illumination_Information_Control_Unit-X1,0
ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2,50
ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3,100
ENG117913-ENG99777-Dimming_Ambient_Illumination_Information_Control_Unit-Y1,0
ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2,50
ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3,100
ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1,0
ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2,10
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,70
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,100
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,220
ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6,253
ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1,1 %
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,1 %
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,6 %
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,10 %
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,70 %
ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6,100 %
ENG117809-p_damping_Display,5 ms
ENG117808-p_HMI_Display,13 %
ENG122219-ENG122287-Radio_Level_Quality_Offsets-Set_AM_Quality_Level_Offset,0
ENG122219-ENG122288-Radio_Level_Quality_Offsets-Set_FM_Quality_Level_Offset,0
adpmap-08-5E0-907-044-Q.CSV
;SW:5E0-907-044-Q HW:5E0-907-044-Q --- Auto HVAC
;Component:Climatronic H04 1002, Coding:02010104002100011005000000101000
;EV_ACClimaBHBVW37X,004131,EV_ACClimaBHBVW37X_004_VW48.rod
;Thursday,22,December,2016,12:33:47:57018
;VCDS Version: Release 16.8.4 (x64) Data version: 20161129 DS267.0
;VCID: B36F5AC01AEB52DA84-80E6
IDE00001-Production mode,Deactivating
IDE01067-Retention of driver's seat heater level,not active
IDE01478-Ignore compressor switch-off by Engine Control Module,Do not ignore
IDE01479-Gear ratio of engine - A/C compressor,0.00
IDE01483-Blower voltage for voice operation,not activated
IDE01488-Retrofitting of parking heater without CAN,not installed
IDE01493-Air quality sensor sensitivity,Maximum
IDE01503-Runtime for compressor run-in basic setting,120 s
IDE01536-Post-heating of parking heater,0 min
IDE02155-Reset all counters,not activated
IDE02332-Deactivate production mode,0
IDE03176-Duration of compressor run in,0 s
IDE03251-Stop release for start-stop function,According to function requirements
IDE04159-Deactivation of start-stop function,not active
IDE06425-Roller test bench mode: functional,not active
IDE06544-Speed switch-off threshold for compressor run-in (engine speed),1500 /min
IDE06545-Blower voltage for production routines,12.0 V
IDE06546-Interior target temperature for production routines,22 °C
IDE06547-Air distribution for production routines,No effect
IDE06593-Recirculation air for production routines,No effect
IDE07108-Climate modes,not activated
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,20 min
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,30 min
IDE07398-Blower logic for manual adjustment,Matching coding
IDE07585-Hand heater function during cold start,active
IDE07865-Automatic Activation of front windshield heater at MAX-Defrost,not active
IDE07948-Retention of frt.pass. seat heater level,not active
IDE80006-Analysis 6,not activated
IDE80007-Analysis 7,00000000 00000000
IDE80008-Analysis 8,active
MAS05739-CO2 compressor on-time reduction,Matching coding
MAS06564-Window condensation exterior reduction at high humidity,Matching coding
MAS07251-Cut-in behavior,Matching coding
ENG122844-ENG101574-dimming_characteristic_1-X1,0
ENG122844-ENG99557-dimming_characteristic_1-X2,6
ENG122844-ENG102140-dimming_characteristic_1-X3,40
ENG122844-ENG102936-dimming_characteristic_1-X4,60
ENG122844-ENG103548-dimming_characteristic_1-X5,80
ENG122844-ENG113992-dimming_characteristic_1-X6,100
ENG122844-ENG99777-dimming_characteristic_1-Y1,0 %
ENG122844-ENG100480-dimming_characteristic_1-Y2,6 %
ENG122844-ENG100773-dimming_characteristic_1-Y3,40 %
ENG122844-ENG100631-dimming_characteristic_1-Y4,60 %
ENG122844-ENG102174-dimming_characteristic_1-Y5,80 %
ENG122844-ENG113993-dimming_characteristic_1-Y6,100 %
ENG122845-ENG101574-dimming_characteristic_2-X1,0
ENG122845-ENG99557-dimming_characteristic_2-X2,10
ENG122845-ENG102140-dimming_characteristic_2-X3,50
ENG122845-ENG102936-dimming_characteristic_2-X4,100
ENG122845-ENG103548-dimming_characteristic_2-X5,220
ENG122845-ENG113992-dimming_characteristic_2-X6,253
ENG122845-ENG99777-dimming_characteristic_2-Y1,2 %
ENG122845-ENG100480-dimming_characteristic_2-Y2,2 %
ENG122845-ENG100773-dimming_characteristic_2-Y3,10 %
ENG122845-ENG100631-dimming_characteristic_2-Y4,21 %
ENG122845-ENG102174-dimming_characteristic_2-Y5,85 %
ENG122845-ENG113993-dimming_characteristic_2-Y6,100 %
ENG122846-ENG101574-dimming_characteristic_3-X1,0
ENG122846-ENG99557-dimming_characteristic_3-X2,10
ENG122846-ENG102140-dimming_characteristic_3-X3,50
ENG122846-ENG102936-dimming_characteristic_3-X4,100
ENG122846-ENG103548-dimming_characteristic_3-X5,220
ENG122846-ENG113992-dimming_characteristic_3-X6,253
ENG122846-ENG99777-dimming_characteristic_3-Y1,3 %
ENG122846-ENG100480-dimming_characteristic_3-Y2,3 %
ENG122846-ENG100773-dimming_characteristic_3-Y3,6 %
ENG122846-ENG100631-dimming_characteristic_3-Y4,12 %
ENG122846-ENG102174-dimming_characteristic_3-Y5,100 %
ENG122846-ENG113993-dimming_characteristic_3-Y6,100 %
ENG122847-ENG101574-dimming_characteristic_4-X1,0
ENG122847-ENG99557-dimming_characteristic_4-X2,10
ENG122847-ENG102140-dimming_characteristic_4-X3,50
ENG122847-ENG102936-dimming_characteristic_4-X4,100
ENG122847-ENG103548-dimming_characteristic_4-X5,220
ENG122847-ENG113992-dimming_characteristic_4-X6,253
ENG122847-ENG99777-dimming_characteristic_4-Y1,2 %
ENG122847-ENG100480-dimming_characteristic_4-Y2,2 %
ENG122847-ENG100773-dimming_characteristic_4-Y3,5 %
ENG122847-ENG100631-dimming_characteristic_4-Y4,10 %
ENG122847-ENG102174-dimming_characteristic_4-Y5,85 %
ENG122847-ENG113993-dimming_characteristic_4-Y6,100 %
ENG122848-ENG101574-dimming_characteristic_5-X1,0
ENG122848-ENG99557-dimming_characteristic_5-X2,10
ENG122848-ENG102140-dimming_characteristic_5-X3,50
ENG122848-ENG102936-dimming_characteristic_5-X4,100
ENG122848-ENG103548-dimming_characteristic_5-X5,220
ENG122848-ENG113992-dimming_characteristic_5-X6,253
ENG122848-ENG99777-dimming_characteristic_5-Y1,2 %
ENG122848-ENG100480-dimming_characteristic_5-Y2,2 %
ENG122848-ENG100773-dimming_characteristic_5-Y3,5 %
ENG122848-ENG100631-dimming_characteristic_5-Y4,10 %
ENG122848-ENG102174-dimming_characteristic_5-Y5,85 %
ENG122848-ENG113993-dimming_characteristic_5-Y6,100 %
ENG130577-Knockout_timer_activation,not activated
adpmap-09-5Q0-937-086-AH.CSV
;SW:5Q0-937-086-AH HW:5Q0-937-086-AH --- Cent. Elect.
;Component:BCM PQ37BOSCH 028 0162, Coding:0C000842424702FB47E04000000407080000000000000000000000000000
;EV_BodyContrModul1UDSBosc,015002,EV_BCMBOSCH_016_AU37.rod
;Thursday,22,December,2016,12:34:18:57018
;VCID: 8005C50C1BDD394249-80D4
IDE00001-ENG99061-Production mode-Access control,not active
IDE00001-ENG115730-Production mode-Aussenbeleuchtung,not active
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren,not active
IDE00001-ENG112304-Production mode-Heckwischer,not active
IDE00001-ENG98647-Production mode-Interior lighting,not active
IDE00001-ENG115729-Production mode-Scheinwerferreinigung,not active
IDE00001-ENG115731-Production mode-Virtuel_pedal,not active
IDE00002-Transport mode,active
IDE00820-Activating and deactivating all development messages,not active
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA,not active
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,0
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm,active
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf,active
IDE01268-ENG02322-Windshield wiper-Frontwischer_Abtauposition,not active
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,active
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer,not active
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren,Deactivating
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel,not active
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit,0 ms
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit,0 ms
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit,0 ms
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit,0 ms
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit,0 ms
IDE01268-ENG02321-Windshield wiper-Tippendes_Frontwaschen,not active
IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz,active
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status,not active
IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung,active
IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant,0
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube,not active
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus,active
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube,not active
IDE01550-Service position,166.51 °
IDE02152-Characteristics in production mode,2000 ms
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,Decelerate
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,not active
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,not active
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,not active
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,not active
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,kurz
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,not active
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,not active
IDE02269-ENG02272-Acknowledgement signals-Quittierton bei zweitem ZV-AUF-Befehl,not active
IDE02269-ENG02273-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl,not active
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen,active
IDE02711-ENG02325-Rear Window Wiper-Einzelansteuerung Heckintervallwischen,not active
IDE02711-ENG02323-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1,0 s
IDE02711-ENG02324-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2,0.0 s
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf,not active
IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken,not active
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck,active
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,not active
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum,20 %
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer,40 %
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn,40 %
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung,not enabled
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel,not installed
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel,not installed
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,0.25 °
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.00 %/s
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,both sides
IDE03638-ENG116675-static AFS light-Lower speed threshold,0.00 km/h
IDE03638-ENG116682-static AFS light-Maximaltemperatur,100.00 °C
IDE03638-ENG116679-static AFS light-obere Grenztemperatur,95.00 °C
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,90 °
IDE03638-ENG116680-static AFS light-untere Grenztemperatur,80.00 °C
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,30 °
IDE03638-ENG116676-static AFS light-Upper speed threshold,40.00 km/h
IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119
IDE04923-ENG02307-Turn signal control-Abbruch Komfortblinken,active
IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger,separte
IDE04923-ENG115774-Turn signal control-Komfortblinken,active
IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen,3
IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker,SMLS
IDE04923-ENG116588-Turn signal control-Sonderfunktionen,not enabled
IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung,not active
IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung,Always active
IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor,0.10
IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert,20.00 %
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze,50 km/h
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze,50 km/h
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,integriert in Suchbeleuchtung
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,active
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,0 km/h
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert,One-sided
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,not active
IDE04924-ENG126816-Driving light and parking light-Standlicht aus,active
IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht,active
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht,not active
IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten,Low beam
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus,automatic
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis,Driver door
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung,46400 lx
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,12 lx
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus,Enabled
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome,10 s
IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP,10 s
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,active
IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP,active
IDE04927-IDE01446-Window heater-Running time of heated front window,600 s
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung,35.00 °C
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung,35.00 °C
IDE04927-ENG126845-Window heater-FSH Automatik,active
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,600 s
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,not active
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,not active
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active
IDE04928-ENG115864-Anti-theft device-Alarmsignal,frequency modulated
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,not active
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus,not active
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel,not active
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck,active
IDE05142-ENG116621-Access control-automatisches Entriegeln,active
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit,active
IDE05142-ENG116706-Access control-Autounlock NAR,not active
IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB,not active
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung,active
IDE05142-ENG02315-Access control-Deaktivierung_Laderaumschliessung_extern,not active
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,active
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels,active
IDE05142-ENG115722-Access control-Elektrische Laderaumabdeckung,not active
IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang,not active
IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein,not active
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,not active
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein,not active
IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung,not active
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren,active
IDE05142-ENG02314-Access control-Heckfreigabe_Ohne_Verzoegerung,not active
IDE05142-ENG02316-Access control-LS_Taster_Togglefunktion,not active
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung,active
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock,adjustable
IDE05142-ENG06090-Access control-Mindestbetaetigung_HDF_Innentaster,0.00 s
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active
IDE05142-ENG115755-Access control-Notschließfunktion,active
IDE05142-ENG02317-Access control-Nutzfahrzeug_Schliessung,not active
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung,active
IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe,not active
IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung,Always
IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden,Always
IDE05142-ENG115758-Access control-Valet Parking,not active
IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe,not active
IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT,not active
IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer,not active
IDE05142-ENG02318-Access control-Wiederverriegelung_Laderaum,Freigabe_Softtouch
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel,active
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen,not active
IDE05142-ENG116623-Access control-ZV Tuerentriegelung,Globale Entriegelung
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash,not active
IDE05143-MAS02985-Writing parameter-Value,130
IDE05143-MAS04381-Writing parameter-Parameter address,FE 00 00
IDE05144-Read parameter address,FE 00 00
IDE05145-ENG115874-Light configuration-BAP Bitposition 0,34
IDE05145-ENG115893-Light configuration-BAP Bitposition 1,3E
IDE05145-ENG116063-Light configuration-BAP Bitposition 10,00
IDE05145-ENG116082-Light configuration-BAP Bitposition 11,00
IDE05145-ENG116101-Light configuration-BAP Bitposition 12,38
IDE05145-ENG116120-Light configuration-BAP Bitposition 13,42
IDE05145-ENG116139-Light configuration-BAP Bitposition 14,00
IDE05145-ENG116158-Light configuration-BAP Bitposition 15,00
IDE05145-ENG116177-Light configuration-BAP Bitposition 16,35
IDE05145-ENG116196-Light configuration-BAP Bitposition 17,3F
IDE05145-ENG116215-Light configuration-BAP Bitposition 18,08
IDE05145-ENG116234-Light configuration-BAP Bitposition 19,18
IDE05145-ENG115911-Light configuration-BAP Bitposition 2,00
IDE05145-ENG116253-Light configuration-BAP Bitposition 20,09
IDE05145-ENG116272-Light configuration-BAP Bitposition 21,19
IDE05145-ENG116291-Light configuration-BAP Bitposition 22,29
IDE05145-ENG116310-Light configuration-BAP Bitposition 23,0A
IDE05145-ENG116329-Light configuration-BAP Bitposition 24,1A
IDE05145-ENG116348-Light configuration-BAP Bitposition 25,28
IDE05145-ENG116367-Light configuration-BAP Bitposition 26,0C
IDE05145-ENG116386-Light configuration-BAP Bitposition 27,1C
IDE05145-ENG116405-Light configuration-BAP Bitposition 28,0B
IDE05145-ENG116424-Light configuration-BAP Bitposition 29,1B
IDE05145-ENG115930-Light configuration-BAP Bitposition 3,00
IDE05145-ENG116443-Light configuration-BAP Bitposition 30,00
IDE05145-ENG116462-Light configuration-BAP Bitposition 31,00
IDE05145-ENG116481-Light configuration-BAP Bitposition 32,00
IDE05145-ENG116500-Light configuration-BAP Bitposition 33,00
IDE05145-ENG116519-Light configuration-BAP Bitposition 34,00
IDE05145-ENG115949-Light configuration-BAP Bitposition 4,3A
IDE05145-ENG115968-Light configuration-BAP Bitposition 5,44
IDE05145-ENG115987-Light configuration-BAP Bitposition 6,36
IDE05145-ENG116006-Light configuration-BAP Bitposition 7,40
IDE05145-ENG116025-Light configuration-BAP Bitposition 8,37
IDE05145-ENG116044-Light configuration-BAP Bitposition 9,41
IDE05145-ENG115883-Light configuration-Dimming Direction CD 0,maximize
IDE05145-ENG115902-Light configuration-Dimming Direction CD 1,maximize
IDE05145-ENG116072-Light configuration-Dimming Direction CD 10,maximize
IDE05145-ENG116091-Light configuration-Dimming Direction CD 11,maximize
IDE05145-ENG116110-Light configuration-Dimming Direction CD 12,maximize
IDE05145-ENG116129-Light configuration-Dimming Direction CD 13,maximize
IDE05145-ENG116148-Light configuration-Dimming Direction CD 14,maximize
IDE05145-ENG116167-Light configuration-Dimming Direction CD 15,maximize
IDE05145-ENG116186-Light configuration-Dimming Direction CD 16,maximize
IDE05145-ENG116205-Light configuration-Dimming Direction CD 17,maximize
IDE05145-ENG116224-Light configuration-Dimming Direction CD 18,maximize
IDE05145-ENG116243-Light configuration-Dimming Direction CD 19,maximize
IDE05145-ENG115920-Light configuration-Dimming Direction CD 2,maximize
IDE05145-ENG116262-Light configuration-Dimming Direction CD 20,maximize
IDE05145-ENG116281-Light configuration-Dimming Direction CD 21,maximize
IDE05145-ENG116300-Light configuration-Dimming Direction CD 22,maximize
IDE05145-ENG116319-Light configuration-Dimming Direction CD 23,maximize
IDE05145-ENG116338-Light configuration-Dimming Direction CD 24,maximize
IDE05145-ENG116357-Light configuration-Dimming Direction CD 25,maximize
IDE05145-ENG116376-Light configuration-Dimming Direction CD 26,maximize
IDE05145-ENG116395-Light configuration-Dimming Direction CD 27,maximize
IDE05145-ENG116414-Light configuration-Dimming Direction CD 28,maximize
IDE05145-ENG116433-Light configuration-Dimming Direction CD 29,maximize
IDE05145-ENG115939-Light configuration-Dimming Direction CD 3,maximize
IDE05145-ENG116452-Light configuration-Dimming Direction CD 30,maximize
IDE05145-ENG116471-Light configuration-Dimming Direction CD 31,maximize
IDE05145-ENG116490-Light configuration-Dimming Direction CD 32,maximize
IDE05145-ENG116509-Light configuration-Dimming Direction CD 33,maximize
IDE05145-ENG116528-Light configuration-Dimming Direction CD 34,maximize
IDE05145-ENG115958-Light configuration-Dimming Direction CD 4,maximize
IDE05145-ENG115977-Light configuration-Dimming Direction CD 5,maximize
IDE05145-ENG115996-Light configuration-Dimming Direction CD 6,maximize
IDE05145-ENG116015-Light configuration-Dimming Direction CD 7,maximize
IDE05145-ENG116034-Light configuration-Dimming Direction CD 8,maximize
IDE05145-ENG116053-Light configuration-Dimming Direction CD 9,maximize
IDE05145-ENG115887-Light configuration-Dimming Direction EF 0,maximize
IDE05145-ENG115906-Light configuration-Dimming Direction EF 1,maximize
IDE05145-ENG116076-Light configuration-Dimming Direction EF 10,maximize
IDE05145-ENG116095-Light configuration-Dimming Direction EF 11,maximize
IDE05145-ENG116114-Light configuration-Dimming Direction EF 12,maximize
IDE05145-ENG116133-Light configuration-Dimming Direction EF 13,maximize
IDE05145-ENG116152-Light configuration-Dimming Direction EF 14,maximize
IDE05145-ENG116171-Light configuration-Dimming Direction EF 15,maximize
IDE05145-ENG116190-Light configuration-Dimming Direction EF 16,maximize
IDE05145-ENG116209-Light configuration-Dimming Direction EF 17,maximize
IDE05145-ENG116228-Light configuration-Dimming Direction EF 18,maximize
IDE05145-ENG116247-Light configuration-Dimming Direction EF 19,maximize
IDE05145-ENG115924-Light configuration-Dimming Direction EF 2,maximize
IDE05145-ENG116266-Light configuration-Dimming Direction EF 20,maximize
IDE05145-ENG116285-Light configuration-Dimming Direction EF 21,maximize
IDE05145-ENG116304-Light configuration-Dimming Direction EF 22,maximize
IDE05145-ENG116323-Light configuration-Dimming Direction EF 23,maximize
IDE05145-ENG116342-Light configuration-Dimming Direction EF 24,maximize
IDE05145-ENG116361-Light configuration-Dimming Direction EF 25,maximize
IDE05145-ENG116380-Light configuration-Dimming Direction EF 26,maximize
IDE05145-ENG116399-Light configuration-Dimming Direction EF 27,maximize
IDE05145-ENG116418-Light configuration-Dimming Direction EF 28,maximize
IDE05145-ENG116437-Light configuration-Dimming Direction EF 29,maximize
IDE05145-ENG115943-Light configuration-Dimming Direction EF 3,maximize
IDE05145-ENG116456-Light configuration-Dimming Direction EF 30,maximize
IDE05145-ENG116475-Light configuration-Dimming Direction EF 31,maximize
IDE05145-ENG116494-Light configuration-Dimming Direction EF 32,maximize
IDE05145-ENG116513-Light configuration-Dimming Direction EF 33,maximize
IDE05145-ENG116532-Light configuration-Dimming Direction EF 34,maximize
IDE05145-ENG115962-Light configuration-Dimming Direction EF 4,maximize
IDE05145-ENG115981-Light configuration-Dimming Direction EF 5,maximize
IDE05145-ENG116000-Light configuration-Dimming Direction EF 6,maximize
IDE05145-ENG116019-Light configuration-Dimming Direction EF 7,maximize
IDE05145-ENG116038-Light configuration-Dimming Direction EF 8,maximize
IDE05145-ENG116057-Light configuration-Dimming Direction EF 9,maximize
IDE05145-ENG115891-Light configuration-Dimming Direction GH 0,maximize
IDE05145-ENG115909-Light configuration-Dimming Direction GH 1,maximize
IDE05145-ENG116080-Light configuration-Dimming Direction GH 10,maximize
IDE05145-ENG116099-Light configuration-Dimming Direction GH 11,maximize
IDE05145-ENG116118-Light configuration-Dimming Direction GH 12,maximize
IDE05145-ENG116137-Light configuration-Dimming Direction GH 13,maximize
IDE05145-ENG116156-Light configuration-Dimming Direction GH 14,maximize
IDE05145-ENG116175-Light configuration-Dimming Direction GH 15,maximize
IDE05145-ENG116194-Light configuration-Dimming Direction GH 16,maximize
IDE05145-ENG116213-Light configuration-Dimming Direction GH 17,maximize
IDE05145-ENG116232-Light configuration-Dimming Direction GH 18,maximize
IDE05145-ENG116251-Light configuration-Dimming Direction GH 19,maximize
IDE05145-ENG115928-Light configuration-Dimming Direction GH 2,maximize
IDE05145-ENG116270-Light configuration-Dimming Direction GH 20,maximize
IDE05145-ENG116289-Light configuration-Dimming Direction GH 21,maximize
IDE05145-ENG116308-Light configuration-Dimming Direction GH 22,maximize
IDE05145-ENG116327-Light configuration-Dimming Direction GH 23,maximize
IDE05145-ENG116346-Light configuration-Dimming Direction GH 24,maximize
IDE05145-ENG116365-Light configuration-Dimming Direction GH 25,maximize
IDE05145-ENG116384-Light configuration-Dimming Direction GH 26,maximize
IDE05145-ENG116403-Light configuration-Dimming Direction GH 27,maximize
IDE05145-ENG116422-Light configuration-Dimming Direction GH 28,maximize
IDE05145-ENG116441-Light configuration-Dimming Direction GH 29,maximize
IDE05145-ENG115947-Light configuration-Dimming Direction GH 3,maximize
IDE05145-ENG116460-Light configuration-Dimming Direction GH 30,maximize
IDE05145-ENG116479-Light configuration-Dimming Direction GH 31,maximize
IDE05145-ENG116498-Light configuration-Dimming Direction GH 32,maximize
IDE05145-ENG116517-Light configuration-Dimming Direction GH 33,maximize
IDE05145-ENG116536-Light configuration-Dimming Direction GH 34,maximize
IDE05145-ENG115966-Light configuration-Dimming Direction GH 4,maximize
IDE05145-ENG115985-Light configuration-Dimming Direction GH 5,maximize
IDE05145-ENG116004-Light configuration-Dimming Direction GH 6,maximize
IDE05145-ENG116023-Light configuration-Dimming Direction GH 7,maximize
IDE05145-ENG116042-Light configuration-Dimming Direction GH 8,maximize
IDE05145-ENG116061-Light configuration-Dimming Direction GH 9,maximize
IDE05145-ENG115878-Light configuration-Dimmwert AB 0,100
IDE05145-ENG115897-Light configuration-Dimmwert AB 1,100
IDE05145-ENG116067-Light configuration-Dimmwert AB 10,0
IDE05145-ENG116086-Light configuration-Dimmwert AB 11,0
IDE05145-ENG116105-Light configuration-Dimmwert AB 12,100
IDE05145-ENG116124-Light configuration-Dimmwert AB 13,100
IDE05145-ENG116143-Light configuration-Dimmwert AB 14,0
IDE05145-ENG116162-Light configuration-Dimmwert AB 15,0
IDE05145-ENG116181-Light configuration-Dimmwert AB 16,0
IDE05145-ENG116200-Light configuration-Dimmwert AB 17,0
IDE05145-ENG116219-Light configuration-Dimmwert AB 18,100
IDE05145-ENG116238-Light configuration-Dimmwert AB 19,100
IDE05145-ENG115915-Light configuration-Dimmwert AB 2,0
IDE05145-ENG116257-Light configuration-Dimmwert AB 20,100
IDE05145-ENG116276-Light configuration-Dimmwert AB 21,100
IDE05145-ENG116295-Light configuration-Dimmwert AB 22,100
IDE05145-ENG116314-Light configuration-Dimmwert AB 23,100
IDE05145-ENG116333-Light configuration-Dimmwert AB 24,100
IDE05145-ENG116352-Light configuration-Dimmwert AB 25,100
IDE05145-ENG116371-Light configuration-Dimmwert AB 26,100
IDE05145-ENG116390-Light configuration-Dimmwert AB 27,0
IDE05145-ENG116409-Light configuration-Dimmwert AB 28,100
IDE05145-ENG116428-Light configuration-Dimmwert AB 29,100
IDE05145-ENG115934-Light configuration-Dimmwert AB 3,0
IDE05145-ENG116447-Light configuration-Dimmwert AB 30,0
IDE05145-ENG116466-Light configuration-Dimmwert AB 31,100
IDE05145-ENG116485-Light configuration-Dimmwert AB 32,100
IDE05145-ENG116504-Light configuration-Dimmwert AB 33,100
IDE05145-ENG116523-Light configuration-Dimmwert AB 34,100
IDE05145-ENG115953-Light configuration-Dimmwert AB 4,30
IDE05145-ENG115972-Light configuration-Dimmwert AB 5,30
IDE05145-ENG115991-Light configuration-Dimmwert AB 6,100
IDE05145-ENG116010-Light configuration-Dimmwert AB 7,100
IDE05145-ENG116029-Light configuration-Dimmwert AB 8,100
IDE05145-ENG116048-Light configuration-Dimmwert AB 9,100
IDE05145-ENG115882-Light configuration-Dimmwert CD 0,0
IDE05145-ENG115901-Light configuration-Dimmwert CD 1,0
IDE05145-ENG116071-Light configuration-Dimmwert CD 10,0
IDE05145-ENG116090-Light configuration-Dimmwert CD 11,0
IDE05145-ENG116109-Light configuration-Dimmwert CD 12,0
IDE05145-ENG116128-Light configuration-Dimmwert CD 13,0
IDE05145-ENG116147-Light configuration-Dimmwert CD 14,0
IDE05145-ENG116166-Light configuration-Dimmwert CD 15,0
IDE05145-ENG116185-Light configuration-Dimmwert CD 16,0
IDE05145-ENG116204-Light configuration-Dimmwert CD 17,0
IDE05145-ENG116223-Light configuration-Dimmwert CD 18,0
IDE05145-ENG116242-Light configuration-Dimmwert CD 19,0
IDE05145-ENG115919-Light configuration-Dimmwert CD 2,0
IDE05145-ENG116261-Light configuration-Dimmwert CD 20,0
IDE05145-ENG116280-Light configuration-Dimmwert CD 21,0
IDE05145-ENG116299-Light configuration-Dimmwert CD 22,0
IDE05145-ENG116318-Light configuration-Dimmwert CD 23,100
IDE05145-ENG116337-Light configuration-Dimmwert CD 24,100
IDE05145-ENG116356-Light configuration-Dimmwert CD 25,0
IDE05145-ENG116375-Light configuration-Dimmwert CD 26,0
IDE05145-ENG116394-Light configuration-Dimmwert CD 27,0
IDE05145-ENG116413-Light configuration-Dimmwert CD 28,0
IDE05145-ENG116432-Light configuration-Dimmwert CD 29,0
IDE05145-ENG115938-Light configuration-Dimmwert CD 3,0
IDE05145-ENG116451-Light configuration-Dimmwert CD 30,0
IDE05145-ENG116470-Light configuration-Dimmwert CD 31,0
IDE05145-ENG116489-Light configuration-Dimmwert CD 32,0
IDE05145-ENG116508-Light configuration-Dimmwert CD 33,0
IDE05145-ENG116527-Light configuration-Dimmwert CD 34,0
IDE05145-ENG115957-Light configuration-Dimmwert CD 4,30
IDE05145-ENG115976-Light configuration-Dimmwert CD 5,30
IDE05145-ENG115995-Light configuration-Dimmwert CD 6,0
IDE05145-ENG116014-Light configuration-Dimmwert CD 7,0
IDE05145-ENG116033-Light configuration-Dimmwert CD 8,0
IDE05145-ENG116052-Light configuration-Dimmwert CD 9,0
IDE05145-ENG115886-Light configuration-Dimmwert EF 0,0
IDE05145-ENG115905-Light configuration-Dimmwert EF 1,0
IDE05145-ENG116075-Light configuration-Dimmwert EF 10,0
IDE05145-ENG116094-Light configuration-Dimmwert EF 11,0
IDE05145-ENG116113-Light configuration-Dimmwert EF 12,0
IDE05145-ENG116132-Light configuration-Dimmwert EF 13,0
IDE05145-ENG116151-Light configuration-Dimmwert EF 14,0
IDE05145-ENG116170-Light configuration-Dimmwert EF 15,0
IDE05145-ENG116189-Light configuration-Dimmwert EF 16,0
IDE05145-ENG116208-Light configuration-Dimmwert EF 17,0
IDE05145-ENG116227-Light configuration-Dimmwert EF 18,0
IDE05145-ENG116246-Light configuration-Dimmwert EF 19,0
IDE05145-ENG115923-Light configuration-Dimmwert EF 2,0
IDE05145-ENG116265-Light configuration-Dimmwert EF 20,0
IDE05145-ENG116284-Light configuration-Dimmwert EF 21,0
IDE05145-ENG116303-Light configuration-Dimmwert EF 22,0
IDE05145-ENG116322-Light configuration-Dimmwert EF 23,0
IDE05145-ENG116341-Light configuration-Dimmwert EF 24,0
IDE05145-ENG116360-Light configuration-Dimmwert EF 25,0
IDE05145-ENG116379-Light configuration-Dimmwert EF 26,0
IDE05145-ENG116398-Light configuration-Dimmwert EF 27,0
IDE05145-ENG116417-Light configuration-Dimmwert EF 28,0
IDE05145-ENG116436-Light configuration-Dimmwert EF 29,0
IDE05145-ENG115942-Light configuration-Dimmwert EF 3,0
IDE05145-ENG116455-Light configuration-Dimmwert EF 30,0
IDE05145-ENG116474-Light configuration-Dimmwert EF 31,0
IDE05145-ENG116493-Light configuration-Dimmwert EF 32,0
IDE05145-ENG116512-Light configuration-Dimmwert EF 33,0
IDE05145-ENG116531-Light configuration-Dimmwert EF 34,0
IDE05145-ENG115961-Light configuration-Dimmwert EF 4,100
IDE05145-ENG115980-Light configuration-Dimmwert EF 5,100
IDE05145-ENG115999-Light configuration-Dimmwert EF 6,0
IDE05145-ENG116018-Light configuration-Dimmwert EF 7,0
IDE05145-ENG116037-Light configuration-Dimmwert EF 8,0
IDE05145-ENG116056-Light configuration-Dimmwert EF 9,0
IDE05145-ENG115890-Light configuration-Dimmwert GH 0,0
IDE05145-ENG115908-Light configuration-Dimmwert GH 1,0
IDE05145-ENG116079-Light configuration-Dimmwert GH 10,0
IDE05145-ENG116098-Light configuration-Dimmwert GH 11,0
IDE05145-ENG116117-Light configuration-Dimmwert GH 12,0
IDE05145-ENG116136-Light configuration-Dimmwert GH 13,0
IDE05145-ENG116155-Light configuration-Dimmwert GH 14,0
IDE05145-ENG116174-Light configuration-Dimmwert GH 15,0
IDE05145-ENG116193-Light configuration-Dimmwert GH 16,0
IDE05145-ENG116212-Light configuration-Dimmwert GH 17,0
IDE05145-ENG116231-Light configuration-Dimmwert GH 18,0
IDE05145-ENG116250-Light configuration-Dimmwert GH 19,0
IDE05145-ENG115927-Light configuration-Dimmwert GH 2,0
IDE05145-ENG116269-Light configuration-Dimmwert GH 20,0
IDE05145-ENG116288-Light configuration-Dimmwert GH 21,0
IDE05145-ENG116307-Light configuration-Dimmwert GH 22,0
IDE05145-ENG116326-Light configuration-Dimmwert GH 23,0
IDE05145-ENG116345-Light configuration-Dimmwert GH 24,0
IDE05145-ENG116364-Light configuration-Dimmwert GH 25,0
IDE05145-ENG116383-Light configuration-Dimmwert GH 26,0
IDE05145-ENG116402-Light configuration-Dimmwert GH 27,0
IDE05145-ENG116421-Light configuration-Dimmwert GH 28,0
IDE05145-ENG116440-Light configuration-Dimmwert GH 29,0
IDE05145-ENG115946-Light configuration-Dimmwert GH 3,0
IDE05145-ENG116459-Light configuration-Dimmwert GH 30,0
IDE05145-ENG116478-Light configuration-Dimmwert GH 31,0
IDE05145-ENG116497-Light configuration-Dimmwert GH 32,0
IDE05145-ENG116516-Light configuration-Dimmwert GH 33,0
IDE05145-ENG116535-Light configuration-Dimmwert GH 34,0
IDE05145-ENG115965-Light configuration-Dimmwert GH 4,0
IDE05145-ENG115984-Light configuration-Dimmwert GH 5,0
IDE05145-ENG116003-Light configuration-Dimmwert GH 6,0
IDE05145-ENG116022-Light configuration-Dimmwert GH 7,0
IDE05145-ENG116041-Light configuration-Dimmwert GH 8,0
IDE05145-ENG116060-Light configuration-Dimmwert GH 9,0
IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0,14
IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1,15
IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10,00
IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11,00
IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12,22
IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13,23
IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14,00
IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15,00
IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16,17
IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17,19
IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18,16
IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19,18
IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2,00
IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20,2B
IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21,2D
IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22,2C
IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23,29
IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24,2A
IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25,30
IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26,2E
IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27,2F
IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28,31
IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29,32
IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3,00
IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30,00
IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31,03
IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32,04
IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33,05
IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34,06
IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4,43
IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5,44
IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6,1A
IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7,1B
IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8,1C
IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9,1D
IDE05145-ENG115873-Light configuration-Lasttyp 0,12 - Blinkleuchten
IDE05145-ENG115892-Light configuration-Lasttyp 1,12 - Blinkleuchten
IDE05145-ENG116062-Light configuration-Lasttyp 10,not active
IDE05145-ENG116081-Light configuration-Lasttyp 11,not active
IDE05145-ENG116100-Light configuration-Lasttyp 12,10 - allgemeine Scheinwerfer
IDE05145-ENG116119-Light configuration-Lasttyp 13,10 - allgemeine Scheinwerfer
IDE05145-ENG116138-Light configuration-Lasttyp 14,not active
IDE05145-ENG116157-Light configuration-Lasttyp 15,not active
IDE05145-ENG116176-Light configuration-Lasttyp 16,not active
IDE05145-ENG116195-Light configuration-Lasttyp 17,not active
IDE05145-ENG116214-Light configuration-Lasttyp 18,12 - Blinkleuchten
IDE05145-ENG116233-Light configuration-Lasttyp 19,12 - Blinkleuchten
IDE05145-ENG115910-Light configuration-Lasttyp 2,not active
IDE05145-ENG116252-Light configuration-Lasttyp 20,34 - LED Bremsleuchten
IDE05145-ENG116271-Light configuration-Lasttyp 21,34 - LED Bremsleuchten
IDE05145-ENG116290-Light configuration-Lasttyp 22,34 - LED Bremsleuchten
IDE05145-ENG116309-Light configuration-Lasttyp 23,32 - allgemeine LED bis 12W
IDE05145-ENG116328-Light configuration-Lasttyp 24,32 - allgemeine LED bis 12W
IDE05145-ENG116347-Light configuration-Lasttyp 25,18 - 2* 5W
IDE05145-ENG116366-Light configuration-Lasttyp 26,9 - allgemeine Glühlampe 27W: auch H15
IDE05145-ENG116385-Light configuration-Lasttyp 27,9 - allgemeine Glühlampe 27W: auch H15
IDE05145-ENG116404-Light configuration-Lasttyp 28,9 - allgemeine Glühlampe 27W: auch H15
IDE05145-ENG116423-Light configuration-Lasttyp 29,9 - allgemeine Glühlampe 27W: auch H15
IDE05145-ENG115929-Light configuration-Lasttyp 3,not active
IDE05145-ENG116442-Light configuration-Lasttyp 30,not active
IDE05145-ENG116461-Light configuration-Lasttyp 31,not active
IDE05145-ENG116480-Light configuration-Lasttyp 32,not active
IDE05145-ENG116499-Light configuration-Lasttyp 33,not active
IDE05145-ENG116518-Light configuration-Lasttyp 34,not active
IDE05145-ENG115948-Light configuration-Lasttyp 4,9 - allgemeine Glühlampe 27W: auch H15
IDE05145-ENG115967-Light configuration-Lasttyp 5,9 - allgemeine Glühlampe 27W: auch H15
IDE05145-ENG115986-Light configuration-Lasttyp 6,11 - Abblendlicht
IDE05145-ENG116005-Light configuration-Lasttyp 7,11 - Abblendlicht
IDE05145-ENG116024-Light configuration-Lasttyp 8,10 - allgemeine Scheinwerfer
IDE05145-ENG116043-Light configuration-Lasttyp 9,10 - allgemeine Scheinwerfer
IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0,Always
IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1,Always
IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10,Always
IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11,Always
IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12,Always
IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13,Always
IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14,Always
IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15,Always
IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16,Always
IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17,Always
IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18,Always
IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19,Always
IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2,Always
IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20,Always
IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21,Always
IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22,Always
IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23,Always
IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24,Always
IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25,Always
IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26,Always
IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27,Always
IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28,Always
IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29,Always
IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3,Always
IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30,Always
IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31,Always
IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32,Always
IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33,Always
IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34,Always
IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4,Always
IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5,Always
IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6,Always
IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7,Always
IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8,Always
IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9,Always
IDE05145-ENG116199-Light configuration-Lichtfunktion B 17,0
IDE05145-ENG116126-Light configuration-Lichtfunktion C 13,0
IDE05145-ENG115876-Light configuration-Lichtfunktion A 0,2
IDE05145-ENG115895-Light configuration-Lichtfunktion A 1,4
IDE05145-ENG116065-Light configuration-Lichtfunktion A 10,0
IDE05145-ENG116084-Light configuration-Lichtfunktion A 11,0
IDE05145-ENG116103-Light configuration-Lichtfunktion A 12,18
IDE05145-ENG116122-Light configuration-Lichtfunktion A 13,19
IDE05145-ENG116141-Light configuration-Lichtfunktion A 14,0
IDE05145-ENG116160-Light configuration-Lichtfunktion A 15,0
IDE05145-ENG116179-Light configuration-Lichtfunktion A 16,0
IDE05145-ENG116198-Light configuration-Lichtfunktion A 17,0
IDE05145-ENG116217-Light configuration-Lichtfunktion A 18,2
IDE05145-ENG116236-Light configuration-Lichtfunktion A 19,4
IDE05145-ENG115913-Light configuration-Lichtfunktion A 2,0
IDE05145-ENG116255-Light configuration-Lichtfunktion A 20,24
IDE05145-ENG116274-Light configuration-Lichtfunktion A 21,24
IDE05145-ENG116293-Light configuration-Lichtfunktion A 22,24
IDE05145-ENG116312-Light configuration-Lichtfunktion A 23,8
IDE05145-ENG116331-Light configuration-Lichtfunktion A 24,8
IDE05145-ENG116350-Light configuration-Lichtfunktion A 25,8
IDE05145-ENG116369-Light configuration-Lichtfunktion A 26,26
IDE05145-ENG116388-Light configuration-Lichtfunktion A 27,0
IDE05145-ENG116407-Light configuration-Lichtfunktion A 28,25
IDE05145-ENG116426-Light configuration-Lichtfunktion A 29,25
IDE05145-ENG115932-Light configuration-Lichtfunktion A 3,0
IDE05145-ENG116445-Light configuration-Lichtfunktion A 30,0
IDE05145-ENG116464-Light configuration-Lichtfunktion A 31,45
IDE05145-ENG116483-Light configuration-Lichtfunktion A 32,46
IDE05145-ENG116502-Light configuration-Lichtfunktion A 33,47
IDE05145-ENG116521-Light configuration-Lichtfunktion A 34,48
IDE05145-ENG115951-Light configuration-Lichtfunktion A 4,8
IDE05145-ENG115970-Light configuration-Lichtfunktion A 5,8
IDE05145-ENG115989-Light configuration-Lichtfunktion A 6,11
IDE05145-ENG116008-Light configuration-Lichtfunktion A 7,12
IDE05145-ENG116027-Light configuration-Lichtfunktion A 8,13
IDE05145-ENG116046-Light configuration-Lichtfunktion A 9,14
IDE05145-ENG115877-Light configuration-Lichtfunktion B 0,0
IDE05145-ENG115896-Light configuration-Lichtfunktion B 1,0
IDE05145-ENG116066-Light configuration-Lichtfunktion B 10,0
IDE05145-ENG116085-Light configuration-Lichtfunktion B 11,0
IDE05145-ENG116104-Light configuration-Lichtfunktion B 12,0
IDE05145-ENG116123-Light configuration-Lichtfunktion B 13,0
IDE05145-ENG116142-Light configuration-Lichtfunktion B 14,0
IDE05145-ENG116161-Light configuration-Lichtfunktion B 15,0
IDE05145-ENG116180-Light configuration-Lichtfunktion B 16,0
IDE05145-ENG116218-Light configuration-Lichtfunktion B 18,0
IDE05145-ENG116237-Light configuration-Lichtfunktion B 19,0
IDE05145-ENG115914-Light configuration-Lichtfunktion B 2,0
IDE05145-ENG116256-Light configuration-Lichtfunktion B 20,0
IDE05145-ENG116275-Light configuration-Lichtfunktion B 21,0
IDE05145-ENG116294-Light configuration-Lichtfunktion B 22,0
IDE05145-ENG116313-Light configuration-Lichtfunktion B 23,9
IDE05145-ENG116332-Light configuration-Lichtfunktion B 24,10
IDE05145-ENG116351-Light configuration-Lichtfunktion B 25,30
IDE05145-ENG116370-Light configuration-Lichtfunktion B 26,0
IDE05145-ENG116389-Light configuration-Lichtfunktion B 27,0
IDE05145-ENG116408-Light configuration-Lichtfunktion B 28,0
IDE05145-ENG116427-Light configuration-Lichtfunktion B 29,0
IDE05145-ENG115933-Light configuration-Lichtfunktion B 3,0
IDE05145-ENG116446-Light configuration-Lichtfunktion B 30,0
IDE05145-ENG116465-Light configuration-Lichtfunktion B 31,0
IDE05145-ENG116484-Light configuration-Lichtfunktion B 32,0
IDE05145-ENG116503-Light configuration-Lichtfunktion B 33,0
IDE05145-ENG116522-Light configuration-Lichtfunktion B 34,0
IDE05145-ENG115952-Light configuration-Lichtfunktion B 4,9
IDE05145-ENG115971-Light configuration-Lichtfunktion B 5,10
IDE05145-ENG115990-Light configuration-Lichtfunktion B 6,30
IDE05145-ENG116009-Light configuration-Lichtfunktion B 7,30
IDE05145-ENG116028-Light configuration-Lichtfunktion B 8,15
IDE05145-ENG116047-Light configuration-Lichtfunktion B 9,15
IDE05145-ENG115880-Light configuration-Lichtfunktion C 0,0
IDE05145-ENG115899-Light configuration-Lichtfunktion C 1,0
IDE05145-ENG116069-Light configuration-Lichtfunktion C 10,0
IDE05145-ENG116088-Light configuration-Lichtfunktion C 11,0
IDE05145-ENG116107-Light configuration-Lichtfunktion C 12,0
IDE05145-ENG116145-Light configuration-Lichtfunktion C 14,0
IDE05145-ENG116164-Light configuration-Lichtfunktion C 15,0
IDE05145-ENG116183-Light configuration-Lichtfunktion C 16,0
IDE05145-ENG116202-Light configuration-Lichtfunktion C 17,0
IDE05145-ENG116221-Light configuration-Lichtfunktion C 18,0
IDE05145-ENG116240-Light configuration-Lichtfunktion C 19,0
IDE05145-ENG115917-Light configuration-Lichtfunktion C 2,0
IDE05145-ENG116259-Light configuration-Lichtfunktion C 20,0
IDE05145-ENG116278-Light configuration-Lichtfunktion C 21,0
IDE05145-ENG116297-Light configuration-Lichtfunktion C 22,0
IDE05145-ENG116316-Light configuration-Lichtfunktion C 23,30
IDE05145-ENG116335-Light configuration-Lichtfunktion C 24,30
IDE05145-ENG116354-Light configuration-Lichtfunktion C 25,0
IDE05145-ENG116373-Light configuration-Lichtfunktion C 26,0
IDE05145-ENG116392-Light configuration-Lichtfunktion C 27,0
IDE05145-ENG116411-Light configuration-Lichtfunktion C 28,0
IDE05145-ENG116429-Light configuration-Lichtfunktion C 29,0
IDE05145-ENG115936-Light configuration-Lichtfunktion C 3,0
IDE05145-ENG116449-Light configuration-Lichtfunktion C 30,0
IDE05145-ENG116468-Light configuration-Lichtfunktion C 31,0
IDE05145-ENG116487-Light configuration-Lichtfunktion C 32,0
IDE05145-ENG116506-Light configuration-Lichtfunktion C 33,0
IDE05145-ENG116525-Light configuration-Lichtfunktion C 34,0
IDE05145-ENG115955-Light configuration-Lichtfunktion C 4,30
IDE05145-ENG115974-Light configuration-Lichtfunktion C 5,30
IDE05145-ENG115993-Light configuration-Lichtfunktion C 6,0
IDE05145-ENG116012-Light configuration-Lichtfunktion C 7,0
IDE05145-ENG116031-Light configuration-Lichtfunktion C 8,0
IDE05145-ENG116050-Light configuration-Lichtfunktion C 9,0
IDE05145-ENG115881-Light configuration-Lichtfunktion D 0,0
IDE05145-ENG115900-Light configuration-Lichtfunktion D 1,0
IDE05145-ENG116070-Light configuration-Lichtfunktion D 10,0
IDE05145-ENG116089-Light configuration-Lichtfunktion D 11,0
IDE05145-ENG116108-Light configuration-Lichtfunktion D 12,0
IDE05145-ENG116127-Light configuration-Lichtfunktion D 13,0
IDE05145-ENG116146-Light configuration-Lichtfunktion D 14,0
IDE05145-ENG116165-Light configuration-Lichtfunktion D 15,0
IDE05145-ENG116184-Light configuration-Lichtfunktion D 16,0
IDE05145-ENG116203-Light configuration-Lichtfunktion D 17,0
IDE05145-ENG116222-Light configuration-Lichtfunktion D 18,0
IDE05145-ENG116241-Light configuration-Lichtfunktion D 19,0
IDE05145-ENG115918-Light configuration-Lichtfunktion D 2,0
IDE05145-ENG116260-Light configuration-Lichtfunktion D 20,0
IDE05145-ENG116279-Light configuration-Lichtfunktion D 21,0
IDE05145-ENG116298-Light configuration-Lichtfunktion D 22,0
IDE05145-ENG116317-Light configuration-Lichtfunktion D 23,0
IDE05145-ENG116336-Light configuration-Lichtfunktion D 24,0
IDE05145-ENG116355-Light configuration-Lichtfunktion D 25,0
IDE05145-ENG116374-Light configuration-Lichtfunktion D 26,0
IDE05145-ENG116393-Light configuration-Lichtfunktion D 27,0
IDE05145-ENG116412-Light configuration-Lichtfunktion D 28,0
IDE05145-ENG116431-Light configuration-Lichtfunktion D 29,0
IDE05145-ENG115937-Light configuration-Lichtfunktion D 3,0
IDE05145-ENG116450-Light configuration-Lichtfunktion D 30,0
IDE05145-ENG116469-Light configuration-Lichtfunktion D 31,0
IDE05145-ENG116488-Light configuration-Lichtfunktion D 32,0
IDE05145-ENG116507-Light configuration-Lichtfunktion D 33,0
IDE05145-ENG116526-Light configuration-Lichtfunktion D 34,0
IDE05145-ENG115956-Light configuration-Lichtfunktion D 4,0
IDE05145-ENG115975-Light configuration-Lichtfunktion D 5,0
IDE05145-ENG115994-Light configuration-Lichtfunktion D 6,0
IDE05145-ENG116013-Light configuration-Lichtfunktion D 7,0
IDE05145-ENG116032-Light configuration-Lichtfunktion D 8,0
IDE05145-ENG116051-Light configuration-Lichtfunktion D 9,0
IDE05145-ENG115884-Light configuration-Lichtfunktion E 0,0
IDE05145-ENG115903-Light configuration-Lichtfunktion E 1,0
IDE05145-ENG116073-Light configuration-Lichtfunktion E 10,0
IDE05145-ENG116092-Light configuration-Lichtfunktion E 11,0
IDE05145-ENG116111-Light configuration-Lichtfunktion E 12,0
IDE05145-ENG116130-Light configuration-Lichtfunktion E 13,0
IDE05145-ENG116149-Light configuration-Lichtfunktion E 14,0
IDE05145-ENG116168-Light configuration-Lichtfunktion E 15,0
IDE05145-ENG116187-Light configuration-Lichtfunktion E 16,0
IDE05145-ENG116206-Light configuration-Lichtfunktion E 17,0
IDE05145-ENG116225-Light configuration-Lichtfunktion E 18,0
IDE05145-ENG116244-Light configuration-Lichtfunktion E 19,0
IDE05145-ENG115921-Light configuration-Lichtfunktion E 2,0
IDE05145-ENG116263-Light configuration-Lichtfunktion E 20,30
IDE05145-ENG116282-Light configuration-Lichtfunktion E 21,30
IDE05145-ENG116301-Light configuration-Lichtfunktion E 22,0
IDE05145-ENG116320-Light configuration-Lichtfunktion E 23,0
IDE05145-ENG116339-Light configuration-Lichtfunktion E 24,0
IDE05145-ENG116358-Light configuration-Lichtfunktion E 25,0
IDE05145-ENG116377-Light configuration-Lichtfunktion E 26,0
IDE05145-ENG116396-Light configuration-Lichtfunktion E 27,0
IDE05145-ENG116415-Light configuration-Lichtfunktion E 28,0
IDE05145-ENG116434-Light configuration-Lichtfunktion E 29,0
IDE05145-ENG115940-Light configuration-Lichtfunktion E 3,0
IDE05145-ENG116453-Light configuration-Lichtfunktion E 30,0
IDE05145-ENG116472-Light configuration-Lichtfunktion E 31,0
IDE05145-ENG116491-Light configuration-Lichtfunktion E 32,0
IDE05145-ENG116510-Light configuration-Lichtfunktion E 33,0
IDE05145-ENG116529-Light configuration-Lichtfunktion E 34,0
IDE05145-ENG115959-Light configuration-Lichtfunktion E 4,20
IDE05145-ENG115978-Light configuration-Lichtfunktion E 5,20
IDE05145-ENG115997-Light configuration-Lichtfunktion E 6,0
IDE05145-ENG116016-Light configuration-Lichtfunktion E 7,0
IDE05145-ENG116035-Light configuration-Lichtfunktion E 8,0
IDE05145-ENG116054-Light configuration-Lichtfunktion E 9,0
IDE05145-ENG115885-Light configuration-Lichtfunktion F 0,0
IDE05145-ENG115904-Light configuration-Lichtfunktion F 1,0
IDE05145-ENG116074-Light configuration-Lichtfunktion F 10,0
IDE05145-ENG116093-Light configuration-Lichtfunktion F 11,0
IDE05145-ENG116112-Light configuration-Lichtfunktion F 12,0
IDE05145-ENG116131-Light configuration-Lichtfunktion F 13,0
IDE05145-ENG116150-Light configuration-Lichtfunktion F 14,0
IDE05145-ENG116169-Light configuration-Lichtfunktion F 15,0
IDE05145-ENG116188-Light configuration-Lichtfunktion F 16,0
IDE05145-ENG116207-Light configuration-Lichtfunktion F 17,0
IDE05145-ENG116226-Light configuration-Lichtfunktion F 18,0
IDE05145-ENG116245-Light configuration-Lichtfunktion F 19,0
IDE05145-ENG115922-Light configuration-Lichtfunktion F 2,0
IDE05145-ENG116264-Light configuration-Lichtfunktion F 20,0
IDE05145-ENG116283-Light configuration-Lichtfunktion F 21,0
IDE05145-ENG116302-Light configuration-Lichtfunktion F 22,0
IDE05145-ENG116321-Light configuration-Lichtfunktion F 23,0
IDE05145-ENG116340-Light configuration-Lichtfunktion F 24,0
IDE05145-ENG116359-Light configuration-Lichtfunktion F 25,0
IDE05145-ENG116378-Light configuration-Lichtfunktion F 26,0
IDE05145-ENG116397-Light configuration-Lichtfunktion F 27,0
IDE05145-ENG116416-Light configuration-Lichtfunktion F 28,0
IDE05145-ENG116435-Light configuration-Lichtfunktion F 29,0
IDE05145-ENG116454-Light configuration-Lichtfunktion F 30,0
IDE05145-ENG116473-Light configuration-Lichtfunktion F 31,0
IDE05145-ENG116492-Light configuration-Lichtfunktion F 32,0
IDE05145-ENG116511-Light configuration-Lichtfunktion F 33,0
IDE05145-ENG116530-Light configuration-Lichtfunktion F 34,0
IDE05145-ENG115960-Light configuration-Lichtfunktion F 4,0
IDE05145-ENG115998-Light configuration-Lichtfunktion F 6,0
IDE05145-ENG116017-Light configuration-Lichtfunktion F 7,0
IDE05145-ENG116036-Light configuration-Lichtfunktion F 8,0
IDE05145-ENG116055-Light configuration-Lichtfunktion F 9,0
IDE05145-ENG115941-Light configuration-Lichtfunktion F3,0
IDE05145-ENG115979-Light configuration-Lichtfunktion F5,0
IDE05145-ENG115888-Light configuration-Lichtfunktion G 0,0
IDE05145-ENG115907-Light configuration-Lichtfunktion G 1,0
IDE05145-ENG116077-Light configuration-Lichtfunktion G 10,0
IDE05145-ENG116096-Light configuration-Lichtfunktion G 11,0
IDE05145-ENG116115-Light configuration-Lichtfunktion G 12,0
IDE05145-ENG116134-Light configuration-Lichtfunktion G 13,0
IDE05145-ENG116153-Light configuration-Lichtfunktion G 14,0
IDE05145-ENG116172-Light configuration-Lichtfunktion G 15,0
IDE05145-ENG116191-Light configuration-Lichtfunktion G 16,0
IDE05145-ENG116210-Light configuration-Lichtfunktion G 17,0
IDE05145-ENG116229-Light configuration-Lichtfunktion G 18,0
IDE05145-ENG116248-Light configuration-Lichtfunktion G 19,0
IDE05145-ENG115925-Light configuration-Lichtfunktion G 2,0
IDE05145-ENG116267-Light configuration-Lichtfunktion G 20,0
IDE05145-ENG116286-Light configuration-Lichtfunktion G 21,0
IDE05145-ENG116305-Light configuration-Lichtfunktion G 22,0
IDE05145-ENG116324-Light configuration-Lichtfunktion G 23,0
IDE05145-ENG116343-Light configuration-Lichtfunktion G 24,0
IDE05145-ENG116362-Light configuration-Lichtfunktion G 25,0
IDE05145-ENG116381-Light configuration-Lichtfunktion G 26,0
IDE05145-ENG116400-Light configuration-Lichtfunktion G 27,0
IDE05145-ENG116419-Light configuration-Lichtfunktion G 28,0
IDE05145-ENG116438-Light configuration-Lichtfunktion G 29,0
IDE05145-ENG115944-Light configuration-Lichtfunktion G 3,0
IDE05145-ENG116457-Light configuration-Lichtfunktion G 30,0
IDE05145-ENG116476-Light configuration-Lichtfunktion G 31,0
IDE05145-ENG116495-Light configuration-Lichtfunktion G 32,0
IDE05145-ENG116514-Light configuration-Lichtfunktion G 33,0
IDE05145-ENG116533-Light configuration-Lichtfunktion G 34,0
IDE05145-ENG115963-Light configuration-Lichtfunktion G 4,0
IDE05145-ENG115982-Light configuration-Lichtfunktion G 5,0
IDE05145-ENG116001-Light configuration-Lichtfunktion G 6,0
IDE05145-ENG116020-Light configuration-Lichtfunktion G 7,0
IDE05145-ENG116039-Light configuration-Lichtfunktion G 8,0
IDE05145-ENG116058-Light configuration-Lichtfunktion G 9,0
IDE05145-ENG115889-Light configuration-Lichtfunktion H 0,0
IDE05145-ENG116549-Light configuration-Lichtfunktion H 1,0
IDE05145-ENG116078-Light configuration-Lichtfunktion H 10,0
IDE05145-ENG116097-Light configuration-Lichtfunktion H 11,0
IDE05145-ENG116116-Light configuration-Lichtfunktion H 12,0
IDE05145-ENG116135-Light configuration-Lichtfunktion H 13,0
IDE05145-ENG116154-Light configuration-Lichtfunktion H 14,0
IDE05145-ENG116173-Light configuration-Lichtfunktion H 15,0
IDE05145-ENG116192-Light configuration-Lichtfunktion H 16,0
IDE05145-ENG116211-Light configuration-Lichtfunktion H 17,0
IDE05145-ENG116230-Light configuration-Lichtfunktion H 18,0
IDE05145-ENG116249-Light configuration-Lichtfunktion H 19,0
IDE05145-ENG115926-Light configuration-Lichtfunktion H 2,0
IDE05145-ENG116268-Light configuration-Lichtfunktion H 20,0
IDE05145-ENG116287-Light configuration-Lichtfunktion H 21,0
IDE05145-ENG116306-Light configuration-Lichtfunktion H 22,0
IDE05145-ENG116325-Light configuration-Lichtfunktion H 23,0
IDE05145-ENG116344-Light configuration-Lichtfunktion H 24,0
IDE05145-ENG116363-Light configuration-Lichtfunktion H 25,0
IDE05145-ENG116382-Light configuration-Lichtfunktion H 26,0
IDE05145-ENG116401-Light configuration-Lichtfunktion H 27,0
IDE05145-ENG116420-Light configuration-Lichtfunktion H 28,0
IDE05145-ENG116439-Light configuration-Lichtfunktion H 29,0
IDE05145-ENG115945-Light configuration-Lichtfunktion H 3,0
IDE05145-ENG116458-Light configuration-Lichtfunktion H 30,0
IDE05145-ENG116477-Light configuration-Lichtfunktion H 31,0
IDE05145-ENG116496-Light configuration-Lichtfunktion H 32,0
IDE05145-ENG116515-Light configuration-Lichtfunktion H 33,0
IDE05145-ENG116534-Light configuration-Lichtfunktion H 34,0
IDE05145-ENG115964-Light configuration-Lichtfunktion H 4,0
IDE05145-ENG115983-Light configuration-Lichtfunktion H 5,0
IDE05145-ENG116002-Light configuration-Lichtfunktion H 6,0
IDE05145-ENG116021-Light configuration-Lichtfunktion H 7,0
IDE05145-ENG116040-Light configuration-Lichtfunktion H 8,0
IDE05145-ENG116059-Light configuration-Lichtfunktion H 9,0
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,30 s
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,1.10 °C
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,33.00 °C
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,32.00 °C
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,33.00 °C
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,32.00 °C
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,37.50 °C
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,36.50 °C
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,37.50 °C
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,36.50 °C
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,41.00 °C
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,40.00 °C
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,41.00 °C
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,40.00 °C
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten,active
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM,not active
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe,not active
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten,not active
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung,active
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert,60 %
IDE06425-Roller test bench mode: functional,not active
IDE06507-MAS13125-Button in center console-Funktion Taster 1,Start-stop
IDE06507-MAS13129-Button in center console-Funktion Taster 2,Laderaumschließung
IDE06507-MAS13132-Button in center console-Funktion Taster 3,Driving program
IDE06507-MAS13135-Button in center console-Funktion Taster 4,Steering wheel heater
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag,Daytime running lights
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht,not active
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,active
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte,not active
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active
IDE07356-Position during interval mode,25.51 °
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten nach der Nachlaufzeit
IDE07470-ENG02309-After-run for park light-Bedingungen zur Parklichtbegrenzung,abschaltbar über Energiemanagement
IDE07470-ENG02308-After-run for park light-Bedingungen zur Standlichtbegrenzung,abschaltbar über Energiemanagement
IDE07470-ENG02310-After-run for park light-Faktor fuer Verfügbarkeitstimer,Faktor fuer x5 Minuten
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min
IDE07470-ENG02311-After-run for park light-Standlicht-Verfügbarkeit,24 s
IDE08542-IDE02021-Access control 2-Comfort closing,active
IDE08542-IDE02022-Access control 2-Comfort opening,active
IDE08542-ENG128459-Access control 2-easycloselight_aktiv,not active
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen,active
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen,active
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit,600 s
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus,active
IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen,active
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen,active
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen,active
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen,active
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus,by look command via remote control key
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen,not active
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen,active
IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung,not active
IDE08542-ENG115670-Access control 2-Komfortbedienung global,active
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer,not active
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen,active
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar,adjustable
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen,not active
IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung,not active
IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung,active
IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf,not active
IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel,not active
IDE08542-ENG125656-Access control 2-Regenschliessen_art,once
IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus,not active
IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock,not_active
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen,not active
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen,not active
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen,not active
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen,tilting
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen,active
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen,active
IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung,active
IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt,not active
IDE08542-ENG02339-Access control 2-Spiegelanklappen_bei_Wiederverriegelung,active
IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron,active
IDE08542-ENG115869-Access control 2-Virtuelles_Pedal,not active
IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar,not active
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,2000 ms
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen,active
IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach,not active
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig,kein_Hinweis
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset,active
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert,0 ms
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit,normal
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,not active
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,Not Present
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung,Not Present
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA,active
IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte,not active
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben,active
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15,active
IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active
IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken,not active
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing,not active
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken,not active
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung,not active
IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken,not active
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken,not active
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2,not active
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing,not active
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links,not active
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts,not active
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken,not active
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing,not active
IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,not active
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken,not active
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS,not active
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN,not active
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf,not active
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu,not active
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.25 s
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,2
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,3
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,1
IDE09731-ENG126827-Int. light: 2nd generation-Blauwert Farbe 1,225
IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2,225
IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3,225
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig,not active
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig,not active
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,80 %
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,2
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,80 %
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen,active
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen,active
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,active
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen,active
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen,active
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen,active
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,not active
IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1,225
IDE09731-ENG126829-Int. light: 2nd generation-Gruenwert Farbe 2,225
IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3,225
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,not active
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,active
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,not active
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen,not active
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen,active
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,active
IDE09731-ENG126824-Int. light: 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen,not active
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig,not active
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig,not active
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig,not active
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren,not active
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig,not active
IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1,225
IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2,225
IDE09731-ENG126831-Int. light: 2nd generation-Rotwert Farbe 3,225
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,active
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,not active
IDE09732-ENG02312-Interior light: light configuration-Ambient_Farbliste_HMI,not active
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,not installed
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,not installed
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher,not installed
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,not active
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,not active
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung,not installed
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung,not installed
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil,not installed
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI,not installed
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,not installed
IDE09732-ENG02313-Interior light: light configuration-Frei_Farbwahl_ueber_HMI,not active
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar,not active
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung,not installed
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung,not installed
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,30 %
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,25 %
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,30 %
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,25 %
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,58 %
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,53 %
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,58 %
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,53 %
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,85 %
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,80 %
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,85 %
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,80 %
IDE10298-Alternating park position 1,8.51 °
IDE10299-Alternating park position 2,22.51 °
IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit,64
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach,64
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum,64
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel,64
IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher,64
IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko,64
IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd,64
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer,64
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI,00
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2,00
IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3,00
IDE11477-ENG128662-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_4,00
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI,00
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2,00
IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3,00
IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4,00
IDE11477-ENG128652-Interior lighting: parameter-p_dimmfaktor_farbwechsel_ab,01
IDE11477-ENG128651-Interior lighting: parameter-p_dimmfaktor_farbwechsel_auf,01
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI,00
IDE11477-ENG128653-Interior lighting: parameter-p_farbwechsel_delay,00
IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit,100 %
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach,100 %
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum,100 %
IDE11477-ENG128516-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht,100 %
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel,100 %
IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher,100 %
IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko,100 %
IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd,100 %
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren,100 %
IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit,100 %
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach,100 %
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum,100 %
IDE11477-ENG128513-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht,100 %
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel,100 %
IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher,100 %
IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko,100 %
IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd,100 %
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren,100 %
IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit,100 %
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach,100 %
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum,100 %
IDE11477-ENG128515-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht,100 %
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel,100 %
IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher,100 %
IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko,100 %
IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd,100 %
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren,100 %
IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit,100 %
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach,100 %
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum,100 %
IDE11477-ENG128512-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht,100 %
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel,100 %
IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher,100 %
IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko,100 %
IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd,100 %
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren,100 %
IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit,100 %
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach,100 %
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum,100 %
IDE11477-ENG128517-Interior lighting: parameter-p_helligkeit_einausstieg_innenlicht,100 %
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel,100 %
IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher,100 %
IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko,100 %
IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd,100 %
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren,100 %
IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit,100 %
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach,100 %
IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum,100 %
IDE11477-ENG128508-Interior lighting: parameter-p_helligkeit_entriegelt_innenlicht,100 %
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel,100 %
IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher,100 %
IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko,100 %
IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd,100 %
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren,100 %
IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit,100 %
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach,100 %
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,100 %
IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht,100 %
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel,100 %
IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher,100 %
IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko,100 %
IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd,100 %
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,100 %
IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit,100 %
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach,100 %
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum,127 %
IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht,100 %
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel,100 %
IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher,100 %
IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko,100 %
IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd,100 %
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren,100 %
IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit,126 %
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach,126 %
IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum,126 %
IDE11477-ENG128514-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht,0 %
IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel,126 %
IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher,126 %
IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko,126 %
IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd,126 %
IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren,126 %
IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit,100 %
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach,100 %
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum,127 %
IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht,100 %
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel,100 %
IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher,100 %
IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko,100 %
IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd,100 %
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren,100 %
IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit,100 %
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach,100 %
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,126 %
IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht,100 %
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel,100 %
IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher,100 %
IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko,100 %
IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd,100 %
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,100 %
IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit,100 %
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach,100 %
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum,100 %
IDE11477-ENG128509-Interior lighting: parameter-p_helligkeit_max_innenlicht,100 %
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel,100 %
IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher,100 %
IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko,100 %
IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd,100 %
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren,100 %
IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit,100 %
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach,100 %
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,127 %
IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht,100 %
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel,100 %
IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher,100 %
IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko,100 %
IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd,100 %
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,100 %
IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit,100 %
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach,100 %
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,127 %
IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht,100 %
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel,100 %
IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher,100 %
IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko,100 %
IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd,100 %
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,100 %
IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit,100 %
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach,100 %
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,100 %
IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht,100 %
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel,100 %
IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher,100 %
IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko,100 %
IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd,100 %
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,100 %
IDE11477-ENG06093-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte,100 ms
IDE11477-ENG128488-Interior lighting: parameter-p_t_verzoegerung_ausstieg_cockpit,0 s
IDE11477-ENG128502-Interior lighting: parameter-p_t_verzoegerung_ausstieg_dach,0 s
IDE11477-ENG128481-Interior lighting: parameter-p_t_verzoegerung_ausstieg_fussraum,0 s
IDE11477-ENG128467-Interior lighting: parameter-p_t_verzoegerung_ausstieg_innenlicht,0 s
IDE11477-ENG128495-Interior lighting: parameter-p_t_verzoegerung_ausstieg_miko,0 s
IDE11477-ENG128474-Interior lighting: parameter-p_t_verzoegerung_ausstieg_tueren,0 s
IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit,0 s
IDE11477-ENG128501-Interior lighting: parameter-p_t_verzoegerung_einstieg_dach,0 s
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum,20 s
IDE11477-ENG128466-Interior lighting: parameter-p_t_verzoegerung_einstieg_innenlicht,0 s
IDE11477-ENG128494-Interior lighting: parameter-p_t_verzoegerung_einstieg_miko,0 s
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren,0 s
IDE11477-ENG128490-Interior lighting: parameter-p_t_verzoegerung_entriegelt_cockpit,0 s
IDE11477-ENG128504-Interior lighting: parameter-p_t_verzoegerung_entriegelt_dach,0 s
IDE11477-ENG128483-Interior lighting: parameter-p_t_verzoegerung_entriegelt_fussraum,0 s
IDE11477-ENG128469-Interior lighting: parameter-p_t_verzoegerung_entriegelt_innenlicht,0 s
IDE11477-ENG128497-Interior lighting: parameter-p_t_verzoegerung_entriegelt_miko,0 s
IDE11477-ENG128476-Interior lighting: parameter-p_t_verzoegerung_entriegelt_tueren,0 s
IDE11477-ENG128489-Interior lighting: parameter-p_t_verzoegerung_oeffnen_cockpit,0 s
IDE11477-ENG128503-Interior lighting: parameter-p_t_verzoegerung_oeffnen_dach,0 s
IDE11477-ENG128482-Interior lighting: parameter-p_t_verzoegerung_oeffnen_fussraum,0 s
IDE11477-ENG128468-Interior lighting: parameter-p_t_verzoegerung_oeffnen_innenlicht,0 s
IDE11477-ENG128496-Interior lighting: parameter-p_t_verzoegerung_oeffnen_miko,0 s
IDE11477-ENG128475-Interior lighting: parameter-p_t_verzoegerung_oeffnen_tueren,0 s
IDE11477-ENG128491-Interior lighting: parameter-p_t_verzoegerung_schliessen_cockpit,0 s
IDE11477-ENG128505-Interior lighting: parameter-p_t_verzoegerung_schliessen_dach,0 s
IDE11477-ENG128484-Interior lighting: parameter-p_t_verzoegerung_schliessen_fussraum,0 s
IDE11477-ENG128470-Interior lighting: parameter-p_t_verzoegerung_schliessen_innenlicht,0 s
IDE11477-ENG128498-Interior lighting: parameter-p_t_verzoegerung_schliessen_miko,0 s
IDE11477-ENG128477-Interior lighting: parameter-p_t_verzoegerung_schliessen_tueren,0 s
IDE11477-ENG128492-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_cockpit,0 s
IDE11477-ENG128506-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_dach,0 s
IDE11477-ENG128485-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_fussraum,0 s
IDE11477-ENG128471-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_innenlicht,0 s
IDE11477-ENG128499-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_miko,0 s
IDE11477-ENG128478-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_tueren,0 s
IDE11477-ENG128493-Interior lighting: parameter-p_t_verzoegerung_verriegelt_cockpit,0 s
IDE11477-ENG128507-Interior lighting: parameter-p_t_verzoegerung_verriegelt_dach,0 s
IDE11477-ENG128486-Interior lighting: parameter-p_t_verzoegerung_verriegelt_fussraum,0 s
IDE11477-ENG128472-Interior lighting: parameter-p_t_verzoegerung_verriegelt_innenlicht,0 s
IDE11477-ENG128500-Interior lighting: parameter-p_t_verzoegerung_verriegelt_miko,0 s
IDE11477-ENG128479-Interior lighting: parameter-p_t_verzoegerung_verriegelt_tueren,0 s
IDE11477-ENG128663-Interior lighting: parameter-p_verzoegerung_berechnen,00
IDE11714-ENG02360-Ambientelicht Farbliste-Blauwert Farbe 10,E1
IDE11714-ENG02342-Ambientelicht Farbliste-Blauwert Farbe 4,E1
IDE11714-ENG02345-Ambientelicht Farbliste-Blauwert Farbe 5,E1
IDE11714-ENG02348-Ambientelicht Farbliste-Blauwert Farbe 6,E1
IDE11714-ENG02351-Ambientelicht Farbliste-Blauwert Farbe 7,E1
IDE11714-ENG02354-Ambientelicht Farbliste-Blauwert Farbe 8,E1
IDE11714-ENG02357-Ambientelicht Farbliste-Blauwert Farbe 9,E1
IDE11714-ENG02359-Ambientelicht Farbliste-Gruenwert Farbe 10,E1
IDE11714-ENG02341-Ambientelicht Farbliste-Gruenwert Farbe 4,E1
IDE11714-ENG02344-Ambientelicht Farbliste-Gruenwert Farbe 5,E1
IDE11714-ENG02347-Ambientelicht Farbliste-Gruenwert Farbe 6,E1
IDE11714-ENG02350-Ambientelicht Farbliste-Gruenwert Farbe 7,E1
IDE11714-ENG02353-Ambientelicht Farbliste-Gruenwert Farbe 8,E1
IDE11714-ENG02356-Ambientelicht Farbliste-Gruenwert Farbe 9,E1
IDE11714-ENG02358-Ambientelicht Farbliste-Rotwert Farbe 10,E1
IDE11714-ENG02340-Ambientelicht Farbliste-Rotwert Farbe 4,E1
IDE11714-ENG02343-Ambientelicht Farbliste-Rotwert Farbe 5,E1
IDE11714-ENG02346-Ambientelicht Farbliste-Rotwert Farbe 6,E1
IDE11714-ENG02349-Ambientelicht Farbliste-Rotwert Farbe 7,E1
IDE11714-ENG02352-Ambientelicht Farbliste-Rotwert Farbe 8,E1
IDE11714-ENG02355-Ambientelicht Farbliste-Rotwert Farbe 9,E1
MAS01490-ENG116830-Energy management-Energy_Management_Adaptation,Energy management active
MAS01490-ENG02328-Energy management-Praediktives_Energiemanagement,not active
MAS05055-lower turn position,25.51 °
MAS05056-upper turn position,166.51 °
MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck,active
MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb,not active
MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG,not active
MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global,active
MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen,active
MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen,active
MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen,not active
MAS05934-ENG02319-Convert. top oper.-Remote Lock Unlock Timer s1,80 s
MAS05934-ENG02320-Convert. top oper.-Remote Lock Unlock Timer s3,20.000 ms
MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach,not active
MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung,active
MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy,active
MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder,active
MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung,active
MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy,active
MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder,active
MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein,not active
MAS08228-ENG02362-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze,60 lx
MAS08228-ENG02363-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze,110 lx
MAS08228-ENG02372-Light sensor-ECE_Lichteinschaltschwelle,1000 lx
MAS08228-ENG02361-Light sensor-Einschaltgrenze_CHO_LHO,30 lx
MAS08228-ENG02365-Light sensor-Helligkeitsgrenze_Licht__einschalten,60 lx
MAS08228-ENG02366-Light sensor-Helligkeitsgrenze_Licht_ausschalten,110 lx
MAS08228-ENG02373-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,80
MAS08228-ENG02364-Light sensor-Helligkeitsgrenze_sehr_hell,100 lx
MAS08228-ENG02370-Light sensor-Maximale_Ausgangsspannung,4500 mV
MAS08228-ENG02368-Light sensor-Maximale_Beleuchtungsstaerke,300 lx
MAS08228-ENG02369-Light sensor-Minimale_Ausgangsspannung,2000 mV
MAS08228-ENG02367-Light sensor-Minimale_Beleuchtungsstaerke,0 lx
MAS08228-ENG02371-Light sensor-Tunnel_einschalt_verzoegerung,02
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1,1.00
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10,1.00
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11,1.00
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12,1.00
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13,1.00
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14,1.00
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15,1.00
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2,1.00
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3,1.00
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4,1.00
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5,1.00
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6,1.00
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7,1.00
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8,1.00
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9,1.00
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1,door
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10,door
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11,door
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12,door
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13,door
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14,door
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15,door
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2,door
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3,door
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4,door
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5,door
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6,door
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7,door
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8,door
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9,door
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1,not installed
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10,not installed
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11,not installed
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12,not installed
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13,not installed
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14,not installed
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15,not installed
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2,not installed
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3,not installed
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4,not installed
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5,not installed
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6,not installed
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7,not installed
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8,not installed
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9,not installed
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12,0
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1,0
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10,0
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11,0
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13,0
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14,0
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15,0
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16,0
ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17,0
ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18,0
ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19,0
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2,0
ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20,0
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3,0
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4,0
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5,0
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6,0
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7,0
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8,0
ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9,0
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,00
ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10,0
ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11,0
ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12,0
ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13,0
ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14,0
ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15,0
ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16,0
ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17,0
ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18,0
ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19,0
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2,0
ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20,0
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3,0
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4,0
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5,0
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6,0
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7,0
ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9,0
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8,0
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1,not installed
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10,not installed
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11,not installed
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12,not installed
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13,not installed
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14,not installed
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15,not installed
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16,not installed
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17,not installed
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18,not installed
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19,not installed
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2,not installed
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20,not installed
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3,not installed
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4,not installed
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5,not installed
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6,not installed
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7,not installed
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9,not installed
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8,not installed
ENG126647-ENG98399-debug_light_function-Activation,0
ENG126647-ENG101417-debug_light_function-Adresse,0
ENG126647-ENG126820-debug_light_function-Bitmask,0
ENG126647-ENG126821-debug_light_function-Divisor,0
ENG126647-ENG98827-debug_light_function-Offset,0
ENG126647-ENG126822-debug_light_function-Polaritaet,0
ENG126647-ENG126823-debug_light_function-WBT-Ausgabe,0
ENG99457-ENG117394-Head area heater-blower_speed,1
ENG99457-ENG98971-Head area heater-Temperature,-2
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0,0 ms
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1,200 ms
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10,2000 ms
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2,400 ms
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3,600 ms
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4,800 ms
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5,1000 ms
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6,1200 ms
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7,1400 ms
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8,1600 ms
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9,1800 ms
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0,100.00 %
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1,72.00 %
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10,0.00 %
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2,48.00 %
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3,33.00 %
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4,18.00 %
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5,12.00 %
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6,8.00 %
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7,6.00 %
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8,4.00 %
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9,2.00 %
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0,0
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1,50
ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10,0
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2,100
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3,200
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4,253
ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5,0
ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6,0
ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7,0
ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8,0
ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9,0
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0,0 lx
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1,50 lx
ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10,0 lx
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2,100 lx
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3,200
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4,500
ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5,0
ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6,0 lx
ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7,0 lx
ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8,0 lx
ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9,0 lx
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0,0 ms
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1,200 ms
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10,2000 ms
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2,400 ms
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3,600 ms
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4,800 ms
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5,1000 ms
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6,1200 ms
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7,1400 ms
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8,1600 ms
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9,1800 ms
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0,0.00 %
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1,1.00 %
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10,100.00 %
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2,3.00 %
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3,5.00 %
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4,11.00 %
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5,22.00 %
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6,40.00 %
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7,80.00 %
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8,95.00 %
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9,100.00 %
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0,0.00 %
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1,6.00 %
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2,16.00 %
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3,30.00 %
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4,60.00 %
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5,100.00 %
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0,10
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1,10
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2,100
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3,150
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4,220
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5,253
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0,0 lx
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1,8 lx
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2,200 lx
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3,300 lx
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4,500 lx
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0,16.00
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1,16.00
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2,100.00
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3,100.00
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4,100.00
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0,0 lx
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1,8 lx
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2,220 lx
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3,300 lx
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4,500 lx
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0,6.00
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1,6.00
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2,100.00
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3,100.00
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4,100.00
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0,0
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1,10
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2,50
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3,100
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4,220
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5,253
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0,2.00 %
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1,2.00 %
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2,6.00 %
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3,10.00 %
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4,80.00 %
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5,100.00 %
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0,0 lx
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1,8 lx
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2,50 lx
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3,500 lx
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0,100.00
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1,100.00
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2,100.00
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3,100.00
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0,0 lx
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1,8 lx
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2,50 lx
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3,510 lx
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0,6.00
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1,6.00
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2,100.00
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3,100.00
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0,0.00 %
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1,50.00 %
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2,100.00 %
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0,0.00 %
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1,50.00 %
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2,100.00 %
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0,0 lx
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1,8 lx
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2,50 lx
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3,500 lx
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0,100.00
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1,100.00
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2,100.00
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3,100.00
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0,0 lx
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1,8 lx
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2,50 lx
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3,500 lx
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0,6.00
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1,6.00
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2,100.00
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3,100.00
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0,0.00 %
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1,50.00 %
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2,100.00 %
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0,0.00 %
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1,50.00 %
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2,100.00 %
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0,0 ms
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1,2000 ms
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2,3000 ms
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3,4000 ms
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4,5100 ms
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0,1.00 %
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1,5.00
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2,15.00
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3,40.00
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4,100.00
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0,maximize
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0,maximize
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0,maximize
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,100
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0,0
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0,0
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0,0
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,14
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,12 - Blinkleuchten
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0,Always
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0,not active
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0,not active
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0,not active
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0,not active
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0,not active
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0,not active
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0,not active
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10,maximize
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10,maximize
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10,maximize
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10,0
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10,0
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10,0
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10,0
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,00
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,00
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10,not active
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10,Always
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10,not active
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10,not active
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10,not active
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10,not active
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10,not active
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10,not active
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10,not active
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10,not active
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11,maximize
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11,maximize
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11,maximize
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11,0
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11,0
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11,0
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11,0
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11,00
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11,00
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11,not active
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11,Always
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11,not active
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11,not active
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11,not active
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11,not active
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11,not active
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11,not active
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11,not active
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11,not active
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12,maximize
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12,maximize
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12,maximize
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,100
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12,0
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12,0
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12,0
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,22
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,38
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,10 - allgemeine Scheinwerfer
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12,Always
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,Nebellicht links
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,not active
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12,not active
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12,not active
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12,not active
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12,not active
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12,not active
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12,not active
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13,maximize
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13,maximize
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13,maximize
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,100
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13,0
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13,0
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13,0
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,23
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,42
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,10 - allgemeine Scheinwerfer
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13,Always
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,Nebellicht rechts
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,not active
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13,not active
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13,not active
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13,not active
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13,not active
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13,not active
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13,not active
ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15,maximize
ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15,maximize
ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15,maximize
ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15,0
ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15,0
ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15,0
ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15,0
ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15,00
ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15,00
ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15,not active
ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15,Always
ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15,not active
ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15,not active
ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15,not active
ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15,not active
ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15,not active
ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15,not active
ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15,not active
ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15,not active
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16,maximize
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16,maximize
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16,maximize
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,0
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16,0
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16,0
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16,0
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,17
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,35
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,not active
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,Always
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,not active
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16,not active
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,not active
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16,not active
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16,not active
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16,not active
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16,not active
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16,not active
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17,maximize
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17,maximize
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17,maximize
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,0
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17,0
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17,0
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17,0
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,19
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,3F
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,not active
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,Always
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,not active
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17,not active
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,not active
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17,not active
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17,not active
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17,not active
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17,not active
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17,not active
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18,maximize
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18,maximize
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18,maximize
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,100
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18,0
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18,0
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18,0
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18,16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18,08
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,12 - Blinkleuchten
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18,Always
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18,Blinken links Hellphase
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18,not active
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,not active
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18,not active
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18,not active
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18,not active
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18,not active
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18,not active
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19,maximize
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19,maximize
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19,maximize
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,100
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19,0
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19,0
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19,0
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19,18
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19,18
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,12 - Blinkleuchten
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19,Always
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19,Blinken rechts Hellphase
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19,not active
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,not active
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19,not active
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19,not active
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19,not active
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19,not active
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19,not active
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1,maximize
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1,maximize
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1,maximize
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,100
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1,0
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1,0
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1,0
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,12 - Blinkleuchten
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1,Always
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1,not active
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1,not active
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1,not active
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1,not active
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1,not active
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1,not active
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1,not active
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20,maximize
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20,maximize
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20,maximize
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,100
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20,0
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20,0
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20,0
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,2B
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,09
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,34 - LED Bremsleuchten
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20,Always
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,Brake light
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20,not active
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,not active
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20,not active
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,Coming Home oder Leaving Home aktiv
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20,not active
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20,not active
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20,not active
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21,maximize
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21,maximize
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21,maximize
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,100
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21,0
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21,0
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21,0
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,2D
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,19
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,34 - LED Bremsleuchten
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21,Always
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,Brake light
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21,not active
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,not active
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21,not active
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,Coming Home oder Leaving Home aktiv
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21,not active
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21,not active
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21,not active
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22,maximize
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22,maximize
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22,maximize
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,100
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22,0
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22,0
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22,0
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22,2C
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22,29
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22,34 - LED Bremsleuchten
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22,Always
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22,Brake light
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,not active
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22,not active
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22,not active
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22,not active
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22,not active
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22,not active
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22,not active
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23,maximize
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23,maximize
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23,maximize
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,100
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,100
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23,0
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23,0
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23,29
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23,0A
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,32 - allgemeine LED bis 12W
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23,Always
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,Coming Home oder Leaving Home aktiv
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,not active
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23,not active
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23,not active
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23,not active
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23,not active
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24,maximize
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24,maximize
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24,maximize
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,100
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,100
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24,0
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24,0
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24,2A
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24,1A
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,32 - allgemeine LED bis 12W
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24,Always
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,Parking light right
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,Coming Home oder Leaving Home aktiv
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,not active
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24,not active
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24,not active
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24,not active
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24,not active
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25,maximize
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25,maximize
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25,maximize
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25,100
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25,0
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25,0
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25,0
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25,30
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25,28
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25,18 - 2* 5W
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25,Always
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25,Coming Home oder Leaving Home aktiv
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25,not active
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25,not active
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25,not active
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25,not active
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25,not active
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25,not active
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26,maximize
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26,maximize
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26,maximize
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,100
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26,0
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26,0
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26,0
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,2E
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,0C
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,9 - allgemeine Glühlampe 27W: auch H15
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,Always
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26,not active
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26,not active
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26,not active
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26,not active
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26,not active
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26,not active
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26,not active
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27,maximize
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27,maximize
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27,maximize
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,0
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27,0
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27,0
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27,0
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,2F
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,1C
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,9 - allgemeine Glühlampe 27W: auch H15
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27,Always
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,not active
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27,not active
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27,not active
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27,not active
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27,not active
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27,not active
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27,not active
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27,not active
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28,maximize
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28,maximize
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28,maximize
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,100
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28,0
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28,0
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28,0
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28,31
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28,0B
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,9 - allgemeine Glühlampe 27W: auch H15
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,Always
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28,Rueckfahrlicht
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28,not active
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28,not active
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28,not active
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28,not active
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28,not active
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28,not active
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28,not active
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29,maximize
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29,maximize
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29,maximize
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,100
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29,0
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29,0
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29,0
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29,32
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29,1B
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,9 - allgemeine Glühlampe 27W: auch H15
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,Always
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29,Rueckfahrlicht
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29,not active
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29,not active
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29,not active
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29,not active
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29,not active
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29,not active
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29,not active
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2,maximize
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2,maximize
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2,maximize
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,0
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,0
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,0
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2,0
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,00
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,00
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,not active
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2,Always
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,not active
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2,not active
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,not active
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2,not active
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,not active
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2,not active
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2,not active
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2,not active
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30,maximize
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30,maximize
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30,maximize
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,0
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30,0
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30,0
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30,0
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30,00
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30,00
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,not active
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30,Always
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30,not active
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30,not active
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30,not active
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30,not active
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30,not active
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30,not active
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30,not active
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30,not active
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31,maximize
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31,maximize
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31,maximize
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31,100
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31,0
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31,0
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31,0
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31,03
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31,00
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31,not active
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31,Always
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31,Ambientelicht 1
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31,not active
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31,not active
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31,not active
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31,not active
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31,not active
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31,not active
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31,not active
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32,maximize
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32,maximize
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32,maximize
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32,100
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32,0
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32,0
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32,0
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32,04
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32,00
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32,not active
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32,Always
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,Ambientelicht 2
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32,not active
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32,not active
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32,not active
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32,not active
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32,not active
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32,not active
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32,not active
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33,maximize
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33,maximize
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33,maximize
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33,100
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33,0
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33,0
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33,0
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33,05
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33,00
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33,not active
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33,Always
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,Ambientelicht 3
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33,not active
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33,not active
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33,not active
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33,not active
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33,not active
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33,not active
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33,not active
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34,maximize
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34,maximize
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34,maximize
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34,100
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34,0
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34,0
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34,0
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34,06
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34,00
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34,not active
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34,Always
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,Ambientelicht 4
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34,not active
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34,not active
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34,not active
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34,not active
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34,not active
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34,not active
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34,not active
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3,maximize
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3,maximize
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3,maximize
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,0
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,0
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,0
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3,0
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,00
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,00
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,not active
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3,Always
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,not active
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3,not active
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,not active
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3,not active
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,not active
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3,not active
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3,not active
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3,not active
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4,maximize
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4,maximize
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4,maximize
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,30
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4,30
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,100
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4,0
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,43
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,3A
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,9 - allgemeine Glühlampe 27W: auch H15
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4,Always
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4,Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,Coming Home oder Leaving Home aktiv
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4,not active
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,Daytime running lights
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4,not active
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4,not active
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4,not active
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5,maximize
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5,maximize
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5,maximize
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,30
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5,30
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,100
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5,0
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,44
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,44
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,9 - allgemeine Glühlampe 27W: auch H15
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5,Always
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5,Parking light right
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,Coming Home oder Leaving Home aktiv
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5,not active
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,Daytime running lights
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5,not active
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5,not active
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5,not active
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6,maximize
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6,maximize
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6,maximize
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6,100
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,0
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6,0
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6,0
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6,1A
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6,36
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,11 - Abblendlicht
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6,Always
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6,Abblendlicht links
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,Coming Home oder Leaving Home aktiv
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,not active
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6,not active
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6,not active
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6,not active
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6,not active
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6,not active
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7,maximize
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7,maximize
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7,maximize
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7,100
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,0
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7,0
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7,0
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7,1B
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7,40
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,11 - Abblendlicht
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7,Always
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7,Abblendlicht rechts
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,Coming Home oder Leaving Home aktiv
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,not active
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7,not active
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7,not active
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7,not active
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7,not active
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7,not active
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8,maximize
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8,maximize
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8,maximize
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,100
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,0
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8,0
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8,0
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,1C
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,37
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,10 - allgemeine Scheinwerfer
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8,Always
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Left high beam
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,Lichthupe generell
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,not active
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,not active
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8,not active
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8,not active
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8,not active
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8,not active
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9,maximize
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9,maximize
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9,maximize
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,100
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,0
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9,0
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9,0
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,1D
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,41
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,10 - allgemeine Scheinwerfer
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9,Always
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Right high beam
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,Lichthupe generell
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,not active
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,not active
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9,not active
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9,not active
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9,not active
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9,not active
ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14,maximize
ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14,maximize
ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14,maximize
ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14,0
ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14,0
ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14,0
ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14,0
ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14,00
ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14,00
ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14,not active
ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14,Always
ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14,not active
ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14,not active
ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14,not active
ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14,not active
ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14,not active
ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14,not active
ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14,not active
ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14,not active
ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1,active
ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2,active
ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3,active
ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4,active
ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5,active
ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6,active
ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ,not active
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0,0.00 %
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,5.00 %
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,50.00 %
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,75.00 %
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,110.00
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,126.50
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0,0.00 %
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1,6.00 %
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2,16.00 %
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3,30.00 %
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4,60.00 %
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5,100.00 %
ENG98831-ENG126849-Personalisierung-Aktivierungsoption_im_HMI-Menue_sichtbar,not active
ENG98831-ENG02329-Personalisierung-Anzahl_Benutzerkonten,1
ENG98831-ENG02330-Personalisierung-Automatische_ Schluesselzuordnung,not active
ENG98831-ENG126850-Personalisierung-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,not active
ENG98831-ENG126848-Personalisierung-Personalisierung_aktiv,not active
ENG98831-ENG126851-Personalisierung-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,not active
ENG98831-ENG02331-Personalisierung-PSO_FSG_Setup2_Bit_0,not active
ENG98831-ENG02332-Personalisierung-PSO_FSG_Setup2_Bit_1,not active
ENG98831-ENG02333-Personalisierung-PSO_FSG_Setup2_Bit_2,not active
ENG98831-ENG02334-Personalisierung-PSO_FSG_Setup2_Bit_3,not active
ENG98831-ENG02335-Personalisierung-PSO_FSG_Setup2_Bit_4,not active
ENG98831-ENG02336-Personalisierung-PSO_FSG_Setup2_Bit_5,not active
ENG98831-ENG02337-Personalisierung-PSO_FSG_Setup2_Bit_6,not active
ENG98831-ENG02338-Personalisierung-PSO_FSG_Setup2_Bit_7,not active
ENG122976-ENG128461-Remote_Start_Adaption-Kombi_Fahrerhinweis_m_Uebernahme_RSt,not active
ENG122976-ENG128460-Remote_Start_Adaption-Rueckmeldung_bei_Aktivierung,active
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1,00 00
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2,00 00
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3,00 00
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4,00 00
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1,00 00
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2,00 00
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3,00 00
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4,00 00
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5,00 00
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6,00 00
adpmap-15-3Q0-959-655-AS.CSV
;SW:3Q0-959-655-AS HW:3Q0-959-655-AS --- Airbags
;Component:Airbag VW20 013 0200, Coding:98CCC000000000005C5400CC000800000065
;EV_AirbaVW20TS6VW48X,001116,EV_AirbaVW20TS6VW48X.rod
;Thursday,22,December,2016,12:36:55:57018
;VCDS Version: Release 16.8.4 (x64) Data version: 20161129 DS267.0
;VCID: 8F27F6305683563AC0-80DA
IDE06314-Calibration data: pre-crash,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE06527-IDE06311-Adaptation pre-crash-Seat belt tensioner: left,not defined
IDE06527-IDE06312-Adaptation pre-crash-Seat belt tensioner: right,not defined
MAS00975-IDE01755-Airbag adaptations-Rollover protection system,not defined
MAS00975-IDE02852-Airbag adaptations-Igniter for battery interrupt: high voltage battery,not defined
MAS00975-MAS00001-Airbag adaptations-Driver airbag igniter,activated
MAS00975-MAS00003-Airbag adaptations-Passenger airbag igniter,activated
MAS00975-MAS00005-Airbag adaptations-Driver thorax airbag igniter,activated
MAS00975-MAS00006-Airbag adaptations-Front passenger side airbag igniter,activated
MAS00975-MAS00007-Airbag adaptations-Driver side rear thorax airbag igniter,not defined
MAS00975-MAS00008-Airbag adaptations-Passenger side rear thorax airbag igniter,not defined
MAS00975-MAS00009-Airbag adaptations-Driver head curtain airbag igniter,activated
MAS00975-MAS00010-Airbag adaptations-Front passenger head curtain airbag igniter,activated
MAS00975-MAS00011-Airbag adaptations-Driver knee airbag igniter,activated
MAS00975-MAS00012-Airbag adaptations-Front passenger knee airbag igniter,not defined
MAS00975-MAS00013-Airbag adaptations-Driver side seat belt tension igniter,activated
MAS00975-MAS00014-Airbag adaptations-Front passenger side seat belt tension igniter,activated
MAS00975-MAS00019-Airbag adaptations-Driver side rear safety belt tension igniter,not defined
MAS00975-MAS00020-Airbag adaptations-Passenger side rear safety belt tension igniter,not defined
MAS00975-MAS00022-Airbag adaptations-Igniter for battery interrupt,not defined
MAS00975-MAS00030-Airbag adaptations-Seat occupied recognition,activated
MAS00975-MAS00079-Airbag adaptations-Key switch,Airbag deactivation key switch installed
MAS00975-MAS01503-Airbag adaptations-Pedestrian protection igniter engine hood,not defined
adpmap-16-5Q0-953-521-M.CSV
;SW:5Q0-953-521-M HW:5Q0-953-569-A --- Steering wheel
;Component:Lenks.Modul 075 0195, Coding:1400
;EV_SMLSVALEOMQB,001015,EV_SMLSVALEOMQB.rod
;Thursday,22,December,2016,12:37:10:57018
;VCID: BC7D71FC37B59DA255-80E8
ENG126417-p_n_fehler_p_verriegelt,50
ENG120504-p_s_NWDF_spg,0 ms
ENG102189-p_t_blinker_entprellen,40 ms
ENG102332-p_t_blinker_err_el_kurzschluss,200 ms
ENG104011-p_t_blinker_err_el_unterbrechung,1000 ms
ENG120503-p_t_blinker_err_fernlicht_haengt_aus,5000 ms
ENG120502-p_t_blinker_err_fernlicht_haengt_ein,300 s
ENG104185-p_t_blinker_err_gra_haengt_aus,5000 ms
ENG100988-p_t_blinker_err_gra_haengt_ein,300 s
ENG103202-p_t_blinker_err_lichthupe_haengt_aus,5000 ms
ENG100154-p_t_blinker_err_lichthupe_haengt_ein,300 s
ENG100923-p_t_blinker_err_unplausibel,2000 ms
ENG127113-p_t_blinker_err_weckkontakthaengt_aus,5000 ms
ENG127112-p_t_blinker_err_weckkontakthaengt_ein,3000 ms
ENG103471-p_t_blinker_gra_entprellen,40 ms
ENG101294-p_t_blinker_sperrzeit,100 ms
ENG127114-p_t_entprellung_p_unplausibel,400 ms
ENG104033-p_t_entprellzeit_ueberspannung,90000 ms
ENG101392-p_t_entprellzeit_unterspannung,90000 ms
ENG102689-p_t_fas_entprellen,40 ms
ENG120505-p_t_gra_ea_error,2000 ms
ENG101014-p_t_grahebel_entprellen,40 ms
ENG104117-p_t_grahebel_err_el_kurzschluss,200 ms
ENG102950-p_t_grahebel_err_el_unterbrechung,1000 ms
ENG103784-p_t_grahebel_err_gra_haengt_aus,5000 ms
ENG102546-p_t_grahebel_err_gra_haengt_ein,300 s
ENG103536-p_t_grahebel_err_unplausibel,200 ms
ENG99436-p_t_hupe_entprellen,40 ms
ENG102496-p_t_hupe_err_hinweis,2000 ms
ENG101071-p_t_hupe_err_hupe_haengt_aus,5000 ms
ENG101518-p_t_hupe_err_hupe_haengt_ein,60 s
ENG101702-p_t_hupe_indien_entprellen,500 ms
ENG100796-p_t_spannung_obere_schwelle,18.0 V
ENG102338-p_t_spannung_untere_schwelle,6.5 V
ENG100559-p_t_wischer_entprellen,40 ms
ENG103039-p_t_wischer_err_el_kurzschluss,200 ms
ENG101343-p_t_wischer_err_el_unterbrechung,1000 ms
ENG108143-p_t_wischer_err_intervallpoti_haengt_aus,5000 ms
ENG102443-p_t_wischer_err_intervallpoti_haengt_ein,300 s
ENG101059-p_t_wischer_err_mfa_haengt_aus,5000 ms
ENG100346-p_t_wischer_err_mfa_haengt_ein,300 s
ENG103464-p_t_wischer_err_waschen_haengt_aus,5000 ms
ENG100423-p_t_wischer_err_waschen_haengt_ein,300 s
ENG99933-p_t_wischer_err_wischen_haengt_aus,5000 ms
ENG102586-p_t_wischer_err_wischen_haengt_ein,300 s
ENG101592-p_t_wischer_intervall_entprellen,40 ms
ENG103607-p_t_wischer_winterstellung,60 s
adpmap-17-5E0-920-781-B.CSV
;SW:5E0-920-781-B HW:5E0-920-781-B --- Instruments
;Component:KOMBI 206 7652, Coding:07A40A002180000801082A001000000000000000
;EV_DashBoardJCIMQBAB,009005,EV_DashBoardJCIMQBAB_VW48.rod
;Thursday,22,December,2016,12:37:43:57018
;VCID: A757BE90DE332E7A28-80F2
IDE00295-Oil temperature display,OFF
IDE00301-Distance,29071 km
IDE00342-ESI: Resetting ESI,no warning
IDE00343-Language version,romanian
IDE00345-MAS00234-MFA3-Reset-MFI button RESET / OK,Manual reset: not possible
IDE00345-MAS05463-MFA3-Reset-Refuel detection gasoline / diesel,MFA3-Reset
IDE00345-MAS05464-MFA3-Reset-Refuel detection gas,MFA3-Reset
IDE00499-Display correction of consumptions and operating range,100 %
IDE00500-Hour,12 H
IDE00501-Minute,36 min
IDE00502-Year,2016 yr
IDE00503-Month,12 mon
IDE00504-Day,22 d
IDE00510-ESI: distance driven from inspection,6200 km
IDE00511-ESI: time from inspection,57 d
IDE00512-ESI: minimum value km-driving distance/inspection,15000 km
IDE00513-ESI: maximum value km-driving distance/inspection,30000 km
IDE00514-ESI: maximum value of time between inspections,730 d
IDE00515-ESI: oil quality,good oil quality
IDE00517-ESI: soot entry,12400 km
IDE00518-ESI: thermal load,6900 km
IDE00819-Day counter,313 d
IDE00820-Activating and deactivating all development messages,not active
IDE00827-ESI: minimum value of time between inspections,365 d
IDE01153-SIA: maximum value of distance to service,30000 km
IDE01154-SIA: maximum value of time to service,730 d
IDE02489-Display depiction,Version 1
IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration,-12.8 l
IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1,-12.8 l
IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2,12.7 l
IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3,12.7 l
IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4,12.7 l
IDE03329-Driving profiled for range remaining,6.0 l/100km
IDE03346-IDE00301-Units adjusted-Distance,Kilometers
IDE03346-MAS01230-Units adjusted-Date,dd_mm_yy
IDE03346-MAS01456-Units adjusted-Speed,Kilometers per hour
IDE03346-MAS02201-Units adjusted-Temperature,°C
IDE03346-MAS02957-Units adjusted-Time,24h
IDE03346-MAS03032-Units adjusted-Volume,Liter
IDE03346-MAS03034-Units adjusted-Pressure,bar
IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas),kg per 100 km
IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km
IDE03348-MAS01456-Speed warning-Speed,30
IDE03348-MAS01561-Speed warning-Unit,Kilometers per hour
IDE03348-IDE03348-Speed warning-,not active
IDE03349-FIX: Max. distance until next mileage-related inspection,30000 km
IDE03350-FIX: Maximum time until next time-dependent inspection,730 d
IDE03351-FIX: Distance covered since last mileage-dependent inspection,28900 km
IDE03352-FIX: Time since last time-dependent inspection,286 d
IDE03372-Source for synchronization of time,internal clock
IDE03568-ENG119828-Service-key settings-p_deactivate_SK_Function,On
IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time,10 s
IDE03568-ENG119827-Service-key settings-p_main_switch_Basic,On
IDE03568-ENG102414-Service-key settings-p_main_switch_keyless,On
IDE03568-ENG102611-Service-key settings-p_write_delay_speed,20 km/h
IDE03568-ENG103545-Service-key settings-p_write_delay_time,40 s
IDE03568-ENG104099-Service-key settings-p_write_distance,20 km
IDE03867-Deactivate seat belt warning,No
IDE05930-Service notification in days,30 d
IDE05931-FIX: Reset value for next mileage-dependent inspection,30000 km
IDE05932-FIX: Reset value for next time-dependent inspections,1095 d
IDE06425-Roller test bench mode: functional,not activated
IDE06588-Ignition active message: actuator,Driver door
IDE07221-Cylinder shut-off,Display
IDE11086-Service notification,30 d
MAS03555-Lap counter,Not available
MAS03685-Digital speedometer,Display
ENG117917-BAP_Debug_Mode_Release,not_released
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF
ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34,OFF
ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35,OFF
ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36,OFF
ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37,OFF
ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38,OFF
ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39,OFF
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,OFF
ENG119875-defuel_threshold,9 l
ENG105831-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_day-X1,00
ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2,32
ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3,66
ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4,96
ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5,DC
ENG105831-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_day-X6,FD
ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1,00
ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2,00
ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,00
ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,0A
ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,32
ENG105831-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_day-Y6,64
ENG105832-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_night-X1,00
ENG105832-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_night-X2,0A
ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3,46
ENG105832-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_night-X4,64
ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5,DC
ENG105832-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_night-X6,FD
ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,03
ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,03
ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,11
ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,1F
ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,5A
ENG105832-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_night-Y6,64
ENG105834-ENG101574-dimming_characteristic_curve_adjustment_gauge-X1,00
ENG105834-ENG99557-dimming_characteristic_curve_adjustment_gauge-X2,0A
ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3,46
ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4,64
ENG105834-ENG103548-dimming_characteristic_curve_adjustment_gauge-X5,DC
ENG105834-ENG113992-dimming_characteristic_curve_adjustment_gauge-X6,FD
ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1,03
ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2,03
ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3,11
ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4,1E
ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5,5A
ENG105834-ENG113993-dimming_characteristic_curve_adjustment_gauge-Y6,64
ENG105835-ENG101574-dimming_characteristic_curve_adjustment_indicator_lights-X1,00
ENG105835-ENG99557-dimming_characteristic_curve_adjustment_indicator_lights-X2,0A
ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3,32
ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4,64
ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5,96
ENG105835-ENG113992-dimming_characteristic_curve_adjustment_indicator_lights-X6,FD
ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1,05
ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2,05
ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3,0C
ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4,17
ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5,32
ENG105835-ENG113993-dimming_characteristic_curve_adjustment_indicator_lights-Y6,64
ENG119878-ENG101574-dimming_characteristic_curve_adjustment_internal_phototransistor-X1,00 00
ENG119878-ENG99557-dimming_characteristic_curve_adjustment_internal_phototransistor-X2,00 32
ENG119878-ENG102140-dimming_characteristic_curve_adjustment_internal_phototransistor-X3,00 64
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 C8
ENG119878-ENG103548-dimming_characteristic_curve_adjustment_internal_phototransistor-X5,01 F4
ENG119878-ENG99777-dimming_characteristic_curve_adjustment_internal_phototransistor-Y1,00 00
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 0E
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 41
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 C8
ENG119878-ENG102174-dimming_characteristic_curve_adjustment_internal_phototransistor-Y5,00 FD
ENG105836-ENG101574-dimming_characteristic_curve_adjustment_middle_display_main_field-X1,00
ENG105836-ENG99557-dimming_characteristic_curve_adjustment_middle_display_main_field-X2,0A
ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3,46
ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4,64
ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5,DC
ENG105836-ENG113992-dimming_characteristic_curve_adjustment_middle_display_main_field-X6,FD
ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1,01
ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2,01
ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3,06
ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4,0C
ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5,46
ENG105836-ENG113993-dimming_characteristic_curve_adjustment_middle_display_main_field-Y6,64
ENG125906-ENG126933-Illumination_algorithm-Pointer_illumination_algorithm,terminal_58xd_log_bus_parkinglight
ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm,parking_light
ENG119882-init_fuel_algorithm,No
ENG130585-Leaving_warning_delay,1.6 s
ENG102605-ENG103211-outside_temperature-p_blocking_time_after_v_bigger_0,15 s
ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature,4 °C
ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature,6 °C
ENG102605-ENG102658-outside_temperature-p_kmt_at_delta,25
ENG102605-ENG99866-outside_temperature-p_mileage_after_v_bigger_0,50 km
ENG102605-ENG103631-outside_temperature-P_speed_threshold,20
ENG102605-ENG99450-outside_temperature-p_storage_time_engine_off,180 min
ENG102605-ENG104179-outside_temperature-p_tendency_damping,15
ENG102605-ENG103335-outside_temperature-p_tendency_threshold,1.0 °C
ENG102605-ENG100500-outside_temperature-p_time_constant_pt1,40
ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping,20
ENG119825-Picture_Upload_Download,not active
ENG119876-Service_Key_Clear_All_Counter,No
ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms,0.00 s
ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms,0 s
ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt,30 s
ENG109442-ENG119804-time_parameter_display-hmi_t_FTuerAUF,300 s
ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms,0 s
ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms,0 s
ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms,0 s
ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms,0 s
ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms,0 s
ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms,0 s
ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms,0 s
ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms,0 s
ENG109442-ENG119803-time_parameter_display-hmi_t_USZ,0.00 s
ENG109442-ENG119806-time_parameter_display-rollierblockgroesse,0
ENG109442-ENG101663-time_parameter_display-tDD15_off,0.15 s
ENG109442-ENG103975-time_parameter_display-tDD15_on,0.00 s
ENG109442-ENG100026-time_parameter_display-tDDWUP,1.55 s
adpmap-19-5Q0-907-530-AH.CSV
;SW:5Q0-907-530-AH HW:5Q0-907-530-E --- CAN Gateway
;Component:GW MQB Mid 127 1244, Coding:030100045F087300EB000248080F00010001050000000000000000000000
;EV_GatewLear,013020,EV_GatewLear_013.rod
;Thursday,22,December,2016,12:38:30:57018
;VCID: F7F7AED04E137EFA78-80A2
IDE00001-ENG124491-Production mode-p_mode_deactivate_mfl_keys,Deactivating
IDE00001-ENG118694-Production mode-p_mode_deactivate_recuperation,Deactivating
IDE00002-Transport mode,not active
IDE00945-ENG118688-Hysteresis voltage-Voltage_elevation,12.1 V
IDE00945-ENG118687-Hysteresis voltage-Voltage_lowering,12.1 V
IDE01211-Static current measuring mode,not activated
IDE01457-Energy management deactivation stage,Mode not active
IDE01459-Energy management heat output control status,Mode not active
IDE01844-Increase idle speed request,Mode not active
IDE01847-ENG118685-Auxiliary heater activation restriction request-Set_point_target_time,--
IDE01847-ENG118684-Auxiliary heater activation restriction request-Switch_on_ban_activation,Mode not active
IDE01860-Generator specified voltage value variable,10.6 V
IDE01996-SFT00001-Installation list: specified installations-Engine Control Module 1,coded
IDE01996-SFT00002-Installation list: specified installations-Transmission Control Module,Not coded
IDE01996-SFT00003-Installation list: specified installations-Brakes 1,coded
IDE01996-SFT00006-Installation list: specified installations-Seat Adjustment Passenger Side,Not coded
IDE01996-SFT00008-Installation list: specified installations-Air Conditioning,coded
IDE01996-SFT00009-Installation list: specified installations-Central Electrics,coded
IDE01996-SFT00011-Installation list: specified installations-Auxiliary Air Heater,Not coded
IDE01996-SFT00014-Installation list: specified installations-Media Player Position 1,Not coded
IDE01996-SFT00019-Installation list: specified installations-Adaptive Cruise Control,Not coded
IDE01996-SFT00020-Installation list: specified installations-Wheel Dampening Electronics,Not coded
IDE01996-SFT00021-Installation list: specified installations-Airbag,coded
IDE01996-SFT00022-Installation list: specified installations-Steering Column Electronics,coded
IDE01996-SFT00023-Installation list: specified installations-Dash Board,coded
IDE01996-SFT00024-Installation list: specified installations-Auxiliary Parking Heater,Not coded
IDE01996-SFT00025-Installation list: specified installations-Gateway,1
IDE01996-SFT00028-Installation list: specified installations-Vehicle Position Detection,Not coded
IDE01996-SFT00032-Installation list: specified installations-High Beam Assistance,Not coded
IDE01996-SFT00034-Installation list: specified installations-All Wheel Control,Not coded
IDE01996-SFT00035-Installation list: specified installations-Brake Boost,Not coded
IDE01996-SFT00038-Installation list: specified installations-Electronic Roof Control,Not coded
IDE01996-SFT00043-Installation list: specified installations-Steering Column Locking,Not coded
IDE01996-SFT00048-Installation list: specified installations-Special Function 2,Not coded
IDE01996-SFT00050-Installation list: specified installations-Lock Electronics,Not coded
IDE01996-SFT00054-Installation list: specified installations-Seat Adjustment Driver Side,Not coded
IDE01996-SFT00060-Installation list: specified installations-Lane Change Assistant,Not coded
IDE01996-SFT00061-Installation list: specified installations-Special Function,Not coded
IDE01996-SFT00064-Installation list: specified installations-Air Conditioning Compressor,Not coded
IDE01996-SFT00066-Installation list: specified installations-Door Electronics Driver Side,coded
IDE01996-SFT00068-Installation list: specified installations-Steering Assistance,coded
IDE01996-SFT00071-Installation list: specified installations-Sound System,Not coded
IDE01996-SFT00075-Installation list: specified installations-Multifunction module,Not coded
IDE01996-SFT00081-Installation list: specified installations-Drive Motor Control Module,Not coded
IDE01996-SFT00082-Installation list: specified installations-Door Electronics Passenger Side,coded
IDE01996-SFT00085-Installation list: specified installations-Headlight Regulation,Not coded
IDE01996-SFT00086-Installation list: specified installations-Radio,Not coded
IDE01996-SFT00087-Installation list: specified installations-TV Tuner,Not coded
IDE01996-SFT00095-Installation list: specified installations-Information Control Unit 1,coded
IDE01996-SFT00096-Installation list: specified installations-Tachograph,Not coded
IDE01996-SFT00101-Installation list: specified installations-Tire Pressure Monitoring 1,Not coded
IDE01996-SFT00105-Installation list: specified installations-Trailer Function,Not coded
IDE01996-SFT00108-Installation list: specified installations-Camera System Rear View,Not coded
IDE01996-SFT00109-Installation list: specified installations-Deck Lid Control Unit,Not coded
IDE01996-SFT00117-Installation list: specified installations-Telematics Communication Unit,Not coded
IDE01996-SFT00118-Installation list: specified installations-Parking Assistance,Not coded
IDE01996-SFT00128-Installation list: specified installations-Batterieregelung Zusatzspeicher 1,Not coded
IDE01996-SFT00130-Installation list: specified installations-Head Up Display,Not coded
IDE01996-SFT00140-Installation list: specified installations-Battery Energy Control Module,Not coded
IDE01996-SFT00165-Installation list: specified installations-Front Sensors Driver Assistance System,Not coded
IDE01996-SFT00166-Installation list: specified installations-Microphone Control Unit,Not coded
IDE01996-SFT00169-Installation list: specified installations-Actuator For Structure-borne Sound,Not coded
IDE01996-SFT00183-Installation list: specified installations-Access Startsystem Interface,Not coded
IDE01996-SFT00187-Installation list: specified installations-Door Electronics Rear Driver Side,Not coded
IDE01996-SFT00188-Installation list: specified installations-Door Electronics Rear Passenger Side,Not coded
IDE01996-SFT00189-Installation list: specified installations-High Voltage Battery Charge Management,Not coded
IDE01996-SFT00190-Installation list: specified installations-Sliding Door Rear Left,Not coded
IDE01996-SFT00191-Installation list: specified installations-Sliding Door Rear Right,Not coded
IDE01996-SFT00192-Installation list: specified installations-Actuator For Exterior Noise,Not coded
IDE01996-SFT00197-Installation list: specified installations-Thermal management,Not coded
IDE01996-SFT00198-Installation list: specified installations-Battery Charger Control Module,Not coded
IDE01996-SFT00202-Installation list: specified installations-Control module for sunroof,Not coded
IDE01996-SFT00207-Installation list: specified installations-Control Unit Lane Change Assistant 2,Not coded
IDE01996-ENG118226-Installation list: specified installations-Node_0x01,Not coded
IDE01996-ENG118227-Installation list: specified installations-Node_0x02,Not coded
IDE01996-ENG118228-Installation list: specified installations-Node_0x03,Not coded
IDE01996-ENG118229-Installation list: specified installations-Node_0x04,Not coded
IDE01996-ENG118230-Installation list: specified installations-Node_0x05,Not coded
IDE01996-ENG118231-Installation list: specified installations-Node_0x06,Not coded
IDE01996-ENG118232-Installation list: specified installations-Node_0x07,Not coded
IDE01996-ENG118233-Installation list: specified installations-Node_0x08,Not coded
IDE01996-ENG118234-Installation list: specified installations-Node_0x09,Not coded
IDE01996-ENG118235-Installation list: specified installations-Node_0x0D,Not coded
IDE01996-ENG118236-Installation list: specified installations-Node_0x11,Not coded
IDE01996-ENG118237-Installation list: specified installations-Node_0x16,Not coded
IDE01996-ENG118238-Installation list: specified installations-Node_0x17,Not coded
IDE01996-ENG118239-Installation list: specified installations-Node_0x1A,Not coded
IDE01996-ENG118241-Installation list: specified installations-Node_0x1D,Not coded
IDE01996-ENG118242-Installation list: specified installations-Node_0x1F,Not coded
IDE01996-ENG118243-Installation list: specified installations-Node_0x20,Not coded
IDE01996-ENG118244-Installation list: specified installations-Node_0x21,Not coded
IDE01996-ENG118245-Installation list: specified installations-Node_0x22,Not coded
IDE01996-ENG118246-Installation list: specified installations-Node_0x24,Not coded
IDE01996-ENG118247-Installation list: specified installations-Node_0x25,Not coded
IDE01996-ENG118248-Installation list: specified installations-Node_0x26,Not coded
IDE01996-ENG118249-Installation list: specified installations-Node_0x27,Not coded
IDE01996-ENG118250-Installation list: specified installations-Node_0x28,Not coded
IDE01996-ENG118251-Installation list: specified installations-Node_0x29,Not coded
IDE01996-ENG118252-Installation list: specified installations-Node_0x2A,Not coded
IDE01996-ENG118253-Installation list: specified installations-Node_0x2E,Not coded
IDE01996-ENG118254-Installation list: specified installations-Node_0x2F,Not coded
IDE01996-ENG118255-Installation list: specified installations-Node_0x35,Not coded
IDE01996-ENG118256-Installation list: specified installations-Node_0x36,Not coded
IDE01996-ENG118257-Installation list: specified installations-Node_0x37,Not coded
IDE01996-ENG118258-Installation list: specified installations-Node_0x38,Not coded
IDE01996-ENG118259-Installation list: specified installations-Node_0x39,Not coded
IDE01996-ENG118260-Installation list: specified installations-Node_0x3A,Not coded
IDE01996-ENG118261-Installation list: specified installations-Node_0x3C,Not coded
IDE01996-ENG118262-Installation list: specified installations-Node_0x3D,Not coded
IDE01996-ENG118263-Installation list: specified installations-Node_0x40,Not coded
IDE01996-ENG118264-Installation list: specified installations-Node_0x41,Not coded
IDE01996-ENG118265-Installation list: specified installations-Node_0x43,Not coded
IDE01996-ENG118266-Installation list: specified installations-Node_0x45,Not coded
IDE01996-ENG118267-Installation list: specified installations-Node_0x48,Not coded
IDE01996-ENG118268-Installation list: specified installations-Node_0x49,Not coded
IDE01996-ENG118269-Installation list: specified installations-Node_0x51,Not coded
IDE01996-ENG118270-Installation list: specified installations-Node_0x52,Not coded
IDE01996-ENG118271-Installation list: specified installations-Node_0x53,Not coded
IDE01996-ENG118272-Installation list: specified installations-Node_0x55,Not coded
IDE01996-ENG118273-Installation list: specified installations-Node_0x56,Not coded
IDE01996-ENG118274-Installation list: specified installations-Node_0x58,Not coded
IDE01996-ENG118275-Installation list: specified installations-Node_0x59,Not coded
IDE01996-ENG118276-Installation list: specified installations-Node_0x5A,Not coded
IDE01996-ENG118277-Installation list: specified installations-Node_0x5B,Not coded
IDE01996-ENG118278-Installation list: specified installations-Node_0x5C,Not coded
IDE01996-ENG118279-Installation list: specified installations-Node_0x5D,Not coded
IDE01996-ENG118280-Installation list: specified installations-Node_0x5E,Not coded
IDE01996-ENG118281-Installation list: specified installations-Node_0x5F,Not coded
IDE01996-ENG118282-Installation list: specified installations-Node_0x60,Not coded
IDE01996-ENG118283-Installation list: specified installations-Node_0x61,Not coded
IDE01996-ENG118284-Installation list: specified installations-Node_0x62,Not coded
IDE01996-ENG118285-Installation list: specified installations-Node_0x66,Not coded
IDE01996-ENG118286-Installation list: specified installations-Node_0x68,Not coded
IDE01996-ENG118287-Installation list: specified installations-Node_0x6B,Not coded
IDE01996-ENG118288-Installation list: specified installations-Node_0x6C,Not coded
IDE01996-ENG118289-Installation list: specified installations-Node_0x6E,Not coded
IDE01996-ENG118290-Installation list: specified installations-Node_0x74,Not coded
IDE01996-ENG118291-Installation list: specified installations-Node_0x75,Not coded
IDE01996-ENG118292-Installation list: specified installations-Node_0x78,Not coded
IDE01996-ENG118293-Installation list: specified installations-Node_0x79,Not coded
IDE01996-ENG118294-Installation list: specified installations-Node_0x7A,Not coded
IDE01996-ENG118295-Installation list: specified installations-Node_0x7D,Not coded
IDE01996-ENG118296-Installation list: specified installations-Node_0x7E,Not coded
IDE01996-ENG118297-Installation list: specified installations-Node_0x7F,Not coded
IDE01996-ENG118298-Installation list: specified installations-Node_0x80,Not coded
IDE01996-ENG118299-Installation list: specified installations-Node_0x81,Not coded
IDE01996-ENG118300-Installation list: specified installations-Node_0x82,Not coded
IDE01996-ENG118301-Installation list: specified installations-Node_0x83,Not coded
IDE01996-ENG118302-Installation list: specified installations-Node_0x85,Not coded
IDE01996-ENG118303-Installation list: specified installations-Node_0x86,Not coded
IDE01996-ENG118304-Installation list: specified installations-Node_0x87,Not coded
IDE01996-ENG118305-Installation list: specified installations-Node_0x88,Not coded
IDE01996-ENG118306-Installation list: specified installations-Node_0x89,Not coded
IDE01996-ENG118307-Installation list: specified installations-Node_0x8B,Not coded
IDE01996-ENG118308-Installation list: specified installations-Node_0x8C,Not coded
IDE01996-ENG118309-Installation list: specified installations-Node_0x8D,Not coded
IDE01996-ENG118310-Installation list: specified installations-Node_0x8E,Not coded
IDE01996-ENG118311-Installation list: specified installations-Node_0x8F,Not coded
IDE01996-ENG118312-Installation list: specified installations-Node_0x90,Not coded
IDE01996-ENG118313-Installation list: specified installations-Node_0x91,Not coded
IDE01996-ENG118314-Installation list: specified installations-Node_0x92,Not coded
IDE01996-ENG118315-Installation list: specified installations-Node_0x93,Not coded
IDE01996-ENG118316-Installation list: specified installations-Node_0x94,Not coded
IDE01996-ENG118317-Installation list: specified installations-Node_0x95,Not coded
IDE01996-ENG118318-Installation list: specified installations-Node_0x96,Not coded
IDE01996-ENG118319-Installation list: specified installations-Node_0x97,Not coded
IDE01996-ENG118320-Installation list: specified installations-Node_0x98,Not coded
IDE01996-ENG118321-Installation list: specified installations-Node_0x99,Not coded
IDE01996-ENG118322-Installation list: specified installations-Node_0x9A,Not coded
IDE01996-ENG118323-Installation list: specified installations-Node_0x9B,Not coded
IDE01996-ENG118324-Installation list: specified installations-Node_0x9C,Not coded
IDE01996-ENG118325-Installation list: specified installations-Node_0x9D,Not coded
IDE01996-ENG118326-Installation list: specified installations-Node_0x9E,Not coded
IDE01996-ENG118327-Installation list: specified installations-Node_0x9F,Not coded
IDE01996-ENG118328-Installation list: specified installations-Node_0xA0,Not coded
IDE01996-ENG118329-Installation list: specified installations-Node_0xA1,Not coded
IDE01996-ENG118330-Installation list: specified installations-Node_0xA2,Not coded
IDE01996-ENG118331-Installation list: specified installations-Node_0xA3,Not coded
IDE01996-ENG118333-Installation list: specified installations-Node_0xA5,Not coded
IDE01996-ENG118334-Installation list: specified installations-Node_0xA6,Not coded
IDE01996-ENG118335-Installation list: specified installations-Node_0xA7,Not coded
IDE01996-ENG118336-Installation list: specified installations-Node_0xA8,Not coded
IDE01996-ENG118338-Installation list: specified installations-Node_0xAA,Not coded
IDE01996-ENG118339-Installation list: specified installations-Node_0xAB,Not coded
IDE01996-ENG118340-Installation list: specified installations-Node_0xAC,Not coded
IDE01996-ENG118341-Installation list: specified installations-Node_0xAD,Not coded
IDE01996-ENG118343-Installation list: specified installations-Node_0xAF,Not coded
IDE01996-ENG118344-Installation list: specified installations-Node_0xB0,Not coded
IDE01996-ENG118345-Installation list: specified installations-Node_0xB1,Not coded
IDE01996-ENG118346-Installation list: specified installations-Node_0xB2,Not coded
IDE01996-ENG118347-Installation list: specified installations-Node_0xB3,Not coded
IDE01996-ENG118348-Installation list: specified installations-Node_0xB4,Not coded
IDE01996-ENG118349-Installation list: specified installations-Node_0xB5,Not coded
IDE01996-ENG118350-Installation list: specified installations-Node_0xB6,Not coded
IDE01996-ENG118351-Installation list: specified installations-Node_0xB7,Not coded
IDE01996-ENG118352-Installation list: specified installations-Node_0xB8,Not coded
IDE01996-ENG118353-Installation list: specified installations-Node_0xB9,Not coded
IDE01996-ENG118354-Installation list: specified installations-Node_0xBA,Not coded
IDE01996-ENG118355-Installation list: specified installations-Node_0xBB,Not coded
IDE01996-ENG118356-Installation list: specified installations-Node_0xBC,Not coded
IDE01996-ENG118357-Installation list: specified installations-Node_0xBD,Not coded
IDE01996-ENG118358-Installation list: specified installations-Node_0xBE,Not coded
IDE01996-ENG118359-Installation list: specified installations-Node_0xBF,Not coded
IDE01996-ENG118360-Installation list: specified installations-Node_0xC0,Not coded
IDE01996-ENG118361-Installation list: specified installations-Node_0xC1,Not coded
IDE01996-ENG118362-Installation list: specified installations-Node_0xC2,Not coded
IDE01996-ENG118363-Installation list: specified installations-Node_0xC3,Not coded
IDE01996-ENG118364-Installation list: specified installations-Node_0xC4,Not coded
IDE01996-ENG118365-Installation list: specified installations-Node_0xC5,Not coded
IDE01996-ENG118366-Installation list: specified installations-Node_0xC6,Not coded
IDE01996-ENG118367-Installation list: specified installations-Node_0xC7,Not coded
IDE01996-ENG118368-Installation list: specified installations-Node_0xC8,Not coded
IDE01996-ENG118369-Installation list: specified installations-Node_0xC9,Not coded
IDE01996-ENG118370-Installation list: specified installations-Node_0xCA,Not coded
IDE01996-ENG118371-Installation list: specified installations-Node_0xCB,Not coded
IDE01996-ENG118372-Installation list: specified installations-Node_0xCC,Not coded
IDE01996-ENG118373-Installation list: specified installations-Node_0xCD,Not coded
IDE01996-ENG118374-Installation list: specified installations-Node_0xCE,Not coded
IDE01996-ENG118375-Installation list: specified installations-Node_0xCF,Not coded
IDE01996-ENG118376-Installation list: specified installations-Node_0xD0,Not coded
IDE01996-ENG118377-Installation list: specified installations-Node_0xD1,Not coded
IDE01996-ENG118378-Installation list: specified installations-Node_0xD2,Not coded
IDE01996-ENG118379-Installation list: specified installations-Node_0xD3,Not coded
IDE01996-ENG118380-Installation list: specified installations-Node_0xD4,Not coded
IDE01996-ENG118381-Installation list: specified installations-Node_0xD5,Not coded
IDE01996-ENG118382-Installation list: specified installations-Node_0xD6,Not coded
IDE01996-ENG118383-Installation list: specified installations-Node_0xD7,Not coded
IDE01996-ENG118384-Installation list: specified installations-Node_0xD8,Not coded
IDE01996-ENG118385-Installation list: specified installations-Node_0xD9,Not coded
IDE01996-ENG118386-Installation list: specified installations-Node_0xDA,Not coded
IDE01996-ENG118387-Installation list: specified installations-Node_0xDB,Not coded
IDE01996-ENG118388-Installation list: specified installations-Node_0xDC,Not coded
IDE01996-ENG118389-Installation list: specified installations-Node_0xDD,Not coded
IDE01996-ENG118390-Installation list: specified installations-Node_0xDE,Not coded
IDE01996-ENG118391-Installation list: specified installations-Node_0xDF,Not coded
IDE01996-ENG118392-Installation list: specified installations-Node_0xE0,Not coded
IDE01996-ENG118393-Installation list: specified installations-Node_0xE1,Not coded
IDE01996-ENG118394-Installation list: specified installations-Node_0xE2,Not coded
IDE01996-ENG118395-Installation list: specified installations-Node_0xE3,Not coded
IDE01996-ENG118396-Installation list: specified installations-Node_0xE4,Not coded
IDE01996-ENG118397-Installation list: specified installations-Node_0xE5,Not coded
IDE01996-ENG118398-Installation list: specified installations-Node_0xE6,Not coded
IDE01996-ENG118399-Installation list: specified installations-Node_0xE7,Not coded
IDE01996-ENG118400-Installation list: specified installations-Node_0xE8,Not coded
IDE01996-ENG118401-Installation list: specified installations-Node_0xE9,Not coded
IDE01996-ENG118402-Installation list: specified installations-Node_0xEA,Not coded
IDE01996-ENG118403-Installation list: specified installations-Node_0xEB,Not coded
IDE01996-ENG118404-Installation list: specified installations-Node_0xEC,Not coded
IDE01996-ENG118405-Installation list: specified installations-Node_0xED,Not coded
IDE01996-ENG118406-Installation list: specified installations-Node_0xEE,Not coded
IDE01996-ENG118407-Installation list: specified installations-Node_0xEF,Not coded
IDE01996-ENG118408-Installation list: specified installations-Node_0xF0,Not coded
IDE01996-ENG118409-Installation list: specified installations-Node_0xF1,Not coded
IDE01996-ENG118410-Installation list: specified installations-Node_0xF2,Not coded
IDE01996-ENG118411-Installation list: specified installations-Node_0xF3,Not coded
IDE01996-ENG118412-Installation list: specified installations-Node_0xF4,Not coded
IDE01996-ENG118413-Installation list: specified installations-Node_0xF5,Not coded
IDE01996-ENG118414-Installation list: specified installations-Node_0xF6,Not coded
IDE01996-ENG118415-Installation list: specified installations-Node_0xF7,Not coded
IDE01996-ENG118416-Installation list: specified installations-Node_0xF8,Not coded
IDE01996-ENG118417-Installation list: specified installations-Node_0xF9,Not coded
IDE01996-ENG118418-Installation list: specified installations-Node_0xFA,Not coded
IDE01996-ENG118419-Installation list: specified installations-Node_0xFB,Not coded
IDE01996-ENG118420-Installation list: specified installations-Node_0xFC,Not coded
IDE01996-ENG118421-Installation list: specified installations-Node_0xFD,Not coded
IDE01996-ENG118422-Installation list: specified installations-Node_0xFE,Not coded
IDE01996-ENG118423-Installation list: specified installations-Node_0xFF,Not coded
IDE02200-Component protection showroom mode,not active
IDE02332-Deactivate production mode,0
IDE03256-MAS06105-Battery adaptation-Rated battery capacity,68 Ah
IDE03256-MAS06106-Battery adaptation-Battery technology,Fleece
IDE03256-MAS06107-Battery adaptation-Battery manufacturer,JCB
IDE03256-MAS06108-Battery adaptation-Battery Serial Number,1111111111
IDE03903-Production process data 1,00 00
IDE04159-Deactivation of start-stop function,Mode not active
IDE04186-Battery terminal recognition,connected
IDE04330-Transfer of release code for a SWaP function,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE04331-Selection of release codes for a SWaP function,FF FF FF FF
IDE06425-MAS06026-Roller test bench mode: functional-Activation stages,not activated
IDE06425-MAS06277-Roller test bench mode: functional-Malfunction states,no error
IDE06530-Distance left for deactivation of static current measuring mode,2
IDE06541-Distance left for deactivation of transport mode,50
IDE06753-MAS06278-Efficiency program display-Live tip air resistance: close window/sunroof,activated
IDE06753-MAS06279-Efficiency program display-Live tip engine brake: uncouple not until below 1300 RPM,activated
IDE06753-MAS06280-Efficiency program display-Live tip do not operate gas pedal during engine start,activated
IDE06753-MAS06281-Efficiency program display-Live tip adhere to switch display (only manual switch),activated
IDE06753-MAS06282-Efficiency program display-Live tip use start-stop-system,activated
IDE06753-MAS06283-Efficiency program display-Live tip switch on start-stop-system,activated
IDE06753-MAS06284-Efficiency program display-Live tip air conditioning: close window/sunroof,not activated
IDE06753-MAS06285-Efficiency program display-Live tip use gearshift position D,activated
IDE06753-MAS06286-Efficiency program display-Live tip Do not press accelerator pedal at standstill,activated
IDE06753-MAS06287-Efficiency program display-Live tip sunroof open: switch of A/C (AC button),activated
IDE06753-MAS06288-Efficiency program display-Live tip avoid engine warm-up at standstill,activated
IDE06753-MAS06289-Efficiency program display-Comfort use A/C,activated
IDE06753-MAS06290-Efficiency program display-Comfort use parking heater,activated
IDE06753-MAS06291-Efficiency program display-Comfort use rear window heater,activated
IDE06753-MAS06292-Efficiency program display-Comfort use front seat heater,activated
IDE06753-MAS06293-Efficiency program display-Comfort use front seat ventilation,activated
IDE06753-MAS06294-Efficiency program display-Comfort use rear heater,activated
IDE06753-MAS06295-Efficiency program display-Comfort use fog light,activated
IDE06753-MAS06296-Efficiency program display-Comfort use rear fog light,not activated
IDE06753-MAS06297-Efficiency program display-Comfort use parking heater consumption emission,activated
IDE06753-MAS06298-Efficiency program display-Comfort use windshield heater,activated
IDE06753-MAS06299-Efficiency program display-Comfort use steering wheel heater,activated
IDE06753-MAS06300-Efficiency program display-Comfort use mirror heater,activated
IDE06753-MAS06301-Efficiency program display-Comfort use rear seat heater,not activated
IDE06753-MAS06302-Efficiency program display-Comfort use rear seat ventilation,activated
IDE07838-Counter for inconsistent states,0
IDE08348-Start/stop start voltage limit,7.6 V
IDE08624-MKE Check box,activated
IDE10736-Cyclization limitation request battery service,0
IDE10748-MAS11262-Range gain-Range gain AC system,activated
IDE10748-MAS11263-Range gain-Range gain auxiliary heater,activated
IDE10748-MAS11264-Range gain-Range gain window defogger,activated
IDE10748-MAS11265-Range gain-Range gain seat heater front,activated
IDE10748-MAS11266-Range gain-Range gain front set ventilation,activated
IDE10748-MAS11267-Range gain-Range gain rear heater,activated
IDE10748-MAS11268-Range gain-Range gain fog light,activated
IDE10748-MAS11269-Range gain-Range gain rear fog light,activated
IDE10748-MAS11270-Range gain-Range gain windshield heating,activated
IDE10748-MAS11271-Range gain-Range gain steering wheel heater,activated
IDE10748-MAS11272-Range gain-Range gain mirror heater,activated
IDE10748-MAS11273-Range gain-Range gain rear seat heater,activated
IDE10748-MAS11274-Range gain-Range gain rear seat heater,activated
IDE10748-MAS11275-Range gain-Windshield heater consumption in AC system,not activated
IDE10748-MAS11276-Range gain-Windshield heater range gain in AC system,not activated
IDE10748-MAS11277-Range gain-PTC(low voltage) consumption,not activated
IDE10748-MAS11278-Range gain-PTC(low voltage) range gain,not activated
IDE10748-MAS11279-Range gain-List at engine still stand,activated
IDE10748-MAS12689-Range gain-Catalogue range display,activated
IDE10748-MAS12690-Range gain-Loading condition catalogue range display,activated
IDE10748-MAS13161-Range gain-Listendarstellung Absolutwerte mit Gewichtung,not activated
ENG125878-ENG125896-AGW_Calibration-AGW_Brightness_Start_Sequence,100 %
ENG125878-ENG126255-AGW_Calibration-AGW_fade_in_deactivation_threshold,100
ENG125878-ENG125890-AGW_Calibration-AGW_Time_Fade_In,0 ms
ENG125878-ENG125892-AGW_Calibration-AGW_Time_Fade_In_Start,0 ms
ENG125878-ENG125891-AGW_Calibration-AGW_Time_Fade_Out,0 ms
ENG125878-ENG125893-AGW_Calibration-AGW_Time_Fade_Out_Start,0 ms
ENG125878-ENG125895-AGW_Calibration-AGW_Time_Start_Delay,0 ms
ENG125878-ENG125894-AGW_Calibration-AGW_Time_Start_Sequence,0 ms
ENG125879-ENG125897-AGW_Function_Releases-AGW_Enabling_Brightness,active
ENG125879-ENG125898-AGW_Function_Releases-AGW_Enabling_Flash_Frequency,active
ENG125879-ENG125899-AGW_Function_Releases-AGW_Enabling_Supression_Symbol,active
ENG118777-ENG118712-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Counter_Master_Reset,active
ENG118777-ENG118710-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Limit_Adaptation,100
ENG118777-ENG118711-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Lock_Adaptation,60000 ms
ENG118777-ENG118709-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Time_Adaptation,10000 ms
ENG118777-ENG118705-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Indication_Control_Adaption,3000 ms
ENG118777-ENG118706-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Kombi_Offset_Adaption,0 ms
ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation,180000 ms
ENG118777-ENG118707-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Sync_Time_Adaptation,1500 ms
ENG118777-ENG118703-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation,800 ms
ENG118777-ENG118704-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Touch_Contact_Time_Adaption,2500 ms
ENG05988-ENG113874-EM_energy_management_warning_displays-Batteriemeldungen,Mode not active
ENG05988-ENG98711-EM_energy_management_warning_displays-Charge level,Mode not active
ENG05988-ENG113873-EM_energy_management_warning_displays-Generatormeldungen,Mode not active
ENG05988-ENG118686-EM_energy_management_warning_displays-MMI Vorwarnungen,Mode not active
ENG06003-EM_heating_power_quota_adjustment,1000 W
ENG05989-EM_nominal_voltage_limitation_low_beams,12.1 V
ENG05992-EM_requirement_cyclic_time_voltage_measurement,0 s
ENG05991-EM_requirement_reduction_air_blowers,Mode not active
ENG05990-ENG100689-EM_start_stop_requirement_ambient_temperature-Maximum_temperature,-50.0 °C
ENG05990-ENG06027-EM_start_stop_requirement_ambient_temperature-Minimum_temperature,-50.0 °C
ENG05986-SFT00001-GW_Enable_CAN_Timeout_DTC-Engine Control Module 1,Enabled
ENG05986-SFT00002-GW_Enable_CAN_Timeout_DTC-Transmission Control Module,Enabled
ENG05986-SFT00003-GW_Enable_CAN_Timeout_DTC-Brakes 1,not enabled
ENG05986-SFT00006-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Passenger Side,Enabled
ENG05986-SFT00008-GW_Enable_CAN_Timeout_DTC-Air Conditioning,Enabled
ENG05986-SFT00009-GW_Enable_CAN_Timeout_DTC-Central Electrics,Enabled
ENG05986-SFT00014-GW_Enable_CAN_Timeout_DTC-Media Player Position 1,Enabled
ENG05986-SFT00019-GW_Enable_CAN_Timeout_DTC-Adaptive Cruise Control,Enabled
ENG05986-SFT00020-GW_Enable_CAN_Timeout_DTC-Wheel Dampening Electronics,Enabled
ENG05986-SFT00021-GW_Enable_CAN_Timeout_DTC-Airbag,not enabled
ENG05986-SFT00022-GW_Enable_CAN_Timeout_DTC-Steering Column Electronics,Enabled
ENG05986-SFT00023-GW_Enable_CAN_Timeout_DTC-Dash Board,Enabled
ENG05986-SFT00024-GW_Enable_CAN_Timeout_DTC-Auxiliary Parking Heater,Enabled
ENG05986-SFT00025-GW_Enable_CAN_Timeout_DTC-Gateway,Enabled
ENG05986-SFT00028-GW_Enable_CAN_Timeout_DTC-Vehicle Position Detection,Enabled
ENG05986-SFT00032-GW_Enable_CAN_Timeout_DTC-High Beam Assistance,Enabled
ENG05986-SFT00034-GW_Enable_CAN_Timeout_DTC-All Wheel Control,Enabled
ENG05986-SFT00035-GW_Enable_CAN_Timeout_DTC-Brake Boost,Enabled
ENG05986-SFT00038-GW_Enable_CAN_Timeout_DTC-Electronic Roof Control,Enabled
ENG05986-SFT00043-GW_Enable_CAN_Timeout_DTC-Steering Column Locking,Enabled
ENG05986-SFT00048-GW_Enable_CAN_Timeout_DTC-Special Function 2,Enabled
ENG05986-SFT00050-GW_Enable_CAN_Timeout_DTC-Lock Electronics,Enabled
ENG05986-SFT00054-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Driver Side,Enabled
ENG05986-SFT00060-GW_Enable_CAN_Timeout_DTC-Lane Change Assistant,Enabled
ENG05986-SFT00061-GW_Enable_CAN_Timeout_DTC-Special Function,Enabled
ENG05986-SFT00064-GW_Enable_CAN_Timeout_DTC-Air Conditioning Compressor,Enabled
ENG05986-SFT00066-GW_Enable_CAN_Timeout_DTC-Door Electronics Driver Side,Enabled
ENG05986-SFT00068-GW_Enable_CAN_Timeout_DTC-Steering Assistance,Enabled
ENG05986-SFT00071-GW_Enable_CAN_Timeout_DTC-Sound System,Enabled
ENG05986-SFT00081-GW_Enable_CAN_Timeout_DTC-Drive Motor Control Module,Enabled
ENG05986-SFT00082-GW_Enable_CAN_Timeout_DTC-Door Electronics Passenger Side,Enabled
ENG05986-SFT00085-GW_Enable_CAN_Timeout_DTC-Headlight Regulation,Enabled
ENG05986-SFT00086-GW_Enable_CAN_Timeout_DTC-Radio,Enabled
ENG05986-SFT00087-GW_Enable_CAN_Timeout_DTC-TV Tuner,Enabled
ENG05986-SFT00095-GW_Enable_CAN_Timeout_DTC-Information Control Unit 1,Enabled
ENG05986-SFT00096-GW_Enable_CAN_Timeout_DTC-Tachograph,Enabled
ENG05986-SFT00101-GW_Enable_CAN_Timeout_DTC-Tire Pressure Monitoring 1,Enabled
ENG05986-SFT00105-GW_Enable_CAN_Timeout_DTC-Trailer Function,Enabled
ENG05986-SFT00108-GW_Enable_CAN_Timeout_DTC-Camera System Rear View,Enabled
ENG05986-SFT00109-GW_Enable_CAN_Timeout_DTC-Deck Lid Control Unit,Enabled
ENG05986-SFT00117-GW_Enable_CAN_Timeout_DTC-Telematics Communication Unit,Enabled
ENG05986-SFT00118-GW_Enable_CAN_Timeout_DTC-Parking Assistance,Enabled
ENG05986-SFT00140-GW_Enable_CAN_Timeout_DTC-Battery Energy Control Module,Enabled
ENG05986-SFT00165-GW_Enable_CAN_Timeout_DTC-Front Sensors Driver Assistance System,Enabled
ENG05986-SFT00166-GW_Enable_CAN_Timeout_DTC-Microphone Control Unit,Enabled
ENG05986-SFT00169-GW_Enable_CAN_Timeout_DTC-Actuator For Structure-borne Sound,Enabled
ENG05986-SFT00183-GW_Enable_CAN_Timeout_DTC-Access Startsystem Interface,Enabled
ENG05986-SFT00187-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Driver Side,Enabled
ENG05986-SFT00188-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Passenger Side,Enabled
ENG05986-SFT00189-GW_Enable_CAN_Timeout_DTC-High Voltage Battery Charge Management,Enabled
ENG05986-SFT00190-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Left,Enabled
ENG05986-SFT00191-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Right,Enabled
ENG05986-SFT00192-GW_Enable_CAN_Timeout_DTC-Actuator For Exterior Noise,Enabled
ENG05986-SFT00197-GW_Enable_CAN_Timeout_DTC-Thermal management,Enabled
ENG05986-SFT00198-GW_Enable_CAN_Timeout_DTC-Battery Charger Control Module,Enabled
ENG05986-SFT00202-GW_Enable_CAN_Timeout_DTC-Control module for sunroof,Enabled
ENG05986-SFT09787-GW_Enable_CAN_Timeout_DTC-Lane Change Assistant 2,Enabled
ENG05986-ENG118664-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x00,Enabled
ENG05986-ENG118466-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x01,Enabled
ENG05986-ENG118467-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x02,Enabled
ENG05986-ENG118468-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x03,Enabled
ENG05986-ENG118469-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x04,Enabled
ENG05986-ENG118470-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x05,Enabled
ENG05986-ENG118471-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x06,Enabled
ENG05986-ENG118472-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x07,Enabled
ENG05986-ENG118473-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x08,Enabled
ENG05986-ENG118474-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x09,Enabled
ENG05986-ENG118475-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x0D,Enabled
ENG05986-ENG118476-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x11,Enabled
ENG05986-ENG118477-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x16,Enabled
ENG05986-ENG118478-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x17,Enabled
ENG05986-ENG118479-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1A,Enabled
ENG05986-ENG118480-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1B,Enabled
ENG05986-ENG118481-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1D,Enabled
ENG05986-ENG118482-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1F,Enabled
ENG05986-ENG118483-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x20,Enabled
ENG05986-ENG118484-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x21,Enabled
ENG05986-ENG118485-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x22,Enabled
ENG05986-ENG118486-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x24,Enabled
ENG05986-ENG118487-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x25,Enabled
ENG05986-ENG118488-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x26,Enabled
ENG05986-ENG118489-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x27,Enabled
ENG05986-ENG118490-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x28,Enabled
ENG05986-ENG118491-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x29,Enabled
ENG05986-ENG118492-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2A,Enabled
ENG05986-ENG118493-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2E,Enabled
ENG05986-ENG118494-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2F,Enabled
ENG05986-ENG118495-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x35,Enabled
ENG05986-ENG118496-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x36,Enabled
ENG05986-ENG118497-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x37,Enabled
ENG05986-ENG118498-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x38,Enabled
ENG05986-ENG118499-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x39,Enabled
ENG05986-ENG118500-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3A,Enabled
ENG05986-ENG118501-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3C,Enabled
ENG05986-ENG118502-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3D,Enabled
ENG05986-ENG118503-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x40,Enabled
ENG05986-ENG118504-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x41,Enabled
ENG05986-ENG118505-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x43,Enabled
ENG05986-ENG118506-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x45,Enabled
ENG05986-ENG118507-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x48,Enabled
ENG05986-ENG118508-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x49,Enabled
ENG05986-ENG118509-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x51,Enabled
ENG05986-ENG118510-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x52,Enabled
ENG05986-ENG118511-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x53,Enabled
ENG05986-ENG118512-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x55,Enabled
ENG05986-ENG118513-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x56,Enabled
ENG05986-ENG118514-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x58,Enabled
ENG05986-ENG118515-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x59,Enabled
ENG05986-ENG118516-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5A,Enabled
ENG05986-ENG118517-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5B,Enabled
ENG05986-ENG118518-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5C,Enabled
ENG05986-ENG118519-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5D,Enabled
ENG05986-ENG118520-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5E,Enabled
ENG05986-ENG118521-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5F,Enabled
ENG05986-ENG118522-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x60,Enabled
ENG05986-ENG118523-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x61,Enabled
ENG05986-ENG118524-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x62,Enabled
ENG05986-ENG118525-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x66,Enabled
ENG05986-ENG118526-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x68,Enabled
ENG05986-ENG118527-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6B,Enabled
ENG05986-ENG118528-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6C,Enabled
ENG05986-ENG118529-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6E,Enabled
ENG05986-ENG118530-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x74,Enabled
ENG05986-ENG118531-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x75,Enabled
ENG05986-ENG118532-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x78,Enabled
ENG05986-ENG118533-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x79,Enabled
ENG05986-ENG118534-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7A,Enabled
ENG05986-ENG118535-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7D,Enabled
ENG05986-ENG118536-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7E,Enabled
ENG05986-ENG118537-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7F,Enabled
ENG05986-ENG118538-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x80,Enabled
ENG05986-ENG118539-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x81,Enabled
ENG05986-ENG118540-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x82,Enabled
ENG05986-ENG118541-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x83,Enabled
ENG05986-ENG118542-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x85,Enabled
ENG05986-ENG118543-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x86,Enabled
ENG05986-ENG118544-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x87,Enabled
ENG05986-ENG118545-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x88,Enabled
ENG05986-ENG118546-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x89,Enabled
ENG05986-ENG118547-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8B,Enabled
ENG05986-ENG118548-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8C,Enabled
ENG05986-ENG118549-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8D,Enabled
ENG05986-ENG118550-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8E,Enabled
ENG05986-ENG118551-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8F,Enabled
ENG05986-ENG118552-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x90,Enabled
ENG05986-ENG118553-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x91,Enabled
ENG05986-ENG118554-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x92,Enabled
ENG05986-ENG118555-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x93,Enabled
ENG05986-ENG118556-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x94,Enabled
ENG05986-ENG118557-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x95,Enabled
ENG05986-ENG118558-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x96,Enabled
ENG05986-ENG118559-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x97,Enabled
ENG05986-ENG118560-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x98,Enabled
ENG05986-ENG118561-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x99,Enabled
ENG05986-ENG118562-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9A,Enabled
ENG05986-ENG118563-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9B,Enabled
ENG05986-ENG118564-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9C,Enabled
ENG05986-ENG118565-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9D,Enabled
ENG05986-ENG118566-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9E,Enabled
ENG05986-ENG118567-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9F,Enabled
ENG05986-ENG118568-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA0,Enabled
ENG05986-ENG118569-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA1,Enabled
ENG05986-ENG118570-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA2,Enabled
ENG05986-ENG118571-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA3,Enabled
ENG05986-ENG118572-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA4,Enabled
ENG05986-ENG118573-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA5,Enabled
ENG05986-ENG118574-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA6,Enabled
ENG05986-ENG118575-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA7,Enabled
ENG05986-ENG118576-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA8,Enabled
ENG05986-ENG118577-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA9,Enabled
ENG05986-ENG118578-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAA,Enabled
ENG05986-ENG118579-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAB,Enabled
ENG05986-ENG118580-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAC,Enabled
ENG05986-ENG118581-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAD,Enabled
ENG05986-ENG118582-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAE,Enabled
ENG05986-ENG118583-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAF,Enabled
ENG05986-ENG118584-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB0,Enabled
ENG05986-ENG118585-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB1,Enabled
ENG05986-ENG118586-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB2,Enabled
ENG05986-ENG118587-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB3,Enabled
ENG05986-ENG118588-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB4,Enabled
ENG05986-ENG118589-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB5,Enabled
ENG05986-ENG118590-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB6,Enabled
ENG05986-ENG118591-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB7,Enabled
ENG05986-ENG118592-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB8,Enabled
ENG05986-ENG118593-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB9,Enabled
ENG05986-ENG118594-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBA,Enabled
ENG05986-ENG118595-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBB,Enabled
ENG05986-ENG118596-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBC,Enabled
ENG05986-ENG118597-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBD,Enabled
ENG05986-ENG118598-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBE,Enabled
ENG05986-ENG118599-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBF,Enabled
ENG05986-ENG118600-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC0,Enabled
ENG05986-ENG118601-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC1,Enabled
ENG05986-ENG118602-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC2,Enabled
ENG05986-ENG118603-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC3,Enabled
ENG05986-ENG118604-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC4,Enabled
ENG05986-ENG118605-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC5,Enabled
ENG05986-ENG118606-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC6,Enabled
ENG05986-ENG118607-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC7,Enabled
ENG05986-ENG118608-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC8,Enabled
ENG05986-ENG118609-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC9,Enabled
ENG05986-ENG118610-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCA,Enabled
ENG05986-ENG118611-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCB,Enabled
ENG05986-ENG118612-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCC,Enabled
ENG05986-ENG118613-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCD,Enabled
ENG05986-ENG118614-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCE,Enabled
ENG05986-ENG118615-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCF,Enabled
ENG05986-ENG118616-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD0,Enabled
ENG05986-ENG118617-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD1,Enabled
ENG05986-ENG118618-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD2,Enabled
ENG05986-ENG118619-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD3,Enabled
ENG05986-ENG118620-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD4,Enabled
ENG05986-ENG118621-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD5,Enabled
ENG05986-ENG118622-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD6,Enabled
ENG05986-ENG118623-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD7,Enabled
ENG05986-ENG118624-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD8,Enabled
ENG05986-ENG118625-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD9,Enabled
ENG05986-ENG118626-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDA,Enabled
ENG05986-ENG118627-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDB,Enabled
ENG05986-ENG118628-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDC,Enabled
ENG05986-ENG118629-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDD,Enabled
ENG05986-ENG118630-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDE,Enabled
ENG05986-ENG118631-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDF,Enabled
ENG05986-ENG118632-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE0,Enabled
ENG05986-ENG118633-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE1,Enabled
ENG05986-ENG118634-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE2,Enabled
ENG05986-ENG118635-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE3,Enabled
ENG05986-ENG118636-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE4,Enabled
ENG05986-ENG118637-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE5,Enabled
ENG05986-ENG118638-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE6,Enabled
ENG05986-ENG118639-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE7,Enabled
ENG05986-ENG118640-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE8,Enabled
ENG05986-ENG118641-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE9,Enabled
ENG05986-ENG118642-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEA,Enabled
ENG05986-ENG118643-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEB,Enabled
ENG05986-ENG118644-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEC,Enabled
ENG05986-ENG118645-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xED,Enabled
ENG05986-ENG118646-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEE,Enabled
ENG05986-ENG118647-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEF,Enabled
ENG05986-ENG118648-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF0,Enabled
ENG05986-ENG118649-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF1,Enabled
ENG05986-ENG118650-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF2,Enabled
ENG05986-ENG118651-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF3,Enabled
ENG05986-ENG118652-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF4,Enabled
ENG05986-ENG118653-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF5,Enabled
ENG05986-ENG118654-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF6,Enabled
ENG05986-ENG118655-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF7,Enabled
ENG05986-ENG118656-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF8,Enabled
ENG05986-ENG118657-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF9,Enabled
ENG05986-ENG118658-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFA,Enabled
ENG05986-ENG118659-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFB,Enabled
ENG05986-ENG118660-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFC,Enabled
ENG05986-ENG118661-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFD,Enabled
ENG05986-ENG118662-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFE,Enabled
ENG05986-ENG118663-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFF,Enabled
ENG05987-ENG118464-GW_mirror_mode-mirror_mode_bus,Databus drivetrain
ENG05987-ENG118465-GW_mirror_mode-mirror_mode_typ,not active
ENG05993-GW_routing_0,00 00 00 00 00 00 00 00 00 00 00 00
ENG05994-GW_routing_1,00 00 00 00 00 00 00 00 00 00 00 00
ENG05995-GW_routing_2,00 00 00 00 00 00 00 00 00 00 00 00
ENG05996-GW_routing_3,00 00 00 00 00 00 00 00 00 00 00 00
ENG05997-GW_routing_4,00 00 00 00 00 00 00 00 00 00 00 00
ENG05998-GW_routing_5,00 00 00 00 00 00 00 00 00 00 00 00
ENG05999-GW_routing_6,00 00 00 00 00 00 00 00 00 00 00 00
ENG06000-GW_routing_7,00 00 00 00 00 00 00 00 00 00 00 00
ENG06001-GW_routing_8,00 00 00 00 00 00 00 00 00 00 00 00
ENG06002-GW_routing_9,00 00 00 00 00 00 00 00 00 00 00 00
ENG118774-WakeUpMonitor_Activation,activated
ENG118773-ENG99074-WakeUpMonitor_Configuration-Max_Num_Keeping_Awake_Events,100
ENG118773-ENG103852-WakeUpMonitor_Configuration-Sample_Time_Keeping_Awake_Events,12 s
ENG118773-ENG127936-WakeUpMonitor_Configuration-WakeUpMonitor_Start_Delay,0 s
adpmap-42-5Q4-959-593-E.CSV
;SW:5Q4-959-593-E HW:5Q4-959-593-B --- Door Elect, Driver
;Component:TSG FS 010 0031, Coding:00150120D000040000001100
;EV_DCUDriveSideEWMAXCONT,006001,EV_DCUDriveSideEWMAXCONT.rod
;Thursday,22,December,2016,12:39:18:57018
;VCDS Version: Release 16.8.4 (x64) Data version: 20161129 DS267.0
;VCID: C7971E107E73CE7AC8-8092
IDE00001-Production mode,00000000 00000000 00000000
IDE02332-Deactivate production mode,00000000 00000000 00000000
ENG117304-Patch_Code_Driver_Side_Rear,00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 22 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
ENG117297-Reversing_Threshold_Driver_Side_Front,90 %
ENG117299-Reversing_Threshold_Driver_Side_Rear,90 %
ENG117302-Window_Regulator_Supplier_Settings_Driver_Side_Rear_1,00 00 14 83 2B 14 F0 F0 F0 00 20 00 FC 7C 00 14 00 05 06 64 01 F4 32 0F 00 07 80 00 00 07 3F 80 00 B4 00 0C 00 0C 00 27 00 50 00 89 00 D1 01 29 01 7B 04 04 03 01 03 07 03 E8 0B B8 32 05 0F 2D 50 73 04 04 9A 3C 09 1A 36 63 00 83 E0 E7 04 4E 53 70 CA 00 03 00 0C 00 AF 01 6E 5A 01 90 85 07 D0 10 10 00 14 00 14 03 84 27 10 53 6D 03 00 10 80 0C 01 FF 9F FF 00 00 00 0A 01 00 00 00 9D 42
ENG117303-Window_Regulator_Supplier_Settings_Driver_Side_Rear_2,02 8A 02 26 14 EC FF 02 02 0A 02 01 00 0A 05 32 02 12 19 0A 00 05 F6 32 1E 0F 00 02 FE 05 05 FB 12 0D 00 00 00 00 FF 00 00 00 00 FF 00 23 00 19 1E 20 1E 64 D8 C4 F6 F1 28 1E 32 05 1E 00 00 32 03 19 0B 12 10 64 EC D8 FB F6 1E 14 32 05 0B 00 00 82 02 19 0D 16 14 64 D8 C4 F6 F1 28 1E 32 05 0D 00 0A 28 0A 0A 28 23 05 0A 28 1E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 97 8E
ENG117301-Window_Regulator_VW_Settings_Driver_Side_Rear,F6 00 F0 00 10 19 0F 03 F0 08 00 14 C8 00 00 00 01 A4 01 C2 09 64 23 C8 1E 00 32 32 01 90 00 00 00 00 00 00 00 AF 00 00 32 3C C8 00 4E 00 4D 79 64 64 32 60 D3 6D CF 64 1E 32 0A 0A 5B D9 6D CF 64 14 32 32 32 14 00 00 42 31 30 36 01 00 00 00 00 00 00 00 00 00 D3 27
adpmap-44-5Q0-909-144-S.CSV
;SW:5Q0-909-144-S HW:5Q0-909-144-R --- Steering Assist
;Component:EPS_MQB_ZFLS 126 1063, Coding:0103
;EV_SteerAssisMQB,012140,EV_SteerAssisMQB_VW31.rod
;Thursday,22,December,2016,12:39:39:57018
;VCID: C48D091C4F45E5622D-8090
IDE00820-Activating and deactivating all development messages,not active
IDE03724-Straight line running,active
IDE03734-Support power,100%
IDE04130-Characteristic curve of steering assistance,Driving profile selection button
IDE04555-Activation of pwr steering asst without engine running,not active
IDE05162-Software end stop,active
IDE06419-Driving profile switchover,Incremental: controlled over time
IDE07540-Download without rest bus,not active
IDE09571-RPM monitoring,active
MAS02080-XCP calibration protocol,not active
adpmap-52-5Q4-959-592-E.CSV
;SW:5Q4-959-592-E HW:5Q4-959-592-B --- Door Elect, Pass.
;Component:TSG BFS 010 0031, Coding:00150120D000040000001100
;EV_DCUPasseSideEWMAXCONT,006001,EV_DCUPasseSideEWMAXCONT.rod
;Thursday,22,December,2016,12:39:59:57018
;VCID: C68913147979D77233-8092
ENG117308-Patch_Code_Passenger_Side_Rear,00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 22 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
ENG117298-Reversing_Threshold_Passenger_Side_Front,90 %
ENG117300-Reversing_Threshold_Passenger_Side_Rear,90 %
ENG117306-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_1,00 00 14 83 2B 14 F0 F0 F0 00 20 00 FC 7C 00 14 00 05 06 64 01 F4 32 0F 00 07 80 00 00 07 3F 80 00 B4 00 0C 00 0C 00 27 00 50 00 89 00 D1 01 29 01 7B 04 04 03 01 03 07 03 E8 0B B8 32 05 0F 2D 50 73 04 04 9A 3C 09 1A 36 63 00 83 E0 E7 04 4E 53 70 CA 00 03 00 0C 00 0F 01 6E 5A 01 90 85 07 D0 10 10 00 14 00 14 03 84 27 10 53 6D 03 00 10 80 0C 01 FF 9F FF 00 00 00 0A 01 00 00 00 CE CA
ENG117307-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_2,02 8A 02 26 14 EC FF 02 02 0A 02 01 00 0A 05 32 02 12 19 0A 00 05 F6 32 1E 0F 00 02 FE 05 05 FB 12 0D 00 00 00 00 FF 00 00 00 00 FF 00 23 00 19 1E 20 1E 64 D8 C4 F6 F1 28 1E 32 05 1E 00 00 32 03 19 0B 12 10 64 EC D8 FB F6 1E 14 32 05 0B 00 00 82 02 19 0D 16 14 64 D8 C4 F6 F1 28 1E 32 05 0D 00 0A 28 0A 0A 28 23 05 0A 28 1E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 97 8E
ENG117305-Window_Regulator_VW_Settings_Passenger_Side_Rear,F6 00 F0 00 10 19 0F 03 F0 08 00 14 C8 00 00 00 01 A4 01 C2 09 64 23 C8 1E 00 32 32 01 90 00 00 00 00 00 00 00 AF 00 00 32 3C C8 00 4E 00 4D 79 00 00 32 60 D3 6D CF 64 1E 32 0A 0A 5B D9 6D CF 64 14 32 32 32 14 00 00 42 31 30 36 01 00 00 00 00 00 00 00 00 00 DE A1
Adpmap, advanced
Thursday,22,December,2016,12:42:10:57018
VCDS Version: 16.8.4.2 (x64)
Dealer/Shop Name:
VIN: TMBJG7NE0G01XXXXX License Plate:
Mileage: 29071km-18063mi Repair Order: M01
Address 01: Engine
Control Module Part Number: 04L 906 056 CL
Component and/or Version: R4 1.6l TDI H06 2506
Software Coding: 01114012432419090000
Work Shop Code: WSC 73430
VCID: F9F3A8E87807688A0E-80AC
Advanced Identification/FAZIT
Identification: DH1-00S
Revision: 22004001
Date: 03.02.16
Manufacturer number: UPS6
Test stand number: 1993
Flash Status
Programming Attempts(application): 0/1/1
Flash Date: ----.--.--
Misc.
Hardware number: 04L 907 445 B
Workshop System Name: 2D2D2
ASAM Dataset: EV_ECM16TDI03004L906056CL
ASAM Dataset Revision: 002006
Car Info
Chassis Number: TMBJG7NE0G01XXXXX
Engine code: CXXB
VCDS Info:
Labels: 04L-907-309-V1.clb
Readiness: No script available
ROD: EV_ECM16TDI03004L906056CL_VW37.rod
Address 03: ABS Brakes
Control Module Part Number: 3Q0 907 379 T
Component and/or Version: ESC H32 0393
Software Coding: 1C07629114290970007D060241C3243846289000608224F200400070C002
VCID: CB9F2220621B2A1AEC-809E
Serial number: 60256000000588
Identification: TT1-0AU
Revision: 00000000
Date: 25.01.16
Manufacturer number: 0502
Test stand number: 024C
Flash Status
Programming Attempts(application): 0/0
Flash Date: 00.01.01
Misc.
Hardware number: 3Q0 907 379 C
Workshop System Name: J104
Equipment/PR Code: FFFFFFFFFFFFFFFF
Dataset Number: -----------
Dataset Version: ----
ASAM Dataset: EV_Brake1UDSContiMK100ESP
ASAM Dataset Revision: 034033
VCDS Info:
Labels: 5Q0-907-379-ESP-V1.clb
ROD: EV_Brake1UDSContiMK100ESP_034_SK37.rod
Address 08: Auto HVAC
Control Module Part Number: 5E0 907 044 Q
Component and/or Version: Climatronic H04 1002
Software Coding: 02010104002100011005000000101000
VCID: B36F5AC01AEB52DA84-80E6
Identification: BHB-001
Revision: 00001K07
Date: 19.01.16
Manufacturer number: 0187
Test stand number: 0004
Flash Status
Programming Attempts(application): 1/0
Flash Date: 12.04.10
Misc.
Hardware number: 5E0 907 044 Q
Workshop System Name: J255
Dataset Version: 0000
ASAM Dataset: EV_ACClimaBHBVW37X
ASAM Dataset Revision: 004131
VCDS Info:
Labels: 5G0-907-044.clb
ROD: EV_ACClimaBHBVW37X_004_VW48.rod
Address 09: Cent. Elect.
Control Module Part Number: 5Q0 937 086 AH
Component and/or Version: BCM PQ37BOSCH 028 0162
Software Coding: 0C000842424702FB47E04000000407080000000000000000000000000000
VCID: 8005C50C1BDD394249-80D4
Serial number: 865823011601MN
Identification: RB8-658
Revision: --------
Date: 23.01.16
Manufacturer number: 3040
Test stand number: 01MN
Flash Status
Programming Attempts(application): 0/0/0
Programming Attempts(data): 1
Successful Attempts(data): 1
Flash Date: 00.00.00
Flash Tool Code(data): 00063 790 73430
Misc.
Hardware number: 5Q0 937 086 AH
Workshop System Name: J519
Equipment/PR Code: 000000009459368A
Dataset Number: 5E0063t____
Dataset Version: 0075
ASAM Dataset: EV_BodyContrModul1UDSBosc
ASAM Dataset Revision: 015002
Car Info
VCDS Info:
Labels: 5Q0-937-08X-MV1.clb
ROD: EV_BCMBOSCH_016_AU37.rod
Address 15: Airbags
Control Module Part Number: 3Q0 959 655 AS
Component and/or Version: Airbag VW20 013 0200
Software Coding: 98CCC000000000005C5400CC000800000065
VCID: 8F27F6305683563AC0-80DA
Serial number: 003SQP1ULJ1P
Identification: TS6-PTL
Revision: --------
Date: 25.01.16
Manufacturer number: B802
Test stand number: 5275
Flash Status
Flash Tool Code(data): 00000 790 73430
Misc.
Hardware number: 3Q0 959 655 AS
Workshop System Name: J234
Equipment/PR Code: 0000000000000000
Dataset Number: 5E0003t____
Dataset Version: 0057
ASAM Dataset: EV_AirbaVW20TS6VW48X
ASAM Dataset Revision: 001116
Car Info
VCDS Info:
Labels: 5Q0-959-655.clb
ROD: EV_AirbaVW20TS6VW48X.rod
Address 16: Steering wheel
Control Module Part Number: 5Q0 953 521 M
Component and/or Version: Lenks.Modul 075 0195
Software Coding: 1400
VCID: BC7D71FC37B59DA255-80E8
Serial number: 20160207400241
Identification: URB-001
Revision: FF033033
Date: 07.02.16
Manufacturer number: 0008
Test stand number: 1132
Flash Status
Programming Attempts(application): 1/0/0
Programming Attempts(data): 0/0
Successful Attempts(data): 0/0
Flash Date: 13.01.25
Flash Tool Code(data): 00000 000 00000
Misc.
Hardware number: 5Q0 953 569 A
Workshop System Name: J524
ASAM Dataset: EV_SMLSVALEOMQB
ASAM Dataset Revision: 001015
VCDS Info:
Labels: 5Q0-953-549.clb
ROD: EV_SMLSVALEOMQB.rod
Address 17: Instruments
Control Module Part Number: 5E0 920 781 B
Component and/or Version: KOMBI 206 7652
Software Coding: 07A40A002180000801082A001000000000000000
VCID: A757BE90DE332E7A28-80F2
Identification: WJ3-NVO
Date: 08.02.16
Manufacturer number: 2001
Test stand number: 0045
Flash Status
Flash Date: 14.11.21
Misc.
Hardware number: 5E0 920 781 B
Workshop System Name: J285
ASAM Dataset: EV_DashBoardJCIMQBAB
ASAM Dataset Revision: 009005
Car Info
VCDS Info:
Labels: 5G0-920-XXX-17.clb
ROD: EV_DashBoardJCIMQBAB_VW48.rod
Address 19: CAN Gateway
Control Module Part Number: 5Q0 907 530 AH
Component and/or Version: GW MQB Mid 127 1244
Software Coding: 030100045F087300EB000248080F00010001050000000000000000000000
VCID: F7F7AED04E137EFA78-80A2
Serial number: 0004436045
Identification: LCE-RAB
Revision: --------
Date: 19.01.16
Manufacturer number: 0001
Test stand number: 6045
Flash Status
Programming Attempts(application): 1/1
Successful Attempts(application): 1/1
Programming Attempts(data): 2
Successful Attempts(data): 2
Misc.
Hardware number: 5Q0 907 530 E
Workshop System Name: J533
Equipment/PR Code: 0000000038B70370
Dataset Number: 3V0067t____
Dataset Version: 0015
ASAM Dataset: EV_GatewLear
ASAM Dataset Revision: 013020
Car Info
VCDS Info:
Labels: 5Q0-907-530-V1.clb
ROD: EV_GatewLear_013.rod
Control Module Part Number: 5Q4 959 593 E
Component and/or Version: TSG FS 010 0031
Software Coding: 00150120D000040000001100
Serial number: 0000184913915
Identification: CU5-DCM
Date: 29.01.16
Manufacturer number: 0310
Test stand number: 198E
Flash Status
Programming Attempts(application): 1/0/1
Flash Tool Code(data): 00000 031 73430
Misc.
Hardware number: 5Q4 959 593 B
Workshop System Name: J386
Dataset Number: 5E0222t____
Dataset Version: 0018
ASAM Dataset: EV_DCUDriveSideEWMAXCONT
ASAM Dataset Revision: 006001
VCDS Info:
Labels: 5QX-959-X93-42.clb
Address 44: Steering Assist
Control Module Part Number: 5Q0 909 144 S
Component and/or Version: EPS_MQB_ZFLS 126 1063
Software Coding: 0103
Identification: ZF0-000
Date: 09.02.16
Manufacturer number: 0201
Test stand number: 0902
Flash Status
Programming Attempts(data): 1/1
Misc.
Hardware number: 5Q0 909 144 R
Workshop System Name: J500
Dataset Number: 5E0074t____
ASAM Dataset: EV_SteerAssisMQB
ASAM Dataset Revision: 012140
Car Info
Chassis Number: 00000000000004620
VCDS Info:
Labels: 5Q0-909-144.clb
ROD: EV_SteerAssisMQB_VW31.rod
Address 52: Door Elect, Pass.
Control Module Part Number: 5Q4 959 592 E
Component and/or Version: TSG BFS 010 0031
Serial number: 0000185632144
Date: 03.02.16
Manufacturer number: 0210
Test stand number: 2DF0
Flash Status
Misc.
Hardware number: 5Q4 959 592 B
Workshop System Name: J387
Dataset Number: 5E0157t____
ASAM Dataset: EV_DCUPasseSideEWMAXCONT
VCDS Info:
Labels: 5QX-959-X92-52.clb
Control Module Part Number: 5E0 035 871 A
Component and/or Version: MU-E--ER 852 6490
Software Coding: 03730200FF00000011110001000000002F0000C40000010000
VCID: A34FAA80AA0BC25A74-80F6
Serial number: 04021600013261
Identification: WG8-LGK
Date: 04.02.16
Test stand number: 3261
Flash Status
Programming Attempts(data): 65535/0/1
Successful Attempts(data): 65535/0/1
Flash Tool Code(data): 00063 031 73430
Misc.
Hardware number: 5E0 035 871 A
Workshop System Name: J794
Equipment/PR Code: 000000003D8DDE49
Dataset Number: 5E0CV1t____
Dataset Version: 0261
ASAM Dataset: EV_MUEnt4CGen2LGE
ASAM Dataset Revision: 001025
Car Info
VCDS Info:
Labels: None
ROD: EV_MUEnt4CGen2LGE_SK26.rod
