- Joined
- Aug 23, 2016
- Messages
- 148
- Reaction score
- 40
- Location
- Florida & the Nation's Capital
- VCDS Serial number
- C?ID=53119
Only channel is for sound level %.
Have you maybe tried [Basic setting-04] "Resetting of all adaptation values" if that does anything ?
Or maybe you should have tried from Seat:
Part No SW: 5F0 907 159 A HW: 4H0 907 159 A (used for 1.8l R4 TFSI)
Part No SW: 5F0 907 159 HW: 4H0 907 159 A (used for R4 2.0l EDC)
Part No SW: 5F0 907 159 B HW: 4H0 907 159 A (used for 2.0l R4 TFSI)
Part No SW: 5F0 907 159 C HW: 4H0 907 159 A (used for 2.0l R4 TFSI)
Wow, I wonder if it sees the 1.8T ECU or other config and says "nope". I searched our records and found some scans from similar cars but no 1.8T with A9, only 2.0T.
Test bench module details:
Part No SW: 5G0 920 961 A HW: 5G0 920 961 A
Component: KOMBI 252 2210
Coding: 27A41A002780260001882A01000000
VCID: 281C3DC853B2B302D4-807C
Then that bit is probably not related to our normal Sound Aktuator, but rather to an external noise generator that's present as a warning to pedestrians on models capable of being operated in pure electric mode. Without an external noise generator, they are considered to be "too silent" and thus hazardous to pedestrians.External vehicle noise fault: Drive with caution!
No comment.(U112100) Database missing message
I'm having the same problem retrofitting a Audi S6 module (4G0 907 159 B) on my A6 3.0 TFSI. From what I understand this can only be fixed using a custom CAN emulator which fakes the correct engine type to the A9 module. However I haven't been able to find such a emulator.
Forgive me if I missed it but I was snooping in Andy's GTI 19 map and found Structure-borne Sound stuff. I headed over to my Alltrack map thread and see:
IDE01996-SFT00071-Installation list: specified installations-Sound System Not coded
ENG05986-SFT00169-GW_Enable_CAN_Timeout_DTC-Actuator For Structure-borne Sound Enabled
01-Engine doesn't appear to use any special bits but I wonder if this could be as simple as a 19 Adp tweak?
Yeah since it is active on Andy's 2.0T and not on my 1.8T wagon. In your case shoot for IDE01996-SFT00071-Installation list: specified installations-Sound System Coded (or active). I doubt DTC-Actuator For Structure-borne Sound Enabled changes functionality.
Success ???
Sunday,07,May,2017,09:43:52:39394
VCDS Version: 17.1.3.0 (x64)
Data version: 20170220 DS267.3
VIN: 3VWC17AU2GM517860 License Plate:
Mileage: 20876km-12971mi Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 2B 42 44 47 52 55 5F 75 A9
VIN: 3VWC17AU2GM517860 Mileage: 20876km-12971miles
47-Sound System -- Status: Cannot be reached 0100
A9-Struct. Borne Sound -- Status: Malfunction 0010
Address 01: Engine (J623-CXBB) Labels: 06K-907-425-V1.clb
Part No SW: 8V0 906 264 F HW: 06K 907 425 B
Component: 1.8l R4 TFSI H13 0003
Revision: --H13---
Coding: 091A00122424002F1000
Shop #: WSC 00066 790 00060
ASAM Dataset: EV_ECM18TFS0208V0906264F 001003
ROD: EV_ECM18TFS0208V0906264F.rod
VCID: 3F873DEFA6E45EB9D0-806A
Address 02: Auto Trans (J217) Labels: 09G-927-749-V2.clb
Part No SW: 09G 927 749 AP HW: 09G 927 749 AP
Component: AISIN AG6 G3 129 2943
Coding: 010200000C000000000000000000000000000000
ASAM Dataset: EV_TCMAQ250031 002009
ROD: EV_TCMAQ250031_VW31.rod
VCID: 0717E50FBEB4D679A8-8052
Part No SW: 3Q0 907 379 T HW: 3Q0 907 379 C
Component: ESC H32 0393
Revision: 00000000 Serial number: 53345000000435
Coding: 04FA6AA124210973007F020681C3292056249000408194B400400050C009
Shop #: WSC 12345 123 61029
VCID: 4B9F193FE25CF2194C-801E
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Revision: 00021000 Serial number: 0381142691
Coding: 030C1C
Shop #: WSC 01383 790 50316
VCID: 3A714CFBBDC67B91E7-806E
Address 08: Auto HVAC (J301) Labels: 5G0-907-426.clb
Part No SW: 5GM 907 426 A HW: 5GM 907 426 A
Component: AC Manuell H02 1001
Revision: 00001K01
Coding: 02020004100100000000000010000002
ROD: EV_ACManueBHBVW37X_SK48.rod
VCID: 4689280BF93E0F7193-8012
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 087 AA HW: 5Q0 937 087 AA
Revision: -------- Serial number: 86580111150438
Coding: 00511A464041A2796DE44000111407001800000000000000000000000000
ROD: EV_BCMBOSCH_016_AU37.rod
VCID: 7AF18CFBFD46BB91A7-802E
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 150812 043 0581
Serial number: 160113075324
Coding: 1E4DFF
Subsystem 2 - Part No SW: 5Q0 955 559 A HW: 5Q0 955 559 A Labels: 5Q0-955-547.CLB
Component: RLS 037 0059
Serial number: S2Y15M11D26H23M31S18
Coding: 84A8DD
Subsystem 3 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000055391009
Sun Roof:
Subsystem 4 - Part No SW: 5G0 959 591 A HW: 8V3 959 591 A
Component: J245 PS22.409 H03 0004
Serial number: 0000FST000FDNT800000
Coding: 191800
Roof Blind:
Subsystem 5 - Part No SW: 5G0 959 591 A HW: 8V3 959 591 A
Component: J394 PS22.409 H03 0004
Serial number: 0000FST000FDMS600000
Coding: 191800
Component: AirbagVW20 010 0830
Serial number: 003GCR03MZUJ
VCID: 4797250FFE34167968-8012
Occupant Detection:
Component: BF-Gewichtss. H11 0021
Serial number: IBH00000000000439RNQ
Coding: 303135
Subsystem 2 - Part No SW: ----------- HW: 480 002 110 15
Serial number: 35700000000814CCA61Q
Subsystem 3 - Part No SW: ----------- HW: 480 002 110 15
Serial number: 35800000000D1DCC371Z
Subsystem 4 - Part No SW: ----------- HW: 480 402 310 15
Serial number: 3510002AB1D3F97290EJ
Subsystem 5 - Part No SW: ----------- HW: 480 402 310 15
Serial number: 3520002B71CF1D22013.
Subsystem 6 - Part No SW: ----------- HW: 480 401 010 15
Serial number: 3550002A51CCEA02F0EO
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 401 010 15
Serial number: 3560002A51CCEA02F06H
Address 16: Steering wheel (J524) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 521 AT HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0195
Revision: FF033033 Serial number: 20151021501479
Coding: 0410
ROD: EV_SMLSVALEOMQB.rod
VCID: 040DF2038F82FD61CD-8050
Part No SW: 5G1 920 840 A HW: 5G1 920 840 A
Component: KOMBI 242 6420
Coding: 03A5111AA980CF050108FE001000000000000000
VCID: 254B8F872478E469BA-8070
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 M
Component: GW MQB High 212 2246
Revision: -------- Serial number: 25111510803678
Coding: 0901000830085900FB00000A1C0F00000001050000000000000000000000
Shop #: WSC 00066 790 00199
ROD: EV_GatewConti_013.rod
VCID: 79F393F7F840B089AE-802C
Subsystem 2 - Part No SW: 5G0 959 442 P HW: 5G0 959 442 P Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H16 0101
Serial number: 29150001545520065326
Coding: 31FFFF
Power Converter DC AC:
Subsystem 3 - Part No SW: 5Q0 907 155 A HW: 5Q0 907 155 A
Component: WECHSELRICHTE H53 0041
Serial number: 0111854
131695 - Digital sound System control module
U106A 00 [009] - No Communication
Reset counter: 8
Mileage: 20876 km
Date: 2017.05.07
Time: 09:33:29
Supply voltage: Terminal 30: 12.2 V
Terminal 15: On
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000220563001
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB_SK25.rod
VCID: 346D62C39FA28DE13D-8060
Component: TSG FS 020 0041
Serial number: 02121506050ANJ
Coding: 001F13205C00020000000000
VCID: 438F311FCA0C3A59B4-8016
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000002425948
Coding: 011000
Part No SW: 5Q0 909 144 S HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1063
Coding: 8102
ROD: EV_SteerAssisMQB_VW31.rod
VCID: 448D3203CF023D618D-8010
Part No SW: 5Q0 035 456 HW: 5Q0 035 456
Component: MIB2_lite_amp H20 0130
Revision: 00000001 Serial number: VWZ8Z1FBA014RA5
Coding: 2200000000AAAAAA000000000000
ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003
ROD: EV_AMPMst12C1Gen2ALPI.rod
VCID: 6DDBB7A7BC081C2932-8038
Component: TSG BFS 020 0041
Serial number: 20111506050CZO
Coding: 003F13205E00020000000000
VCID: 4281341BD5163351BF-8016
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000002251843
Coding: 091000
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 061A00000B000400
VCID: 40853E13DB1A2141A9-8014
Subsystem 1 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0004
Coding: 2E0000
Subsystem 2 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0004
Coding: 2E0000
Address 5F: Information Electr. (J794) Labels: 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 844 HW: 3Q0 035 844
Component: MU-S-S-US 620 0613
Coding: 02730200FF00000051220002001808001F0106F40120010003
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 6CDDBAA38712152125-8038
Subsystem 1 - Part No SW: 3G0 919 605 H HW: 3G0 919 605 H
Component: ABT_Std-2 H52 1028
Serial number: VWZ8Z9RES01133
B11CF 53 [009] - Deactivated
Reset counter: 8
Mileage: 20876 km
Date: 2017.05.07
Time: 09:37:12
Voltage terminal 30: 12.3 V
SDARS_tuner_status_2-Audio Signal: Available
SDARS_tuner_status_2-Antenna current: 129 mA
SDARS_tuner_status_2-Reception quality: good_signal
SDARS_tuner_status_2-Tuner für Satellitenradio: Status der Voraktivierung: 05
SDARS_tuner_status_2-Tuner für Satellitenradio: Wert der Voraktivierung: 05
7219 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 8
Mileage: 20876 km
Date: 2017.05.07
Time: 09:36:32
BAP-BAP_Function_ID: 02
7223 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 8
Mileage: 20876 km
Date: 2017.05.07
Time: 09:36:32
Address 75: Telematics (J949) Labels: 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0568
Coding: 02730002C2823A01000000000000
ROD: EV_OCULowMQB.rod
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0014
Serial number: 150929202770
ROD: EV_SoundActuaGen2AU64X_VW26.rod
VCID: 6BDFB9BF821C12192C-803E
0005 - Incorrect Vehicle Type
U10D9 00 [009] - -
Reset counter: 8
Mileage: 20876 km
Date: 2017.05.07
Time: 09:34:19
End-------------------------(Elapsed Time: 04:27)--------------------------
Control Module Part Number: 5G0 907 159
Component and/or Version: SAS-GEN 2 H06 0014
Software Coding:
Work Shop Code:
Advanced Identification/FAZIT
Identification: KKE-KKK
Date: 29.09.15
Manufacturer number: EOL1
Test stand number: 2770
Flash Status
Programming Attempts(application): 1/2/2
Flash Date: 00.01.01
Misc.
Hardware number: 4H0 907 159 A
Workshop System Name: J869
Equipment/PR Code: 0000000000000000
Dataset Number: -----------
Dataset Version: ----
ASAM Dataset Revision: 003010
VCDS Info:
Try this:
IDE01996-SFT00169-Installation list: specified installations-Actuator For Structure-borne Sound,coded
ENG05986-SFT00169-GW_Enable_CAN_Timeout_DTC-Actuator For Structure-borne Sound,Enabled
Yeah something weird happened there.This happened, besause you added sound system like dynaudio instead of borne actuator...
Michael,
If the channels you tweaked were labeled Structure-borne Sound please post the contents from the AdpLog.CSV file on that PC. The Adaptation Function Control Module map couldn't hurt either.
Try this:
It should be in your Debug sub-folder.Silly question but what is the best way to pull the AdpLog.CSV file
[Applications]and the Adaptation Function Control Module map?
