Hi
I have a SEAT Leon mk3 (2014 model year)
around a year ago I had my media screen replaced (the touch screen for all the media and sat nav etc)
since then I have had this error on it
after clearing the error it just come straight back up again
I have been meaning to go back to SEAT for them to sort out seen as though the problem has been there since they replaced the screen but I just haven't had the time
Is there a way to resolve this myself?
full scan if needed
Thanks Stu
B201A 00 [009] - -
Reset counter: 122
Mileage: 18775 km
Date: 2015.12.07
Time: 17:47:56
Voltage terminal 30: 12.4 V
full scan if needed
Wednesday,31,August,2016,17:49:36:06801
VCDS Version: 16.8.0.0 (x64)
Data version: 20160731 DS254
VIN: VSSZZZ5FZER075101 License Plate:
Chassis Type: 5F (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 55 5F
VIN: VSSZZZ5FZER075101 Mileage: 28556km-17743miles
Address 01: Engine (J623-CLHA) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 021 M HW: 04L 907 309 B
Component: R4 1,6L EDC H22 6545
Revision: 84H22---
Coding: 01110012032501090000
Shop #: WSC 00049 770 00123
ASAM Dataset: EV_ECM16TDI01104L906021M 002011
ROD: EV_ECM16TDI01104L906021M.rod
VCID: 2F6668327607DD3A0A-807A
Part No SW: 5Q0 907 379 R HW: 5Q0 907 379 F
Component: EMB8 EHCB H31 0356
Revision: 00000000 Serial number: 6344300000086F
Coding: 20EE8A92142709710078060041C4240451289000608224F200410070C002
Shop #: WSC 00049 770 00103
ROD: EV_Brake1UDSContiMK100ESP_SE37.rod
VCID: 4B9E1CA2E2DF811A06-801E
16389 - TPMS Display
C1146 F1 [137] - Currently Not Available
Reset counter: 89
Mileage: 28510 km
Date: 2016.08.30
Time: 07:11:55
Address 08: Auto HVAC (J301) Labels: 5G0-907-426.clb
Part No SW: 5F0 907 426 H HW: 5F0 907 426 H
Component: AC Manuell H01 0705
Revision: 00001K07
Coding: 00100104200100001000000000001000
ASAM Dataset: EV_ACManueBHBVW37X 003017
ROD: EV_ACManueBHBVW37X.rod
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AE HW: 5Q0 937 084 AE
Component: BCM MQBAB H H16 0124
Serial number: 00011335200737
Coding: 0B000A424241005B0BA44000B10403081000000000000000000000000000
ROD: EV_BCMBOSCH_SE37.rod
VCID: 7BFE8C62F2FFF19AF6-802E
Subsystem 1 - Part No SW: 5F2 955 119 HW: 5F1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 131209 041 0574
Serial number: 131212224635
Coding: 0BC5FD
Subsystem 2 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY132802V93
Subsystem 3 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000028639206
Part No SW: 3Q0 959 655 AC HW: 3Q0 959 655 AC
Component: Airbag VW20 012 0189
Revision: -------- Serial number: 003P4P08ND4J
Coding: 98CCC000000000005C0000CC008800000065
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 7F067872E6E7EDBADA-802A
Subsystem 1 - Part No SW: ----------- HW: 454 000 101 14
Serial number: 3576U0000007586D8E0Q
Subsystem 2 - Part No SW: ----------- HW: 454 000 306 13
Serial number: 3586U000000C84492D0I
Subsystem 3 - Part No SW: ----------- HW: 454 802 811 13
Component: SideSensor_Dr 111 0148
Serial number: 3516RC8AF8102000000C
Subsystem 4 - Part No SW: ----------- HW: 454 802 811 13
Component: SideSensor_Pr 111 0148
Serial number: 3526RFB988102000000B
Subsystem 5 - Part No SW: ----------- HW: 454 801 112 13
Component: FrontSensor_D 114 0149
Serial number: 3556V3AC732020000003
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 507 AC HW: 5Q0 953 549
Component: Lenks. Modul 007 0070
Revision: -------- Serial number: 07011404220205
Coding: 1400
ROD: EV_SMLSKLOMQB_SE37.rod
VCID: 77F69052CED7D5FA92-8022
Part No SW: 5F0 920 971 H HW: 5F0 920 971 H
Component: KOMBI 303 2210
Coding: 27A402002980260001086A00000000
ROD: EV_DashBoardVDDMQBAB_SE37.rod
Part No SW: 5Q0 907 530 Q HW: 5Q0 907 530 M
Component: GW MQB High 212 2163
Revision: -------- Serial number: 04011410800358
Coding: 030100F40B087300EF000448080F00010001000000000000000000000000
ASAM Dataset: EV_GatewConti 010015
ROD: EV_GatewConti.rod
VCID: 3F863872A6672DBA9A-806A
Subsystem 2 - Part No SW: 5F0 959 537 B HW: 5F0 959 537 B
Component: E221__MFL-PR6 H03 0120
Serial number: 000000000A0191250913
Coding: 002000
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 2682221903
Part No SW: 5Q4 959 593 B HW: 5Q4 959 593 B
Component: TSG FS 009 0014
Serial number: 0000085988215
Coding: 00100220C001040000001000
VCID: 448C379ECF814E62C7-8010
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A
Serial number: 00000000000001244240
Coding: 2D0000
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 122 1043
Coding: 0103
VCID: 41823E8AD0935B4AEC-8014
Part No SW: 5Q4 959 592 B HW: 5Q4 959 592 B
Component: TSG BFS 009 0014
Serial number: 0000086757684
VCID: 438E3482CA8F495AFE-8016
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A
Serial number: 00000000000001486367
Coding: 350000
Address 55: Headlight Range (J431) Labels: 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Coding: 048C000009000000
ROD: EV_HeadlRegulVWLWRMQB_VW26.rod
VCID: 75EA9A5AD4DBA7EA80-8020
Address 5F: Information Electr. (J794) Labels: Redir Fail!
Part No SW: 5F0 035 858 A HW: 5F0 035 858 A
Component: MU-S-ND-ER 040 0425
Serial number: E5F00601142423
Coding: 04730001D70A000021111101000800002F0106060100010046
ASAM Dataset: EV_MUStd6C1PASE 002030
ROD: EV_MUStd6C1PASE_VW37.rod
VCID: 2952862A48E3B30AD4-807C
Subsystem 1 - Part No SW: 5F0 919 603 A HW: 5F0 919 603 A
Component: ABTmin_Std_Nv H60 0030
Serial number: SEZ8Z9RT902MB7
Subsystem 2 - Part No SW: 5F0 919 866 F HW: -----------
Component: ECE 2014 --- 0036
B201A 00 [009] - -
Reset counter: 122
Mileage: 18775 km
Date: 2015.12.07
Time: 17:47:56
End-------------------------(Elapsed Time: 03:01)--------------------------
Thanks Stu
