2014 Jetta TDI - INSPEC and SRI
Stdenis25
London ON
C?ID=200501
I recently did a service on my 2014 Jetta TDI and reset the SRI through VCDS. I now have two service intervals, and can only reset the first one. When I reset it following the instructions in the manual, it works, however there is still a second service interval reminder that flashes every time I start the car. There is a small "1" in the corner when I am on the first SRI, and a small "2" when the INSPEC message comes up reminding me it requires a service.
Would the dealer have set a separate reminder? Any idea how to reset or delete the second reminder?
Thanks,
DrPeter
16.4905° S, 151.7375° W
Hi, could you please provide us with an Auto-Scan of the vehicle and what exactly did you change with VCDS?
Thank you,
drpeter
Stdenis25
London ON
C?ID=200501
Will do this tonight and attach some screen shots. Thanks!
While you're in there, please make a map of the Adaptation channels.
[Applications]
[Controller Channel Map]
Controller Address = 17
Login or security access code = leave blank
Function = Adaptation
Output = Pre-Label File​
[Go]
It may take a few minutes to run through all the channels.
Stdenis25
London ON
C?ID=200501
VCDS Version: Release 12.12.2
Data version: 20140212
Tuesday,17,June,2014,19:55:34:30101
Chassis Type: AJ (6N0)
Scan: 01 03 05 08 09 15 17 19 25 2B 2E 44 56 77
VIN: 3VW3L7AJ4EM364931
Address 01: Engine (CJA)       Labels: None
   Part No SW: 03L 906 019 KD    HW: 03L 907 309 AA
   Component: R4 2,0L EDC G000SG  5680
   Revision: 12H16---    Serial number:
   Coding: 0050072
   VCID: 77D30FDF06B8D1A6AAD-8022
   Revision: 00H31001
   Coding: A14B400C492800FE851402E7921A0042211000
   VCID: 7DDF1DF7E484FBF6F01-8028
Address 05: Acc/Start Auth. (J518)       Labels: 5K0-959-434.clb
   Component: VWKESSYPQ35GP 086 1101
   Revision: 00086000    Serial number: 0193712079
   Coding: 030C0C
   ROD: EV_KESSYPQ35G.rod
   VCID: 3449F8D39F4EFABE4FF-8061
   Part No SW: 5C0 820 047 BA    HW: 5C0 820 047 BA
   Component: J301  Klimaanlage   0204
   Revision: 2001012S    Serial number: 00000001701529
   VCID: 60E14483B336361EFB7-8035
Address 09: Cent. Elect. (J519)       Labels: 6R0-937-08x-09.clb
   Part No SW: 5C0 937 087 J    HW: 5C0 937 087 A
   Component: BCM25 JLB H3  H34 0411
   Revision: B2034001    Serial number: 08018221130218
   Coding: 7A994B9008210F0008382000240884C50082502E6000000030A010000000
   Shop #: WSC 00066 123 12345
   VCID: 3449F8D3974EFABE4FF-8061
   Subsystem 1 - Part No SW: 6R0 959 801 AN    HW: 6R0 959 801 AN  Labels: 6R0-959-801.CLB
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 AS    HW: 6R0 959 802 AS  Labels: 6R0-959-802.CLB
   Coding: 820000
   Subsystem 3 - Part No SW: 5K0 959 591     HW: 5K0 959 591
   Component: J245 PS41.022  H10 0007
   Coding: 180000
   Subsystem 4 - Part No SW: 5K0 959 542 C    HW: 5K0 959 542 C
   Component: E221__MFL-TAS  H31 0037
   Coding: 020000
   Subsystem 5 - Part No SW: 6R0 959 811 M    HW: 6R0 959 811 M
   Coding: 800000
   Subsystem 6 - Part No SW: 6R0 959 812 M    HW: 6R0 959 812 M
   Coding: 800000
   Part No SW: 5C0 959 655 AD    HW: 5C0 959 655 AD
   Component: AirbagVW10    102 0912
   Serial number: 003MVD00KME$
   Coding: 00004138
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 74C938D3DFCEBABE8FF-8021
   Serial number: 6940000Y130000WBME07
   Coding: 303042
   Serial number: 3572MSME7464347BZZZ$
   Serial number: 3582MSME55213279ZZZS
   Serial number: 3516KSME450D3926ZZZV
   Serial number: 3526KSME33695625ZZZT
   Serial number: 3556LSME5C683125ZZZ-
   Crash sensor for front airbag; passenger side:
   Serial number: 3566LSME3E5A3125ZZZ
   Part No SW: 5C6 920 853 A    HW: 5C6 920 853 A
   Component: KOMBI         H04 0809
   Coding: 380C00
   Shop #: WSC 00066 123 00201
   ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
   VCID: 2A75E6AB4D8ABC4EE53-807F
Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 5C0 937 087 A
   Component: GW-K-CAN TP20 H34 0411
   Revision: B2034001
   Coding: 102200
   VCID: F0C1B4C323D6069EEB7-80A5
   Component: IMMO          H04 0809
   Coding: 000007
   Shop #: WSC 00066 000 00122
   ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
   VCID: EAF5A6AB0D0AFC4EA53-80BF
Address 2B: Steer. Col. Lock (J764)       Labels: 5K0-905-861.clb
   Revision: 00000000    Serial number: 13000110808003
   Coding: 4100000000000000
   Shop #: WSC 00066 790 50316
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 3041F4C36B56C69E2B7-8065
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 70     3501
   Revision: 00H22000
   VCID: 3957C9E7702C07D69C9-806C
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 1K0 035 180 AF    HW: 1K0 035 180 AF
   Component: Radio Prem-8  H05 0008
   Revision: -----09S    Serial number: VWZ4Z7N3488359
   Coding: 21000400020006
   VCID: 64E94893672E2A3E1FF-8031
Address 77: Telephone (J412)       Labels: None
   Component: TELEFON       H05 0315
   Revision: 1B001001    Serial number: 00007664960534
   Coding: 0210030080010110
   Shop #: WSC 01383 790 50316
   ROD: EV_UHVUMI.rod
   VCID: 2E7DEABB7162D06E39B-807B
Changed by:
Instruments (17)
Adaptation (10)
ESI: resetting ESI
Did you make a channel map, as suggested 2 posts up?
Stdenis25
London ON
C?ID=200501
just did... how do I post it? sorry.. new to this.
Stdenis25
London ON
C?ID=200501
(2)-Additional coding-Coolant temperature source	via CAN
(3)-Additional coding-Tank characteristic curve	1
(4)-Additional coding-Number of fuel level sensors	1
(5)-Additional coding-Locking bit	locked
Automatic door locking	Yes
Display correction of consumptions and operating range	100%
Display correction of fuel gauge	0
Display depiction	Not available
Distance	34190 km
(1)-ESI: Code service interval extension-Status ESI or SID	ESI or SID on
(2)-ESI: Code service interval extension-Selection of ESI or SID	Service interval display (SID)
(3)-ESI: Code service interval extension-Oil level	no oil level evaluation
(4)-ESI: Code service interval extension-Oil pressure	dynamic oil pressure
(5)-ESI: Code service interval extension-Remote clock receiver	without remote clock receiver
(6)-ESI: Code service interval extension-Oil quality	poor oil quality
(7)-ESI: Code service interval extension-TOG	Oil level thermal sensor not connected to instrument cluster
ESI: Distance driven from inspection	4000 km
ESI: Oil quality	poor oil quality
ESI: Resetting ESI	Reset
ESI: Soot entry	0 km
ESI: Time from inspection	21 d
FIX: Distance covered since last mileage-dependent inspection	34100 km
FIX: Maximum time until next time-dependent inspection	730 d
FIX: Reset value for next mileage-dependent inspection	45000 km
FIX: Reset value for next mileage-dependent inspections	365 d
FIX: Time since last time-dependent inspection	29 d
Fix:Max. distance until next mileage-related inspection	30000 km
Hour	20 H
Language version	US English
Light warning buzzer; condition	Open
Minute	5 min
Pause recommendation	Yes
Seat belt warning	Version 2
Service notification in days	20 d
(1)-Service-key settings-p_write_delay_time	40 s
(2)-Service-key settings-p_write_delay_speed	20 km/h
(3)-Service-key settings-p_write_distance	20 km
(4)-Service-key settings-p_forcewrite_qual_time	10 s
(5)-Service-key settings-p_main_switch_keyless	On
(6)-Service-key settings-p_main_switch_basis	On
SIA: maximum value of distance to service	15000 km
SIA: Maximum value of timet o service	372 d
SIE: thermal load	0 km
Speed threshold of dynamic oil pressure warning	kein Offset
Steering Assistance	Version 2
(1)-Units adjusted-Temperature	°C
(2)-Units adjusted-Distance	Kilometers
(3)-Units adjusted-Speed	Kilometers per hour
(4)-Units adjusted-Pressure	kPa
(5)-Units adjusted-Volume	Liter
(6)-Units adjusted-Time	12h AM_PM
(7)-Units adjusted-Date	mm_dd_yy
(8)-Units adjusted-Consumption	Liters per 100 km
Volume to be replenished	No
(1)-additional_adaption-Logic address	0
(2)-additional_adaption-Function status	No
indicator_celebration	not active
Service_Key_Clear_All_Counters	Yes
(1)-velocity_detection-Speed source	Distance impulses
(2)-velocity_detection-Distance impulses	4
this??
I think it's here:
Assuming you've done whatever your service booklet specifies should be done every 30,000 km, try putting 0 in there.
Stdenis25
London ON
C?ID=200501
As you can see it seems like there are two service intervals set up. The one I reset with VCDS to 15,000 km, its now down to 11,000. The other one is now negative as it shows I am over, note the small "2" beside it.
Stdenis25
London ON
C?ID=200501
You rock! Thanks for the quick replies. Problem solved.
Dana
Western PA, USA
It looks like the Distance and Time based Service scheme so this A6 page may be helpful:
http://wiki.ross-tech.com/wiki/index.php/Audi_A6_(4G)_Instrument_Cluster
At some point please try resetting all 3 channels:
1) ESI: Resetting ESI
2) FIX: Distance covered since last mileage-dependent inspection
3) FIX: Time since last time-dependent inspection
.. and check to see if either ESI: Time from inspection and ESI: Distance driven from inspection channel happen to zero after a key cycle. If they do not zero out please let us know if entering a new value of 0 in each of those resolves this.
Edit. I missed that update but make sure all 3 resets were completed so you don't have to deal with that anytime soon :)
Stdenis25
London ON
C?ID=200501
that page you posted is great. Exactly what I needed to do from the start.
Thanks!
Yeah, but without seeing the channel map first, it wasn't obvious that VW was now using that same scheme.
Dana
Western PA, USA
Yeah Uwe, we would have been guessing for a while without it :) I assumed London was RoW but that is a Canadian market car using what I would describe as a RoW service scheme! Build date of 14.08.2013 so it is new but it wasn't built yesterday so we are going to see more of these inquiries real soon.
Update. After further research I added the additional steps to the Mk6 Golf chassis cluster page.
The PR codes from this Canadian (km) VIN are:
Service indicator QI4 Service indicator 15000 km or 1 year ( fix )
Service interval prolongation QG0 Without service interval prolongation
The PR Codes from a 2014 US (mile) VIN with similar control module map channels are:
Service indicator QI7 Service indicator ( 10000 miles )
