I would like to disable ESC on my VW T6 TSI but when I go on abs module and ask for long coding help it says that my car is not supported.
Attached a scan of it.I’m using vcds 16.6
On that one I have a lot of DTC because I try to change the last two digit from 00 to 01 ( 04 also do the same all the other digit are rejected). with that ESP is disable but I get orange light on dash for no esc,no abs, tyre pressure and all sort of DTC because of disable ABS.
Will you bring the Long coding helper for the T6 in futur?
If so when do you think it will be available?
The Esc on the T6 is very intrusive and you can't disable it with ASR switch like I could on my old T5.
I'm going crazy with that thing as on mountain road it activate the brake in every curve because it think's i'm too fast.
Also on snow when pulling brake to make tight curve the ESC make the Van pull straight. Already end up in a snow wall.
I would also like to know if it's possible to change some setting so that I can left foot brake?
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H05 0132
Revision: 00000000 Serial number: 43255000001382
Coding: 557EC39865698485AA7EC377A6832196780001
Shop #: WSC 02739 790 50316
ROD: EV_Brake1ESCCONTIVN75XGP2_VN35.rod
VCID: 3FCE8820A62955BBE0-806B
0039 - Front Left Wheel Speed Sensor
C101A 4A [137] - Incorrect component(s) installed
Reset counter: 14
Mileage: 12984 km
Date: 2016.07.27
Time: 18:03:30
0055 - Front Right Wheel Speed Sensor
C101B 4A [008] - Incorrect component(s) installed
Reset counter: 54
Mileage: 12984 km
Date: 2016.07.27
Time: 18:09:10
0397 - TPMS Warning
C102D F0 [008] - Pressure Loss
Reset counter: 21
Mileage: 11958 km
Date: 2016.06.30
Time: 17:14:40
