Hi all. Can somebody assist me with PDC retrofit coding please.
Monday,18,July,2016,18:04:32:35923
VCDS Version: 16.6.0.2
Data version: 20160602 DS251
Workshop Code: 211 02434 000001
VIN: WAUZZZ8V7EAXXXXXX License Plate:
Mileage: 34075km-21173mi Repair Order:
Chassis Type: 8V (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F BB BC
VIN: WAUZZZ8V7EAXXXXXX Mileage: 34075km-21173miles
10-Park/Steer Assist -- Status: Not registered 0011
Address 01: Engine (J623-CPTA) Labels: 04E-907-309-V1.clb
Part No SW: 04E 906 016 AC HW: 04E 907 309 G
Component: 1,4l R4 TSI H02 6190
Revision: WKH02---
Coding: 02190012242401082000
Shop #: WSC 45733 002 1048576
ASAM Dataset: EV_ECM14TFS01104E906016AC 002008
ROD: EV_ECM14TFS01104E906016AC.rod
VCID: 63C555D76AD9EB5BA4-8036
17158 - Databus
U1123 00 [039] - Received Error Message
Mileage: 34075 km
Date: 2016.07.18
Time: 17:55:08
Coolant temperature: 31 °C
Intake air temperature: 30 °C
Voltage terminal 30: 11.544 V
Mass flow through throttle valve: 0.0 kg/h
Readiness: 1110 0001
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 60374000000B6A
Coding: 12F16AA224242A71017C060341C9294856245480608294F2022100788608
Shop #: WSC 06314 790 00021
ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
VCID: 7BF50DB7F269339B8C-802E
Reset counter: 132
Mileage: 34075 km
Date: 2016.07.18
Time: 17:54:44
Address 08: Auto HVAC (E87) Labels: 8V0-820-043.clb
Part No SW: 8V0 820 043 C HW: 8V0 820 043 C
Component: AC Automat H13 0052
Revision: 20026000 Serial number: 00000000243687
Coding: 03000004000000011000000000001100
VCID: 326BE09365A332D31F-8066
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AE HW: 5Q0 937 084 AE
Component: BCM MQBAB H H16 0124
Serial number: 00011403701288
Coding: 04040A42C24122FD43844004001C07A80000000000000000000000000000
ROD: EV_BCMBOSCH_VW37.rod
Subsystem 1 - Part No SW: 8V1 955 119 A HW: 8V1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 140122 041 0580
Serial number: 140124124550
Coding: 0A47F7
Component: G397_RLFS H06 0002
Serial number: 22238107
Coding: 00006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 L HW: 8V0 941 531 L
Component: E1 - LDS MQB H05 0032
Serial number: 18 11 2013 00000022
Address 10: Park/Steer Assist (J446) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 L HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0056
Revision: -------- Serial number: 39331521901264
Coding: 0021055001
VCID: 4487B64BCF178C63BD-8010
13637426 - Databus
Reset counter: 132
Mileage: 34075 km
Date: 2016.07.18
Time: 17:54:34
13639168 - Databus
Reset counter: 132
Mileage: 34075 km
Date: 2016.07.18
Time: 17:54:34
Part No SW: 5Q0 959 655 N HW: 5Q0 959 655 N
Component: AirbagVW20 011 0361
Serial number: 003M2R054P13
Coding: 98CCC0000C0000005C5400CA004800000065
VCID: 4B959D77E249431B7C-801E
Subsystem 1 - Part No SW: ----------- HW: 480 000 302 14
Serial number: 357670000009E410DE0/
Subsystem 2 - Part No SW: ----------- HW: 480 000 302 14
Serial number: 3586700000034410DE0P
Subsystem 3 - Part No SW: ----------- HW: 480 400 602 14
Serial number: 3516502A912AB1B240A7
Subsystem 4 - Part No SW: ----------- HW: 480 400 302 14
Serial number: 3526502AB12AB1B0D0FM
Subsystem 5 - Part No SW: ----------- HW: 480 401 701 14
Serial number: 3556502C913013E0F0EC
Pedestrian Protection Driver:
Subsystem 6 - Part No SW: ----------- HW: 480 400 302 14
Component: PedP_Sensor_D 001 6149
Serial number: 2286502C113013F3230Q
Subsystem 7 - Part No SW: ----------- HW: 480 402 001 14
Component: PedP_Sensor_P 001 6149
Serial number: 2296502A112FAE21716A
Pedestrian Protection Center:
Subsystem 8 - Part No SW: ----------- HW: 480 402 001 14
Component: PedP_Sensor_C 001 6149
Serial number: 2306502A112FAE258336
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 8V0 953 521 BP HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 07021408490442
Coding: A408
ROD: EV_SMLSKLOMQB_AU37.rod
VCID: 0919677FA8B5110B8E-805C
Part No SW: 8V0 920 870 G HW: 8V0 920 870 G
Component: KOMBI H03 2220
Coding: 07A409002B8000080D00E800100000
Shop #: WSC 02434 211 00001
VCID: 3F8DB9A7A6F1EFBBE0-806A
Part No SW: 5Q0 907 530 Q HW: 5Q0 907 530 F
Component: GW MQB High 125 1164
Revision: -------- Serial number: 0001542847
Coding: 030100042B0857005B000248080B00000001000000000000000000000000
ROD: EV_GatewLear.rod
Subsystem 2 - Part No SW: 8U0 951 528 A HW: 8U0 951 528 A
Component: E221 - MFL H02 0014
Serial number: 22 01 2014 D0389576
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 4737162403
66304 - Databus
U1124 00 [009] - Additional Installations Detected
Reset counter: 132
Mileage: 34075 km
Date: 2016.07.18
Time: 17:54:35
Supply voltage; Terminal 30: 11.4 V
Terminal 15: On
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 26011402091604
Coding: 001C8F204000040000001002
VCID: 408FBA5BDB0F904399-8014
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 122 1043
Coding: 8103
VCID: 4189BF5FD005994B96-8014
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 01021403110830
Coding: 001C87204000040000001002
Address 55: Headlight Range (J431) Labels: 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Coding: 019A000001000000
ROD: EV_HeadlRegulVWLWRMQB_AU37.rod
VCID: 75E11B8FD44D65EBFA-8020
Address 5F: Information Electr. (J794) Labels: 8V0-035-MIB-STD1.clb
Part No SW: 8V0 035 864 B HW: 8V0 035 864 B
Component: MU-S-N-ER 040 0420
Serial number: A3F00802142337
Coding: 01730301FF0A000021110001000A00002F0004440100010006
ASAM Dataset: EV_MUStd6C3PASE 002020
ROD: EV_MUStd6C3PASE_AU37.rod
VCID: 3A7BC8B3BDD3CA93D7-806E
Subsystem 1 - Part No SW: 8V0 919 866 B HW: -----------
Component: ECE 2014 --- 0036
Subsystem 2 - Part No SW: 8V0 919 603 C HW: 8V0 919 603 C
Component: DU Std H49 0013
Serial number: AUZ8Z9EY301LP1
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 B HW: 8V0 919 614 B
Component: ControlUnit_B H33 0037
Serial number: C1000007121300020433
Address BB: Door Rear Drv
Address BC: Door Rear Pass Labels: None
VCID: 55A17B0F348D05EBDA-8000
No ASAM data for: "Unknown" (AU37)
End-------------------------(Elapsed Time: 04:16)--------------------------
