I figured I should make my first post on the ross tech forums a really good one. I have had my cable for years now and It has been one of the best investments I have ever made for my shop. Until now I have managed quite well with it but this Phaeton has me stumped and I really need some help up here.
I found this car on Kijiji in Manitoba and I ended up trading one of my Passat w8s for it because I am oh so broke
It was still a great deal in my eyes however, how often do you come across a Phaeton? Running or not. So I put in some batteries and found the keys did not work and all I could get was Immobil Active on the display. This was the first scan of the kessy module:
After clearing the faults these came back
these antenna fault codes stayed.
After some google searching I found this :
http://www.renntech.org/forums/topic/37055-keyless-kessy-entry-problem-fixed-after-5-dollars-and-1-hour-o/
So I got out my handy dandy soldering iron and proceeded to replace the mosfets and resistors, no luck I still had the antenna faults. The only Phaeton wiring diagrams I can find are for the european/keyless access model that has the antennas but when I looked at the pinout on the connector, those wires were not there. It was at this point I found the box for the kessy module and realized it was brand new. Ok so it has not been coded correctly at the dealer!!!
It was at this point I contacted an ebay seller that does kessy key matching to see if I could get the SKC. He was very helpful and gave me some valuable tips that allowed me to properly code the module and get rid of the antenna faults. Once that was sorted out we were able to see that the kessy was synced to the car and all that needed to be done was program the keys to it.
So I sent away the kessy and keys to be matched and I waited. Buddy wasn't able to match the keys so he gave me the 5 digit pin instead 19798
When I got it back I could not log in with 19798, Then he gave me 65281 and that one did not work either. I have messed with workshop code and importer numbers in my Workshop Identification in VCDS program options and it still locks me out for extended periods with both login codes.
This is a scan I took today:
Saturday,23,April,2016,11:41:45:51336
VCDS Version: Release 15.7.4 (x64) Running on Windows 7 x64
Punchbuggies Racing
Address 25: Immobilizer Labels: None
Control Module Part Number: 3D0 909 137 G HW: 3D0 909 137 G
Component and/or Version: Kessy 6850
Software Coding: 0133356
Work Shop Code: WSC 17250 001 1048576
Additional Info: 4E0905852C ELV 1734
Additional Info: Geraet 1048576
VCID: 2B5F353389CDB866FB-512A
11 Faults Found:
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 46
Date: 2064.00.00
Time: 00:00:14
00087 - Terminal 30 for Starting Relevant Consumers
Reset counter: 46
Date: 2064.00.00
Time: 00:00:14
00576 - Terminal 15
006 - Short to Plus
Fault Status: 01100110
Reset counter: 46
Date: 2064.00.00
Time: 00:00:14
00185 - Control Circuit; Relay for Supply Voltage Terminal 15
009 - Open or Short to Ground
Fault Status: 01101001
Fault Frequency: 0
Reset counter: 46
Date: 2064.00.00
Time: 00:00:14
00165 - Switch for Transmission Position P/N
010 - Open or Short to Plus
Fault Status: 01101010
Fault Frequency: 0
Reset counter: 46
Date: 2064.00.00
Time: 00:00:14
01176 - Key
Fault Frequency: 14
Date: 2064.00.00
Time: 00:00:14
00179 - Access/Start Authorization Antenna; Drivers Side (R134)
Fault Frequency: 0
Reset counter: 6
Date: 2064.00.00
Time: 00:00:14
00180 - Access/Start Authorization Antenna; Passenger Side (R135)
Fault Frequency: 0
Reset counter: 6
Date: 2064.00.00
Time: 00:00:14
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
Fault Frequency: 0
Reset counter: 6
Date: 2064.00.00
Time: 00:00:14
00182 - Luggage Compartment Access/Start Authorization Antenna (R137)
Fault Frequency: 0
Reset counter: 6
Date: 2064.00.00
Time: 00:00:14
00183 - Interior Access/Start Authorization Antenna 1 (R138)
Fault Frequency: 0
Reset counter: 6
Date: 2064.00.00
Time: 00:00:14
Saturday,23,April,2016,11:49:31:51336
Punchbuggies Racing
6 Faults Found:
01176 - Key
Date: 2064.00.00
Time: 00:00:14
Fault Frequency: 0
Reset counter: 6
Date: 2064.00.00
Time: 00:00:14
Fault Frequency: 0
Reset counter: 6
Date: 2064.00.00
Time: 00:00:14
Fault Frequency: 0
Reset counter: 6
Date: 2064.00.00
Time: 00:00:14
Fault Frequency: 0
Reset counter: 6
Date: 2064.00.00
Time: 00:00:14
Fault Frequency: 0
Reset counter: 6
Date: 2064.00.00
Time: 00:00:14
Monday,23,May,2016,12:14:21:51336
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
Dealer/Shop Name: Punchbuggies
Workshop Code: 999 06167 006167
VIN: WVWAF63D648008387 License Plate:
Chassis Type: 3D - VW Phaeton (2002 > 2006)
Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 27 28 29 2E
34 36 37 38 39 46 47 55 56 57 65 66 68 69 71 75 76 77
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 137 G HW: 3D0 909 137 G
Component: Kessy 6850
Revision: 00H24072 Serial number: VWZ3Z0C5098367
Coding: 0000232
Shop #: WSC 17250 001 104857
Component: ELV XXXX
01176 - Key
Date: 2064.00.00
Time: 00:00:14
Address 06: Seat Mem. Pass Labels: 3D0-959-759.lbl
Part No: 3D0 959 759 B
Component: Sitzmemory D1 BF 1520
Coding: 0000003
Shop #: WSC 01065 000 00000
VCID: 356B134B5F89FE969D-5148
16 Faults Found:
01971 - Adjuster for Seat Heating & Ventilation (E399)
01900 - Passengers Seat Fore / Aft Adjusting Motor (V31)
007 - Short to Ground
01975 - Passengers Seat Height Adjustment Motor (V191)
01902 - Lumbar Support Fore / Aft Adjustment Motor (V230)
01904 - Passengers Backrest Adjusting Motor (V46)
01903 - Seat Tilt Adjustment Motor (V231)
01901 - Lumbar Support Height Adjustment Motor (V229)
00455 - Control Module for Access and Start Control; Comfort CAN (J518)
00477 - Control Module; Display & Input; Comfort CAN; Front (J523)
Address 08: Auto HVAC Labels: 3D0-907-040.lbl
Part No: 3D0 907 040 G
Component: Climatronic D1 1132
VCID: 2241D817FE07792E48-5148
12 Faults Found:
01273 - Fresh Air Blower (V2)
00711 - Left Footwell Flap Positioning Motor (V108)
00026 - Motor for Distribution Flap; Right (V205)
00785 - Temp Sensor in Instrument Panel (G56)
00053 - Rear Left Center Console Temperature Sensor (G311)
00054 - Rear Right Center Console Temperature Sensor (G312)
00926 - Terminal 30
Address 09: Cent. Elect. Labels:
VCID: 55ABB3CBACC9DE967D-512A
Note: Excessive Comm Errors
Address 16: Steering wheel Labels: 3D0-953-549.lbl
Part No: 3D0 953 549 D
Component: Lenksäulenmodul 3401
Coding: 0000032
VCID: 2E593C27BADFCD4EDC-512A
Address 37: Navigation Labels:
Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No: 3D0 035 456
Component: 08K-AUDIOVERST 0109
VCID: 5EB9ACE78AFF1DCE2C-5148
Subsystem 1 - Part No: 3D0 035 456
No Faults Found
End-------------------------(Elapsed Time: 10:55)--------------------------
