- Joined
- Oct 7, 2015
- Messages
- 53
- Reaction score
- 14
- VCDS Serial number
- C?ID=180423
A friend bought this car quite used with the ABS light on, among others. He brought it over and I scanned it, then cleared it. He got a new ABS controller, installed it, and we're still getting codes. I tried to login per the instructions in the wiki with no joy.
As was:
After clearing all:
Then after replacing the ABS controller (and doing some regular maintenance):
He replaced the wheel speed sensor, but that didn't fix it. Also I saw on a similar post Uwe request block 125. It's ABS 0 / Instruments 1. We checked and made sure the controller is properly plugged in, top and bottom, as well as the wheel speed sensor. Thanks for any help!
As was:
Thursday,25,February,2016,14:32:56:59113
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
Chassis Type: 3B (3B - VW Passat B5 (1997 > 2005))
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
VIN: Mileage: 230010km-142921miles
Address 01: Engine Labels: 078-907-551-ATQ.lbl
Part No: 3B0 907 551 CG
Component: 2.8L V6/5V G 0001
Coding: 07501
Shop #: WSC 00028
VCID: 6ADB9F571699006ECF-5140
WVWPH63B22P189333 VWZ7Z0A4249291
6 Faults Found:
P1570 - 35-10 - - Intermittent
18057 - Powertrain Data Bus
P1649 - 35-00 - Missing Message from ABS Controller
17819 - Secondary Air Injection System; Bank 2
P1411 - 35-00 - Insufficient Flow
17584 - Bank1: O2 (Lambda) Correction Behind Catalyst
P1176 - 35-10 - Control Limit Reached - Intermittent
16523 - Oxygen (Lambda) Sensor B1 S2
P0139 - 35-10 - Response too Slow - Intermittent
16826 - EVAP Emission Control Sys
P0442 - 35-10 - Small Leak - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 C
Component: 09 AIRBAG VW6 04 0004
Coding: 12345
Shop #: WSC 00028
VCID: 377D762315AB6D8680-4AE8
00532 - Supply Voltage B+
Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
Part No: 3B0 920 927 B
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 07235
VCID: 2447B16FB43D161E35-5124
01176 - Key
49-00 - No Communications
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00028
VCID: 70EF8D3F3045FABE81-5106
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 08 Komfortgerát HLO 0001
Coding: 00258
Shop #: WSC 00028
Subsystem 1 - Part No: 1C1959801
Component: 08 Tõrsteuer.FS KLO 0002
Subsystem 2 - Part No: 1C1959802
Component: 08 Tõrsteuer.BF KLO 0002
Subsystem 3 - Part No: 1C0959811
Component: 08 Tõrsteuer.HL KLO 0002
Subsystem 4 - Part No: 1C0959812
Component: 08 Tõrsteuer.HR KLO 0002
00913 - Window Regulator Switch; Front Right Driver (E81)
29-00 - Short to Ground
Address 56: Radio Labels: 3B7-035-1xx-56.lbl
Part No: 3B7 035 180
Component: Radio NP2 0005
Coding: 00031
Shop #: WSC 00028
VCID: 5DB1C48BD7D767D63A-5124
End-------------------------(Elapsed Time: 05:01)--------------------------
After clearing all:
Thursday,25,February,2016,16:57:40:59113
VIN: WVWPH63B22P189333 License Plate:
VIN: WVWPH63B22P189333 Mileage: 230010km-142921miles
Coding: 07501
Shop #: WSC 00028
Readiness: 0110 1101
Coding: 12345
Shop #: WSC 00028
VCID: 377D762315AB6D8680-5124
Coding: 07235
Coding: 00006
Shop #: WSC 00028
VCID: 70EF8D3F3045FABE81-5124
Coding: 00258
Shop #: WSC 00028
VCID: 377D762315AB6D8680-4B00
No Faults Found
Coding: 00031
Shop #: WSC 00028
End-------------------------(Elapsed Time: 05:12)--------------------------
VCDS Version: Release 15.7.4 (x64) Running on Windows 7 x64
Data version: 20160216
Thursday,21,April,2016,15:08:22:59113
VIN: WVWPH63B22P189333 Mileage: 237100km-147327miles
Coding: 07501
Shop #: WSC 00028
VCID: 6ADB9F571699006EC0-5140
Readiness: 0010 1001
Address 03: ABS Brakes Labels: 8E0-614-111-EDS.lbl
Part No: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D10
Shop #: BB 24334
VCID: 1C37898F8C4D2EDE82-5140
30-00 - Open or Short to Plus
Coding: 12345
Shop #: WSC 00028
VCID: 377D762315AB6D868F-5124
Coding: 07235
VCID: 2447B16FB43D161E3A-5124
01176 - Key
Coding: 00006
Shop #: WSC 00028
VCID: 70EF8D3F3045FABE8E-5124
Coding: 00258
Shop #: WSC 00028
VCID: 377D762315AB6D868F-4B00
Coding: 00031
Shop #: WSC 00028
VCID: 5DB1C48BD7D767D635-5106
End-------------------------(Elapsed Time: 04:54)--------------------------
