Need help
masanca
C?ID=261513
Hello guys I purchased a used Audi 2009 A4 couple of months ago my battery keeps dying on cold tempetures I decide to scan the car today and here is the report please help me out I’m trying to get answers and possible solutions I scan the car with engine running otherwise the battery will die, also this is the second battery since the car was purchased the first one was replaced from the dealer and the second one which I purchased was from autozone, I will include the two scans one from a month ago and the one from today
THIS IS THE OLD SCAN FROM LAST MONTH OR SO ONLY TWO CODES
Chassis Type: 8K (8T0)
Scan: 01 02 03 05 08 09 15 16 17 19 2E 36 42 46 47 52 53 55 56 62
          65 72 77
VIN: WAUSF78K69N056463   Mileage: 173460km-107783miles
Address 01: Engine (DL0MA-CAEB)       Labels: 06H-907-115-CAB.clb
   Part No SW: 8K2 907 115 AL    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF H14 0001
   Revision: E1H14---
   Coding: 0104010A190F0160
   Shop #: WSC 06120 444 122157
   ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001
   ROD: EV_ECM20TFS0118K2907115AL.rod
   VCID: 79F9B0D8F87B1BF61A-802C
7144 - Please Check DTC Memory in CAN Gateway (J533)
          U1008 00 [047] - -
                    Fault Frequency: 21
                    Mileage: 173199 km
                    Date: 2015.12.22
                    Time: 09:31:00
Address 02: Auto Trans (J217)       Labels: 0B6-927-156.clb
   Part No SW: 8K0 927 158 C    HW: 0B6 927 156
   Component: 0B6 20TFSIUSA H04 0050
   Revision: --H04---
   Coding: 001002
   Shop #: WSC 02145 785 00200
   ASAM Dataset: EV_TCMAL651 A01004
   ROD: EV_TCMAL651.rod
   VCID: 36637BE489E5348EB7-8062
Address 03: ABS Brakes        Labels: None
   VCID: 55A1DC68BCA31F965E-FFFE
No Faults Found
   Part No SW: 8K0 907 064 F    HW: 8K0 907 064 F
   Component: BCM2 1.1      H80 0145
   Coding: 090100
   Shop #: WSC 02399 823 56573
   VCID: 336542F0929721A690-8066
   Subsystem 1 - Part No SW: 8T0 959 754 A    HW: 8T0 959 754 A
   Component: ELVAUDIB8  H36 0041
   Part No SW: 8T1 820 043 AC    HW: 8T1 820 043 AC
   Component: KLIMA 3 ZONEN H06 0150
   Revision: C1000000    Serial number: 01160120090965
   Coding: 64002000
   Shop #: WSC 02391 823 56573
   VCID: 72EB87F4AD0D68AE5B-8026
   Part No SW: 8K0 907 063 D    HW: 8K0 907 063 D
   Component: BCM1 1.0      H22 0253
   Revision: 05022001    Serial number: 00000000298142
   Coding: 26001091063CAF010000080300003D0D0F1C520800010161000000
   VCID: 306F4DFC63811ABEED-8064
   Component: WWS 160109  H06 0070
   Coding: 00FD11
   Component: RLS  H04 0003
   Coding: 025028
   Subsystem 3 - Part No SW: 8K0 941 531 AA    HW: 8K0 941 531 AA
   Component: E1 - LDS  H07 0080
   Subsystem 4 - Part No SW: 8K0 907 410 B    HW: 8K0 907 410 B
   Component: HOMELINK  H01 0010
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 F    HW: 8K0 959 655 F
   Component: AirbagVW-AU10 H27 0410
   Serial number: 0039KD14S9CD
   Coding: 303836354230303030304A55304C384B3053
   Shop #: WSC 02135 785 00200
   ROD: EV_AirbaECUVWAUDI010_AU48.rod
   VCID: 408F1D3CDB218A3E1D-8014
   Subsystem 1 - Part No SW: 8K0 959 339 B    HW: 8K0 959 339 B
   Component: BF-Gewichtss.  H01 0030
   Serial number: 5810000R0800003ABP
   Serial number: 6334MSME42626D3DM
   Serial number: 6344MSME461141180
   Serial number: 6352QSME1E1904309
   Serial number: 6362QSME3E1B3734O
   Serial number: 63732SME07182134P
   Serial number: 63832SME39170D2E6
   Component: Lenks.Modul   H13 0013
   Revision: --------    Serial number: 90315IAF000HD
   Coding: 000016
   VCID: 3D7164C8A4D3E7D676-8068
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
   Part No SW: 8K0 920 950 A    HW: 8K0 920 950 A
   Component: KOMBIINSTR.   H18 0224
   Revision: 00000000    Serial number: 9DR66JF19
   Coding: 8B1F09000300D705020000
   VCID: 2D51548874B37756C6-8078
   Part No SW: 8T0 907 468 M    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0095
   Revision: GB300043    Serial number: 4300G091140028
   Coding: 000303
   VCID: 4B953A10EA675966F8-801E
02071 - Local Databus
                    Reset counter: 231
                    Mileage: 173206 km
                    Date: 2015.12.22
                    Time: 09:38:46
02252 - Generator
                    Fault Frequency: 19
                    Reset counter: 243
                    Mileage: 173207 km
                    Date: 2015.12.22
                    Time: 09:39:53
00458 - Control Module for Battery Monitoring (J367)
                    Fault Frequency: 19
                    Reset counter: 243
                    Mileage: 173207 km
                    Date: 2015.12.22
                    Time: 09:39:53
Address 2E: Media Player 3 (R199)       Labels: 8T0-035-785.clb
   Part No SW: 8T0 035 785     HW: 8T0 035 785
   Component: SG ext.Player H06 0210
   Revision: 00000000
   Coding: 020302
   VCID: 78FFB5DCCB7102FE65-802C
Address 36: Seat Mem. Drvr (J136)       Labels: 8T0-959-760.clb
   Part No SW: 8K0 959 760     HW: 8K0 959 760
   Component: MEM-FS        H05 0043
   Revision: AA000000    Serial number: 00001001206969
   Coding: 00581300000000000000
   VCID: 77FDB6E0C66F0D866C-8022
   Part No SW: 8K0 959 793 D    HW: 8K0 959 793 D
   Revision:             Serial number: 0000008282327
   Coding: 011C03204E00410001
   VCID: 41891838D82B833612-8014
   Revision: 00002001    Serial number: 0116792945
   Coding: 0106063A007A440400B001
   Subsystem 1 - Part No SW: 8K0 959 719     HW: 8K0 959 719
   Component: GTO BF  H06 0040
   Subsystem 3 - Part No SW: 8K0 959 591     HW: 8K0 959 591
   Component: J245 PS034  H06 0037
02615 - Fuel Tank Cap; Lock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 231
                    Mileage: 173210 km
                    Date: 2015.12.22
                    Time: 09:45:24
02616 - Fuel Tank Cap; Unlock
                    Reset counter: 231
                    Mileage: 173210 km
                    Date: 2015.12.22
                    Time: 19:32:47
Address 47: Sound System (J525)       Labels: 8T0-035-223-ASC.clb
   Part No SW: 8T0 035 223 AB    HW: 8T0 035 223
   Component: DSP STD       H07 0220
   Revision: S2100000
   Coding: 0203010102
   VCID: 6ED39384B9354C4EBF-803A
   Part No SW: 8K0 959 792 D    HW: 8K0 959 792 D
   Revision:             Serial number: 0000008239251
   Coding: 011C03205E00410001
   VCID: 408F1D3CD3218A3E1D-8014
   Part No SW: 8K0 907 801 F    HW: 8K0 907 801 F
   Component: EPB Audi B8   H06 0070
   Revision: 00000003    Serial number: 10000000161823
   VCID: 326B47F46D8D28AE9B-8066
   Part No: 8K5 907 357
   Coding: 0000004
   VCID: 77FDB6E0066F0D866C-8022
Address 56: Radio (J503)       Labels: 8Tx-035-1xx-56.clb
   Part No SW: 8T1 035 195 L    HW: 8T1 035 195 L
   Component: Symph3 Sirius H02 0231
   Revision: 00000005    Serial number: AUZ5Z4H1073396
   Coding: 040200020101850043D9070800
   Subsystem 1 - Part No SW: 8T0 919 603 F    HW: 8T0 919 603 F
   Component: Display
Address 62: Door, Rear Left (J388)       Labels: 4F0-959-795.clb
   Part No SW: 4F0 959 795 N    HW: 8K0 959 795 C
   Revision:             Serial number: 0000100642381
   Coding: 010C03204000210001
   VCID: 4487112CC739961E39-8010
Address 65: Tire Pressure (J502)       Labels: 8K0-907-273.clb
   Part No SW: 8K0 907 273 A    HW: 8K0 907 273 A
   Component: J502-RDK      H03 0250
   Revision: 00001001    Serial number: 13140790028943
   Coding: 0CD154
Address 72: Door, Rear Right (J389)       Labels: 4F0-959-795.clb
   Revision:             Serial number: 0000100642370
   Part No SW: 8T0 862 336 C    HW: 8T0 862 336 C
   Component: FSE_256x BT     H33 0550
   Revision: 00000000    Serial number: 00000005030286
   Coding: 0010370
   Shop #: WSC 02256 785 00200
   VCID: 3B756AD07AC7E9E648-806E
TODAY'S SCAN SAME 2 CODES PLUS ANOTHER 2 IM WONDERING IF IT IS LOW VOLTAGE
Thursday,17,March,2016,19:21:48:41545
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
VIN: WAUSF78K69N056463   License Plate:
Mileage: 178200km-110728mi   Repair Order: Audi 2009 A4
          65 72 77
VIN: WAUSF78K69N056463   Mileage: 178200km-110728miles
   Revision: E1H14---
   VCID: 79F9B0D8F87B1BF636-802C
          U1113 00 [039] - -
                    Mileage: 178208 km
                    Date: 2016.03.17
                    Time: 19:15:34
          U1113 00 [039] - -
                    Mileage: 178208 km
                    Date: 2016.03.17
                    Time: 19:15:34
          U1008 00 [039] - -
                    Mileage: 178208 km
                    Date: 2016.03.17
                    Time: 19:15:35
Readiness: 1110 0101
   Revision: --H04---
   Coding: 001002
   VCID: 36637BE489E5348E9B-8062
Address 03: ABS Brakes (J104)       Labels: 8K0-907-379-V1.clb
   Part No SW: 8K0 907 379 AF    HW: 8K0 907 379 AF
   Component: ESP8 quattro  H04 0210
   Coding: 150500
   VCID: 7DF1A4C8E45327D61A-8028
   Coding: 090100
   VCID: 336542F0929721A6BC-8066
   Coding: 64002000
   VCID: 72EB87F4AD0D68AE77-8026
   VCID: 306F4DFC63811ABEC1-8064
   Coding: 00FD11
   Coding: 025028
   VCID: 408F1D3CDB218A3E31-8014
   Coding: 000016
   VCID: 3D7164C8A4D3E7D65A-8068
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 190
                    Mileage: 178208 km
                    Date: 2016.03.17
                    Time: 19:15:34
   VCID: 2D51548874B37756EA-8078
   Coding: 000303
   VCID: 4B953A10EA675966D4-801E
                    Reset counter: 190
                    Mileage: 178208 km
                    Date: 2016.03.17
                    Time: 19:15:34
02252 - Generator
                    Reset counter: 190
                    Mileage: 178208 km
                    Date: 2016.03.17
                    Time: 19:16:34
                    Reset counter: 190
                    Mileage: 178208 km
                    Date: 2016.03.17
                    Time: 19:16:34
   Revision: 00000000
   Coding: 020302
   VCID: 78FFB5DCCB7102FE49-802C
   VCID: 77FDB6E0C66F0D8640-8022
   VCID: 41891838D82B83363E-8014
   Coding: 0106063A007A448400B001
   Revision: S2100000
   Coding: 0203010102
   VCID: 6ED39384B9354C4E93-803A
   VCID: 408F1D3CD3218A3E31-8014
   VCID: 326B47F46D8D28AEB7-8066
                    Fault Status: 11101101
                    Reset counter: 190
                    Mileage: 178208 km
                    Date: 2016.03.17
                    Time: 19:17:37
                    Voltage: 13.20 V
                    Count: 80
                    Hex Value: 0x0270
                    Hex Value: 0x0001
                    Hex Value: 0x0101
                    Reset counter: 190
                    Mileage: 178208 km
                    Date: 2016.03.17
                    Time: 19:15:34
                    Voltage: 13.10 V
                    Count: 62
                    Hex Value: 0x0270
                    Hex Value: 0x0001
                    Hex Value: 0x0101
   Coding: 0000004
   VCID: 77FDB6E0066F0D8640-8022
   Component: Display
   VCID: 4487112CC739961E15-8010
   Coding: 0CD154
   Coding: 0010370
   VCID: 3B756AD07AC7E9E664-806E
End-------------------------(Elapsed Time: 03:51)--------------------------
Address 53: DTCs cleared
DrPeter
16.4905° S, 151.7375° W
....please help me out I’m trying to get answers and possible solutions I scan the car with engine running otherwise the battery will die, also this is the second battery since the car was purchased the first one was replaced from the dealer and the second one which I purchased was from autozone
- If you have a look at your Auto-Scan, there are two fault codes in the 19-Gateway controller that tell the story.
02252 - Generator
Without proper communication to the above, the Gateway can not properly handle the Generator and Battery functions.
- You should verify you have the correct battery, the stock battery by VIN was '380A (80 Ah)' = [PR-J0R code(on vehicle build sticker)]
- You can use non OEM/Audi batteries, I find that using a battery from Audi is best because the Gateway controller will know that battery by part number and that was what the vehicle systems were designed around.
- And, you will need to teach the Gateway the new battery when these faults have been corrected.
Audi CAN Gateway Battery Coding (8T/8K/8R+)
- Next you will need to evaluate the status of the LIN-Bus for the Gateway controller, this can be done by looking at Measuring Value Block group [006]
Here you will find the following:
Generator Communication Status and Battery Sensor (J367) Communication Status
- If you find a value of (1) - this indicates there is LIN-Bus communication at this time, a value of (0) means no signal/communication with that component.
- You can also view some information about the Generator within the Advanced Measuring Values when connected to the 01-Engine. Select the following:
066 - Generator power (watts)
067 - Generator load signal (%)
181 - Supply voltage Terminal 30 (volts)
I would recommend to use the Factory Wiring diagrams and workshop manual to locate and help inspect the wiring harness, connections and components for any concerns.
Hope this helps,
drpeter
masanca
C?ID=261513
Hope this helps,
drpeter
Thank you, I will keep you posted also today I have a message on the dashboard that states to turn off the car because the car dint have any oil in it which is impossible cause we change the oil 2 weeks ago.
