Lights issues after changing BCM (1k0 937 087 J)
killep2
C?ID=214777
Hello Guys,
I need your urgent assistence please!!
I changed the "BCM" since the original fail on my front left turn signal (It was turned ON permanently even if the car was Off)
Both, the original and the new one are the same number (087J)
After I changed the unit, I just copy and then paste the Original Code from the Module 09 to the New one
Made the tunning on the Adaptation as it was on the old one and Wala ! I fix the turning light issue.
But I found an issues,
1) The reverse (backup light) left - driver side Light not working when reversing. I figure this out since my reverse sensor connected to this light and it stopped working.
BUT! The interesting point is that the bulbs test when turning on the ignition (the blinking)works fine on this light. I hear the Bip-Bip from the reversing sensor unit and if i am putting a LED instead of regular bulb I see it blinking three time. From my side, this mean the the "channel" is OK.
2) I don't know if this is an issue with my configuration after the change of the BCM or after some config changes (after the change of BCM) but when my trunk is open, the parking lights (the small tail bulbs) not works . They are turning on only when I am closing the trunk !!!!! :(
3) I have now a warning light about washing liquid when I even dont have the sensor :( I don't know how to turn off this light.
The car is SKODA Octavia 1.8 TSI model 2011 Elegance.
I am attaching the full-scan.
Wednesday,14,May,2014,20:21:03:40508
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
Dealer/Shop Name: Big-Byte
VIN: TMBBK61Z7B8022701   License Plate:
Chassis Type: 1Z (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
Address 01: Engine (CDA)       Labels: 06J-907-115-CDA.clb
   Part No SW: 3T0 907 115 G    HW: 1Z0 907 115 F
   Component: 1.8l R4/4V TFSI     0030
   Revision: AAH18---    Serial number:
   Coding: 0203000C24070060
   Shop #: WSC 64888 768 16448
   VCID: 356136445CDF4AB6781-8060
001089 - EVAP Emission Control Sys
               P0441 - 000 - Incorrect Flow
                    Mileage: 65255 km
                    Date: 2001.14.18
                    Time: 20:00:35
                    RPM: 834 /min
                    Load: 15.7 %
                    Temperature: 90.0°C
                    Temperature: 39.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.716 V
Readiness: 0010 0000
Address 02: Auto Trans        Labels: 0AM-300-04x.lbl
   Part No SW: 0AM 300 050 E    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 2673
   Revision: 00043014    Serial number: CU501307285442
   Shop #: WSC 00029 730 29360
   VCID: 2B55103C8A9B0C461E5-807E
   Part No SW: 1K0 907 379 BE    HW: 1K0 907 379 BE
   Component: ESP MK60EC1   H31 0108
   Revision: 00H31001
   Coding: 113B401C092400FC881202E4901A0041350800
   Shop #: WSC 73430 790 00000
   VCID: 76E3F148C15901AEB1B-8023
   Part No SW: 3T0 907 044 AR    HW: 3T0 907 044 AR
   Component: Climatronic   H15 0401
   Revision: 00005001
   Coding: 0000000002
   Shop #: WSC 73430 790 00999
   ROD: EV_ClimaAutoBasis_SE36.rod
   VCID: 820B1D981591AD0E0D3-80D7
   Part No SW: 1K0 937 087 J    HW: 1K0 937 087 J
   Component: BCM PQ35  H   103 0615
   Revision: 00103 AD
   Coding: 40180AB8AC3708C04008008111008DE442FD00EE504D89205C0440000040
   VCID: 387F3F708BCDB7DE637-806D
   Subsystem 1 - Part No: 1Z1 955 119 D  Labels: 1KX-955-119.CLB
   Component: Wischer 18101  26  0601
   Coding: 00DFB7
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 178
                    Mileage: 65255 km
                    Date: 2001.14.18
                    Time: 20:17:29
                    Voltage: 13.70 V
                        Term 50 Off
00985 - Right Tail Light (M2)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 178
                    Mileage: 65255 km
                    Date: 2001.14.18
                    Time: 20:17:30
                    Voltage: 13.75 V
                        Term 50 Off
   Component: Q6 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PC212XEE
   Coding: 0020790
   VCID: 3D712E6464EF92F6B01-8068
   Subsystem 1 - Serial number: 6332MSME583233702
   Subsystem 2 - Serial number: 6342MSME583233679
   Subsystem 3 - Serial number: 6351HSME24654321.
   Subsystem 4 - Serial number: 6361HSME24635D078
   Part No SW: 5K0 953 521 AR    HW: 5K0 953 569 A
   Component: LENKS.MODUL   009 0136
   Revision: FF010039    Serial number: 20101008301625
   Coding: 1882000000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7CF7E360F7755BFEC7F-8029
   Subsystem 1 - Part No SW: 3T0 959 537     HW: 3T0 959 537   Labels: 3C8-959-537.CLB
   Component: E221__MFL-URO  H07 0012
   Coding: 800000
   Part No SW: 1Z0 920 843 K    HW: 1Z0 920 843 K
   Component: KOMBI         H20 0420
   Coding: 110D01
   Shop #: WSC 73430 031 12345
   ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
   VCID: 408F5790DB1DFF1EDB7-8015
Address 19: CAN Gateway        Labels: 7N0-907-530-V1.clb
   Part No SW: 7N0 907 530     HW: 1K0 907 951
   Component: J533  Gateway   H27 5603
   Revision:   H27       Serial number: 161010F2002537
   Coding: ED807F0600020200001302
   VCID: EDD15E24F40F4276C01-80B8
   Component: IMMO          H20 0420
   ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
   VCID: EADB55380DE1554EA53-80BF
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
   Part No SW: 1T0 959 701 AA    HW: 1T0 959 701 AA
   Coding: 0004342
   VCID: 76E3F148015901AEB1B-8023
   Part No: 1K0 909 144 J
   Revision: 00H17000
   VCID: 31690254A8B76696249-8064
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
   Part No SW: 1T0 959 702 S    HW: 1T0 959 702 S
   Coding: 0004342
   VCID: 489F4FB03B2DC75E137-801D
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 1Z0 035 161 F    HW: 1Z0 035 161 F
   Component: SWING         009 0065
   Revision: 0I001001    Serial number: SKZ1Z2K8411072
   Coding: 050004000004
   VCID: 3169025468B76696249-8064
   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Coding: 0000144
   Shop #: WSC 73430 790 1012544
   VCID: 326B0D58ADB15D8E5D3-8067
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0000144
   VCID: 3365085C52AB5486565-8066
Do you have the old BCM still and did you read the coding prior to swap?
killep2
C?ID=214777
I think this is the one. This is the only config I have that the oldest one.
From the fault of the Turn light I can assume that this is the old one since this was a main issue on the BCM
Sunday,11,May,2014,15:52:13:40508
VIN:    License Plate: 6018473
Mileage: 64987   Repair Order:
               P0441 - 000 - Incorrect Flow - Intermittent
                    Mileage: 64525 km
                    Date: 2001.14.06
                    Time: 14:37:54
                    RPM: 834 /min
                    Load: 19.2 %
                    Temperature: 97.0°C
                    Temperature: 45.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 13.589 V
005488 - Engine Start Blocked by Immobilizer
               P1570 - 000 -  - Intermittent
                    Mileage: 64972 km
                    Date: 2001.14.15
                    Time: 10:59:04
                    RPM: 912 /min
                    Load: 14.5 %
                    Temperature: 95.0°C
                    Temperature: 51.0°C
                    Voltage: 11.684 V
   Revision: 00H31001
   Coding: 113B401C092400FC881202E4901A0041350000
   Revision: 00005001
   Coding: 0000000002
9472881 - Motor for Fresh Air / Recirculated Air Flap
          B108B 71 [008] - Actuator stuck
                    Reset counter: 172
                    Mileage: 64239 km
                    Date: 2001.14.01
                    Time: 16:54:37
   Revision: 00103 AD
   Coding: 40180AB8A00508C04008008011000124420000AE524D89605C0440000040
   Coding: 00D7B7
6 Faults Found:
01503 - Bulb for 3rd Brake Light (M25)
                    Fault Status: 00100111
                    Fault Frequency: 176
                    Reset counter: 207
                    Mileage: 64119 km
                    Date: 2000.14.29
                    Time: 08:06:31
                    Voltage: 13.65 V
                        Term 50 Off
                    Fault Status: 00101010
                    Fault Frequency: 76
                    Reset counter: 207
                    Mileage: 64121 km
                    Date: 2000.14.29
                    Time: 08:11:32
                    Voltage: 13.75 V
                        Term 50 Off
                    Fault Status: 00101110
                    Fault Frequency: 109
                    Reset counter: 207
                    Mileage: 64147 km
                    Date: 2000.14.29
                    Time: 17:06:56
                    Voltage: 14.00 V
                        Term 50 Off
                    Fault Frequency: 27
                    Reset counter: 167
                    Mileage: 64145 km
                    Date: 2000.14.29
                    Time: 16:58:23
                    Voltage: 14.05 V
                        Term 50 Off
                    Reset counter: 167
                    Mileage: 64987 km
                    Date: 2001.14.15
                    Time: 15:46:27
                    Voltage: 12.10 V
                        Term 50 Off
01800 - Light Switch (E1)
                    Reset counter: 204
                    Mileage: 64893 km
                    Date: 2001.14.14
                    Time: 20:21:57
                    Voltage: 13.95 V
                        Term 50 Off
   Coding: 0020790
   Coding: 1882040000
   Coding: 800000
   Coding: 110B01
   Shop #: WSC 73430 031 00000
   Coding: 0004342
00131 - Outside Door Handle Illumination/mirror Light Driver Side
   Revision: 00H17000
   Coding: 0004342
00132 - Outside Door Handle Illumination/mirror Light Passenger Side
   Coding: 050004000001
   Coding: 0000144
   Coding: 0000144
old : 40180AB8A00508C04008008011000124420000AE524D89605C0440000040<<<<<<<<<<<<<<<<<<<<<< try recoding to this.
new: 40180AB8AC3708C04008008111008DE442FD00EE504D89205C0440000040
killep2
C?ID=214777
Hi again,
I will try to do this tomorrow.
Meanwhile, I just found another issue
The backup light that I mentioned in my original post is working (dont laugh) when I am turning OFF DLR on the panel menu......
Also the back parking-light stop work when I am opening the trunk. It is come back to normal when I am closing it.
I dont know what is wrong there
I will try to change the code back to what you wrote and post the results
Dana
Western PA, USA
Hi again,
Okay man but I am laughing......sorry.;)
Welcome to Byte 18 club! Once you join you cannot go back - LOL
In all seriousness the LR reverse/rear fog and RF DRL swap positions when Byte 18 is modified. Common with Mk6 Golf LED tail light retrofits so the fix is to code Byte 18 properly and then swap wires if needed. (NAR cars aren't born with rear fogs at all)
This isn't a Golf and you aren't retrofitting tails so I don't want to steer you off track. I'm just saying that is a coding issue and a neat game the module plays. Code this per Jack's suggestion and if that isn't resolved we can dig deeper.
killep2
C?ID=214777
Man, its not funnyyyyyhhh :D
Listen, I didnt change the 18 one so I dont know where it come from, My luck I save the original scan :))
As I mention, I will try tomorrow and reply with the results.
I have few more issues but I am afraid you will laugh again ;) (just kidding)
cheers
killep2
C?ID=214777
I checked the new code on my car.
After I put the new code. I didnt find any changes to better side
Just the configuration from my coding dissaper (cornering)
I am also checked the 18 bytes. I can guarantee for 100% that I didnt change there nothing since I saw the warning.
* Is it possible that is was changed some how from another coding ?
* Is it possible that it was change befire arrive to me ....(The BCM was on Factory Mode when it arrive)
After the change I have disconnect the battery and by that reset the BCM (some Options on the menu dissappear only after that)
Current situation is as follow:
1) now both of reversing light not functioning (also on the backup light test and on the Lamp test)
2) I found out that the Rear fog light not functioning also and also both. I see on dashboard that it is turned on but it wasn't.
3) Still have issue with Parking light going off when trunk open
I am posting again the scan after i issue the new code that you provides me.....HELP!!!!!!!!!! PLEASE!! !!!
 Friday,16,May,2014,12:17:58:40508
                    Mileage: 65315 km
                    Date: 2001.14.20
                    Time: 10:09:30
                    RPM: 836 /min
                    Load: 18.8 %
                    Temperature: 96.0°C
                    Temperature: 51.0°C
                    Voltage: 13.589 V
001674 - ECM Power Relay Load Circuit: (J271)
               P068A - 000 - De-Energized Performance Too Early
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 96.0°C
                    Temperature: 60.0°C
                    Voltage: 9.144 V
   Revision: 00H31001
   Revision: 00005001
   Coding: 0000000002
   Revision: 00103 AD
   Coding: 00DFB7
            014 - Defective
                    Fault Frequency: 10
                    Reset counter: 181
                    Mileage: 65321 km
                    Date: 2001.14.20
                    Time: 10:50:19
                    Voltage: 11.90 V
                        Term 50 Off
01134 - Alarm Horn (H12)
                    Reset counter: 181
                    Mileage: 65321 km
                    Date: 2001.14.20
                    Time: 10:56:38
                    Voltage: 11.80 V
                        Term 50 Off
01502 - Bulb for Rear Fog; Left (L46)
                    Reset counter: 221
                    Mileage: 65321 km
                    Date: 2001.14.20
                    Time: 11:01:55
                    Voltage: 13.65 V
                        Term 50 Off
                    Fault Status: 01100111
                    Fault Frequency: 7
                    Reset counter: 181
                    Mileage: 65321 km
                    Date: 2001.14.20
                    Time: 10:57:30
                    Voltage: 13.60 V
                        Term 50 Off
                    Reset counter: 181
                    Mileage: 65321 km
                    Date: 2001.14.20
                    Time: 00:00:44
                    Voltage: 12.25 V
                        Term 50 Off
   Coding: 0020790
   Coding: 1882000000
   Coding: 800000
   Coding: 110901
   Coding: 0004342
   Revision: 00H17000
            000 - - - MIL ON
                    Fault Status: 11100000
                    Battery Volts: 12.6 V
                        PD
                    Temperature: 61.0°C
                    Count: 2
                    Steering Angle: 0.00°
                    Count: 1
                        SteerAng n.Init
   Coding: 0004342
   Coding: 0000144
   Coding: 0000144
Okay................I want you to remove bulbs one at a time and search for damaged or cross filaments dumping current or ground on a back feed causing ghosts.
Also after each removal check function of other lights in question.
Start with current DTC's at default coding from the old unit......
Battery voltage and connectivity is suspect at static key on, please check into that...........!
Dana
Western PA, USA
Per the original coding:
.. Byte 18 was masked / hidden by zeros. That means the real value was not shown and the new control module would not be coded properly out of the box in this particular area. For this reason we will need to find the proper value but I'm concerned about the nature of the original BCM failure. That happens when aftermarket lights (typically cheap HID kits) or aftermarket trailer modules are installed but BCMs can fail for any number of reasons.
That main questions/concerns at this point are:
How or why did that original controller fail?
Are ALL of the exterior lights and light bulbs per factory design at this time?
-Dana
killep2
C?ID=214777
-Dana
Hi Dana and Jack
First of all I would like to thank you for the help
Dana,
Yes, it fails on the next day after aftermarket HID kits installation.
The fail occured on the left front "turn signal". It is glowed parmanently, even if the car is turned off.... just in one moment it started to glow :(
I didn't understand your last question;
You asking me, If all the fail that I see, they are on the bulbs and lights that was designed on factory ? If so, the answer is YES.
This is not about retrofitted lights.
The main reason for buying VCDS was to change the BCM and turn on "Cornering on Fog light" and maybe some additional tweaks.....
Jack, regarding your suggestion.
I did this check even before I wrote a post.
I even changed all the bulbs to the new one.
All the results that I describe here are a conclusions from my test so it is not a wiring problem or whatever ... :(
I am sure for 100% that If I will change the BCM back on to the OLD one, then lights would be back to normal...
But I am not taking this in account, since the old BCM got a fail on the "turn signal"
Looking forward for your reply!
Thanks again,
nitram
CT
C?ID=162205
Not sure if I can be much help to you as it may be too late and I am a novice at this, the type of problem you are experiencing seems to relate to Byte18 and this setting comes with a warning not to make changes. I changed the BCM (CECM) in my car a couple of years ago and took extensive notes at the time, these included pictures, screen shots of every byte and full scans before I started. After installing the new BCM and taking it out of factory mode I copied and pasted the old settings and it worked perfectly.
I have been through my notes and I really don't see anything else that would account for your issues, but it wouldn't do any harm to step through every one with the long coding helper and verify these are correct.
I would suggest you also double check the the old and new unit are the same part number, I don't think you can mix up the 3 connectors but verify these are also correct, on my car they are Black - White - Gold.
I am also attaching a file which I am not sure if this is applicable to your car but may help, it describes the code options for byte18, I don't know if it is correct and I have never tried changing any of these buy it may help you to resolve your problems.
DEC HEX
 1 01 BCM default ROM 1
 2 02 VW360 Halogen VW360 RdW TFL_0 ROM 2 VW360 VW360 halogen RdW TFL_0 Rom 2
 3 03 VW360 Halogen VW360 NAR TFL_0 ROM 3 VW360 VW360 halogen NAR TFL_0 ROM 3
 4 04 VW360 GTI Halogen "VW360 RdW TFL_0_LED + LED_SBBR" ROM 4 VW360 GTI halogen "VW360 RdW TFL_0_LED + LED_SBBR" ROM 4
 5 05 VW351 Halogen VW351 RdW TFL_0 ROM 5 VW351 VW351 halogen RdW TFL_0 ROM 5
 6 06 VW351 Halogen VW351 NAR TFL_0 ROM 6 VW351 VW351 halogen NAR TFL_0 ROM 6
 7 07 VW351C Halogen VW351 CHN TFL_0 ROM 7 VW351C halogen VW351 CHN TFL_0 ROM 7
 8 08 VW362 Halogen VW362 RdW TFL_0 ROM 8 VW362 VW362 halogen RdW TFL_0 ROM 8
 9 09 VW362 Halogen VW362 NAR TFL_0 ROM 9 VW362 VW362 halogen NAR TFL_0 ROM 9
 10 0A VW364 LL Halogen VW364 RdW TFL_0 LL ROM 10 VW364 VW364 halogen LL LL ROW TFL_0 ROM 10
 11 0B VW364 RL Halogen VW364 RdW TFL_0 RL ROM 11 VW364 VW364 RL halogen RdW TFL_0 RL ROM 11
 12 0C VW367 Halogen VN337 RdW TFL_0 ROM 12 VW367 halogen VN337 RdW TFL_0 ROM 12
 13 0D VW368 Halogen VN337 RdW TFL_0_Ska ROM 13 VW368 halogen VN337 RdW TFL_0_Ska ROM 13
 14 0E VW369 Halogen VW369 RdW TFL_0 ROM 14 VW369 VW369 halogen RdW TFL_0 ROM 14
 15 0F SE350/2 Xenon XENON SE352/7 NAR TFL_0 XE ROM 15 SE350 / SE352 XENON Xenon 2 / 7 NAR TFL_0 XE ROM 15
 16 10 SE351/9 Xenon XENON SE351/9 NAR TFL_0 XE ROM 16 SE351 / SE351 XENON Xenon 9 / 9 NAR TFL_0 XE ROM 16
 17 11 SE350/2 Halogen Halogen SE352/7 NAR TFL_S ROM 17 SE350 / SE352 2 Halogen Halogen / 7 NAR TFL_S ROM 17
 18 12 SE351/9 Halogen Halogen SE351/9 NAR TFL_S ROM 18 SE351 / SE351 9 Halogen Halogen / 9 NAR TFL_S ROM 18
 19 13 VW428 Halogen VW428 RdW TFL_1 ROM 19 VW428 VW428 halogen RdW TFL_1 ROM 19
 20 14 VW428 XENON VW428 RdW TFL_1 XE ROM 20 VW428 VW428 RdW TFL_1 XENON XE ROM 20
 21 15 VW360 GTI Halogen "VW360 RdW TFL_0 +LED SBBR" ROM 21 VW360 GTI halogen "VW360 RdW TFL_0 + LED SBBR" ROM 21
 22 16 SE350/2 Xenon XENON SE352/7 RdW TFL_0 XE ROM 22 SE350 / SE352 XENON Xenon 2 / 7 ROW TFL_0 XE ROM 22
 23 17 SE351/9 Xenon XENON SE351/9 RdW TFL_0 XE ROM 23 SE351 / SE351 XENON Xenon 9 / 9 ROW TFL_0 XE ROM 23
 24 18 SE350/2 Halogen Halogen SE352/7 RdW TFL_S ROM 24 SE350 / SE352 2 Halogen Halogen / 7 ROW TFL_S ROM 24
 25 19 SE351/9 Halogen Halogen SE351/9 RdW TFL_S ROM 25 SE351 / SE351 9 Halogen Halogen / 9 ROW TFL_S ROM 25
 26 1A Halogen SK462 ohneTFL / TFL-ABL ROM 26 Halogen SK462 ohneTFL / TFL-ABL ROM 26
 27 1B SK461 Halogen SK461 ohne TFL / TFL-ABL ROM 27 SK461 SK461 halogen without TFL / DRL-ABL ROM 27
 28 1C SK461 Halogen SK461 RdW sep.TFL_1 ROM 28 SK461 SK461 halogen RdW sep.TFL_1 ROM 28
 29 1D SK461 XENON SK356 ASUV TFL_Sep ROM 29 SK461 SK356 XENON ASUV TFL_Sep ROM 29
 30 1E VW360 Halogen "VW351 NAR TFL_0 + SMR auf SL-hinten " ROM 30 VW360 halogen "VW351 NAR TFL_0 + SMR on SL-back" ROM 30
 31 1F VW360 Halogen "VW360 NAR TFL_0+LED SBBR" ROM 31 VW360 halogen "VW360 NAR TFL_0 + LED SBBR" ROM 31
 32 20 VW360 Halogen VW360 NAR TFL_0_LED ROM 32 VW360 VW360 halogen NAR TFL_0_LED ROM 32
 33 21 VW360 Halogen "VW360 NAR TFL_0_LED+LED_SBBR" ROM 33 VW360 halogen "VW360 NAR TFL_0_LED + LED_SBBR" ROM 33
 34 22 VW360 Halogen "VW360 RdW/Japan+LED_SBBR" ROM 34 VW360 halogen "VW360 ROW / Japan + LED_SBBR" ROM 34
 35 23 AU350PA Halogen "VW360 NAR TFL_0_LED+LED_SBBR" ROM 35 AU350PA halogen "VW360 NAR TFL_0_LED + LED_SBBR" ROM 35
 36 24 AU350PA Halogen VW362 RdW TFL_1 ROM 36 AU350PA halogen VW362 RdW TFL_1 ROM 36
 37 25 AU350PA Halogen VW364 RdW TFL_0 LL_Ska ROM 37 AU350PA halogen VW364 RdW TFL_0 LL_Ska ROM 37
 38 26 AU350PA XENON VW364 RdW TFL_0 RL_Ska ROM 38 AU350PA XENON VW364 RdW TFL_0 RL_Ska ROM 38
 39 27 AU350PA XENON VW316 RdW TFL_1_Ska ROM 39 AU350PA XENON VW316 RdW TFL_1_Ska ROM 39
 40 28 AU350PA XENON VW465 RdW TFL_1_Ska ROM 40 AU350PA XENON VW465 RdW TFL_1_Ska ROM 40
 41 29 AU353PA Halogen VW362 RdW TFL_0_Ska ROM 41 AU353PA halogen VW362 RdW TFL_0_Ska ROM 41
 42 2A AU353PA Halogen "TFL mit Heck, AB2 PA 5Türer ECE" ROM 42 AU353PA halogen "TFL rear, AB2 PA 5Doors ECE" ROM 42
 43 2B AU353PA XENON "LED TFL ohne Heck, AB2 PA 5Türer ECE" ROM 43 AU353PA XENON "LED TFL without Heck, PA AB2 5Doors ECE" ROM 43
 44 2C AU353PA XENON "LED TFL mit Heck, AB2 PA 5Türer ECE" ROM 44 AU353PA XENON "LED TFL rear, AB2 PA 5Doors ECE" ROM 44
 45 2D AU356PA Halogen AU356PA RdW TFL_0 ROM 45 AU356PA halogen AU356PA RdW TFL_0 ROM 45
 46 2E AU356PA XENON AU356PA RdW TFL_0 XE ROM 46 XENON XE AU356PA AU356PA RdW TFL_0 ROM 46
 47 2F VW316 Halogen/XENON VW316 RdW TFL_0 ROM 47 VW316 Halogen / Xenon VW316 RdW TFL_0 ROM 47
 48 30 VW316 XENON Halogen/XENON VW316 RdW TFL_S ROM 48 VW316 XENON Halogen / Xenon VW316 RdW TFL_S ROM 48
 49 31 SK462 Halogen SK462 separat TFL_1 ROM 49 SK462 SK462 halogen separately ROM TFL_1 49
 50 32 SK350 Halogen SK35x-RS TFL_LED-RL aus TFL ROM 50 SK350 SK35x halogen-RS-RL TFL_LED ROM from TFL 50
 51 33 SK350 Halogen SK35x-RS TFL_LED-LL aus TFL ROM 51 SK350 SK35x halogen-RS-LL TFL_LED ROM from TFL 51
 52 34 SK350 Halogen SK351 TFL_1sep. SK350 SK351 TFL_1sep halogen. RL aus TFL ROM 52 RL ROM from TFL 52
 53 35 SK350 Halogen SK351 TFL_1.sep LL ausTFL ROM 53 SK350 SK351 halogen TFL_1.sep LL ausTFL ROM 53
 54 36 SK350 Halogen SK351 RL TFL-ABL(S) ROM 54 SK350 SK351 halogen RL TFL-ABL (P) ROM 54
 55 37 SK350 Halogen SK351 LL TFL-ABL(S) ROM 55 SK350 SK351 halogen LL TFL-ABL (P) ROM 55
 56 38 SK350 Halogen SK351 TFL_SH RL ROM 56 SK350 SK351 halogen TFL_SH RL ROM 56
 57 39 SK350 Halogen SK351 TFL_SH LL ROM 57 SK350 SK351 halogen TFL_SH LL ROM 57
 58 3A AU210 Halogen VW364 RdW TFL_S LL ROM 58 AU210 halogen VW364 TFL_S ROW ROM 58
 59 3B entfallen XENON VW364 RdW TFL_S RL ROM 59 XENON account VW364 RdW TFL_S RL ROM 59
 60 3C VW360 XENON VW360 RdW XE TFL_S ROM 60 VW360 VW360 RdW XENON XE TFL_S ROM 60
 61 3D VW360 XENON VW360 NAR XE TFL_S ROM 61 VW360 VW360 NAR XENON XE TFL_S ROM 61
 62 3E VW360 Halogen VW360 NAR ROM 62 VW360 VW360 halogen NAR ROM 62
 63 3F VW360 XENON "VW360 Ska XE TFL_S LED_SBBR" ROM 63 VW360 XENON "VW360 Ska XE TFL_S LED_SBBR" ROM 63
 64 40 VW360 Halogen VW360 RdW ROM 64 VW360 VW360 halogen ROW ROM 64
 65 41 VW360 XENON VW360 RdW XE PO_LED ROM 65 VW360 VW360 RdW XENON XE PO_LED ROM 65
 66 42 VW360 XENON VW360 Ska XE TFL_S_LED ROM 66 VW360 VW360 Ska XENON XE TFL_S_LED ROM 66
 67 43 VW360 Halogen "VW360 Ska TFL_S LED_SBBR" ROM 67 VW360 halogen "VW360 Ska TFL_S LED_SBBR" ROM 67
 68 44 VW360 XENON "VW360 RdW XE LED_SBBR" ROM 68 VW360 XENON "VW360 RdW XE LED_SBBR" ROM 68
 69 45 VW360 Halogen VW360 Ska TFL_0_S ROM 69 VW360 VW360 halogen Ska TFL_0_S ROM 69
 70 46 VW369 Halogen VW369 Ska TFL_0_S ROM 70 VW369 VW369 halogen Ska TFL_0_S ROM 70
 71 47 VW369 XENON VW369 RdW XE PO_LED ROM 71 VW369 VW369 RdW XENON XE PO_LED ROM 71
 72 48 VW369 XENON VW369 RdW XE TFL_LED ROM 72 VW369 VW369 RdW XENON XE TFL_LED ROM 72
 73 49 VW369 Halogen VW369 Ska TFL_S ROM 73 VW369 VW369 halogen Ska TFL_S ROM 73
 74 4A VW351 XENON VW351 RdW XE PO_LED ROM 74 VW351 VW351 RdW XENON XE PO_LED ROM 74
 75 4B VW351 XENON VW351 RdW TFL _LED ROM 75 VW351 VW351 XENON RdW TFL _LED ROM 75
 76 4C VW351 XENON VW351 NAR TFL _LED ROM 76 VW351 VW351 XENON NAR TFL _LED ROM 76
 77 4D VW362 XENON VW362 RdW XE PO_LED ROM 77 VW362 VW362 RdW XENON XE PO_LED ROM 77
 78 4E VW362 XENON VW362 RdW XE TFL_LED ROM 78 VW362 VW362 RdW XENON XE TFL_LED ROM 78
 79 4F VW362 XENON VW362 NAR XE TFL_LED ROM 79 VW362 VW362 NAR XENON XE TFL_LED ROM 79
 80 50 VW316 Halogen/XENON VW316 NAR TFL_1 ROM 80 VW316 Halogen / Xenon VW316 NAR TFL_1 ROM 80
 81 51 VW316 Halogen/XENON VW316 NAR TFL_S ROM 81 VW316 Halogen / Xenon VW316 NAR TFL_S ROM 81
 82 52 VW465 Halogen/XENON VW465 RdW TFL_1 ROM 82 VW465 Halogen / Xenon VW465 RdW TFL_1 ROM 82
 83 53 VW465 Halogen/XENON VW465 NAR TFL_1 ROM 83 VW465 Halogen / Xenon VW465 NAR TFL_1 ROM 83
 84 54 VW465 Halogen/XENON VW465 RdW TFL_S ROM 84 VW465 Halogen / Xenon VW465 RdW TFL_S ROM 84
 85 55 VW465 Halogen/XENON VW465 NAR TFL_S ROM 85 VW465 Halogen / Xenon VW465 NAR TFL_S ROM 85
 86 56 AU354 Halogen VW465 RdW TFL_S 2R ROM 86 AU354 halogen VW465 RdW TFL_S 2R ROM 86
 87 57 AU354 Halogen VW465 NAR TFL_S_II ROM 87 AU354 halogen VW465 NAR TFL_S_II ROM 87
 88 58 AU354 XENON "AU354 TT NF LED TFL+Choming H SL" ROM 88 AU354 XENON "AU354 TT NF LED TFL Choming + H SL" ROM 88
 89 59 AU354 XENON "AU354 TT NF LED TFL+POL+SL+KZL+Choming H SL" ROM 89 AU354 XENON "AU354 TT NF LED TFL POL + + SL + + KZL Choming H SL" ROM 89
 90 5A SK35x Halogen/XENON SK35x-RS-RL TFL-LED aus Shutter ROM 90 SK35x Halogen / Xenon SK35x-RS-RL-LED TFL Shutter ROM 90
 91 5B SK35x Halogen/XENON SK35x-RS-LL TFL-LED aus Shutter ROM 91 SK35x Halogen / Xenon SK35x LL-RS-LED TFL-ROM from shutter 91
 92 5C VW465 FL Halogen "VW465FL RdW TFL_1 8TA" ROM 92 VW465 FL halogen "VW465FL RdW TFL_1 8TA" ROM 92
 93 5D VW465 FL XENON "VW465FL RdW TFL_1_LED 8TA" ROM 93 VW465 FL XENON "VW465FL RdW TFL_1_LED 8TA" ROM 93
 94 5E VW465 FL Halogen "VW465FL RdW TFL_1 8TC_8TD" ROM 94 VW465 FL halogen "VW465FL RdW TFL_1 8TC_8TD" ROM 94
 95 5F VW465 FL XENON "VW465FL RdW TFL_1_LED 8TC_8TD" ROM 95 VW465 FL XENON "VW465FL RdW TFL_1_LED 8TC_8TD" ROM 95
 96 60 VW465 FL Halogen "VW465FL NAR TFL_1 8TA" ROM 96 VW465 FL halogen "VW465FL NAR TFL_1 8TA" ROM 96
 97 61 VW465 FL XENON "VW465FL NAR TFL_1_LED 8TA" ROM 97 VW465 FL XENON "VW465FL NAR TFL_1_LED 8TA" ROM 97 98 62 VW465 FL Halogen "VW465FL RdW TFL_1_Ska 8TC_8TD" ROM 98 VW465 FL Halogen "VW465FL RdW TFL_1_Ska 8TC_8TD" ROM 98
 99 63 VW465 FL XENON "VW465FL RdW TFL_1_LED_Ska 8TC_8TD" ROM 99 VW465 FL XENON "VW465FL RdW TFL_1_LED_Ska 8TC_8TD" ROM 99
100 64 R8 Halogen/XENON "LED TFL ohne Heck, R8 ECE" ROM 100 R8 Halogen / Xenon "LED TFL without tail, R8 ECE" ROM 100
101 65 R8 Halogen/XENON "LED TFL mit Heck, R8 ECE" ROM 101 R8 Halogen / Xenon "LED TFL rear, R8 ECE" ROM 101
102 66 R8 Halogen/XENON "LED TFL ohne Heck, R8 Halogen / Xenon "LED TFL without tail, R8 USA (SM 0W)" ROM 102 R8 USA (SM 0W) "ROM 102
103 67 R8 Halogen/XENON "LED TFL mit Heck, R8 Halogen / Xenon "LED TFL rear, R8 USA (SM 0W)" ROM 103 R8 USA (SM 0W) "ROM 103
104 68 R8 Halogen/XENON "Komplett LED, LED TFL o. Heck, R8 ECE " ROM 104 R8 Halogen / Xenon "Complete LED, LED TFL without a tail, R8 ECE" ROM 104
105 69 R8 Halogen/XENON "Komplett LED, LED TFL m. Heck, R8 ECE" ROM 105 R8 Halogen / Xenon "Complete LED, LED TFL m. Heck, R8 ECE" ROM 105
106 6A R8 Halogen/XENON "Komplett LED, LED TFL ohne Heck, R8 Halogen / Xenon "Complete LED, LED tail without TFL, R8 USA (SM 0W)" ROM 106 R8 USA (SM 0W) "ROM 106
107 6B R8 Halogen/XENON "Komplett LED, LED TFL mit Heck, R8 Halogen / Xenon "Complete LED, LED rear TFL, R8 USA (SM 0W)" ROM 107 R8 USA (SM 0W) "ROM 107
108 6C AU210 Halogen/XENON "TFL ohne Heck, AU210 Halogen/ Bulb 8.08.08 " ROM 108 AU210 Halogen / Xenon "TFL without Heck, AU210 Halogen / Bulb 8:08:08" ROM 108
109 6D AU210 Halogen/XENON "TFL mit Heck, AU210 Halogen/ Bulb 8.08.08 " ROM 109 AU210 Halogen / Xenon "TFL rear, halogen AU210 / Bulb 8:08:08" ROM 109
110 6E AU210 Halogen/XENON "TFL ohne Heck, AU210 Halogen/ LED 8.08.08 " ROM 110 AU210 Halogen / Xenon "TFL without Heck, AU210 halogen / LED 8:08:08" ROM 110
111 6F AU210 Halogen/XENON "TFL mit Heck, AU210 Halogen/ LED 8.08.08 " ROM 111 AU210 Halogen / Xenon "TFL rear, AU210 halogen / LED 8:08:08" ROM 111
112 70 AU210 Halogen/XENON "TFL ohne Heck, AU210 LED TFL/ Bulb 8.08.08 " ROM 112 AU210 Halogen / Xenon "Heck no TFL, TFL AU210 LED / Bulb 8:08:08" ROM 112
113 71 AU210 Halogen/XENON "TFL mit Heck, AU210 LED TFL/ Bulb 8.08.08 " ROM 113 AU210 Halogen / Xenon "TFL rear, AU210 LED TFL / Bulb 8:08:08" ROM 113
114 72 AU210 Halogen/XENON "TFL ohne Heck, AU210 LED TFL/ LED 8.08.08 " ROM 114 AU210 Halogen / Xenon "Heck no TFL, TFL AU210 LED / LED 8:08:08" ROM 114
115 73 AU210 Halogen/XENON "TFL mit Heck, AU210 LED TFL/ LED 8.08.08 " ROM 115 AU210 Halogen / Xenon "TFL rear, AU210 LED TFL / LED 8:08:08" ROM 115
116 74 SK461 China Halogen/XENON "SK461-China ohne TFL SL mit BL-Funktion LED SBBR" ROM 116 SK461 China Halogen / Xenon "SK461-China without TFL, SL, BL-function LED SBBR" ROM 116
117 75 SK461 China Halogen/XENON "SK461-China ohne TFL/TFL-ABL SL ohne BL-Funktion LED SBBR" ROM 117 SK461 China Halogen / Xenon "SK461-China without TFL / DRL SL-ABL without BL-function LED SBBR" ROM 117
118 76 AU354 Halogen "AU354 TT NF NAR sep TFL ohne SL bei CHO" ROM 118 AU354 halogen "AU354 TT NF NAR sep TFL without SL in CHO" ROM 118
119 77 AU354 XENON "AU354 TT NF NAR LED TFL + CHO SL" ROM 119 AU354 XENON "AU354 TT NF NAR LED TFL CHO + SL" ROM 119
120 78 VW364 LL Halogen/XENON VW364 RdW TFL_S LL ROM 120 VW364 LL Halogen / Xenon VW364 RdW TFL_S LL ROM 120
121 79 VW364 RL Halogen/XENON VW364 RdW TFL_S RL ROM 121 VW364 RL Halogen / Xenon VW364 RdW TFL_S RL ROM 121
122 7A AU354 Halogen/XENON " sep TFL mit Heck,TTNF, NAR" ROM 122 AU354 Halogen / Xenon "sep TFL rear, TTNF, NAR" ROM 122
123 7B AU354 Halogen/XENON " LED TFL mit Heck,TTNF, NAR" ROM 123 AU354 Halogen / Xenon "LED TFL rear, TTNF, NAR" ROM 123
124 7C AU210 Halogen/XENON "TFL ohne Heck, AU210 Halogen/ Bulb (ged. TFL als SL)" ROM 124 AU210 Halogen / Xenon "TFL without Heck, AU210 Halogen / Bulb (ged. TFL as SL)" ROM 124
125 7D AU210 Halogen/XENON "TFL ohne Heck, AU210 Halogen/ LED (ged. TFL als SL)" ROM 125 AU210 Halogen / Xenon "DFL without Heck, AU210 halogen / LED (DFL ged. as SL)" ROM 125
126 7E AU316 Halogen/XENON VW351 Südk. AU316 Halogen / Xenon VW351 Südk. TFL_0 (aus 05) ROM 126 TFL_0 (from 05) ROM 126
127 7F AU316 Halogen/XENON VW351 Südk. AU316 Halogen / Xenon VW351 Südk. TFL_S (aus 35) ROM 127 TFL_S (from 35) ROM 127
128 80 AU316 Halogen/XENON VW364 RdW TFL_0 o. NSL ROM 128 AU316 Halogen / Xenon VW364 RdW TFL_0 o. NSL ROM 128
129 81 AU316 Halogen/XENON VW364 RdW TFL_S o. NSL ROM 129 AU316 Halogen / Xenon VW364 RdW TFL_S o. NSL ROM 129
130 82 AU316 Halogen / Xenon "VW364 R-SCI TFL_1 LL8TC" ROM 130
131 83 AU316 Halogen / Xenon "VW364 R-SCI TFL_1 RL 8TA/8TD" ROM 131 8TA/8TD "ROM 131
132 84 AU316 Halogen/XENON "VW364 R-SCI TFL_1 LL Ska 8TC" ROM 132 AU316 Halogen / Xenon "VW364 R-SCI TFL_1 LL ska 8TC" ROM 132
133 85 AU316 Halogen/XENON "VW364 R-SCI TFL_1 RL Ska 8TA/8TD" ROM 133 AU316 Halogen / Xenon "VW364 R-SCI TFL_1 RL Ska 8TA/8TD" ROM 133
134 86 VW351 Halogen/XENON VW351 RdW TFL_0_Ska ROM 134 VW351 Halogen / Xenon VW351 RdW TFL_0_Ska ROM 134
135 87 VW352 Halogen/XENON VW362 RdW TFL_0_Ska ROM 135 VW352 Halogen / Xenon VW362 RdW TFL_0_Ska ROM 135
136 88 VW364 LL Halogen/XENON VW364 RdW TFL_1 LL_Ska ROM 136 VW364 LL Halogen / Xenon VW364 RdW TFL_1 LL_Ska ROM 136
137 89 VW364 RL Halogen/XENON VW364 RdW TFL_1 RL_Ska ROM 137 VW364 RL Halogen / Xenon VW364 RdW TFL_1 RL_Ska ROM 137
138 8A VW416 Halogen/XENON VW316 RdW TFL_1_Ska ROM 138 VW416 Halogen / Xenon VW316 RdW TFL_1_Ska ROM 138
139 8B VW465 Halogen/XENON VW465 RdW TFL_1_Ska ROM 139 VW465 Halogen / Xenon VW465 RdW TFL_1_Ska ROM 139
140 8C VW361 Halogen/XENON VW361 RdW TFL_1 ROM 140 VW361 Halogen / Xenon VW361 RdW TFL_1 ROM 140
141 8D VW361 Halogen/XENON VW361 NAR TFL_1 ROM 141 VW361 Halogen / Xenon VW361 NAR TFL_1 ROM 141
142 8E VW465 FL Halogen/XENON VW368 RdW TFL_1 ROM 142 VW465 FL Halogen / Xenon VW368 RdW TFL_1 ROM 142
143 8F VW465 FL Halogen/XENON VW368 RdW TFL_1_Ska ROM 143 VW465 FL Halogen / Xenon VW368 RdW TFL_1_Ska ROM 143
144 90 VW465 FL Halogen/XENON VW368 RdW TFL_1_LED ROM 144 VW465 FL Halogen / Xenon VW368 RdW TFL_1_LED ROM 144
145 91 VW465 FL Halogen/XENON VW368 RdW TFL_1_LED_Ska ROM 145 VW465 FL Halogen / Xenon VW368 RdW TFL_1_LED_Ska ROM 145
146 92 SE428 Halogen SE428 RdW TFL_1 ROM 146 SE428 SE428 halogen RdW TFL_1 ROM 146147 93 SE428 XENON SE428 RdW TFL_1 XE ROM 147 SE428 SE428 RdW TFL_1 XENON XE ROM 147
148 94 VW465 Halogen/XENON VW465 TFL_S NAR /2RFL ROM 148 VW465 Halogen / Xenon VW465 TFL_S NAR / 2RFL ROM 148
149 95 VN337 Halogen/XENON VN337 RdW TFL_S ROM 149 VN337 Halogen / Xenon VN337 RdW TFL_S ROM 149
150 96 VW411 Halogen/XENON VW411 NAR TFL_1 ROM 150 VW411 Halogen / Xenon VW411 NAR TFL_1 ROM 150
151 97 VW411 Halogen VW411 NAR TFL_S ROM 151 VW411 VW411 halogen NAR TFL_S ROM 151
152 98 VW411 Halogen/XENON VW411 CHN TFL_1 ROM 152 VW411 Halogen / Xenon VW411 CHN TFL_1 ROM 152
153 99 VW411 Halogen/XENON VW411 CHN TFL_S ROM 153 VW411 Halogen / Xenon VW411 CHN TFL_S ROM 153
154 9A SE350 XENON SE350 NAR TFL_0 XE ROM 154 SE350 SE350 NAR TFL_0 XENON XE ROM 154
155 9B SE350 Halogen SE350 NAR TFL_S ROM 155 SE350 SE350 halogen NAR TFL_S ROM 155
156 9C SE350 XENON SE350 RdW TFL_0 XE ROM 156 SE350 SE350 RdW TFL_0 XENON XE ROM 156
157 9D SE350 Halogen SE350 RdW TFL_S ROM 157 SE350 SE350 halogen RdW TFL_S ROM 157
Good luck.
killep2
C?ID=214777
DEC HEX
Good luck.
Thank you
Noted!
I will wait for Dana and Jack answer. I am not sure I want to change or even touch the 18byte... till direct request from they...
The interesting point is that I dont see My car on the 18byte list AT ALL!! and now I am wondering if it was on the list on my old one.
I believe Dana and Jack will solve my issue, (I heard a lot about they professionalism :)
So as I mention, noted but will be usable if no another option will be available.
The Unit is exactly the same Number (the difference is that My was Romania made and this one is from Chaina Factory)
The Cables wasn't mix. as you mention this is very difficult to mix...
What exactly you copy when you change your BCM ? Let's say I have only the Long code.... it is enough ?
I mean did you change something else beside this code ?
Also, maybe you want me just to scan or whatever one of our car (in our area) one like my and then somehow code the code to my one ? Include 18 byte....
Just let me know I have one not so far from me..
nitram
CT
C?ID=162205
No problem, as I said I am a novice at this so just trying to provide you with information that may be useful, I agree I would wait for the experts to help you out, I cannot verify the accuracy of the list or how current it is, so probably only good for a last resort.
In regards to your questions copying the code is all you need to do, I believe you have done this correctly, the long coding helper is just to assist with understanding the changes and options. Since our cars are different make/models and are made for different markets my codes will not help you, but as you asked for them I am including it below. I don't think the adaptation settings change these, and I do recall having to reprogram the keys etc after changing the BCM using this option.
I think your issue is a wiring problem caused by the Xenon lights doing some damage, there are a lot of posts warning that this is a problem. I installed Xenon's in my car, but used the factory parts and not after market, these work correctly and I have not had any problems, but it is an expensive upgrade and lots of parts to order, the high line BCM was the fist step in my upgrade list as the BCM installed from the factory didn't support Xenon's. You will notice that the part number on the BCM for my car is different to yours, in my case both the old and new units were made in Germany by Continental.
Part No SW: 5K0 937 087 G HW: 5K0 937 087 G
Component: BCM PQ35 H+ 111 1129
Revision: BL111001
Coding: 61580A3890212EC4808000811000070441015186524D89605C8000000000
Shop #: WSC 18752 008 00032
VCID: 39799730B0BD3CD693D-806C
I wish you luck and hope you get this resolved quickly.
killep2
C?ID=214777
Revision: BL111001
thanks
it's not issue like you thinking since the problem started after the BCM change.
I dont have a time but today or tomorrow I Am going to change back the BCM to the old one to see the results....I sure almost for 100% that there will be no problem...
Let's wait for expert and see...
killep2
C?ID=214777
thanks
Guys ? Someone ?:(
I would swap it out.......test everything and retrace steps....
killep2
C?ID=214777
Done!
I save the Scan from the old one again (by the way the long code is exactly the same you gave me)
I dont know what esle I can save from the old one
Everything works fine with the old one (exclude the original problem with the turn light)
After I put back the new one I was so brave to change the byte18....(anyway I dont know the original coding)
The most perfect coding for me was Skoda Superb Vagon with separate DRL....
Everything come back to normal exclude the error about Back light (the bottom one) even it is ok for 100%.
Some one know what to fix to clear that error ? or it is just not the correct coding ? I hope it is since it is the best result I get on the whole Fu3#3g coding procedure ...... :(
Dana
Western PA, USA
Dana,
My main concern with the lights that are currently installed was related to the nature of the BCM failure and the current condition. For example, we wouldn't want you to try configuring a new BCM with aftermarket lights installed because they could directly ruin the new module in addition to causing new issues when we are attempting to get this back to baseline/normal.
Skoda isn't sold here but that looks like a LHD (1Z33MD | SK351) Octavia elegance sedan, or at least the sedan with a partial hatch instead of a complete hatchback/wagon. If I'm correct that would narrow the documented Byte 18 values down to 3 possibilities:
34,Lighting: Skoda Octavia (1Z/SK35) Rest of World / Left Hand Drive / separate DRLs
36,Lighting: Skoda Octavia (1Z/SK35) Rest of World / Left Hand Drive / Scandinavian DRLs
38,Lighting: Skoda Octavia (1Z/SK35) Rest of World / Left Hand Drive / Xenon-Shutter DRLs
... providing the factory headlights are installed HEX 34 looks like the best bet to me but post the most recent scan if you need further assistance.
-Dana
