- Joined
- Sep 30, 2015
- Messages
- 15
- Reaction score
- 5
- Location
- Netherlands
- VCDS Serial number
- C?ID=182324
Enable WLAN on Discover Pro MIB1
Warning: you will not have data access if you don't have premium telephony, so there will be NO online services. This WILL lead to an error in Phone menu when selecting "Premium phone". It will do no damage, but as with all VCDS changes: use your brain.
Module 5F
Login 20103
Long Coding:
Byte 15, bit 4 = 1 (Phone NAD)
Byte 24, bit 3 = 1 (WLAN Module)
Adaptation:
WLAN: On
(7)-Vehicle configuration-WIFI_Hotspot: On
(17)-Vehicle configuration-UPnP: On (Will enable DLNA)
After you've set this, RESET the device by holding Power for ~15 seconds.
You can now find the WLAN settings in the device settings menu.
If not, that's bad luck. The MIB1 is a mysterious device... it could be that you need to set "LTE Module" to on...
That's all.
Feel free to experiment with this. Be careful though.
Please post your findings here!
Module 5F
Login 20103
Long Coding:
Adaptation:
WLAN: On
That's all.
