DIY - Audi A6/A7 Active Lane Assist Retrofit - DONE
Mrclopec
Nipomo, CA, USA
C?ID=149231
A6/A7 (2012-Current) Active Lane Assist Retrofit.
This retrofit originally started on the AudiWorld Forums by the member IKnowHuhA6. He approached me and asked for help in attempting this retrofit. After successful completion and with his permission, I have put together this DIY for the benefit of others. This retrofit is based on A6/A7 chassis vehicles that are already factory fitted with Adaptive Cruise Control and have the 85-On Board Camera and 8E-Image Processing control modules installed. It can be fitted if Adaptive Cruise Control is not already fitted, but it will require changing of the windscreen, installation of the 85-On Board Camera, installation of the Image Processing Control Module, all necessary connectors and wiring, and then most likely will require dealer calibration. Additionally any retrofits you perform by following this guide you do so at your own risk. I assume no liability.
The system can be set in the MMI for “early” or “late” intervention. Within either setting, there is a buffer that the system sets between lane markings at which the system will not intervene. Choosing “early” just decreases the size of this buffer, but will not decrease it so much that it will keep the vehicle perfectly centered. WARNING - This system is considered a driving aide and is not advanced enough to simulate autonomous driving. If given the opportunity, the vehicle will inevitably bounce back and forth within the lane, or disable itself until your hands are placed back on the steering wheel which seems like a pretty smart driving habit to have.
Background:
In the 4G chassis, adaptive cruise control utilizes distance regulation sensors in the front grill of the vehicle as well as an on board camera in the top of the windscreen. This camera is different than the Lane Assist camera found in the A4/A5/Q5 chassis and in conjunction with the image processing control module, serves more than one purpose (Adaptive Cruise, Lane Assist, Traffic Sign Recognition - NOT USA). If the vehicle in question was factory fitted with Adaptive Cruise Control, then the camera and image processing control module which controls the Active Lane Assist is already present. Below is a picture of the on board camera needed.
Prior to 2012 the system was only a Lane Departure Warning. This previous system was not “active” and would not provide steering recommendations or interventions. It would only vibrate the steering wheel (by means of a vibration motor in the steering wheel itself) when the vehicle drifted out of its lane.
Active Lane Assist requires electromechanical power steering for the steering adjustments and steering wheel vibration. Unlike the previous generation that used a vibration motor in the steering wheel, this newer generation uses a harmonic whatchamacallit (I don’t know what its called) in the steering system to generate the vibration warning.
Parts Needed:
New Steering Column Lever Assembly - 4G8-953-502-P (Sedan with ACC and ALA)
New Steering Column Lever Assembly - 4G8-953-502-S (Avant with ACC and ALA)
Section 1 – Changing of the Steering wheel levers.
Your new steering column switches if purchased from the dealer will not come with the steering column clock spring control module (4H0 953 568). If you purchased a set of switches that came with one (ie eBay), I STRONGLY recommend you switch it out for the one on your existing turn level assembly so you can avoid recoding it or having several errors pop up onto your dash for stability control faults and steering angle faults. Trust me, this will be much easier for you in the long run and will save you a world of headaches!
Step 1 – Park vehicle on a flat surface and center your wheels and steering wheel.
Step 2 – Turn the car on only to the point of accessory power.
Step 3 – Disconnect the battery ground terminal while the vehicle is on in order to ensure a full power discharge from the airbag system.
Step 4 – Remove the Airbag from the steering wheel.
Step 5 – Remove the center bolt using a 12mm 12-point star (not torx) bit and remove the steering wheel. (Make sure you take note of the exact position of the steering wheel on the teeth of the steering column.
Step 6 – Remove the upper steering column cover.
Step 7 – Remove the lower steering column cover.
Step 8 – Disconnect the electrical connectors from the back of the switches and loosen the bolt, which holds the steering switches to the column itself.
Step 9 – Remove the steering column multi-switch assembly.
Reinstall the new steering column multi-switch with the Active Lane Assist button on the end of the turn signal lever. Installation is reverse of removal. The steering wheel bolt must be tightened to 30Nm + 90 degrees.
Section 2 – Coding the vehicle using VCDS.
Perform a scan of the vehicle and make sure modules 10, 16, 17, 44, 85 and 8E are present. 85 will not need to be coded but it does need to be present.
Step 1 – Access 10-Park/Steer Assist>07Coding>Long Coding Helper>Enable Byte 1 Bit 5 "Lane Maintenance Assist(PR-7Y4/7Y5) installed".
Step 2 – Access 16-Steering Wheel>07 Coding>Long Coding Helper>Byte 2 Bits 6&7 change to "C0 Lane Assist with Heading Control installed".
Step 3 – Access 44-Steering Assist>07 Coding>Long Coding Helper>Enable Byte 2 Bit 0 "Lane Assist installed"
Step 4 – Access 8E-Image Processing>07 Coding>Long Coding Helper>Byte 1 Bits 5&6 change to "40 Lane Assist and Lane Change Assist installed (PR-7Y5)"
Step 5 – Access 17-Instruments>07 Coding>Long Coding Helper>Enable Byte 4 Bit 6 "Lane Assist Installed". After reviewing numerous scans, some vehicles have this enabled and some do not. I would test functionality in the vehicle before enabling this bit.
Step 6 – Enter the hidden (green)menu on the MMI to activate the menu system for Active Lane Assist
Step 7 – Car>Cardevicelist>Check “Lane Departure Warning”
Step 8 – Car>Carmenuoperation>Lane Departure Warning – Change from 0 to 5
Step 9 – Clear all faults and refresh the system. No errors should be present.
Section 7 – Calibrating
The really awesome thing that we found after activating the system was that calibration was not necessary. This may not be the case for everyone. My best guess is it was already completed during the end of line programming at the factory. When a vehicle is finished being assembled, all of its driver assistance system are calibrated at the same time. The system used to calibrate Adaptive Cruise Control is also part of the same system that calibrates Active Lane Assist. It would appear that because the image processing camera in the windscreen also serves purpose to the Adaptive Cruise Control feature, it must have also captured the calibration data for the Active Lane Assist system at the same time while the calibration board was in front of the car. The data had just been sitting dormant. If after retrofitting, there is a stored fault code under 8E-Image Processing that calibration is required, then a trip to the dealer will be necessary.
AMBSC
Brazil
C?ID=233374
Hello all!
Sorry to dig this thread up, but I'm buying an A6 C7 with ACC and the image processing camera and I have a doubt about this tweak.
Is it really necessary to change the lever? I mean: I can turn the lane assist on through the MMI, correct?
Cheers.
Mrclopec
Nipomo, CA, USA
C?ID=149231
I don't believe so. You can turn it on and off via vcds, but other than that, you will need to change the lever. If you want the feature and are shopping for a car, I'd find one with the feature already.
AMBSC
Brazil
C?ID=233374
Hello!
I coded lane assist in my A6 post-facelift and I would like to give my 2 cents of experience to this tweak - it might help people who got the facelifted A6/A7:
1 - I followed all Mrclopec steps, except the green menu one;
2 - The tweak to turn the "green/hidden menu" doesn't work in facelifted A6/A7 - new MMI gen, if I'm not wrong. Anyway, that doesn't matter at all, because, even if you get to the hidden menu by other means, it's quite useless for this subject. The hidden menu doesn't play the same relevant role he did before. You won't be able to enable lane assist menu through it.
3 - That said, I´ve done this:
- Enter module 5F-Information Elect, 10 - adaptation
- ENG122227-ENG117506-Car_Functions_Adaptations.......Lane_Departure_Warning : activate
- ENG122227-ENG117508-Car_Functions_Adaptations.......Lane_Departure_Warning_over_threshold_high : activate
- ENG122229-ENG117740-Car_Function_List_BAP.......LDW_HCA_0x19 : activate
- ENG122229-ENG117741-Car_Function_List_BAP.......LDW_HCA_0x19_msg_bus : Terminal 15
Done that, the lane assist menu in the MMI is supposed to be there.
4 - For the ones like me who got module 82-Heads Up Display:
- 07-Coding, "Long Coding Helper"
- Byte 0, Bit 2 - check it
5 - 10-Park/Steer Assist module is not a must have for lane assist. Can´t tell exactly how the park assist side sensors help the lane assist function, but I remember I coded lane assist in my former GTI MK7, it had this module and, as far as I remember, the module was not coded. My A6 doesn´t have it, and lane assist is working.
Cheers, and thanks Mrclopec for this tweak.
CuturiloD
Serbia
C?ID=361908
If someone know how what adaptation is necessary for RMC 5F -Information Electr. ? part nr.4G1 035 193 A
Mike_Jones
C?ID=18137
Lane Assist on A6 Avant Facelift UK
OK - well after reading the post, I have undertaken the Lane Assist upgrade on my 2015 A6 4G. My car has matrix LED headlights and therefore had a camera (8E). Unfortunately it had no Image Processing I got one of eBay and with Elsawin's help wired it up. The video connector was not in use on the camera so connected that up to the 85 module along with coupling it in to the flexray link from the gateway to the ABS controller.
Using the instructions above I was able to get it working (looks like they calibrate the camera even if its only being used for Matrix beam.
HOWEVER, I cannot get the menu's to work properly on the 5F. The menu comes up and then disappears and both 5F and 85 are complaining about missing messages.
It seems like the adaptations in the thread for Lane Departure Warning and not Active Lane Assist (no green menu on facelift). The menu I get is called "lane assist" not "active lane assist". When the menu comes on the only option is vibration intensity but the manual indicates I should get options for early, medium and late guidance plus on/off for the vibration. I will read though all the 5F adaptations but if anyone has any clues about the correct adaptations on the 5F for "active lane assist"
Current scan below, spent some time trying up put some pics in but no luck!
/Users/Mike/Desktop/Lane Assist Instruments.jpg
Sunday,23,June,2019,16:10:23:55272
VCDS Version: 19.6.0.4 (x64)
VIN: WAUZZZ4G8FN068483   License Plate:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 28 3B 42 44 46 52 53 55 5F 62
          69 6C 6D 72 85 8E AC
VIN: WAUZZZ4G8FN068483   Mileage: 108775km-67589miles
17-Instruments -- Status: Malfunction 0110
Address 01: Engine (J623-CRTD)       Labels:. 059-907-401-V2.clb
   Part No SW: 4G2 907 401 B    HW: 4G2 907 401
   Component: 3.0TDI EDC17  H33 0001
   Revision: 92H33---
   Coding: 12254012052601030000
   ASAM Dataset: EV_ECM30TDI0114G2907401B 001001
   ROD: EV_ECM30TDI0114G2907311C.rod
   VCID: 244720EF2F0C176FD3-8070
   Part No SW: 4G0 927 166 C    HW: 0B5 927 156 K
   Component: 0B5 30 TDIRdW H03 0007
   Revision: --H03---
   Coding: 100001
   ASAM Dataset: EV_TCMDL501021 001021
   ROD: EV_TCMDL501021.rod
   VCID: 2D51C5CB7CC6D6270C-8078
   Part No SW: 4G0 907 379 Q    HW: 4G0 907 379 Q
   Component: ESP9 Premium  H01 0420
   Coding: 17A69E41E86579829B00
   ASAM Dataset: EV_ESP9BOSCHAU57X 003019
   ROD: EV_ESP9BOSCHAU57X_003.rod
   VCID: 3F8D8F83A6AA54B7AE-806A
   Part No SW: 4H0 907 064 FN    HW: 4H0 907 064 EN
   Component: BCM2 2.0      H36 0560
   Coding: 01B9704E000000000000
   VCID: 7AFB3E97F508B19FD9-802E
   Serial number: 3215000011387005
   Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
   Component: KLIMA 4 ZONEN H14 0112
   Serial number: 12021500040194
   Coding: 36A21178250000
   VCID: 63C563F36A825057EA-8036
   Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
   Revision: 15020001    Serial number: 00001008344002
   Coding: 0105001440349FE041014083000018000F9DE7082F08020100000894E100130200400034030000
   Shop #: WSC 53920 001 104857
   VCID: 71E919BBA87EF2C768-8024
   Component: WWS57X 150111  H37 0080
   Serial number:         150126014513
   Coding: 0045F7
   Serial number: 23730186
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
   Component: E1 - LDS  H07 0044
   Serial number: 13 02 2015  00000883
   Serial number: F818C297000000000001
   Part No SW: 4H0 959 655 H    HW: 4H0 959 655 H
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P100390YW
   Coding: 30333130313730323737554A305234473053
   VCID: 3B75FB93B2B2489782-806E
   Serial number: 3575HRB401G52UQM71L
   Serial number: 3585HRB405133PKM68CD
   Serial number: 3515JRB40145358SI2AU
   Serial number: 3525JRB40145358SP91-
   Serial number: 3554VRB400Q534069H6.
   Serial number: 3564VRB400M5340670PY
   Revision: --------    Serial number: 90372OBC00036
   Coding: 0004F5
   VCID: 387FE49F8B84638F6F-806C
   Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
   Serial number: 06 01 2015  C0007902
   Part No SW: 4G8 920 985 L    HW: 4G8 920 985 L
   Component: TDieGb        H08 0043
   Revision: 04001037    Serial number: 658180215596026
   Coding: 33A612000B552600010000
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K_AU57.rod
   VCID: 408F8C7FDB542B4FD7-8014
1048578 - No Basic Setting
          B2010 00 [009] - -
                    Reset counter: 230
                    Mileage: 108745 km
                    Date: 2019.06.23
                    Time: 11:04:58
16776980 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 16
                    Mileage: 108753 km
                    Date: 2019.06.23
                    Time: 12:20:17
   Part No SW: 4G8 907 468     HW: 4G8 907 468
   Component: J533--Gateway H13 0075
   Revision: --------    Serial number: 00000001729380
   Coding: C0CD078118
   ASAM Dataset: EV_GatewPkoUDS 001024
   VCID: 75E12DABD416DEE7B4-8020
   Serial number: 1900125603
   Voltage stabilizer:
   Serial number: 1412100000000000044B
   Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
   Component: KLIMA FOND    H08 0112
   Serial number: 14021500040455
   Coding: 22
   VCID: 3D71F58BACA646A7BC-8068
   Component: SARA 6D       H04 0056
   Revision: --------    Serial number: EJ1BPA8208ZJ6T
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 3663EAA7899095FF7D-8062
   Coding: 011C16015001620002080002
   VCID: 479D9763F67A1C7716-8012
   Part No SW: 4G0 909 144 M    HW: 4G0 909 144 G
   Component: RCEPS         H41 0011
   Revision: 00001000    Serial number: 0016426092
   Coding: 101001010001
   ASAM Dataset: EV_RCEPS 009010
   ROD: EV_RCEPS_009.rod
   VCID: 3365D3B39AE280D75A-8066
   Revision: 00002001    Serial number: 0360799116
   Coding: 013B0622A0B93080C320090420010F470000000000000000000000000000
   VCID: 46839A67F170057FED-8012
   Revision: --------    Serial number: 00000001368405
   ROD: EV_ParkiBrake_VW51.rod
   Part No SW: 4H4 907 357 D    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0081
   Coding: 04FE02202A130200
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005003
   Coding: E01F00
   Coding: E01F00
   Matrix Headlamp Powermodule 1 Left:
   Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo li.  H03 0031
   Coding: E01F00
   Matrix Headlamp Powermodule 1 Right:
   Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo re.  H03 0031
   Coding: E01F00
Address 5F: Information Electr. (J794)       Labels:* 4G1-035-MIB-HGH2.clb
   Part No SW: 4G1 035 021 D    HW: 4G1 035 021
   Component: MU-H-LND-EU   041 0389
   Serial number: A588B0F7505471
   Coding: 017502010000000013111102000A00132F0006E7F1700100DF
   VCID: 1B351B131272289762-804E
   Subsystem 1 - Part No SW: V03 959 801 FD    HW: -----------
   Component: ECE 2017/2018  --- 0161
   Subsystem 2 - Part No SW: 4G1 919 605 A    HW: 4G1 919 605 A
   Serial number: AUZ8Z9EY800PTF
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 4G2 919 610 F    HW: 4G2 919 610 F
   Serial number: 90349OBD0006Q
   Component: Gracenote2  --- 1012
7961 - Control module
          B2001 00 [008] - Incorrect software version
                    Reset counter: 17
                    Mileage: 108771 km
                    Date: 2019.06.23
                    Time: 15:53:53
                    Voltage terminal 30: 14.5 V
   Part No SW: 4G8 959 795 D    HW: 4G8 959 795
   Component: TSG HL        H03 0212
   Coding: 01081C004001620000080002
   Shop #: WSC 02312 785 00200
   VCID: 43858373C2423057CA-8016
Address 69: Trailer (J345)       Labels:| 4H0-907-383-V2.clb
   Part No SW: 4G8 907 383 B    HW: 4G8 907 383 B
   Component: Anhaenger     H14 0113
   Serial number: 0000454261
   Coding: 0100000202000000
   Revision: --H04---    Serial number: 525 PA8J1XG2SO
   Coding: 1030005
   Shop #: WSC 98765 666 38384
   VCID: 26433AE79130E57FCD-8072
03006 - Back-up Camera System not calibrated
                    Reset counter: 230
   Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
   Component: HDSG-Modul    H05 0150
   Revision: 14005001    Serial number: 030500754
   Coding: 093205C010
   ROD: EV_HDSGAu571.rod
   Component: TSG HR        H03 0212
   Shop #: WSC 28100 141 104456
   Part No SW: 4H0 907 217 F    HW: 4H0 907 217 A
   Component: DPC-SG        H27 0081
   Coding: 71160000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2C57C8CF47DCDF2F1B-8078
   Part No SW: 4H0 907 107 H    HW: 4H0 907 107
   Component: BV-SG         H33 0090
   Serial number: 005000621903157
   Coding: 044239040111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
0025 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 230
                    Mileage: 108745 km
                    Date: 2019.06.23
                    Time: 11:50:49
                    Outside air temperature: 18.5 ∞C
                    Voltage terminal 15: 11.6 V
                    Control Module temperature: 30.0 ∞C
0061 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 230
                    Mileage: 108745 km
                    Date: 2019.06.23
                    Time: 11:50:48
   Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0012
   Revision: 00000000    Serial number: 150210145
   ROD: EV_RDCMA00100_008.rod
End-------------------------(Elapsed Time: 05:51)--------------------------
Rizzio
Trondheim, Norway
C?ID=369124
I'm trying this retrofit from scratch on my A6 MY2015 facelift without acc/led
I've retrofitet the new windscreen, the dash and the headup at the same time, coded the camera and its up and runing.
Hud is also working as it should. I'm waiting for my new 3B unit with sara6.
My problem is that there is no response from the 8E imageproc. (pined power to 1,2. flexray to 3,4,9,10)
Is my problem coding or hw related?
Friday,19,July,2019,21:28:57:62878
VIN: WAUZZZ4G5FN064973   License Plate:
Mileage: 88693km-55111mi   Repair Order:
Scan: 01 02 03 05 08 09 15 16 17 19 28 36 3B 42 44 46 52 53 5F 62
          69 6C 6D 72 82 85 8E 8F 90 AC
VIN: WAUZZZ4G5FN064973   Mileage: 88693km-55111miles
17-Instruments -- Status: Cannot be reached 0100
82-Heads Up Display -- Status: Malfunction 0010
8E-Image Processing -- Status: Cannot be reached 0100
Address 01: Engine (J623-CRTE)       Labels: Redir Fail!
   Part No SW: 4G2 907 311 C    HW: 4G2 907 401
   Component: 3.0TDI EDC17  H33 0007
   Revision: 92H33---
   Coding: 12254012053601030000
   Shop #: WSC 28389 002 1048576
   ASAM Dataset: EV_ECM30TDI0114G2907311C 001007
   VCID: 2502E37C24149867CA-8070
   Part No SW: 4G0 927 166 A    HW: 0B5 927 156 K
   Component: 0B5 30 TDIRdW H03 0009
   Revision: --H03---
   Coding: 100001
   VCID: 2B16154442F0AE171C-807E
   Coding: 17A69E41E8657982BB00
   VCID: 3FCE5114A68822B7A0-806A
   Coding: 01A9700E000000000000
   VCID: 7AB8E000F52AC79FD7-802E
   Serial number: 30011500041629
   Coding: 360211B8210000
   VCID: 6386BD646AA02657E4-8036
   Revision: 15020001    Serial number: 00001002845902
   Coding: 2600001500349FE08181408380001D0CCF9CE60826090201000008206101150200400024030000
   VCID: 71AAC72CA85C84C766-8024
   Component: WWS57X 150124  H37 0080
   Serial number:         150130081946
   Coding: 0045F7
   Serial number: 23704895
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BG    HW: 4G0 941 531 BG
   Serial number: 28 02 2014  00001000
   Serial number: DBD80197000000000001
   Revision: --------    Serial number: 003P10033D6B
   Coding: 30333130313730323736554A304C34473053
   VCID: 3B362504B2903E978C-806E
   Serial number: 3575HRB405P33HNGA0R-
   Serial number: 3585HRB405D33RVK81T5
   Serial number: 3515JRB4016533VUN1QW
   Serial number: 3525JRB4006534EADOSB
   Serial number: 3554VRB400S52RDAI1CY
   Serial number: 3564VRB401052RDAO269
   Revision: C0068538    Serial number: 90862OB500081
   Coding: 000015
   VCID: 3B362504BA903E978C-806E
   Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
   Serial number: 17 12 2014  E0064336
   Part No SW: 4G8 920 933 Q    HW: 4G8 920 933 Q
   Component: TDieRdw       H07 0043
   Revision: 03001036    Serial number: 658050215596016
   Coding: 03AF12000B410008010000
   VCID: 3E302C10A1822BBFAB-806A
   Revision: --------    Serial number: 00000001719911
   Coding: C0CD078118
   VCID: 75A2F33CD434A8E7BA-8020
   Serial number: 3565135603
   Voltage stabilizer:
   Serial number: 14112700000000000490
6653 - Image processing control module
          U1079 00 [009] - No communication
                    Reset counter: 19
                    Mileage: 88693 km
                    Date: 2019.07.19
                    Time: 20:48:19
                    Voltage terminal 30: 12.2 V
                    Voltage terminal 15: 12.2 V
                    Control Module temperature: 25 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
   Part No SW: 4G0 919 158 R    HW: 4G0 919 158 R
   Serial number: 04021500040558
   Coding: 20
   Revision: AA000000    Serial number: 00000134103691
   Coding: 0058130000006001000001010101102030303232203232
   VCID: 77BEF934C638DAF7A8-8022
   Component: SARA 3D       H04 0056
   Revision: --------    Serial number: EJ1BPA720FLTWE
   ROD: EV_SARA2.rod
   VCID: 33260D249AC0F6D754-8066
   Coding: 011F17014E00628002080002
   VCID: 47DE49F4F6586A7718-8012
   Revision: 00001000    Serial number: 0008397702
   Coding: 101000010001
   Revision: 00002001    Serial number: 0359813205
   Coding: 0100063820B930008320090028010F470000000000000000000000000000
   VCID: 46C044F0F152737FE3-8012
   Revision: --------    Serial number: 00000001356261
   VCID: 2D121B5C7CE4A02702-8078
   Part No SW: 4G1 035 044 D    HW: 4G1 035 044
   Component: MU-H-LN-EU    041 0389
   Serial number: A589B0F7507774
   Coding: 01750201FF0A000013110001000A00132F0006E5F1700100DF
   VCID: 200CF2683B367D4FB9-8074
   Serial number: AUZ8Z9FY8013QG
   Serial number: 90349OB2000V5
3086 - Antenna for Telephone Mount
          B1564 01 [009] - Electrical Failure
                    Reset counter: 19
                    Mileage: 88693 km
                    Date: 2019.07.19
                    Time: 21:08:11
                    Voltage terminal 30: 12.5 V
                    Status of telephone-Antenna diagnostic: OK
                    Status of telephone-Telephone baseplate diagnostic: not connected
                    Status of telephone-Handset in handset holder (cradle): not selected
                    Status of telephone-Handset holder (cradle): not connected
6733 - Control Head Module; Rear Right
          U12B0 00 [009] - No Communication
          [Smart display carrier 1: no signal/communication]
                    Reset counter: 19
                    Mileage: 88693 km
                    Date: 2019.07.19
                    Time: 21:08:00
   Coding: 010F15004000628002080002
   VCID: 49DA4FCCE04C9C070E-801C
   Component: Anhaenger     H14 0137
   Revision: 7B001001    Serial number: 0359195306
Address 6C: Back-up Cam. (J772)       Labels:| 4S0-980-556.clb
   Part No SW: 4S0 980 556 A    HW: 5Q0 980 556 B
   Component: RVC Compact   H12 0201
   Coding: 0275000103002007000040
   Shop #: WSC 17873 123 50804
   ASAM Dataset: EV_CamSysRVRVCPANAAU57X 002003
   ROD: EV_CamSysRVRVCPANAAU57X_002_AU57.rod
   VCID: 393A3F0CB8AC0C879E-806C
10489856 - No Basic Setting
          B2010 00 [009] - -
          [RearView system not calibrated]
                    Reset counter: 19
                    Mileage: 88693 km
                    Date: 2019.07.19
                    Time: 21:16:18
                    passive
   Revision: 14005001    Serial number: 022501421
   Coding: 093205C011
   VCID: 3620343089B2E3FF73-8062
Address 82: Heads Up Display (J898)       Labels:| 4G0-919-604.clb
   Part No SW: 4G0 919 604 M    HW: 4G0 919 604 M
   Component: HeadUpDisplay H07 0304
   Coding: AF0000
   ASAM Dataset: EV_HUDContiC7 001025
   ROD: EV_HUDContiC7.rod
   VCID: 3522333C94B4E8E77A-8060
16776965 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [LDW_02_FR keine Kommunikation]
                    Reset counter: 19
                    Mileage: 88693 km
                    Date: 2019.07.19
                    Time: 21:20:15
16776970 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [VZE_01_ keine Kommunikation]
                    Reset counter: 19
                    Mileage: 88693 km
                    Date: 2019.07.19
                    Time: 21:20:15
   Coding: 72060000
   VCID: 2C14165847FEA92F15-8078
0730 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [SARA_SARA_04_Signal_error]
                    Reset counter: 19
                    Mileage: 88693 km
                    Date: 2019.07.19
                    Time: 21:24:38
                    Outside air temperature: -41.0 °C
                    Voltage terminal 15: 12.1 V
                    Control Module temperature: 46.0 °C
0773 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [SARA_SARA_05_Signal_error]
                    Reset counter: 19
                    Mileage: 88693 km
                    Date: 2019.07.19
                    Time: 21:24:38
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 312A072C60DCC4C726-8064
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 3228082065DAFFDF5F-8066
   Revision: 00000000    Serial number: 150090361
End----------(Elapsed Time: 01:48, VBatt start/end: 12.4V/12.4V)-----------
Friday,19,July,2019,21:31:55:62878
Gateway Installation List:  4G8 907 468
pcourt
C?ID=303438
I have a 2012 Audi A7 with ACC, Side Assist, and the HUD. Thanks to this post and a Ross-Tech cable, I was able to add Lane Keeping Assist (I will use this term loosely. My Audi calls it different things in my menus and manuals. It vibrates the wheel when I'm about to depart the lane and actively steers the car back). I added a new stalk as well to have the button. It's been working flawlessly.
Each year at the annual maintenance, the dealer would flash the system and wipe out my mods. So I'd go back and reprogram following these instructions summarized from above.
1. Update the VCDS software and cable while the cable is connected to the car and the internet
2. CAR SHOULD BE ON BUT ENGINE NOT RUNNING. PRESS BUT DON’T HOLD THE INGNTION BUTTON.
3. Scan the vehicle and save the file.
4. For each of these, you will go to Long Coding, use the down arrow to change the BYTE, select the Bit, then hit ESC to back out, and then hit “Do it!”
5. Access 10-Park/Steer Assist>07Coding>Long Coding Helper>Enable Byte 1 Bit 5 "Lane Maintenance Assist(PR-7Y4/7Y5) installed".
6. Access 16-Steering Wheel>07 Coding>Long Coding Helper>Byte 2 Bits 6&7 change to "C0 Lane Assist with Heading Control installed".
7. Access 17-Instruments>07 Coding>Long Coding Helper>Enable Byte 4 Bit 6 "Lane Assist Installed".
8. Access 44-Steering Assist>07 Coding>Long Coding Helper>Enable Byte 2 Bit 0 "Lane Assist installed" ENGINE MUST BE OFF BUT IGNITION ON TO CLEAR ERROR.
9. Access 8E-Image Processing>07 Coding>Long Coding Helper>Byte 1 Bits 5&6 change to "40 Lane Assist and Lane Change Assist installed (PR-7Y5)"
10. Reboot the MMI (Menu button +Center knob+Top Right soft button)
11. Enable the Green Menu by holding Car and Menu
12. Car>Cardevicelist>Check “Lane Departure Warning”
13. Car>Carmenuoperation>Lane Departure Warning – Change from 0 to 5
14. Clear all faults and refresh the system. No errors should be present.
15. To exit the green menu just hit another function button
This year, I did all the above, as I have done the past three years, but had the following conditions.
1. Lane-keeping assist (LKA) was working, as evidenced by the proper symbology on the instrument panel.
2. The MMI included LKA as an option in car systems with the choice of steering wheel vibration on or off.
3. BUT...there was no symbology on the HUD, AND
4. In the HUD display options in the MMI, there was no choice to include LKA.
Dana at Ross-Tech was helpful with suggesting checking 5F. I did not find anything there. But I did find this:
Access 82 HUD>07 Coding>Long Coding Helper>Enable Byte 0 Bit 2 "Lane Departure Warning, Available"
This was experimental coding. I performed this mod and everything worked great. The symbology popped up on the HUD and the MMI menu now says "ACC/Lane Departure Warning."
I just wanted to share this info in case it would help someone.
I'm new to posting on here, but glad to post a scan if needed.
JPE
Manchester, UK
C?ID=426958
I have a 2016 A7 and I am retrofitting Active Lane Assist + Traffic sign recognition, I have Led Matrix lights and adaptive headlights so have the camera in the windscreen . I installed the loom from KUFATEC and a used 8E-Image Processing unit and stalk I kept my original steering slip ring.
The problem is I can not program unit 16 to say I have the new stalk with ACC and Lane assist I get the error 31 and I am not sure if the problem is the stalks or the steering slip ring please can somebody help me please?
Revision: C0068538 Serial number: 90862PDQ00001
Coding: 000034
VCID: 3B233C93936E9D13660-806E
Serial number: 10 03 2016 F0034864
Control Module Part Number: 4H0 953 568 K
Component and/or Version: Lenks.Modul H06 0005
Software Coding: 000034
Work Shop Code: WSC 02391
Advanced Identification
Identification: KLO-KO3
Revision: C0068538
Date: 26.04.16
Manufacturer number: 0862
Test stand number: 0001
Flash Status
Programming Attempts(application): 0
Successful Attempts(application): 0
Programming Status: 00000000
Flash Date: 2016.04.25
Flash Tool Code: 00000 000 00000
Software
CAN: 01.26.02
TP 2.0: 03.05.00
KWP2000: 03.00.00
OSEK-OS: 03.21.00
HiSpd Net: 01.12.01
OSEK-Com: 03.21.00
LIN 2.0: 00.01.31
Bootloader/Flasher: 01.07.00
Misc.
Hardware number: 4H0 953 568 K
Workshop System Name: J527
VCDS Info:
Labels: 4H0-953-568.clb
PetrolDave
Westbury, UK
C?ID=1423
We always ask for a full unedited Auto-Scan not just an small edited section, your coding of address 16 is likely affected by what others modules your car has and what their hardware/software versions are.
JPE
Manchester, UK
C?ID=426958
The full scan is below I believe the other faults are because of the fault with the switch.
   Component: 3.0TDI EDC17  H34 0007
   Revision: 92H34---
   Coding: 1A254012042601030800
   Shop #: WSC 46458 001 1048576
   ASAM Dataset: EV_ECM30TDI0114G2907401B 001007
   ROD: EV_ECM30TDI011_AU57.rod
   VCID: 2411E7EF0E50C2EB37A-8070
   Component: 0B5 30 TDIRdW H03 0008
   Revision: --H03---
   Coding: 100001
   VCID: 2D0702CB5D9A03A3E84-8078
   Coding: 17A69E43E86579C29B00
   ROD: EV_ESP9BOSCHAU57X.rod
   VCID: 41DF4E7BF102F7C33CC-8014
   Part No SW: 4H0 907 064 GP    HW: 4H0 907 064 GP
   Component: BCM2 2.0      H37 0572
   Coding: 05BA6F4E000000000000
   VCID: 7DA7F28BCDFA5323184-8028
   Serial number: 3216000077090014
   Serial number: 27041600040222
   Coding: 36231178350000
   VCID: 6393A4F34BDE85D30E0-8036
0369 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Steuergerät für Spurhalteassistent: kein Signal / Kommunikation]
                    Reset counter: 219
                    Mileage: 44754 km
                    Date: 2021.01.17
                    Time: 15:01:14
                    Voltage terminal 30: 11.71 V
                    Outside temperature: 7.5 °C
                    Engine RPM: 0 /min
   Part No SW: 4H0 907 063 DG    HW: 4H0 907 063 AG
   Revision: 14020001    Serial number: 00001331176601
   Coding: 0105C01440349FE04101408380001800CF9DC30A2F080201000008946100130200400010010000
   VCID: 70B9DBBF8AA82E4B832-8024
   Component: WWS57X 160217  H38 0080
   Serial number:         160228053230
   Coding: 0045F7
   Serial number: 61722058
   Coding: 02006E
   Serial number: 21 04 2016  00001360
   Component: AQ_Hum_Sensor  H03 0005
   Serial number: 8279C42800PAG0MUFU01
Address 10: Park/Steer Assist (J791)       Labels:| 4H0-919-475-7X5.clb
   Part No SW: 4G0 919 475 H    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0080
   Revision: --------    Serial number: 56261611000440
   Coding: B81310
   ASAM Dataset: EV_EPHVA2CAU64X0000 001014
   ROD: EV_EPHVA2CAU64X0000.rod
   VCID: 36352DA7A8CC407B99E-8062
   Revision: --------    Serial number: 003P1009KHA%
   Coding: 30333046313130313235554A305234473853
   VCID: 3B233C9393EE9D13660-806E
   Serial number: 3575HRB405J42AEMB1NI
   Serial number: 3585HRB405H42AEMFGHU
   Serial number: 3515JRB4002570BQGGSE
   Serial number: 3525JRB401455COAEA5.
   Serial number: 3554VRB400E570BMM0IH
   Serial number: 3564VRB400E570BMO0LN
   Coding: 000034
   Part No SW: 4G8 920 986 M    HW: 4G8 920 986 M
   Component: TDieGb        H11 0106
   Revision: 09001102    Serial number: 658230416596014
   Coding: 33AF02024B472600010100
   ASAM Dataset: EV_RBD4K 004055
   VCID: 42DD4177F404ECDB256-8016
16776969 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 219
                    Mileage: 44754 km
                    Date: 2021.01.17
                    Time: 15:01:14
   Part No SW: 4G8 907 468 F    HW: 4G8 907 468
   Component: J533--Gateway H14 0083
   Revision: --------    Serial number: 00000002232267
   Coding: C0CD078118
   ASAM Dataset: EV_GatewPkoUDS 001028
   Serial number: 1556779903
   Voltage stabilizer:
   Serial number: 1602180000000000045C
   Serial number: 27041600041730
   Coding: 22
   VCID: 3D27328B8DFA9323584-8068
   Part No SW: 4H0 907 440     HW: 4H0 907 440
   Component: STS           H06 0030
   Revision: S0H06000    Serial number: 00000000093188
   Coding: 01010101000000000001000202
   VCID: 6491A7EF4E5082EBF7A-8030
   Revision: AA000000    Serial number: 00000196428310
   Coding: 00781B0000006001000001010101102030303232203232
   VCID: 77ABE0A3EFC67973428-8022
   Revision: --------    Serial number: EJ1BPA820BFHNR
   ROD: EV_SARA2.rod
   Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
   Component: SWA Master    H07 0060
   Serial number: 0385170675
   Coding: 040212
   VCID: 392F269B99D2AF0374C-806C
   Lane change assistance control module 2:
   Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
   Component: SWA Slave  H07 0060
   Serial number: 0385011234
   Coding: 040212
   Coding: 011F56035E21620002080412
   VCID: 47CB5063DFA6C9F3F28-8012
   Component: RCevo         H54 0202
   Revision: 00000002    Serial number: 0000808351
   Coding: 101101010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   VCID: 3A2D39979CD4A41B7D6-806E
   Revision: 00002001    Serial number: 0402083434
   Coding: 013B0E22A0B9B881C3200A0400030D470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177 A
   Component: Sensor, DWA  005 0002
   Subsystem 3 - Part No SW: 4G8 959 252 A    HW: 4G8 959 252
   Component: HSP-SG  H11 0031
   Serial number: WA123841000021275368
   Subsystem 4 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93802366
   Part No SW: 4H0 907 801 L    HW: 4H0 907 801 A
   Component: EPB-4         H05 0017
   Revision: --------    Serial number: 00000001820401
   ASAM Dataset: EV_ParkiBrake 001029
   VCID: 313F1EBB41A26743CCC-8064
   Coding: 05FE02202A130200
   VCID: 343117AFBEB0526BA7A-8060
   Left LED Headlamp Power Output Stage 1:
   Subsystem 1 - Part No SW: 7PP 941 472 K    HW: 7PP 941 472 K  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H07 7570
   Coding: E02100
   Right LED Headlamp Power Output Stage 1:
   Subsystem 2 - Part No SW: 7PP 941 472 K    HW: 7PP 941 472 K  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H07 7570
   Coding: E02100
   Power module 1 for left matrix headlamp:
   Coding: E02100
   Power module 1 for right matrix headlamp:
   Coding: E02100
   Part No SW: 4G1 035 018     HW: 4G1 035 021 D
   Component: MU-H-LND-EU   051 0389
   Serial number: A733D0GB011566
   Coding: 017503010000000013111102000A00332F000CE7F1708100FF
   VCID: 5DE7920B6DBAB323384-8008
   Data carrier:
   Subsystem 1 - Part No SW: V03 959 801 PR    HW: -----------
   Component: ECE 2018  --- 0166
   Multimedia System 1:
   Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
   Serial number: AUZ8Z9GY8053WC
   Multimedia system control head:
   Serial number: 90349PDM0005H
   Compact disc data bank:
7193 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Lane departure warning: heading control (0x19) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 219
                    Mileage: 44754 km
                    Date: 2021.01.17
                    Time: 15:01:18
                    Voltage terminal 30: 11.9 V
                    BAP-BAP_Function_ID: 02
   Coding: 010F14024021620002080002
   VCID: 49CF565BC9B23F83E4C-801C
   Part No SW: 4S0 980 556     HW: 4M0 980 556
   Component: RVC Compact   H08 0140
   Coding: 0275000102002003000040
   ASAM Dataset: EV_CamSysRVRVCPANAAU57X 001001
   ROD: EV_CamSysRVRVCPANAAU57X_001.rod
   VCID: 78A9E39FE258760B4B2-802C
   Part No SW: 4G8 959 107 S    HW: 4G8 959 107 H
   Component: HDSG-Modul    H14 0049
   Revision: 11014001    Serial number: 103601673
   Coding: 0A3305C022
   ASAM Dataset: EV_HDSGAu573 001022
   VCID: 45D75A6BE52ADBE3004-8010
   Part No SW: 4G8 919 604 N    HW: 4G8 919 604 N
   Component: HeadUpDisplay H08 0306
   Coding: A70000
   ASAM Dataset: EV_HUDContiC7 001027
   VCID: 3E25358780FC883B41E-806A
          U1111 00 [009] - -
                    Reset counter: 219
                    Mileage: 44754 km
                    Date: 2021.01.17
                    Time: 15:01:14
   Coding: 72140000
   VCID: 2C010FCF66800AABFFA-8078
   Serial number: 005000621906157
   Coding: 032239181111
   ROD: EV_BC7.rod
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 160950291
   ROD: EV_RDCMA00100.rod
   VCID: 2F3B18C3579671B3DA8-807A
End----------(Elapsed Time: 02:25, VBatt start/end: 12.1V/12.2V)-----------
JPE
Manchester, UK
C?ID=426958
These are the options available and the stalk has the correct buttons but the long code will not save with Bit2-3 or bit 6-7 changes.
markdjr
Portland, OR, USA
C?ID=428957
Thanks for all the info on this thread!! Dealership said this wasn't possible, but as you all know, it is and I just completed the retrofit. I have a 2012 a7 and also had to code 87 HUD per PCourt's instructions. This is such a useful feature, I can't for the life of me figure out why it wasn't included from factory.
Rizzio
Trondheim, Norway
C?ID=369124
If your stalks have all the buttons, its the slip ring that needs to be exchanged. Error 31 means the controler is missing that control aerea
ahmedmph
Dubai, UAE
C?ID=234898
Greetings All
I have a 2016 A7 and I am retrofitting Active Lane Assist + Traffic sign recognition, I have Led Matrix lights and adaptive headlights so have the camera in the windscreen . I installed the loom from KUFATEC and a used 8E-Image Processing unit and stalk and new steering slip ring.
all codings are accepted as it should be, but still both Active Lane Assist + Traffic sign recognition still not working
i have video cable error in Image processing control unit which i think is the main reason, cable was provided by KUFATE
here is my full car scan maybe coding is wrong somewhere if any one can help
Tuesday,20,December,2022,15:24:52:27351
VCDS Version: 22.10.0.1 (x64)  HEX-V2 CB: 0.4623.4
Data version: 20221026 DS344.0
VIN: WAUSGCFC2GN020932   License Plate:
Mileage: 137949km-85717mi   Repair Order:
82-Head Up Display -- Status: OK 0000
Tuesday,20,December,2022,15:30:22:27351
Chassis Type: FC-AU57 (4G8)
Scan: 01 02 03 05 06 08 09 10 15 16 17 19 28 36 3B 3C 42 44 46 52
          53 55 5F 62 6C 6D 72 82 85 88 89 8E 8F 90 47
VIN: WAUSGCFC2GN020932   Mileage: 137949km-85717miles
Address 01: Engine (J623-CREC)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G2 907 551 B    HW: 4H2 907 551 A
   Component: 3.0l V6 TFSI  H10 0002
   Revision: --H10---    CVN: 800590BF
   Coding: 1A2500340526010B3000
   ASAM Dataset: EV_ECM30TFS0214G2907551B 002002
   ROD: EV_ECM30TFS0214G2907551B_002.rod
   VCID: 2A0D0E5EBC79842B956-807E
   VINID: 9D19635D3593097780080243086C356868
Readiness: 1010 0001
   Part No SW: 4G0 927 166 D    HW: 0B5 927 156 K
   Component: 0B5 30TFSIRdW H03 0011
   Revision: --H03---    CVN: 00009481
   Coding: 100001
   VCID: 2E05024E8091E80B49E-807A
   Coding: 44A68E43226571C29B00
   VCID: 41DF49F2210F6773A4C-8014
   Part No SW: 4H0 907 064 FT    HW: 4H0 907 064 ET
   Coding: 05AA6F0E000000000000
   VCID: 00598CF66A05AE7BEB2-8054
   Part No SW: 4G8 959 760 B    HW: 4G8 959 760 B
   Component: MEM-BFS       H04 0157
   Revision: AA000000    Serial number: 00000139490519
   Coding: 0018320000006201000001010101112030303333283333
   VCID: 392F2112495F3FB3ECC-806C
   Part No SW: 4G0 820 043 CC    HW: 4G0 820 043 CC
   Serial number: 22031700041642
   Coding: 660331783D0000
   Shop #: WSC 00046 000 00000
   VCID: 629DA67E84C91C6B9D6-8036
   Part No SW: 4H0 907 063 DF    HW: 4H0 907 063 AF
   Revision: 13020001    Serial number: 00001047371701
   Coding: 0105C01440349FE0C1014080A0001800CF9CC3082E0802010000089461011302004000010B0000
   Shop #: WSC 00046 123 12345
   VCID: 6FBBDF4A479BA103028-803A
   Component: WWS57X 150412  H37 0080
   Serial number:         150415151900
   Coding: 0045F7
   Serial number: 23926181
   Coding: 02006E
   Serial number: 15 04 2015  00000842
   Serial number: E04845A7000000000001
   Part No SW: 4G0 919 475 G    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0070
   Revision: --------    Serial number: 56291509901611
   Coding: B82310
   ASAM Dataset: EV_EPHVA2CAU64X0000 001011
   VCID: 35372D2265C7DBD3084-8060
   Revision: --------    Serial number: 003P1004G0FL
   Coding: 30333046313130313233554A304C34473853
   VCID: 3B233B1A43E30DA3FE0-806E
   Serial number: 3575HRB404R3761S5H7C
   Serial number: 3585HRB404R3761S8H4D
   Serial number: 3515JRB405P370PI70IB
   Serial number: 3525JRB4059370PIIGHM
   Serial number: 3554VRB405T36RTAAOI-
   Serial number: 3564VRB405R36RTAJ8FP
   Revision: --------    Serial number: 90372NAD000C8
   Coding: 0000F4
   VCID: 38292416725526BB132-806C
   Serial number: 24 03 2015  10078355
   Part No SW: 4G8 920 933 N    HW: 4G8 920 933 N
   Component: TBenRdw       H08 0106
   Revision: 04001037    Serial number: 658230415596008
   Coding: 13BF11024B478008010500
   Shop #: WSC 12345 123 61029
Address 19: CAN Gateway (J533)       Labels:| 4H0-907-468.clb
   Revision: --------    Serial number: 00000001820607
   Coding: C0CF073018
   GVL: FFA1E84CDCA368CD40040000
   VCID: 75B7ED2225479BD3C84-8020
   Serial number: 5708916203
   Voltage stabilizer:
   Serial number: 150208000000000005BC
   Serial number: 29041500040001
   Coding: 20
   VCID: 3D2735025DF70393C04-8068
   Component: MEM-FS        H04 0157
   Revision: AA000000    Serial number: 00000139490516
   Coding: 00183B0000016201000001010101112030303333203333
   Revision: --------    Serial number: EJ1BPA8209CXKZ
   ROD: EV_SARA2.rod
   VCID: 36352A2E78C1D0CB01E-8062
   Component: SWA Master    H06 0060
   Serial number: 0365807371
   Coding: 040211
   VCID: 392F211249DF3FB3ECC-806C
   Component: SWA Slave  H06 0060
   Serial number: 0366540028
   Coding: 040211
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0511
   Coding: 011F5F035E00628202080412
   VCID: 45D75DE235A74B53984-8010
   Part No SW: 4G0 909 144 S    HW: 4G0 909 144 G
   Component: RCEPS         H43 0012
   Revision: 00001000    Serial number: 0015720471
   ASAM Dataset: EV_RCEPS 009013
   Revision: 00002001    Serial number: 0366940821
   Coding: 01000E3820B9B085C3300A840A030D470000000000000000000000000000
   Subsystem 1 - Part No SW: 4G8 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS40.402  H03 0004
   Serial number: 0000FST00090LRL00000
   Coding: 901F02
   Subsystem 2 - Part No SW: 4G0 947 135 F    HW: 4G0 947 135
   Serial number: 0000000AP00012714567
   Subsystem 3 - Part No SW: 4G8 959 252     HW: 4G8 959 252
   Component: HSP-SG  H11 0029
   Serial number: WA120634000012835917
   Serial number: 93496837
03615 - Rear Right Reading Light
                    Reset counter: 213
                    Mileage: 137949 km
                    Date: 2022.12.20
                    Time: 15:23:59
   Part No SW: 4G8 959 792 H    HW: 4G8 959 792 F
   Component: TSG BF        H04 0507
   Coding: 011F5F035E00628202080402
   VCID: 44D140E63E9D725B8FA-8010
   Revision: --------    Serial number: 00000001444079
   VCID: 2D0705428D979313704-8078
   Coding: 05FA02202A100200
   VCID: 343110266EBDC2DB3FA-8060
   Coding: E02100
   Coding: E02100
   Coding: E02100
   Coding: E02100
   Part No SW: 4G1 035 046 M    HW: 4G1 035 046
   Component: MU-H-LN-RW    041 1425
   Serial number: A592D0F7515077
   Coding: 0175030C0000000013110002004F00102F010CE4F17087007E
   VCID: 2B030B5AB3839D236E0-807E
   Data carrier:
   Subsystem 1 - Part No SW: V03 959 803 BM    HW: -----------
   Component: ROW 2022/2023  --- 0101
   Serial number: AUZ8Z9FY801DJY
   Serial number: 90349ODL000MP
   Component: Gracenote2  --- 4013
7182 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Mirror (0x0E) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 213
                    Mileage: 137949 km
                    Date: 2022.12.20
                    Time: 15:24:01
                    Voltage terminal 30: 13.9 V
   Part No SW: 4G8 959 795 H    HW: 4G8 959 795 F
   Coding: 010F1D024000628202080002
   VCID: 47CB57EA0FAB59436A8-8012
   Part No SW: 4H0 907 428 D    HW: 7P6 907 441 F
   Component: TopView       H07 0330
   Revision: 11001001    Serial number: 82330JF0223449
   Coding: 0217000001010100000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 008027
   ROD: EV_CamerSysteTopViewAUDI.rod
9616786 - Surroundings Camera Front
          B127C F0 [009] - Calibration Failed
                    Reset counter: 213
                    Mileage: 137949 km
                    Date: 2022.12.20
                    Time: 15:23:57
                    Voltage terminal 30: 13.6 V
9616787 - Surroundings Camera Rear
          B127D F0 [009] - Calibration Failed
                    Reset counter: 213
                    Mileage: 137949 km
                    Date: 2022.12.20
                    Time: 15:23:57
          B2010 00 [009] - -
          [TopView system not calibrated]
                    Reset counter: 213
                    Mileage: 137949 km
                    Date: 2022.12.20
                    Time: 15:23:57
   Revision: 11014001    Serial number: 110500560
   Coding: 0A3305C022
   VCID: 45D75DE235274B53984-8010
Address 82: Head Up Display (J898)       Labels:| 4G0-919-604.clb
   Part No SW: 4G8 919 604 M    HW: 4G8 919 604 M
   Component: HeadUpDisplay H07 0306
   Coding: A78000
   Coding: 72160000
   VCID: 2C010846B68D9A1B67A-8078
   Part No SW: 4G8 881 073     HW: 4G8 881 073
   Component: P2G           H02 0032
   Serial number: 0F4F2AE
   Coding: 662FF0
   ASAM Dataset: EV_P2GDriveSideFrnt 001006
   ROD: EV_P2GDriveSideFrnt.rod
   VCID: 6E85C24E4011A80B09E-803A
   Valve block 1 in front seat driver side:
   Subsystem 1 - Part No SW: 4G8 907 181     HW: 4G8 907 181
   Component: PSLB  H02 0023
   Serial number: 00000000000000F3G3PB
   Serial number: 0F482XA
   Coding: 262FF0
   ASAM Dataset: EV_P2GPasseSideFrnt 001006
   ROD: EV_P2GPasseSideFrnt.rod
   Valve block 1 in front seat passenger side:
   Serial number: 00000000000000F3U2NV
   Component: BV-SG         H33 0092
   Serial number: 005000621311157
   Coding: 0340B11A1111
   ROD: EV_BC7.rod
0148 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [QSP_Timeout]
                    Reset counter: 213
                    Mileage: 137949 km
                    Date: 2022.12.20
                    Time: 15:23:59
                    Outside temperature: 30.0 °C
                    Voltage terminal 15: 13.6 V
                    Control Module temperature: 47.0 °C
0161 - Video Cable for Image Processing
          C1107 02 [009] - Signal Failure
          [No_camera_found_on_startup]
                    Reset counter: 213
                    Mileage: 137949 km
                    Date: 2022.12.20
                    Time: 15:24:07
                    Outside temperature: 30.5 °C
                    Voltage terminal 15: 13.7 V
   ROD: EV_RGS_L.rod
   VCID: 313F193291AFF7F354C-8064
   ROD: EV_RGS_R.rod
   VCID: 323D163E94A9CCEB2D6-8066
   Part No SW: 4G5 035 223 E    HW: 4G5 035 223
   Component: MIB2_amp_P    H02 0440
   Serial number: 00000000033587
   Coding: 0175030A018AF02A5A0000010000
   ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
   ROD: EV_AMPMst16C4Gen2BOSE_AU57.rod
   VCID: 2411E066DE5D525BAFA-8070
1635 - Data Set Implausible
          B2012 00 [009] - -
          [Steuergerät (DatensatzDownload) - Datensatz unplausibel für ANC]
                    Reset counter: 213
                    Mileage: 137949 km
                    Date: 2022.12.20
                    Time: 15:23:57
                    Voltage terminal 30: 12.3 V
1632 - Active Noise Cancellation
          B1765 F0 [009] - Engine Speed Implausible
                    Reset counter: 213
                    Mileage: 137949 km
                    Date: 2022.12.20
                    Time: 15:24:02
End----------(Elapsed Time: 02:23, VBatt start/end: 13.7V/13.8V)-----------
Mrclopec
Nipomo, CA, USA
C?ID=149231
Cant help much with the traffic sign...but try the code below for your long coding in Module 17 and see if that fixes the ALA.
13BF11020B578008010500
