Hi Guys
Just taken delivery of a new (facelift) A6 Avant S-Line Ultra with tech pack and a few little extras.
The car has an electric opening tailgate and I'd like to be able to close it with the key rather than just the button on the tailgate.
I've posted the following in the A6-C7 forum but have not yet had a response:
"Picked up my new FL Avant Ultra a few days ago. Overall very pleased. Used VCDS successfully for the following tweaks:
1.Enabling Gauge Test/Needle Sweep
2. Enabling Lap Timer
4. Beep on lock
15. Enable auto handbrake when shift into P
Also tried:
16. Close electric boot lid from key
[Select]
[46 - Cent Conv]
[Coding - 07]
Click on byte 2, bit 2
Tick Comfort operation: Remote control active
[Do It!]
[Select]
[4D - Trunk Elec]
[Security Access - 16]
Input 12345
[Adaption - 10]
Activation using rear lid opening button in remote key - Touch function for closing
Change to ACTIVE
[Do It!]
Unfortunately this one didn't work for me. In fact the factory delivered settings were already exactly the same as the tweak. Using VCDS output tests I was able to close the boot with the software but not with the remote key. So it's obviously possible.
Any ideas please anyone. Has anyone else got it working with anew FL model,
Thanks. Glynn"
Full scan of vehicle below. Can anyone help please?
Many thanks - Glynn
4. Beep on lock
Also tried:
[Select]
[46 - Cent Conv]
[Coding - 07]
[Do It!]
[Select]
[4D - Trunk Elec]
Input 12345
[Adaption - 10]
Change to ACTIVE
[Do It!]
Thanks. Glynn"
Many thanks - Glynn
Monday,12,October,2015,13:10:24:22222
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
VIN: WAUZZZ4G8GN070672 License Plate: AUDI SIL5356
Mileage: 315km-195mi Repair Order:
Chassis Type: 4G (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 20 28 3B 42 44 46 52 53 55 5F
62 6D 72 AC
VIN: WAUZZZ4G8GN070672 Mileage: 315km-195miles
Address 01: Engine (J623-CNHA) Labels: None
Part No SW: 04L 906 021 FQ HW: 04L 907 309
Component: R4 2,0L EDC H23 1649
Revision: 85H23---
Coding: 12254012242401080000
ASAM Dataset: EV_ECM20TDI01104L906021FQ 002004
ROD: EV_ECM20TDI01104L906021FQ.rod
VCID: 79F9376FF88F9CF61A-802C
Address 02: Auto Trans (J217) Labels: None
Part No SW: 4G1 927 153 B HW: 0CK 927 156 S
Component: 0CK 20TDI RdW H03 0002
Revision: --H03--- Serial number: 0000000108
Coding: 100001
ASAM Dataset: EV_TCMDL382021 002020
ROD: EV_TCMDL382021.rod
VCID: 2959272F48AFEC762A-807C
Subsystem 2 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 K
Component: V553 MTFP HB1 0572
Serial number: 75117051150219000361
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 4G0 907 379 S HW: 4G0 907 379 S
Component: ESP9 Premium H01 0530
Coding: 06A29E41604579829B00
ROD: EV_ESP9BOSCHAU57X.rod
VCID: 41899F8FD0DF043612-8014
Part No SW: 4H0 907 064 GN HW: 4H0 907 064 GN
Component: BCM2 2.0 H37 0572
Coding: 01B9704E000000000000
VCID: 7BF52D67FAB3AEE608-802E
Part No SW: 4G0 820 043 CD HW: 4G0 820 043 CD
Component: KLIMA 4 ZONEN H14 0112
Serial number: 27081500040098
Coding: 34220978210000
ROD: EV_AirCondiComfoUDS.rod
VCID: 63C575076A03762620-8036
Address 09: Cent. Elect. (J519) Labels: Redir Fail!
Part No SW: 4H0 907 063 DH HW: 4H0 907 063 AH
Component: BCM1 2.0 H20 0311
Revision: 15020001 Serial number: 00001143856901
Coding: 0105001440349FE04101408300001800CF9DC7082F08020100000894E100140200400024030000
VCID: 71E90F4FA8FFD4B6A2-8024
Component: WWS57X 150624 H38 0080
Coding: 0045F7
Component: G397_RLFS H06 0004
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 BE HW: 4G0 941 531 BE
Component: E1 - LDS H07 0044
Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Address 15: Airbags (J234) Labels: 4H0-959-655.clb
Component: Airbag10.43 H82 0086
Revision: -------- Serial number: 003P100631RN
Coding: 30333130313630323639554A305234473053
VCID: 3B75ED67B2336EE648-806E
Serial number: 3575HRB404R3JK5A998L
Serial number: 3585HRB40513HTVG609P
Serial number: 3515JRB404T3E9P4HOA%
Serial number: 3525JRB405J3FQH0N19M
Serial number: 3554VRB405P3K0OQH869
Serial number: 3564VRB405P3K0OQKG7M
Address 16: Steering wheel (J527) Labels: 4H0-953-568.clb
Part No SW: 4H0 953 568 K HW: 4H0 953 568 K
Component: Lenks.Modul H06 0005
Revision: C0068538 Serial number: 90862OHQ0008J
Coding: 000035
VCID: 3B75ED67BA336EE648-806E
Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb
Part No SW: 4G8 920 986 M HW: 4G8 920 986 M
Component: TDieGb H11 0104
Revision: 07001088 Serial number: 658170815596020
Coding: 33A612000B412600010000
ASAM Dataset: EV_RBD4K 004055
ROD: EV_RBD4K.rod
VCID: 428B9083D5D91F2E0B-8016
Part No SW: 4G8 907 468 F HW: 4G8 907 468
Component: J533--Gateway H14 0083
Revision: -------- Serial number: 00000001950272
Coding: C0CD074418
ASAM Dataset: EV_GatewPkoUDS 001028
ROD: EV_GatewPkoUDS.rod
Serial number: 4779187503
Voltage stabilizer:
Address 20: High Beam Assist. (J844) Labels: None
Part No SW: 4H0 857 511 HW: 4H0 857 511
Component: FLA H04 0021
Revision: AA001002
Coding: 04028264747464545425363E00
VCID: 67DD6117963B1A06FC-8032
Address 28: HVAC, Rear (E265) Labels: 4G0-919-158.clb
Part No SW: 4G0 919 158 Q HW: 4G0 919 158 Q
Component: KLIMA FOND H08 0112
Serial number: 27081500041885
Coding: 22
ROD: EV_ClimaContrUnitRearUDS.rod
VCID: 3D71E37FAC2760D676-8068
Part No SW: 4G0 907 637 H HW: 4G0 907 637 D
Component: SARA 3D H04 0056
Revision: -------- Serial number: EJ1BPA720KCYUD
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2_AU57.rod
VCID: 3365C5479A63A6A690-8066
Component: TSG FA H03 0511
Coding: 011F16015C01620002080002
VCID: 479D8197F6FB3A06DC-8012
Address 44: Steering Assist (J500) Labels: 8K0-909-144.clb
Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
Component: RCevo H53 0202
Revision: 00000001 Serial number: 0000178123
Coding: 101000010001
ASAM Dataset: EV_RCEPS 106007
ROD: EV_RCEPS.rod
VCID: 3A7BE863BD0957EE53-806E
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0375802338
Coding: 013B0622A0B93080C320090400010F470000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177 A
Component: Sensor, DWA 005 0002
Component: TSG BF H03 0511
Coding: 011F16015E01620002080002
VCID: 46838C93F1F1230E27-8012
Part No SW: 4H0 907 801 H HW: 4H0 907 801 A
Component: EPB-4 H04 0015
Revision: -------- Serial number: 00000001575630
ROD: EV_ParkiBrake_AU48.rod
VCID: 2D51D33F7C47F056C6-8078
Address 55: Headlight Range (J745) Labels: 4H4-907-357-V2.clb
Component: MxB-ECU 001 0100
Coding: 04FE02102A630200
ROD: EV_HeadlRegulAUDIMXBAU64X_AU57.rod
VCID: 3467C65B9F6DA19E89-8060
Subsystem 1 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7560
Coding: E01E00
Subsystem 2 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7560
Coding: E01E00
Part No SW: 4G1 035 021 E HW: 4G1 035 021
Component: MU-H-LND-EU 042 0335
Serial number: A588H0F7525791
Coding: 01750201FF0A000013111101000A00132F0006E7F1700100DF
VCID: 1C370EFB17FD09DEA1-8048
Engine Control Module 2:
Subsystem 1 - Part No SW: V03 959 801 F HW: -----------
Component: ECE 2015/2016 --- 0122
Seat Adjustment Driver Side:
Subsystem 2 - Part No SW: 4G1 919 605 A HW: 4G1 919 605 A
Component: DU8 C7 SV H63 0006
Serial number: AUZ8Z9FY802E2L
Sound System:
Subsystem 3 - Part No SW: 4G2 919 610 F HW: 4G2 919 610 F
Serial number: 90349OHL000PA
Door Electronics Rear Left:
Component: Gracenote --- 1010
Component: TSG HL H03 0511
Coding: 010F14004001620002080002
VCID: 499987AFE0EFCC76CA-801C
Address 6D: Trunk Elect. (----) Labels: Redir Fail!
Part No SW: 4G9 959 107 C HW: 4G9 959 107 B
Component: HDSG-Modul H05 0151
Revision: 14005001 Serial number: 218500945
Coding: 093205C010
ROD: EV_HDSGAu571.rod
VCID: 3663FC538911B38EB7-8062
Component: TSG HR H03 0511
Part No SW: 4G0 907 355 G HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0013
Revision: 00000000 Serial number: 152110602
ROD: EV_RDCMA00100.rod
VCID: 2F6DC937764B8246F4-807A
End-------------------------(Elapsed Time: 04:38)--------------------------
