I just need some direction on this car. like where to start and which mvb's to look at. I did the out put test and the flapper seems to be working at this time.
Tuesday,22,September,2015,19:43:37:49874
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
VIN: 3VWPL7AJ3AM646814 License Plate:
Mileage: 129070km-80200mi Repair Order:
Chassis Type: AJ (1K0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 62 65 72
77
VIN: 3VWPL7AJ3AM646814 Mileage: 129070km-80200miles
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 906 019 CM HW: 03L 906 022 TS
Component: R4 2,0L EDC G000AG 9971
Revision: 12H02--- Serial number:
Coding: 0050078
Shop #: WSC 22599 444 12425
VCID: 78F4162B0B1199FE65-802C
001151 - Exhaust Pressure Control Valve
P047F - 000 - Stuck Open - Intermittent
Mileage: 128267 km
Date: 2010.01.07
Time: 16:47:06
RPM: 1012 /min
Speed: 5.0 km/h
Load: 22.4 %
Load: 77.6 %
Lambda: 100.2 %
Temperature: 54.0°C
Temperature: 44.1°C
009315 - Diesel Particle Filter
P2463 - 000 - Excessive Soot Accumulation - Intermittent
Mileage: 128329 km
Date: 2010.01.09
Time: 10:11:53
RPM: 1909 /min
Speed: 41.0 km/h
Mileage: 100 km
40.2
18.6
Pressure: -3 mbar
milliliters: 108 ml
009305 - Diesel Particulate Filer
P2459 - 000 - Regeneration Frequency
Mileage: 128962 km
Date: 2010.02.11
Time: 09:20:55
RPM: 1058 /min
Speed: 11.0 km/h
Mileage: 30 km
18.6
4.2
Pressure: -10 mbar
milliliters: 108 ml
Readiness: 0 1 0 0 0
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 052 T HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2114
Revision: 51112 Serial number: 00000911130047
Shop #: WSC 02069 000 90108
VCID: 254A0F5FEC23D4160E-8070
19143 - Unexpected / Implausible Mechanical Gear Disengagement
P2711 - 005 - - Intermittent
Fault Status: 00100101
Fault Frequency: 255
Reset counter: 28
Mileage: 128501 km
Date: 2010.01.12
Time: 09:18:15
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 114B600C49260000881306E5921D0042310000
Shop #: WSC 00066 000 00000
VCID: 7AF00C23F51D8BEE13-802E
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 3C8 907 336 AJ HW: 3C8 907 336 AJ
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000001002
Shop #: WSC 00066 000 00184
ROD: EV_ClimaBasis_VW36.rod
VCID: 75EA1F1FD403E4967E-8020
Part No SW: 5K0 937 085 G HW: 5K0 937 085 G
Component: BCM PQ35 B++ 111 0128
Revision: BI111001
Coding: 2D380E1A902F3EC480080001400000C401000086535D8560648020000000
VCID: 3776D517868F5686AC-8062
Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 15120 21 0512
Coding: 009795
Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
Component: AirbagVW10G 021 0706
Serial number: 003C4D0A23AE
Coding: 00003044
VCID: 3972D32FB89B40F65A-806C
Subsystem 1 - Part No SW: 1KM 959 339 HW: 1KM 959 339
Component: BF-Gewichtss. 007 0001
Serial number: ---0000R--0004YJC000
Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Serial number: 3572MSME3910444AZZZS
Subsystem 3 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Serial number: 3582MSME3246534AZZZV
Serial number: 3511HSME1125222BZZZ7
Serial number: 3521HSME3D4F791DZZZ4
Serial number: 35527SME1B4F731EZZZW
Serial number: 35627SME4905581EZZZN
Part No SW: 1K0 953 549 CD HW: 1K0 953 549 CD
Component: J0527 056 0111
Coding: 0001532
VCID: 76E818130105EF8E77-8022
Subsystem 1 - Part No: 5K0 959 542 Labels: 3C8-959-537.CLB
Coding: 00000130
Part No SW: 5K0 920 970 Q HW: 5K0 920 970 Q
Component: KOMBI H03 0305
Coding: 270F00
Shop #: WSC 00066 000 00146
VCID: 3C7CCA3BB7A975DE41-8068
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H07 0111
Revision: H07 01 Serial number: 281009F1000324
Coding: ED807F07001612002002
VCID: 69D2436F40BB3076EA-803C
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1225223T67RJ04
VCID: 7EF800332935A7CE2F-802A
Component: IMMO H03 0305
VCID: 6AD03C638DBD3B6EE3-803E
Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
Revision: A1001003 Serial number: 7667638518
VCID: 264808535125DF0E07-8072
Part No SW: 3C0 959 701 B HW: 3C0 959 793
Component: TUER-SG FT 002 0307
Revision: 13101005 Serial number: 0000165280
Coding: 0004B5
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_DCU42BroseDriveSide A03004
ROD: EV_DCU42BroseDriveSide.rod
VCID: 275605575E2FC6063C-8072
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 006 1401
Serial number: 00000004553648
Coding: 000490
Part No: 1K0 909 144 H
Component: EPS_ZFLS Kl. 70 2901
Revision: 00H17000
VCID: 2F66ED77BEDF9E46F4-807A
Part No SW: 3C0 959 702 B HW: 3C0 959 792
Component: TUER-SG BT 002 0307
Revision: 15101005 Serial number: 0000159674
Coding: 0004B4
ASAM Dataset: EV_DCU52BrosePasseSide A03004
ROD: EV_DCU52BrosePasseSide.rod
VCID: 2854066B5331C97E35-807C
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 006 1401
Serial number: 00000004470635
Coding: 000490
67589 - Turn Signal in Exterior Mirror
B11FD 01 [008] - Electrical Failure
Reset counter: 223
Mileage: 122576 km
Date: 2015.04.30
Time: 14:43:35
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 180 AC HW: 1K0 035 180 AC
Component: Radio Prem-8 H10 0035
Revision: -----19S Serial number: VWZ4Z7J3013118
Coding: 0100040004
Shop #: WSC 22599 444 06665
VCID: 61C25B4F788B783632-8034
Fault Status: 00101011
Reset counter: 226
Mileage: 128871 km
Date: 2010.02.08
Time: 13:17:23
Address 65: Tire Pressure (J502) Labels: 1K0-937-08x-65.clb
Component: RDK 111 0821
Coding: 018705
Address 77: Telephone (J738) Labels: 1K8-035-730.clb
Part No SW: 1K8 035 730 C HW: 1K8 035 730 C
Component: Telefon H08 6600
Revision: 00008000 Serial number: 20389520276747
Coding: 412100
VCID: 2952036F403BF0762A-807C
End-------------------------(Elapsed Time: 03:01)--------------------------
Friday,25,September,2015,08:30:06:49874
77
Coding: 0050078
Mileage: 128267 km
Date: 2010.01.07
Time: 16:47:06
RPM: 1012 /min
Speed: 5.0 km/h
Load: 22.4 %
Load: 77.6 %
Lambda: 100.2 %
Temperature: 54.0°C
Temperature: 44.1°C
Mileage: 128329 km
Date: 2010.01.09
Time: 10:11:53
RPM: 1909 /min
Speed: 41.0 km/h
Mileage: 100 km
40.2
18.6
Pressure: -3 mbar
milliliters: 108 ml
Mileage: 128962 km
Date: 2010.02.11
Time: 09:20:55
RPM: 1058 /min
Speed: 11.0 km/h
Mileage: 30 km
18.6
4.2
Pressure: -10 mbar
milliliters: 108 ml
Reset counter: 28
Mileage: 128501 km
Date: 2010.01.12
Time: 09:18:15
Revision: 00H30001
Revision: 00009001
Coding: 0000001002
Revision: BI111001
Coding: 009795
Coding: 00003044
Coding: 0001532
Coding: 00000130
Coding: 270F00
Coding: 0004B5
Slave Driver:
Coding: 000490
Revision: 00H17000
Coding: 0004B4
Slave Passenger:
Coding: 000490
Reset counter: 223
Mileage: 122576 km
Date: 2015.04.30
Time: 14:43:35
Coding: 0100040004
Reset counter: 226
Mileage: 128871 km
Date: 2010.02.08
Time: 13:17:23
Coding: 018705
Coding: 412100
End-------------------------(Elapsed Time: 03:02)--------------------------
Friday,25,September,2015,08:37:44:49874
77
Coding: 0050078
Mileage: 128267 km
Date: 2010.01.07
Time: 16:47:06
RPM: 1012 /min
Speed: 5.0 km/h
Load: 22.4 %
Load: 77.6 %
Lambda: 100.2 %
Temperature: 54.0°C
Temperature: 44.1°C
Mileage: 128329 km
Date: 2010.01.09
Time: 10:11:53
RPM: 1909 /min
Speed: 41.0 km/h
Mileage: 100 km
40.2
18.6
Pressure: -3 mbar
milliliters: 108 ml
Mileage: 128962 km
Date: 2010.02.11
Time: 09:20:55
RPM: 1058 /min
Speed: 11.0 km/h
Mileage: 30 km
18.6
4.2
Pressure: -10 mbar
milliliters: 108 ml
Reset counter: 28
Mileage: 128501 km
Date: 2010.01.12
Time: 09:18:15
Revision: 00H30001
Revision: 00009001
Coding: 0000001002
Revision: BI111001
Coding: 009795
Coding: 00003044
Coding: 0001532
Coding: 00000130
Coding: 270F00
Coding: 0004B5
Slave Driver:
Coding: 000490
Revision: 00H17000
Coding: 0004B4
Slave Passenger:
Coding: 000490
Reset counter: 223
Mileage: 122576 km
Date: 2015.04.30
Time: 14:43:35
Coding: 0100040004
Reset counter: 226
Mileage: 128871 km
Date: 2010.02.08
Time: 13:17:23
Coding: 018705
Coding: 412100
End-------------------------(Elapsed Time: 02:56)--------------------------
