Led back up light 7440
elbcano718
C?ID=213134
How can I clear the malfunction indicator light for the reverse LED lights
 Saturday,25,July,2015,11:03:16:54355
VCDS Version: 14.10.2.0
Data version: 20150311
VIN: WVWGD7AJ7CW092017   License Plate: 0101
Mileage: 64460km-40053mi   Repair Order:
Chassis Type: AJ (7N0)
Scan: 01 03 08 09 15 16 17 19 25 2E 37 42 44 46 52 55 56 62 72
VIN: WVWGD7AJ7CW092017   Mileage: 64460km-40053miles
09-Cent. Elect. -- Status: Malfunction 1010
46-Central Conv. -- Status: Sporadic communication error 1000
Address 01: Engine (CBF)       Labels: 06J-907-115-CBF.clb
   Part No SW: 1K0 907 115 AT    HW: 1K0 907 115 AK
   Component: 2.0l R4/4V TFSI     0010
   Revision: E3H26---    Serial number:
   Coding: 0403010818070160
   VCID: 78FFBAB40B0718E156F-802D
050217 - Implausible Data Received from Steering Column Control Module
               U0429 - 000 -  - Intermittent
                    Mileage: 64468 km
                    Date: 2015.07.25
                    Time: 11:27:53
                    Temperature: 48.0°C
                    Temperature: 35.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 11.938 V
Readiness: 1110 1101
   Revision: 00H31001
   Coding: 114B600C492B00FC880B06E592200041B70800
   VCID: 7BF5A5B8FA3133F93BD-802E
   Part No SW: 7N0 907 426 AN    HW: 7N0 907 426 AN
   Component: AC Manuell    H19 0404
   Revision: 00001015
   Coding: 0000001002
   VCID: 000FD2549BD750216EF-8055
   Part No SW: 1K0 937 086 P    HW: 1K0 937 086 P
   Component: BCM PQ35  M   110 0651
   Revision: 00110 AC
   Coding: 6F180ABB80252AC4008800C5350009E44F752077434D8D20E48428240040
   VCID: 3D716BA0A4A5FDC9459-8068
   Component: Wischer 12081  26  0512
   Coding: 009795
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Frequency: 20
                    Reset counter: 210
                    Mileage: 64365 km
                    Date: 2015.07.24
                    Time: 17:57:37
                    Voltage: 12.45 V
                        Term 50 On
                    Fault Frequency: 20
                    Reset counter: 210
                    Mileage: 64365 km
                    Date: 2015.07.24
                    Time: 17:57:38
                    Voltage: 12.45 V
                        Term 50 On
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 210
                    Mileage: 64365 km
                    Date: 2015.07.24
                    Time: 18:09:23
                        Term 15 Off
                    Voltage: 12.50 V
                        Term 50 Off
01800 - Light Switch (E1)
                    Reset counter: 250
                    Mileage: 64365 km
                    Date: 2015.07.24
                    Time: 18:13:15
                    Voltage: 13.50 V
                        Term 50 On
                    Fault Status: 00100111
                    Reset counter: 250
                    Mileage: 64365 km
                    Date: 2015.07.24
                    Time: 23:41:10
                    Voltage: 13.95 V
                        Term 50 On
   Serial number: 003GVRA0GXDK
   Coding: 00003131
   VCID: 3F8D11A8A6A9EFD9575-806A
   Subsystem 1 - Part No SW: 5K0 959 339     HW: 5K0 959 339
   Component: BF-Gewichtss.  007 0002
   Serial number: ---0000R--00060WHR00
   Serial number: 3572MSME2C6B1363ZZZ.
   Serial number: 3582MSME7E015362ZZZW
   Serial number: 3512QSME76035D61ZZZW
   Serial number: 3522QSME4E445A46ZZZ0
   Serial number: 35527SME4A1B1728ZZZK
   Serial number: 35627SME5B341728ZZZI
   Part No SW: 5K0 953 507 BC    HW: 5K0 953 549 E
   Revision: --------    Serial number:  90422KGT000RI
   Coding: 108A140000
   ROD: EV_SMLSNGKUDS_SE36.rod
   VCID: 72EB889CA57B72B168B-8027
   Serial number: 0428503
   Coding: 820000
   Part No SW: 5K6 920 972 C    HW: 5K6 920 972 C
   Coding: 270D01
   VCID: 3663748C89932E91843-8063
   Revision:   H42       Serial number: 030811F1001134
   Coding: 350002
   VCID: 356173809C9525898D9-8060
                    Fault Status: 00110100
                    Reset counter: 248
                    Mileage: 64365 km
                    Date: 2015.07.24
                    Time: 13:53:35
                    Reset counter: 248
                    Mileage: 64365 km
                    Date: 2015.07.24
                    Time: 13:53:35
   Component: IMMO          H03 0607
   VCID: 6ADB90FC8DABBA71D0B-803F
   Revision: A1001003    Serial number: 7660641902
   Coding: 020000
   VCID: 2959AFF0402D7169191-807C
   Part No SW: 1K0 035 274 B    HW: 1K0 035 274 B
   Component: RNS315-NAR    H32 0265
   Serial number: VWZAZ2L8465234
   Coding: 04000401040005000000100A
   ASAM Dataset: EV_RNS315NARV2UDS A01004
   ROD: EV_RNS315NARV2UDS.rod
   VCID: 2345BDD82A01AB3953D-8076
   Component: NAR_V2  0002
          B11CF 53 [008] - Deactivated
                    Reset counter: 238
                    Mileage: 40448 km
                    Date: 2014.01.04
                    Time: 19:42:07
   Coding: 0001204
   VCID: 31694790A8FD09A9D11-8064
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 74     3201
   Revision: 00H20000
   VCID: 34674E8457EF3C81BA7-8061
   Coding: 0001204
   VCID: 326B489CADFB32B1A8B-8067
   Coding: 1446940
   Subsystem 1 - Part No: 7L6 941 329 B
   Component: AFS-Lst.-Modul l    0004
   Coding: 00000022
   Subsystem 2 - Part No: 7L6 941 329 B
   Coding: 00000022
   Coding: 0001168
   Shop #: WSC 01357 011 1012552
   VCID: 356173805C9525898D9-8060
   Coding: 0001168
   VCID: 3663748C41932E91843-8063
End-------------------------(Elapsed Time: 02:14)--------------------------
