Need Steering Column Access Code
kpac
C?ID=24877
This 2013 Passat was involved in a crash. The body shop replaced the Air Bag module and the Clock Spring/Steering Column module. I was able to successfully code the Air Bag module but I can't code the Steering Column module with a valid Access Code. When I hover over the code box there is no pop-up with a valid Access Code. I am currently using the beta version 15.6.1 and I have also tried the older version 14.10. I have attached an auto scan. Can you provide me with a valid Access Code?
VCDS Version: Beta 15.6.1
Data version: 20150612
Sunday,19,July,2015,19:16:32:61215
Chassis Type: A3 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 42 46 4F 52 56 62 72 77
VIN: 1VWAH7A35DC144384   Mileage: 48660km-30235miles
Address 01: Engine (CBT)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 DD    HW: 07K 907 309 A
   Component: 2,5l R5/4V      G01 4735
   Revision: T6H02---    Serial number:
   Coding: 0000075
   Shop #: WSC 09003 957 00200
   VCID: 73EFA456125A37A7F4-8026
005699 - Please check DTC Memory of Electric Load Controller
               P1643 - 000 -
                    Mileage: 48664 km
                    Date: 2015.07.17
                    Time: 02:10:45
                    Temperature: 81.0°C
                    Temperature: 50.0°C
                    Absolute Pres.: 1010.0 mbar
001384 - Cruise Control Switch (E45)
               P0568 - 000 - Implausible Signal - Intermittent
                    Mileage: 48664 km
                    Date: 2015.07.17
                    Time: 03:08:09
                    Temperature: 63.0°C
                    Temperature: 45.0°C
Readiness: 1010 0101
   Part No SW: 09G 927 750 LH    HW: 09G 927 750 LH
   Component: AQ 250 6F           2251
   Revision: 00H97000    Serial number:
   Coding: 0000840
   VCID: 0201F1925DE00E2FEF-8056
   Part No SW: 1K0 907 379 BK    HW: 1K0 907 379 BK
   Revision: 00H31001
   Coding: C54BC0F5492608FEA30E03EC921D1061A61000
   VCID: 7CFD8F6AFF0478DFA5-8028
Address 08: Auto HVAC (J301)       Labels: None
   Part No SW: 561 907 426 A    HW: 561 907 426 A
   Component: AC Manuell    H02 0101
   Revision: 00001K07
   Coding: 0010001002
   ASAM Dataset: EV_ACManuaElectGen2BHTC 001002
   ROD: EV_ACManuaElectGen2BHTC_VW36.rod
   VCID: 1933B6FE1876ADF71E-804C
   Part No SW: 5K0 937 085 S    HW: 5K0 937 085 S
   Component: BCM PQ35 B+   021 0068
   Revision: BH021001
   Coding: 6F200E18902B08D408800001160004480071008640801D60648060000C70
   VCID: 438F3496C27AC727A4-8016
                    Fault Status: 00101010
                    Reset counter: 218
                    Mileage: 48664 km
                    Date: 2015.07.17
                    Time: 04:05:58
                    Voltage: 14.05 V
   Part No SW: 5C0 959 655 AE    HW: 5C0 959 655 AE
   Component: AirbagVW10G   014 0851
   Serial number: 003MWM02SGJF
   Coding: 00005033
   ROD: EV_AirbaVW10SMEVW360_SE36.rod
   VCID: 75EB9A4ED42E2997DA-8020
   Serial number: 6940000Y130000TWJP0X
   Coding: 303044
   Serial number: 3572MSME630B217AZZZX
   Serial number: 3582MSME020A217AZZZQ
   Serial number: 3516KSME5C5D2C23ZZZ0
   Serial number: 3526KSME0F146E23ZZZZ
   Serial number: 3556LSME36126D21ZZZS
   Serial number: 3566LSME25276721ZZZR
   Part No SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
   Component: LENKS.MODUL   016 0162
   Revision: --X01---    Serial number: 20150313200567
   Coding: 7982A00000
   Shop #: WSC 01286 386 08256
   VCID: 0201F19295E00E2FEF-8056
   Subsystem 1 - Part No SW: 561 959 537     HW: 561 959 537
   Component: E221__MFL-YVJ  H07 0022
   Serial number: 00000000000000881159
   Coding: 620000
226827 - Turn Signal Switch
          B1144 13 [008] - Open Circuit
                    Reset counter: 217
                    Mileage: 48664 km
                    Date: 2015.07.17
                    Time: 03:08:46
226839 - Turn Signal Switch
          B1144 11 [008] - Short to Ground
                    Reset counter: 217
                    Mileage: 48664 km
                    Date: 2015.07.17
                    Time: 03:08:45
229127 - Cruise Control Switch
          B1154 11 [009] - Short to Ground
                    Reset counter: 177
                    Mileage: 48664 km
                    Date: 2015.07.17
                    Time: 03:06:28
229147 - Cruise Control Switch
          B1154 13 [009] - Open Circuit
                    Reset counter: 177
                    Mileage: 48664 km
                    Date: 2015.07.17
                    Time: 03:06:28
   Part No SW: 561 920 960 C    HW: 561 920 960 C
   Component: KOMBI         H06 0705
   Coding: 230E01
   Part No SW: 7N0 907 530 AH    HW: 7N0 907 530 AH
   Component: J533  Gateway H50 1634
   Revision:   H50       Serial number: 17051303290218
   Coding: 461000
   VCID: 76E99D42C128228FD3-8022
   Component: IMMO          H06 0705
   VCID: 6AD1B9328D90F66F47-803E
   Component: SG EXT.PLAYER H19 0550
   Revision: A1001003    Serial number: 7664696027
   Coding: 010100
   VCID: 2A5179324510366F87-807E
   Component: TUER-SG FT    002 0525
   Revision: 13110009    Serial number: 0006668839
   Coding: 0404D5
   ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 5BBFECF652CA9FE7CC-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811 B    HW: 561 959 811 B
   Component: J388__TSG_HL  006 5470
   Serial number: 14102630130508065430
   Coding: 800000
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AH
   Component: EZE_2         H50 1634
   Coding: 00000008
   VCID: 6FE7A826BE72134710-803A
   Subsystem 1 - Part No SW: 561 919 204 B    HW: 561 919 204 B
   Component: Analoguhr  008 0005
   Component: TUER-SG BT    002 0525
   Revision: 15110009    Serial number: 0006670831
   Coding: 0404D4
   ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 5CBDEFEA57C498DFC5-8008
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812 B    HW: 561 959 812 B
   Component: J389__TSG_HR  006 5470
   Serial number: 14102631130506175600
   Coding: 800000
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 1K0 035 164 F    HW: 1K0 035 164 F
   Component: LOW NAR SDARS H03 0005
   Revision: -----07S    Serial number: VWZ4Z6N3574059
   Coding: 0100040002000B
   VCID: 254B8A0E2C0E1917AA-8070
                    Reset counter: 177
                    Mileage: 48664 km
                    Date: 2015.07.17
                    Time: 03:05:22
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Revision: 1B001001    Serial number: 00007664482586
   Coding: 0A10040000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA.rod
   VCID: 3A714972BDB086EFF7-806E
End-------------------------(Elapsed Time: 03:05)--------------------------
I don't see faults for security.........or CP.
What about the faults at hand in 0x16 & 0x09 .......
Why do you think you need a login?
kpac
C?ID=24877
The fault is not for the vehicle security system. It is for the fault with the Cruise Control System which is due to the new Clock Spring/Steering Column module which is not coded for the correct vehicle installation. Looking at the long code data there is an option for "Cruise Control controlled via Turn Signal Lever".
The Cruise Control does not operate and the body shop has already replaced the Turn Signal Switch Assy. prior to delivering the vehicle to me.
Use coding helper if application available, get old module install and get coding, or SVM at dealer.
kpac
C?ID=24877
I have already used the coding helper. That is how I determined that the coding needs to be changed for this installation. After I selected the coding changes and clicked "Do It" the box displays: "Coding rejected. Error 31: Request out of range". I believe that the reason for this rejection is because I have not been able to log-in to Security Access without a valid Access Code. When I coded the Air Bag Module a valid Security Access Code was displayed in a pop-up box, but there is NO pop-up box in the Steering Column Module. Do you know of a valid Access Code for this module?
Maybe contact paid tech support in the AM at RT.
Have you verified the part # is correct for the attributes of PR-codes?
"Error 31: Request out of range" is not generally indicative of needing a security access code. IMO, something else is wrong here, but I'm not exactly sure what.
rlarsen
Copenhagen, Denmark
C?ID=78998
Correct - you get this popup error if the control unit doesn't support the operation - because the unit need to have another firmware or just need to be newer. Normally the last index of the units part number tells you which unit you have, and what's supports of functionality.
Dana
Western PA, USA
Providing PartsLink24 is correct that vehicle should have been born with HW# 5K0 953 569 H. The complete Auto-Scan prior to repairs would include both the SW and HW numbers in addition to the original coding so it couldn't hurt to plug the old one in at some point if you can't get it to accept reasonable coding.
5K0 953 569 H (assuming that's correct) does supersede to 5K0 953 569 AL so I would try to paste this into the new coding: 098A140000
If 098A140000 is accepted make sure all functions (horn, turn signals, high beam, CCS, etc) work and test drive it to see if the ABS/ESP is happy.
If 098A140000 is rejected I would reinstall (or plug in) the old controller to rule out incorrect coding in addition to the incorrect new part.​
Edit: I originally missed the fact that this car does not have a electromechanical steering rack (#44) so I edited my original suggestion from 088A140000 -to- the current version of 098A140000
kpac
C?ID=24877
I have verified with the VW dealership the VIN to Clock Spring/Module part number to be correct which is the same as shown in the auto scan. The dealership tells me that there is no other index numbers for this part. When I checked ElsaWin for replacement instructions of the Clock Spring/Module (Steering Column Switch Module) it states that: "If a new steering column electronics control unit - J527- is installed, it muse be coded". I believe that the faults for the Cruise Control Switch are due to the new module not yet coded to this vehicle. Before I send this vehicle to the dealership I wanted to code the module myself which is why I am requesting the Security Access code. Please note that last year I had a different 2013 VW in which the Clock Spring/Module was also replaced and since I couldn't code that vehicle either I sent it to the dealership for programming. After the dealership completed the programing all of the fault DTCs were resolved. Is there any available Security Access Code for this module?
rlarsen
Copenhagen, Denmark
C?ID=78998
If you do a Controller Channels Map, how many channels have the "Security Access" error ??
The "Error 31: Request out of range" has nothing to do with a missing login!
NEtech
C?ID=56995
Have you double checked assembly and connectors ?
kpac
C?ID=24877
Dana thanks for your suggestion. After making the coding changes there are NO Steering Module/Cruise Control faults, however I do have a new code which I did not have before in the Engine controller: "050210 - Implausible Data Received from Body Control Module (Central Electric)" Is it likely due to the coding changes made within the Steering Module which might not yet be correct for this vehicle? I have attached another auto scan for you to view.
Monday,20,July,2015,14:02:08:61215
   Coding: 0000075
               U0422 - 000 -
                    Mileage: 48664 km
                    Date: 2015.07.20
                    Time: 21:41:07
                    RPM: 789 /min
                    Load: 21.6 %
                    Temperature: 80.0°C
                    Temperature: 39.0°C
               P1643 - 000 -
                    Mileage: 48664 km
                    Date: 2015.07.20
                    Time: 21:41:07
                    RPM: 789 /min
                    Load: 21.6 %
                    Temperature: 80.0°C
                    Temperature: 39.0°C
Readiness: 1110 0101
   Coding: 0000840
   Revision: 00H31001
   Revision: 00001K07
   Coding: 0010001002
   Revision: BH021001
   Coding: 00005033
   Coding: 303044
   Coding: 098A140000
   Coding: 620000
   Coding: 230E01
   Coding: 230E01
   Coding: 461000
   Coding: 010100
   Coding: 0404D5
   Slave Driver:
   Coding: 800000
   Coding: 00000008
   Coding: 0404D4
   Slave Passenger:
   Coding: 800000
                    Reset counter: 180
                    Mileage: 48664 km
                    Date: 2015.07.20
                    Time: 21:56:27
   ROD: EV_UHVNA.rod
End-------------------------(Elapsed Time: 02:57)--------------------------
Dana
Western PA, USA
If that vehicle happens to have one of those goofy steering wheels with buttons only on one side, instead of the normal Mk6 style as shown here, try this in the #16 module: 498A140000
kpac
C?ID=24877
Dana, YES this vehicle is one of those "goofy" ones with the buttons on one side only. BUT, after I turned OFF the Ignition Switch to take a phone call and several minutes later I returned to this vehicle to continue with diagnostics. I cleared the Engine Module faults again and they did NOT return. I drove the Vehicle to verify proper operation of the Cruise Control and NO other Instrument Cluster MILs were illuminated. I then ran another auto scan to verify NO stored fault DTCs other than the stupid radio which I tend to ignore because I see this in many VWs. Thanks very much for your help. << P.S. >>Could you tell me were you retrieved the coding information that you provided me for this repair?
Monday,20,July,2015,14:39:40:61215
VIN: 1VWAH7A35DC144384   Mileage: 48670km-30242miles
   Coding: 0000075
Readiness: 0000 0100
   Coding: 0000840
   Revision: 00H31001
   Revision: 00001K07
   Coding: 0010001002
   Revision: BH021001
   Coding: 00005033
   Coding: 303044
   Coding: 098A140000
   Coding: 620000
   Coding: 230E01
   Coding: 461000
   Coding: 010100
   Coding: 0404D5
   Slave Driver:
   Coding: 800000
   Coding: 00000008
   Coding: 0404D4
   Slave Passenger:
   Coding: 800000
                    Reset counter: 180
                    Mileage: 48664 km
                    Date: 2015.07.20
                    Time: 21:56:27
   ROD: EV_UHVNA.rod
End-------------------------(Elapsed Time: 03:02)--------------------------
Dana
Western PA, USA
Thanks for the feedback. You might want to enable that "Board Computer controlled via Wiper Lever" bit to prevent a customer concern with the MFA functions even though the car is fault free at the moment.
The coding info I have was from the (older) 15.2.0 Data Version so you would have the latest greatest in Beta 15.6.1 when using the Long Coding Helper. Don't feel bad though :) I missed the lack of a #44-Steerign Assist controller in my first scroll through the scan and then missed the fact that some NMS Passat models used that goofy Jetta wheel. It took me 3 attempts to get it right!
kpac
C?ID=24877
No security code is needed to code the module.
Jack, you are right regarding no security code is needed to code this module. I was simply applying my own ignorance regarding the modules which I have successfully coded that did require a Security Access code. The missing information that I needed was provided by Dana and I know others will benefit from this thread. Thank you for your expertise and replies towards helping me understand that not all Coding requires Security Access codes.
Most modules do not need a security code and many modules will not allow for a coding if DTC's are present and some will.
The main thing to always be sure is to have a tester #, WSC #, and Importer # assigned to the tester, because some modules won't allow a coding or adaption if a tester isn't proper for config.
