i have this throttle code intermittent
and i dont find the problem
the customer complains that the vehicle:
extended crank hot or cold same
buck at idle (stop)
epc light come on/off in the cluster
all the symptoms of intermittent way
here is the last repair:
the tba relearning was made
a new throttle body
a new spark plug
a new oxygen sensor 1st
the tsb for the throttle body connector was replace
a new turbo
new breather valve
new valve cover
new exhaust valve on cylinder #3
and cam follower is new
I look for ideas please
buck at idle (stop)
a new throttle body
a new spark plug
a new turbo
new breather valve
new valve cover
Monday,13,July,2015,08:12:46:24102
VCDS Version: 14.10.2.0
Data version: 20150311
VIN: WVWGV71K97W035216 License Plate:
Mileage: 186730km-116028mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 1C 25 42 44 46 52 55 56 62 72
VIN: WVWGV71K97W035216 Mileage: 186730km-116028miles
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 1K0 907 115 H HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0040
Revision: 5BH14--- Serial number: VWZ7Z0F8016501
Coding: 0403010A18070160
Shop #: WSC 94759 999 83929
VCID: 2B5531228A5B1679EBD-807E
6 Faults Found:
008598 - Oxygen (Lambda) Sensor B1 S1
P2196 - 004 - Signal too High (Rich) - Intermittent
Mileage: 186580 km
Time: 03:47:29
RPM: 752 /min
Load: 18.0 %
Temperature: 81.0°C
Temperature: 30.0°C
Absolute Pres.: 970.0 mbar
Voltage: 13.970 V
000289 - Throttle Position Sensor (G69)
P0121 - 008 - Implausible Signal - Intermittent
Mileage: 186581 km
Time: 03:53:45
RPM: 2352 /min
Load: 28.2 %
Speed: 63.0 km/h
Temperature: 94.0°C
Temperature: 46.0°C
Absolute Pres.: 980.0 mbar
Voltage: 13.843 V
005497 - Throttle Actuator (J338)
P1579 - 001 - Adaptation Not Started - Intermittent
Fault Status: 00100001
Mileage: 186668 km
Time: 01:55:58
RPM: 257 /min
Load: 66.2 %
Temperature: 91.0°C
Temperature: 30.0°C
Absolute Pres.: 960.0 mbar
Voltage: 10.795 V
005445 - Throttle Valve Controller
P1545 - 002 - Malfunction
Fault Status: 01100010
Mileage: 186668 km
Time: 01:56:01
Temperature: 87.0°C
Temperature: 45.0°C
Voltage: 11.938 V
P1545 - 008 - Malfunction - Intermittent
Mileage: 186672 km
Time: 10:27:33
RPM: 765 /min
Load: 60.0 %
Temperature: 76.0°C
Temperature: 27.0°C
Voltage: 12.192 V
005465 - Throttle Body (J338)
P1559 - 008 - Fault in basic settings - Intermittent
Mileage: 186718 km
RPM: 265 /min
Load: 69.8 %
Temperature: 18.0°C
Temperature: 18.0°C
Voltage: 10.795 V
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Revision: 00H11001
Coding: 0021122
Shop #: WSC 01279 785 00200
VCID: 73E5E94212EB0EB963D-8026
013 - Check DTC Memory
Part No: 1K0 820 047 FJ
Component: Climatic PQ35 120 0606
VCID: 71E9E34A68F73CA9911-8024
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 Q HW: 3C0 937 049 Q
Component: Bordnetz-SG H46 1501
Revision: 00H46000 Serial number: 00000005836611
Coding: 178F8F214004150000140000001400000028770B5C0000
Shop #: WSC 94848 999 53423
VCID: 377D1D524613A2999F5-8062
Component: Wischer 200606 020 0501
Coding: 00046997
Shop #: WSC 94848
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 5M AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D0524WX
Coding: 0013645
Shop #: WSC 01269 785 00200
VCID: 6CD7F23E4FD5D141A27-8039
Subsystem 1 - Serial number: 6332MSME100677170
Subsystem 2 - Serial number: 6342MSME10073117Z
Subsystem 3 - Serial number: 6352QSME103B33097
Subsystem 4 - Serial number: 6362QSME100227493
Subsystem 5 - Serial number: 63727SME0A4856687
Subsystem 6 - Serial number: 63827SME0A5C612C9
Part No SW: 1K0 953 549 AJ HW: 1K0 953 549 AJ
Component: J0527 034 0070
Coding: 0002022
VCID: 7AFBC46635817FF120B-802F
Component: E0221 002 0010
Part No SW: 1K6 920 873 A HW: 1K6 920 873 A
Component: KOMBIINSTRUMENT VDD 1610
Revision: V0003000 Serial number: VWZ7Z0F8016501
Coding: 0007303
VCID: 306F264EA37D75A1DEF-8065
Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 31001066240D7A
Coding: 7D3F03400F000002
VCID: 2C57323E8F551141E27-8079
Part No SW: 1K6 919 879 HW: 1K6 919 879
Component: Kompass 001 0002
Revision: 00001000 Serial number: 1225223T1EGT02
VCID: 7DF1CF7A24AF48C9059-8028
Component: IMMO VDD 1610
Shop #: WSC 94743 999 103300
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 005 0971
Coding: 0001205
VCID: 387F1E6E4B0DADE196F-806D
00109 - Left Mirror Turn Signal Lamp (L131)
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.074 H07 1806
Shop #: WSC 00000 028 00001
VCID: 34672A5E57654981BA7-8061
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CA HW: 1K0 959 433 CA
Component: KSG PQ35 G2 020 0202
Revision: 00020000 Serial number: 00000000000000
Coding: 139006885103281B0904058FB0080F0488FC00
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0001204
VCID: 39791B6A7007B4E9691-806C
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
VCID: 74E7EA5E17E509817A7-8021
Part No SW: 1K0 035 180 H HW: 1K0 035 180 H
Component: Radio PM6 165 0035
Revision: 00165000 Serial number: VWZ5Z7F2090519
Coding: 0040401
VCID: 2541C71AECBF20093D9-8070
Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
Component: Tuer-SG 005 0913
Coding: 0000192
Shop #: WSC 01279 785 1012552
01813 - Supply Voltage for Door Controller; Rear Left (J388)
002 - Lower Limit Exceeded
Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
Coding: 0000192
Shop #: WSC 01279 785 1012551
00123 - Outside Warning Light/Door exit Light; Rear Right
00103 - Rear Right Interior Locking Button (E311)
End-------------------------(Elapsed Time: 01:40)--------------------------
