2004 Audi A8 Energy Management problems?? Please help
BostonSlaya
Rhode Island, USA
C?ID=240768
I have a 2004 Audi A8 that is giving me some new power problems. I replaced my battery with a new one from Audi dealer everything was fine up until a few weeks ago.
The first thing that I noticed was that my car has had a lack of power when starting and taking off.
I then started noticing that my alarm wouldn't beep anymore so I decided to look at my MMI screen and look at the status of my Battery. Boom, I saw that my battery indicator in the MMI was showing one bar from being at zero, I did notice some starting problems as well but didn't think twice about it. I then left the screen up with the battery indicator on when I drove and not long after the bar would go up to 100%.. After the car sitting over night and I would start my car it would be close to zero again.. I then took the car to Advance Auto and had the Battery, Alternator and starter checked. All came back as good?? Then today I washed my car and then started it put it into the garage for a quick detail then wen't to start the car and nothing. no clicking sound nothing, no radio,: or anything. I tried again and then my key would not come out of the ignition??? Weird!! I then let it sit with everything off for a few until the key finally came out so I could get into my trunk.
I then hooked my battery charger up and let it charge for awhile and the car started. I left it charging until the battery indicator in the MMI showed 100%. Then I ran an AutoScan and got a huge amount off errors. Below is a full AutoScan of my car. I have already cleared the codes and reran fine but there has to be a reason for all this if everything is dead overnight.
could this be the battery regulator module??? Thanks in advance for all the help..
Sunday,03,May,2015,20:50:51:14758
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
VIN: WAUML44E74N017518   License Plate:
Mileage: 77500km-48156mi   Repair Order:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 25 28 34 36 37 38
          42 46 47 4F 52 53 55 56 61 62 65 72 76 77
VIN: WAUML44E74N017518   Mileage: 77500km-48156miles
06-Seat Mem. Pass -- Status: Cannot be reached 1100
Address 01: Engine        Labels: 077-910-560-BFM.lbl
   Part No SW: 4E0 910 560 A    HW: 4E0 907 560
   Component: 4.2L V8/5V      G   0070
   Revision: 00000000    Serial number: AUX3Z0CD531019
   Coding: 0007773
   Shop #: WSC 02313 785 00200
   VCID: 1F4DDD45CE847AD9775-804A
17981 - Left Engine Mount Solenoid Valve (N144)
            P1573 - 004 - Open Circuit
18282 - Valve for Torque Support Mount
            P1874 - 001 - Short to Plus
16804 - Catalyst System; Bank 1
            P0420 - 002 - Efficiency Below Threshold - Intermittent - MIL ON
16814 - Catalyst System; Bank 2
            P0430 - 002 - Efficiency Below Threshold - MIL ON
   Part No SW: 4E0 910 156 E    HW: 09E 927 156 A
   Component: AG6 09E 4,2L5V USA  0110
   Revision: 00000001    Serial number:        0027237
   VCID: 2447D2A9E7E259012A7-8071
Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
   Part No SW: 4E0 910 517 B    HW: 4E0 614 517 BC
   Component: ESP 5.7 allrad  H46 0510
   Coding: 0007597
   Shop #: WSC 23435 000 00000
   VCID: 224BD4B1FDF6573158B-8077
Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
   Part No SW: 4E0 910 131     HW: 4E0 909 131 A
   Component:     FBS AUDID3  H03 0140
   Revision: 01403903    Serial number: AUX3Z0CD531019
   Coding: 0263168
   Shop #: WSC 02311 785 00200
   VCID: 58BFB659EB2ACDE176F-800D
   Subsystem 1 - Part No: 4E0 905 852 C
   Component: ELV                 1734
                    Reset counter: 176
                    Mileage: 76832 km
                    Date: 2015.04.20
                    Time: 19:44:18
Address 06: Seat Mem. Pass
Address 07: Control Head        Labels: 4E0-910-7xx-07.lbl
   Part No SW: 4E0 910 729 J    HW: 4E0 035 729
   Component: Interfacebox    H43 0600
   Revision: 00000000    Serial number: 346IP047514325
   Coding: 0000103
   VCID: 2F6D2D85BE24EA59C75-807A
   Subsystem 1 - Part No: 4E0 910 611
   Component: E0380 BedienteilH01 0050
   Subsystem 2 - Serial number: 00000000097794
   Subsystem 3 - Serial number: 0113.11.130000000100010015ÿ
   Subsystem 4 - Serial number: 010015ÿ
                    Reset counter: 113
                    Mileage: 76837 km
                    Date: 2015.04.21
                    Time: 10:10:05
00532 - Supply Voltage B+
                    Reset counter: 176
                    Mileage: 77503 km
                    Date: 2015.05.03
                    Time: 19:49:21
   Part No SW: 4E0 910 043     HW: 4E0 820 043 B
   Component: KLIMAAUTOMAT    016 0240
   Revision: 00000022    Serial number: 00000000033347
   Coding: 1151313
   VCID: 5ABBAC519526DFF140B-800F
   Subsystem 1 - Part No: 4E0 910 772 A
   Component: Sitzluefter  FS H02  010
   Subsystem 2 - Part No: 4E0 910 772 A
   Component: Sitzluefter BFS H02  010
   Subsystem 3 - Serial number: 898053000
   Subsystem 4 - Serial number: HO15122003065A000000000168ÿ†89
   Subsystem 5 - Serial number: 000168ÿ†898053000      000-SHO
   Subsystem 6 - Serial number:     000-SHO18122003065A00000000
   Subsystem 7 - Serial number: 65A000000000072ÿ
00066 - Rear Right Footwell Heater (Z43)
                    Reset counter: 118
                    Mileage: 76784 km
                    Date: 2015.04.20
                    Time: 09:11:51
                    Voltage: 13.50 V
Address 09: Cent. Elect.        Labels: 4E0-910-279.lbl
   Part No SW: 4E0 910 279 E    HW: 4E0 907 279 E
   Component: ILM Fahrer      H11 0100
   Coding: 0111113
   VCID: 2A5B3C9185C68F7110B-807F
   Subsystem 1 - Part No: 4E1 910 113
   Component: Wischer WWS D3  H30 0320
   Coding: 00000030
   Shop #: WSC 02313
                    Reset counter: 176
                    Mileage: 77503 km
                    Date: 2015.05.03
                    Time: 19:52:09
   Part No SW: 4E0 910 111     HW: 4E0 035 111
   Component: CD-Changer      H43 0220
   Revision: 00000501    Serial number: AUZ5ZBD1033967
   VCID: 56A3B861E13EFB91643-8003
Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
   Part No: 4E0 910 593 B
   VCID: 2643C8A191DEAB11343-FFFF
Address 15: Airbags        Labels: 4E0-910-655-84.lbl
   Part No SW: 4E0 910 655 A    HW: 4E0 959 655 E
   Component: Airbag 8.4E+    H10 0920
   Coding: 0530707
Address 16: Steering wheel        Labels: 4E0-910-549.lbl
   Part No SW: 4E0 910 549     HW: 4E0 953 549 A
   Coding: 0012241
   VCID: 65C18FADAC586009FD9-8030
   Component: Lenkradmodul    H04 0080
Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
   Part No SW: 4E0 910 900     HW: 4E0 920 950 B
   Component: KOMBIINSTR. VDO H44 0090
   Revision: D15         Serial number: AUDID3CD006664
   Coding: 0000232
   Shop #: WSC 65537 000 00032
   VCID: 5CB7AA499F1221C1527-8009
                    Reset counter: 176
                    Mileage: 77503 km
                    Date: 2015.05.03
                    Time: 19:48:22
Address 19: CAN Gateway        Labels: 4E0-910-468.lbl
   Part No SW: 4E0 910 468 A    HW: 4E0 907 468 C
   Component: Gateway         H07 0030
   Revision: 07          Serial number: 0200503C0111AE
   Coding: FCFE7FDD1B3904
   Shop #: WSC 07228 444 53694
   VCID: 2643C8A191DEAB11343-8073
00461 - Control Module for Seat Memory; Passenger (J521)
                    Fault Frequency: 40
                    Reset counter: 136
                    Mileage: 76784 km
                    Date: 2015.04.20
                    Time: 09:40:01
                    Fault Frequency: 39
                    Reset counter: 136
                    Mileage: 76784 km
                    Date: 2015.04.20
                    Time: 09:41:28
Address 25: Immobilizer        Labels: 4E0-910-131.lbl
   Coding: 0263168
   Component: ELV                 1734
   4E0905852C  ELV                 1734
                    Reset counter: 176
                    Mileage: 76832 km
                    Date: 2015.04.20
                    Time: 19:44:18
   Part No SW: 4E0 910 158     HW: 4E0 919 158 A
   Component: KLIMA-STG. FOND 015 0210
   Revision: 00000014    Serial number: 00000000013996
   Coding: 0000000
   VCID: 61C99BBDB8700C29011-8034
01863 - Air Outlet Motor; Rear Left (V218)
01864 - Air Outlet Motor; Rear Right (V219)
Address 34: Level Control        Labels: 4E0-910-553.lbl
   Part No SW: 4E0 910 553 E    HW: 4E0 907 553 E
   Component: LUFTFDR.-CDC    H05 4290
   Coding: 0015510
   Shop #: WSC 22145 444 54027
   VCID: 2541CFADECD8A0093D9-8070
                    Fault Status: 11101100
                    Fault Frequency: 7
                    Reset counter: 136
                    Reset counter: 164
                    Mileage: 76818 km
                    Date: 2015.04.20
                    Time: 17:20:42
01598 - Drive Battery Voltage
                    Reset counter: 176
                    Mileage: 77503 km
                    Date: 2015.05.03
                    Time: 19:52:10
01398 - Signal Conductor for Central Locking; Doors Open
                    Reset counter: 176
                    Mileage: 77503 km
                    Date: 2015.05.03
                    Time: 19:52:10
   VCID: 55A1BF6DBC38F0896D9-FFFF
No Faults Found
   Part No SW: 4E0 910 887 K    HW: 4E0 919 887 C
   Component: MNS US          H42 0570
   Revision: 00000000    Serial number: 355LL037514310
   VCID: 35611FED5C78D0898D9-8060
00862 - Antenna for GPS Navigation (R50/R52)
                    Fault Status: 00101011
                    Fault Frequency: 35
                    Reset counter: 176
                    Mileage: 76873 km
                    Date: 2015.04.21
                    Time: 14:42:01
                    Reset counter: 176
                    Mileage: 77503 km
                    Date: 2015.05.03
                    Time: 19:51:43
Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
   Part No SW: 4E0 910 135 A    HW: 4E0 907 135
   Component: Dachknoten D3   H01 0090
   Serial number: 00000332500063
   Coding: 0004021
   VCID: 1D31E74DC48868C9659-8048
02138 - Control Circuit for Front Right Interior Lights
                    Reset counter: 112
                    Mileage: 76784 km
                    Date: 2015.04.20
                    Time: 09:40:00
00211 - Control Circuit for Rear Illumination Lights
                    Reset counter: 112
                    Mileage: 76784 km
                    Date: 2015.04.20
                    Time: 09:46:00
00213 - Control Circuit for Reading Lights Front Right
                    Reset counter: 127
                    Mileage: 77260 km
                    Date: 2015.04.29
                    Time: 17:54:00
                    Reset counter: 176
                    Mileage: 77500 km
                    Date: 2015.05.03
                    Time: 19:50:00
Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
   Part No SW: 4E1 910 802     HW: 4E1 959 801
   Component: Türsteuer.FS BRM005 0110
   Coding: 0028196
   VCID: 5EB3A041890E33D13C3-800B
                    Reset counter: 112
                    Mileage: 76784 km
                    Date: 2015.04.20
                    Time: 10:29:16
02111 - Motor for Window Regulator
                    Reset counter: 176
                    Mileage: 77488 km
                    Date: 2015.05.03
                    Time: 19:49:16
                    Reset counter: 176
                    Mileage: 77488 km
                    Date: 2015.05.03
                    Time: 19:49:16
Address 46: Central Conv.        Labels: 4E0-910-289.lbl
   Part No SW: 4E0 910 289 A    HW: 4E0 907 289
   Component: Komfortgeraet   H03 0030
   Revision: 00300003    Serial number:  W040312110112
   Coding: 0065086
   VCID: 275DC5A596D4B2190F5-8072
   Component: Heckdeckel      H06 0060
   Component: Neigungssensor  H02 0020
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Fault Frequency: 138
                    Reset counter: 136
                    Mileage: 75669 km
                    Date: 2015.03.30
                    Time: 12:35:18
                    Reset counter: 174
                    Mileage: 77157 km
                    Date: 2015.04.27
                    Time: 14:40:50
                    Reset counter: 136
                    Mileage: 193858 km
                    Date: 2011.08.15
                    Time: 01:50:33
01503 - Bulb for 3rd Brake Light (M25)
                    Fault Status: 00101001
                    Reset counter: 176
                    Mileage: 77503 km
                    Date: 2015.05.03
                    Time: 19:53:57
Address 47: Sound System        Labels: 4E0-910-223.lbl
   Part No SW: 4E0 910 223 H    HW: 4E0 035 223 B
   Component: DSP-High D3/AUX H13 0370
   Revision: Dev_D01     Serial number: 00000000655399
   Coding: 0000018
Address 4F: Centr. Electr. II        Labels: None
   Part No SW: 4E0 910 280 A    HW: 4E0 907 280 A
   Component: ILM Beifahrer   H08 0020
   Revision:             Serial number: 00000000030051
   Coding: 0010111
   VCID: 1E33E041C98E73D17C3-804B
   Subsystem 1 - Serial number: VK4978T078WE
                    Reset counter: 167
                    Mileage: 77260 km
                    Date: 2015.04.29
                    Time: 17:49:00
                    Reset counter: 176
                    Mileage: 77500 km
                    Date: 2015.05.03
                    Time: 19:51:00
Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
   Part No SW: 4E1 910 802     HW: 4E1 959 802
   Component: Türsteuer.BF BRM005 0110
   Coding: 0028196
                    Reset counter: 112
                    Mileage: 76784 km
                    Date: 2015.04.20
                    Time: 10:29:16
01482 - Motors for Central Locking
                    Fault Status: 00100110
                    Reset counter: 167
                    Mileage: 77264 km
                    Date: 2015.04.29
                    Time: 18:33:32
                    Reset counter: 172
                    Mileage: 77344 km
                    Date: 2015.05.01
                    Time: 15:39:30
                    Reset counter: 176
                    Mileage: 77488 km
                    Date: 2015.05.03
                    Time: 19:49:14
                    Reset counter: 176
                    Mileage: 77488 km
                    Date: 2015.05.03
                    Time: 19:49:14
Address 53: Parking Brake        Labels: 4E0-910-801.clb
   Part No SW: 4E0 910 801 A    HW: 4E0 907 801
   Component: EPB  AV1C1010   H01 1010
   Revision: AV1C1010
   Coding: 0000532
   Shop #: WSC 23435 444 58960
02596 - Rear Brake Pads Worn
                    Fault Status: 01111000
                    Reset counter: 46
                    Voltage: 6.21 V
                    Count: 61
Address 55: Headlight Range        Labels: 4E0-910-357.lbl
   Part No SW: 4E0 910 357     HW: 4E0 907 357
   Component: Pre-AFS         H01 0040
   VCID: 62CB94B1BD76173118B-8037
                    Fault Status: 11100101
                    Reset counter: 112
                    Mileage: 76792 km
                    Date: 2015.04.20
                    Time: 09:40:00
01310 - Level Control System Control Module (J197)
                    Fault Status: 00101101
                    Fault Frequency: 0
                    Reset counter: 176
                    Mileage: 76792 km
                    Date: 2015.04.20
                    Time: 09:40:01
   Part No SW: 4E0 910 541 B    HW: 4E0 035 541
   Component: TUNER EU/US/RDW H41 0220
   Revision: 00000000    Serial number: 304CE047583230
   Shop #: WSC 06802 176 59446
Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
   Part No SW: 4E0 910 181 B    HW: 4E0 915 181
   Component: ENERGIEMANAGER  H02 0240
   Revision: 00000000    Serial number: 00000001900564
   Subsystem 1 - Part No: 000 915 105 DL
   Component: von VA0  341010A32K
   Coding: 303030393135313035444C5641303334313031304133324B
   Shop #: WSC 22186 444 58975
            000 -  -  - Intermittent
                    Fault Frequency: 59
                    Mileage: 76815 km
                    Date: 2015.04.20
                    Time: 14:45:54
02276 - Quiescent Current Stage 5
                    Fault Frequency: 59
                    Mileage: 76815 km
                    Date: 2015.04.20
                    Time: 14:46:04
02274 - Quiescent Current Stage 3
                    Fault Frequency: 59
                    Mileage: 76815 km
                    Date: 2015.04.20
                    Time: 14:46:14
                    Fault Frequency: 57
                    Mileage: 76815 km
                    Date: 2015.04.20
                    Time: 14:46:24
Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802 A    HW: 4E0 959 801 C
   Component: Türsteuer.HL BRM003 0100
   Coding: 0032364
                    Fault Frequency: 0
                    Reset counter: 176
                    Mileage: 77488 km
                    Date: 2015.05.03
                    Time: 19:49:14
                    Fault Frequency: 0
                    Reset counter: 176
                    Mileage: 77488 km
                    Date: 2015.05.03
                    Time: 19:49:14
Address 65: Tire Pressure        Labels: 4E0-910-273.lbl
   Part No SW: 4E0 910 273     HW: 4E0 907 273
   Component: Reifendruck 2   H01 0210
   Coding: 0212127
   Shop #: WSC 65762 132 574529
   VCID: 5FCD9D458E043AD9375-800A
6 Faults Found:
01467 - Front Left Tire Pressure Sensor (G222)
                    Fault Status: 11100100
                    Reset counter: 73
                    Mileage: 75476 km
                    Date: 2015.03.26
                    Time: 22:58:22
                    Voltage: 11.30 V
                    (no units): 46.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
01468 - Front Right Tire Pressure Sensor (G223)
                    Reset counter: 117
                    Mileage: 75476 km
                    Date: 2015.03.26
                    Time: 22:58:22
                    Voltage: 11.30 V
                    (no units): 49.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
01469 - Rear Left Tire Pressure Sensor (G224)
                    Reset counter: 73
                    Mileage: 75476 km
                    Date: 2015.03.26
                    Time: 22:58:22
                    Voltage: 11.30 V
                    (no units): 52.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
01470 - Rear Right Tire Pressure Sensor (G225)
                    Reset counter: 73
                    Mileage: 75476 km
                    Date: 2015.03.26
                    Time: 22:58:23
                    Voltage: 11.30 V
                    (no units): 55.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
01477 - System Switched Off
                    Fault Frequency: 253
                    Reset counter: 136
                    Mileage: 75819 km
                    Date: 2015.03.31
                    Time: 22:24:56
                    Temperature: 25.0°C
                    Error Code: 0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                    Reset counter: 70
                    Mileage: 75498 km
                    Date: 2015.03.27
                    Time: 09:26:31
                    Speed: 99.0 km/h
                    Temperature: 23.0°C
                    Error Code: 0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802     HW: 4E0 959 802 A
   Component: Türsteuer.HR BRM005 0110
   Coding: 0028196
   VCID: 5DB1A74D840828C9259-8008
                    Reset counter: 176
                    Mileage: 77488 km
                    Date: 2015.05.03
                    Time: 19:49:28
                    Reset counter: 176
                    Mileage: 77488 km
                    Date: 2015.05.03
                    Time: 19:49:34
Address 76: Park Assist        Labels: 4E0-910-283.lbl
   Part No SW: 4E0 910 283 A    HW: 4E0 919 283 B
   Component: Parkhilfe 8-Kan H11 0010
   Revision: --.--.--    Serial number: 00000335600021
   Coding: 0001208
   VCID: 2149DBBDF8F04C29411-8074
Address 77: Telephone
End-------------------------(Elapsed Time: 04:48)--------------------------
victor35ma
Los Angeles CA.
C?ID=242342
Hello, OK... from an Auto techno point of view... we have already run into this problems so many times that we considered it Normal on 10 years old AUDIs. Most of your DTC are software updates, and Battery drains.
For battery drain, here in CA there was a warranty recall for trunk replacements. the LH , HR automatic lead trunk hinge is not working properly. even though it is closed. the controller see it still open consuming power.
What I like to see here is the explanation from VCDS experts in checking this switches on the trunks. so I can learn how to use VCDS in this case.
about CAT(s) since both cats are having the same issue. this was very likely the criteria to check for software updates or TBS. we spent time in the past checking O2 Sensor already and at the end it was always software updates.
About this DTC 18282 - Valve for Torque Support Mount . this is a mix... Audi has told us to install a Plug. we stock it. it is amazing how often this is happening here in old Audis. they say this is not longer needed so they came up with a Plug with an internal resistor as a solution so that's what I remember about them form 2008.
regards
BostonSlaya
Rhode Island, USA
C?ID=240768
regards
Wow great feedback!!
Ok so I'll start with the trunk motor, the trunk was not closing all the way down and the motor wasn't string enough to open or close in it own. I ended up taking the motor out taking it apart and putting paste on the non magnetic side of the wheel to help it grab better I seen this in several videos and seemed to work for people. This did not work in my case, as a matter of fact I don't know if you have to install it in some special way but every way I tried to install it now the trunk won't go up and down all the way it's almost like it locks itself.
Also my passenger side trunk is higher and I cannot seem to get it closed all the way down no matter how I adjust it
CAN I JUST UNPLUG THE MOTOR? Would this help?
As for software update I would love to get this done but unfortunately my CD player doesn't read CDs and to replace this for just an update is so expensive!! When I update can I update to the newest one? Or do I have to do it in stages? (Wish I could borrow a CD player to do this lol)
DTC 18282 with this do you have a part number or something I could look up to buy online? Or get from the dealer?
Also sometimes I get a quick smell of gas when I start it could this be because the O2 sensors running to lean??
I want my power back to my car
I cannot thank you enough for the help I could also place pictures of anything if this helps? Thanks
Dana
Western PA, USA
I located TSB # 10-08-04 | TPI # 2010270/6 per the notes on the 18282 DTC Wiki page in the repair manual and the part number was: 4E0-971-067-A
You might be able to find the resistance specification in another forum and make one.
BostonSlaya
Rhode Island, USA
C?ID=240768
Thanks for the feedback Dana only one question it says 2005-2007 and I have a 2004. Does this make a difference? I'm going to order it anyways but what motor mount gets the plug? Both?
BostonSlaya
Rhode Island, USA
C?ID=240768
I purchased the wire harness for it I assume it plugs into the front motor mount let's see what happens.
BostonSlaya
Rhode Island, USA
C?ID=240768
Ok I have the wire harness now where do I plug it in? What motor mount? Do I need two of them because there is two mount DTC's?
I know where the fronts are but the valve for torque one where is this located? Thanks
BostonSlaya
Rhode Island, USA
C?ID=240768
New AutoSacan After installing the wire Harness into my Left Engine Mount Solenoid Valve (N144)
Thursday,07,May,2015,21:09:15:14758
Mileage: 77820km-48355mi   Repair Order:
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 25 28 34 36 37 38 42
VIN: WAUML44E74N017518   Mileage: 77820km-48355miles
   Coding: 0007773
Readiness: 0110 1101
   Coding: 0007597
   Coding: 0263168
   Coding: 0000103
   Coding: 1151313
                    Reset counter: 143
                    Mileage: 77821 km
                    Date: 2015.05.07
                    Time: 19:56:04
                    Voltage: 12.90 V
   Coding: 0111113
   Coding: 00000030
   Shop #: WSC 02313
   Part No SW: 4E0 910 593 B    HW: 4E0 035 593
   Component: SDAR
   Revision: 0000000    Serial number: AUZ4Z7E20
   Coding: 0530707
   Coding: 0012241
   Coding: 0000232
   Coding: 0000232
   Coding: 0000232
   Coding: FCFE7FCD1B2904
   Coding: 0263168
   XXXXXXXXXXX ELV                 XXXX
   Coding: 0000000
   Coding: 0015510
                    Reset counter: 143
                    Mileage: 77824 km
                    Date: 2003.10.08
                    Time: 00:41:24
No Faults Found
   Coding: 0004021
                    Reset counter: 143
                    Mileage: 77828 km
                    Date: 2003.10.08
                    Time: 00:47:00
   Coding: 0028196
                    Reset counter: 136
                    Mileage: 77488 km
                    Date: 2015.05.03
                    Time: 21:13:28
02110 - Window Regulator Switch
                    Reset counter: 177
                    Mileage: 77520 km
                    Date: 2015.05.04
                    Time: 11:55:28
   Coding: 0065086
                    Fault Frequency: 168
                    Reset counter: 143
                    Mileage: 75669 km
                    Date: 2015.03.30
                    Time: 12:35:18
                    Reset counter: 143
                    Mileage: 193858 km
                    Date: 2011.08.15
                    Time: 01:50:33
   Coding: 0000018
   Coding: 0010111
   Coding: 0028196
                    Reset counter: 136
                    Mileage: 77488 km
                    Date: 2015.05.03
                    Time: 21:13:28
                    Reset counter: 177
                    Mileage: 77552 km
                    Date: 2015.05.04
                    Time: 15:59:40
                    Reset counter: 181
                    Mileage: 77728 km
                    Date: 2015.05.06
                    Time: 17:19:40
   Revision: AV1C1010
   Coding: 0000532
                    Reset counter: 46
                    Voltage: 6.21 V
                    Count: 61
                    Reset counter: 143
                    Mileage: 77832 km
                    Date: 2003.10.08
                    Time: 00:41:29
                    Fault Status: 11101101
                    Reset counter: 143
                    Mileage: 77832 km
                    Date: 2003.10.08
                    Time: 00:41:29
   Coding: 0032364
   Coding: 0212127
6 Faults Found:
                    Reset counter: 136
                    Mileage: 77503 km
                    Date: 2015.05.03
                    Time: 20:57:19
                    Voltage: 11.10 V
                    (no units): 46.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                    Reset counter: 136
                    Mileage: 77503 km
                    Date: 2015.05.03
                    Time: 20:57:20
                    Voltage: 11.00 V
                    (no units): 49.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                    Reset counter: 136
                    Mileage: 77503 km
                    Date: 2015.05.03
                    Time: 20:57:20
                    Voltage: 11.10 V
                    (no units): 52.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                    Reset counter: 136
                    Mileage: 77503 km
                    Date: 2015.05.03
                    Time: 20:57:20
                    Voltage: 11.10 V
                    (no units): 55.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                    Fault Frequency: 39
                    Reset counter: 143
                    Mileage: 77503 km
                    Date: 2015.05.03
                    Time: 20:57:19
                    Temperature: 22.0°C
                    Error Code: 0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                    Reset counter: 137
                    Mileage: 77518 km
                    Date: 2015.05.04
                    Time: 11:50:34
                    Speed: 133.0 km/h
                    Temperature: 26.0°C
                    Error Code: 0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
   Coding: 0028196
   Coding: 0001208
End-------------------------(Elapsed Time: 03:32)--------------------------
This ended up clearing up the DTC code 17981- P1573.. Thanks!!! I assume I'm going to purchase another wire harness for the 18282-Valve for torque Support Mount P1874????
If so were is this mount located?? Thanks in advance.. For some weird reason the o2 Sensors are now not showing up?? Thanks again..
BostonSlaya
Rhode Island, USA
C?ID=240768
So I'm still having the same problem with the battery draining overnight. I have purchased a new battery regulator and will be here soon.
My question is there a special way I have to replace it? I know I'll have to recode the battery to it again but do I have to recode the regulator? If so some guidance would be great.
BostonSlaya
Rhode Island, USA
C?ID=240768
Hi Dana, I was hoping you can help me I'm still having battery drain even with the new battery like before I'm recoding the battery but it keeps saying battery coding rejected. I notice after I do this the battery indicator goes right up to 100% right away but then starts to drain again. I replaced my battery regulator and tried to recode again and still having the same problem. Again battery coding rejected but VCDS shows the new settings were applied but still having the issue. Everything has been checked that the battery and alternator is good. I'm so lost!! It stinks because when my car sits over night it nearly wants to start and I get all kinds of DTC's. Your help would be great thanks.
What values are you entering into the battery coding assistant?
What values are you using for WSC, Importer, and Equipment Number on the coding screen?
Some screen-shots of what you're doing an what's being rejected might be useful here.
As for the drain issue, it sounds to me like one or more modules aren't going to sleep as they should. In your scans above, you've got plenty of fault codes in various body and infotainment systems. How many of them are still present? Have you started measuring for millivolt drop across various fuses after the car has had a chance to settle down with the ignition off for a while, to try to narrow down where the current is being drawn?
BostonSlaya
Rhode Island, USA
C?ID=240768
What I have done is go into 61 and went to battery coding and selected 1 in the drop down menu. It poped up and I entered the BEM# the serial hit ok. Went to the screen and clicked do it. Then I got the error. I could do a screen shot or a short video on all if it helps.
As for faults I got allot cleared and down to a minimum. When the battery goes dead then a bunch of codes come up again. I haven't checked to see what fuses have power after car is shut down. ill do a full autoscan again with the module and take it from there. Thanks so much for your help.
Yeah, that might tell us why your coding is being rejected.
It's not a question of what fuses have power after the car is shut down. It's a question of voltage drop across the fuses. That voltage drop is indicative of current flowing through the fuse.
BostonSlaya
Rhode Island, USA
C?ID=240768
Is there a place I could put a video?
Component: 4.2L V8/5V G 0070 <<<<<<<<<<<<<<<<<< Firmware update needed which may save you the cost of those two error codes.
As Uwe said you must enter a WSC, tester # and Importer # into the config screen in VCDS and save it. 12345 444 54321
Do not use all zeros.
In addition to what has already been discussed.......It would be a good idea to check ground straps, since we have a DTC here.
Specifically engine to chassis..........add overlay is advised due to age of vehicle.
It could be affecting an intermittent or lose of charge during load offsets, however, tests okay at idle.
Sometimes I put a meter on and lock brakes while twisting the chassis going no where, to see if I spot a charge loss.
Ultimately I would change this immediately based on scan, because this could be a known parasite.
1Fault Found:
BostonSlaya
Rhode Island, USA
C?ID=240768
This is a AutoScan when the car is at like 10% on the battery level indicator on the MMI screen.
Saturday,06,June,2015,22:00:02:14758
VCDS Version: 15.5.0.0 (x64)
Data version: 20150510
Mileage: 79990km-49703mi   Repair Order:
VIN: WAUML44E74N017518   Mileage: 79990km-49703miles
   Coding: 0007773
   VCID: 1F4DDD45CE847AC796-804A
Readiness: 0000 0001
   VCID: 2447D2A9E7E2591FCB-8071
   Coding: 0007597
   VCID: 224BD4B1FDF6572FB9-8077
   Coding: 0263168
   VCID: 58BFB659EB2ACDFF97-800D
   Component: ELV                 1734
                    Reset counter: 229
                    Mileage: 79984 km
                    Date: 2015.06.06
                    Time: 21:38:08
   Coding: 0000103
   VCID: 2F6D2D85BE24EA4726-807A
   Coding: 1151313
   VCID: 5ABBAC519526DFEFA1-800F
                    Reset counter: 187
                    Mileage: 79943 km
                    Date: 2003.10.08
                    Time: 14:45:05
                    Voltage: 12.60 V
   Coding: 0111113
   VCID: 2A5B3C9185C68F6FF1-807F
   Coding: 00000030
   Shop #: WSC 02313
   VCID: 56A3B861E13EFB8F85-8003
   Component: SDAR
   VCID: 2643C8A191DEAB0FD5-8073
   Coding: 0530707
   Coding: 0012241
   VCID: 65C18FADAC5860171C-8030
   Coding: 0000232
   VCID: 5CB7AA499F1221DFB3-8009
   Coding: 0263168
   Component: ELV                 1734
   4E0905852C  ELV                 1734
                    Reset counter: 229
                    Mileage: 79984 km
                    Date: 2015.06.06
                    Time: 21:38:08
   Coding: 0000000
   VCID: 61C99BBDB8700C37E0-8034
   Coding: 0015510
   VCID: 2541CFADECD8A017DC-8070
                    Reset counter: 189
                    Mileage: 79990 km
                    Date: 2015.06.06
                    Time: 21:50:28
   VCID: 55A1BF6DBC38F0978C-FFFF
No Faults Found
   Part No SW: 4E0 910 888 M    HW: 4E0 919 887 C
   Component: MNS US          H42 1100
   VCID: 387F16D94B6A2DFF77-806D
   Coding: 0004021
   VCID: 1D31E74DC48868D784-8048
   Coding: 0020004
   VCID: 5EB3A041890E33CFDD-800B
                    Reset counter: 188
                    Mileage: 79952 km
                    Date: 2015.06.06
                    Time: 13:37:02
   Coding: 0065086
   VCID: 275DC5A596D4B207EE-8072
                    Reset counter: 189
                    Mileage: 79942 km
                    Date: 2003.10.08
                    Time: 00:25:02
                    Reset counter: 189
                    Mileage: 193858 km
                    Date: 2011.08.15
                    Time: 01:50:33
   Coding: 0000018
   Coding: 0010111
   VCID: 1E33E041C98E73CF9D-804B
   Coding: 0049148
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 187
                    Mileage: 79936 km
                    Date: 2003.10.08
                    Time: 14:43:54
                    Reset counter: 189
                    Mileage: 79984 km
                    Date: 2015.06.06
                    Time: 21:37:14
   Revision: AV1C1010
   Coding: 0000532
                    Reset counter: 46
                    Voltage: 6.21 V
                    Count: 61
   VCID: 62CB94B1BD76172FF9-8037
                    Reset counter: 189
                    Mileage: 79960 km
                    Date: 2015.06.06
                    Time: 19:43:30
                    Reset counter: 189
                    Mileage: 79960 km
                    Date: 2015.06.06
                    Time: 19:43:30
   Part No SW: 4E0 910 181 A    HW: 4E0 915 181
   Component: ENERGIEMANAGER  H02 0230
   Revision: 00000000    Serial number: 00000004980755
   Shop #: WSC 07212 444 82777
   Component: von VA0  341010A32S
   Coding: 303030393135313035444C56413033343130313041333253
   Coding: 0032364
02130 - Interior Door Lighting
                    Fault Status: 00101100
                    Fault Frequency: 0
                    Reset counter: 229
                    Mileage: 79968 km
                    Date: 2015.06.06
                    Time: 19:49:02
   Coding: 0212127
   VCID: 5FCD9D458E043AC7D6-800A
6 Faults Found:
                    Reset counter: 187
                    Mileage: 79940 km
                    Date: 2003.10.08
                    Time: 00:14:57
                    Voltage: 12.70 V
                    (no units): 46.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                    Reset counter: 187
                    Mileage: 79940 km
                    Date: 2003.10.08
                    Time: 00:14:57
                    Voltage: 12.60 V
                    (no units): 49.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                    Reset counter: 187
                    Mileage: 79940 km
                    Date: 2003.10.08
                    Time: 00:14:59
                    Voltage: 12.50 V
                    (no units): 52.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                    Reset counter: 187
                    Mileage: 79940 km
                    Date: 2003.10.08
                    Time: 00:14:58
                    Voltage: 12.60 V
                    (no units): 55.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                    Fault Frequency: 11
                    Reset counter: 189
                    Mileage: 79940 km
                    Date: 2003.10.08
                    Time: 00:14:58
                    Temperature: 33.0°C
                    Error Code: 0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                    Reset counter: 188
                    Mileage: 79948 km
                    Date: 2003.10.08
                    Time: 14:53:37
                    Speed: 9.0 km/h
                    Temperature: 27.0°C
                    Error Code: 0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
   Coding: 0028196
   VCID: 5DB1A74D840828D7C4-8008
   Coding: 0001208
   VCID: 2149DBBDF8F04C37A0-8074
End-------------------------(Elapsed Time: 03:36)--------------------------
This is after the car was at 100% Battery indicator on the MMI Screen and DTCS where cleared.
Saturday,06,June,2015,22:07:22:14758
   Coding: 0007773
   Coding: 0007597
   Coding: 0263168
   Component: ELV                 1734
   Coding: 0000103
   Coding: 1151313
   Coding: 0111113
   Coding: 00000030
   Shop #: WSC 02313
   Component: SDAR
   Serial number: AUZ4Z7E2009013
   Coding: 0530707
   Coding: 0012241
   Coding: 0000232
   Coding: 0000232
   Coding: 0263168
   Component: ELV                 1734
   4E0905852C  ELV                 1734
   Coding: 0000000
   Coding: 0015510
                    Reset counter: 189
                    Mileage: 79990 km
                    Date: 2015.06.06
                    Time: 22:03:56
No Faults Found
   Coding: 0004021
   Coding: 0020004
   Coding: 0065086
                    Reset counter: 189
                    Mileage: 79942 km
                    Date: 2003.10.08
                    Time: 00:25:02
                    Reset counter: 189
                    Mileage: 193858 km
                    Date: 2011.08.15
                    Time: 01:50:33
   Coding: 0000018
   Coding: 0010111
   Subsystem 1 - Part No: 4E0 910 511 A
   Component: UGDO HL US      H02 0030
   Subsystem 2 - Serial number: VK4978T078WE
   Coding: 0049148
   Revision: AV1C1010
   Coding: 0000532
                    Reset counter: 46
                    Voltage: 6.21 V
                    Count: 61
                    Reset counter: 189
                    Mileage: 79992 km
                    Date: 2015.06.06
                    Time: 22:05:26
                    Reset counter: 189
                    Mileage: 79992 km
                    Date: 2015.06.06
                    Time: 22:05:26
   Coding: 0032364
   Coding: 0212127
                    Reset counter: 189
                    Mileage: 79990 km
                    Date: 2015.06.06
                    Time: 22:05:58
                    Temperature: 27.0°C
                    Error Code: 0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
   Coding: 0028196
   Coding: 0001208
End-------------------------(Elapsed Time: 04:14)--------------------------
BostonSlaya
Rhode Island, USA
C?ID=240768
Here are the pictures requested
You can see by the time on the MMI Screen that after I try to recode the battery it says rejected but takes the save of the BEM and serial#, the battery indicator goes all the way to 100% right away but then drops down fast. All the times are in the battery dropping pictures and it is a matter of minutes..
As for the WCS your talking about it doesnt let me edit that it automaticly fills those fields in for me.
I have ordered a new CD player because mine is broking and I will be Updating my MMI software to the newest for my car and hope some of the DTC's will be cleared out..
Reset counter: 189
Mileage: 79942 km
Date: 2003.10.08
Time: 00:25:02
This fault will present no sleep mode ............
Battery from fast recharges is new but kaput most likely .....
BostonSlaya
Rhode Island, USA
C?ID=240768
Reset counter: 189
Mileage: 79942 km
Date: 2003.10.08
Time: 00:25:02
First thing is thanks soooo much for your help.
Ok does this mean I have to replace
4e0-910-289-A??
Until I order the part can I disable looking system via VCDS so the car doesn't try to communicate with the module so the battery doesn't drain?
Also where is this module located? Thanks
BostonSlaya
Rhode Island, USA
C?ID=240768
Reset counter: 189
Mileage: 79942 km
Date: 2003.10.08
Time: 00:25:02
Also what do you meen by battery from fast recharges kaput? What is part is kaput? Thanks
