Audi A3 8V mirror dipping function (mirror not returning to its original position)
fzanicotti
Brazil
C?ID=201619
My Audi 2015 A3 8V (5Q0) did not come with the folding mirror option, but getting the passenger mirror dip on reverse was easy with VCDS Release 14.10.2 following the advice on this forum and others.
- [52] Door Electronics, Passenger > Long coding > Byte 04 > Set bits 02 and 03
I'm assuming here all readers do know how it works: engage reverse, mirror selector switch to the 'passenger' position and the mirror dips to show the curb. Well, it does that but does not return to its original position afterwards (expected).
Actually I noticed a pattern: it travels a little further each time (irritating) around 10%. Just to mention, after a few times I have to readjust the mirror's position to bring it back to the view I first set.
I see a lot of discussions on this and a lot of drivers that do not bother readjusting it. Not my case though.
I found under Adaptations on [52] the following 'Channel': 'Reversing_Threshold_Passenger_Side_Front' with a 'Stored Value' of 90%. I tried but could not change it because it asks for the 'security access code'.
To the point: does anyone know the security access code to the [52] Door Electronics, Passenger? I would like to change it to '100%' and give it a go. Let's see what happens.
Finally, see below the Auto-Scan from my car:
Saturday,25,April,2015,20:20:11:39651
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
VIN: WAUACJ8V4F1043418   License Plate: AFZ-8818
Mileage: 1158km-719mi   Repair Order:
Chassis Type: 8V (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 30 42 44 52 55 5F
VIN: WAUACJ8V4F1043418   Mileage: 1158km-719miles
Address 01: Engine (J623-CJSA)       Labels: 06K-907-425-V1.clb
   Part No SW: 8V0 906 264 B    HW: 06K 907 425 A
   Component: 1.8l R4 TFSI  H09 0003
   Revision: --H09---
   Coding: 0A2500322424010B2800
   Shop #: WSC 10603 002 1048576
   ASAM Dataset: EV_ECM18TFS0218V0906264B 001003
   ROD: EV_ECM18TFS0218V0906264B_AU37.rod
   VCID: 3B70A2ABB2FF43F97BD-806E
Readiness: 0000 0001
   Part No SW: 0CW 300 048     HW: 0AM 927 769 K
   Component: GSG DQ200-MQB H43 5201
   Revision: 00043014    Serial number: CU501407016336
   Shop #: WSC 17734 418 534600
   ROD: EV_TCMDQ200021_AU37.rod
   VCID: 79FC78A3F843B1E9291-802C
   Revision: 00000000    Serial number: 61924000001788
   Coding: 13F16AA234242A6F017B060141CB29C8562C5480608294F4024100388608
   ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
   VCID: 4584C453C43B05091D9-8010
Address 08: Auto HVAC (E87)       Labels: 8V0-820-043.clb
   Part No SW: 8V0 820 043 C    HW: 8V0 820 043 C
   Revision: 20026000    Serial number: 00000000380227
   Coding: 03000014110000011000000000001500
   Shop #: WSC 06385 790 00016
   VCID: 326E8F8F65B582B1A8B-8067
   Component: BCM MQBAB H   H18 0134
   Serial number: 01011418200232
   Coding: 04141A42C26122FD03804004B10807A80000000000000000000000000000
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: 000A15479B99E0216EF-8055
   Slave 1:
   Subsystem 1 - Part No SW: 8V1 955 119 C    HW: 8V1 955 119 A
   Component: WWS371 140711  042 0585
   Serial number:         140715225250
   Coding: 0A47F7
   Slave 2:
   Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B
   Serial number: 22866471
   Coding: 00006C
   Slave 3:
   Subsystem 3 - Part No SW: 8V0 941 531 L    HW: 8V0 941 531 L
   Serial number: 01 04 2014  00000748
   Serial number: 000000000ZY141554R3L
   Serial number: 00000000000060071579
   Subsystem 6 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.014  H02 0007
   Serial number:     WOO3091052.
   Coding: 901E00
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 E    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0051
   Revision: --------    Serial number: 39231418900464
   Coding: 0000050011
   ROD: EV_EPHVA14AU3700000_AU37.rod
   Part No SW: 5Q0 959 655 AB    HW: 5Q0 959 655 AB
   Component: AirbagVW20    014 0385
   Serial number: 003MMR01NPD7
   Coding: 98CCC000000000005C540000004800000065
   Subsystem 1 - Part No SW: -----------    HW: 480 000 707 14
   Serial number: 3576700000083D7CFF0F
   Subsystem 2 - Part No SW: -----------    HW: 480 000 707 14
   Serial number: 358670000009108CFF03
   Subsystem 3 - Part No SW: -----------    HW: 480 400 807 14
   Serial number: 3516502AD1656B83417B
   Subsystem 4 - Part No SW: -----------    HW: 480 400 807 14
   Serial number: 3526502C51697524D102
   Subsystem 5 - Part No SW: -----------    HW: 480 400 207 14
   Serial number: 3556502C7156E9E381DX
   Part No SW: 8V0 953 521 BT    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 17071408490255
   Coding: A018
   ROD: EV_SMLSKLOMQB_AU37.rod
   VCID: 0D143C73DCCBBD49159-8058
   Part No SW: 8V0 920 871     HW: 8V0 920 871
   Component: KOMBI         H02 4291
   Coding: 07AD19082B8000081A00EA001000000000000000
Address 19: CAN Gateway (J533)       Labels: Redir Fail!
   Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2186
   Revision: --------    Serial number: 07071410802208
   Coding: 030100042F085A005B0002481C0B00000001010000000000000000000000
   ROD: EV_GatewConti_AU37.rod
   VCID: 428EDF4FD515323138B-8017
   Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
   Serial number: 28 06 2014  E0088712
   Serial number: 9858563603
Address 30: Special Function II (J843)       Labels: None
   Part No SW: 8V0 907 440     HW: 4H0 907 440
   Component: STS MQB       H06 0020
   Serial number: 00000000061873
   Coding: 1C1000
   ASAM Dataset: EV_PrepaTrackSysteAU37x 001032
   ROD: EV_PrepaTrackSysteAU37x.rod
   VCID: 76E6739FC95DDE91443-8023
   Part No SW: 5Q0 959 393 B    HW: 5Q0 959 393 B
   Serial number: 03071406071052
   Coding: 001C0E204100040000001002
   VCID: 3E76ABBFA1ED56D15C3-806B
   Component: EPS_MQB_ZFLS  123 1043
   Coding: 8103
   ROD: EV_SteerAssisMQB.rod
   VCID: 418CD043D0132929211-8014
   Part No SW: 5Q0 959 392 B    HW: 5Q0 959 392 B
   Serial number: 28061404080531
   Coding: 001C06204D00040000001002
   VCID: 3D74ACB3ACEB4DC9459-8068
Address 55: Headlight Range (J431)       Labels: 5Q0-907-357.clb
   Coding: 019A000001000000
   ROD: EV_HeadlRegulVWLWRMQB_AU37.rod
   VCID: 75E47493D45BD5894D9-8020
   Part No SW: 8V0 035 045 C    HW: 8V0 035 045 C
   Component: MU-H-N-RW     H43 0357
   Serial number: A307G0EB002633
   Coding: 01730103FF0A000021220001001A00002F000104010001005E
   ROD: EV_MUHig6C3HBAS_AU37.rod
   Engine Control Module 2:
   Subsystem 1 - Part No SW: V03 959 800 TC    HW: -----------
   Component: ROW 2014/2015  --- 0033
   Seat Adjustment Driver Side:
   Component: DU High  H49 0013
   Serial number: AUZ8Z9EY201BD7
   Sound System:
   Subsystem 3 - Part No SW: 8V0 919 614 K    HW: 8V0 919 614 K
   Component: ControlUnit_H  H81 0816
   Serial number: C1000010051400010007
   Door Electronics Rear Left:
   Component: Gracenote  --- 4006
End-------------------------(Elapsed Time: 04:08)--------------------------
DV52
C?ID=194404
fzanicotti:hello. I believe that your issue is hardware related- rather than being a software/coding issue.
The passenger side control module on your car is: 5Q0 959 392 B
I've recently had discussions with a colleague on another forum regarding the dipping reverse mirror: Like you, he had an MQB vehicle (mk7 Golf in his case) and like you he couldn't get the reverse mirror function to work properly. Also like you his car had the steering wheel on the wrong side - an American custom, I believe! But in his case his car was fitted with the 5Q0 959 592 B type module.
To cut a very long story short, we both concluded that the problem was that the control module (which VW calls J387) wasn't suitable for mirror dipping - our shared hypothesis was that the control module lacked the required memory module that is necessary to "re-locate" the mirror to its starting position. Without the memory facility, we argued that the re-location position would use a "rough-guess" to get back to its original position. That is, we surmised that the resetting position without the required memory would be reliant on "residual charges" (rather than an actual value in a memory address) in the electronic positioning circuits -hence the inaccurate relocation of the mirror. It's entirely possible that the module in your car suffers from the same problem!
Anyhow, to complete the story my colleague installed a 5Q4 959 592 unit (which I understand is the unit used in European countries that also have their steering wheel on the wrong side of the car). And it worked! Unfortunately, my colleague installed a 5Q4 959 592B unit on his car in his first attempt to fix this problem. To his chagrin (and to his disappointment), he found that B module reversed the "pitch" and "yaw" functions on the mirror switch.
Also like you his car had the steering wheel on the wrong side of his car - an American custom, I believe!
Ahem. On what side of the car is the steering wheel fitted in dem Vaterland? ;)
fzanicotti
Brazil
C?ID=201619
DV52: thank you for responding. Do you have this discussion documented elsewhere so I can follow and perhaps contribute? I understand your argument but do not believe its hardware related. I'm sorry but I'm just not convinced. Would you please elaborate how did you and your friend get to the conclusion? I believe if there is hardware, one could be able to code it to give it a desired functionality. Add to that it is not a random return or a 'rough-guess' to quote you.
Uwe: do you know the security access code to the [52] Door Electronics, Passenger?
DV52
C?ID=194404
Fzanicotti: not a problem if you think differently (I always applaud countervailing opinions)- my hypothesis is just that! I would be delighted to learn that your issue can be solved by a simple coding change!
In fact, I will wager a glass of your fine Brazilian beer against a glass of our Aussie brew on the outcome - to be collected by the winner if he/she ever visits the loser's place of residence!
Click Here for a full exposé on the discussion
fzanicotti
Brazil
C?ID=201619
Fair enough! I see it as a win-win contribution, plus I have a brother living in New Zealand and to fly there usually we have AUS in our route. BTW, your wines are not behind. Last year I watched live Australia vs. Spain game in Curitiba. Aussie soccer fans make a lot of noise! :thumbs:
diskoboy
C?ID=50403
It's the same problem on all MBQ cars (Golf 7, Octavia 3, Audi A3 8v). I've coded 5-10 cars and all of them are not returning to its original position.
Perhaps the "Reversing_Threshold_Passenger_Side_Front" would solve the problem.... if anyone knows the code...
DV52
C?ID=194404
Discoboy: As I indicated to Fzanicotti, my MQB car has a fully functioning mirror on the passenger door controller when reversing. Here's the admap from my car. As you can see, "Reversing_Threshold_Passenger_Side_Front has a setting of 90%.
fzanicotti
Brazil
C?ID=201619
Discoboy: true, DV52 contributed a lot to this topic but let's not forget he drives on the wrong side of the road! :D Anyway, differences may apply to the modules. Bits and bytes behave odd sometimes. Keep posting your findings.
