Hi there,
have a Audi A6 2012, which the rear wipe starts to wipe intermittent when you put the car into reverse. I would like to disable this function by coding it out. I think it is probably in control module 09 somewhere, but cant find anything in the long coding helper. Any advice ?
Also, in Norway you need to use DRL during daytime. I really do not think you need to have the rear lights on during daytime. But I would like them to be on. Is this possible to code ?
Monday,23,February,2015,19:12:51:41099
VCDS Version: 15.2.0.0
Data version: 20150130
VIN: WAUZZZ4GXCN057142 License Plate: AUDI A6
Mileage: 77556km-48191mi Repair Order:
Chassis Type: 4G (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 20 28 34 3B 3C 42 44
46 47 52 53 55 56 5F 62 69 72 82 85 8B 8E 8F 90
VIN: WAUZZZ4GXCN05XXXX Mileage: 77556km-48191miles
Address 01: Engine (J623-CDUC) Labels: Redir Fail!
Part No SW: 4G0 907 401 F HW: 4G0 907 401
Component: 3.0TDI EDC17 H37 0004
Revision: 53H37---
Coding: 1225401A057601020000
Shop #: WSC 09667 001 1048576
ASAM Dataset: EV_ECM30TDI0114G0907401F 001004
ROD: EV_ECM30TDI0114G0907401F.rod
VCID: A600BC07D9470608B9-80F3
Address 02: Auto Trans (J217) Labels: 0B5-927-156.clb
Part No SW: 4G1 927 156 B HW: 0B5 927 156 F
Component: 0B5 30 TDIRdW H10 0001
Revision: --H10--- Serial number: 0000000313
Coding: 000001
Shop #: WSC 02311 785 00200
ROD: EV_TCMDL501.rod
VCID: AC144E2FC7AB3C586F-80F9
Address 03: ABS Brakes (J104) Labels: 4G0-907-379.clb
Part No SW: 4G0 907 379 G HW: 4G0 907 379 G
Component: ESP PREMIUM H09 0250
Coding: 27A6C701E465E380EB00
ASAM Dataset: EV_ESPPremiAU57X 004017
ROD: EV_ESPPremiAU57X_AU57.rod
VCID: B5226B4B14E17D9000-80E0
Part No SW: 4H0 907 064 BN HW: 4H0 907 064 BN
Component: BCM2 2.0 H31 0330
Coding: 01A93006000000000000
VCID: F6A0AC4741673688C9-80A3
Part No SW: 4G0 820 043 K HW: 4G0 820 043 K
Component: KLIMA 4 ZONEN H11 0062
Serial number: 15091100040250
Coding: 361200783C
ASAM Dataset: EV_AirCondiComfoUDS 002033
ROD: EV_AirCondiComfoUDS.rod
VCID: A71EB103DE4D1F0082-80F2
Address 09: Cent. Elect. (J519) Labels: 4H0-907-063.clb
Part No SW: 4H0 907 063 BG HW: 4H0 907 063
Component: BCM1 2.0 H12 0100
Revision: 11012002 Serial number: 00000001213626
Coding: 0907201009749FE28981008300001800CF9CE7082E080101000108542F01
VCID: EE90842739370E4801-80BB
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119
Component: WWS57X 110830 H35 0051
Coding: 0045F7
Component: RLS H04 0003
Coding: 02512B
Subsystem 3 - Part No SW: 4G0 941 531 G HW: 4G0 941 531 G
Component: E1 - LDS H07 0044
Subsystem 4 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A31 LED Mod1L H03 0006
Coding: 110000
Subsystem 5 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A27 LED Mod1R H03 0006
Coding: 110000
Subsystem 6 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H02 0002
Address 10: Park/Steer Assist (J791) Labels: 4H0-919-475-7X5.clb
Part No SW: 4H0 919 475 P HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0030
Revision: -------- Serial number: 56261122100635
Coding: 992B08
ASAM Dataset: EV_EPHVA2CAU57X0000 002008
ROD: EV_EPHVA2CAU57X0000.rod
VCID: BFCE096326DDB7C0DA-80EA
Address 13: Auto Dist. Reg (J428) Labels: 4H0-907-561.clb
Part No SW: 4G0 907 561 HW: 4G0 907 561
Component: ACC3 H15 0160
Coding: 3F04010202
ASAM Dataset: EV_AdaptCruisContrAU57X 001003
ROD: EV_AdaptCruisContrAU57X.rod
VCID: E79EF1031ECDDF0042-80B2
Address 15: Airbags (J234) Labels: 4H0-959-655.clb
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H40 0040
Revision: -------- Serial number: 003JG0046NF0
Coding: 30323436313330303339554A304C34473053
VCID: B6206C4709E7768809-80E3
Serial number: 3575HRB405T0OPMG6G6D
Serial number: 3585HRB40650Q3SKG1AN
Serial number: 3515JRB40690NHDIDHO0
Serial number: 3525JRB40530NHDGFHBO
Serial number: 3554VRB405D0NI3IC0DN
Serial number: 3564VRB405D0NI3I4HH.
Address 16: Steering wheel (J527) Labels: 4H0-953-568.clb
Part No SW: 4H0 953 568 G HW: 4H0 953 568 G
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90372KIG0017A
Coding: 0000FD
VCID: B73E614306ED8F8012-80E2
Component: E221 - MFL H08 0009
Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb
Part No SW: 4G8 920 931 J HW: 4G8 920 931 J
Component: TDieRdwAcc H79 0375
Revision: 26181120 Serial number: 658200911593034
Coding: 138611001F150008000000
ASAM Dataset: EV_RBD4K 004040
ROD: EV_RBD4K.rod
Address 18: Aux. Heat (J364) Labels: 8R0-265-105.clb
Part No SW: 4H0 265 105 E HW: 4H0 265 105 E
Component: Standheizung H24 0250
Revision: 66006006 Serial number: 20110804225306
Coding: 5D3B00
VCID: A404A60FA77BF418A7-80F1
Part No SW: 4G0 907 468 E HW: 4G0 907 468 A
Component: J533--Gateway H08 0213
Revision: -------- Serial number: 00000000244812
Coding: 00CD077D00
ROD: EV_GatewUDS_AU57.rod
VCID: B2285057E58F6AA825-80E7
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0140
Serial number: 00000000005650457450
Voltage stabilizer:
Address 20: High Beam Assist. (J844) Labels: 8K0-857-511.clb
Part No SW: 8K0 857 511 E HW: 8K0 857 511 A
Component: FLA H04 0004
Revision: AA001002
Coding: 04018264747464545425363E
VCID: B3265553129563A02E-80E6
Address 28: HVAC, Rear (E265) Labels: 4G0-919-158.clb
Part No SW: 4G0 919 158 C HW: 4G0 919 158 C
Component: KLIMA FOND H07 0062
Serial number: 13091100040404
Coding: 01
ASAM Dataset: EV_ClimaContrUnitRearUDS 002015
ROD: EV_ClimaContrUnitRearUDS.rod
VCID: AF2E5923F6BD47404A-80FA
Address 34: Level Control (J197) Labels: None
Part No SW: 4G0 907 553 C HW: 4G0 907 553
Component: LUFE-DAEMPFER H17 0779
Coding: 008003
ASAM Dataset: EV_AirSuspe 003022
ROD: EV_AirSuspe_AU57.rod
VCID: AB164D33C2A53B6066-80FE
Part No SW: 4G0 907 637 B HW: 4G0 907 637 B
Component: SARA 6D H02 0004
Revision: -------- Serial number: EJ1BPA42021N8Y0
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA.rod
VCID: AD12432BFCB1355078-80F8
Part No SW: 4G0 907 566 D HW: 4G0 907 566
Component: J769 SWA MasterH02 0020
Revision: 00H02000 Serial number: 6PZ 010 287-03
Coding: 0010102
VCID: B02C5A5F238358B853-80E5
Subsystem 1 - Part No: 4G0 907 568 D
Component: J770 SWA Slave H01 0020
Subsystem 2 - Serial number: 6PZ 010 287-23
Subsystem 3 - Serial number: 5F21.09.1100H010003CF20338ˇ
Subsystem 4 - Serial number: F20338ˇ
Part No SW: 4G8 959 793 D HW: 4G8 959 793
Component: TSG FA H05 0212
Coding: 011F16205000628002080013
Shop #: WSC 02312 785 00200
VCID: C1CA0F9B5829C130AC-8094
Address 44: Steering Assist (J500) Labels: 8K0-909-144.clb
Component: RCEPS H35 0010
Revision: 00001000 Serial number: 0006160872
Coding: 101101010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS.rod
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0159077062
Coding: 0100062020B90494832009042E0104000000000000000000000000000000
Subsystem 1 - Part No SW: 4G9 959 591 HW: 8V3 959 591
Component: J245 PS20.006 H02 0007
Coding: 001F00
Subsystem 2 - Part No SW: 4G9 959 591 HW: 8V3 959 591
Component: J394 PS20.006 H02 0007
Coding: 180800
Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
Component: BOSE-G3-C7 H07 0160
Revision: CJ007000 Serial number: 00000000023539
Coding: 030000
Shop #: WSC 09670 001 1048576
VCID: 9D7293EB8411C5D0E8-80C8
Part No SW: 4G8 959 792 E HW: 4G8 959 792 A
Component: TSG BF H05 0212
Coding: 011F16205000628002080002
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000141261
ROD: EV_ParkiBrake_AU48.rod
VCID: AA184837CD5F22689D-80FF
Address 55: Headlight Range (J431) Labels: None
Part No SW: 4H0 907 357 A HW: 4H0 907 357 A
Serial number: 110927-0002-072
Coding: 11226F601002A300
ROD: EV_HeadlRegulBasic.rod
Part No SW: 4G1 035 053 E HW: 4G1 035 053
Component: Radio U Basic H41 0093
Revision: AB001007 Serial number: 049IY0BB023405
Coding: 010003010000000001
VCID: A10AAF1BB869E130CC-80F4
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 4G0 035 666 G HW: 4G0 035 666
Component: H-BN-EU H47 0484
Revision: -------- Serial number: 426I00B7613577
Coding: 050100010003FFED3D30EB3E00000003E80101020000000000
VCID: AC144E2FCFAB3C586F-80F9
Subsystem 1 - Part No: 8R0 060 884 N
Component: EUR 2011 1205
Subsystem 2 - Part No SW: 4G0 919 605 A HW: 4G0 919 605 A
Component: DU8 C7 SV H42 0021
Subsystem 3 - Part No SW: 4G1 919 610 C HW: 4G1 919 610 A
Component: E380 BDT C7 H08 0204
Component: CD-Database 3371
Part No SW: 4G8 959 795 E HW: 4G8 959 795 A
Component: TSG HL H04 0212
Coding: 010F14204000628002080002
VCID: C4C4068F473BD41887-8091
Address 69: Trailer (J345) Labels: None
Part No SW: 4G8 907 383 HW: 4G8 907 383
Component: Anhaenger H07 0072
Revision: 5G001002 Serial number: 00000133243781
Coding: 0109080000000000
VCID: F1AA9F5B280911B01C-80A4
Component: TSG HR H04 0212
Address 82: Heads Up Display (J898) Labels: 4G0-919-604.clb
Part No SW: 4G0 919 604 G HW: 4G0 919 604 G
Component: HeadUpDisplay 005 0106
Coding: 470000
ASAM Dataset: EV_HUDContiC7 001020
ROD: EV_HUDContiC7.rod
Address 85: On Board Cam. (J852) Labels: None
Part No SW: 4G0 907 217 HW: 4H0 907 217 A
Component: DPC-SG H24 0036
Revision: -------- Serial number: 262130025421000
Coding: EA060000
ROD: EV_OnBoardCamerDPC.rod
VCID: E582FB0BE4C1CD1070-80B0
Address 8B: Adaptive Cruise 2 (J428) Labels: 4H0-907-561.clb
Part No SW: 4G0 907 541 HW: 4G0 907 541
Coding: 3F04010202
ASAM Dataset: EV_AdaptCruisContr2AU57X 001002
ROD: EV_AdaptCruisContr2AU57X.rod
Address 8E: Image Processing (J851) Labels: 4G0-907-107.clb
Part No SW: 4G0 907 107 B HW: 4H0 907 107
Component: BV-SG H29 0034
Serial number: 000040182408117
Coding: 04C0BB1C1111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7_AU57.rod
VCID: A502BB0BA4410D10B0-80F0
Part No SW: 4H0 980 945 B HW: 4H0 980 945 B
Component: RGS-VL H13 0080
Coding: 0066E608031F037E070308014240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: B12A5F5BE08951B05C-80E4
Part No SW: 4H0 980 946 B HW: 4H0 980 946 B
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
End-------------------------(Elapsed Time: 04:14)--------------------------
