- Joined
- Jan 12, 2015
- Messages
- 185
- Reaction score
- 15
- Location
- Singapore
- VCDS Serial number
- C?ID=232348
Hi Guys,
I have a problem with my GT golf. My rear wiper, dual washer pump and cigaret lighter don't work.
My front wipers work just fine.
I have tested all my fuses and they all work. I pulled the washer pump out and tested on 12V independent and found the pump to be operational just fine (loud and noise as they normally operate) .
My VCDS diagnostic doesn't show anything with this subject matter at all.
I have further isolated the two fuse seats at 41 and 42 that control windshield washer pump and cigaret lighter are inactive,... although the 20A fuses are in correct position (tested in another slot and multimeter) .
Is there a reason why entire line in a row in Fuse box would be inactive?
_____
Update,
I have bypassed the two fuses with direct wire connection of the battery positive to the two seats.
Everything worked perfect. Obviously all the components work ( pump, motors etc), but the power is not getting to the second last row (fuse box) 41, 41, 42 ,43, 44, 45//
Does anyone have a clue here how I should proceed. Does this sound like the wiring issue or possibly J519 Control Module.
I have tested all my relays and they seem to work fine, as I have replaced them from my GTi model.
The fuses in position 41, 42, 43 are inactive ( no power to them)
What I noticed when I bridge the switch on the back of the J519 the fuses come alive. (When the switch is inserted in its position at the back of J519 nothing works.
Any ideas?
_____
Update,
Any ideas?
