codes.dat
Jef
HQ
If you get a message of "Can't Open Codes File: CODES.DAT", the issue can happen for different reasons:
  • security settings on your computer is not giving the VCDS software read/write permission
  • hyperactive virus scanner
  • CIA mind control penetrating the foil cap
Delete the default install of VCDS which is found on here on your hard drive:
C:\Ross-Tech\VCDS
Deleting the Ross-Tech folder will remove the software. Now run the VCDS installer again, when you get to the Choose Install Location screen, click on the [Browse] button:
Browse to your Documents type folder, select the folder and then click [OK]:
You will now see the new install location of VCDS:
Click on [Install] to continue.
Thomas_Niemisto
C?ID=22881
Yes, I had this problem too. The solution that worked for me was to right-click the VCDS program shortcut and select "Run as Administrator". (I have the VCDS software installed in the "Program Files" folder.) To make the setting permanent, right-click the program shortcut, select "Properties", open the "Compatibility" tab, and check-mark "Run as Administrator".
Despite the Download page stating quite clearly that you shouldn't do that? Why?
It should not be necessary to run VCDS "as administrator".
Thomas_Niemisto
C?ID=22881
It's so that all users can use the program with just one installation.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
The VCDS setup/installer doesn't differentiate between individual and all user installations at this point, however - this should only effect the start menu shortcuts at this point. The installation folder should have no effect on multi or single-user installations.
