- Joined
- Feb 13, 2017
- Messages
- 84
- Reaction score
- 65
- VCDS Serial number
- C?ID=65958
One fine day I opened my van to be met with flashing hazard lights, a wiper stalk which turns on the horn- I don't recall what the horn now does! Alarm going off constantly too. Central locking does still work fine. Engine starts no problem but still hazard lights, alarm etc continue to do what they want.
The van has had a genuine cruise control retrofitted by me some years ago.
Full scan:
I will of course check fuses and I've ordered a secondhand J519 (address 09) for a quick test once coded.
The power cable to the module under the drivers seat (address 46?) was sorted a few years ago.
From experience, I know J519 faults can lead you down abstract avenues....the last one being to a vacuum valve failure on the 4motion diff lock of all things.
I'm away for a few days so I am gathering info so that hopefully upon my return I can hit the ground running and get the van back on the road again.
Any thoughts/pointers appreciated.
Full scan:
Saturday,14,July,2018,10:40:30:61795
VCDS Version: 18.2.1.5 (x64)
VIN: WV1ZZZ7HZ9H012117 License Plate:
Mileage: 180980km-112455mi Repair Order: 20180714_1
Chassis Type: 7H (7H - VW Transporter/Multivan (2003 > 2010))
Scan: 01 02 03 08 09 0B 0D 15 16 17 18 19 1C 22 2D 37 45 46 47 56
57 6E 76 77 78 7D
VIN: WV1ZZZ7HZ9H012117 Mileage: 180980km-112455miles
Address 01: Engine Labels: 070-906-016-BPC.clb
Part No SW: 070 906 016 EC HW: 070 906 016 EC
Component: R5 2,5L EDC G001SG 2539
Revision: --H06--- Serial number: VWZ7Z0H6765279
Coding: 0001172
Shop #: WSC 66565 257 00032
VCID: 55A60D0AFFF035EC27-5168
001384 - Cruise Control Switch (E45)
P0568 - 000 - Implausible Signal
Mileage: 180981 km
Voltage: 11.02 V
Bin. Bits: 00001000
Bin. Bits: 11000000
(no units): 0.0
Address 03: ABS Brakes Labels: 7H0-907-37x-ABS.clb
Part No SW: 7H0 907 379 S HW: 7H0 907 379 S
Component: (M)ABS MK25E 0103
Revision: 00H21001
Coding: 0000092
Shop #: WSC 02736 790 00000
VCID: 4586DD4A0F50856C57-512E
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 7H0 820 045 AM
Component: CLIMA/AC 0303
VCID: 70E85C9E605270C4D4-514A
Address 09: Cent. Elect. Labels:. 7H0-937-049.lbl
Part No: 7H0 937 049 AD
Component: BORDNETZ SGVER 1.0 2101
Coding: 0000102
VCID: 74E0508E144A4CE430-514A
8 Faults Found:
00909 - Windshield Wiper Motor (V) Stage 1/2
00906 - Horn (H1)
00901 - Back-Up Lamps
014 - Defective
02092 - Enabling Heated Seat
006 - Short to Plus
00886 - Turn Signal Switch (E2)
00991 - Interior Lights
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 A
Component: 3C AIRBAG VW51 0011
Coding: 13123
Shop #: WSC 02736
VCID: 224C66D6AE3E925412-512E
Address 17: Instruments Labels: 7Hx-920-xxx-17.lbl
Part No: 7H0 920 951 T
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 00413
Shop #: WSC 00373
VCID: 3D76B5AA3780CDAC0F-514A
WV1ZZZ7HZ9H012117 VWZ7Z0H6765279
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00022
Shop #: WSC 02736
VCID: 70E85C9E305270C4D4-514A
Address 22: AWD Labels: None
Part No: 7H0 907 554 F
Component: HALDEX 4Motion 2110
VCID: 3362939251C40BDCE9-512E
Address 45: Inter. Monitor Labels: 7Hx-951-171.lbl
Part No: 7H0 951 171 B
Component: Innenraumueberw. 2920
Coding: 0000021
Shop #: WSC 02737 790 00000
VCID: 295E71FA8308410C53-51FC
Address 46: Central Conv. Labels: 7H0-959-433.lbl
Part No: 7H0 959 433 B
Component: C1W Komfortgerát 0004
Coding: 00020
Shop #: WSC 02736
VCID: 326C9696FEDE02D4E2-4B28
Address 56: Radio Labels: None
Part No SW: 7H0 057 152 HX HW: 7H0 057 152 HX
Component: Radio LG3 0018
Revision: 00009000 Serial number: VWZCZ5I0100151
Coding: 0020200
Shop #: WSC 00461 210 87671
VCID: 0302035241E47B5C39-514A
End-------------------------(Elapsed Time: 05:55)--------------------------
