Touareg air suspension base heights erased
Swampdog
C?ID=340111
A quick run down to what happened.
Rear left corner kept dropping, suspected air leak.
Drenched suspect unit in bubbles, no leak detected.
Removed complete strut and submerged in water. ..still no bubbles.
Suspected solenoid on back of compressor was faulty and air draining back through system so drained air from system by removing pipes from solenoid block
Gave solenoid a little squirt of wd40 in case valves were sticking internally (don't know if I should have done this).
Went to inflate system. Wouldn't raise and red running gear fault on MFA.
Purchased vcds from ross-tech.
Was resetting heights. Got through steps 1-4 entering new heights. Went to save new heights in step 5.
Came up with communications error and didn't save heights and wiped out the original settings
Now I can't enter anything as can't delete fault code of no initial settings learned.
Any help is massively appreciated as currently the motor is parked up down on its bump stops and I need it as it's my daily
Gary
Please post an Auto-Scan for context. Right now, we don't even know what generation of Touareg you have, and the suspension modules did change rather dramatically between them.
PS: Moved to Car Repair Support.
Swampdog
C?ID=340111
Sorry. ...new here....still figuring out what's where.
It's a 2005 4.2 v8 touareg. I'm using my phone so can only copy and paste scans at mo.
First scan results were done when I initially received vcds. And second one the car sits today. Thanks
Saturday,07,July,2018,11:20:08:30857
VCDS Version: 18.2.1.5 (x64)  HEX-V2 CB: 0.4411.4
VIN: WVGZZZ7LZ5D042646   License Plate: LS02 EXG
Mileage: 157960km-98151mi   Repair Order:
Chassis Type: 7L - VW Touareg (2003 > 11/2006)
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
          37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
   Mileage: 157960km-98151miles
   Part No: 09D 927 750 BQ
   Component: AL 750 6A           0550
   Coding: 0012330
   Shop #: WSC 31414 000 00000
   VCID: 7EA50230BCE0FD67038-5160
Address 03: ABS Brakes        Labels: 7L0-907-379-MK25.lbl
   Part No: 7L0 907 379 G
   Component: ESP ALLRAD MK25     0203
   Coding: 0014594
   VCID: 3D27C53CF166267F5A2-5184
   Part No SW: 3D0 909 135 N    HW: 5WK 470 21
   Component:    Kessy            6610
   Revision: 66105312    Serial number: VWZ3Z0D1272374
   Coding: 0000232
   VCID: 3039EC083634DB17C14-5184
Address 08: Auto HVAC        Labels: 7L6-907-040.clb
   Part No: 7L6 907 040 H
   Component: CLIMAtronic R/L   X 3716
   VCID: 3537DD1CC956FE3F922-5184
00353 - Function Return Message from Fresh Air Blower Regulator
                    Voltage: 13.90 V
                    Voltage: 12.10 V
                    Voltage: 5.56 V
                    Voltage: 14.00 V
            014 - Defective
00445 - Loss of Refrigerant
                    Temperature: 76.0°C
                    RPM: 608 /min
                    Absolute Pres.: 15.0 bar
                    Load: 91.0 %
                    Temperature: 11.0°C
                    Temperature: 24.0°C
                    Load: 43.6 %
                    Temperature: 91.0°C
Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V1.clb
   Part No: 7L6 937 049 M
   Component:                     3001
   Coding: 0105724
   VCID: 46D5AAD0A4B065A70B8-5184
   Part No: 3D0 909 601 E
   Component: 0B Airbag 8.4E+ H10 0951
   Coding: 0012354
   VCID: 25170D5C79F68EBF222-5184
   Part No: 7L6 953 549 D
   Component: Lenksäulenmodul     3301
   Coding: 0000031
   VCID: 40D9BCC886944B97314-5184
01750 - Multi-Function Switch in Steering Wheel (E440); Left
            006 - Short to Plus
Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
   Part No: 7L6 920 980 R
   Component: KOMBIINSTRUMENT RB8 3135
   Coding: 0007411
   Shop #: WSC 00674 210 82674
   VCID: 47CBA7D4A3BA7CAFF0E-5184
   Part No: 6N0 909 901
   Coding: 0000006
   VCID: 70B92C08F6B49B17814-5184
   Part No: 0AD 927 755 BE
   Component: TRANSFERCASE        0122
   VCID: 7F5BFF34BBEAF46F08E-5160
Address 29: Left Light        Labels: 3D0-909-157.lbl
   Part No: 3D0 909 157
   Component: EVG GDL+AutoLWR(l)  0001
   Coding: 0000003
   VCID: 66954A50C47045A7EB8-5184
00003 - Control Module
Address 34: Level Control        Labels: 7Lx-907-553-34.clb
   Part No: 7L0 907 553 H
   Component: LUFTFDR.-CDC- 3C3P1 3099
   Coding: 0015521
   Shop #: WSC 37249 001 1048576
   VCID: 3829D428DE440357894-5184
7 Faults Found:
00807 - Suspension Strut Valve; Rear Left (N150)
00808 - Suspension Strut Valve; Rear Right (N151)
00805 - Suspension Strut Valve; Left Front (N148)
00806 - Suspension Strut Valve; Front Right (N149)
01773 - Level Control Accumulator Valve (N311)
01400 - Suspension Level Control
01772 - Signal from Level Control Pressure Sensor (G291)
   Part No: 3D0 909 158
   Coding: 0000003
   VCID: 678B4754C37A5CAFD0E-5160
   Part No: 7L0 959 933 E
   Component: GT HSG              0201
   Coding: 0000065
   VCID: 3E25C230FC603D67438-4B1E
   Subsystem 1 - Part No: 7L0 959 701 K
   Component: Tuersteuergeraet FS 0201
   Subsystem 2 - Part No: 7L0 959 702 K
   Component: Tuersteuergeraet BF 0201
   Subsystem 3 - Part No: 7L0 959 703 C
   Subsystem 4 - Part No: 7L0 959 704 C
   Subsystem 5 - Part No: 7L0 907 719
   Component:    Neigungssensor   0020
   Subsystem 6 - Part No: 7L6 951 171
   Component: A  Innenraumsensor  0019
Address 56: Radio        Labels: 3B7-035-1xx-56.lbl
   Part No: 7L6 035 195
   Component: Radio DE2           0012
   Coding: 0001405
Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
   Part No: 7L0 955 119 L
   Component: Front Wiper         4027
   Coding: 0000855
   Shop #: WSC 31414 000 376832
   Subsystem 2 - Part No: 1K0 955 559 M  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 005  0605
   Coding: 00217125
   Shop #: WSC 31414
   Part No: 7L0 919 283 F
   Component: 0D Einparkhilfe     1107
   VCID: 392FD12CE54E1A5F76A-5184
01627 - Sensor for Parking-Aid; Front Mid-Right (G253)
            006 - Short to Plus
End----(Elapsed Time: 10:14, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
Address 02: DTCs cleared
Address 03: DTCs cleared
Address 05: DTCs cleared
Second scan:
Saturday,07,July,2018,17:12:33:30857
   VCID: 55F77D9C6C06DE3F722-FFFE
   Coding: 0014594
   Coding: 0000232
                    Voltage: 13.90 V
                    Voltage: 12.10 V
                    Voltage: 5.56 V
                    Voltage: 14.00 V
            014 - Defective
                    Temperature: 76.0°C
                    RPM: 608 /min
                    Load: 91.0 %
                    Temperature: 11.0°C
                    Temperature: 24.0°C
                    Load: 43.6 %
                    Temperature: 91.0°C
   Component:                     3001
   Coding: 0105724
   Coding: 0012354
   Coding: 0000031
            006 - Short to Plus
   Coding: 0007411
   Coding: 0000006
   VCID: 7F5BFF34BBEAF46F08E-5184
   Coding: 0000003
   Coding: 0015521
   Coding: 0000003
   VCID: 678B4754C37A5CAFD0E-5184
   Coding: 0000065
   Coding: 0001405
   Coding: 0000855
   Coding: 00217125
   Shop #: WSC 31414
            006 - Short to Plus
End----------(Elapsed Time: 10:01, VBatt start/end: 14.0V/14.0V)-----------
Sunday,08,July,2018,11:00:48:30857
   Coding: 0012330
   VCID: 7EA50230BCE0FD67038-5184
   Coding: 0014594
   Coding: 0000232
                    Voltage: 13.90 V
                    Voltage: 12.10 V
                    Voltage: 5.56 V
                    Voltage: 14.00 V
            014 - Defective
                    Temperature: 76.0°C
                    RPM: 608 /min
                    Load: 91.0 %
                    Temperature: 11.0°C
                    Temperature: 24.0°C
                    Load: 43.6 %
                    Temperature: 91.0°C
   Component:                     3001
   Coding: 0105724
   Coding: 0012354
   Coding: 0000031
            006 - Short to Plus
   Coding: 0007411
   Coding: 0000006
   Coding: 0000003
   Coding: 0015521
01437 - Control Position not Learned
   Coding: 0000003
   Coding: 0000065
   Coding: 0001405
   Coding: 0000855
   Coding: 00217125
   Shop #: WSC 31414
            006 - Short to Plus
End----------(Elapsed Time: 09:36, VBatt start/end: 14.0V/14.0V)-----------
Hmm... I'm a bit bothered by the fact that 01-Engine does not show up in any of these three scans and the second one shows wonkiness communicating with 02-Auto-Trans as well.
What kind of computer are you using? What version of Windows? Is there any "Nannyware" on it?
Swampdog
C?ID=340111
I'm using a Toshiba satellite c50 laptop with windows 10, I believe. What do you mean by nannyware? There's no restrictions on it as far as I know
"Nannyware" means virus or malware scanners that interfere with program operations, particularly the third-party ones such as McAffee.
Swampdog
C?ID=340111
The only thing I've got is free avg.other than that nothing as far as I know. I'm in the garage now so will try my wife's lappy. It's same as mine but might be 'cleaner'. I'll post a scan in a minute.
Thanks for your quick reply by the way
Swampdog
C?ID=340111
here's the scan i just did.....it seems to be finding a lot more fault codes. would that be because i disconnected the battery for a day or so (i was advised to this in the hope it would reset everything).....anyway....
Wednesday,11,July,2018,17:01:33:30857
   Coding: 0012330
   Coding: 0014594
   Coding: 0000232
                    Voltage: 13.90 V
                    Voltage: 12.10 V
                    Voltage: 5.56 V
                    Voltage: 14.00 V
            014 - Defective
                    Temperature: 76.0°C
                    RPM: 608 /min
                    Load: 91.0 %
                    Temperature: 11.0°C
                    Temperature: 24.0°C
                    Load: 43.6 %
                    Temperature: 91.0°C
   Component:                     3001
   Coding: 0105724
   Coding: 0012354
   Coding: 0000031
            006 - Short to Plus
   Coding: 0007411
   Coding: 0000006
   Coding: 0000003
   VCID: 66954A50C47045A7EB8-5160
   Coding: 0015521
8 Faults Found:
   Coding: 0000003
   Coding: 0000065
   Coding: 0001405
   Coding: 0000855
   Coding: 00217125
   Shop #: WSC 31414
            006 - Short to Plus
End----------(Elapsed Time: 09:21, VBatt start/end: 14.0V/14.1V)-----------
Was this one done using your wife's computer? Still no engine...
And all the "Short to GND" codes are back in the Suspension module...
Swampdog
C?ID=340111
Yes I used my wife's one.
I'm just guessing, but i think those codes are from unplugging the compressor and solenoid block ( which I have done since last scan) .I'm sure if I cleared the codes they would disappear. But I thought it best for you to see everything.
Would the ecu from my lpg system be blocking the engine ecu from being read do you think.
I also apologise as I haven't figured how to compress my resulted. I see you've edited.
I have no idea, but now that you've mentioned it, I'll ignore the lack of communications with the ECU.
Here's the thing with those suspension calibrations: The whole procedure has to be done in a single diagnostic session. If anything kills the session, the procedure will fail. Pretty much any fault in the suspension module or the stuff it monitors will also cause the procedure to fail. Unfortunately, it's not entirely to me clear what's causing it to fail for you.
Swampdog
C?ID=340111
So the fact that I've erased the original settings shouldn't normally be a problem then? They can be re-entered can they?
When I go into adaptations to set the height, the top left box says 'wait' in green letters. The compressor cuts in and the rear goes up a little but the front doesn't move. So the box never changes to 'value' .
In guessing the car levels in stages, rear then front then rear etc, till its found where it is. But besause the front didn't move the vcds gets stuck if you get me.
Would that make sense, if so could it have anything to do with solenoid not working properly?
You should check fuses and all connections for supply and ground to the 0x34.
Verify each of the components in fault with level controller & if fuses are good isolate all using the RTFB and checking tracks or sensors with WD
Swampdog
C?ID=340111
Wow, lol...thanks for reply....but I'm afraid just about everything you said was like a foreign language to me.
I'm afraid I'm a novice with vcds and vw.
You'll need to explain terminology a bit to start with please
Dana
Western PA, USA
Providing these do not return
.. and the only reoccurring issues are specific to
005 - No or Incorrect Basic Setting / Adaptation​
and
.. I would suspect you have a leak, the check valve on the left rear shock is faulty, the valve block isn't switching or the compressor isn't functioning properly (which could be power/ground related).
The thing is, you can't calibrate a broken system so 01437 - Control Position not Learned - No or Incorrect Basic Setting / Adaptation is not a high priority until the system is functioning properly. I would try this:
http://forums.ross-tech.com/showthread.php?1996-Level-Control-Bleeding-Charging
If it won't raise and lower via Basic Settings you should be able to further diagnose this based on those results.
Swampdog
C?ID=340111
and
that's exactly what happened last time i cleared the codes,so thats good. it is a suspected leak that started all this,but it's not the residual valve,i've already replaced that,and removed strut,charged with residual air and dunked it under water and couldn't find leak,that's what led me to suspect it was leaking back through system and maybe the solenoid valve block,and from what you say,the compressor works fine,so that leads back to valve block
right,ok....i was under the belief it was the other way round and the height settings need to be in there before the system will fire up,so that also makes me feel better
been in there,and although it seems to charge/drain the systems....at least,it gives readings of bar pressure......but the car doesn't lift??
so what might that suggest? does it point back to a faulty valve block do you think?
i thought it was easier to answer in your quote,thanks,cause you've helped me understand alot more
It may be easier for you, but it makes it far more tedious for the next person to quote you.
Lgibson
C?ID=41716
My bet is a leak at the valve block. See if you can find 4-page Technical Bulletin C 43-05-02 out there somewhere, published Dec.9, 2005.
Swampdog
C?ID=340111
That's my reckoning too. Ordered one yesterday, hopefully be here by weekend. I'll have a dig about for the bulletin.
Thanks mucky.
