Hey,
I have a problem with Skoda Octavia 2016 (5E).
After the last inspection and oil change in my authorized service, I can't delete notifications which are displayed on the radio display and counters:
In "Adaptaction" -> "ESI: Resetting ESI" -> the ESI value is set to "Warning active". When I select the "Reset" item, the VCDS confirms the change (controller accepted the changes....).
When the VCDS loads the channels again the ESI Resetting value is still "Warning active".
This information is displayed every time the car is turned on or off, without sound signaling.
My skoda service claims that they can't change it, but I don't think they are right, because I didn't have this message before.
VIN: TMBAE7NE9G0198641 License Plate:
Chassis Type: NE-SK37 (5Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 20 2B 32 36 42 44 47 52 55
5F A9
VIN: TMBAE7NE9G0198641 Mileage: 33567km-20857miles
Address 01: Engine (J623-CHHA) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 C HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 0C1D00124424010B1000
Shop #: WSC 73430 031 00000
ROD: EV_ECM20TFS0205G0906259C_SK37.rod
VCID: 2E04F98630915867D3B-807A
Part No SW: 0D9 300 020 J HW: 02E 927 770 AQ
Component: DQ250-6V MQB H53 4901
Revision: 06253104 Serial number: TFK01601050273
Shop #: WSC 73430 031 00063
ROD: EV_TCMDQ250021.rod
VCID: 1C60234E562DDAF78DF-8048
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-ESP-V1.clb
Part No SW: 3Q0 907 379 T HW: 3Q0 907 379 C
Component: ESC H32 0393
Revision: 00000000 Serial number: 50316000000326
Coding: 1A076B9154292974007D060441C42958D62A9400608294F600410071C009
VCID: 4BC29012A3430D4FD45-801E
Revision: 00021000 Serial number: 0393284197
Coding: 030C0C
Shop #: WSC 73430 790 00000
VCID: 3A2CC5D6FCD984C77F3-806E
Part No SW: 5E0 907 044 T HW: 5E0 907 044 T
Component: Climatronic H04 1002
Revision: 00001K07
Coding: 01010004000100011005004100101000
ROD: EV_ACClimaBHBVW37X_004_SK37.rod
VCID: 3634D1E6C8C160A79BB-8062
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 CL HW: 5Q0 937 084 AN
Component: BCM MQBAB H H24 0175
Serial number: 01061603602470
Coding: 0C111B66C2C722FB07A04082B10807280800000000000000000000000000
Shop #: WSC 73430 790 12345
ROD: EV_BCMBOSCH_015.rod
VCID: 04507B2ECE9D023755F-8050
Subsystem 1 - Part No SW: 5E1 955 119 HW: 5E1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS371 160110 041 0570
Serial number: 160130220746
Coding: 064DDD
Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S3Y16M02D09H08M31S20
Coding: 00885D
Subsystem 3 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171
Serial number: 000000000ZY152571AEV
Subsystem 4 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0313
Serial number: 00000000000064860878
Sun Roof:
Subsystem 5 - Part No SW: 6R0 959 591 D HW: 6R0 959 591 D
Component: J245 PS72.403 H03 0004
Serial number: 0000FST000QZPLZ00000
Coding: 981803
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39391603509608
Coding: 0031051051
Shop #: WSC 73430 790 00063
ROD: EV_EPHVA18AU3700000_002_AU37.rod
VCID: 43D2B8328B13C50F2C5-8016
Part No SW: 3Q0 959 655 AS HW: 3Q0 959 655 AS
Component: Airbag VW20 013 0200
Revision: -------- Serial number: 003SQP1ZP1U2
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 0F7A440297DB716FF8D-805A
Subsystem 1 - Part No SW: ----------- HW: 454 002 001 16
Serial number: 3576U0000001CA403915
Subsystem 2 - Part No SW: ----------- HW: 454 002 301 16
Serial number: 3586U00000027D603917
Subsystem 3 - Part No SW: ----------- HW: 454 801 401 16
Component: SideSensor_Dr 301 0148
Serial number: 3516RE713D6090000009
Subsystem 4 - Part No SW: ----------- HW: 454 801 201 16
Component: SideSensor_Pr 301 0148
Serial number: 3526RCD0FD709000000Q
Subsystem 5 - Part No SW: ----------- HW: 454 801 512 15
Component: FrontSensor_D 304 0149
Serial number: 3556VE2F23C09000000L
Part No SW: 5Q0 953 507 HG HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0120
Revision: -------- Serial number: 03011608490003
Coding: 1010
ASAM Dataset: EV_SMLSKLOMQB 020001
ROD: EV_SMLSKLOMQB_VW37.rod
VCID: 025C7D36D4890C07673-8056
Part No SW: 5E0 920 756 B HW: 5E0 920 756 B
Component: KOMBI 325 6422
Coding: 07AD011829800008010A6A001000000000000000
Shop #: WSC 29033 001 1048576
VCID: 290E0A9A097F3F5F069-807C
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 F
Component: GW MQB High 128 1244
Revision: -------- Serial number: 0004458112
Coding: 030100047F085900EB00026B1C0F00010001050000000000000000000000
VCID: 79AE1ADAB95F4FDF369-802C
Subsystem 2 - Part No SW: 3V0 919 719 B HW: 3V0 919 719 B
Component: E221__MFL-PR6 H02 0150
Serial number: 000000000A2633020216
Subsystem 3 - Part No SW: 5Q0 915 181 H HW: 5Q0 915 181 H
Component: J367-BDMConti H02 1011
Serial number: 74185704001601310165
Address 20: High Beam Assist. (J844) Labels:| 8X0-857-511.clb
Part No SW: 5G0 857 511 D HW: 5G0 857 511 D
Component: FLA H05 0002
Revision: AA001001
Coding: 02018F6B74745D545420363E01
VCID: 2B02F09203832D4FF45-807E
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 16000012309010
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 3430EBEEDEBD72B7A5F-8060
Address 32: Differential Locks (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 E HW: 0CQ 907 554 E
Component: Quersperre H52 8042
Serial number: HA1-00010.11.15
Coding: 0201
ASAM Dataset: EV_LockElectHA1VW37X 001007
ROD: EV_LockElectHA1VW37X.rod
VCID: 47CAAC22BF2BE92FF0D-8012
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 5Q0 959 760 B HW: 5Q0 959 760 B
Component: Sitzmemory H07 0020
Serial number: Y0006PA816749
Coding: 0010000000000500018480808080000000008181000000D400
VCID: 3C20C3CEF6EDBAF76DF-8068
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 010 0031
Serial number: 0000185998861
Coding: 001D0020DE00040000001100
Serial number: 00000000000097014193
Coding: 010200
Part No SW: 3Q0 909 144 J HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5063
Coding: 8103
VCID: 392EDADAF9DF8FDF769-806C
Address 47: Sound System (J525) Labels:| 3Q0-035-466.clb
Part No SW: 3Q0 035 466 A HW: 3Q0 035 466 A
Component: MIB2_amp_P_SK H02 0250
Revision: 00000001 Serial number: SKZ8Z1FAS016J3.
Coding: 0373010000AA002AAA0000000000
ASAM Dataset: EV_AMPMst16C4Gen2ALPI 001002
ROD: EV_AMPMst16C4Gen2ALPI.rod
VCID: 2D06FE8A3D97237FEA1-8078
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 010 0031
Serial number: 0000186005326
VCID: 46D4A126B821F0270BB-8012
Serial number: 00000000000008796345
Coding: 190200
B1487 54 [009] - Missing Calibration / Basic Setting
Reset counter: 164
Mileage: 33488 km
Date: 2018.07.02
Time: 18:11:33
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 03DA00003F010000
VCID: 40D8B73E9A05DE17317-8014
Subsystem 1 - Part No SW: 1T0 941 329 B HW: 1T0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo links H06 0009
Coding: 3E0000
Subsystem 2 - Part No SW: 1T0 941 329 B HW: 1T0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo rechts H06 0009
Coding: 3E0000
Part No SW: 3V0 035 044 B HW: 3V0 035 044
Component: MU-H-LN-EU H50 1233
Serial number: A675A0GB000846
Coding: 037351010000000011110002000000102F0001E401200100FE
Subsystem 1 - Part No SW: 5E0 919 606 HW: 5E0 919 606
Component: ABT_High H61 0032
Serial number: SKZ8Z9RW800Y94
Subsystem 2 - Part No SW: V03 959 801 JN HW: -----------
Component: ECE 2017/2018 --- 0161
Subsystem 3 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2--- --- 1012
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 5E0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0001
Serial number: 160116201753
VCID: 698E4A9AC9FFFF5FC69-803C
End------(Elapsed Time: 02:06, VBatt start/end: 12.4V/12.4V, udsna)--------
