Haven't posted here in a while. This is my 2007 VW "Passetta" with 2.5L engine swap ... hence I've posted my problem here.
I haven't really been driving the car much, just trying to get some things finished up before I sell it. The last thing done was the 12-Warranty body and paintwork at the dealer ... got it back about a week ago from some touch-up work.
The car has run fine, no problems ... I try to drive it at least once a week. I've got about 12,500 miles on the swap now.
Two days ago, I went to start it and drive it for a while ... RED steering light shows up on the dash! ... NO power steering! Drove it down the road ... still nothing. Disconnected the battery and let it sit a while ... reconnected and still nothing.
I've never had any problems with the steering on this car, and although I've changed and modified a lot of things ... I've never touched the steering or it's circuits, so I'm not really familiar with it.
Any ideas? ... Where is the steering control module? ... is it common for them to just up and quit? ... I'm thinking possibly a corroded electrical connection somewhere?
The following day I ran a VCDS scan .... (don't let the 1K0 chassis throw you ... remember it's a "Passetta") ...
Tuesday,26,June,2018,13:00:16:23114
VCDS Version: 18.2.0.3 (x64) HEX-V2 CB: 0.4411.4
VIN: WVWBA71K78W315062 License Plate:
Mileage: 119160km-74042mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 56 62 72
VIN: WVWBA71K78W315062 Mileage: 119160km-74042miles
Address 01: Engine (CBT) Labels: 06A-906-032-BGP.lbl
Part No SW: 07K 906 032 BJ HW: 07K 906 032 Q
Component: 2,5l R5/4V G 1567
Revision: 1NH01--- Serial number: VWX7Z0H33N97Z2
Coding: 0000003
Shop #: WSC 01279 785 00200
VCID: 72BED2CB78AA853774C-8026
Readiness: 0000 0011
Part No SW: 09G 927 750 HE HW: 09G 927 750 HE
Component: AQ 250 6F 1090
Revision: 00H69000 Serial number:
Coding: 0000584
VCID: 7BA0FFEF2FE0C47F27A-802E
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Revision: 00H11001
Coding: 0004738
Shop #: WSC 64692 001 104857
VCID: 73B0D7CF07B08C3F7FA-8026
Part No: 1K0 820 047 EB
Component: Climatic PQ35 090 0505
VCID: 688AB0A34E767FE7DA8-803C
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 Q HW: 3C0 937 049 Q
Component: Bordnetz-SG H46 1501
Revision: 00H46000 Serial number: 00000005468122
Coding: 008C0E0140041A00470A00000F00000000285D035C0000
Shop #: WSC 05311 123 12345
VCID: 372823DF5348201F832-8062
Subsystem 1 - Part No: 3C1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer VW461 012 0503
Coding: 00063445
Shop #: WSC 05311
Part No SW: 8E0 035 593 H HW: 8E0 035 593 H
Component: SDAR SIRIUS H06 0080
Revision: 00000000 Serial number: AUZ4Z7G0220909
VCID: 2E0606BBAC12E1D7D04-807A
Fault Frequency: 7
Reset counter: 196
Mileage: 117778 km
Time: 14:44:02
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 K HW: 3C0 909 605 K
Component: 0N AIRBAG VW8R 029 2521
Revision: 10029000 Serial number: 003A3P2W7PWA
Coding: 0012366
Shop #: WSC 05311 000 08193
Subsystem 1 - Part No: 3C0 959 339 A
Component: BF-Gewichtsens. 006 0002
Subsystem 2 - Serial number: 00000000032EPS
Subsystem 3 - Serial number: 0001.01.000000600000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332MSME0E716159Eÿ†63
Subsystem 5 - Serial number: 16159Eÿ†6342MSME105B60746ÿ†63
Subsystem 6 - Serial number: B60746ÿ†6351HTS64IKQTM627ÿ†63
Subsystem 7 - Serial number: QTM627ÿ†6361HTS6TLLE15C3Uÿ†63
Subsystem 8 - Serial number: E15C3Uÿ†63727TS63IK2T6C39ÿ†63
Subsystem 9 - Serial number: 2T6C39ÿ†63827TS63IKEPNQ25ÿ
Subsystem 10 - Serial number: EPNQ25ÿ
Part No SW: 3C0 953 549 H HW: 3C0 953 549 H
Component: J0527 0015
Revision: 00005000 Serial number: 3C9953507R
Coding: 0102014
Shop #: WSC 05311 000 00000
VCID: 313C1DC7BD2CFE2FCD6-8064
Part No SW: 1K0 920 954 F HW: 1K0 920 954 F
Component: KOMBIINSTRUMENT 3HL 1212
Revision: V0002000 Serial number: VWX7Z0G924F0W7
Coding: 0023203
VCID: 2F381BBFAB18E8DFDB2-807A
Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 31001065142381
Coding: 3F3F03600F002002
Shop #: WSC 00066 123 12345
VCID: 2C020CB39A0E93C7FE0-8078
Part No SW: 3C0 919 965 A HW: 3C0 919 965 A
Component: Kompass 001 0002
Revision: 00001000 Serial number: 1339817TQ3XP02
Component: IMMO 3HL 1212
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2801
Coding: 0001201
VCID: 36362EDB5442D917984-8062
Part No: 1K1 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
VCID: 333017CF4730CC3FBFA-8066
00003 - Control Module
014 - Defective
Part No SW: 3C0 959 433 C HW: 3C0 959 433 C
Component: KSG PQ46 RDK 041 0213
Revision: 00041000 Serial number: VWZCZ000000000
Coding: 1B900C88D103005200001414700A0F0E082800
Shop #: WSC 64713 001 104857
VCID: 2A0E0AAB90FA8DF70CC-807E
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001200
Part No SW: 1K0 035 180 L HW: 1K0 035 180 L
Component: Radio DE2 016 0020
Revision: 00016000 Serial number: VWZ4Z7G2175822
Coding: 0010400
VCID: 290CF5A795FC86EF056-807C
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 3C9 959 703 A
Component: Tuer-SG 021 2507
Coding: 0000144
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 3C9 959 704 A
Coding: 0000144
VCID: 323E12CBB82AC537B4C-8066
End----------(Elapsed Time: 01:09, VBatt start/end: 14.4V/14.3V)-----------
