I am trying to figure out what is causing my 2005 Audi A4 2.0T from starting. There is no start, not even attempting to crank even when hooked up to a battery. All of the accessories are working properly. Starter was replaced, fuses were replaced, noticed an access build up of water in the ECU, fuse panel under hood. I am waiting for a replacement however looking for input until it arrives.
Thank you !
Here is the auto-scan:
Thank you !
VIN: WAUDF68E75A460032 License Plate:
Mileage: 265020km-164675mi Repair Order:
67 69 75 76 77
VIN: WAUDF68E75A460032 Mileage: 265020km-164675miles
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 8E0 910 115 B HW: 8E0 907 115 C
Component: 2.0l R4/4V TFSI 0130
Revision: --H02--- Serial number:
Coding: 0104010A190F0120
Shop #: WSC 08174 444 83947
VCID: 200C139CF3FAE94438-8074
P0300 - 001 - - Intermittent
Fault Status: 00110001
Mileage: 264780 km
RPM: 997 /min
Load: 26.3 %
Temperature: 87.0°C
Temperature: 45.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 13.716 V
000770 - Cylinder 2
P0302 - 001 - Misfire Detected - Intermittent
Mileage: 264780 km
RPM: 810 /min
Load: 41.6 %
Speed: 3.0 km/h
Temperature: 87.0°C
Temperature: 39.0°C
Voltage: 13.589 V
000771 - Cylinder 3
P0303 - 001 - Misfire Detected - Intermittent
Mileage: 264886 km
RPM: 651 /min
Load: 40.0 %
Temperature: 93.0°C
Temperature: 13.0°C
Voltage: 13.462 V
001672 - ECM Power Relay Load Circuit
P0688 - 004 - Open Circuit
Mileage: 265022 km
Temperature: 21.0°C
Temperature: 23.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 0.000 V
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
Readiness: 0110 0101
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 8E1 910 156 A HW: 09L 927 156
Component: AG6 09L 2.0TFSI USA 0080
Revision: 00000001 Serial number: ÿÿÿÿÿÿÿ
Shop #: WSC 22122 444 00067
VCID: 25020288ECD80C6C4B-8070
18289 - Powertrain Data Bus: Missing Message
P1881 - 001 - Acceleration Request
Fault Status: 01110001
Reset counter: 40
Mileage: 265022 km
(no units): 30.0
(no units): 25.0
Temperature: 8.0°C
T.B. Angle: 60.0°
18258 - Powertrain Data Bus
P1850 - 000 - Missing Message from ECU
Fault Status: 01110000
Reset counter: 40
Mileage: 265022 km
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 C HW: 8E0 614 517 BB
Component: ESP8 quattro H04 0180
Coding: 0004528
Shop #: WSC 06335 000 00000
VCID: 271E088096D41E7C79-8072
Reset counter: 40
Hex Value: 0x0000
Hex Value: 0x4002
Hex Value: 0x00FF
Hex Value: 0xFF8C
Hex Value: 0x00FF
00493 - ESP-Sensor Unit (G419)
Reset counter: 40
Hex Value: 0x0000
Hex Value: 0x5002
Hex Value: 0x00FF
Hex Value: 0xFF61
Hex Value: 0x06FF
Fault Frequency: 14
Reset counter: 40
Hex Value: 0x0080
Hex Value: 0x0702
Hex Value: 0x00FF
Hex Value: 0xFF9E
Hex Value: 0x00FF
Fault Frequency: 16
Reset counter: 40
Hex Value: 0x0080
Hex Value: 0x0702
Hex Value: 0x00FF
Hex Value: 0xFFA2
Hex Value: 0x00FF
Part No: 8E0 820 043 AL
Component: A4 Klimaautomat 2731
Coding: 00000
VCID: 6B9634B01BBCFA1CDD-513C
01809 - Actuating Motor for Temperature Flap; Left (V158)
00532 - Supply Voltage B+
53-10 - Supply Voltage Too Low - Intermittent
27-00 - Implausible Signal
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 J
Component: int. Lastmodul USA 0303
Coding: 01023
Shop #: WSC 65536
VCID: 393ADEF82160988C1F-4B1E
Part No SW: 8E0 035 593 D HW:
Component: SDAR SIRIUS
Revision: Serial number: AUZ4Z7D1007668
VCID: 2A18F1B487C6231466-50F4
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 H HW: 8E0 959 655 H
Component: Airbag 9.41 H10 3230
Revision: 91H10323 Serial number: 0036N00053DA
Coding: 0032607
VCID: 3C34C7EC7F52ADA404-8068
Subsystem 1 - Part No: 8E0 910 339 B
Component: BF-Gewichtsens. 02 0070
Serial number: 6332DRB401308D95M
Coding: 00032607
Subsystem 2 - Serial number: 6342DRB4011393247
Subsystem 3 - Serial number: 6352ARB40040E7018
Subsystem 4 - Serial number: 6362ARB4003F64A9U
Subsystem 5 - Serial number: 63729RB400406A49G
Subsystem 6 - Serial number: 63829RB4004062EEO
01794 - Control Module - Incorrect Chassis (VIN) Number
Fault Status: 00110000
Fault Frequency: 31
Reset counter: 99
Fault Frequency: 41
Reset counter: 99
02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
014 - Defective - Intermittent - MIL ON
Fault Status: 10101110
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0601
Coding: 04041
Shop #: WSC 06335
VCID: 41CAB61849B0C04C57-4B1E
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 981 N HW: 8E0 920 981 N
Component: KOMBI+WFS 4 H12 0040
Revision: 0040 Serial number: 00000000000000
Coding: 0023201
Shop #: WSC 40816 444 83580
VCID: 383CDBFC4A6A8184E0-5160
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0023201
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
Part No: 8E0 959 760
Component: Sitzmemory R2 F 0305
Coding: 00002
VCID: 71AA26D83A9010CCE7-4AC2
79-00 - Please Check Fault Codes
Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
Part No SW: 8E0 035 192 D HW: 8E0 035 192 D
Component: RNS-E US3 H48 0150
Revision: 03S Serial number: AUZBZ5C0015892
Coding: 0309615
Shop #: WSC 24864 133 04061
VCID: 25020288EED80C6C4B-50F4
8 Faults Found:
Fault Frequency: 13
Reset counter: 81
Date: 2004.12.06
Time: 00:01:00
Voltage: 12.20 V
Fault Frequency: 26
Reset counter: 81
Date: 2004.12.06
Time: 00:00:30
Voltage: 12.20 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
02261 - Data Medium
014 - Defective
Fault Status: 01111110
Reset counter: 119
Date: 2014.08.28
Time: 16:26:53
Mileage: 655350 km
Count: 2905
Clock: 21:54
Fault Status: 00101011
Fault Frequency: 137
Reset counter: 81
Date: 2004.12.10
Time: 05:13:06
Mileage: 655350 km
Count: 612
Clock: 01:32
00852 - Loudspeaker(s); Front
Fault Frequency: 25
Reset counter: 144
Date: 2004.12.06
Time: 00:16:39
Reset counter: 239
Date: 2004.12.06
Time: 00:16:27
02446 - Disk Drive Mechanical Malfunction
Fault Status: 00100011
Fault Frequency: 15
Reset counter: 167
Date: 2016.07.01
Time: 17:05:31
02005 - Coding Pin
Reset counter: 239
Date: 2004.12.06
Time: 00:16:47
Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb
Part No: 8E0 959 433 BT
Component: Komfortgerát T7B 3132
Coding: 11896
Shop #: WSC 06335
VCID: 04447F0C162215643C-4B1E
Subsystem 1 - Part No: 8E1959801F
Component: Tõrsteuer.FS BRM 0305
Component: Tõrsteuer.BF BRM 0205
Subsystem 3 - Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0205
Subsystem 4 - Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0205
10 Faults Found:
35-00 - -
35-00 - -
35-00 - -
01373 - Alarm triggered by Radio Ground Contact
35-00 - -
37-10 - Faulty - Intermittent
Part No SW: 4F0 910 357 C HW: 4F0 907 357 C
Component: AFS 1 H01 0020
Coding: 0000019
Shop #: WSC 40816 444 85866
VCID: 2600058491DE077442-8072
Subsystem 1 - Part No: 8E0 941 329
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 8E0 941 329
Component: AFS-Modul rechtsH05 0030
Fault Status: 11100100
Fault Frequency: 65
Reset counter: 40
Address 56: Radio Labels: 8E0-035-192-RNSE.clb
Coding: 0309615
8 Faults Found:
Fault Frequency: 13
Reset counter: 81
Date: 2004.12.06
Time: 00:01:00
Voltage: 12.20 V
Fault Frequency: 26
Reset counter: 81
Date: 2004.12.06
Time: 00:00:30
Voltage: 12.20 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
02261 - Data Medium
014 - Defective
Reset counter: 119
Date: 2014.08.28
Time: 16:26:53
Mileage: 655350 km
Count: 2905
Clock: 21:54
Reset counter: 81
Date: 2004.12.10
Time: 05:13:06
Mileage: 655350 km
Count: 612
Clock: 01:32
Fault Frequency: 25
Reset counter: 144
Date: 2004.12.06
Time: 00:16:39
Reset counter: 239
Date: 2004.12.06
Time: 00:16:27
Fault Frequency: 15
Reset counter: 167
Date: 2016.07.01
Time: 17:05:31
02005 - Coding Pin
Reset counter: 239
Date: 2004.12.06
Time: 00:16:47
Part No SW: 8P0 862 335 AA HW: 8P0 862 335 S
Component: FSE_256x BT H34 0600
Revision: 00000000 Serial number: 00000005122588
Coding: 0011822
VCID: 75A212C81EF83CEC3B-50D0
Reset counter: 232
Time Indication: 15
Reset counter: 230
Time Indication: 15
End----(Elapsed Time: 04:42, VBatt start/end: 11.4V/11.3V. VIgn 11.2V)-----
