Audi a3 abs speed sensor
Kristian Hasa
Albania
C?ID=309376
Hello a audi a3 came into the shop and the owner said it has the abs light on i diagnosed it and it said the abs speed sensor has electrical fault in the circuit, i tried clearing the problem but it showd it again.I putted a new sensor in it and now it still shows the code after clearing the fault codes.
here a autoscan
Friday,22,June,2018,12:14:04:50280
VCDS Version: 18.2.1.2  HEX-NET CB: 0.4411.4
VIN: WAUZZZ8P85A069407   License Plate:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72 7D
VIN: WAUZZZ8P85A069407   Mileage: 229820km-142803miles
Address 01: Engine        Labels: 03G-906-016-BKD.clb
   Part No SW: 03G 906 016 FF    HW: 028 101 190 5
   Component: R4 2,0L EDC 0000SG  7364
   Revision: 12345678    Serial number: AUX7Z0D9FNE03Q
   Coding: 0000072
   Shop #: WSC 01455 264 89190
   VCID: EC949CEFCF4F1F246B-80B8
Readiness: 0 0 1 1 1
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0104
   Coding: 0023174
   Shop #: WSC 06435 000 00000
   VCID: BA386AB7F59B7194A9-80EE
00283 - ABS Wheel Speed Sensor; Front Left  (G47)
   Part No SW: 8P0 820 043 D    HW: 8P0 820 043 D
   Component: KlimavollautomatH12 0150
   Revision: 105816      Serial number: 8P0820043D
   Shop #: WSC 06314 000 00000
   VCID: AD1251EB34D5D62C3C-80F8
Address 09: Cent. Elect.        Labels:. 8P0-907-279-23-H.lbl
   Part No SW: 8P0 907 279 C    HW: 8P0 907 279 C
   Component: Bordnetz-SG     H34 0301
   Revision: 00H34000    Serial number: 00000001125484
   Coding: 05884F029214100000160000160000000000FE0F5C
   VCID: BD3261ABE4B546AC8C-80E8
   Subsystem 1 - Component: Fehler Lin-Slave 01
10 Faults Found:
02071 - Local Databus
00153 - Windshield Wiper Motor;  Driver Side (V216)
01800 - Light Switch (E1)
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
            009 - Open or Short to Ground
            010 - Open or Short to Plus
Address 15: Airbags        Labels: 8P0-959-655-94.lbl
   Part No SW: 8P0 959 655 C    HW: 8P0 959 655 C
   Component:    Airbag 9.41  H10 2620
   Revision: 91H10262    Serial number: 00362000PJU%
   Coding: 0033622
   VCID: C2C812579D4B3954F1-8096
   Subsystem 1 - Serial number: 6332DRB400DC0E96.
   Subsystem 2 - Serial number: 6342DRB400DC469B$
   Subsystem 3 - Serial number: 63528RB4002B166BH
   Subsystem 4 - Serial number: 63628RB4002B119FK
   Subsystem 5 - Serial number: 63729RB4002BA85BU
   Subsystem 6 - Serial number: 63829RB4002BA788U
   Part No SW: 1K0 953 549 A    HW: 1K0 953 549 A
   Component: Lenksäulenmodul 012 0030
   Coding: 0000012
   VCID: B02C489F23E7BBC417-80E4
   Part No SW: 8P0 920 930 K    HW: 8P0 920 930 K
   Component: KOMBIINSTR. VDO H71 0210
   Revision: D03         Serial number: 2249DD03035907
   Coding: 0004148
   Shop #: WSC 80093 222 69422
   Part No SW: 1K0 907 530 D    HW: 1K0 907 951
   Component: Gateway         H08 0100
   Revision: 08          Serial number: 2500104928044E
   Coding: 3D3F0B42072102
   VCID: A81CA0FF1B37F304CF-80FC
   Revision: D03         Serial number: AUX7Z0D9FNE03Q
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MAX1.lbl
   Part No: 8P0 959 801 F
   Component: Tuersteuerger.  H10 0030
   Coding: 0000120
   VCID: BE3066A7E9B35DB495-80EA
   Part No: 1K1 909 144 G
   Component: EPS_ZFLS Kl.10      1401
   VCID: AF2E4BE33ED9A43C0E-80FA
02546 - Steering Limit Stop
                    Mileage: 9800 km
                    Temperature: 29.0°C
                    Voltage: 12.30 V
                    Voltage: 12.00 V
   Part No: 8P0 959 433 E
   Component:    KSG          H04 0050
   Coding: 188000186D088505488F016000
   Part No SW: 8P4 035 382     HW: 8P4 035 382
   Component: AB2 SUBWOOFERBOXH02 0160
   Revision: 00001       Serial number: 10000001189632
   VCID: F1AA8D9BE86DF2CC58-80A4
Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MAX1.lbl
   Part No: 8P0 959 802 F
   Coding: 0000120
   VCID: BFCE1BA3EEB954BC9E-80EA
Address 56: Radio        Labels: 8P0-035-1xx-56.lbl
   Part No SW: 8P0 035 186 C    HW: 8P0 035 186 C
   Component: concert II EU   H51 0100
   Revision:      01S    Serial number: AUZ2Z3D1532145
   Coding: 0001001
   VCID: B22842972DEB89D461-80E6
Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
   Part No: 8P4 959 801 B
   Component: Tuer-SG         H10 0010
   Coding: 0000216
Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
   Part No: 8P4 959 802 B
   Coding: 0000216
   Revision: 00800000    Serial number:
End----------(Elapsed Time: 01:18, VBatt start/end: 12.3V/12.3V)-----------
looking at the steering assist it shows steering limit stop does it affect the speed sensor ?:confused: Thanks
iichel
Netherlands, eastern part
C?ID=284912
No, the Power steering DTC has nothing to do with the speed sensor. But it would be a good idea to fix this, while you're at it.
Turn the steering wheel from stop to stop for a few cycles, in an attempt to relief the steering limit error.
Check the wiring from ABS module to speed sensor for short circuits or interruptions and check connectors for water ingress.
Kristian Hasa
Albania
C?ID=309376
Okay thanks for the help i will check the wiring if i see anythings :)
Check ABS reluctor for FOD or damage or improper spin on hub unit!
Kristian Hasa
Albania
C?ID=309376
thanks for the help some workshop had made some mistakes in the wiring harness and the abs module was faulty we fixed the wiring and he went to change and code the abs module
Golftwincharged
Guyana
C?ID=320847
make sure the replacements are exact part numbers , with same ending Letters on part number, ive had issues and the sensor looked excatly same but numbers differ, hopw this helps.
