2009 audi Q5 3.0 tdi ccwa
stu@gep
C?ID=79638
VCDS Version: 18.2.0.3 (x64)
VIN: WAUZZZ8R19A038569   License Plate: EEN999W
Mileage: 127210km-79044mi   Repair Order:
Chassis Type: 8R-AU48 (8T0)
Scan: 01 02 03 05 08 09 0E 10 13 15 16 17 19 20 42 46 52 53 55 56
          57 5F 62 6C 6D 72
VIN: WAUZZZ8R19A038569   Mileage: 127210km-79044miles
Address 01: Engine (J623-CCWA)       Labels:| 059-907-401-V1.clb
   Part No SW: 8R0 907 401 J    HW: 8K1 907 401 A
   Component: 3.0TDI EDC17  H01 0008
   Revision: 15H01---
   Coding: 0121002C240F0220
   Shop #: WSC 06335 000 00000
   ASAM Dataset: EV_ECM30TDI0118R0907401J 001008
   ROD: EV_ECM30TDI0118R0907401J.rod
   VCID: 397D7DCBB8506B8C1F-806C
4807 - EGR System
          P0401 00 [232] - Insufficient Flow
                    Fault Frequency: 110
                    Mileage: 126487 km
                    Date: 2018.05.23
                    Time: 09:50:01
                    Engine speed: 1216.50 /min
                    Normed load value: 42.7 %
                    Vehicle speed: 76 km/h
                    Coolant temperature: 94 °C
                    Intake air temperature: 26 °C
                    Voltage terminal 30: 13.980 V
                    Crankshaft speed (RPM): 1346.0 /min
                    Vehicle speed: 52.38 km/h
                    Air Ctl m Gov Dvt: -258.4 mg/stroke
                    AFS dm: 132.1 kg/h
                    Inj Ctl q Curr: 14.73 mg/stroke
                    Charge air pressure: actual value: 1265 hPa
                    Intake air temperature: 21.1 °C
4875 - Coolant Pump 2
          P261A 00 [101] - Open circuit
                    Mileage: 126827 km
                    Date: 2018.06.01
                    Time: 21:27:05
                    Engine speed: 1312.50 /min
                    Normed load value: 53.7 %
                    Vehicle speed: 63 km/h
                    Coolant temperature: 93 °C
                    Voltage terminal 30: 13.820 V
                    Crankshaft speed (RPM): 1312.5 /min
                    Vehicle speed: 63.44 km/h
                    Field regeneration status-Bits 0-7: 00000000
                    Field regeneration status-Bits 0-7: 00000001
                    Mean injection quantity: 8.78 mg/stroke
                    Fuel temperature: 34.3 °C
                    Intake air temperature: 26.1 °C
                    Air Ctl st Air Ctl Bits-Bits 0-7: 00000000
Readiness: 1 1 0 0 0
   Part No SW: 8R0 927 156 D    HW: 0B5 927 156 D
   Component: 0B5 30 TDIRdW H02 0009
   Revision: --H02---    Serial number: 0000001358
   ASAM Dataset: EV_TCMDL501 A02044
   ROD: EV_TCMDL501.rod
   VCID: 3C7364DFB7625EA404-8068
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V1.clb
   Part No SW: 8R0 907 379 C    HW: 8R0 907 379 C
   Component: ESP8 quattro  H06 0230
   Coding: 0F5D00
   VCID: 408B102FD38A3A4458-8014
   Part No SW: 8K0 907 064 AQ    HW: 8K0 907 064 AQ
   Component: BCM2 1.1      H80 0145
   Coding: 051500
   VCID: 7F0953D3EEF485BC61-802A
   Subsystem 1 - Part No SW: 8K0 905 852 D    HW: 8K0 905 852 D
   Serial number: 0209000011453014
   Part No SW: 8T2 820 043 T    HW: 8T2 820 043 T
   Component: KLIMA 3 ZONEN H06 0150
   Revision: D1000000    Serial number: 01050320090855
   Coding: 36150000
   VCID: 43811F23C29C215C45-8016
   Part No SW: 8K0 907 063 D    HW: 8K0 907 063 D
   Component: BCM1 1.0      H24 0253
   Revision: 05024001    Serial number: 00000000334646
   Coding: 260050914074AF010001000300001D0D0F1D470800010141000000
   VCID: 306B40EF632AAAC4A8-8064
   Subsystem 1 - Part No SW: 8R2 955 119 A    HW: 8R2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 090129  H10 0041
   Serial number: 90243015081212195829
   Coding: 01DD13
   Component: RLS  H04 0003
   Serial number: 10403466
   Coding: 024D25
   Subsystem 3 - Part No SW: 8K0 941 531 AA    HW: 8K0 941 531 AA
   Component: E1 - LDS  H07 0090
   Serial number: 00000000000503090123
Address 0E: Media Player 1 (R41)       Labels: 4E0-910-111.lbl
   Part No SW: 4E0 910 110 L    HW: 4E0 035 110 A
   Component: CDC-MP3-Pana  H47 0050
   Revision: 00000012
   VCID: 214DB5AB38C0134C37-8074
Address 10: Park/Steer Assist (J446)       Labels:. 8K0-919-475.clb
   Part No SW: 8K0 919 475 G    HW: 8K0 919 475 A
   Component: PARKHILFE 8K  H06 0040
   Revision: 11001001    Serial number: 40040906409857
   Coding: 300108
   VCID: 3D7569DBA47857AC33-8068
Address 13: Auto Dist. Reg (J428)       Labels: Redir Fail!
   Part No SW: 8R0 907 561     HW: 8R0 907 561
   Component: ACC2          H01 0020
   Coding: 0079B6
   VCID: 76E7B6F7C1CEC4F432-8022
Address 15: Airbags (J234)       Labels:| 8R0-959-655.clb
   Part No SW: 8R0 959 655 B    HW: 8R0 959 655 B
   Component: AirbagVW-AU10 H03 0310
   Serial number: 003E8D03ALTF
   Coding: 30323131313030303030554A305238523053
   ASAM Dataset: EV_AirbaAU10SMEAU416 001001
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 43811F23CA9C215C45-8016
   Serial number: 6334MSME4474772DL
   Serial number: 6344MSME452349135
   Serial number: 6352QSME611B10164
   Serial number: 6362QSME2B1E4902L
   Serial number: 63732SME6B1C1600-
   Serial number: 63832SME2D1B501A0
   Part No SW: 8K0 953 568 G    HW: 8K0 953 568 G
   Component: Lenks.Modul   H15 0013
   Revision: --------    Serial number: 90319IC50008K
   Coding: 00003F
   VCID: 3E776ED7A97E4CB42A-806A
00886 - Turn Signal Switch (E2)
                    Fault Status: 00101110
                    Reset counter: 11
                    Mileage: 127166 km
                    Date: 2018.06.06
                    Time: 16:42:15
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 980 G    HW: 8R0 920 980 G
   Component: KOMBIINSTR.   H07 0224
   Revision: 00100000    Serial number: 9EX5513C8
   Coding: 2F0622000F002600010000
   Part No SW: 8T0 907 468 Q    HW: 8T0 907 468 L
   Component: GW-BEM 5CAN-M H10 0095
   Revision: FB600048    Serial number: 4800F092188394
   Coding: 000303
   VCID: 4FA923131ED4D53CD1-801A
   Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
   Component: J367-BDM  H07 0107
   Serial number: 00000000004140449592
            000 -  -  - Intermittent
                    Fault Frequency: 77
                    Reset counter: 13
                    Mileage: 118561 km
                    Date: 2017.10.21
                    Time: 07:35:00
   Part No SW: 8K0 857 511 C    HW: 8K0 857 511 A
   Component: FLA           H04 0003
   Revision: AA001002
   Coding: 02022064747464545425363E
   VCID: 316D45EB6820A3CCA7-8064
   Part No SW: 8K0 959 793 D    HW: 8K0 959 793 D
   Revision:             Serial number: 0000008603189
   Coding: 011D12205001440004
   VCID: 418D152BD880334C57-8014
   Revision: 00002001    Serial number: 0117129804
   Coding: 013B0E2220393481042005
   Part No SW: 8K0 959 792 D    HW: 8K0 959 792 D
   Revision:             Serial number: 0000008535932
   Part No SW: 8K0 907 801 G    HW: 8K0 907 801 G
   Component: EPB Audi B8   H08 0080
   Revision: 00000003    Serial number: 10000000193916
   VCID: 33614FE3923C91DCD5-8066
Address 55: Headlight Range        Labels: 8T0-907-357.clb
   Part No SW: 8H0 907 357 A    HW: 8H0 907 357
   Coding: 0000021
   Shop #: WSC 06334 000 00000
   VCID: 306B40EFA32AAAC4A8-8064
   Component: AFS-Modul links H07 0004
   Subsystem 2 - Part No: 7L6 941 329 A
   Component: AFS-Modul rechtsH07 0004
   Part No SW: 4F0 035 061 B    HW: 4F0 035 061
   Component: Radio U DAB   H45 0020
   Revision: AB001007    Serial number: 343CN097518050
   Coding: 010103020100000001
   VCID: 1B3187431AAC399CED-804E
Address 57: TV Tuner (R78i)       Labels: None
   Part No SW: 4F0 919 129 B    HW: 4F0 919 129
   Component: HybridTV-DVB  H06 0230
   Revision: R0060000    Serial number: 76300802126201
   Coding: 03020000
   VCID: 2B5157834A0CC91C9D-807E
   Part No SW: 8T2 035 670 D    HW: 8T2 035 670
   Component: H-BNT-EU      H64 0047
   Revision: --------    Serial number: 329CV097514283
   Coding: 010101060105A9EF21000B1E000000030000
   VCID: 37797BF386447DFCE9-8062
   Subsystem 1 - Part No: 8R0 060 884 C
   Component: EUROPE 2008  5608
   Subsystem 2 - Part No SW: 4F0 919 604     HW: 4F0 919 604
   Component: DU7 High  H43 0306
   Serial number: 9356CM091071516
   Subsystem 3 - Part No SW: 8T0 919 609 G    HW: 8T0 919 609 G
   Component: E0380 Bedient  H08 0100
   Serial number: 00000000247060
   Part No SW: 4F0 959 795 M    HW: 8K0 959 795 B
   Revision:             Serial number: 0000008523501
   Coding: 010C12204001240004
                    Fault Frequency: 48
                    Reset counter: 14
                    Mileage: 120315 km
                    Date: 2017.12.06
                    Time: 10:58:51
   Part No SW: 8R0 907 441     HW: 4L0 907 441 A
   Component: J772__Rearview      0070
   Revision: --H12---    Serial number: 525PA8-J91A0L4
   Coding: 1022010
   VCID: 73E18FE312BCD1DC15-8026
   Part No SW: 8R0 827 851 A    HW: 8R0 827 851
   Component: J605  Master  H27 0290
   Revision: --------    Serial number: 8R0827851
   VCID: 3A7F62C7B556609416-806E
   Subsystem 1 - Part No SW: 8R0 827 852 A    HW: 8R0 827 852
   Component: J756  Slave  H27 0290
   Serial number: 8R0827852
   Revision:             Serial number: 0000008521798
                    Fault Frequency: 43
                    Reset counter: 230
                    Mileage: 121379 km
                    Date: 2017.12.19
                    Time: 10:34:33
End-------------------------(Elapsed Time: 04:09)--------------------------
Hi i was wondering if anybody could help with an intermittant egr flow fault im having on this Q5
The egr valve has been replaced and as much pipe work as we could has been cleaned. After clearing the system the fault can take several weeks to return and normaly on a long journey. Also does anyone know where to locate coolant pump 2. Thanks any info would be great.
Moved from Forum Support & Feedback to Car Repair Support.
