Sunday,17,June,2018,18:18:41:40315
VCDS Version: 18.2.1.2 (x64) HEX-V2 CB: 0.4422.4
Dealer/Shop Name: w h enterprise
VIN: WAUZZZ8V7EA051852 License Plate: BF63YNW
Mileage: 61329km-38108mi Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F BB BC
VIN: WAUZZZ8V7EA051852 Mileage: 61329km-38108miles
Address 01: Engine (J623-CLHA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 N HW: 04L 907 309 B
Component: R4 1,6L EDC H22 5518
Revision: 84H22---
Coding: 02250032032501092000
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM16TDI01104L906021N 002009
ROD: EV_ECM16TDI01104L906021N_002.rod
VCID: 3039EC84DAAA8437C17-8064
U0428 00 [039] - -
Mileage: 61329 km
Date: 2018.04.06
Time: 01:51:53
Engine speed: 769.50 /min
Normed load value: 35.3 %
Coolant temperature: 96 °C
Intake air temperature: 76 °C
Voltage terminal 30: 13.440 V
17158 - Databus
U1123 00 [039] - Received Error Message
Mileage: 61329 km
Date: 2018.04.06
Time: 01:51:53
Engine speed: 771.50 /min
Normed load value: 34.9 %
Voltage terminal 30: 13.460 V
Drivetrain coordinator: brake fault status-Bits 0-7: 5
Drivetrain coordinator: brake function status-Bits 0-7: 0
Drivetrain coordinator: brake function status-Bits 0-7: 4
Acceleration: 0.000 m/s²
Part No SW: 0CW 300 045 L HW: 0AM 927 769 G
Component: GSG DQ200-MQB H43 4506
Revision: 00043014 Serial number: CU501308056901
Shop #: WSC 17734 418 534600
ROD: EV_TCMDQ200021_VW27.rod
VCID: 42DDB64C640606A7273-8016
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 62193000000AB8
Coding: 12F18AA224250A6D017F060541C52548512450806082A4F20241F0788508
ROD: EV_Brake1UDSContiMK100IPB_033_AU37.rod
VCID: 7BA30BA8436CB76F245-802E
0143 - ABS/ESP Control Module
U10C5 00 [137] - No or Incorrect Basic Setting
[valve calibrating data missing]
Reset counter: 26
Date: 2018.04.06
Time: 01:51:52
0295 - Steering angle sensor
Reset counter: 26
Date: 2018.04.06
Time: 01:51:52
8277 - Databus
U1122 00 [009] - Implausible Message
[FCAN: EPS_DSR_Status signal is invalid]
Reset counter: 26
Date: 2018.04.06
Time: 01:51:52
8299 - Databus
[FCAN: Anhaenger_01_alt veraltet bit is set]
Reset counter: 26
Date: 2018.04.06
Time: 01:51:52
Reset counter: 26
Mileage: 61329 km
Date: 2018.04.06
Time: 01:52:01
Part No SW: 8V0 820 043 A HW: 8V0 820 043 A
Component: AC Automat H13 0031
Revision: 20023000 Serial number: 00000000132240
Coding: 03100104002000011000000000001100
ASAM Dataset: EV_AirCondiFrontVaAU37X 008016
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 9778CFB6000000000001
262914 - Refrigerant Pressure
B10AB F0 [009] - Too Low
Reset counter: 26
Mileage: 61329 km
Date: 2018.04.06
Time: 01:51:51
Outside air temperature: 41.5 °C
Engine speed: 771.00 /min
Temperature after evaporator: 31.9 °C
Refrigerant pressure: 1.2 bar
System run time-Terminal 15 on: 79 s
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 T HW: 5Q0 937 084 T
Component: BCM MQBAB M+ H14 0112
Serial number: 00011321002628
Coding: 07001846C24102FD03844004B31407A80000000000000000000000000000
ROD: EV_BCMBOSCH_011.rod
VCID: 49CFA1605930D5FFE69-801C
Subsystem 1 - Part No SW: 8V2 955 119 A HW: 8V2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 130715 041 0580
Serial number: 130802135812
Coding: 0A47F7
Component: G397_RLFS H06 0002
Serial number: 21583462
Coding: 00006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 Q HW: 8V0 941 531 Q
Component: E1 - LDS MQB H05 0032
Serial number: 31 05 2013 00001168
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY1317700D4
Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000057082965
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5Q0 919 298 B HW: 5Q0 919 298
Component: PARKHILFE PLA H11 0033
Revision: -------- Serial number: 61131322101806
Coding: 0110060051
ASAM Dataset: EV_EPHVA2CAU3700000 003015
ROD: EV_EPHVA2CAU3700000_003_AU37.rod
VCID: 3E25C2BC10FE624743B-806A
13637426 - Databus
Reset counter: 26
Mileage: 61329 km
Date: 2018.04.06
Time: 01:51:51
13697025 - Control Module
U110F 00 [009] - I'm sorry Dave; I'm afraid I can't do that!
[Steuergerät für Lenkhilfe-J500 - LH_EPS_01.EPS_PLA_Status - PLA-Codierung in Lenkhilfe prüfen]
Reset counter: 26
Mileage: 61329 km
Date: 2018.04.06
Time: 01:51:51
Part No SW: 5Q0 959 655 N HW: 5Q0 959 655 N
Component: AirbagVW20 011 0361
Serial number: 003M2R02SGY5
VCID: 4BC39B68534CC7EFD45-801E
Subsystem 1 - Part No SW: ----------- HW: 480 000 208 13
Serial number: 357670000006B23DCC01
Subsystem 2 - Part No SW: ----------- HW: 480 000 208 13
Serial number: 358670000000D23DCC0+
Subsystem 3 - Part No SW: ----------- HW: 480 400 908 13
Serial number: 35165029B1074480D2A5
Subsystem 4 - Part No SW: ----------- HW: 480 400 908 13
Serial number: 35265029B107448552B4
Subsystem 5 - Part No SW: ----------- HW: 480 401 107 13
Serial number: 3556502B5106FA4062CC
Pedestrian Protection Driver:
Subsystem 6 - Part No SW: ----------- HW: 480 401 307 13
Component: PedP_Sensor_D 001 6149
Serial number: 2286502BD107DB54808K
Subsystem 7 - Part No SW: ----------- HW: 480 401 106 15
Component: PedP_Sensor_P 001 6149
Serial number: 2296502AF1B5A883B2AY
Pedestrian Protection Center:
Subsystem 8 - Part No SW: ----------- HW: 480 401 106 15
Component: PedP_Sensor_C 001 6149
Serial number: 2306502B11B5A8808241
9439002 - Igniter for Seat Belt Tensioner; Passenger's Side
B1007 1A [137] - Resistance Too Low
Mileage: 61329 km
Date: 2018.04.06
Time: 01:51:52
Mileage: 61329 km
Date: 2018.04.06
Time: 01:51:52
9451547 - Igniter 1 for pedestrian protection
B1038 1B [136] - Resistance Too High
Mileage: 61329 km
Date: 2018.04.06
Time: 01:51:53
Part No SW: 8V0 953 521 B HW: 5Q0 953 549 A
Component: Lenks. Modul 007 0070
Revision: -------- Serial number: 12081308490249
Coding: A418
ROD: EV_SMLSKLOMQB_013_AU37.rod
VCID: 392FD1A009D0457F769-806C
Part No SW: 8V0 920 970 N HW: 8V0 920 970 N
Component: KOMBI H03 2211
Coding: 27A40A08239046000100E800000000
VCID: 47CBA7584F24238FF0D-8012
Part No SW: 5Q0 907 530 L HW: 5Q0 907 530 E
Component: GW MQB Mid 124 1144
Revision: -------- Serial number: 0000899518
Coding: 030100040B0876005B0002481C0B00000001000000000000000000000000
ASAM Dataset: EV_GatewLear 009013
ROD: EV_GatewLear_009_VW37.rod
VCID: 3A2DCEAC0CD64E677F3-806E
Subsystem 2 - Part No SW: 8U0 951 528 C HW: 8U0 951 528 C
Component: E221 - MFL H02 0014
Serial number: 01 08 2013 D0282700
Subsystem 3 - Part No SW: 5Q0 915 181 D HW: 5Q0 915 181 D
Component: J367-BDM H08 0192
Serial number: 00000000004051820217
Part No SW: 5Q0 959 593 A HW: 5Q0 959 593
Component: TSG FS 012 0006
Serial number: 16071306070407
Coding: 00108E205C01040000001002
VCID: 3FDBBFB817F46B4F48D-806A
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 M
Component: EPS_MQB_ZFLS 127 1021
Coding: 80
ROD: EV_SteerAssisMQB_008.rod
VCID: 3D27C5B01DF8795F5A1-8068
15873 - Steering angle sensor
Reset counter: 26
Mileage: 61329 km
Date: 2018.04.06
Time: 01:51:51
Motor status: 01
System status: Driving mode
Supply voltage: 13.25 V
Temperature: 40.0 °C
KFC: 3E
KFA: 00 01
Environmental conditions: 5F
uAdSensI_U5VFiltered_xdu16: 5.07331 V
uioUdNotFilt_xdu16: 13.22 V
uAdSensI_SwitchedKl30_xdu16: 13.21 V
ASC_CTRL_GET_ILWS_ERR_FLAGS: 14
Part No SW: 5Q0 959 592 A HW: 5Q0 959 592
Component: TSG BFS 012 0006
Serial number: 27071303110009
Coding: 001086205E01040000001002
Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-STD1.clb
Part No SW: 8V0 035 874 B HW: 8V0 035 874 B
Component: MU-S-ND-ER 040 0420
Serial number: A7F02507131486
Coding: 01730301FF00000021111101000A00002F0004460100010006
ASAM Dataset: EV_MUStd4CPASE 002018
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 3B23CBA803EC776F645-806E
Subsystem 1 - Part No SW: 8V0 919 603 A HW: 8V0 919 603 A
Component: DU Std H48 0013
Serial number: AUZ8Z9DG6021HL
Multimedia Operating Unit:
Subsystem 2 - Part No SW: 8V0 919 614 B HW: 8V0 919 614 B
Component: ControlUnit_B H33 0037
Serial number: C1000022061300010928
Part No SW: 5Q0 959 595 A HW: 5Q0 959 595
Component: TSG HFS 010 0006
Serial number: 25071302090039
Coding: 000086204001040000001002
VCID: 41DFB94061001DBF3E9-8014
Component: TSG HBFS 010 0006
Serial number: 25071304080038
End----------(Elapsed Time: 01:28, VBatt start/end: 12.8V/12.8V)-----------
