- Joined
- Aug 17, 2015
- Messages
- 25
- Reaction score
- 4
- Location
- Netherlands
- VCDS Serial number
- C?ID=254125
Hi all,
In the past few months i did some extra retrofits ( see auto scan ! )
They are all working fine ( allmost then ) but the last thing to do is code the new ABS module.
With a few friend and some long coding helping labels we tried some coding but all not working.
Is there a smarter person that could help me out with the flashing lights on the dashboard, that gets me crazy when driving
Here is the Auto scan, did remove some unnecessary error messages that are irrelevant for this problem
Part No SW: 1K0 907 379 BS HW: 1K0 907 379 BS
Component: ESP MK60EC1 H46 0166
Revision: 00H46001
Coding: 0000000000000000000000000000000000000000
Shop #: WSC 19427 133 00001
VCID: 04444230879646643C-8050
Revision: 00H46001
Thursday,07,June,2018,21:03:15:36185
VCDS Version: 18.2.0.3 HEX-NET CB: 0.4422.4
Dealer/Shop Name: 7
VIN: WVWGD7AJ9BW289978 License Plate:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 25 2B 3C 42 44 46 47 52
55 5F 62 65 69 72 A5
VIN: WVWGD7AJ9BW289978 Mileage: 56850km-35324miles
17-Instruments -- Status: Status: OK 0000
Address 01: Engine (CBF) Labels:. 06J-907-115-CBF.clb
Part No SW: 1K0 907 115 AT HW: 1K0 907 115 AK
Component: 2.0l R4/4V TFSI 0040
Revision: E3H25--- Serial number:
Coding: 040301081C070960
Shop #: WSC 00191 264 15243
VCID: 78BC26C00B5E128420-802C
10 Faults Found:
002129 - Park/Neutral Switch Input Circuit
P0851 - 000 - Short to Ground - MIL ON
008568 - Bank 1; System Too Rich off Idle
P2178 - 000 - - Intermittent
000257 - Mass Air Flow Sensor (G70)
P0101 - 000 - Implausible Signal - MIL ON
U1017 - 007 - - Intermittent
049441 - No Communication with ABS Brake Control Module
U0121 - 000 - - Intermittent
Readiness: 0010 1100
Part No SW: 02E 300 057 C HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2716
Revision: 05351113 Serial number: 00001105300653
VCID: 197A0344D014EB8CFF-804C
Revision: 00H46001
Reset counter: 73
Date: 2018.06.07
Time: 20:11:04
Count: 2
Count: 12
Count: 20992
Count: 195
Count: 48896
Count: 65280
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 A HW: 5K0 959 434 A
Component: VWKESSYPQ35GP 085 0802
Revision: 00085000 Serial number: 0144798723
Coding: 030C1C
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_KESSY_PQ35GP A01018
ROD: EV_KESSY_PQ35GP.rod
VCID: 3326D1EC9AB831DCD5-8066
Part No SW: 1K8 907 044 AC HW: 1K8 907 044 AC
Component: Climatronic H05 0304
Revision: 00001K03
Coding: 001801C002
Shop #: WSC 00219 123 12345
VCID: 70AC1EE0AB2E4AC4E8-8024
Part No SW: 5K0 937 087 Q HW: 5K0 937 087 Q
Component: BCM PQ35 H+ 111 0148
Revision: BL111001
Coding: 67080AB7EC33E5C41058028970000B8443FD0011557D8D90E4806824A040
VCID: 43C6812CC218815C45-8016
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 11031 26 0512
Coding: 009FB5
Component: RLS 070712 05 54 0403
Coding: 0730AD
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 1K8 919 475 D HW: 5Q0 919 298
Component: PARKHILFE PLA 011 0480
Coding: 0031167111
Shop #: WSC 00099 780 00200
ASAM Dataset: EV_EPHVA2CVW364GP00 001010
ROD: EV_EPHVA2CVW364GP00_VW36.rod
VCID: 3B36F9CCB2E8F99C0D-806E
12658720 - Databus
[Steuergerät für elektrische Park-/Handbremse-J540 - mEPB_1 - kein Signal/keine Kommunikation]
Reset counter: 73
Mileage: 56854 km
Date: 2018.06.07
Time: 20:11:05
Address 14: Susp. Elect. (J250) Labels:. 3C0-907-376.clb
Part No SW: 3C0 907 376 HW: 3C0 907 376
Component: DAEMPFUNGS-SG H07 0069
Revision: 00000000 Serial number: 13020800690002
Coding: 000180
Shop #: WSC 00219 000 00000
VCID: 668078B891EA947482-8032
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 73
Mileage: 56854 km
Date: 2018.06.07
Time: 20:32:40
Bin. Bits: 00000000 00001000
Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
Component: AirbagVW10G 021 0706
Serial number: 003C4R02280F
Coding: 00003031
ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 393AE3C4B8D4CB8C1F-806C
Subsystem 1 - Part No SW: 5K0 959 339 HW: 5K0 959 339
Component: BF-Gewichtss. 007 0002
Serial number: ---0000R--0005LPJ600
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME4532205DZZZR
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME402E255DZZZ$
Serial number: 3512QSME7419077CZZZ
Serial number: 3522QSME5658097BZZZ0
Component: F.Sens.Fahr --- ----
Serial number: 35527SME6C617526ZZZL
Component: F.Sens.Beif --- ----
Serial number: 35627SME1C617526ZZZH
Part No SW: 5K0 953 521 BR HW: 5K0 953 569 E
Revision: FF010040 Serial number: 20110329301698
Coding: 1012100000
ROD: EV_SMLSNGVOLWS.rod
VCID: 7DB237D4EC7C37AC73-8028
Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H06 0010
Coding: 830000
Part No SW: 1K8 920 885 H HW: 1K8 920 885 H
Component: KOMBI H04 1018
Coding: 171E230000
Shop #: WSC 00020 999 12345
VCID: 3C34FAD0B7E6FEA404-8068
Part No SW: 7N0 907 530 BL HW: 7N0 907 530 AN
Component: J533 Gateway H56 1682
Revision: H56 Serial number: 21041600F13292
Coding: 350002
VCID: 7BB639CCFA68399C4D-802E
Component: IMMO H04 1018
Coding: 000007
VCID: 6A980C888DF2B014A6-803E
Address 2B: Steer. Col. Lock (J764) Labels:| 5K0-905-861.clb
Part No SW: 5K0 905 861 A HW: 5K0 905 861 A
Component: ELV-PQ35 H20 0230
Revision: 00000000 Serial number: 11000077897004
Coding: 4900000000000000
ROD: EV_ELVMarquMPVW36X.rod
VCID: 2E10C098719A1C34BA-807A
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 B HW: 5Q0 907 686 B
Component: HRE_Master H11 0071
Serial number: 0367435529
Coding: 02012102
Shop #: WSC 00046 123 12345
ROD: EV_HREntryHella_VW27.rod
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 5Q0 907 685 B HW: 5Q0 907 685 B
Component: HRE_Slave H11 0071
Serial number: 0366681323
Coding: 020121
Part No SW: 5K0 959 701 C HW: 5K0 959 701 C
Component: Tuer-SG 009 2120
Coding: 0005366
Shop #: WSC 80093 222 69422
VCID: 3228D4E8ADA238D4DE-8066
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 183 3201
Revision: 00H20000
VCID: 3424D2F057B636E4CC-8060
Part No SW: 5K0 035 456 HW: 5K0 035 456
Component: KonzernAmp 8K H06 0340
Revision: -------- Serial number: BP218109117144
VCID: 679E75BC9EE08D7CB9-8032
Part No SW: 5K0 959 702 E HW: 5K0 959 702 E
Component: Tuer-SG 009 2151
Coding: 0005622
Shop #: WSC 46651 001 104857
VCID: 3522EFF45CCC2FECFB-8060
Component: AFS-Steuergeraet 0148
Coding: 1477724
Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l 0004
Coding: 00000022
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0004
Coding: 00000022
Part No SW: 5L0 035 680 E HW: 5L0 035 680 E
Component: MU-S-ND-ER X72 X346
Serial number: SKZAZ2R1995438
Coding: 03130601AA00000011111105C0880A021F0807C400210100CF
Shop #: WSC 12345 102 209715
ROD: EV_MUStd4CTSAT_VW36.rod
VCID: 2C14CA9047866E2494-8078
7 Faults Found:
1543 - Control Module Incorrectly Coded
U1014 00 [009] - -
Reset counter: 73
Mileage: 56854 km
Date: 2018.06.07
Time: 20:38:32
Voltage terminal 30: 11.6 V
Byte_Coding_Condition-byte_0_condition: OK
Byte_Coding_Condition-byte_1_condition: OK
Byte_Coding_Condition-byte_10_condition: ERROR
Byte_Coding_Condition-byte_11_condition: ERROR
Byte_Coding_Condition-byte_12_condition: ERROR
Byte_Coding_Condition-byte_13_condition: ERROR
Byte_Coding_Condition-byte_14_condition: ERROR
Byte_Coding_Condition-byte_15_condition: ERROR
Byte_Coding_Condition-byte_16_condition: ERROR
Byte_Coding_Condition-byte_17_condition: ERROR
Byte_Coding_Condition-byte_18_condition: ERROR
Byte_Coding_Condition-byte_19_condition: ERROR
Byte_Coding_Condition-byte_2_condition: OK
Byte_Coding_Condition-byte_20_condition: ERROR
Byte_Coding_Condition-byte_21_condition: ERROR
Byte_Coding_Condition-byte_22_condition: ERROR
Byte_Coding_Condition-byte_23_condition: ERROR
Byte_Coding_Condition-byte_24_condition: ERROR
Byte_Coding_Condition-byte_25_condition: ERROR
Byte_Coding_Condition-byte_26_condition: ERROR
Byte_Coding_Condition-byte_27_condition: ERROR
Byte_Coding_Condition-byte_3_condition: OK
Byte_Coding_Condition-byte_4_condition: OK
Byte_Coding_Condition-byte_5_condition: OK
Byte_Coding_Condition-byte_6_condition: OK
Byte_Coding_Condition-byte_7_condition: OK
Byte_Coding_Condition-byte_8_condition: OK
Byte_Coding_Condition-byte_9_condition: OK
B201A 00 [009] - -
Reset counter: 73
Mileage: 56854 km
Date: 2018.06.07
Time: 20:38:32
Status_Software_Version_Management-module_name:
13697024 - Component Protection
U1100 00 [009] - No Basic Setting
[Anti-theft protection - component protection: no basic setting or basic setting incorrect]
Reset counter: 73
Mileage: 56854 km
Date: 2018.06.07
Time: 20:38:32
U1101 00 [009] - Active
[Anti-theft protection - component protection active (0xEA6200)]
Reset counter: 73
Mileage: 56854 km
Date: 2018.06.07
Time: 20:38:32
0011 - Digital Radio Antenna
B1103 13 [009] - Open Circuit
Reset counter: 73
Mileage: 56854 km
Date: 2018.06.07
Time: 20:59:05
Voltage terminal 30: 13.1 V
Status of digital radio antenna 1-Antenna current: 0 mA
Status of digital radio antenna 1-Connection between radio and antenna amplifier: Open circuit
Status of digital radio antenna 1-Connection between antenna amplifier and antenna: Not available
Status of digital radio antenna 1-DAB_Bit_Error_Rate_FIC: 0.000000
Status of digital radio antenna 1-DAB_Bit_Error_Rate_MSC: 0.000000
1552 - Expanded Bus Activity Active
U1104 00 [009] - -
Reset counter: 73
Mileage: 56854 km
Date: 2018.06.07
Time: 20:38:32
U11B8 00 [009] - No Communications
[USB - communication error]
Reset counter: 73
Mileage: 56854 km
Date: 2018.06.07
Time: 20:38:33
Interface for external media: status-Status: Open circuit
Part No SW: 5K0 959 703 D HW: 5K0 959 703 D
Component: Tuer-SG 007 2101
Coding: 0001232
Shop #: WSC 01357 011 1012552
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 H HW: 5Q0 907 273
Component: RDKBERU30 H04 0012
Serial number: 30000000035684
ROD: EV_RDKBERU30_006_VW36.rod
8397058 - Front Left TPMS Sensor
C1050 31 [009] - No Signal
Reset counter: 136
Mileage: 49670 km
Date: 2017.11.29
Time: 19:11:05
Vehicle speed: 90 km/h
Outside air temperature: 2.0 °C
Reception level antenna 1: 620 mV
Offset level antenna 1: 300 mV
8397314 - Front Right TPMS Sensor
C1051 31 [009] - No Signal
Reset counter: 136
Mileage: 49670 km
Date: 2017.11.29
Time: 19:11:05
Reception level antenna 1: 640 mV
8397570 - Rear Left TPMS Sensor
C1052 31 [009] - No Signal
Reset counter: 136
Mileage: 49670 km
Date: 2017.11.29
Time: 19:11:05
Reception level antenna 1: 630 mV
8397826 - Rear Right TPMS Sensor
C1053 31 [009] - No Signal
Reset counter: 136
Mileage: 49670 km
Date: 2017.11.29
Time: 19:11:05
Reception level antenna 1: 650 mV
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: Anhaenger H09 0100
Revision: 3A001001 Serial number: 00000147679016
Coding: 010D000202000000
VCID: 302CDEE063AE0AC4A8-8064
Part No SW: 5K0 959 704 D HW: 5K0 959 704 D
Coding: 0001232
VCID: 3620E8F841CA24F4F2-8062
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3AA-980-654.clb
Part No SW: 3AA 980 654 D HW: 3AA 980 654 A
Component: MFK_Gen1 H08 0300
Serial number: 0185616805
Coding: 010001000102020F0200040001010000
Shop #: WSC 06745 128 28888
ASAM Dataset: EV_47X 001639
ROD: EV_47X.rod
2621440 - Databus
[ERR_CAN_PSD_01_TIMEOUT]
Reset counter: 73
Mileage: 56854 km
Date: 2018.06.07
Time: 21:02:56
2686976 - Databus
[ERR_CAN_PSD_02_TIMEOUT]
Reset counter: 73
Mileage: 56854 km
Date: 2018.06.07
Time: 21:02:56
4456448 - Databus
[ERR_CAN_CAN_MBREMSE_5_ERROR]
Reset counter: 73
Mileage: 56854 km
Date: 2018.06.07
Time: 21:02:56
End----------(Elapsed Time: 01:51, VBatt start/end: 13.7V/13.7V)-----------
