Greetings
2008 Jetta 2.5 with Red steering failure light
-yellow light once occurred a few weeks ago, but went away
-stock, unrelated evap solenoid replaced some time between yellow and red lights
What I have done:
-Ran Auto Scan
-started the forum search process
-measured battery voltage11.38 12.38v
-checked F2 on distribution box
-removed battery/battery box (before scan) to physically inspect rack harness
Looking for VCDS pointers to distinguish/troubleshoot between rack failure and other failure modes.
Thank you
What I have done:
-Ran Auto Scan
Thank you
Thursday,14,June,2018,18:43:36:60407
VCDS Version: 18.2.1.2 (x64) HEX-V2 CB: 0.4411.4
VIN: 3VWRM71K58M124341 License Plate:
Mileage: 281290km-174785mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 65 72
VIN: 3VWRM71K58M124341 Mileage: 281290km-174785miles
Address 01: Engine (CBT) Labels: 06A-906-032-BGP.lbl
Part No SW: 07K 906 032 BJ HW: 07K 906 032 Q
Component: 2,5l R5/4V G 1567
Revision: 1NH01--- Serial number: VWX7Z0H024D091
Coding: 0000003
VCID: 72BD267B28A19EE7773-8026
Readiness: 0110 1101
Part No SW: 09G 927 750 HE HW: 09G 927 750 HE
Component: AQ 250 6F 1090
Revision: 00H69000 Serial number:
Coding: 0000584
VCID: 7BA30B5F7FEBDFAF245-802E
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Revision: 00H11001
Coding: 0021122
VCID: 73B3237F57BB97EF7C5-8026
Part No SW: 1K0 820 047 HJ HW: 1K0 820 047 HJ
Component: Climatic PQ35 141 1010
Revision: 00141028 Serial number: 00000000000000
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-M.lbl
Part No SW: 3C0 937 049 AH HW: 3C0 937 049 AH
Revision: 00H54000 Serial number: 00000000838405
Coding: 14058E234004150007140000001400000008730B5C000100000000000000
VCID: 6FBB2F0F3B93B30F98D-803A
Component: Wischer 280108 021 0501
Coding: 00038805
Shop #: WSC 00066
01505 - Bulb for Blinkers; Rear Right (M8)
Fault Status: 00101100
Reset counter: 229
Mileage: 280314 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 13.70 V
Part No SW: 8E0 035 593 H HW: 8E0 035 593 H
Component: SDAR SIRIUS H06 0080
Revision: 00000000 Serial number: AUZ4Z7H0239842
VCID: 2E05F20BFC19FA07D3B-807A
Fault Frequency: 64
Reset counter: 127
Mileage: 278260 km
Time: 07:11:04
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 6A AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6M04763J
Coding: 0013889
VCID: 6C8138030A854817BDF-8038
Subsystem 2 - Serial number: 6332MSME195023270
Subsystem 3 - Serial number: 6342MSME19504C57F
Subsystem 4 - Serial number: 6351HSME127B51374
Subsystem 5 - Serial number: 6361HSME10174511V
Subsystem 6 - Serial number: 63727SME122B1E71%
Subsystem 7 - Serial number: 63827SME12350F4E5
00532 - Supply Voltage B+
Part No SW: 1K0 953 549 BF HW: 1K0 953 549 BF
Component: J0527 051 0100
Coding: 0010021
VCID: 77AB176F43C3FBCF40D-8022
00576 - Terminal 15
00885 - Ignition Switch (D) Terminal 50
Part No SW: 1K0 920 954 Q HW: 1K0 920 954 Q
Component: KOMBIINSTRUMENT 3HL 1212
Revision: V0002000 Serial number: VWX7Z0H024D091
Coding: 0023203
VCID: 3A2DCE5B305126A77F3-806E
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533 Gateway H07 0052
Revision: H07 01 Serial number: 101207F2001561
Coding: ED807F070003021002
VCID: 3039EC73E62DECF7C17-8064
Component: IMMO 3HL 1212
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1133
Revision: 32008001 Serial number: 00000033588106
Coding: 0001205
VCID: 3B23CB5F3F6B1FAF645-806E
Reset counter: 5
Mileage: 227934 km
Fault Status: 00111000
Reset counter: 5
00105 - Signal Central Locking SAVE/LOCK Drivers Side
Reset counter: 5
Mileage: 212387 km
01030 - Central Locking Key Switch; Driver Side; Lock
Fault Frequency: 12
Reset counter: 5
Mileage: 279451 km
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.070 H08 1901
VCID: 3537DD67194FC9DF921-8060
00569 - Steering Motor Current
Mileage: 281290 km
Temperature: 25.0°C
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
Component: KSG PQ35 RDK 052 0221
Revision: 00052000 Serial number: 00000000000000
Coding: 13900F880186281B0904058FB0880F0488DCA0
VCID: 045170A30215A05755F-8050
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1133
Revision: 32008001 Serial number: 00000095588109
Coding: 0001204
VCID: 3C21C8433A6518976DF-8068
Part No SW: 1K0 035 180 L HW: 1K0 035 180 L
Component: Radio DE2 016 0020
Revision: 00016000 Serial number: VWZ4Z7H2181378
Coding: 0010400
VCID: 290F0117C5F79D3F069-807C
00003 - Control Module
014 - Defective
Part No SW: 1K0 959 703 Q HW: 1K0 959 795 J
Component: J388 TUER-SG HL 1120
Revision: 12006001 Serial number: 00000002678627
Coding: 0001168
VCID: 3E25C24B2C790A8743B-806A
Reset counter: 235
Mileage: 259125 km
Fault Status: 00111100
Fault Frequency: 43
Reset counter: 0
Mileage: 259127 km
Component: RDK 0450
Coding: 0100101
Fault Status: 00110100
Fault Frequency: 25
Reset counter: 5
Mileage: 273659 km
Time: 06:12:29
Part No SW: 1K0 959 704 Q HW: 1K0 959 794 J
Component: J389 TUER-SG HR 1120
Revision: 12006001 Serial number: 00000002632565
Coding: 0001168
VCID: 3FDBBF4F2B73038F48D-806A
Reset counter: 0
Mileage: 264161 km
Fault Frequency: 147
Reset counter: 0
Mileage: 263586 km
End----(Elapsed Time: 01:30, VBatt start/end: 12.0V/11.9V. VIgn 11.8V)-----
