Skoda Octavia 2005 (1Z) Type Steering Fault Or Coding
hikahuza
Sweden
C?ID=234299
Hello guys
Im not sure this is the right board to post it but I give it a try and see
I have a Skoda Octavia 2005 where Steering angle sensor was bad, when making fault scan it gave me on ABS and Steering wheel that Steering angle sensor is defect.
I bought a new used working one and mount it to car but still the Steering Wheel lamp and Anti spin lamp is On on the dashboard
Now im not sure if these need calibration or need coding or whatnot
I have attached the faults before clearing them all, and the faults AFTER i cleared them..
If anyone can see and have any idea what can be problem please let me know !
Without clearing codes :
Monday,04,June,2018,10:53:23:62265
VCDS Version: 18.1.0.2
VIN: TMBGE61Z352094421   License Plate: SKODAOCTAVIA
Mileage: 134660km-83673mi   Repair Order:
Chassis Type: 1Z (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 69 72 7D
VIN: TMBGE61Z352094421   Mileage: 134660km-83673miles
00-Steering Angle Sensor -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine        Labels: 03G-906-016-BKD.clb
   Part No SW: 03G 906 016 DS    HW: 028 101 195 3
   Component: R4 2,0L EDC G000AG  7000
   Revision: 12345678    Serial number: SKZ7Z0E2963411
   Coding: 0000078
   Shop #: WSC 00011 888 181093
   VCID: 77C5A9E0063E7DFD84-8022
18104 - Powertrain Data Bus
            P1696 - 000 - Implausible Message from Steering Column Controller
                    RPM: 945 /min
                    Torque: 4.0 Nm
                    Speed: 14.0 km/h
                    Voltage: 13.98 V
                    Bin. Bits: 11001011
                    Bin. Bits: 00000000
                    (no units): 1.0
   Part No SW: 02E 300 041 A    HW: 02E 927 770 AD
   Component: GSG DSG         041 0817
   Revision: 04004010    Serial number: 00000504140199
   Shop #: WSC 73430 790 00000
   VCID: 1017F27C03904AC525-8044
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0104
   Coding: 0023170
   VCID: 3A4370D475ACA095BB-806E
   Part No: 1Z0 907 044 J
   Component: ClimatronicPQ35 084 0305
   VCID: 3D497BC8648297AD9E-8068
   Part No SW: 1K0 937 049 N    HW: 1K0 937 049 N*
   Component: Bordnetz-SG     H34 0803
   Revision: 00H34000    Serial number: 00000003132561
   Coding: 098A8F020004140000110D000000000000087F075C
   Subsystem 1 - Part No: 1Z1 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer SK351  012  0401
   Coding: 00065525
   Shop #: WSC 73430
   Part No SW: 1K0 909 605 M    HW: 1K0 909 605 M
   Component: Q2 AIRBAG VW8   024 0700
   Revision: 07024000    Serial number: 0038DD0RHSE.
   Coding: 0020786
   VCID: 365B64E441B444F55F-8062
   Subsystem 1 - Serial number: 6332MSME684C0C0A
   Subsystem 2 - Serial number: 6342MSME0C696509
   Subsystem 3 - Serial number: 6351HSME5B503A07
   Subsystem 4 - Serial number: 6361HSME02133A07
   Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
   Component: J0527           H38 0070
   Coding: 0004042
   Shop #: WSC 06314 000 00000
   VCID: 46BB14243154D475CF-8012
   Component: E0221           H07 0050
01301 - Control Module for Voice Recognition (J507)
00895 - Cruise Control Switch (E45)
            014 - Defective
            000 -  -  - Intermittent
   Part No: 1Z0 920 841 D
   Component: KOMBIINSTRUMENT VD1 0918
   Coding: 0007101
   Shop #: WSC 80093 222 69422
   VCID: 374569E046BEBDFD44-8062
   Part No SW: 1K0 907 530 E    HW: 1K0 907 951
   Component: Gateway         H11 0110
   Revision: 11          Serial number: 29001053180079
   Coding: 3F3F4B40072302
   VCID: 2961BF98800A1B0DC2-807C
                    Fault Frequency: 7
                    Reset counter: 55
                    Mileage: 134636 km
                    Time: 00:10:08
   Component: IMMO            VD1 0918
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1T0 959 701
   Component: Tuersteuergeraet 09 0165
   Coding: 0000118
   VCID: 74DF9EEC174816E5A1-8020
   Part No: 1K1 909 144 H
   Component: EPS_ZFLS Kl.3       1502
   VCID: 305752FCA3D06AC505-8064
Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AK
   Coding: 00D002007F2D8505084F010004C8
   VCID: 79C1AFD8302A6B8DF2-802C
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1T0 959 702
   Coding: 0000118
   VCID: 75D9A3E81C320FED96-8020
   Part No SW: 1Z0 035 161 B    HW: 1Z0 035 161 B
   Component: Radio FO3       013 0028
   Revision: 00013000    Serial number: SKZ7Z3F0101468
   Coding: 0000400
   Shop #: WSC 40334 222 84898
   VCID: 2D694B88B4E2072D2E-8078
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
   Part No: 1K0 959 703 B
   Component: Tuersteuergeraet 06 0219
   Coding: 0000048
   VCID: 2F555180BEEE753D1C-807A
Address 69: Trailer        Labels: 8P0-907-383.clb
   Part No SW: 8P0 907 383     HW: 8P0 907 383
   Component: ANHAENGERELEKTR H01 0010
   VCID: 76DBA4E4013404F59F-8022
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
   Part No: 1K0 959 704 B
   Coding: 0000048
   Revision: 00800000    Serial number:
End-------------------------(Elapsed Time: 01:15)--------------------------
and here is after i cleared the codes
Monday,04,June,2018,10:58:10:62265
VIN: TMBGE61Z352094421   License Plate: OCTAVIACLEARDDTC
   Coding: 0000078
                    RPM: 819 /min
                    Torque: 26.0 Nm
                    Voltage: 13.60 V
                    Bin. Bits: 11001100
                    Bin. Bits: 00000000
                    (no units): 1.0
Readiness: 0 0 1 1 1
   Coding: 0023170
   Coding: 00065525
   Shop #: WSC 73430
   Coding: 0020786
   Coding: 0004042
            014 - Defective
   Coding: 0007101
                    Reset counter: 15
                    Mileage: 134666 km
                    Time: 21:13:25
   Coding: 0000118
   Coding: 0000118
   Coding: 0000400
   Coding: 0000048
   Coding: 0000048
End-------------------------(Elapsed Time: 01:16)--------------------------
Regards
The problem is: "Steering Angle Sensor (G85) - No Signal/Communication". ;)
hikahuza
Sweden
C?ID=234299
Hi
this means its need calibration or the sensor itself is not fitted as it should be
regards
hikahuza
Sweden
C?ID=234299
the sensor was for different car
now i mounted a new one and it seems it needs coding or adaptation, see latest fault scan
Tuesday,05,June,2018,13:38:07:62265
VIN: TMBGE61Z352094421   License Plate: NEWSCAN
Mileage: 134730km-83717mi   Repair Order:
VIN: TMBGE61Z352094421   Mileage: 134730km-83717miles
   Coding: 0000078
   Coding: 0023170
   Coding: 00065525
   Shop #: WSC 73430
   Coding: 0020786
   Part No SW: 1K0 953 549 G    HW: 1K0 953 549 G
   Component: Lenksäulenmodul 021 0050
   Coding: 0002042
   Shop #: WSC 06403 785 00200
   Component: Lenkradmodul    007 0050
   Coding: 0007101
   Coding: 0000118
02546 - Steering Limit Stop
                    Mileage: 4720 km
                    Temperature: 48.0°C
                    Voltage: 13.40 V
                    Voltage: 13.30 V
   Coding: 0000118
   Coding: 0000400
   Coding: 0000048
   Coding: 0000048
can anyone guide me on how to do this settings or adaptation ?
Regards
Bruce
Near Philadelphia, PA, USA
hikahuza
Sweden
C?ID=234299
managed, thanks!
