- Joined
- May 30, 2018
- Messages
- 10
- Reaction score
- 1
- Location
- Netherlands
- VCDS Serial number
- C?ID=290183
Hello can you help me out with this problem, previous it was possible with older versions of VCDS to program the folding mirror so they work by pushing the lock button on the remote ( car key ) but now I can`t find it anymore, are there chances in the program, ore is it renamed. below the old way.
1.Select [42-Door Elec, Driver]
2.Klik [Security Access - 16]
3.enter security code "04354" and click op "Do it!"
4.Back in the previous menu , click [Adaptation -10]
5.Selectthe next channel: (9)-System_Parameter_0-System Parameter Byte8 ( it should be a bit at the bottom )
6.now you See the value is 90. You have 2 options : 1.95 – on remote keep lock button pressed to fold mirrors and unfold with motor on.
2.99 - Keep lock button pressed to fold mirror, and unfold by opening the door.
7.Klik op "Do it!" than "Yes"
8.than you get the massage code accepted click ok
9.Now you are done...
Here my adaption map.
And a scan of my car.
;SW:3C0-959-701-A HW:3C0-959-793-A --- Door Elect, Driver --- SA: 04354
;Component:TUER-SG FT 002 0329, Coding:0011FF
;EV_DCU42BroseDriveSide,A03004,EV_DCU42BroseDriveSide_VW32.rod
;Thursday,31,May,2018,17:39:08:35994
;VCDS Version: Release 18.2.1 (x64) Data version: 20180518 DS287.1
;VCID: 26427CA5596B97747D-8072
ENG106031-ENG103506-ECU ID2 PartNumber HW SW-Byte 1,1 ,22
ENG106031-ENG99970-ECU ID2 PartNumber HW SW-Byte 10,G ,22
ENG106031-ENG103845-ECU ID2 PartNumber HW SW-Byte 11, ,22
ENG106031-ENG103008-ECU ID2 PartNumber HW SW-Byte 12,0 ,22
ENG106031-ENG100040-ECU ID2 PartNumber HW SW-Byte 13,0 ,22
ENG106031-ENG101630-ECU ID2 PartNumber HW SW-Byte 14,1 ,22
ENG106031-ENG99906-ECU ID2 PartNumber HW SW-Byte 15,C ,22
ENG106031-ENG99415-ECU ID2 PartNumber HW SW-Byte 16, ,22
ENG106031-ENG101004-ECU ID2 PartNumber HW SW-Byte 17, ,22
ENG106031-ENG100194-ECU ID2 PartNumber HW SW-Byte 18, ,22
ENG106031-ENG102302-ECU ID2 PartNumber HW SW-Byte 19, ,22
ENG106031-ENG100432-ECU ID2 PartNumber HW SW-Byte 2,K ,22
ENG106031-ENG102337-ECU ID2 PartNumber HW SW-Byte 20, ,22
ENG106031-ENG100802-ECU ID2 PartNumber HW SW-Byte 21, ,22
ENG106031-ENG101604-ECU ID2 PartNumber HW SW-Byte 22, ,22
ENG106031-ENG103171-ECU ID2 PartNumber HW SW-Byte 3,0 ,22
ENG106031-ENG99780-ECU ID2 PartNumber HW SW-Byte 4,9 ,22
ENG106031-ENG101635-ECU ID2 PartNumber HW SW-Byte 5,5 ,22
ENG106031-ENG100290-ECU ID2 PartNumber HW SW-Byte 6,9 ,22
ENG106031-ENG101242-ECU ID2 PartNumber HW SW-Byte 7,7 ,22
ENG106031-ENG101974-ECU ID2 PartNumber HW SW-Byte 8,9 ,22
ENG106031-ENG100834-ECU ID2 PartNumber HW SW-Byte 9,5 ,22
ENG106032-ENG103506-ECU ID2 PartNumber VW SW ID-Byte 1,1 ,20
ENG106032-ENG99970-ECU ID2 PartNumber VW SW ID-Byte 10,P ,20
ENG106032-ENG103845-ECU ID2 PartNumber VW SW ID-Byte 11, ,20
ENG106032-ENG103008-ECU ID2 PartNumber VW SW ID-Byte 12,L ,20
ENG106032-ENG100040-ECU ID2 PartNumber VW SW ID-Byte 13,1 ,20
ENG106032-ENG101630-ECU ID2 PartNumber VW SW ID-Byte 14,5 ,20
ENG106032-ENG99906-ECU ID2 PartNumber VW SW ID-Byte 15,9 ,20
ENG106032-ENG99415-ECU ID2 PartNumber VW SW ID-Byte 16,± ,20
ENG106032-ENG101004-ECU ID2 PartNumber VW SW ID-Byte 17,1 ,20
ENG106032-ENG100194-ECU ID2 PartNumber VW SW ID-Byte 18,1 ,20
ENG106032-ENG102302-ECU ID2 PartNumber VW SW ID-Byte 19,4 ,20
ENG106032-ENG100432-ECU ID2 PartNumber VW SW ID-Byte 2,K ,20
ENG106032-ENG102337-ECU ID2 PartNumber VW SW ID-Byte 20,8 ,20
ENG106032-ENG103171-ECU ID2 PartNumber VW SW ID-Byte 3,0 ,20
ENG106032-ENG99780-ECU ID2 PartNumber VW SW ID-Byte 4,9 ,20
ENG106032-ENG101635-ECU ID2 PartNumber VW SW ID-Byte 5,5 ,20
ENG106032-ENG100290-ECU ID2 PartNumber VW SW ID-Byte 6,9 ,20
ENG106032-ENG101242-ECU ID2 PartNumber VW SW ID-Byte 7,7 ,20
ENG106032-ENG101974-ECU ID2 PartNumber VW SW ID-Byte 8,0 ,20
ENG106032-ENG100834-ECU ID2 PartNumber VW SW ID-Byte 9,3 ,20
ENG106033-ENG103506-ECU ID3 HW ID VW-Byte 1,0 ,3
ENG106033-ENG100432-ECU ID3 HW ID VW-Byte 2,0 ,3
ENG106033-ENG103171-ECU ID3 HW ID VW-Byte 3,5 ,3
ENG106034-ECU ID4 VW Tester ID,00 00 00 00 14 BF B1 31 31 34 ,10
ENG108997-ENG103506-Software Version Number-Byte 1,± ,4
ENG108997-ENG100432-Software Version Number-Byte 2,1 ,4
ENG108997-ENG103171-Software Version Number-Byte 3,1 ,4
ENG108997-ENG99780-Software Version Number-Byte 4,4 ,4
ENG108998-ENG103506-Software Version Number(Front)-Byte 1,0 ,4
ENG108998-ENG100432-Software Version Number(Front)-Byte 2,3 ,4
ENG108998-ENG103171-Software Version Number(Front)-Byte 3,2 ,4
ENG108998-ENG99780-Software Version Number(Front)-Byte 4,9 ,4
ENG109228-System Data Part 1 (rear),00 04 01 59 A9 00 ,6
ENG109230-System Data Part 10 (rear),30 30 31 30 30 30 31 36 32 36 31 ,11
ENG109232-System Data Part 11 (rear),00 ,1
ENG109234-System Data Part 12 (rear),3F ,1
ENG109236-System Data Part 13 (rear),7E 40 00 ,3
ENG109238-System Data Part 2 (rear),00 00 00 00 10 84 00 00 ,8
ENG109240-System Data Part 3 (rear),00 01 00 01 02 00 05 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,24
ENG109242-System Data Part 4 (rear),00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,24
ENG109244-System Data Part 5 (rear),00 00 00 0B 00 03 3D 00 00 FF FF 7E 40 00 ,14
ENG109246-System Data Part 6 (rear),01 10 09 C2 ,4
ENG109248-System Data Part 7 (rear),06 10 17 62 61 97 36 24 01 05 FE 00 00 00 00 00 ,16
ENG109250-System Data Part 8 (rear),05 57 35 2E 98 40 64 25 79 03 03 02 00 00 00 00 ,16
ENG109252-System Data Part 9 (rear),30 30 30 30 30 30 30 30 37 35 30 34 30 32 42 52 46 30 30 31 31 37 31 30 30 36 31 31 ,28
ENG109253-System Data Part1,00 00 01 0C 16 02 00 00 00 01 00 11 00 0F D9 00 00 58 89 00 02 02 04 04 00 00 00 00 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 8F 12 12 12 00 02 01 00 00 00 ,56
ENG109254-System Data Part2,00 00 00 00 00 00 65 92 74 7D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 30 30 30 30 30 30 30 37 35 30 34 30 32 00 00 07 07 07 07 07 07 07 07 07 07 07 07 07 00 00 06 00 00 06 02 02 06 06 05 05 07 07 07 02 05 06 01 06 07 04 07 07 03 03 05 06 07 05 07 07 00 07 04 02 01 01 03 05 04 07 07 07 07 03 07 07 00 02 01 00 00 00 00 01 01 00 00 00 00 01 02 00 00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 03 00 00 00 00 00 01 00 00 01 00 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 00 ,216
ENG109255-System Data Part3,FF FF 08 5E 03 02 DD E5 00 46 26 D9 5E FF FF 08 CD 01 02 89 61 00 42 36 D1 39 FF FF 08 B1 01 02 42 CC 00 3E 55 12 B4 FF FF 08 C1 04 02 22 86 00 3C FA A4 B0 FF FF 08 C1 08 02 22 86 00 3C FA A5 0A FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 02 0A 00 84 AC 22 E0 FE 00 00 00 00 00 00 00 00 A5 FF ,174
ENG109256-System Data Part4,10 09 17 04 14 91 84 32 01 01 00 00 00 00 42 52 46 2D 30 30 31 31 37 2E 30 39 2E 31 30 30 30 30 31 30 34 31 34 31 32 31 30 31 30 30 35 54 55 45 52 2D 53 47 20 46 54 20 20 20 30 30 30 31 35 33 30 35 35 30 ,68
ENG109257-System Data Part5,03 31 3D 42 98 83 30 00 05 06 00 00 00 00 00 00 00 00 00 00 ,20
ENG109258-System Data Part6,FF FE 00 FF FF FF FF FF FF FF FF FF FF FF FF FF 00 01 00 01 FF FF FF FF FF FF FF FF FF FF FF FF 00 00 00 00 00 00 ,38
ENG109259-System Data Part7,00 ,1
ENG109260-System Data Part8,3F ,1
ENG109263-System Parameter Part16,FF 11 00 01 81 C8 F6 30 39 16 06 17 00 00 ,14
ENG109264-System Parameter Part-17,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1F 2A 0A 08 03 79 2A 0A 3D 00 19 00 00 00 00 00 00 00 00 00 00 00 C2 42 0C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,70
ENG109265-System Parameters Part 1 (rear),74 9E 0F 34 00 05 6F 50 ,8
ENG109266-System Parameters Part 10 (rear),00 ,1
ENG109267-System Parameters Part 2 (rear),0C A8 0E 56 53 65 00 00 06 08 10 1E 50 96 3F 48 84 00 5A 3F 01 FF 58 44 ,24
ENG109268-System Parameters Part 3 (rear),3E 28 64 50 3E 3E 3E 3E 8A 92 B2 99 07 07 07 87 FB 84 65 34 00 44 28 46 ,24
ENG109269-System Parameters Part 4 (rear),07 B7 82 C1 73 46 10 27 3C 85 14 2B 0D 20 08 0C ,16
ENG109270-System Parameters Part 5 (rear),87 51 12 1B 37 83 A4 7D 0C 13 C5 18 B4 22 19 FF ,16
ENG109271-System Parameters Part 6 (rear),00 19 19 3E 42 71 77 BB BC FF 00 5A 6B CA D6 FF 00 2D 33 66 CC FF DF 77 6B 5E C6 1E 03 64 83 02 51 50 1F 7F 7D 00 ,38
ENG109272-System Parameters Part 7 (rear),0E 46 20 20 20 0D 03 02 02 0D 0D 5A 34 32 03 22 05 02 ,18
ENG109273-System Parameters Part 8 (rear),03 00 00 D0 ,4
ENG109274-System Parameters Part 9 (rear),B6 E5 A4 3F B7 E5 08 E0 0F 0A E0 0C 9E E6 06 A1 D0 26 0D A6 94 9E E7 07 A6 FF B7 B6 B7 B7 10 B8 81 9D 9D 9D 9D 81 D0 1C ,40
ENG109279-System_Parameter_0,7F BE 0F 34 00 0D C3 51 95 F2 07 E4 E4 62 00 28 ,16
ENG109280-System_Parameter_1,E4 00 4C 00 0C 7A 0F 87 69 9E 00 00 05 08 0C 10 ,16
ENG109281-System_Parameter_10,1E 28 37 46 5A 64 00 03 07 0A 0E 0F 28 1E 0A 75 ,16
ENG109282-System_Parameter_11,75 DF 72 5B DF 72 5B 07 03 00 28 14 00 64 02 00 ,16
ENG109283-System_Parameter_12,00 00 26 18 32 14 14 EA 00 00 00 00 00 00 00 00 ,16
ENG109284-System_Parameter_13,00 00 00 00 00 00 00 00 FF FF FF FF FF FF FF 0F ,16
ENG109285-System_Parameter_14,74 E0 1E E4 00 00 00 00 00 00 00 00 00 00 00 00 ,16
ENG109286-System_Parameter_15,00 00 ,2
ENG109287-System_Parameter_2,18 44 3F 62 9E 00 6E 3F 01 60 29 44 78 3C 64 55 ,16
ENG109288-System_Parameter_3,46 46 4B 46 8A 88 9E 96 91 8C 07 8A FD 72 B5 34 ,16
ENG109289-System_Parameter_4,00 53 50 19 07 B3 9B 61 73 2D 08 27 3C 86 14 28 ,16
ENG109290-System_Parameter_5,0A 1D 14 0A 87 51 12 20 37 A0 B6 7D A0 3F AA 47 ,16
ENG109291-System_Parameter_6,D9 22 19 0D 75 FF 32 75 C8 00 08 8C FF 2B 0E 80 ,16
ENG109292-System_Parameter_7,10 04 9C 00 02 0D F2 0D 32 0C 0F 32 0A 0A 03 32 ,16
ENG109293-System_Parameter_8,0A 03 20 20 20 0D 03 02 02 0D 0D 00 00 32 00 00 ,16
ENG109294-System_Parameter_9,00 00 00 00 00 00 14 00 00 03 2A 9B 00 00 00 00 ,16
ENG109297-System-Parameter Block,7F BE 0F 34 00 0D C3 51 95 F2 07 E4 E4 62 00 28 E4 00 4C 00 0C 7A 0F 87 69 9E 00 00 05 08 0C 10 18 44 3F 62 9E 00 6E 3F 01 60 29 44 78 3C 64 55 46 46 4B 46 8A 88 9E 96 91 8C 07 8A FD 72 B5 34 00 53 50 19 07 B3 9B 61 73 2D 08 27 3C 86 14 28 0A 1D 14 0A 87 51 12 20 37 A0 B6 7D A0 3F AA 47 D9 22 19 0D 75 FF 32 75 C8 00 08 8C FF 2B 0E 80 10 04 9C 00 02 0D F2 0D 32 0C 0F 32 0A 0A 03 32 0A 03 20 20 20 0D 03 02 02 0D 0D 00 00 32 00 00 00 00 00 00 00 00 14 00 00 03 2A 9B 00 00 00 00 1E 28 37 46 5A 64 00 03 07 0A 0E 0F 28 1E 0A 75 75 DF 72 5B DF 72 5B 07 03 00 28 14 00 64 02 00 00 00 26 18 32 14 14 EA 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FF FF FF FF FF FF 0F 74 E0 1E E4 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,242
ENG110034-VW-Identification,30 30 31 31 30 33 30 30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 33 43 30 39 35 39 37 30 31 41 20 00 00 00 00 00 00 00 00 33 43 30 39 35 39 37 39 33 41 20 00 00 00 00 00 00 00 00 00 00 00 00 00 30 30 32 4A 33 38 36 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 33 32 39 45 56 5F 44 43 55 34 32 42 72 6F 73 65 44 72 69 76 65 53 69 64 65 00 00 00 00 41 30 33 30 30 34 01 81 C8 F6 30 39 16 06 17 00 00 00 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,242
ENG110126-MAS00478-Window_Lifter_Position-Reserved,00 ,8
ENG110126-ENG102781-Window_Lifter_Position-Data 1,0.25 ,8
ENG110126-ENG102143-Window_Lifter_Position-Data 2,8789.5 ,8
ENG110126-ENG103757-Window_Lifter_Position-Data 3,00 ,8
ENG110126-ENG101787-Window_Lifter_Position-Data 4,01 ,8
Elapsed Time: 00:39
Thursday,31,May,2018,17:46:11:35994
VCDS Version: 18.2.1.2 (x64)
VIN: WVWZZZ3CZ7E100568 License Plate: 31-05-2018
Mileage: 207540km-128959mi Repair Order:
Chassis Type: 3C-VW46 (3C0)
Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 52 53 56 62 69 6C
72 77
VIN: WVWZZZ3CZ7E100568 Mileage: 207540km-128959miles
Part No SW: 06F 906 056 GN HW: 06F 906 056 EK
Component: MED9.5.10 G00 0184
Revision: 69H03--- Serial number: VWZCZ000000000
Coding: 0000072
Shop #: WSC 05311 000 00000
VCID: 7BF47DD13A69FA9C72-802E
006480 - Radiator Fan (V7)
P1950 - 002 - Movement Restricted / Jammed - Intermittent
Fault Frequency: 48
Mileage: 205677 km
Date: 2018.04.17
Time: 16:48:29
RPM: 680 /min
Load: 41.9 %
Speed: 1.0 km/h
Temperature: 93.0°C
Address 03: ABS Brakes Labels:. 3C0-614-095-C2.clb
Part No SW: 3C0 614 095 P HW: 3C0 614 095 P
Component: ESP 440 C2 H015 0004
Revision: H015 Serial number: 0668044179
Coding: 0013710
Shop #: WSC 09436 000 1048576
VCID: 2F6C9981BE91D63C8E-807A
Part No SW: 3AA 907 044 BA HW: 3AA 907 044 BA
Component: Climatronic H03 0404
Revision: 00001K01
Coding: 0618004A02
VCID: 70EE5AFDAB2F89C4D7-8024
9484402 - Motor for Indirect Ventilation Flap
B10B8 54 [009] - Missing Calibration / Basic Setting
Reset counter: 231
Mileage: 204394 km
Date: 2018.03.19
Time: 20:20:14
13701424 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 126
Mileage: 204394 km
Date: 2018.03.19
Time: 18:59:24
U1111 00 [009] - -
Reset counter: 126
Mileage: 204394 km
Date: 2018.03.19
Time: 18:59:24
9479189 - Signal Line for Air Quality Sensor
B10A4 15 [008] - Open or Short to Plus
Reset counter: 162
Mileage: 207480 km
Date: 2018.05.30
Time: 18:52:09
Revision: 00H54000 Serial number: 00000008504106
Coding: E58C0FA510000000C0000F000F0000008019FF4B6410210C000000000000
VCID: 336495F152B9F2DCEA-8066
Subsystem 1 - Part No: 3C1 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer VW461 012 0503
Coding: 00063445
Shop #: WSC 12345
Subsystem 2 - Part No: 1K0 955 559 AE Labels: 1K0-955-559-AF.CLB
Component: RLS 091006 014 1201
Coding: 00471077
Shop #: WSC 12345
Address 10: Park/Steer Assist (J446) Labels:| 1Q0-919-475.clb
Part No SW: 56D 919 475 A HW: 56D 919 475
Component: PARKHILFE 8K H02 0006
Revision: -------- Serial number: 35831413600938
Coding: 310003
ASAM Dataset: EV_EPHVA18VW4110000 001007
ROD: EV_EPHVA18VW4110000.rod
VCID: 336495F19AB9F2DCEA-8066
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 M HW: 3C0 909 605 M
Component: 03 AIRBAG VW8 031 2522
Revision: 11031000 Serial number: 003B1PLSDHB1
Coding: 0012339
VCID: 306E9AFDA3AFC9C497-8064
Subsystem 1 - Serial number: 6332MSME1228235C
Subsystem 2 - Serial number: 6342MSME13370E2C
Subsystem 3 - Serial number: 6351HTS66HB0HON6
Subsystem 4 - Serial number: 6361HTS6S4CSD4N6
Part No SW: 3C0 953 549 E HW: 3C0 953 549 E
Component: J0527 0015
Revision: 00006000 Serial number: 3C9953507P
Coding: 0000312
VCID: 2E528485B99BDF3485-807A
Component: E0221 002 0010
Part No SW: 3C0 920 870 T HW: 3C0 920 870 T
Component: KOMBIINSTRUMENT VD1 1614
Revision: X0006000 Serial number: 00000000000000
Coding: 0007105
Shop #: WSC 02129 003 1048576
VCID: 346696ED57B7F5E4F3-8060
Address 19: CAN Gateway Labels:. 3C0-907-530-V3.clb
Part No SW: 3C0 907 530 Q HW: 3C0 907 951
Component: J533 Gateway H13 0172
Revision: H13 Serial number: 3690P10C141166
Coding: F9A07F46404602002002
Part No SW: 3C0 959 433 R HW: 3C0 959 433 R
Component: IMMO 042 0383
Revision: 00042000 Serial number: VWZCZ000000000
Shop #: WSC 43674 001 1048576
VCID: 3978A7D970D5088C20-806C
Component: ELV 029 0380
3C0905861J ELV 029 0380
02823 - Requirements for Locking the Steering Column Lock not met
Reset counter: 139
Mileage: 206910 km
Date: 2018.05.18
Time: 14:41:53
02827 - Wake-Up request via ESP
Reset counter: 139
Mileage: 206910 km
Date: 2018.05.18
Time: 14:41:54
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 1T0 035 680 P HW: 1T0 035 680 F
Component: RNS-MID H06 5269
Revision: AB001001 Serial number: VWZ6Z7L7135074
Coding: 02010400010000200000
VCID: 3B74BDD1BAE93A9C32-806E
Subsystem 1 - Part No: 1T0 919 859 B
Component: EU West V15 8515
Part No SW: 3C0 959 701 A HW: 3C0 959 793 A
Component: TUER-SG FT 002 0329
Revision: 12101005 Serial number: 0001530550
Coding: 0011FF
ASAM Dataset: EV_DCU42BroseDriveSide A03004
ROD: EV_DCU42BroseDriveSide_VW32.rod
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 703 P HW: 1K0 959 795 G
Component: J388__TSG-HL 005 1114
Serial number: 00000000750402
Coding: 0000D0
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.133 H07 1806
Component: KSG PQ46 ELV 042 0472
Coding: 0091020051030E76300294157008CF0B607C00
Part No SW: 3C0 959 702 A HW: 3C0 959 792 A
Component: TUER-SG BT 002 0329
Revision: 14101005 Serial number: 0001436895
Coding: 0011FE
ASAM Dataset: EV_DCU52BrosePasseSide A03004
ROD: EV_DCU52BrosePasseSide.rod
VCID: 275C71A15E618E7C46-8072
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 704 P HW: 1K0 959 794 G
Component: J389__TSG-HR 005 1114
Serial number: 00000000748883
Coding: 0000D0
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Part No SW: 3C0 907 801 G HW: 3C0 907 801 G
Component: EPB VD8HC005 013 0005
Revision: 013
Coding: 0000012
VCID: 26427CA5916B97747D-8072
02844 - Lamp for Automatic Parking Function
009 - Open or Short to Ground - MIL ON
Fault Status: 11101001
Reset counter: 126
Mileage: 206264 km
Date: 2018.04.30
Time: 17:20:08
Voltage: 10.46 V
Count: 64
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Address 69: Trailer Labels: 1K0-907-383-V1.clb
Part No SW: 1K0 907 383 HW: 1K0 907 383
Component: ANHAENGERELEKTR 003 0020
VCID: 6ADA489545F3731499-803E
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 3C0 907 441 HW: 3C0 907 441
Component: J772__Rearview 0042
Revision: 00H05000 Serial number: PA8 J810528
Coding: 0031007
VCID: 5FCC29418EB106BC7E-800A
Address 77: Telephone Labels: 3C0-035-730.lbl
Part No SW: 5N0 035 730 B HW: 5N0 035 730 B
Component: J412 8502
Revision: 00015000 Serial number: 0000B7A090504
Coding: 0020041
VCID: 275C71A196618E7C46-8072
01524 - Antenna for Telephone
Fault Status: 00101011
Reset counter: 135
Mileage: 206716 km
Date: 2018.05.15
Time: 16:54:38
End-------------------------(Elapsed Time: 03:28)--------------------------
