Vehicle Identification No. 3VWG57BUXKM009598
Model Jetta 1.4
JEM
Date of production 15.03.2018
Year 2018
Sales type BU34MS
Engine Code DGXA
Transmission Code RZE
Model Jetta 1.4
JEM
Year 2018
Sales type BU34MS
Engine Code DGXA
Tuesday,29,May,2018,11:55:18:29015
VCDS Version: 18.5.0.0 (x64) HEX-NET CB: 0.4422.4
Data version: 20180518 DS291.0
VIN: 3VWG57BUXKM009598 License Plate:
Chassis Type: BU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 13 15 17 19 2B 36 3C 42 44 47 52 5F 75 A5
CA
VIN: 3VWG57BUXKM009598 Mileage: 73km-45miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DGXA) Labels: None
Part No SW: 04E 906 024 L HW: 04E 907 309 BT
Component: R4 1.4l TSI H20 5595
Revision: D4H20000
Coding: 012A0012236411087000
Shop #: WSC 00066 790 00390
ASAM Dataset: EV_ECM14TFS01104E906024L 001003
ROD: EV_ECM14TFS01104E906024B.rod
VCID: AA1701FECD8EFE1BB9-80FE
Readiness: 0000 0100
Address 02: Auto Trans (J217) Labels: Redir Fail!
Part No SW: 09S 927 158 R HW: 09S 927 158
Component: AISIN 8G30/18 301 3552
Coding: 0100000100000000000000000000000000000000
Shop #: WSC 49359 002 1048576
ASAM Dataset: EV_TCMAQ300031 001008
ROD: EV_TCMAQ300031.rod
VCID: CEDF6D6E91A6F23B05-809A
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 DA HW: 5Q0 614 517 AH
Component: ESC H62 0753
Revision: 00000000 Serial number: 50108000000951
Coding: 70FB6AA124202175C57C0209A0CB250E562484A34005A4701841F058C2A2430B00000012121212B835351919323200
Shop #: WSC 01383 790 50316
VCID: F3A9DC9A5AC4FFD3CA-80A6
Part No SW: 3Q0 959 435 J HW: 3Q0 959 435 J
Component: VWKESSYMQB 037 1104
Revision: 00037000 Serial number: 0468173036
Coding: 132C0C0723
ASAM Dataset: EV_KessyHellaMQBAB 004043
VCID: C1C5465250F81D4388-8094
Part No SW: 5GM 907 044 J HW: 5GM 907 044 J
Component: Climatronic H05 2007
Revision: 00001K04
Coding: 0102001420011800110400001211100C
ASAM Dataset: EV_ACClimaBHBVW37X 006148
VCID: CBD9647A62B4C71362-809E
Part No SW: 5Q0 937 087 AS HW: 5Q0 937 087 AP
Component: BCM PQ37BOSCH 034 0246
Revision: -------- Serial number: C86420021800Q7
ROD: EV_BCMBOSCH_018.rod
VCID: 8C5BA766273A802BAB-80D8
Subsystem 1 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 047 0105
Serial number: SAY18M03D01H15M36S42
Coding: 0038DD
Steering Column Switch:
Subsystem 3 - Part No SW: 5Q1 953 521 AS HW: 5Q1 953 569
Component: Lenks.Modul H03 0120
Serial number: 0100190220180C300594
Subsystem 4 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Component: SysNameFanLin 014 0101
Serial number: ESE0368260
Subsystem 5 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE0373266
Subsystem 6 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE0860569
Subsystem 7 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE0865485
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 5Q0 907 572 N HW: 3QF 907 572
Component: ACC BOSCH MQB H10 0681
Coding: 320000C159FFC428949C810580301600000000000000000004
ASAM Dataset: EV_ACCBOSCHVW416 002008
VCID: C2C7495E55FE065B91-8096
Part No SW: 5Q0 959 655 AG HW: 5Q0 959 655 AG
Component: AirbagVW21 004 0336
Serial number: 003NUM07V681
Coding: 8CCCFC00000000005000001AC20800000065
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 854D92420450F163F4-80D0
Occupant Detection:
Component: BF-Gewichtss. H13 0022
Serial number: IBH000000000008LEIH
Coding: 303444
Subsystem 2 - Part No SW: ----------- HW: 480 002 112 17
Serial number: 357000000002785CFA2X
Subsystem 3 - Part No SW: ----------- HW: 480 002 112 17
Serial number: 358000000004D265D92R
Subsystem 4 - Part No SW: ----------- HW: 480 402 912 17
Serial number: 3510001A728C2081E750
Subsystem 5 - Part No SW: ----------- HW: 480 402 012 17
Serial number: 3520001A1288D0F163E6
Subsystem 6 - Part No SW: ----------- HW: 480 400 202 18
Component: FrontSensor_D 000 6149
Serial number: 3550001B728A2CC306DE
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 400 202 18
Component: FrontSensor_P 000 6149
Serial number: 3560001B728D614564FB
Address 17: Instruments (J285) Labels:* None-SRI3
Part No SW: 17A 920 890 HW: 17A 920 890
Component: KOMBI 514 0610
Coding: 09A4091A6788CF050288630B50000000A0000000
Shop #: WSC 00066 790 00079
ASAM Dataset: EV_DashBoardVDDMQBA0 001024
ROD: EV_DashBoardVDDMQBA0_VW27.rod
VCID: E58DB2C2E410116354-80B0
Part No SW: 3Q0 907 530 L HW: 3Q0 907 530 C
Component: GW MQB High 518 5323
Serial number: 08031800840069
Coding: 030100047F085708FB0002D81C0F00010001070000000000000000000000
Shop #: WSC 00066 790 00014
ROD: EV_GatewNF.rod
VCID: B8332BB603225C8B3F-80EC
Subsystem 2 - Part No SW: 5G0 959 442 AB HW: 5G0 959 442 AB Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0052
Serial number: 39170002878940017524
Coding: 2CFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Serial number: 0601705600
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Part No SW: 2Q0 905 861 A HW: 2Q0 905 861 A
Component: ELV-MQBB H07 0021
Serial number: 17000396046004
Coding: 0800000000000000
ROD: EV_ELVMarqMQBA0.rod
VCID: B1251692E0588DC378-80E4
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 5Q0 959 760 C HW: 5Q0 959 760 C
Component: Sitzmemory H09 0023
Serial number: Y0006RAK25505
Coding: 0010000000000500018280808000000000008101000000F400
VCID: BD3D3AA22C0079A3EC-80E8
Address 3C: Lane Change (J1086) Labels:* None
Part No SW: 2Q0 907 686 A HW: 2Q0 907 686 A
Component: HRE3_Kl15_Mst H03 0052
Serial number: 00000467002142
Coding: 5000C500
ASAM Dataset: EV_HREntryHellaGen3Kl15 001009
ROD: EV_HREntryHellaGen3Kl15.rod
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 011 0032
Serial number: 5038735600905
Coding: 00391B200200028000000000
VCID: C7D1584A7EDC237346-8092
Subsystem 1 - Part No SW: 5Q4 959 811 F HW: 5Q4 959 811 F
Component: Fond FHSG DRV 010 0004
Serial number: 00000000000000194631
Coding: 011000
Part No SW: 5QM 909 144 B HW: 5QM 909 144 B
Component: EPS_MQB_ZFLS 172 1081
Coding: 911F0000
ROD: EV_SteerAssisMQB_015.rod
VCID: D0E373168B92E4CB17-8084
Address 47: Sound System (J525) Labels:* None
Part No SW: 5F0 035 456 HW: 5F0 035 456
Component: KonzernAmp12K H03 2109
Revision: -------- Serial number: A1126A00003379
Coding: 0203000000AAAAAA000000000000
ASAM Dataset: EV_AMPCAN12C4PASE 001002
ROD: EV_AMPCAN12C4PASE.rod
VCID: E287A9DEF53E665BB1-80B6
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 011 0032
Serial number: 6038801302456
Coding: 003913200200028000000000
VCID: C6CF554E79D63A7BBD-8092
Subsystem 1 - Part No SW: 5Q4 959 812 F HW: 5Q4 959 812 F
Component: Fond FHSG PSG 010 0004
Serial number: 00000000000000204618
Coding: 091000
Part No SW: 3Q0 035 876 B HW: 3Q0 035 876 B
Component: MU-S-NS-US 851 0867
Coding: 02730102AA00000041220003001808009F0510F401200405C6
ROD: EV_MUStd4CDELP_VW26.rod
VCID: B3291C9A1A44BFD30A-80E6
Subsystem 1 - Part No SW: 5G6 919 605 D HW: 5G6 919 605 D
Component: ABT_Std-2_Nav H50 8130
Serial number: VWZ6ZJV0456050
Subsystem 2 - Part No SW: 3G0 919 866 BP HW: -----------
Component: NAR 2018 --- 0715
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 009 0570
Coding: 02730102C2823A017F1E06000000
ROD: EV_OCULowMQB.rod
VCID: C3C94C5A4AE40F539A-8096
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3QD 980 654 HW: 3Q0 980 654 A
Component: MQB_B_MFK H08 1272
Serial number: 27101741K11290
Coding: 0003070100020201002213548150490084000E200120
ROD: EV_MFKBoschMQBB_VW27.rod
VCID: 88539B763342EC0B8F-80DC
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4M0 907 594 K HW: 4M0 907 594
Component: SAD_STG_1 014 0005
Coding: 00800073710B
VCID: BE3F3DAE210662BBF5-80EA
End----------(Elapsed Time: 01:41, VBatt start/end: 11.9V/11.9V)-----------
