Unable to obtain ABS long coding
ThatBeardedGuy
Virginia, USA
I am going to replace my ABS module in my 2009 Rabbit but the module is completely shot and does not communicate for me to read what the long coding is. Just wondering if anyone could help me out.
I already took it to the dealer for the recall but per the recall protocol they have to be able to communicate to the module to send the "update" first before they will replace it :banghead:
 Monday,21,May,2018,17:19:20:40245
VCDS Version: 18.2.0.3 (x64)
VIN: WVWDA71K19W047863   License Plate:
Mileage: 278590km-173107mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 65 72
VIN: WVWDA71K19W047863   Mileage: 278590km-173107miles
03-ABS Brakes -- Status: Cannot be reached 1100
65-Tire Pressure -- Status: Malfunction 1010
Address 01: Engine (CBT)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 P    HW: 07K 906 055 M
   Component: 2,5l R5/4V      G   9205
   Revision: G6H01---    Serial number: VWX7Z0H53NR8W4
   Coding: 0000075
   Shop #: WSC 09254 444 103873
   VCID: 3B5BDFF17AF8959C0D-806E
049441 - No Communication with ABS Brake Control Module
               U0121 - 000 -  - MIL ON
                    Fault Status: 11100000
                    Mileage: 278597 km
                    Time: 00:10:16
                    RPM: 726 /min
                    Load: 22.7 %
                    Temperature: 57.0°C
                    Temperature: 34.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 13.970 V
005668 - MIL Request Signal Active (Check TCM for errors too!)
               P1624 - 000 -  - Intermittent
                    Mileage: 278597 km
                    Time: 00:10:16
                    RPM: 727 /min
                    Load: 22.7 %
                    Temperature: 57.0°C
                    Temperature: 34.0°C
                    Voltage: 13.843 V
Readiness: 0110 1101
   Part No SW: 09G 927 750 JE    HW: 09G 927 750 JE
   Component: AQ 250 6F           1377
   Revision: 00H76000    Serial number:
   Coding: 0000840
   Shop #: WSC 01279 785 00200
   VCID: 7DDF11E9246C5BAC73-8028
                    Reset counter: 202
                    Mileage: 276964 km
Address 03: ABS Brakes
   Part No SW: 1K0 820 047 JM    HW: 1K0 820 047 JM
   Component: Climatic PQ35   142 1212
   Revision: 00142032    Serial number: 00000000000000
   VCID: 78D100FD0B4E7E8420-802C
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
   Revision: 00H54000    Serial number: 00000008598759
   Coding: 008D8F214004150047140000001400000008730B5C000100000000000000
   Shop #: WSC 01287 785 00200
   VCID: 3245F2D5ADB254D4DE-8066
   Component: Wischer 180608 021  0501
   Coding: 00038805
   Shop #: WSC 01287
                    Reset counter: 149
                    Mileage: 278597 km
                    Voltage: 12.40 V
   Component: 6K AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6D0AURJX
   Coding: 0013899
   Shop #: WSC 01269 785 00200
   VCID: 6CF92CAD4F16C224D4-8038
   Subsystem 2 - Serial number: 6332MSME3D412A66G
   Subsystem 3 - Serial number: 6342MSME3D404B22B
   Subsystem 4 - Serial number: 6352QSME7E485179W
   Subsystem 5 - Serial number: 6362QSME7E48443DZ
   Subsystem 6 - Serial number: 63727SME081E5E1BE
   Subsystem 7 - Serial number: 63827SME08315327X
   Part No SW: 1K0 953 549 BF    HW: 1K0 953 549 BF
   Coding: 0010022
   VCID: 77D303C1065071FC29-8022
00002 - Transmission Control Unit
00576 - Terminal 15
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
   Part No SW: 1K0 920 954 S    HW: 1K0 920 954 S
   Component: KOMBIINSTRUMENT VDD 1222
   Revision: V0003000    Serial number: VWX7Z0H53NR8W4
   Coding: 0007203
   Shop #: WSC 09220 444 84857
   VCID: 3C59DCED7FF692A404-8068
                    Reset counter: 149
                    Mileage: 278597 km
                    Time: 00:11:13
                    Reset counter: 189
                    Mileage: 278597 km
                    Time: 00:16:40
   Component: J533  Gateway   H07 0062
   Revision:   H07 01    Serial number: 280608F2000992
   Coding: ED807F070002020002
   VCID: 354FC9C95CDC43ECFB-8060
                    Reset counter: 149
                    Mileage: 278597 km
                    Time: 00:11:57
                    Reset counter: 189
                    Mileage: 278597 km
                    Time: 00:16:41
   Component: IMMO            VDD 1222
Address 42: Door Elect, Driver        Labels: None
   Part No SW: 1K0 959 701 AK    HW: 1K0 959 701 AK
   Component: Tuer-SG         006 1203
   Coding: 0001205
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.070 H08 1901
   Shop #: WSC 00000 028 00001
00625 - Vehicle Speed Signal
                    Mileage: 278590 km
                    Temperature: 31.0°C
                    Voltage: 14.20 V
                    Voltage: 14.00 V
   Coding: 139006885103083F0904058FB0080F0488DC80
   VCID: 0429640D47862A643C-8050
                    Reset counter: 149
                    Mileage: 278597 km
                    Time: 00:16:56
   Component: Tuer-SG         006 1219
   Coding: 0001204
   VCID: 3957C5F970C4A78C1F-806C
   Part No SW: 1K0 035 180 M    HW: 1K0 035 180 M
   Component: Radio PM6       019 0037
   Revision: 00019000    Serial number: VWZ5Z7H2239753
   Coding: 0040402
   VCID: 2A75EAB585621C1466-807E
                    Fault Frequency: 12
                    Reset counter: 149
                    Mileage: 278344 km
                    Time: 02:14:22
                    Fault Frequency: 7
                    Reset counter: 149
                    Mileage: 278344 km
                    Time: 02:14:22
00857 - CD Changer Unit (R41)
                    Reset counter: 149
                    Mileage: 278344 km
                    Time: 02:14:30
   Component: Tuer-SG         006 1302
   Coding: 0001168
   Shop #: WSC 01279 785 1012552
   VCID: 3851C0FD4BCEBE84E0-806C
   Coding: 0100101
                    Fault Status: 01111000
                    Reset counter: 149
                    Mileage: 278597 km
                    Time: 00:12:59
   Component: Tuer-SG         006 1305
   Coding: 0001168
End-------------------------(Elapsed Time: 01:23)--------------------------
Address 01: DTCs cleared
Address 65: DTCs cleared
Address 19: DTCs cleared
Address 17: DTCs cleared
TIA
iichel
Netherlands, eastern part
C?ID=284912
we could probably help out bit first we'll need a scan to see what the HW/SW version of the new module are.
Probably a MK60EC1 but they have different SW versions etc etc.
I presume you already checked fuses, connectors, GNDs and data lines?
If fuses, connectors, GNDs and data lines are all OK, sometimes those modules can be gotten back to life temporarily with a judicious application of mechanical forces.
Also, since this is presumably a US model car, any VW dealer can pull old scans done at any other dealer from the corporate server.
ThatBeardedGuy
Virginia, USA
I'll have to double check everything to fully eliminate that possibility
I have another 2009 Rabbit parts car (I know) that I was gonna grab the module out of just so I can get this thing road worthy and inspected. I'm sure it will fail again and that's when I'll replace with newer.
I'll have to hook my jump box up to it and try and get that info.
Judicious application of mechanical force is right up my alley.
I did not know that. I'll have to give my local dealer and ring and see if they can pull that information up for me
ThatBeardedGuy
Virginia, USA
Just an update on the dealer searching the main database. Car apparently only had 1 scan with no data. So unlucky for me that option is no longer an option.
I have been busy and it's been pouring rain here so still waiting to get the HW/SW info of the replacement. Will also try the judicial mechanical force and see what happens.
Thanks for all the feedback as of now.
Dana
Western PA, USA
Make sure you give the old unit a few love taps with the ignition off. That may help prevent lost coding if it comes to life key on and then drops back offline due to one too many love taps with the ignition on.
ThatBeardedGuy
Virginia, USA
Another update:
Smacking it didn't seem to help my cause.
I looked at the module I am gonna use to swap and the part # is: 1K0 614 517 BD
That's also what the pump/module shows on the current non communicating one. I know swapping another module from an 09 isn't ideal but if it works enough for them to be able to do the recall I'm fine with it.
Any suggestions now? 🙄
Dana
Western PA, USA
We need to see the scan data from it because 1K0 614 517 BD isn't the SW# or SWL we need.
Since MK60EC1 BS modules fail with great regularity I'd try to get the parts car powered up and obtain the scan data from it. If the parts car ABS module is also faulty, meaning it won't communicate, I wouldn't bother taking it off.
However, if the parts car doesn't power up I suppose you could just pull the used module and plug it into the good car so you can scan it. Don't bother bolting it on or bleeding brakes until you post the scan (because those aren't fun to swap back and forth if the donor isn't correct).
ThatBeardedGuy
Virginia, USA
Was able to get the scan from the parts car. Here that is:
 Friday,25,May,2018,17:21:53:40245
VCDS Version: 18.2.1.2 (x64)
VIN: WVWAB71K19W027029   License Plate: PARTS
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 65
08-Auto HVAC -- Status: Cannot be reached 1100
17-Instruments -- Status: Cannot be reached 1100
25-Immobilizer -- Status: Cannot be reached 1100
Address 01: Engine (CBU)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 N    HW: 07K 906 055 M
   Component: 2,5l R5/4V      G   3255
   Revision: G6H01---    Serial number: VWX7Z0H53NB8A4
   Coding: 0000071
   VCID: 3957C5F970C4A78C20-806C
10 Faults Found:
005386 - Engine Off Timer Performance
               P150A - 000 -  - Intermittent
                    Date: 2047.15.31
                    Time: 31:63:63
                    RPM: 119 /min
                    Load: 100.0 %
                    Speed: 255.0 km/h
                    Temperature: 9.0°C
                    Temperature: 4.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 9.652 V
001152 - Coolant Fan Control Circuit 1
               P0480 - 000 - Electrical Malfunction
                    Temperature: 22.0°C
                    Temperature: -40.0°C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 0.000 V
008581 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
               P2185 - 000 - Signal too High
                    Temperature: 32.0°C
                    Voltage: 12.065 V
000290 - Throttle Position Sensor (G69)
               P0122 - 000 - Signal too Low - MIL ON
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 32.0°C
                    Voltage: 12.065 V
000546 - Angle Sensor 2 for Throttle (G188)
               P0222 - 000 - Signal Too Low - MIL ON
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 32.0°C
                    Voltage: 12.065 V
009266 - Secondary. Air Inj. Sys. Flow/Pressure Sens Bank 1
               P2432 - 000 - Short to Ground
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 33.0°C
                    Voltage: 11.684 V
049493 - No Communication with Instrument Cluster
               U0155 - 000 -
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 33.0°C
                    Voltage: 11.684 V
000264 - Manifold / Barometric Pressure Sensor (G71) / (F96)
               P0108 - 000 - Signal too High
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 33.0°C
                    Voltage: 11.684 V
049508 - No Communications with HVAC Control Module (J301)
               U0164 - 000 -
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 33.0°C
                    Voltage: 11.684 V
000275 - Intake Air Temp. Sensor (G42)
               P0113 - 000 - Signal too High
                    Temperature: 33.0°C
                    Voltage: 11.938 V
   Part No SW: 1K0 907 379 AD    HW: 1K0 907 379 AD
   Component: ESP MK60EC1   H35 0104
   Revision: 00H35001
   Coding: 1162401A494A00228833020C924100413000
   Shop #: WSC 01316 785 00200
   VCID: 74C934CDD7261AE433-8020
01130 - ABS Operation
                    Fault Frequency: 7
                    Reset counter: 96
                    Mileage: 184675 km
                    Count: 4160
                    Count: 33024
                    Count: 12800
                    Count: 125
                    Count: 48452
                    Count: 65266
                    Count: 65280
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 56
                    Count: 2
                    Count: 12544
                    Count: 8193
                    Count: 42752
                    Reset counter: 56
                    Count: 2
                    Count: 12544
                    Count: 8208
                    Count: 42496
03391 - Coding Not Possible
                    Reset counter: 56
                    Count: 2
                    Count: 12544
                    Count: 8254
                    Count: 43776
                    Reset counter: 56
                    Count: 2
                    Count: 12544
                    Count: 8211
                    Count: 43776
   Revision: 00H54000    Serial number: 00000008480174
   Coding: 108D8F214004150047140000001400000008730B5C000100000000000000
   Shop #: WSC 00000 785 00200
   VCID: 3245F2D5ADB254D4E1-8066
   Component: Wischer 310508 021  0501
   Coding: 00038805
10 Faults Found:
                    Fault Status: 01111100
                    Reset counter: 56
                    Voltage: 11.75 V
                    Reset counter: 56
                    Mileage: 187773 km
                    Voltage: 11.80 V
01505 - Bulb for Blinkers; Rear Right (M8)
                    Reset counter: 56
                    Voltage: 11.70 V
                    Reset counter: 56
                    Mileage: 187770 km
                    Voltage: 12.00 V
                    Reset counter: 56
                    Mileage: 183748 km
                    Voltage: 14.15 V
                    Reset counter: 56
                    Voltage: 11.75 V
                    Reset counter: 56
                    Voltage: 11.75 V
                    Reset counter: 56
                    Voltage: 11.75 V
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 56
                    Voltage: 11.75 V
                    Reset counter: 56
                    Voltage: 11.75 V
   Revision: 05034000    Serial number: 003B6D0BBX24
   Coding: 0013899
   VCID: 6CF92CAD4F16C224EB-8038
   Subsystem 1 - Part No: 000 000 000 000
   Component: BF-Gewichtsens. 000 0000
   Subsystem 2 - Serial number: 6332MSME3A7248027
   Subsystem 3 - Serial number: 6342MSME25705856A
   Subsystem 4 - Serial number: 6352QSME67780E11L
   Subsystem 5 - Serial number: 6362QSME64692009E
   Subsystem 6 - Serial number: 637  SME
   Subsystem 7 - Serial number: 63827SME16711551V
10 Faults Found:
01738 - Crash Sensor for Front Airbag; Drivers Side (G283)
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
            009 - Open or Short to Ground - MIL ON
00591 - Seat Belt Switch; Driver (E24)
00592 - Seat Belt Switch; Passenger (E25)
02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
01217 - Side Airbag Igniter; Driver Side (N199)
02511 - Control Module for Seat Occupied Recognition (J706)
   Part No SW: 1K0 953 549 BN    HW: 1K0 953 549 BN
   Coding: 0000022
   VCID: 7F23EBE12E6049BC5E-802A
00576 - Terminal 15
00885 - Ignition Switch (D) Terminal 50
   Revision:   H07 01    Serial number: 300508F1000078
   Coding: E9801F070002020000
   VCID: 354FC9C95CDC43ECC4-8060
                    Reset counter: 56
                    Reset counter: 56
                    Reset counter: 56
                    Reset counter: 56
                    Mileage: 187773 km
                    Time: 00:00:01
                    Fault Frequency: 10
                    Reset counter: 56
                    Mileage: 187773 km
                    Time: 00:00:02
   Component: Tuer-SG         006 1207
   Coding: 0001077
   VCID: 3851C0FD4BCEBE84DF-806C
   Component: EPS_ZFLS Kl.069 H08 1901
   Coding: 139006885103281B0904058FB0080A04889C80
   VCID: 0429640D47862A6403-8050
                    Reset counter: 56
                    Reset counter: 56
                    Mileage: 187773 km
                    Time: 00:00:01
   Coding: 0001076
01553 - Motor for Central Locking; Passenger Door (V57); Lock
Address 56: Radio
   Coding: 0100101
00667 - Ambient Temperature Signal
                    Reset counter: 56
End-------------------------(Elapsed Time: 01:15)--------------------------
Dana
Western PA, USA
Thanks. This DTC is concerning:
Fault Frequency: 7
Reset counter: 96
Mileage: 184675 km
I realize that's a parts car and low voltage (or a crash) could have caused any number of codes however that one is common when MK60EC1 ABS modules start to fail and it had a frequency of 7. So, the replacement may not be long lived but it won't hurt to try. Just make sure to keep the old Hyd pump in the event that you buy a new repair kit from a dealer one day and need to bolt the new revised module onto the old Hyd pump.
Moving forward, I'll try to build ABS coding for VIN: WVWDA71K19W047863 based on the donor ABS:
Revision: 00H35001
Dana
Western PA, USA
iichel
C?ID=284912
1162401A494A00228833020C924100413000 R2,5 CBU 1K chassis LHD FWD WVWAB71K19W027029
1162401A49260001881302EA921C00413000 R2,5 CBT 1K chassis LHD FWD WVWDA71K19W047863 updated for VIN <-- try this code
113B400D49260001881302EA921C00413000 <--- try this code first
System function test http://wiki.ross-tech.com/wiki/index.php/ESP_System_Function_Test
Wiki http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Brake_Electronics_(MK60EC1)
EDIT: sorry Dana didn't see 2nd page of the topic.
I'd recommend to try Danas coding first.
Dana
Western PA, USA
No worries Michel. Jack and I overlap all the time, sometimes I don't even notice until the next day :-)
P.S. we came up with the same (113B400D49260001881302EA921C00413000) so that's excellent.
ThatBeardedGuy
Virginia, USA
The factory condition ABS coding for WVWDA71K19W047863 should be:
If the Shop #: WSC 01316 785 00200 happen to show zeros make sure to enter non-zeros before clicking Do It. After the coding is accepted, the first 3 Basic Setting on this page should be completed:
Awesome, thanks so much to everyone who helped me out. Much appreciated!
I will be swapping them out this weekend so i'll let you know how it goes.
ThatBeardedGuy
Virginia, USA
 Thursday,14,June,2018,09:54:32:40245
65-Tire Pressure -- Status: Not registered 0001
   Coding: 0000075
   VCID: 3B5BDFF17AF8959C32-806E
   Coding: 0000840
   VCID: 7DDF11E9246C5BAC4C-8028
   Revision: 00H35001
   Coding: 113B400D49260001881302EA921C00413000
   VCID: 78D100FD0B4E7E841F-802C
   Coding: 00038805
   Shop #: WSC 01287
                    Reset counter: 150
                    Mileage: 278597 km
                    Voltage: 11.95 V
   Coding: 0013899
   Coding: 0010022
   VCID: 77D303C1065071FC16-8022
   Coding: 0007203
   VCID: 3C59DCED7FF692A43B-8068
   Coding: ED807F060002020002
                    Mileage: 278597 km
                    Time: 16:56:07
   Coding: 0001205
00912 - Window Regulator Switch; Front Left (E40)
02546 - Steering Limit Stop
                    Mileage: 278590 km
                    Temperature: 31.0°C
                    Voltage: 13.60 V
                    Voltage: 13.40 V
   Coding: 0001204
   Coding: 0040402
   VCID: 2A75EAB585621C1459-807E
                    Reset counter: 150
                    Mileage: 278597 km
                    Time: 16:23:21
                    Reset counter: 150
                    Mileage: 278597 km
                    Time: 16:23:21
                    Reset counter: 150
                    Mileage: 278597 km
                    Time: 16:23:29
   Coding: 0001168
   Coding: 0100101
   Coding: 0001168
End-------------------------(Elapsed Time: 01:24)--------------------------
Got the modules swapped out and went through the process and I thought everything went smoothly but it seems the steering angle sensor isn't taking right? I did them all 3 or 4 times and got the same result every time. Am I missing something? The coding seemed to stick without any issue just not the steering sensor.
iichel
C?ID=284912
Hm interesting.
First off all, register the 65 module so the gateway is happy. The licence plate light is not happy but won't affect your G85 either.
03 seems very happy with the coding and calibration.
What if you keep the car stationairy with the engine running and turn the steering wheel from lock to lock for a few cycles?
ThatBeardedGuy
Virginia, USA
Hm interesting.
Yeah I resolved the gateway issue after this scan I do believe but will make sure.
That's gonna be my plan of action when I get home :thumbup:
ThatBeardedGuy
Virginia, USA
Finally got around to getting the rear end back together and was able to drive the car a little to see if the codes cleared. The ABS and ESP light have gone out but I still have the yellow steering wheel light on and these codes remain. I seem to have not done something properly when coding? The CAN Gateway code i'm assuming is from this? The battery had died/needs charging or a change so don't mind the low voltage stuff.
Tuesday,26,June,2018,18:41:02:40245
   Coding: 0000075
   Coding: 0000840
   Revision: 00H35001
   Coding: 00038805
   Shop #: WSC 01287
01598 - Drive Battery Voltage
                    Reset counter: 151
                    Mileage: 278597 km
                    Voltage: 13.75 V
   Coding: 0013899
   Coding: 0010022
   Coding: 0007203
                    Mileage: 278597 km
                    Time: 00:14:01
   Coding: 0001205
                    Mileage: 278590 km
                    Temperature: 32.0°C
                    Voltage: 13.90 V
                    Voltage: 13.70 V
   Coding: 0001204
   Coding: 0040402
                    Reset counter: 40
                    Mileage: 278597 km
                    Time: 16:08:54
                    Fault Status: 00101011
                    Reset counter: 190
                    Mileage: 278597 km
                    Time: 16:23:21
                    Reset counter: 190
                    Mileage: 278597 km
                    Time: 16:23:21
                    Fault Status: 00110100
                    Reset counter: 190
                    Mileage: 278597 km
                    Time: 16:23:29
   Coding: 0001168
01813 - Supply Voltage for Door Controller; Rear Left (J388)
   Coding: 0100101
   Coding: 0001168
01814 - Supply Voltage for Door Controller; Rear Right (J389)
End-------------------------(Elapsed Time: 01:26)--------------------------
