NO ACCESS CENTRAL 17 INSTRUMENTS ADAPTATION POLO TSI 2018!!!
Papa Leguas
Brazil
C?ID=307965
HI EVERYONE,
TODAY I DID CODING IN THE NEW POLO TSI 2018.
BUT I DIDN´T WORK ACCESS IN THE ADAPTATION 17 INTRUMENTS.
I HAD THE ALMOST PROBLEM WITH TIGUAN 2017 TSI CENTRAL 42.
I USED THE VERSION 18.2 HEX NET AND VERSION 18.4 ALPHA, BUT DIDN´T WORK.
BELOW THE COMPLETE SCAN OF THE CAR.
BEST REGARDS AND THANKS FOR THE SUPPORT.
Saturday,19,May,2018,18:15:17:17240
VCDS Version: 18.2.0.3 (x64)  HEX-NET CB: 0.4422.4
VIN: 9BWAH5BZ6JP082403   License Plate:
Mileage: 1272km-790mi   Repair Order:
Chassis Type: BZ-VW27 (2Q0)
Scan: 01 02 03 05 08 09 10 15 17 19 44 5F
VIN: 9BWAH5BZ6JP082403   Mileage: 1272km-790miles
Address 01: Engine (J623-DHSB)       Labels: None
   Part No SW: 04C 906 026 BT    HW: 04C 907 309 AH
   Component: R3 1.0l TFS   H21 5244
   Revision: WVH21---
   Coding: 011A0012232400001000
   Shop #: WSC 01530 935 00200
   ASAM Dataset: EV_ECM10TFS01104C906026BT 001002
   ROD: EV_ECM10TFS01104C906026BT.rod
   VCID: 74A437E1DFF877E40C-8020
   CAN Converter 01:
Address 02: Auto Trans (J217)       Labels: None
   Part No SW: 09G 927 158 CL    HW: 09G 927 158
   Component: AISIN AG6 G3  202 3409
   Coding: 0000000000000000010000000000000000000000
   ASAM Dataset: EV_TCMAQ250031 002009
   ROD: EV_TCMAQ250031_002_VW25.rod
   VCID: 7F4EE8CDE6BE24BC61-802A
   Part No SW: 2Q0 614 517 S    HW: 2Q0 614 517 L
   Component: ESC_base      H13 0222
   Serial number: 86404930180306
   Coding: 33044C673749CCAF3200EC1614DD126A49444D26226A242444541254452848569222B26444562424222A482AA229344004942C0220
   ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004032
   ROD: EV_Brake1BOSCHESPMQBA0.rod
   VCID: 3E30D5C9A134EDB42A-806A
   Component: VWKESSYMQB    037 0907
   Revision: 00037000    Serial number: 0464637692
   Coding: 132C0C0723
   Part No SW: 6EA 820 045 A    HW: 6EA 820 045 A
   Component: SG_AC_Manuell H50 0301
   Coding: 012000000800000000000400000000000000000000000000000000000000
   ASAM Dataset: EV_ACManuePrehMQBA0 001011
   ROD: EV_ACManuePrehMQBA0.rod
   VCID: 302CFBF16B600BC4A8-8064
   Part No SW: 2Q0 937 089     HW: 2Q0 937 089
   Component: BCM A0 Std    H97 0916
   Serial number: 20117344010302
   ASAM Dataset: EV_BCMA0 204001
   ROD: EV_BCMA0_104_VW27.rod
   VCID: 77BE00EDCE8E1CFC29-8022
   Subsystem 1 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
   Component: RLS  047 0105
   Serial number: S2Y18M03D07H08M45S06
   Coding: 0038DD
   Drivers Door Control Module:
   Subsystem 2 - Part No SW: 2Q1 959 881 B    HW: 2Q1 959 881 B
   Component: FHSG_DRV  001 0001
   Serial number: 00000000000018924795
   Coding: 138000
   Subsystem 3 - Part No SW: 2Q1 959 882 D    HW: 2Q1 959 882 D
   Component: FHSG_PSG  001 0002
   Serial number: 00000000000018991182
   Coding: 098000
   Serial number: 000000000ZY173330HF9
   Subsystem 5 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D
   Component: FOND_FHSG_DRV  006 0007
   Serial number: 00000000000018837169
   Coding: 030000
   Subsystem 6 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D
   Component: FOND_FHSG_PSG  006 0007
   Serial number: 00000000000019135148
   Coding: 1B0000
   Part No SW: 5Q0 919 294 L    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0056
   Revision: --------    Serial number: 55401807725128
   Coding: 0011051011
   ROD: EV_EPHVA18AU3700000_002_VW27.rod
   VCID: 44C4A721CFD887647C-8010
   Part No SW: 2QB 959 655     HW: 2QB 959 655
   Component: VW22Airbag    010 0246
   Revision: --------
   Coding: 88C0C00000000000540000CF000000000065
   ASAM Dataset: EV_AirbaVW22BPAVW27X 001010
   ROD: EV_AirbaVW22BPAVW27X.rod
   VCID: 0C544F01A7080F2474-8058
   Subsystem 1 - Part No SW: -----------    HW: 442 1A2 001 18
   Component: SideSensor_Df  2C4 0148
   Serial number: 349B4D2C5292F3F4D2BA
   Subsystem 2 - Part No SW: -----------    HW: 442 1A2 001 18
   Component: SideSensor_Pf  2C4 0148
   Serial number: 350B4D2C5292F3F1E0F2
   Subsystem 3 - Part No SW: -----------    HW: 442 131 001 18
   Component: FrontSensor_D  290 118A
   Serial number: 355AG11A92824C5534AT
Address 17: Instruments (J285)       Labels:* None-SRI3
   Part No SW: 6EA 920 740 A    HW: 6EA 920 740 A
   Component: KOMBI         309 0460
   Coding: 042402082000000C020822001000000000000000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001020
   ROD: EV_DashBoardVDDMQBA0_VW27.rod
   VCID: 3326F4FD9A7630DCD5-8066
   Part No SW: 2Q0 909 901     HW: 2Q0 937 089
   Component: GW MQB A0     H97 0916
   Coding: 0101000020085600F80000081C0F00000001070000000000000000000000
   ASAM Dataset: EV_GatewA0 013020
   ROD: EV_GatewA0_VW27.rod
   VCID: 6FAE388DB6DE543CF1-803A
   Subsystem 2 - Part No SW: 56D 959 442     HW: 56D 959 442
   Component: E221__MFL-834  H01 0130
   Serial number: 000000000B0907190318
   Coding: 200000
Address 44: Steering Assist (J792)       Labels:* None
   Part No SW: 2Q1 909 144 J    HW: 2Q1 909 144 F
   Component: TRW_G4L_MQBA0 610 6030
   Serial number: 02I1J073CB4J087
   Coding: 00000001000000000101020101000101000001
   ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 009014
   ROD: EV_SteerAssisTRWG4LMQBA0_009.rod
   VCID: 393AC6D5B81ACA8C1F-806C
   Part No SW: 5G0 035 280 C    HW: 5G0 035 280 C
   Component: MU-G--RW      557 5516
   Serial number: VWZ7Z2U4677437
   Coding: 02721000BE00000000220001010000002F0000040000010003
   ASAM Dataset: EV_MUGlb4CGen25TPWR 001001
   ROD: EV_MUGlb4CGen25TPWR.rod
   VCID: 210A0EB5308AB24C37-8074
End----------(Elapsed Time: 01:10, VBatt start/end: 12.6V/12.5V)-----------
iichel
Netherlands, eastern part
C?ID=284912
The Polo AW has only been on the market for a few months now, I guess it needs some time before all these things are figured out.
NEtech
C?ID=56995
What problem do you have with adaptation for [Instrument-17] ?
What do you mean, that you had almost problem with Tiguan 2017 ?
Papa Leguas
Brazil
C?ID=307965
Because i had the "same" (wasn't with access "adaptation") problem but the tiguan central 42 and polo central 17. Understand me? I sent the complete scan because i think that in the next release we will solve this problem.
PetrolDave
Westbury, UK
C?ID=1423
What adaptation channel were you trying to access in 17? And what error message did you see?
Did you try using a security access code?
Understand me?
I do not.
Your scan shows VCDS finding a ROD file for that instrument cluster, and there are plenty of Adaptation channels defined in that ROD file.
Your Tiguan problem was different; the chassis was mis-identified by VCDS (due to a different break in the VINs in your market than the rest of the world) causing VCDS not to find ROD for the door control modules.
Whatever problem you are having here does not seem to be at all the same.
Papa Leguas
Brazil
C?ID=307965
I am trying access channel 17 in the adaptation, but the button "adaptation" isn't available to click.
I didnt use the security access code.
Thaks for your attetion.
Papa Leguas
Brazil
C?ID=307965
I do not.
Hi Uwe,
I understand you.
The problem with tiguan was solve. Thank you.
Now, the problem is adaptation in the channel 17.
Thank you for your attention!
If could help me...
Best regards and tks.
Let's be sure we understand. Do you mean address 17, the Instrument Cluster?
A "channel" is usually something lower down, in a function, once we have accessed a module.
Have you seen any error messages?
Papa Leguas
Brazil
C?ID=307965
Yes, you are correct. But the problem is just the button adaptation
I know, but i just informed of the problem.
Unfortunately no. But i remerber something about .ROD.
Helped?
You are not providing enough information for us to understand what could be causing your problem.
How about some screen-shots?
Papa Leguas
Brazil
C?ID=307965
Ok! I will take a picture and i will send you.
Tks,
Papa Leguas
Brazil
C?ID=307965
Papa Leguas
Brazil
C?ID=307965
hello, any news about the post above?
Please try Beta 18.7; it has all-new ROD data.
If it still does not work, please post a complete Auto-Scan from this car made with that version.
Papa Leguas
Brazil
C?ID=307965
Wednesday,16,May,2018,17:42:18:17240
VIN: 9BWAH5BZ0JP068402   License Plate:
Mileage: 75km-46mi   Repair Order:
VIN: 9BWAH5BZ0JP068402   Mileage: 75km-46miles
   Revision: WVH21---
   Shop #: WSC 07165 002 1048576
   CAN Converter 01:
Readiness: 0010 0001
   Serial number: 86403753180119
   Coding: 33044C673747CCB53200EC1614DC126A49444D26226A242444541254452848569222B26444562424222A482AA229344004942C0220
1250 - ABS Operation
          C1016 00 [008] -  -
                    Reset counter: 50
                    Mileage: 55 km
                    Date: 2018.05.16
                    Time: 15:21:30
   Revision: 00037000    Serial number: 0465013805
   Coding: 132C0C0723
          U1400 00 [008] - -
                    Reset counter: 47
                    Mileage: 17 km
                    Date: 2018.05.15
                    Time: 14:09:33
                    Terminal_50_Kessy_specified_value: On
                    Terminal_50_Kessy_actual_value: On
                    ZAT_pressed: On
                    Enabling Steering Column Lock: Condition met
                    Control Module Voltage: 8.692 V
                    Vehicle speed: 0.0 km/h
                    Engine speed: 0.0 /min
                    Status of vehicle locking: Vehicle unlocked at single door
                    Coding information: coded
                    Coding information: Not coded
                    Driver door: closed
                    Front Passenger Door: closed
                    Left rear door: closed
                    Right rear door: closed
                    Active_LF_scans: Init
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
   Component: BCM A0 Std    H97 0915
   Serial number: 20117347021901
   Serial number: S5Y17M09D27H07M10S13
   Coding: 0038DD
   Serial number: 00000000000017895818
   Coding: 138000
   Serial number: 00000000000018236298
   Coding: 098000
   Serial number: 000000000ZY173193M4M
   Serial number: 00000000000018698189
   Coding: 030000
   Serial number: 00000000000018619814
   Coding: 1B0000
   Revision: --------    Serial number: 55401801621322
   Coding: 0011051011
   Revision: --------
   Subsystem 1 - Part No SW: -----------    HW: 442 1A1 912 17
   Serial number: 349B4D1AB28A7CC36243
   Subsystem 2 - Part No SW: -----------    HW: 442 1A1 801 18
   Serial number: 350B4D1B72943BE5035P
   Serial number: 355AG11A72824C55E1D
   Component: GW MQB A0     H97 0915
   Serial number: 000000000A0633030118
   Coding: 200000
   Serial number: 02I130YICB4J054
   Serial number: VWZ7Z2U3628402
End----------(Elapsed Time: 01:10, VBatt start/end: 13.0V/13.0V)-----------
