Issues with White Cluster Swap into 2006 B6 Passat
pskop9
C?ID=312634
I'm having an issue with my white cluster swap. I used a 36/32 pin adapter so i'm having an error code for the 2nd fuel pressure sensor causing my fuel gauge to be off. i'm planning on fixing this today. The issue i can't figure out is that the vehicle status lists two items that i can't "ok" out of. the airbag error, due to the airbag igniter 2 not being resisted out (Planning on doing this weekend), and a service interval reminder. i tried clicking ok on the steering wheel, the back button, i just can't seem to get past the vehicle status menu. I'm guessing this is the reason i'm not able to see any of the audio track names, etc. I can see all other menus such as bluetooth (when my phone is connected), MFA for mpgs, speed, etc, and settings menu (minus convenience). When i had the red cluster, i had to ok past the airbag issue before i could see track names from the radio but i can't seem to do that anymore since the cluster upgrade. Any help would be appreciated. Below is a list of the hardware i'm using:
MK6 GLI Steering Wheel
RCD510 from 2014 Passat (1K0 035 188 F)
Bluetooth Module (7P6035730N)
White Cluster from 2013 Passat (3C8920 971B)
CAN Gateway (3C0907530Q)
Tuesday,08,May,2018,11:35:16:45999
Workshop Code: 028 00028 000001
VIN: WVWFU93C96P141044   License Plate: XXXXXX
Mileage: 93810km-58290mi   Repair Order:
Chassis Type: 3C-VW46 (3C0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 22 25 36 42 44 46 52 53 56
          62 65 72 77
VIN: WVWFU93C96P141044   Mileage: 93810km-58290miles
Address 01: Engine        Labels: 03H-906-032-BLV.clb
   Part No SW: 03H 997 033 M    HW: Hardware No
   Component: P3.6-FSI-LEV2   G00 2370
   Revision: --H08---    Serial number: VWZCZ000000000
   Coding: 0000175
   Shop #: WSC 00028 028 00001
   VCID: 372823B8C346BE4F832-8062
000406 - Engine Oil Temp. Sensor (G8)
               P0196 - 004 - Implausible Signal
                    Mileage: 93497 km
                    Date: 2018.05.05
                    Time: 00:04:46
                    RPM: 646 /min
                    Load: 31.0 %
                    Temperature: 65.0°C
                    Temperature: 45.0°C
                    Absolute Pres.: 830.0 mbar
                    Voltage: 13.716 V
   Part No SW: 09G 927 750 HK    HW: 09G 927 750 AJ
   Component: AQ 250 6F           1271
   Revision: 00H38000    Serial number:
   Coding: 0000072
   Shop #: WSC 20129 444 64522
   VCID: 015C8D60DD0230FF7D6-8054
Address 03: ABS Brakes        Labels:. 3C0-614-095-C2.clb
   Part No SW: 3C0 614 095 Q    HW: 3C0 614 095 Q
   Component: ESP 440 C2     H015 0003
   Revision:  H015       Serial number: 0658525310
   Coding: 0046544
   Shop #: WSC 20129 444 84803
   VCID: 303A18A426286977C28-8064
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
   Part No SW: 3C0 907 044 AC    HW: 3C0 907 044 AC
   Component: ClimatronicPQ46 050 0404
   Revision: 00050005    Serial number: 00000000000000
   VCID: 629EA2EC38448BE704C-8036
00710 - Defroster Flap Positioning Motor (V107)
                    Reset counter: 159
                    Mileage: 93815 km
                    Date: 2018.05.08
                    Time: 11:29:23
                    Reset counter: 159
                    Mileage: 93815 km
                    Date: 2018.05.08
                    Time: 11:29:23
   Revision: 00H46000    Serial number: 00000002275893
   Coding: E5848B1340041000400A00000F00000000680040640000
   Subsystem 1 - Part No: 3C1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer VW461  012  0503
   Coding: 00063445
   Shop #: WSC 00028
   Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 011  1110
   Coding: 00208933
   Shop #: WSC 00028
Address 0F: Digital Radio        Labels: 8E0-035-593-XM.lbl
   Part No SW: 8E0 035 593 E    HW: 8E0 035 593 E
   Component: SDAR XM         H03 0080
   Revision: 00000000    Serial number: AUZ4Z7E2039462
   VCID: 2B000FC80F0E0AAFF7A-807E
                    Reset counter: 159
                    Mileage: 93815 km
                    Date: 2018.05.08
                    Time: 11:28:44
   Part No SW: 3C0 909 605 K    HW: 3C0 909 605 K
   Component: 0M AIRBAG VW8R  029 2521
   Revision: 10029000    Serial number: 003A3PQVZGM%
   Coding: 0012365
   VCID: 2E0606DC3C1C7F87D04-807A
   Subsystem 1 - Part No: 3C0 959 339 A
   Component: BF-Gewichtsens. 006 0002
   Subsystem 2 - Serial number: 00000000032UUM
   Subsystem 3 - Serial number: 0001.01.000000600000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332MSME0D32666CJÿ†63
   Subsystem 5 - Serial number: 2666CJÿ†6342MSME0D451A70Cÿ†63
   Subsystem 6 - Serial number: 51A70Cÿ†6351HTS69SDQUAL2Jÿ†63
   Subsystem 7 - Serial number: QUAL2Jÿ†6361HTS69SDMAN72 ÿ†63
   Subsystem 8 - Serial number: MAN72 ÿ†63727TS6I2IIPQI20ÿ†63
   Subsystem 9 - Serial number: IPQI20ÿ†63827TS6I2I6QN23Fÿ
   Subsystem 10 - Serial number: 6QN23Fÿ
01587 - Igniter 2 for Airbag; Drivers Side (N250)
Address 16: Steering wheel        Labels: 3C0-953-549-SW25.lbl
   Part No SW: 3C0 953 549 AJ    HW: 3C0 953 549 AJ
   Component: J0527               0025
   Revision: 00030000    Serial number: 3C5953507CN
   Coding: 0002811
   VCID: 74B2D4B492B01557660-8020
   Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS   H08 0010
   Coding: 00000131
   Part No SW: 3C8 920 971 B    HW: 3C8 920 971 B
   Coding: 261F00
   VCID: 2C020CD406800D97FE0-8078
9459739 - Fuel Level Sensor 2
          B1058 1B [009] - Resistance Too High
                    Reset counter: 158
                    Mileage: 93815 km
                    Date: 2018.05.08
                    Time: 11:19:24
   Part No SW: 3C0 907 530 Q    HW: 3C0 907 951
   Component: J533  Gateway   H13 0172
   Revision:   H13       Serial number: 3640P1612801E9
   Coding: FD82FF0700170200F102
   VCID: 2F381BD83B16768FDB2-807A
   Part No SW: 3C0 919 965     HW: 3C0 919 965
   Component: Kompass         005 0002
   Revision: 00005000    Serial number: 1166279TPYVX04
   VCID: 6D84C1D0F19AC49FA9E-8038
   VCID: 55F489307D0A6C5F71E-8000
No Faults Found
   Part No SW: 3C0 959 433 Q    HW: 3C0 959 433 Q
   Component:    IMMO         051 0383
   Revision: 00051000    Serial number: VWZCZ000000000
   Shop #: WSC 20129 444 54527
   VCID: 382A2084CE58B1378A8-806C
   Component:    ELV          027 0380
   3C0905861G     ELV          027 0380
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C0 959 760 B    HW: 3C0 959 760 B
   Component: Sitzverstellung     0701
   Revision: 00003000    Serial number: 00000000000000
   VCID: 2C020CD40A000D97FE0-8078
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX2.lbl
   Part No: 1K0 959 701 L
   Component: Tuer-SG         024 2461
   Coding: 0001463
   Part No: 1K1 909 144 K
   VCID: 333017A8D73E526FBFA-8066
   Component:    KSG PQ46 RDK 051 0218
   Coding: 1B910F8801860E761804141FF00A8F0E081800
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX2.lbl
   Part No: 1K0 959 702 L
   Coding: 0001462
   Revision:   013
   Coding: 0000013
   VCID: 211CEDE07DC2D0FF5D6-8074
   Part No SW: 1K0 035 188 F    HW: 1K0 035 188 F
   Component: Radio Prem-8  H05 0008
   Revision: -----09S    Serial number: VWZ4Z7N3483641
   Coding: 0501000001000B
   VCID: 2B000FC8030E0AAFF7A-807E
02633 - Antenna for Satellite Tuner
                    Reset counter: 159
                    Mileage: 93815 km
                    Date: 2018.05.08
                    Time: 11:28:42
                    Reset counter: 159
                    Mileage: 93815 km
                    Date: 2018.05.08
                    Time: 11:28:42
   Part No: 1K0 959 703 D
   Component: Tuer-SG         021 2432
   Coding: 0000144
   VCID: 313C1DA02D22607FCD6-8064
   Component:    RDK              0420
   Coding: 0100100
   Part No: 1K0 959 704 D
   Coding: 0000144
   VCID: 323E12AC28245B67B4C-8066
   Part No SW: 7P6 035 730 N    HW: 7P6 035 730 N
   Component: TELEFON       H16 4217
   Revision: 1B001001    Serial number: 00007666860899
   Coding: 0A10040000010110
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3D243190EDFA941F59E-8068
End----------(Elapsed Time: 02:11, VBatt start/end: 13.7V/13.7V)-----------
PetrolDave
Westbury, UK
C?ID=1423
pskop9
C?ID=312634
The coding for my red gauge cluster was 0007205. I can't copy over the code without having major issues correct?
Definitely not. "0007205" is an older, 'short' coding whereas "261F00" is a newer-style 'long' coding. Yes, that's counter-intuitive since the newer one actually has one digit less.
As for your Service Interval reminder.. What do you have in the SRI-related Adaptation channels?
pskop9
C?ID=312634
I was able to get rid of the SRI item by resetting the oil quality. Now the only issue I have is with the airbag error. Is there a reason why I can't ok past the error message or is there a way to bypass it on the MFA screen? I know I can't get rid of the airbag light on the dash but I have no idea why I can't ok out of the airbag error message
pskop9
C?ID=312634
So i'm super confused now. I resisted out the error for the airbag so i'm all good to go as far as errors on the dash go. No here is where i'm scratching my head. there is no audio track info whatsoever. i scroll through all the options and nothing. See below:
I looked through my radio coding and there are no BAP or DDP options. I'm assuming this is because the radio came out of a 2014 vehicle. what's weird is that when i had my red dash, it would display all audio information from all sources except Bluetooth. Does anyone have any idea on where i could look next? i highly doubt the fuel gauge error is causing my audio info to be missing. I have also removed the navigation from my can list. I had this check by mistake.
On another note, I previously had a compass, can that be coded to the new cluster or would i need to swap CCM's? Auto-scan is below:
Thursday,17,May,2018,19:59:05:45999
Mileage: 94870km-58949mi   Repair Order:
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 22 25 36 37 42 44 46 52 53
          56 62 65 72 77
VIN: WVWFU93C96P141044   Mileage: 94870km-58949miles
   Coding: 0000175
               P0196 - 004 - Implausible Signal - Intermittent
                    Mileage: 93497 km
                    Date: 2018.05.05
                    Time: 00:04:46
                    RPM: 646 /min
                    Load: 31.0 %
                    Temperature: 65.0°C
                    Temperature: 45.0°C
                    Voltage: 13.716 V
   Coding: 0000072
   Coding: 0046544
                    Reset counter: 177
                    Mileage: 94871 km
                    Date: 2018.05.17
                    Time: 19:55:20
   Coding: 00063445
   Shop #: WSC 00028
   Coding: 00208933
   Shop #: WSC 00028
                    Reset counter: 177
                    Mileage: 94871 km
                    Date: 2018.05.17
                    Time: 19:55:19
   Coding: 0012365
   Subsystem 3 - Serial number: 0001.01.000000600000000000ÿ† 63
   Subsystem 4 - Serial number: 000000ÿ† 6332MSME0D32666CJÿ† 63
   Subsystem 5 - Serial number: 2666CJÿ† 6342MSME0D451A70Cÿ† 63
   Subsystem 6 - Serial number: 51A70Cÿ† 6351HTS69SDQUAL2Jÿ† 63
   Subsystem 7 - Serial number: QUAL2Jÿ† 6361HTS69SDMAN72 ÿ† 63
   Subsystem 8 - Serial number: MAN72 ÿ† 63727TS6I2IIPQI20ÿ† 63
   Subsystem 9 - Serial number: IPQI20ÿ† 63827TS6I2I6QN23Fÿ
   Coding: 0002811
   Coding: 00000131
   Coding: 240D00
                    Reset counter: 177
                    Mileage: 94871 km
                    Date: 2018.05.17
                    Time: 19:48:10
   Coding: FD82FF0740170200F102
                    Reset counter: 177
                    Mileage: 94871 km
No Faults Found
Address 37: Navigation
   Coding: 0001463
   Coding: 0001462
   Revision:   013
   Coding: 0000013
   Coding: 00000001010010
                    Reset counter: 177
                    Mileage: 94871 km
                    Date: 2018.05.17
                    Time: 19:55:18
                    Reset counter: 177
                    Mileage: 94871 km
                    Date: 2018.05.17
                    Time: 19:55:18
   Coding: 0000144
   Component:    RDK              0420
   Coding: 0100100
   Coding: 0000144
End----------(Elapsed Time: 02:13, VBatt start/end: 13.4V/13.5V)-----------
Spacewalker
Poland
C?ID=159607
radio is too old ,
pskop9
C?ID=312634
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
For radio, go to Gan gateway and uncheck 37 -Navi, then save new list. I do not think RCD-510 have Navi .
For Compass , you have to add GPS antenna to RCD-510 to have compass.
But your main problem will be fuel gauge , it will not read correct, because cluster not see Fuel level sensor 2.
For this email me direct.
Coding: 240D00
Reset counter: 177
Mileage: 94871 km
Date: 2018.05.17
Time: 19:48:10
pskop9
C?ID=312634
i'm gonna try to disconnect the battery and see if maybe that fixes the missing compass and audio menu. i can fix the fuel gauge once i get the pins for the harness in the mail
Spacewalker
Poland
C?ID=159607
Coding: 240D00
he have 4WD, he just need missing PIN into adaptor ,. he knew that already
pskop9
C?ID=312634
After disconnecting the battery for an hour, the audio menu appeared on the cluster. All is good now. Regarding the compass, what will I need to enable this?
mreuro
C?ID=48919
I have the same issue with fuel gauge. Can you provide what pins have to be changed or added. Thank you.
Spacewalker
Poland
C?ID=159607
but what happen ?
you did retrofits , or what ...
more details always need ...not just simple "help"
kamold
Australia
C?ID=241363
For Passat you need to modify the 32-36 pin adapter harness as they do not include all the needed wires (add these wires)
Black 36 pin -> Blue 32 pin
16 -> 3
23 -> 4
Suitable for Passat 4mo.
For Golf 4mo you also need to add a wire to fuel sender 2 under the back seat as it is missing a wire from the fuel sender to the cluster at pin 4 of the new 32pin connector.
mreuro
C?ID=48919
but what happen ?
Yes I did retrofit Cluster from 2012 CC and I did get the adapter and I do have the same codes and the fuel gauge is only showing 1/2 tank.
mreuro
C?ID=48919
16 -> 3
23 -> 4
Thank you!
mreuro
C?ID=48919
I know I still have to code the cluster to read from two fuel senders not one. I found where I have to do it but i need the security code to do it. I have looked and I found one security code but it still wont let me change it from 1 to 2.
The code I found is 25327 was accepted but not to change what i need to change.
Spacewalker
Poland
C?ID=159607
no ...you dont now
this always show 1 , even if car is factory 2 fuel sensor
