Hello everyone,
I am a new user on this great forum. I am a car mechanic and mostly like troubleshooting on cars.
Hope to be able to help people on this forum and also like to ask for help when needed.
For now some advice is appreciated in this case :
How to remove the static speed limiter on this VW Crafter 2.0 tdi year 2012, ecu is bosch edc17c54 by VCDS ?
Tried engine ecu--> security acces 12233--> adaption , there are three channels there : 1. Static speed limit, 2.Activation of static speed limit, 3. Deactivation of static speed limit.
When I select option 1. and try to change value 90 kmh/h to 160 km/h i get massege request out of range.
Same issue when I choose option 2 , try to change "On" to "Off" , and option 3 : change value to 01 or 00 or other value
What is problem here : need other security code ?
Also see label file and screen shots oploaded here : https://we.tl/xBNQwpBUov
Best regards
John
Best regards
John
Monday,23,April,2018,17:02:57:06375
VCDS Version: 17.8.1.0 (x64)
Dealer/Shop Name:
VIN: WV1ZZZ2EC700xxx License Plate:
Chassis Type: 2F-N/A (2E - VW Crafter Panel Van (LT3 / 2006 > 2016))
B0 B1 B2 B3 B4 B5 B6 C1
VIN: WV1ZZZ2EZC700xxxx
Address 01: Engine (J623-CKTC) Labels:. 03L-906-012-CKT.clb
Part No SW: 03L 997 403 A HW: 03L 906 012 A
Component: R4 2.0l TDI H23 9978
Revision: 72H23--- Serial number: VWZCZ000000000
Coding: 0119401220440C080000
ASAM Dataset: EV_ECM20TDI01103L997403A 002002
ROD: EV_ECM20TDI01103L997403A.rod
VCID: 306F112F6B3BB4C621-8064
17262 - Terminal 30
U140A 00 [032] - Open Circuit
Vehicle speed: 255 km/h
Coolant temperature: -40 °C
Intake air temperature: -40 °C
Ambient air pressure: 0 mbar
Voltage terminal 30: 11.500 V
Unlearning counter according OBD: 13
Engine control module reset status-Bit 0: 0
Engine control module reset status-Bit 8: 0
Limitation: torque: 0.0 Nm
Engine torque: -500.0 Nm
Generator: load signal: 0.00 %
Address 93: LT3 Immo Labels: 2E0-905-865-93.clb
Part No SW: 2E0 909 052 HG HW: 906 900 200 0
Component: IMMO 0805 1006
Revision: 00805000 Serial number: VWXDZ0K1031296
Shop #: WSC 30745 002 1048576
VCID: 6FEDD2537E85EB3E78-803A
01312 - Powertrain Data Bus
02241 - Engine Control Module; Immobilizer Data not Adapted
Address 94: LT3 Airbag
Part No HW: 9069014700
Shop #: WSC 00118 555 00000
ASAM Dataset: 3 3332
ROD: CRFT_AB_3_3331.rod (*)
VCID: 55A180BB3419B1EE92-8000
Address 95: LT3 ESP
Part No SW: 9069022500 HW: 0004460153
ASAM Dataset: 3 4102
ROD: CRFT_ESP_3_4102.rod
VCID: 010984EB9011ED4E9E-8054
Address 96: LT3 Instruments
Part No SW: 9069026000 HW: 9069015000
ASAM Dataset: 32 788
ROD: CRFT_KOMBI_32_788.rod
9100 - Drivetrain CAN: No communication
Test Complete - Stored
Address 99: LT3 Ign. Switch
Part No HW: 9069002000
ASAM Dataset: 67 257
ROD: CRFT_EZS_67_257.rod (*)
Address 9A: LT3 Central Locks Labels: 2E0-905-865-9A.clb
Component: HF-FFB 0805 1006
Revision: 00805000 Serial number: 12345678901234
00172 - Key 2 not learned
Address 9B: LT3 Driver Door
Part No HW: 9068205626
ASAM Dataset: 33 260
ROD: CRFT_FTUHR_33_260.rod
Address 9C: LT3 HVAC
Part No SW: 2514450200 HW: 9068300885
ASAM Dataset: 21 3
ROD: CRFT_KLIMA_21_3.rod (*)
VCID: 77FDEA33CED5A3FEA0-8022
Address B3: LT3 Trailer Module
Part No HW: 1695455632
ASAM Dataset: 21 4
ROD: CRFT_TRL_21_4.rod (*)
Address B4: LT3 Central Elec.
Part No SW: 9069027500 HW: 9069011300
ASAM Dataset: 33 292
ROD: CRFT_EZE_33_292.rod (*)
VCID: 060397F7B93FCA76AB-8052
6 Faults Found:
9042 - Front Interior Light (W1): Short to Plus
Test Complete - Active/Stored
9020 - Bulb for Left Taillamp (M4): Open circuit
901A - Perimeter lights: Open circuit
9023 - Bulb for Right Taillamp (M2): Open circuit
901C - License plate lights/side-marker lights: Short to Plus
90B5 - Control module: Faulty
Address B6: LT3 Steering Wheel
Part No SW: 9065402545 HW: 9065402545
ASAM Dataset: 72 257
ROD: CRFT_SML_72_257.rod (*)
VCID: 081F99CFB32BDC06D9-805C
End-------------------------(Elapsed Time: 02:56)--------------------------
