z0re
New Member
Hi, my Audi A6 was skidded in the snow and hit a kurb at approx 15 miles an hour. There was no body panel damage. However the rear wheel was bent and drivers seat and curtain airbag deployed.
The wheel hub, seat and curtain airbag were changed.
Before changing the airbag SRS, i wanted to clear all the codes which I have not been able to do. The errors in the airbag module are
1) Igniter for battery interrupt B1015 1B [137] - Resistance Too High
2) Driver's Belt Force Limiter Igniter B1013 1B [137] - Resistance Too High
3) Passenger's Belt Force Limiter Igniter B1014 1B [137] - Resistance Too High
4) Igniter for Seat Belt Tensioner; Driver's Side B1006 1B [137] - Resistance Too High
5) Igniter for Seat Belt Tensioner; Passenger's Side B1007 1B [137] - Resistance Too High
6) Multiple collision brake B13BC F2 [137] - No function
I will need to replace the drivers seat beat. Do I need to replace the passengers airbag? How can I clear error 1, or do I need to replace the interrupt? How can I clear error 6?
Full scan below. Any help on this much appreciated.
any help much appreciated.
Friday,20,April,2018,15:44:23:64250
VCDS Version: 18.2.0.3 (x64)
VIN: WAUZZZ4G8 License Plate: AUDIA6
Mileage: 25807km-16035mi Repair Order:
Gateway Installation List: 4G5 907 468 K
Chassis Type: 4G-AU57 (4G5)
Scan: 01 02 03 05 08 09 15 16 17 19 20 28 36 3B 42 44 46 52 53 55
5F 62 72 AC
VIN: WAUZZZ4G8 Mileage: 25807km-16035miles
Address 01: Engine (J623-DDDA) Labels: None
Part No SW: 04L 906 021 HC HW: 04L 907 309 AA
Component: R4 2.0l TDI H20 4164
Revision: 8DH20---
Coding: 0A254012242601080000
ASAM Dataset: EV_ECM20TDI01104L906021HC 004004
ROD: EV_ECM20TDI01104L906021HA_004.rod
VCID: 6DDBD358BC6B042CC3-8038
U1113 00 [039] - -
Mileage: 25807 km
Date: 2018.04.20
Time: 15:43:23
Coolant temperature: 63 °C
Intake air temperature: 56 °C
Voltage terminal 30: 11.600 V
Cruise Control System (CCS): switch position-Bits 0-7: 129
Cruise Control System (CCS): status-Bits 0-7: 44
Cruise control switch-off: irreversible-Bits 0-7: 255
Cruise control switch-off: reversible-Bits 0-7: 255
Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
U1113 00 [039] - -
Mileage: 25807 km
Date: 2018.04.20
Time: 15:43:23
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 4G0 927 166 N HW: 0B5 927 156 K
Component: 0B5 20 TDIRdW H06 0004
Revision: --H06---
Coding: 100001
ASAM Dataset: EV_TCMDL501021 001022
ROD: EV_TCMDL501021.rod
VCID: 3875320C83A97184E0-806C
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 4G0 907 379 S HW: 4G0 907 379 S
Component: ESP9 Premium H01 0530
Coding: 06A69E41606579829B00
ROD: EV_ESP9BOSCHAU57X.rod
VCID: 41835FE8D073304C57-8014
178432 - Function Restriction due to Faults in Other Modules
U1113 00 [047] - -
Mileage: 25807 km
Date: 2018.04.20
Time: 15:43:24
VzRef: 00
Bit Info 1: 00
Bit Info 2: 02
Bit Info 3: 22
Bit Info 4: 1F
Uz: 95
178688 - Function Restriction due to Implausible Message(s)
U1112 00 [035] - -
179200 - Function Restriction due to Faults in Other Modules
U1113 00 [035] - -
179456 - Function Restriction due to Implausible Message(s)
U1112 00 [035] - -
201728 - Control Module Incorrectly Coded
U1014 00 [253] - -
MIL ON - Confirmed - Not Tested Since Memory Clear
Mileage: 25802 km
Date: 2018.03.17
Time: 05:54:42
VzRef: 00
Bit Info 1: 40
Bit Info 2: 0F
Bit Info 3: 06
Bit Info 4: 1F
Uz: 9B
Part No SW: 4H0 907 064 HN HW: 4H0 907 064 HN
Component: BCM2 2.0 H61 0825
Coding: 01B8704E000000000000
VCID: 7CFDEE1CFF119DA444-8028
Serial number: 3217000080927007
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 CD HW: 4G0 820 043 CD
Serial number: 08051700040082
Coding: 34210978210000
VCID: 63CFB5606AAF425C65-8036
0554 - Function limitation due to crash signal
B1397 00 [009] - -
Reset counter: 127
Mileage: 25807 km
Date: 2018.04.20
Time: 15:43:23
Voltage terminal 30: 11.71 V
Address 09: Cent. Elect. (J519) Labels: Redir Fail!
Part No SW: 4H0 907 063 GH HW: 4H0 907 063 AH
Component: BCM1 2.0 H20 0368
Revision: 1502003S Serial number: 00001660311202
Coding: 0105001440349FE041014083800018000F9DC3082F08020100000894E100150200400024030000
VCID: 74EDC63CD741D5E40C-8020
Component: WWS57X 170301 H38 0080
Serial number: 170401060325
Coding: 0045F7
Subsystem 2 - Part No SW: 81A 955 547 A HW: 81A 955 547
Component: G397_RLFS H06 0002
Serial number: 20208883X81A955547A0
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 BE HW: 4G0 941 531 BE
Component: E1 - LDS H07 0044
Serial number: 18 04 2017 00000173
Subsystem 4 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H01 0006
Serial number: 2DB886A800PAG0MUFU03
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 127
Mileage: 25807 km
Date: 2018.04.20
Time: 15:43:24
Reset counter: 127
Mileage: 25807 km
Date: 2018.04.20
Time: 15:43:23
Address 15: Airbags (J234) Labels:| 4H0-959-655.clb
Component: Airbag10.43 H82 0092
Revision: -------- Serial number: 003P100DJXHP
Coding: 30333130313630323639554A305234473053
VCID: 3B7F2D00B29F5A9C0D-806E
Serial number: 3575HRB401859KNIB1PS
Serial number: 3585HRB400S59KNIFOSZ
Serial number: 3515JRB400E59H1UH8GK
Serial number: 3525JRB400A59H1UR9CO
Serial number: 3554VRB405L4PF6INOP+
Serial number: 3564VRB400O59ISIG958
6 Faults Found:
9442587 - Igniter for battery interrupt
Mileage: 25807 km
Date: 2018.04.20
Time: 15:43:29
9442075 - Driver's Belt Force Limiter Igniter
Mileage: 25807 km
Date: 2018.04.20
Time: 15:43:29
9442331 - Passenger's Belt Force Limiter Igniter
Mileage: 25807 km
Date: 2018.04.20
Time: 15:43:29
Mileage: 25807 km
Date: 2018.04.20
Time: 15:43:29
Mileage: 25807 km
Date: 2018.04.20
Time: 15:43:29
9682162 - Multiple collision brake
Mileage: 25807 km
Date: 2018.04.20
Time: 15:43:39
Part No SW: 4H0 953 568 K HW: 4H0 953 568 K
Component: Lenks.Modul H06 0005
Revision: C0068538 Serial number: 91560QDS0009F
Coding: 000034
VCID: 3B7F2D00BA9F5A9C0D-806E
Serial number: 03 03 2017 E0011278
Address 17: Instruments (J285) Labels:. 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 951 E HW: 4G8 920 951 E
Component: MDieGb H43 0604
Revision: 32450309 Serial number: 658040517592040
Coding: 33A60D000B412600010000
ASAM Dataset: EV_RBC7KMID 004050
ROD: EV_RBC7KMID.rod
VCID: 3261002465D59BD4DE-8066
Part No SW: 4G5 907 468 K HW: 4G0 907 468 AC
Component: J533--Gateway H15 0110
Revision: -------- Serial number: 00000002599692
Coding: C0CD074418
ASAM Dataset: EV_GatewPkoUDS 002011
ROD: EV_GatewPkoUDS_002.rod
VCID: 3D7B2318AC8B54AC33-8068
Subsystem 1 - Part No SW: 8S0 915 181 B HW: 8S0 915 181 B
Serial number: 2003993604
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 D HW: 8K0 959 663 D
Component: J532_DCDCStab H23 0022
Serial number: 170221000000000000CD
Address 20: High Beam Assist. (J844) Labels: None
Part No SW: 4H0 857 511 HW: 4H0 857 511
Component: FLA H04 0021
Revision: AA001002
Coding: 04028264747464545425363E00
VCID: 67D7A17096972E7CB9-8032
Address 28: HVAC, Rear (E265) Labels:* 4G0-919-158.clb
Part No SW: 4G0 919 158 Q HW: 4G0 919 158 Q
Component: KLIMA FOND H08 0113
Serial number: 05051700040114
Coding: 22
Component: MEM-FS H03 0157
Revision: AA000000 Serial number: 00000253239485
VCID: 77F7F130C637BEFC29-8022
Part No SW: 4G0 907 637 H HW: 4G0 907 637 D
Component: SARA 3D H04 0056
Revision: -------- Serial number: EJ1BPA720WKRMI
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 336F05209ACF92DCD5-8066
Component: TSG FA H03 0511
Coding: 011C16015E01620002080002
VCID: 479741F0F6570E7C99-8012
Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
Component: RCevo H54 0202
Revision: 00000002 Serial number: 0000796085
Coding: 101000010001
ASAM Dataset: EV_RCEPS 106007
ROD: EV_RCEPS_106.rod
VCID: 3A712804BDA5639416-806E
6628353 - Internal Control Module Memory Check Sum Error
B2000 49 [137] - Internal electronic failure
Mileage: 25802 km
Date: 2018.03.17
Time: 05:46:32
Revision: 00002001 Serial number: 0440925914
Coding: 011B062280B90080C320088400010E470000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177 B
Component: Sensor, DWA 005 0002
Subsystem 2 - Part No: 1K0 951 605 F
Component: LIN BACKUP HO H01 0008
Subsystem 3 - Part No SW: 4G0 947 135 B HW: 4G0 947 135
Serial number: 0000000AP00032787587
Component: TSG BF H03 0511
VCID: 46894CF4F15D177462-8012
Part No SW: 4H0 907 801 M HW: 4H0 907 801 M
Component: EPB-4 H01 0018
Revision: -------- Serial number: 00000002187717
ROD: EV_ParkiBrake_VW51.rod
Address 55: Headlight Range (J745) Labels:| 4H4-907-357-V2.clb
Component: MxB-ECU 001 0100
Coding: 04FE02102A600200
VCID: 346D063C9FC195E4CC-8060
Subsystem 1 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7560
Coding: E01E00
Subsystem 2 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7560
Coding: E01E00
Part No SW: 4G1 035 192 F HW: 4G1 035 192 A
Component: RMC Nav Plus H62 0186
Coding: 010100010141DB47082B060301010000000000
VCID: 2649EC74511DF77442-8072
Subsystem 1 - Part No: 8X0 919 884 K
Component: P38-50-16.03 0001
Subsystem 2 - Part No SW: 4G0 919 603 B HW: 4G0 919 603 B
Component: DU6 Basic H43 0084
Serial number: 9464D$0H2809208
Subsystem 3 - Part No SW: 4G2 919 610 E HW: 4G2 919 610 E
Serial number: 90349QE4000BN
Component: TSG HL H03 0511
VCID: 499347C8E043F80C8F-801C
Component: TSG HR H03 0511
Part No SW: 4G0 907 355 G HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0013
Revision: 00000000 Serial number: 170941107
ROD: EV_RDCMA00100_008.rod
VCID: 2F67095076E7B63CB1-807A
End-------------------------(Elapsed Time: 04:37)--------------------------
