I had to remove temporarly the front grill where the ACC radar is located. I think I might have turn the ignition on during the process. Since then, I have this error that doesn't want to go away:
Address 13: Auto Dist. Reg Labels: 3Q0-907-572.CLB
Control Module Part Number: 5Q0 907 572 J HW: 3QF 907 572
Component and/or Version: ACC BOSCH MQB H10 0654
Software Coding: 3500004101FFC728949C810520400600000000000000000000
Work Shop Code: WSC 00066 790 00075
ASAM Dataset: EV_ACCBOSCHVW416 002006 (VW37)
ROD: EV_ACCBOSCHVW416.rod
VCID: 3E25C39DD0FC1FA75A9-806A
0791 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [009] - -
[FAULT_MISALIGNMENT_VERTICAL]
Reset counter: 149
Mileage: 6244 km
Date: 2018.04.20
Time: 14:10:12
Control Module temperature: 30 °C
Voltage terminal 15: 14.0 V
I drove for at least 6h since then and the problem doesn't want to go away. I've read that it should calibrate itself after some time, but I'm starting to doubt that it's actually the case. Current values are :
I've read somehwere that there should be a "reset vertical misalgnment" option, but this one seems unavailable for my unit. I do have a "Calibration of adaptive cruise control" but I believe this one require special hardware.
Any tips or help to prevent a dealearship visit would be appreciated!
C1103 00 [009] - -
Reset counter: 149
Mileage: 6244 km
Date: 2018.04.20
Time: 14:10:12
