Controller Maps
gdallas
C?ID=95831
Hi guys,
I have a number of modules with no labels so have watched the video how 2 for instructions. Seems straightforward but I was just wondering how long it normally takes for maps to be incorporated into a build once they are emailed over? My car is an A6 2015 3.0 BITDI. I've only had my new cable a week.
There's no set time frame for this. Maps help, but generally aren't sufficient by themselves.
gdallas
C?ID=95831
OK, appears I have 10 modules that dont have labels. Ive emailed all the 46 map files to you guys.
Monday,16,April,2018,20:45:38:12530
VIN: WAUZZZ4G8GN095717   License Plate:
Mileage: 24629km-15303mi   Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 20 28 3B 42 44 46 52 53 55 5F
          62 72 A9 AC C0
VIN: WAUZZZ4G8GN095717   Mileage: 24629km-15303miles
Address 01: Engine (J623-CVUA)       Labels: None
   Part No SW: 4G0 907 589 D    HW: 4G0 907 589 B
   Component: 3.0BTD EDC17  H23 0002
   Revision: 54H23---
   Coding: 0A2A4032252603030000
   ASAM Dataset: EV_ECM30BTD0114G0907589D 001002
   ROD: EV_ECM30BTD0114G0907589D.rod
   VCID: 3537DC9805C2798F91E-8060
   Part No SW: 4G0 927 158 AK    HW: 0BK 927 156 AM
   Component: 0BK 30RTDIRdW H19 1005
   Revision: --H19---
   Coding: 000001
   VCID: 77AB16905F4E4B9F432-8022
   Coding: 49A79E4192E579829B00
   ROD: EV_ESP9BOSCHAU57X.rod
   VCID: 41DFB848410AC52F3D6-8014
124416 - Function Restriction due to Faults in Other Modules
          U1113 00 [040] - -
          [Ldm_ApbFailureState]
                    Mileage: 24425 km
                    Date: 2018.04.13
                    Time: 09:31:14
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 00
                    Bit Info 3: 22
                    Bit Info 4: 1F
                    Uz: 9A
   Part No SW: 4H0 907 064 GN    HW: 4H0 907 064 GN
   Component: BCM2 2.0      H37 0572
   Coding: 01B8704E000000000000
   VCID: 7BA30AA063E66FFF27A-802E
   Serial number: 0215000188678006
00956 - Key 2
                    Reset counter: 61
                    Mileage: 22750 km
                    Date: 2018.03.22
                    Time: 13:55:41
   Part No SW: 4G0 820 043 CC    HW: 4G0 820 043 CC
   Component: KLIMA 4 ZONEN H14 0112
   Serial number: 08101500040560
   Coding: 36211178210000
   VCID: 629D57C4E4CCBE3704C-8036
Address 09: Cent. Elect. (J519)       Labels: Redir Fail!
   Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
   Revision: 15020001    Serial number: 00001182453302
   Coding: 0105801440349FE0410140C0000018000F9DC3082F08020100000894E100150200400024030000
   VCID: 71BF288831AA15AF8D6-8024
   Component: WWS57X 150715  H38 0080
   Serial number:         150819223949
   Coding: 0045F7
   Serial number: 20763505
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
   Component: E1 - LDS  H07 0044
   Serial number: 13 10 2015  00000873
   Serial number: ED8880D7000000000001
Address 15: Airbags (J234)       Labels:| 4H0-959-655.clb
   Part No SW: 4H0 959 655 H    HW: 4H0 959 655 H
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P1006SWY0
   Coding: 30333130313730323737554A305234473053
   VCID: 3B23CAA023E6AFFF67A-806E
   Serial number: 3575HRB40633JUD03OCK
   Serial number: 3585HRB40573KGI0APDP
   Serial number: 3515JRB404T3JK6259MM
   Serial number: 3525JRB40633FSTU6HIG
   Serial number: 3554VRB400S553HED8T/
   Serial number: 3564VRB400S553HED90D
   Revision: C0068538    Serial number: 90862OJC00068
   Coding: 000034
   VCID: 3B23CAA02366AFFF67A-806E
   Serial number: 01 09 2015  C0002893
   Part No SW: 4G8 920 986 M    HW: 4G8 920 986 M
   Component: TDieGb        H11 0106
   Revision: 07001088    Serial number: 658150915596041
   Coding: 23A70A000B412600010000
   ASAM Dataset: EV_RBD4K 004055
   ROD: EV_RBD4K.rod
   VCID: 42DDB744440CDE3724C-8016
   Part No SW: 4G8 907 468 F    HW: 4G8 907 468
   Component: J533--Gateway H14 0083
   Revision: --------    Serial number: 00000002004092
   Coding: C0CD078118
   ASAM Dataset: EV_GatewPkoUDS 001028
   Serial number: 1931577903
   Voltage stabilizer:
   Serial number: 150725000000000004E9
   Part No SW: 4H0 857 511     HW: 4H0 857 511
   Component: FLA           H04 0021
   Revision: AA001002
   Coding: 04028264747464545425363E00
   VCID: 678B46D00F6EDB1FD32-8032
   Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
   Component: KLIMA FOND    H08 0112
   Serial number: 09101500040125
   Coding: 22
   VCID: 3D27C4B83DF2A1CF59E-8068
   Component: SARA 3D       H04 0056
   Revision: --------    Serial number: EJ1BPA720KW0DP
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 3333E2800BB667BFBFA-8066
   Coding: 011C16014001620002080002
   VCID: 47CBA6506FAEFB1FF32-8012
   Component: RCevo         H53 0202
   Revision: 00000002    Serial number: 0000283456
   Coding: 101000010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   VCID: 3A2DCFA42CDC96F77CC-806E
   Revision: 00002001    Serial number: 0382488804
   Coding: 011F062280B90000C320080400010E470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177 A
   Component: Sensor, DWA  005 0002
   VCID: 46D5AB5468A4E217084-8012
   Revision: --------    Serial number: 00000001619448
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D07F4F8ED92314FE9E-8078
   Coding: 04FE02102A630200
   VCID: 3431E19C0EB86087A60-8060
   Coding: E01E00
   Coding: E01E00
   Part No SW: 4G1 035 021 E    HW: 4G1 035 021
   Component: MU-H-LND-EU   042 0335
   Serial number: A588J0F7528209
   Coding: 017501010000000013111102000A00132F0006E7F1700100DF
   ROD: EV_MUHig6C3Gen2HBAS_AU49.rod
   VCID: 1C61293C8628C8C78E0-8048
   Subsystem 1 - Part No SW: V03 959 801 FC    HW: -----------
   Component: ECE 2017  --- 0157
   Subsystem 2 - Part No SW: 4G1 919 605 A    HW: 4G1 919 605 A
   Component: DU8 C7 SV  H63 0006
   Serial number: AUZ8Z9FY802QD8
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 4G2 919 610 F    HW: 4G2 919 610 F
   Serial number: 90349OJ6000EJ
   Component: Gracenote  --- 1010
   VCID: 49CFA06879BA0D6FE56-801C
   Part No SW: 4G0 907 159 D    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0007
   Serial number: 151002203103
   VCID: 2E05F3F4E0944A57D04-807A
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 152451062
   ROD: EV_RDCMA00100_008.rod
   VCID: 2F3BEEF0E79E435FDB2-807A
Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
   Part No SW: 4G0 907 160 E    HW: 4G0 907 160 B
   Component: SAS-GEN 2 AGA H09 0011
   Serial number: 151001200324
   VCID: 270B06D0CF6E1B1F132-8072
End----------(Elapsed Time: 02:00, VBatt start/end: 14.4V/14.4V)-----------
Tuesday,17,April,2018,11:31:37:12530
          62 72 A9 AC C0
   Revision: 54H23---
   Revision: --H19---
   Coding: 000001
Address 05: Acc/Start Auth. (J393)       Labels:. 8K0-907-064-05.CLB
Address 09: Cent. Elect. (J519)       Labels: REDIR FAIL!
   Coding: 0045F7
   Coding: 02006D
Address 16: Steering wheel (J527)       Labels:. 4H0-953-568.CLB
   Coding: 000034
   ROD: EV_RBD4K.rod
   Component: J533--Gateway H14 J533--Gateway H14 00830083
   Coding: C0CD078118
   Voltage stabilizer:
Address 20: High Beam Assist. (J844)       Labels: NONE
   Revision: AA001002
   Coding: 22
   ROD: EV_SARA2.rod
Address 42: Door Elect, Driver (J386)       Labels: NONE
Address 46: Central Conv. (J393)       Labels:. 4H0-907-064-46.CLB
Address 52: Door Elect, Pass. (J387)       Labels: NONE
   Coding: E01E00
   Coding: E01E00
Address 62: Door, Rear Left (J388)       Labels: NONE
Address 72: Door, Rear Right (J389)       Labels: NONE
End------(Elapsed Time: 20:27, VBatt start/end: 14.5V/12.9V, Deb=2)--------
