2013 Audi S4
Unitronic Stage 2 + DSG tune + bolt-ons
Hi All,
This is my first post so if I have made any mistakes according to the proper format of posts for this forum please bring it to my attention.
FAILED EMISSIONS TEST
I had my battery disconnected for a few days while I was working on my vehicle in preparation for an upcoming track day. After putting everything back together I drove to get it inspected and failed. I was told all 4 O2 sensors failed which implied that there was no readings after the battery was disconnected. No check engine light. I drove it a few times over the next week (I drive this vehicle on average 20 miles a week but recently I've driven it a little more to see if I could get the car to set its own readiness). Went back for an inspection the following week and failed again.
I reached out to ROSS-TECH and received the HEX-V2. After performing an [Automatic Test Sequence] in the Basic Settings I produced the following logs:
This may be too much information or not the correct information needed to assess the problem so let me know what you guys are looking for. I do know that running the fault codes after using the test sequence will produce something like "EVAP Systems failure" or something similar to that.
Where I am lost is if I have a bad part or if the ECU is just refusing to complete certain tests. My registration is due so it would be nice to get this sorted. I appreciate in advance any information to point me in a direction
Hi All,
Friday,13,April,2018,14:33:59:24600
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(Parallels)
VCDS Version 18.2.0.3 (x64) HEX-V2 CB: 0.4411.4
VIN: WAUBGAFL8DA199680 License Plate:
Mileage: 99860km-62050mi Repair Order:
Chassis Type: FL-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 36 42 44 46 47 52 53 56 5F
62 6C 72 A9
VIN: WAUBGAFL8DA199680 Mileage: 99860km-62050miles
Address 01: Engine (J623-CGXC) Labels:. 06E-907-551-CGW.clb
Part No SW: 8K5 907 551 E HW: 4G0 907 551 A
Component: 3.0l V6 TFSIX07 0002
Revision: --X07---
Coding: 0A250034052600060000
Shop #: WSC 06208 000 00000
ASAM Dataset: EV_ECM30TFS0218K5907551E 001002
ROD: EV_ECM30TFS0218K5907551E.rod
VCID: 3829D4FF22D58A478A8-806D
Readiness: 1110 1101
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 8K2 927 156 M HW: 0B5 927 156 J
Component: 0B5 30TFSINAR H01 0011
Revision: --H01---
Coding: 000001
Shop #: WSC 06325 000 00000
ROD: EV_TCMDL501021.rod
VCID: 40D9BC1F7A05C287328-8015
Part No SW: 8K0 907 379 CK HW: 8K0 907 379 CK
Component: ESP8 quattro H09 0100
Coding: 291D1A
VCID: 0451700F2E1D1EA7560-8051
Part No SW: 8K0 907 064 GM HW: 8K0 907 064 FM
Component: BCM2 2.0 H12 0633
Coding: 0D814000000000000000
VCID: 015F791B310F0B8F7D6-8055
Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 2313000002535002
02823 - Requirements for Locking the Steering Column Lock not met
Reset counter: 246
Mileage: 99815 km
Date: 2018.04.09
Time: 14:35:32
Part No SW: 8K1 820 043 T HW: 8K1 820 043 T
Revision: C1000000 Serial number: 01280120131475
Coding: 6600228000
VCID: 392FD1FB195F934F756-806D
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Component: BCM1 1.0 H16 0103
Revision: 08016001 Serial number: 00000545862102
Coding: 26000015873CAFE0210140C300003D0D4F9CD308A2090221000008004000030100000030000000
Shop #: WSC 06325 123 12345
VCID: 78A914FF62D54A474A8-802D
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 250113 H07 0080
Serial number: SWF13010250313
Coding: 00FD11
Component: G397_RLFS H06 0002
Serial number: 20912988
Coding: 02005D
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Serial number: 00000000002301130837
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Serial number: 0000002274555R4JWK02
Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: E9D88B86000000000001
Address 15: Airbags (J234) Labels:| 8K0-959-655.clb
Part No SW: 8K0 959 655 P HW: 8K0 959 655 P
Serial number: 003KJD91BNR/
Coding: 303842354730303030304A55304C384B3053
VCID: 4ACD9E374C3908D7ECC-801F
Subsystem 1 - Part No SW: 8K0 959 339 C HW: 8K0 959 339 C
Component: BF-Gewichtss. H02 0040
Serial number: 5810000R120000C0BW
Serial number: 6334MSME77762C5BU
Serial number: 6344MSME7733355AH
Serial number: 6352QSME1F2B1A62P
Serial number: 6362QSME60293B5AO
Serial number: 63732SME45292566
Serial number: 63832SME3D2B1D707
B1007 1B [137] - Resistance Too High
Mileage: 99815 km
Date: 2018.04.09
Time: 14:50:21
9442331 - Passenger's Belt Force Limiter Igniter
B1014 1B [137] - Resistance Too High
Mileage: 99815 km
Date: 2018.04.09
Time: 14:50:21
Part No SW: 8R0 953 568 S HW: 8R0 953 568 S
Component: Lenks.Modul H07 0171
Revision: 00000000 Serial number: 20130128001265
Coding: 000036
VCID: 51FF895BA1EF3B0FAD6-8005
Component: E221 - MFL H03 0004
Part No SW: 8K0 920 982 L HW: 8K0 920 982 L
Component: KOMBIINSTR. H35 0556
Revision: 00300000 Serial number: UVU71FW1E
Coding: 83B709008301D705020001
VCID: 3D27C5EB0D77AF6F59E-8069
Part No SW: 8R0 907 468 N HW: 8R0 907 468 C
Component: GW-BEM 4CAN-M H11 0055
Revision: 1Y060027 Serial number: 2741Y131150556
Coding: 80C303FF00
VCID: 4ACD9E374CB908D7ECC-801F
Serial number: 1708928901
Address 22: AWD (J492) Labels: 8K0-907-163.clb
Part No SW: 8K0 907 163 B HW: 8K0 907 163 A
Component: 4 Wheel Drive H13 0100
Serial number: 001601130001468
ASAM Dataset: EV_AllWheelDiffeQSPCAN 003019
VCID: 2F3BEFA3D79B4DFFDB2-807B
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
Part No SW: 8K0 959 760 D HW: 8K0 959 760 D
Component: MEM-FS H06 0076
Revision: AA000000 Serial number: 00000049226523
Coding: 00581B00000000000000
VCID: 3B23CBF31363A15F67A-806F
Part No SW: 8T0 959 793 P HW: 8T0 959 793 G
Component: TSG FA H09 0304
Coding: 011C13204E00410001
VCID: 56F57A4788015C37784-8003
Address 44: Steering Assist (J500) Labels:| 8K0-909-144.clb
Part No SW: 8K0 909 144 E HW: 8K0 909 144 B
Component: RCEPS H37 0506
Revision: 00001000 Serial number: 0011181134
Coding: 100000010001
Shop #: WSC 06324 000 00000
ASAM Dataset: EV_RCEPSAU48X 006012
ROD: EV_RCEPSAU48X_006.rod
VCID: 3333E3D33BB3691FBFA-8067
Revision: 00002001 Serial number: 0300325200
Coding: 01060E3A00FA40058330013200000000
Shop #: WSC 06324 123 12345
Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000000627662
Subsystem 3 - Part No SW: 8K0 959 591 B HW: 8K0 959 591
Component: J245 PS050 H08 0043
009 - Open or Short to Ground
Fault Status: 01101001
Fault Frequency: 21
Reset counter: 198
Mileage: 90822 km
Date: 2017.07.13
Time: 11:31:05
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813010230602
VCID: 2D07F5ABDD173FEFE9E-8079
Part No SW: 8T0 959 792 P HW: 8T0 959 792 G
Component: TSG BF H09 0304
VCID: 55F77D4B9507572F71E-8001
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 L HW: 8K0 907 801 J
Component: EPB-4 H01 0003
Revision: -------- Serial number: 20000000215192
ROD: EV_ParkiBrake_AU48.rod
6 Faults Found:
131840 - Switch for Electric Parking Brake
C100C 13 [000] - Open Circuit
10613248 - Terminal 15
U1405 00 [008] - Implausible signal
[FC_IGNITION_CROSS_CHECK_FAULT]
Reset counter: 169
Mileage: 99452 km
Date: 2018.03.08
Time: 07:31:01
Voltage terminal 30: 11.9 V
Internal Fault ID: 44
Network management state: Reset
Function light in parking brake button: On
Red operating lamp: On
Red warning lamp: OFF
Green operating lamp: OFF
Yellow warning lamp: On
Terminal 15 status: On
RWU: not active
DSD: not active
HTR: active
ECD: not active
Auto Adjust: not active
Internal Parking Brake state: No enabling
Status of parking brake button: Open circuit
Status ParkingBrake left: Set
Status ParkingBrake right: Set
197120 - Indicator Lamp in Controls
C1014 14 [008] - Open or Short to Ground
Fault Frequency: 59
Reset counter: 169
Voltage terminal 30: 12.0 V
Internal Fault ID: 57
Vehicle speed: 510 km/h
Yellow warning lamp: OFF
Terminal 15 status: OFF
RWU: not active
DSD: not active
HTR: active
ECD: not active
333312 - Function Restricted due to Missing Message(s)
U1111 00 [000] - -
[FC_AIRBAG_02_MESSAGE_TIMEOUT]
329728 - Function Restricted due to Missing Message(s)
U1111 00 [000] - -
[FC_GETRIEBE_03_MESSAGE_TIMEOUT]
329984 - Function Restricted due to Missing Message(s)
U1111 00 [000] - -
[FC_GETRIEBE_04_MESSAGE_TIMEOUT]
Part No SW: 4G0 035 082 E HW: 4G0 035 082
Component: Radio U SIRIU H60 0121
Revision: AB001007 Serial number: 156A.0D7684910
Coding: 020007010000000001
VCID: 221D169794C9F09744C-8077
Part No SW: 8R1 035 746 C HW: 8R1 035 746 B
Component: H-BNT-NA H44 0624
Revision: -------- Serial number: 204AW0D7556436
Coding: 000200020306E3EF4702CF4E00000403140000000000000000
VCID: 372BD7C32F4B853F832-8063
Subsystem 1 - Part No: 8R0 060 884 BA
Component: NAR 2013 0703
Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
Component: DU7 High H42 0104
Serial number: A130AP0D2633782
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Component: E0380 Bedient H02 0030
Serial number: 00000001393350
Component: CD-Database 4949
Part No SW: 8T0 959 795 Q HW: 8T0 959 795 H
Component: TSG HL H07 0304
Coding: 010C13204000210001
VCID: 59EF717BF91F734F556-800D
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
Component: J772__Rearview 0040
Revision: --H07--- Serial number: 525PA8-J2Y91BU
Coding: 1000006
VCID: 3829D4FF2E558A478A8-806D
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-794.clb
Component: TSG HR H07 0304
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 8K0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0005
Serial number: 130109200328
ASAM Dataset: EV_SoundActuaGen2AU64X 002005
ROD: EV_SoundActuaGen2AU64X_002.rod
VCID: 72BD26D70429201774C-8027
End----------(Elapsed Time: 01:59, VBatt start/end: 13.4V/14.1V)-----------
Friday,13,April,2018,15:35:11:24600
62 6C 72 A9
Revision: --X07---
19581 - EVAP Emission Control Sys
P0441 00 [101] - Incorrect Flow
Mileage: 99860 km
Date: 2018.04.13
Time: 14:43:34
Engine speed: 1988.00 /min
Normed load value: 13.3 %
Coolant temperature: 96 ∞C
Intake air temperature: 43 ∞C
Voltage terminal 30: 14.116 V
Engine speed: actual: 1984 /min
MAF_ENVD: 108.94117 mg/stroke
Coolant temperature (unfiltered): 96.00 ∞C
Engine: operating status: IS
Engine load: 13.281250 %
Vehicle speed: actual: 0 km/h
Readiness: 1110 0101
Revision: --H01---
Coding: 000001
Coding: 291D1A
Reset counter: 246
Mileage: 99815 km
Date: 2018.04.09
Time: 14:35:32
Coding: 6600228000
Coding: 00FD11
Coding: 02005D
Mileage: 99815 km
Date: 2018.04.09
Time: 14:50:21
Mileage: 99815 km
Date: 2018.04.09
Time: 14:50:21
Coding: 000036
Coding: 80C303FF00
Fault Frequency: 21
Reset counter: 198
Mileage: 90822 km
Date: 2017.07.13
Time: 11:31:05
6 Faults Found:
Reset counter: 169
Mileage: 99452 km
Date: 2018.03.08
Time: 07:31:01
RWU: not active
DSD: not active
HTR: active
ECD: not active
Fault Frequency: 59
Reset counter: 169
RWU: not active
DSD: not active
HTR: active
ECD: not active
U1111 00 [000] - -
U1111 00 [000] - -
U1111 00 [000] - -
Coding: 1000006
End----------(Elapsed Time: 01:56, VBatt start/end: 13.3V/13.9V)-----------
Saturday,07,April,2018,13:48:25:24600
Readiness Status: 1110 1101
Exhaust Gas Recirculation: Failed or Incomplete
Oxygen Sensor Heating: Failed or Incomplete
Oxygen Sensor(s): Failed or Incomplete
Air Conditioning: Passed
Secondary Air Injection: Failed or Incomplete
Evaporative Emissions: Failed or Incomplete
Catalyst Heating: Passed
Catalytic Converter(s): Failed or Incomplete
Friday,13,April,2018,14:44:46:24600
Address 01: Engine (8K5 907 551 E)
14:44:29
IDE00021 Engine speed 695 /min
IDE00025 Coolant temperature 96 °C
IDE00030 Status of actuator test not active
IDE00450 Operating Instructions End of system test: system not OK
IDE00451 Currently running routine Tank ventilation valve check
IDE00727 Test steps still to be performed 2
Friday 13 April 2018 14:43:56:24600-VCID:3829D4FF22D58A478A8-806D VCDS Version: Release 18.2.0 (x64) Data version: 20180212 DS287.0
8K5 907 551 E ADVMB 3.0l V6 TFSIX07 0002
G002 F0 G003 F0 G004 F0 G022 F0 G023 F0 G053 F0 G000
Marker TIME Loc. IDE00021 TIME Loc. IDE00025 TIME Loc. IDE00030 TIME Loc. IDE00450 TIME Loc. IDE00451 TIME Loc. IDE00727
STAMP Engine speed STAMP Coolant temperature STAMP Status of actuator test STAMP Operating Instructions STAMP Currently running routine STAMP Test steps still to be performed
/min ∞C
0.03 709 0.07 96 0.12 not active 0.17 End of system test: system not OK 0.21 Tank ventilation valve check 0.26 2
0.43 704 0.48 96 0.53 not active 0.57 End of system test: system not OK 0.62 Tank ventilation valve check 0.67 2
0.84 699 0.89 96 0.94 not active 0.98 End of system test: system not OK 1.03 Tank ventilation valve check 1.08 2
1.28 697 1.32 96 1.37 not active 1.42 End of system test: system not OK 1.46 Tank ventilation valve check 1.52 2
1.73 707 1.78 96 1.82 not active 1.87 End of system test: system not OK 1.91 Tank ventilation valve check 1.95 2
2.12 704 2.17 96 2.22 not active 2.26 End of system test: system not OK 2.3 Tank ventilation valve check 2.34 2
2.54 700 2.59 96 2.63 not active 2.66 End of system test: system not OK 2.7 Tank ventilation valve check 2.74 2
2.95 706 2.99 96 3.04 not active 3.09 End of system test: system not OK 3.13 Tank ventilation valve check 3.17 2
3.34 704 3.38 96 3.42 not active 3.46 End of system test: system not OK 3.52 Tank ventilation valve check 3.56 2
3.76 701 3.81 96 3.86 not active 3.91 End of system test: system not OK 3.95 Tank ventilation valve check 3.99 2
4.2 695 4.24 96 4.28 not active 4.32 End of system test: system not OK 4.37 Tank ventilation valve check 4.42 2
4.59 701 4.63 96 4.67 not active 4.72 End of system test: system not OK 4.76 Tank ventilation valve check 4.8 2
4.99 705 5.03 96 5.07 not active 5.12 End of system test: system not OK 5.17 Tank ventilation valve check 5.21 2
5.41 704 5.45 96 5.49 not active 5.55 End of system test: system not OK 5.59 Tank ventilation valve check 5.63 2
5.81 705 5.85 96 5.91 not active 5.95 End of system test: system not OK 5.99 Tank ventilation valve check 6.04 2
6.21 702 6.26 96 6.3 not active 6.34 End of system test: system not OK 6.38 Tank ventilation valve check 6.42 2
6.58 702 6.62 96 6.67 not active 6.71 End of system test: system not OK 6.76 Tank ventilation valve check 6.8 2
7 711 7.04 96 7.08 not active 7.12 End of system test: system not OK 7.17 Tank ventilation valve check 7.22 2
7.42 698 7.46 96 7.51 not active 7.56 End of system test: system not OK 7.6 Tank ventilation valve check 7.66 2
7.83 697 7.87 96 7.92 not active 7.96 End of system test: system not OK 8.01 Tank ventilation valve check 8.06 2
8.26 701 8.31 96 8.36 not active 8.41 End of system test: system not OK 8.45 Tank ventilation valve check 8.49 2
8.7 707 8.74 96 8.79 not active 8.84 End of system test: system not OK 8.88 Tank ventilation valve check 8.91 2
9.11 703 9.15 96 9.2 not active 9.25 End of system test: system not OK 9.29 Tank ventilation valve check 9.34 2
9.54 700 9.58 96 9.62 not active 9.67 End of system test: system not OK 9.71 Tank ventilation valve check 9.76 2
9.93 711 9.98 96 10.02 not active 10.06 End of system test: system not OK 10.11 Tank ventilation valve check 10.15 2
10.35 699 10.41 96 10.44 not active 10.48 End of system test: system not OK 10.53 Tank ventilation valve check 10.57 2
10.74 699 10.78 96 10.82 not active 10.88 End of system test: system not OK 10.92 Tank ventilation valve check 10.97 2
11.17 704 11.21 96 11.26 not active 11.31 End of system test: system not OK 11.36 Tank ventilation valve check 11.4 2
11.61 698 11.65 96 11.7 not active 11.74 End of system test: system not OK 11.79 Tank ventilation valve check 11.84 2
12.04 704 12.09 96 12.14 not active 12.19 End of system test: system not OK 12.23 Tank ventilation valve check 12.28 2
12.48 707 12.53 96 12.57 not active 12.62 End of system test: system not OK 12.66 Tank ventilation valve check 12.7 2
12.88 703 12.92 96 12.96 not active 13.02 End of system test: system not OK 13.06 Tank ventilation valve check 13.11 2
13.31 707 13.36 96 13.41 not active 13.45 End of system test: system not OK 13.49 Tank ventilation valve check 13.52 2
13.73 704 13.78 96 13.83 not active 13.87 End of system test: system not OK 13.92 Tank ventilation valve check 13.96 2
14.17 706 14.21 96 14.27 not active 14.31 End of system test: system not OK 14.35 Tank ventilation valve check 14.4 2
14.61 697 14.66 96 14.7 not active 14.75 End of system test: system not OK 14.79 Tank ventilation valve check 14.84 2
15.04 699 15.09 96 15.14 not active 15.19 End of system test: system not OK 15.23 Tank ventilation valve check 15.28 2
15.48 704 15.53 96 15.58 not active 15.62 End of system test: system not OK 15.67 Tank ventilation valve check 15.72 2
15.92 714 15.96 96 16.02 not active 16.06 End of system test: system not OK 16.1 Tank ventilation valve check 16.16 2
16.36 712 16.41 96 16.46 not active 16.52 End of system test: system not OK 16.55 Tank ventilation valve check 16.59 2
16.79 703 16.83 96 16.87 not active 16.92 End of system test: system not OK 16.97 Tank ventilation valve check 17.01 2
17.19 705 17.23 96 17.28 not active 17.32 End of system test: system not OK 17.37 Tank ventilation valve check 17.41 2
17.6 704 17.63 96 17.66 not active 17.71 End of system test: system not OK 17.76 Tank ventilation valve check 17.8 2
18 704 18.04 96 18.08 not active 18.12 End of system test: system not OK 18.15 Tank ventilation valve check 18.2 2
18.37 704 18.42 96 18.46 not active 18.51 End of system test: system not OK 18.55 Tank ventilation valve check 18.58 2
18.79 707 18.84 96 18.89 not active 18.93 End of system test: system not OK 18.98 Tank ventilation valve check 19.02 2
19.23 700 19.27 96 19.33 not active 19.37 End of system test: system not OK 19.42 Tank ventilation valve check 19.46 2
19.67 704 19.71 96 19.76 not active 19.8 End of system test: system not OK 19.83 Tank ventilation valve check 19.87 2
20.08 703 20.12 96 20.17 not active 20.21 End of system test: system not OK 20.26 Tank ventilation valve check 20.31 2
20.51 710 20.55 96 20.58 not active 20.62 End of system test: system not OK 20.67 Tank ventilation valve check 20.71 2
20.92 703 20.96 96 21.01 not active 21.06 End of system test: system not OK 21.1 Tank ventilation valve check 21.14 2
21.3 713 21.34 96 21.39 not active 21.43 End of system test: system not OK 21.48 Tank ventilation valve check 21.52 2
21.73 699 21.77 96 21.82 not active 21.87 End of system test: system not OK 21.92 Tank ventilation valve check 21.96 2
22.16 708 22.2 96 22.25 not active 22.29 End of system test: system not OK 22.34 Tank ventilation valve check 22.38 2
22.55 709 22.58 96 22.62 not active 22.67 End of system test: system not OK 22.72 Tank ventilation valve check 22.76 2
22.93 703 22.98 96 23.03 not active 23.07 End of system test: system not OK 23.12 Tank ventilation valve check 23.16 2
23.35 701 23.39 96 23.43 not active 23.47 End of system test: system not OK 23.51 Tank ventilation valve check 23.55 2
23.75 706 23.79 96 23.84 not active 23.88 End of system test: system not OK 23.92 Tank ventilation valve check 23.97 2
24.17 702 24.22 96 24.26 not active 24.31 End of system test: system not OK 24.35 Tank ventilation valve check 24.38 2
24.55 698 24.59 96 24.63 not active 24.67 End of system test: system not OK 24.72 Tank ventilation valve check 24.76 2
24.93 703 24.98 96 25.02 not active 25.06 End of system test: system not OK 25.11 Tank ventilation valve check 25.15 2
25.35 699 25.38 96 25.41 not active 25.45 End of system test: system not OK 25.5 Tank ventilation valve check 25.54 2
25.71 706 25.76 96 25.8 not active 25.84 End of system test: system not OK 25.88 Tank ventilation valve check 25.91 2
26.11 706 26.15 96 26.19 not active 26.23 End of system test: system not OK 26.28 Tank ventilation valve check 26.32 2
26.49 699 26.52 96 26.56 not active 26.6 End of system test: system not OK 26.66 Tank ventilation valve check 26.7 2
26.86 699 26.9 96 26.95 not active 26.99 End of system test: system not OK 27.03 Tank ventilation valve check 27.07 2
27.25 702 27.3 96 27.34 not active 27.38 End of system test: system not OK 27.43 Tank ventilation valve check 27.47 2
27.67 701 27.72 96 27.76 not active 27.81 End of system test: system not OK 27.85 Tank ventilation valve check 27.89 2
28.05 704 28.09 96 28.13 not active 28.17 End of system test: system not OK 28.22 Tank ventilation valve check 28.26 2
28.43 697 28.48 96 28.53 not active 28.57 End of system test: system not OK 28.62 Tank ventilation valve check 28.66 2
