Issues entering Long coding
Is my HEX USB+CAN interface now out of date and I need to upgrade to a HEX-NET? I am having a few issues but mainly long coding values that won't go in and adaptations where the message says aborted for safety reasons.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Neither of both is likely going to be resolved by switching to new hardware. You may want to verify the values you are entering and double check (i.e. if the hardware actually supports the options in question), what the safety reasons are etc.
What concerns me and is causing my customers to ask questions is the UDS message in a lot of fault code reads, one nasty piece of work had a go at me over it saying my diagnostic equipment was rubbish amateur stuff and he should not be paying me for the code read...
The aborted for safety reasons and inability to enter long coding were solved using Delphi and ODIS respectively, VCDS failed me in both instances.
PetrolDave
Westbury, UK
C?ID=1423
Might be worth posting examples of those messages: "UDS message", "aborted for safety reasons" as well as details of when/where you couldn't enter long coding - otherwise we can only guess at the problems and solutions.
This is a screen shot of the code I have just read this morning on a Q3, this is after I tried to clear the code but it would not clear and I could not see how to deal with it.
Instruments fault code screen shot for web by Steve Cresswell, on Flickr
This is the code read before I tried to clear the error.
           Windows Based VAG/VAS Emulator Running on Windows 10 x64
       VCDS Version: Release 18.2.0(x64) Data version: 20180212 DS287.0
                      Dealer/Shop Name: C&R Enterprises
                       Workshop Code: 210 01523 000001
                              Self-Diagnosis Log
                     Monday,16,April,2018,10:00:25:58544
               VIN: WAUZZZ8U8ER079071   License Plate:
     Mileage: 59970km-37263mi   Repair Order: Haldex oil change pre scan
    Chassis Type: 8U-AU21 (8U0)
    Scan: 01 03 08 09 10 15 16 17 19 22 25 42 44 46 52 53 55 5F 62 72
    VIN: WAUZZZ8U8ER079071   Mileage: 59970km-37263miles
       Part No SW: 03L 906 018 CM    HW: 03L 906 018 ES
       Component: R4 2.0l TDI   H28 9977
       Revision: 41H28---    Serial number:
       Coding: 00190012041701080000
       Shop #: WSC 28722 001 1048576
       ASAM Dataset: EV_ECM20TDI01103L906018CM 003005
       ROD: EV_ECM20TDI01103L906018CM.rod
       VCID: 77FBB791CE29F4FC29-8022
    Address 03: ABS Brakes        Labels: 5N0-614-109-C6.clb
       Part No SW: 5N0 614 109 BL    HW: 5N0 614 109 BL
       Component: J104   C6 450M V45C 0151
       Revision: --H07---    Serial number: 00000007886774
       Coding: 0052359
       Shop #: WSC 00049 770 00153
       VCID: 76E5BA9501238DF432-8022
       Part No SW: 8U0 820 043 D    HW: 8U0 820 043 D
       Component: E87  Klimavoll      0100
       Revision: 00H04000    Serial number: 8U0820043D
       VCID: 326D4685ADCBD1D4DE-8066
    Address 09: Cent. Elect. (J519)       Labels:. 8X0-907-063.clb
       Part No SW: 8X0 907 063 N    HW: 8X0 907 063 N
       Component: BCM PQ35  M   112 0775
       Revision: AH112775
       Coding: 0E000A2CA805F1C0201841C00100094C43FF84AA206F912BE400878400C1
       Shop #: WSC 00049 770 00009
       VCID: 479B0751F649447C99-8012
       Subsystem 1 - Part No SW: 8U2 955 119     HW: 8U2 955 119   Labels: 1KX-955-
       Component: WWS316 140201  H37 0085
       Serial number:         140204223415
       Coding: 0047F7
       Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B  Labels: 8U0-95
       Serial number: 22248726
       Coding: 02006E
       Subsystem 3 - Part No: 8X0 951 177
       Component: DWA-Sensor H0  H01 0020
    Address 10: Park/Steer Assist (J446)       Labels:| 8X0-919-475.clb
       Part No SW: 8X0 919 475 Q    HW: 8X0 919 475
       Component: PARKHILFE 4K  H03 0070
       Revision: 11001001    Serial number: 37031402201029
       Coding: 0C0005
       Shop #: WSC 00049 770 00118
       ASAM Dataset: EV_EPHVA14AU21X0000 003006
       ROD: EV_EPHVA14AU21X0000_003.rod
       VCID: 54A1201D3F1FFFE4EC-8000
    Address 15: Airbags (J234)       Labels:| 8X0-959-655.clb
       Part No SW: 8U0 959 655 B    HW: 8U0 959 655 B
       Component: AirbagVW-AU10 H08 0520
       Serial number: 003LRR07K0V7
       Coding: 30393132313030303030554A305238553053
       ASAM Dataset: EV_AirbaAU10SMEAU316 001005
       ROD: EV_AirbaAU10SMEAU316_001.rod
       VCID: 46850A55F9435D7462-8012
       Subsystem 1 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
       Serial number: 3496KSME75501F2CZZZ0
       Subsystem 2 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
       Serial number: 3506KSME7600632BZZZN
       Serial number: 3516KSME5E12212CZZZS
       Serial number: 3526KSME232C6B2BZZZ$
       Subsystem 5 - Part No SW: 8U0 959 651     HW: 8U0 959 651
       Serial number: 3555USME3B59262BZZZ8
    Address 16: Steering wheel (J527)       Labels:| 8X0-953-569.clb
       Part No SW: 8X0 953 521 B    HW: 5K0 953 569 AE
       Revision: FF010018    Serial number: 20140221100696
       Coding: 1084004000
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 3B736BA1B281109C0D-806E
       Subsystem 1 - Part No SW: 8U0 951 528 G    HW: 8U0 951 528 G
    Address 17: Instruments (J285)       Labels:| 8X0-920-xxx-17.clb-SRI1
       Part No SW: 8U0 920 980 E    HW: 8U0 920 980 E
       Component: KOMBI_MEDIUM  H01 0330
       Coding: 42CF00
       ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04399
       VCID: 3E7562B5A19305B42A-806A
    1048578 - No Basic Setting
              B2010 00 [009] -  -
              [New feature! Extended UDS fault detail is only supported by current
                    Reset counter: 84
                    Mileage: 59415 km
                    Date: 2018.03.23
                    Time: 14:24:25
    Address 19: CAN Gateway (J533)       Labels: 8X0-907-468.clb
       Part No SW: 8U0 907 468 Q    HW: 8U0 907 468 G
       Component: GAT 4CAN 1L M H13 0063
       Revision: 1P120037    Serial number: 3741P1420905AB
       Coding: FBCF1A5A000100610353
       VCID: 50A92C0D030783C4C8-8004
       Component: J367-BDM  H07 0180
       Serial number: 41056508331491813244
       Serial number: 14056003533021200181
       Part No SW: 0AY 907 554 F    HW: 0AY 907 554 F
       Component: Haldex4Motion H52 7521
       Serial number: HA1-00012.02.14
       Coding: 0001
       VCID: 4E95327511339534DA-801A
       Component: IMMO          H01 0330
       Coding: 000002
       ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04113
       ROD: EV_Immo_UDS_VDD_AU10.rod
    Address 42: Door Elect, Driver (J386)       Labels:. 8X0-959-793.clb
       Part No SW: 8X0 959 793 H    HW: 8X0 959 793 H
       Component: TSG FA        H10 0415
       Coding: 011806200001000000
       VCID: 52AD26050D0BF1D4FE-8006
       Part No: 5N0 909 144 R
       Component: EPS_ZFLS Kl. 296    3501
       Revision: 00H22000
       VCID: 40891C4D1367734458-8014
    Address 52: Door Elect, Pass. (J387)       Labels:. 8X0-959-792.clb
       Part No SW: 8X0 959 792 H    HW: 8X0 959 792 H
       Component: TSG BF        H10 0415
       VCID: 51AF2909080D8ACCC7-8004
       Revision:   H19       Serial number: 00000001928261
       Coding: 0025167
       VCID: 36657A9541A3CDF4F2-8062
       Serial number: 140217-0002-195
       Coding: 1157A41010002500
       ROD: EV_HeadlRegulBasic.rod
       VCID: 428D1645D56B61544E-8016
       Part No SW: 8U0 035 192 E    HW: 8U0 035 192 C
       Component: RMC Nav Plus  H55 0801
       Coding: 01010600020153070823020103010000000000
       VCID: 36657A9581A3CDF4F2-8062
       Subsystem 1 - Part No: 8X0 919 884 J
       Component: P32-50-15.03  0001
       Subsystem 2 - Part No SW: 8U0 919 603 A    HW: 8U0 919 603 A
       Component: DUBasic AU316  H42 0018
       Serial number: AUZ8ZDEM500MSKR
       Part No SW: 8X0 959 795 C    HW: 8X0 959 795 C
       Component: TSG HL        H07 0415
       Coding: 010006200001000000
       VCID: 4FAB2F711E399C3CD1-801A
       Component: TSG HR        H07 0415
End----------------------------------------------------------------------
Right, the "New feature! Extended UDS fault detail" is only available with our current generation of interfaces.
FWIW, the dealers' ODIS software doesn't provide this info at all.
PetrolDave
Westbury, UK
C?ID=1423
It's telling you what the fault is:
              B2010 00 [009] -  -
                    Reset counter: 84
                    Mileage: 59415 km
                    Date: 2018.03.23
                    Time: 14:24:25
You won't be able to just clear the fault code, you need to RTFB to learn how to set the "Basic Setting" on this module.
NEtech
C?ID=56995
And normally in this case, it means there are wrong values in Adaptation channels in the Instrument.
It would be interesting to see what "New feature" text is this case.
PetrolDave
Westbury, UK
C?ID=1423
An Adaptation Channel map could be helpful too?
There is no information provided in the VCDS Basic Settings on this and there is no book on the Q3 plus there is no facility for direct entry to try any of the usual ones.
VAG's fault code text is misleading here. This fault isn't fixed by carrying out a Basic Setting. It's fixed by tweaking Adaptation Channels (usually the SRI-related ones) to values that make the cluster happy.
Keithuk
Stoke on Trent, England
C?ID=122432
There are a lot of pages on Ross-Tech Wiki that show nothing.
It was only in for a Haldex oil change and I just noticed it had the UDS message I mentioned but the discs and pads are in a poor state and she will be back in the not too distant future. When I went onto erWin Audi to enter the Haldex oil change in the Digital Service Schedule, I could see my local Audi main dealer serviced it a month ago.
PetrolDave
Westbury, UK
C?ID=1423
Does that suggest that the Audi main dealer made a mess of the SRI-related settings when they serviced it?
From what Uwe said it would seem so and when I checked the DSS data there was a milage discrepaency, i.e. if it was servived last week it had done a few hundred miles the year before and 10000 in following month. The customer had gone by then so I will try and ask her in the next few days.
I did a code read on an A4 this morning and got this result at address 46 on the installation list
Monday,23,April,2018,09:23:23:58544
VCDS Version: 18.2.0.3 (x64)
VIN: WAUZZZF46HA049220   License Plate: FL66WBN
Mileage: 23107km-14358mi   Repair Order: Air bag light on
Chassis Type  F4-AU49 (4M1)
Scan: 01 03 08 09 15 16 17 19 2B 42 44 46 52 5F 6D A5 BB BC
VIN: WAUZZZF46HA049220   Mileage: 23107km-14358miles
46-Central Conv. -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-CVNA)       Labels: None
   Part No SW: 04E 906 022 B    HW: 04E 907 309 R
   Component: R4 1.4l TFS   H22 3206
   Revision: 44H22000
   Coding: 021900324324150834080000000000000000000000000000
   Shop #: WSC 06314 790 00001
   ASAM Dataset: EV_ECM14TFS01104E906022B 002001
   ROD: EV_ECM14TFS011_AU49.rod
   VCID: 1E358235015365B40A-804A
5581 - Oil Pressure Switch
          P164A 00 [096] - Implausible Signal
Address 03: ABS Brakes (J104)       Labels:. 8W0-907-379-PLU-V1.clb
   Part No SW: 8W0 907 379 E    HW: 8W0 907 379 J
   Component: ESP9 Plus     H06 0593
   Coding: 04AA049908A60A9F15A04093007D5292F6C19620201050A802004A496F8369
   Shop #: WSC 06324 790 00001
   ASAM Dataset: EV_ESP9BOSCHAU49X 012014
   ROD: EV_ESP9BOSCHAU49X_012.rod
   VCID: 479B0751FE49447C99-8012
12615680 - FlexRay Databus Defective
          U0080 00 [096] - -
200448 - Databus
   Part No SW: 8W0 820 043 F    HW: 8W0 820 043 F
   Component: Klima Zone 3  H32 0071
   Coding: 240800095544040D02000100880000000000000000000000000000000000
   Shop #: WSC 06325 790 00001
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 36657A9589A3CDF4F2-8062
   Subsystem 1 - Part No SW: 4M2 820 021     HW: 4M2 820 021
   Component: J216 FLuftV  H05 0001
   Serial number: 00000000000000961272
   Component: AQ_Hum_Sensor  H01 0005
   Serial number: 38F88D3800PAG0MUFU02
   Subsystem 3 - Part No SW: 8W0 919 158     HW: 8W0 919 158
   Component: Klima Heck  H40 0073
   Part No SW: 8W0 907 063 BC    HW: 8W0 907 063 BC
   Component: BCM1 MLBevo   H13 0248
   Coding: 80453142451800CD010487145B0E00B9110B3108000000000000000020001A2000410022025601
   ASAM Dataset: EV_BCM1BOSCHAU736 016006
   ROD: EV_BCM1BOSCHAU736_016.rod
   VCID: 7DF7A5B9EC15DEAC73-8028
   Subsystem 1 - Part No SW: 8W2 955 119     HW: 8V2 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS491 160613  043 0813
   Serial number: 894253?0401616501349
   Coding: 5BC7F7
   Subsystem 2 - Part No SW: 81A 955 555     HW: 81A 955 555
   Component: G397_RLFSS  H06 0001
   Serial number: 20088642X81A95555500
   Coding: 02005D
   Light switch:
   Subsystem 3 - Part No SW: 4M0 941 531 AA    HW: 4M0 941 531 AA
   Component: E1 - LDS  H06 0008
   Serial number: 19 05 2016  00361787
   Subsystem 4 - Part No SW: 8W0 857 511     HW: 8W0 857 511
   Serial number: GX1CE126051612010497
   Coding: 210000
   Interior Light Module:
   Subsystem 5 - Part No SW: 8W0 947 135 D    HW: 8W0 947 135
   Component: J528-Dachele  H14 0130
   Serial number: B10205809
   Subsystem 6 - Part No SW: 8W0 925 301 BC    HW: 8W0 925 301 BC
   Component: SL-B9/Q5NF  H16 0010
   Serial number: 2616000080767007
Address 15: Airbags (J234)       Labels:| 8W0-959-655.clb
   Part No SW: 8W0 959 655     HW: 8W0 959 655
   Component: Airbag10.44   H72 0086
   Serial number: 003M6005NDPB
   Coding: AACCF0C00C800000585400F3C08C00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 005012
   ROD: EV_AirbaAU10BPAAU736_005_AU49.rod
   VCID: 0605CA55B9C39D7422-8052
   Subsystem 1 - Part No SW: -----------    HW: 442 060 707 16
   Serial number: 3577Y00AB1FACC31D52M
   Subsystem 2 - Part No SW: -----------    HW: 442 060 607 16
   Serial number: 3587Y009B1FACC30720A
   Subsystem 3 - Part No SW: -----------    HW: 442 0B1 307 16
   Serial number: 3517700BB20F7C3561FP
   Subsystem 4 - Part No SW: -----------    HW: 442 0B1 307 16
   Serial number: 3527700BB20F7C341206
   Subsystem 5 - Part No SW: -----------    HW: 442 0C2 306 16
   Serial number: 3557500A120BEED632FU
   Front Sensor Passenger:
   Subsystem 6 - Part No SW: -----------    HW: 442 0C2 306 16
   Component: FrontSensor_P  1C5 014A
   Serial number: 35675009F20BEED4A0B0
   Pedestrian Protection Center:
   Subsystem 7 - Part No SW: -----------    HW: 442 0C2 306 16
   Component: PedP_Sensor_C  1C5 014A
   Serial number: 23075009F20BEED0628P
9735428 - Pedestrian Protection Crash Sensor 2; Driver Side
          B148D 04 [136] - Internal System Fault
                    Mileage: 22855 km
                    Date: 2018.04.17
                    Time: 14:44:40
9735684 - Pedestrian Protection Crash Sensor 2; Passenger Side
          B148E 04 [136] - Internal System Fault
                    Mileage: 22855 km
                    Date: 2018.04.17
                    Time: 14:44:40
   Part No SW: 4M0 907 129 HD    HW: 4M0 907 129 HD
   Component: Lenks.Modul   H11 0009
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 79FFB1A9F83DE28C5F-802C
   Part No SW: 8W5 920 940 A    HW: 8W5 920 940 A
   Component: MMA4M17BENUK  H06 0339
   Revision: 0339v7      Serial number:    PY5FN8E7S
   Coding: 24A4689028800600010069601000000000000000
   ASAM Dataset: EV_DashBoardAU736 001022
   VCID: 3D7765B9AC951EAC33-8068
16777018 - Control unit for information electronics 1
          U1054 00 [008] - No Communication
                    Reset counter: 107
                    Mileage: 1056 km
                    Date: 2016.10.02
                    Time: 11:02:52
16777020 - Control unit for information electronics 1
                    Reset counter: 92
                    Mileage: 899 km
                    Date: 2016.09.28
                    Time: 14:47:01
16777030 - Control unit for information electronics 1
                    Reset counter: 103
                    Mileage: 939 km
                    Date: 2016.09.30
                    Time: 12:51:57
   Part No SW: 4M1 907 468 C    HW: 4M1 907 468 A
   Component: Gateway       H15 0098
   Revision: 4R040002    Serial number: 0244R037E16729
   Coding: 0301000100008E40260700000059001248080007000000000100000000000000
   ASAM Dataset: EV_GatewCONTIAU736 002060
   ROD: EV_GatewCONTIAU736_002_AU49.rod
   VCID: 377B77918EA934FCE9-8062
   Subsystem 1 - Part No SW: 8W0 951 523 C    HW: 8W0 951 523 C
   Component: J453 MFL  H02 0002
   Serial number: 20160716040636 00595
   Serial number: 9163050904
16646145 - predictive route data
          B1630 02 [009] - Signal Failure
                    Fault Frequency: 243
                    Reset counter: 0
                    Mileage: 5 km
                    Date: 2016.09.07
                    Time: 09:17:07
   Part No SW: 3Q0 905 861 A    HW: 3Q0 905 861 A
   Component: ELV-MLBevo    H05 0032
   Serial number: 16000157784001
   Coding: 0000000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 326D468565CBD1D4DE-8066
   Part No SW: 8W0 959 593 G    HW: 8W0 959 593
   Component: TSG FS        005 0052
   Serial number: 0000210167236
   Coding: 001F8A204001000000001082
   ROD: EV_DCU2DriveSideMAXHCONT.rod
   Part No SW: 8W0 909 144 F    HW: 8W0 909 144 B
   Component: EPS_MLBEVO_ZF H08 0407
   Coding: 09000380008000
   ASAM Dataset: EV_EPSZFAU49X 002015
   ROD: EV_EPSZFAU49X_002.rod
   VCID: 40891C4DDB67734458-8014
Address 46: Central Conv.
Interface not compatible.
   Part No SW: 8W0 959 592 G    HW: 8W0 959 592
   Component: TSG BFS       005 0052
   Serial number: 0000210187239
   Coding: 001F8A204001000000001080
   ROD: EV_DCU2PasseSideMAXHCONT.rod
   VCID: 4D9735791C35AE2CA3-8018
Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGS2.clb
   Part No SW: 8W0 035 192 A    HW: 8W0 035 192 A
   Component: MU-HS-LND-EU  045 0148
   Coding: 01940201FF0A000013111101000A00102F0001C601F00100CE
   ASAM Dataset: EV_MUHigScl6C3DELP 001011
   ROD: EV_MUHigScl6C3DELP_AU49.rod
   VCID: 3461409D9FDFDFE4CC-8060
   Subsystem 1 - Part No SW: V03 959 801 PC    HW: -----------
   Component: ECE 2016/2017  --- 0020
   Subsystem 2 - Part No SW: 8W2 919 604     HW: 8W2 919 604
   Component: AU49x_DU_STD  H40 0008
   Serial number: AUZ8Z9GBH00DCN
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8W0 919 614 J    HW: 8W0 919 614 J
   Component: ControlUnit_B  H21 0134
   Serial number: APVAK105071600040130
   Part No SW: 4M0 959 107 B    HW: 4M0 959 107 A
   Component: HDSG-Modul    H13 0161
   Revision: --------    Serial number: 30823891400000
   Coding: 0550
   ROD: EV_DeckLidCONTIAU736_AU49.rod
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* None
   Part No SW: 8W0 907 217 B    HW: 8W0 907 217
   Component: BVS           H14 0042
   Coding: 0404090200000401024023A0A40000FC00F0C010C000
   ROD: EV_BVSMLBevKOSTAAU736.rod
1123714 - Databus
                    Reset counter: 37
                    Mileage: 22855 km
                    Date: 2018.04.17
                    Time: 14:44:44
                    Control Module temperature: 33 °C
                    Voltage terminal 15: 13.20 V
1123591 - predictive route data
                    Fault Frequency: 191
                    Reset counter: 0
                    Mileage: 5 km
                    Date: 2016.09.07
                    Time: 09:17:08
                    Control Module temperature: 31 °C
                    Voltage terminal 15: 12.50 V
1123600 - predictive route data
          B1630 02 [008] - Signal Failure
                    Fault Frequency: 9
                    Reset counter: 101
                    Mileage: 21986 km
                    Date: 2018.03.19
                    Time: 22:35:17
                    Control Module temperature: 11 °C
                    Voltage terminal 15: 14.90 V
1123601 - predictive route data
                    Reset counter: 88
                    Mileage: 23001 km
                    Date: 2018.04.19
                    Time: 20:38:33
                    Voltage terminal 15: 12.60 V
   Part No SW: 8W0 959 595 G    HW: 8W0 959 595
   Component: TSG HFS       005 0052
   Serial number: 0000210205748
   Coding: 000F88200001000000001080
   ROD: EV_DCU2RearDriveMAXHCONT.rod
   VCID: 50A92C0D0B0783C4C8-8004
   Component: TSG HBFS      005 0052
   Serial number: 0000210205746
   ROD: EV_DCU2RearPasseMAXHCONT.rod
End-------------------------(Elapsed Time: 05:05)--------------------------
I had to edit out the interface bit and thankfully his issue was air bags not central convenience, what is the solution to this, a new interface or an update?
Santos
New interface. The HEX+CAN never fully supported the B9 A4. Our HEX+CAN pages had the notice for a year or more
"2016+ Audi A4 B9 (Rest-of-World) chassis 8W (2017+ North American Region chassis F4)."
