Monday,09,April,2018,18:17:10:39527
VCDS Version: 18.2.0.3 (x64) HEX-NET CB: 0.4411.4
VIN: WUAC6AFR5EA901 License Plate:
Chassis Type: FR-AU48 (8R0)
Scan: 01 02 03 05 06 08 09 15 16 17 19 22 36 3C 42 44 46 47 52 53
56 5F 6C
VIN: WUAC6AFR5EA901828 Mileage: 13990km-8692miles
Address 01: Engine (------CFSA) Labels:. 079-907-560-CFS.clb
Part No SW: 8T2 907 560 F HW: 8T1 907 560
Component: 4.2l V8HDZ / H04 0003
Revision: NAH04---
Coding: 1A25003225A6080D3000
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_ECM42FSI0118T2907560F 001002
ROD: EV_ECM42FSI0118T2907560F.rod
VCID: 3FCE8F79A6E7DBBC21-806A
8634 - Camshaft Position Sensor (G301)
P0392 00 [167] - Signal too Low
Mileage: 13994 km
Date: 2018.04.09
Time: 20:14:45
Engine speed: 301.50 /min
Normed load value: 73.3 %
Coolant temperature: 33 °C
Intake air temperature: 34 °C
Voltage terminal 30: 9.847 V
CAN status - engine control module-Bits 0-7: 64
CAN status - transmission control module-Bits 0-7: 64
CAN status - brake control module 1-Bits 0-7: 64
CAN status - brake control module 2-Bits 0-7: 64
selected gear-Bits 0-7: 0
Cruise control switch actuation-Bits 0-7: 0
Readiness: 1110 1101
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 8T0 927 156 H HW: 0B5 927 156 K
Component: 0B5 42 FSINAR H02 0003
Revision: --H02---
Coding: 000001
ROD: EV_TCMDL501021.rod
VCID: 42C8868DD515B6544E-8016
Part No SW: 8T0 907 379 F HW: 8T0 907 379 F
Component: ESP8 quattro H09 0100
Coding: 2C1D1A
VCID: 45C29D91CC3B816C6B-8010
Part No SW: 8K0 907 064 JM HW: 8K0 907 064 JM
Component: BCM2 2.0 H14 0650
Coding: 0D804040000000000000
VCID: 04444095878178643C-8050
Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 0214000007611006
Address 06: Seat Mem. Pass (J521) Labels:. 8T0-959-760.clb
Part No SW: 8T0 959 760 E HW: 8T0 959 760 E
Component: MEM-BFS H10 0077
Revision: AA000000 Serial number: 00000089867497
Coding: 00037025002C00000000
Part No SW: 8K1 820 043 T HW: 8K1 820 043 T
Revision: C1000000 Serial number: 01100220140370
Coding: 4802200000
VCID: 393AE161B0C3F58C1F-806C
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 27
Mileage: 13994 km
Date: 2018.04.09
Time: 20:10:55
Temperature: 32.0°C
Temperature: 33.0°C
Absolute Pres.: 1.2 bar
Current: 0.000 A
Temperature: 36.0°C
Part No SW: 8K0 907 063 DJ HW: 8K0 907 063 DJ
Component: BCM1 1.0 H16 0103
Revision: 09016001 Serial number: 00000058993101
Coding: 06000091043C9FE0250048C3000039090F9CD388A2090221000008004000010200040034000000
VCID: 7AB83E6DF5453E9456-802E
Subsystem 1 - Part No SW: 8T1 955 119 D HW: 8J1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 070214 H15 0080
Serial number: SWF14020075298
Coding: 00FD11
Component: G397_RLFS H06 0002
Serial number: 22221293
Coding: 02005D
Subsystem 3 - Part No SW: 8K0 941 531 AQ HW: 8K0 941 531 AQ
Component: E1 - LDS H03 0031
Serial number: 00000000002001140470
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Serial number: 0000002274555R9LA803
Subsystem 5 - Part No SW: 8K5 941 329 HW: 8K5 941 329
H01 0031
Subsystem 6 - Part No SW: 8K5 941 329 HW: 8K5 941 329
H01 0031
Subsystem 7 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: AA09CD07000000000001
Address 15: Airbags (J234) Labels:| 8K0-959-655.clb
Part No SW: 8K0 959 655 P HW: 8K0 959 655 P
Component: AirbagVW-AU10 H47 0610
Serial number: 003KJDB12CKF
Coding: 303343334830303030304A55304C38543053
VCID: 4AD8AEADED256E1486-801E
Subsystem 1 - Part No SW: 8K0 959 339 A HW: 8K0 959 339 A
Component: BF-Gewichtss. H02 0060
Serial number: 5810000R140000HWUA
Serial number: 6334MSME417E3649L
Serial number: 6344MSME417D5312A
Serial number: 6352QSME443A2E5EX
Serial number: 6362QSME4C3A2644N
Serial number: 63732SME1F3C237A9
Serial number: 63832SME133D0C4E7
Part No SW: 8K0 953 568 M HW: 8K0 953 568 M
Component: Lenks.Modul H04 0005
Revision: -------- Serial number: 90372NB4000VL
Coding: 000036
VCID: 44C48095C701B8647C-8010
Component: E221 - MFL H03 0004
Part No SW: 8T0 920 984 H HW: 8T0 920 984 H
Component: KOMBIINSTR. H35 0564
Revision: 00000000 Serial number: Z9X29PX1F
Coding: 8BBF01008B03D705020000
Part No SW: 8R0 907 468 P HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0060
Revision: 1Z120030 Serial number: 3041Z1412705D9
Coding: 80E3031600
VCID: 4CD4A8B5EF517024B4-8018
Serial number: 8983742403
Reset counter: 27
Mileage: 13994 km
Date: 2018.04.09
Time: 20:14:50
Bin. Bits: 10011
Voltage: 11.30 V
Count: 6
Address 22: AWD (J492) Labels: 8K0-907-163.clb
Part No SW: 8K0 907 163 B HW: 8K0 907 163 A
Component: 4 Wheel Drive H14 0100
Serial number: 002501140001599
ASAM Dataset: EV_AllWheelDiffeQSPCAN 003019
VCID: 2F2EDF3976872B3CB1-807A
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
Component: MEM-FS H10 0077
Revision: AA000000 Serial number: 00000089930988
Coding: 001B7B25002C00000000
Address 3C: Lane Change (J769) Labels:| 5Q0-907-566.clb
Part No SW: 8T0 907 566 B HW: 8T0 907 566 B
Component: SWA Master H05 0071
Serial number: 0324206826
Coding: 010211
Shop #: WSC 06324 000 00000
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 8T0 907 568 B HW: 8T0 907 568 B
Component: SWA Slave H05 0071
Serial number: 0324161859
Coding: 010211
Part No SW: 8T0 959 793 P HW: 8T0 959 793 G
Component: TSG FA H09 0305
Coding: 011C13224E00120102
VCID: 56E04ADD219D3AF412-8002
Address 44: Steering Assist (J500) Labels:| 8K0-909-144.clb
Part No SW: 8K0 909 144 G HW: 8K0 909 144 B
Component: RCEPS H40 0508
Revision: 00001000 Serial number: 0025248314
Coding: 100000010001
ASAM Dataset: EV_RCEPSAU48X 008015
ROD: EV_RCEPSAU48X_008.rod
VCID: 3522ED5194DB11ECFB-8060
Revision: 00002001 Serial number: 0326763341
Coding: 0106029A00FAC00580B0003200000000
Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000000792288
Subsystem 3 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H05 0220
Subsystem 4 - Part No SW: 4G8 959 252 HW: 4G8 959 252
Component: HSP-SG H11 0029
Serial number: WA107531000006098953
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813025485504
VCID: 2D12C531748B592C83-8078
Part No SW: 8T0 959 792 P HW: 8T0 959 792 G
Component: TSG BF H09 0305
VCID: 55E24DD13C9B31EC1B-8000
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 N HW: 8K0 907 801 J
Component: EPB-4 H01 0005
Revision: -------- Serial number: 30000000166863
ROD: EV_ParkiBrake_AU48.rod
VCID: 3A38FE6DBDC5FE9416-806E
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Component: Radio U SIRIU H60 0133
Revision: AB001007 Serial number: 156B70E7964578
Coding: 020007010000000001
VCID: 24042015274198645C-8070
Part No SW: 8R1 035 746 E HW: 8R1 035 746 D
Component: H-BNT-NA H41 0756
Revision: -------- Serial number: 204BU0E7639331
Coding: 150200020306A1EF55028B5E00000403140000000000000000
Subsystem 1 - Part No: 8R0 060 884 BL
Component: NAR 2014 0902
Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
Component: DU7 High H42 0104
Serial number: A130A 0E2936698
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Component: E0380 Bedient H02 0030
Serial number: 00000001748213
Component: CD-Database 5571
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
Component: J772__Rearview 0040
Revision: --H09--- Serial number: 525PA8-J3Y92HB
Coding: 1020008
VCID: 383CE4654BC9EC84E0-806C
End----(Elapsed Time: 01:49, VBatt start/end: 11.4V/11.3V. VIgn 11.4V)-----
