- Joined
- Aug 10, 2016
- Messages
- 3,768
- Reaction score
- 4,182
- Location
- Netherlands, eastern part
- VCDS Serial number
- C?ID=284912
a good VW friend is a mechanic at a dealership and is slowly discovering the power of VCDS.
it's quite entertaining at times, in a very positive and supportive way, and genuinely good to see him working with the programme.
the dealership has an original hex+can interface and he sent me a few scans.
i believe he noticed the car having CC via MFSW, but in the 16 steering wheel control module, byte 0 bit 4-6 are set to 0.
I noticed a few of these things as well on an earlier Polo 6C. maybe it's because of the CC via stalk vs CC via MFSW?
Wednesday,21,March,2018,13:01:02:49337
VCDS Version: 18.2.0.3 (x64)
VIN: VSSZZZ5FZER053682 License Plate:
Mileage: 68780km-42737mi Repair Order:
Chassis Type: 5F-SE37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F 69
VIN: VSSZZZ5FZER053682 Mileage: 68780km-42737miles
Address 01: Engine (J623-CRKB) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 FD HW: 04L 907 309 E
Component: R4 1,6L EDC H22 6544
Revision: 86H22---
Coding: 01190012033401090000
Shop #: WSC 17833 000 1048576
ASAM Dataset: EV_ECM16TDI01104L906021FD 002004
ROD: EV_ECM16TDI01104L906021FD.rod
VCID: 6CD724C4874B4E24D4-8038
4865 - No Communication with Towing System Control Module (J345)
U1003 00 [032] - -
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 907 379 R HW: 5Q0 907 379 F
Component: EMB8 EHCB H31 0356
Revision: 00000000 Serial number: 62883000000502
Coding: 20EE62922425096F007D060841C5240446249000608224F200410070C002
Shop #: WSC 00049 770 00107
VCID: 4B958758E205A91CBD-801E
Part No SW: 5F0 907 044 E HW: 5F0 907 044 E
Component: Climatronic H03 0705
Revision: 00001K07
Coding: 00000104200100011005000000101000
ROD: EV_ACClimaBHBVW37X_003_SK37.rod
VCID: 285F18D45333A20470-807C
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AE HW: 5Q0 937 084 AE
Component: BCM MQBAB H H16 0124
Serial number: 00011329400720
Coding: 08020A46424102FB4BE44080401407081000000000000000000000000000
ROD: EV_BCMBOSCH_012.rod
VCID: 7BF51798F225D99C4D-802E
Subsystem 1 - Part No SW: 5F1 955 119 HW: 5F1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 130930 041 0574
Serial number: 131001214411
Coding: 0BC5FD
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 042 0105
Serial number: S4Y16M09D19H10M51S44
Coding: 008F77
11274 - Bulb for Center Brake Light
B12C6 15 [008] - Open or Short to Plus
Reset counter: 116
Mileage: 1048574 km
Time: 00:00:00
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 C HW: 5Q0 919 294 A
Component: PARKHILFE 8K H02 0033
Revision: -------- Serial number: 94231330201943
Coding: 0031051101
ASAM Dataset: EV_EPHVA18AU3700000 002019
ROD: EV_EPHVA18AU3700000_002_AU37.rod
VCID: 3B75D798B2A5199C0D-806E
Part No SW: 3Q0 959 655 AC HW: 3Q0 959 655 AC
Component: Airbag VW20 012 0189
Revision: -------- Serial number: 003P4PNPQRL7
Coding: 98CCC000000000005C0000CC000800000065
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 7F0DE388E63DC5BC61-802A
Subsystem 1 - Part No SW: ----------- HW: 454 001 310 13
Serial number: 3576U000000959443E0D
Subsystem 2 - Part No SW: ----------- HW: 454 001 310 13
Serial number: 3586U000000A29443E0C
Subsystem 3 - Part No SW: ----------- HW: 454 802 310 13
Component: SideSensor_Dr 111 0148
Serial number: 3516R24313A02000000O
Subsystem 4 - Part No SW: ----------- HW: 454 802 410 13
Component: SideSensor_Pr 111 0148
Serial number: 3526RB7813B020000000
Subsystem 5 - Part No SW: ----------- HW: 454 801 410 13
Component: FrontSensor_D 114 0149
Serial number: 3556VD5D104020000002
Part No SW: 5Q0 953 507 AC HW: 5Q0 953 549
Component: Lenks. Modul 007 0070
Revision: -------- Serial number: 31101308491505
Coding: 1400
ROD: EV_SMLSKLOMQB_013_AU37.rod
VCID: 77FD0BA8CE0DFDFC29-8022
Part No SW: 5F0 920 871 A HW: 5F0 920 871 A
Component: KOMBI 303 2210
Coding: 07A402002980000800086A00000000
ROD: EV_DashBoardVDDMQBAB_008_VW26.rod
VCID: 275D1BE85E2DAD7C79-8072
Part No SW: 5Q0 907 530 Q HW: 5Q0 907 530 F
Component: GW MQB High 125 1164
Revision: -------- Serial number: 0001219784
Coding: 030100F40B087600EF000648080F00010001000000000000000000000000
ROD: EV_GatewLear_010_SE37.rod
VCID: 3F8DA388A6BD05BC21-806A
Subsystem 2 - Part No SW: 5F0 959 537 B HW: 5F0 959 537 B
Component: E221__MFL-PR6 H03 0120
Serial number: 000000000A0084140314
Coding: 002000
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 3938821503
131655 - No Communication with Towing System Control Module (J345)
U1003 00 [008] - -
Reset counter: 106
Mileage: 68100 km
Date: 2018.02.03
Time: 11:58:29
Supply voltage: Terminal 30: 12.5 V
Terminal 15: OFF
Part No SW: 5Q4 959 593 B HW: 5Q4 959 593 B
Component: TSG FS 009 0014
Serial number: 0000079650422
Coding: 00100320D000040000001000
Shop #: WSC 00049 770 00129
VCID: 4487AC64CF5B66647C-8010
Component: FOND_FHSG_DRV 005 0004
Serial number: 00000000000000985070
Coding: 310000
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 M
Component: EPS_MQB_ZFLS 127 1021
Coding: 01
ROD: EV_SteerAssisMQB_008.rod
VCID: 3D71D980ACB117AC33-8068
Part No SW: 5Q4 959 592 B HW: 5Q4 959 592 B
Component: TSG BFS 009 0014
Serial number: 0000079603373
VCID: 4385AF78CA55615C45-8016
Component: FOND_FHSG_PSG 005 0004
Serial number: 00000000000000912462
Coding: 290000
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Coding: 048A000009000000
VCID: 75E101A0D4018FEC3B-8020
Address 5F: Information Electr. (J794) Labels:* Redir Fail!
Part No SW: 5F0 035 846 A HW: 5F0 035 846 A
Component: MU-S-N-ER 040 0425
Serial number: E1F00111130783
Coding: 04730001D70A000021110001000800002F0103040100010046
ASAM Dataset: EV_MUStd6C1PASE 002030
ROD: EV_MUStd6C1PASE.rod
VCID: 264316EC5927B47442-8072
Subsystem 1 - Part No SW: 5F0 919 603 A HW: 5F0 919 603 A
Component: ABTmin_Std_Nv H51 0022
Serial number: SEZ8Z9NL400BJQ
Subsystem 2 - Part No SW: 5F0 060 884 S HW: -----------
Component: ECE 2016/17 --- 0059
Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb
Part No SW: 5Q0 907 383 HW: 5Q0 907 383
Component: Anheanger H10 0030
Serial number: 00006789000000
Coding: 0100000200000000
ASAM Dataset: EV_TrailFunctDemouHella 001001
ROD: EV_TrailFunctDemouHella.rod
VCID: 74E73CA4DF7B96E40C-8020
End-------------------------(Elapsed Time: 03:26)--------------------------
