VW Golf Sportswagen 2015, Dead Infotainment after jumpstart
Moni
C?ID=288542
Hi there,
Any help would be appreciated.
I had to receive cold-weather related jump start from another car (not a charging device).
I made the mistake to connect the negative cable directly to the negative terminal of the battery.
Car started but the infotainment console went dark.
I did check the fuses in banks F10 (MINI, Display, infotainment controls), F12 (ATO, Infotainment Services), F16 (MINI, Phone).
These fuses are fine.
Any ideas about other fuses that I could check?
Many thanks for any replies!
P.S. Correction year is 2015, not 2018
I've fixed the thread title for you.
It couldn't hurt to run an Auto-Scan and post the results. No guarantees, but there might be clues in there.
Moni
C?ID=288542
Thank you Uwe!
Will do this tomorrow.
New Info:
I let the car run and:
- Checked all fuses in both fuse boxes (inside and engine) with a multimeter - all fuses are fine.
- I also took out and plugged back in the fuses for the infotainment system (hoping for some sort of reboot)
No cigar ...
Moni
C?ID=288542
Here we go:
Thursday,22,March,2018,20:23:36:17869
VCDS Version: 18.2.0.3 (x64)  HEX-NET CB: 0.4411.4
VIN: 3VWC17AU7FM50####   License Plate:
Mileage: 27675km-17196mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F 75
VIN: 3VWC17AU7FM50####   Mileage: 27675km-17196miles
5F-Information Electr. -- Status: Cannot be reached 0100
Address 01: Engine (J623-CXBB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5GM 906 264     HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0001
   Revision: --H13---
   Coding: 091A00122424002F0000
   Shop #: WSC 00066 790 00218
   ASAM Dataset: EV_ECM18TFS0205GM906264 001001
   ROD: EV_ECM18TFS0208V0906264F.rod
   VCID: 0444442E8F5ED2643C-8050
   Part No SW: 09G 927 749 D    HW: 09G 927 749 D
   Component: AISIN AG6 G3  129 2866
   Coding: 010200000C000000000000000000000000000000
   ASAM Dataset: EV_TCMAQ250031 002009
   ROD: EV_TCMAQ250031_002_VW25.rod
   VCID: 3A38FAD6BD1A549416-806E
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-ESP-V1.clb
   Part No SW: 3Q0 907 379 P    HW: 3Q0 907 379 C
   Component: ESC           H32 0385
   Revision: 00000000    Serial number: 50115000000088
   Coding: 04FA6AA12420096F007C020481CA292056249000408194B400430050C002
   Shop #: WSC 01383 790 50316
   VCID: 47DE9322FEE8397C99-8012
   Part No SW: 5GM 907 426     HW: 5GM 907 426
   Component: AC Manuell    H02 1001
   Revision: 00001K01
   Coding: 02020004200100000000000000000000
   ROD: EV_ACManueBHBVW37X_003_VW37.rod
   VCID: 0542592A8464EB6C2B-8050
          B10CD 00 [008] -  -
                    Reset counter: 48
                    Mileage: 27163 km
                    Date: 2018.03.18
                    Time: 20:20:18
                    Voltage terminal 30: 10.9 V
Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-BV1.clb
   Part No SW: 5Q0 937 087 Q    HW: 5Q0 937 087 Q
   Component: BCM PQ37BOSCH 028 0145
   Revision: --------    Serial number: 86581201151322
   Coding: 000018424041804169E44000000403001000000000000000000000000000
   Shop #: WSC 00066 790 00082
   ROD: EV_BCMBOSCH_014.rod
   VCID: 49DA951AE8FCCF0C8F-801C
   Component: WWS    140902  043 0581
   Serial number:         150225003202
787212 - Windshield Washer Pump
          B1261 01 [008] - Electrical Failure
132363 - Voltage Supply; Terminal 30; Left
          B140D 13 [008] - Open Circuit
                    Reset counter: 51
                    Mileage: 27675 km
                    Date: 2018.03.22
                    Time: 08:51:40
                    Fault Frequency: 33
                    Reset counter: 52
                    Mileage: 24838 km
                    Date: 2017.12.31
                    Time: 11:11:43
   Serial number: 003GCR0165G0
   Occupant Detection:
   Component: BF-Gewichtss.  H10 0021
   Serial number: IBH0000J150002C9GK01
   Coding: 303138
   Subsystem 2 - Part No SW: -----------    HW: 480 001 912 14
   Serial number: 3570000000070D214212
   Subsystem 3 - Part No SW: -----------    HW: 480 001 912 14
   Serial number: 358000000005AAD0721L
   Subsystem 4 - Part No SW: -----------    HW: 480 401 411 14
   Serial number: 3510002B1188FC13C3DD
   Subsystem 5 - Part No SW: -----------    HW: 480 401 311 14
   Serial number: 35200029D188FC1582DL
   Subsystem 6 - Part No SW: -----------    HW: 480 401 612 14
   Serial number: 3550002A1196FF60320/
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 401 612 14
   Serial number: 3560002C9196FF622119
9483264 - Seat Occupied Recognition
          B10B4 00 [008] - Function Restriction due to Undervoltage
          [Bladder Mat: functional restriction because of low voltage]
                    Reset counter: 48
                    Mileage: 27163 km
                    Date: 2018.03.19
                    Time: 05:50:12
   Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20150118400498
   Coding: 0410
   Shop #: WSC 66564 385 16448
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3FCE8BC2A63871BC21-806A
   Part No SW: 5G1 920 840     HW: 5G1 920 840
   Component: KOMBI         243 4270
   Coding: 0BB4110A2180CF0502086A001000000000000000
   VCID: 648464AE6F1E72649C-8030
16777018 - Function Restricted due to Interrupted Communications
          U1110 00 [009] - -
          [BAP_Audio_0x31 keine Kommunikation]
                    Reset counter: 10
                    Mileage: 27595 km
                    Date: 2018.03.19
                    Time: 10:35:57
16777020 - Function Restricted due to Interrupted Communications
          U1110 00 [009] - -
          [BAP_TEL_0x28 keine Kommunikation]
                    Reset counter: 10
                    Mileage: 27595 km
                    Date: 2018.03.19
                    Time: 10:35:57
16777022 - Function Restricted due to Interrupted Communications
          U1110 00 [009] - -
          [BAP_NAV SD_0x32 keine Kommunikation]
                    Reset counter: 10
                    Mileage: 27595 km
                    Date: 2018.03.19
                    Time: 10:35:57
   Part No SW: 5Q0 907 530 AB    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2203
   Revision: --------    Serial number: 22011510001560
   Coding: 0101000820085900EF0000081C0F00000001050000000000000000000000
   Shop #: WSC 00066 790 07029
   ROD: EV_GatewConti_011_VW37.rod
   VCID: 71AA1DFAA0ECD7CCE7-8024
   Subsystem 2 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H16 0101
   Serial number: 27150000246550085071
   Coding: 29FFFF
131699 - Control unit for information electronics 1
          U1054 00 [009] - No Communication
          [Timeout Knoten 0x73 / 5F - Steuergerät für Informationselektronik 1]
                    Reset counter: 12
                    Mileage: 27675 km
                    Date: 2018.03.22
                    Time: 08:56:42
                    Supply voltage: Terminal 30: 11.5 V
                    Terminal 15: On
66052 - Infotainment CAN Bus (SAE Bus E)
          U0065 00 [008] - Performance
          [Globaler Timeout CAN-Infotainment]
                    Fault Frequency: 33
                    Reset counter: 51
                    Mileage: 27163 km
                    Date: 2018.03.19
                    Time: 05:44:10
                    Terminal 15: OFF
   Part No SW: 5Q0 959 393 B    HW: 5Q0 959 393 B
   Serial number: 060215060507EO
   Coding: 003003200000040000000000
   VCID: 3E30F6C6A13278B42A-806A
   Serial number: 00000000000000422812
   Coding: 011000
589829 - Window Regulator; Rear Driver side
          B131F F5 [008] - Supply Voltage too Low
                    Reset counter: 48
   Component: EPS_MQB_ZFLS  126 1061
   Coding: 0102
   VCID: 43C68732CAD0155C45-8016
   Part No SW: 5Q0 959 392 B    HW: 5Q0 959 392 B
   Serial number: 060215060509NL
   VCID: 3D32F1CAAC3463AC33-8068
   Serial number: 00000000000000611718
   Coding: 091000
589845 - Window Regulator; Front Passenger side
          B1320 F5 [008] - Supply Voltage too Low
                    Reset counter: 48
   Component: OCULowMQBUS   007 0564
   Coding: 02730202C2821A017F1E06000000
   Shop #: WSC 00066 790 00122
   ROD: EV_OCULowMQB.rod
0022 - Databus
          [CAN TO radio]
                    Fault Frequency: 12
                    Reset counter: 12
                    Mileage: 27163 km
                    Date: 2018.03.19
                    Time: 05:43:26
0036 - Databus
          [CAN TO GPS data]
                    Reset counter: 11
                    Mileage: 27163 km
                    Date: 2018.03.19
                    Time: 05:43:26
13636864 - Mobile Online Services
          B149A F0 [008] - Vehicle Condition Report
                    Reset counter: 45
End----------(Elapsed Time: 01:17, VBatt start/end: 13.9V/13.9V)-----------
OK, the 5F module (your Infotainment) is definitely off-line.
Does anyone know if those MIB1 units have a dedicated fuse on the back of them like so many older VW/Audi radios did?
Moni, I suggest you to clear all fault codes the slow way; from the Auto-Scan screen, with 'Use CAN command' un-checked. Then cycle the ignition OFF and back ON again and re-scan. Reason: I think there are still spurious codes in various systems from your dead battery incident and I'd like to have them gone and to see what comes back.
Moni
C?ID=288542
Thank you Uwe.
The how-to steps made it easy for me
Saturday,24,March,2018,10:57:53:17869
VIN: 3VWC17AU7FM50####   License Plate: CLEAN
   Revision: --H13---
Readiness: 1010 1101
   Revision: 00001K01
   Occupant Detection:
   Coding: 303138
   Coding: 0410
          U1110 00 [009] - -
                    Reset counter: 14
                    Mileage: 27675 km
                    Date: 2018.03.24
                    Time: 22:49:17
          U1110 00 [009] - -
                    Reset counter: 14
                    Mileage: 27675 km
                    Date: 2018.03.24
                    Time: 22:49:16
          U1110 00 [009] - -
                    Reset counter: 14
                    Mileage: 27675 km
                    Date: 2018.03.24
                    Time: 22:49:17
   Coding: 29FFFF
                    Reset counter: 14
                    Mileage: 27675 km
                    Date: 2018.03.24
                    Time: 22:49:29
                    Supply voltage: Terminal 30: 13.8 V
                    Terminal 15: On
   Coding: 011000
   Coding: 0102
   Coding: 091000
0022 - Databus
          [CAN TO radio]
                    Reset counter: 14
                    Mileage: 27675 km
                    Date: 2018.03.24
                    Time: 22:50:36
0036 - Databus
          [CAN TO GPS data]
                    Reset counter: 14
                    Mileage: 27675 km
                    Date: 2018.03.24
                    Time: 22:50:36
End----------(Elapsed Time: 01:13, VBatt start/end: 13.9V/13.9V)-----------
OK, now the only faults left are IMO attributable to the 5F-Infotainment module being off-line.
One suggestion I received privately was: Try cold-booting it. You could do that by disconnecting the car's battery for a while, but if it were me, I'd do it by pulling the Infotainment unit, unplugging it from the car's harness and checking to see it it has its own fuse on the back of it, like so many other VW/Audi radios do. If it does, and that fuse is blown, well, you've found the culprit. If not, then while you have it out, you can use a meter to verify that the module is getting power as it should.
MasterTommy
Amsterdam
C?ID=295586
My MIB2.5 unit does not have one on the back. There might be one inside the housing, but since mine works i’m not really feel like busting seals unfortunately. I have seen pictures of other MIB units that do have one, visible when you disconnect the quadlock connector. If it doesnt have one, triple check if the right fuse in the fuse box is really okay (DVM), check power to unit as Uwe said, and as a last resort you could check if it has an internal fuse. Although voltage spikes can FUBAR electronics instantly and without burning through any fuses...
nazdaq100
London, United Kingdom
C?ID=314050
Hi everyone can anyone please help me what are the basic steps to code infotainment on to the car. in other words code into the car to make it work.
On a vw polo 2014 model
Do I need to go can gateway and click on installation list and tick 5F
Let me know buddy
The car is 100 miles away a request by Jack has been made to me so I couldn't post a scan at this stage
"Hello Sam, it's Jack with the gti that time. Sorry it's a little late. Not sure if you can help but can you reprogram an infotainment system on a 64 plate polo? Thanks again"
Kind Regards
DV52
C?ID=194404
^ ^^^Hi. Can you clarify your wants - please ?
"can you reprogram an infotainment system on a 64 plate polo?" and "in other words code into the car to make it work. On a vw polo 2014 model" - are a tad confusing (to me, at least)
And please post-up an autoscan for the car that is to receive the 5F unit
