Audi A3 8P No Start - No Comms
jimpoole
C?ID=221559
I borrowed my brothers A3 which was a bad move as it has cratered more or less as soon as I got it.
I was driving down the road normally and all the warning lights started to come on: Low Oil Pressure, ESP, Steering Assist etc. I did and auto scan and saw that there were module communication errors, cleared the codes and it started and ran normally. Later in the day I went out in it again . After a few miles the same happened again. I stopped off and the car restarted and drove back with all the lights on. When I got the car back on my drive I turned off the engine and then went to start it again. Unfortunately now it wont start!
I have checked all the fuses and none are blown and as far as I can tell the relays are all fine.
The autoscan shows that most of the modules aren't communicating.
Please can anyone shed some light on this??
Tuesday,13,March,2018,18:26:38:22812
VCDS Version: 18.2.0.3 (x64)
VIN: WAUZZZ8P24A048518   License Plate: EDS1
Mileage: 151850km-94355mi   Repair Order: 003
Chassis Type: 8P (1K0)
VIN: WAUZZZ8P24A048518   Mileage: 151850km-94355miles
00-Steering Angle Sensor -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Cannot be reached 1100
15-Airbags -- Status: Cannot be reached 1100
44-Steering Assist -- Status: Cannot be reached 1100
Address 01: Engine
Address 03: ABS Brakes
   Part No SW: 8P0 820 043     HW: 8P0 820 043
   Component: KlimavollautomatH11 0130
   Shop #: WSC 06435 000 00000
   VCID: 69D9A3314020FE0CAF-803C
                    Fault Status: 00101010
                    Reset counter: 153
                    Mileage: 162154 km
                    Date: 2016.10.29
                    Time: 00:00:17
                    Temperature: 6.5°C
            007 - Short to Ground
                    Fault Status: 01100111
                    Fault Frequency: 119
                    Reset counter: 113
                    Mileage: 158263 km
                    Date: 2017.11.23
                    Time: 08:17:08
                    Temperature: 7.5°C
                    Reset counter: 113
                    Mileage: 151854 km
                    Date: 2013.05.09
                    Time: 00:14:48
Address 09: Cent. Elect.        Labels:. 8P0-907-279-23-H.lbl
   Part No SW: 8P0 907 279 A    HW: 8P0 907 279 A*
   Component: Bordnetz-SG 1.0 H27 0401
   Revision: 00000000    Serial number: 00000000113579
   Coding: 018C4F00A0141000000000000000000000
   VCID: 3B7529797A3CBC9C0D-806E
   Subsystem 1 - Part No: 8P2 955 119 C  Labels: 1TX-955-119.CLB
   Component: Wischer WWS Audi350 0180
   Coding: 16711696
00188 - Control Circuit 1; Relay for Supply Voltage Terminal 50
00187 - Control Circuit; Relay for Supply Voltage Terminal 75X
Address 15: Airbags
   Part No SW: 1K0 953 549 A    HW: 1K0 953 549 A
   Component: Lenksäulenmodul 009 0030
   Coding: 0000012
   VCID: 306F0E55A37A4FC4A8-8064
   Part No SW: 8P0 920 980 E    HW: 8P0 920 980 E
   Component: KOMBIINSTR. VDO H25 0070
   Revision: D04         Serial number: 2246CD04001561
   Coding: 0004403
   Shop #: WSC 80093 222 69422
   VCID: 3979337170008E8C1F-806C
00003 - Control Module
            014 - Defective
                    Fault Status: 00000011
                    Mileage: 86113 km
                    Date: 2008.09.07
                    Time: 12:11:12
                    Reset counter: 105
                    Mileage: 1844 km
                    Date: 2009.05.29
                    Time: 09:41:42
   Part No SW: 1K0 907 530 B    HW: 1K0 907 951
   Component: Gateway         H08 0070
   Revision: 08          Serial number: 2000103626775F
   Coding: 3D0F0340070101
   VCID: 2643E80D91BE117442-8072
6 Faults Found:
                    Fault Frequency: 34
                    Reset counter: 153
                    Mileage: 151854 km
                    Date: 2013.05.09
                    Time: 00:15:14
                    Fault Frequency: 20
                    Reset counter: 113
                    Mileage: 151854 km
                    Date: 2013.05.09
                    Time: 00:15:14
                    Fault Frequency: 39
                    Reset counter: 153
                    Mileage: 151854 km
                    Date: 2013.05.09
                    Time: 00:15:14
                    Fault Frequency: 22
                    Reset counter: 113
                    Mileage: 151854 km
                    Date: 2013.05.09
                    Time: 00:15:14
                    Fault Frequency: 34
                    Reset counter: 153
                    Mileage: 151854 km
                    Date: 2013.05.09
                    Time: 00:15:14
01312 - Powertrain Data Bus
                    Fault Status: 00101110
                    Fault Frequency: 9
                    Reset counter: 153
                    Mileage: 151854 km
                    Date: 2013.05.09
                    Time: 00:26:41
   Revision: D04         Serial number: AUX7Z0C6FNM0AE
02241 - Engine Control Module; Immobilizer Data not Adapted
            000 -  -  - Intermittent
01176 - Key
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN1.lbl
   Part No: 8P0 959 801 A
   Component: Tuersteuerger.  H10 0010
   Coding: 0000048
Address 44: Steering Assist
   Part No: 8P0 959 433
   Component:    KSG          H02 0030
   Coding: 008800186D288505485AC63000
   VCID: 79F9F37130804E8C5F-802C
   Subsystem 2 - Part No: 1K0 907 719
   Component: Neigungssensor  002 0002
   Component: Innenraumueberw.H01 0010
01134 - Alarm Horn (H12)
            013 - Check DTC Memory
Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MIN2.lbl
   Part No: 8P0 959 802 H
   Component: Tuer-SG         020 0050
   Coding: 0000512
   VCID: 41895B9118D0D64C57-8014
Address 56: Radio        Labels: 8P0-035-1xx-56.lbl
   Part No SW: 8P0 035 186     HW: 8P0 035 186
   Component: concert II EU   H52 0060
   Revision:      05S    Serial number: AUZ2Z3C1294378
   Coding: 0000201
   VCID: 6FEDCD297EC4103CF1-803A
End-------------------------(Elapsed Time: 01:39)--------------------------
I believe the Relay codes in the Central Electric Module are from me removing the relays to test them.
MasterTommy
Amsterdam
C?ID=295586
Well at least the radio is fine? :rolleyes:
Check power & ground to modules that are not communicating. Seeing as there are a lot, they probably share a common point of failure. If all modules have power and ground, check bus wires.
Oh and before you ask, yeah you need to get a WD from Erwin, unless you fancy trying your luck.
Check fuses...........!
Check battery connections!
Check ignition switch & all terminal relays for function!
jimpoole
C?ID=221559
After downloading the circuit diagrams last night, I checked SB40 and I have 12V both sides but when I go to SC2, I have 0V. I'm guessing there must be a wiring issue between the two.
Jef
HQ
Since SB40 is hot, and SC2 in not... first I'd just quickly replace fuse SB40 just for giggles and hope for the best. What does the underside of the SB fuse panel look like? SB40 goes to T40/19 and then weld point B273. I wonder if one of those two locations has some rot issues?
Vehicle Identification No. WAUZZZ8P24A048518
Model audi a3 2.0
A3
Date of production 09.08.2003
Year 2004
Sales type 8P1B7C
Engine Code AXW
Transmission Code GLB
jimpoole
C?ID=221559
I must admit, now I'm stumped!
I went out to the car this evening and tried to start it. It started but all the warning lights are on.
I did an auto scan and tried to clear the codes to try and see what remains. Both scans attached below.
I've been through and tested each fuse and there's power on SC2.
What's really weird is I used my multimeter to test all the fuses and I know I have a good ground but it is measuring 0V on fuses 32, 33, 44, 45 and 46. My wiring diagram shows 32 to be the injectors yet the engine still runs. Utterly stumped!!
Wednesday,14,March,2018,19:19:07:22812
Mileage: 151850km-94355mi   Repair Order: 0006
Address 01: Engine
                    Reset counter: 153
                    Mileage: 162154 km
                    Date: 2016.10.29
                    Time: 00:00:17
                    Temperature: 6.5°C
                    Fault Frequency: 120
                    Reset counter: 113
                    Mileage: 158263 km
                    Date: 2017.11.23
                    Time: 08:17:08
                    Temperature: 7.5°C
   Coding: 16711696
Address 15: Airbags
   Coding: 0000012
   Coding: 0004403
            014 - Defective
                    Mileage: 86113 km
                    Date: 2008.09.07
                    Time: 12:11:12
                    Reset counter: 105
                    Mileage: 1844 km
                    Date: 2009.05.29
                    Time: 09:41:42
6 Faults Found:
                    Fault Frequency: 10
                    Reset counter: 153
                    Mileage: 151854 km
                    Date: 2013.05.09
                    Time: 00:10:59
                    Reset counter: 113
                    Mileage: 151854 km
                    Date: 2013.05.09
                    Time: 00:11:06
                    Reset counter: 113
                    Mileage: 151854 km
                    Date: 2013.05.09
                    Time: 00:11:26
                    Fault Frequency: 7
                    Reset counter: 113
                    Mileage: 151854 km
                    Date: 2013.05.09
                    Time: 00:11:26
                    Reset counter: 113
                    Mileage: 151854 km
                    Date: 2013.05.09
                    Time: 00:11:26
                    Reset counter: 113
                    Mileage: 151854 km
                    Date: 2013.05.09
                    Time: 00:11:26
01176 - Key
   Coding: 0000048
   Coding: 0000512
00106 - Signal Central Locking SAVE/LOCK Passenger Side
   Coding: 0000201
End-------------------------(Elapsed Time: 01:25)--------------------------
Address 17: DTCs cleared
Address 08: DTCs cleared
Address 09: DTCs cleared
Address 16: DTCs cleared
Address 19: DTCs cleared
Address 25: DTCs cleared
Address 42: DTCs cleared
Address 46: DTCs cleared
Address 52: DTCs cleared
Address 56: DTCs cleared
Address 01: Engine
                    Reset counter: 113
                    Mileage: 158263 km
                    Date: 2017.11.23
                    Time: 08:17:08
                    Temperature: 7.5°C
   Coding: 16711696
Address 15: Airbags
   Coding: 0000012
   Coding: 0004403
            014 - Defective
                    Mileage: 86113 km
                    Date: 2008.09.07
                    Time: 12:11:12
                    Reset counter: 113
                    Mileage: 151854 km
                    Date: 2013.05.09
                    Time: 00:29:14
                    Reset counter: 113
                    Mileage: 151854 km
                    Date: 2013.05.09
                    Time: 00:29:14
                    Reset counter: 113
                    Mileage: 151854 km
                    Date: 2013.05.09
                    Time: 00:29:14
                    Reset counter: 113
                    Mileage: 151854 km
                    Date: 2013.05.09
                    Time: 00:29:14
                    Reset counter: 113
                    Mileage: 151854 km
                    Date: 2013.05.09
                    Time: 00:29:14
   Coding: 0000048
   Coding: 0000512
   Coding: 0000201
End-------------------------(Elapsed Time: 01:36)--------------------------
jimpoole
C?ID=221559
I grounded the black lead to the main ground on the chassis next to the battery and then checked DC Voltage at each of the little metal tabs on the top of each fuse.
All the other fuses apart from the ones I have mentioned showed 14.5 V with the engine running.
jimpoole
C?ID=221559
I forgot the mention the other weird thing is that if I carry out an autoscan, the Engine ECU can't be found. If I select the Engine ECU as a module I can find it and read PIDs. I can't do the same with the ABS module.
Jef
HQ
My comments in post #6 still very relevant. Jack, do you want to wager on what color the rot will be?
IDK maybe a tinge of aqua green with a bit of off white bird-shit in color scheme? :rolleyes:
jimpoole
C?ID=221559
So, the million dollar question is where is this connection?
Will I have to split all the loom open from the fuse box to find it?
Tone generator will allow you to follow it.
Isolate zone areas and load test the track or overlay if suspect or fails test.
Jef
HQ
The fuse box in the engine bay, there should be 2 terminal housings on the bottom side of it, a T40 and a T26. I would pull that fuse panel up to get to those connectors, unplug them and inspect the electrical connectors.
The weld point I mentioned, B273, hard to say where that would be found, it isn't officially documented but I would suspect it would be about 15 to 20 inches (38 to 51 cm) down the wiring harness from the T40 plug.
jimpoole
C?ID=221559
I think I've sorted it!
I took apart the fuse box as suggested and it was pristine. I then unwrapped the loom as far back as I could and couldn't find the splice so decided to try a different tack.
I went to each of the modules that wouldn't communicate and disconnected them one at a time and checked the powers and grounds as well as conducting an auto scan. I did ABS unit first, then cluster and then steering rack and bingo. With the steering rack disconnected, everything works!
With all the rain we've had I bet the rack electrics have been flooded.
Thanks for you help guys! :)
