2011 Audi A6 C7 - Enable start/stop memory function?
piehole1983
Belfast, Northern Ireland
C?ID=295335
Hey everyone!
I'm looking for some advice on how to enable the memory function for start/stop where the car remembers the last state the start/stop was in before shutting down the engine. I've seen a few posts on how to do it and videos of it working which I tried but did not work. The method I tried was controller 09, channel 34 and adding 32 to the current value. Tested after saving but made no difference. I reverted back to the normal value of 20. Autoscan attached for completeness.
Monday,12,March,2018,11:30:59:48959
VCDS Version: 17.8.1.0 (x64)  HEX-V2 CB: 0.4401.4
Dealer/Shop Name: CWR
Workshop Code: 022 00003 000011
VIN: WAUZZZ4G5BN035371   License Plate: A6 C7
Mileage: 206234km-128147mi   Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 3B 42 44 46 52 53 5F 62 72
VIN: WAUZZZ4G5BN035371   Mileage: 206234km-128147miles
Address 01: Engine (J623-CLAB)       Labels:. 059-907-401-V2.clb
   Part No SW: 4G0 907 311 G    HW: 4G0 907 401
   Component: 3.0TDI EDC17  H37 0003
   Revision: 53H37---
   Coding: 0A034012052401020000
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_ECM30TDI0114G0907311G 001003
   ROD: EV_ECM30TDI0114G0907311G.rod
   VCID: 2708F1E87F66E7CF3BB-8072
5603 - Park/Neutral Switch Input Circuit
          P0851 00 [096] - Short to Ground
Address 02: Auto Trans (J217)       Labels:| 0AW-927-156.clb
   Part No SW: 4G1 927 155 D    HW: 0AW 927 156 K
   Component: 0AW 30TDI RdW H04 0005
   Revision: --H04---    Serial number: 0000000093
   Coding: 000001
   ASAM Dataset: EV_TCMVL381 A02428
   ROD: EV_TCMVL381.rod
   VCID: 2D0403C05D9ACD9FC17-8078
2260 - Starter Interlock Signal
          P1724 00 [032] - Short to Ground
10076 - Valve for Transmission Fluid Cooler
          P2755 00 [044] - Short to Plus
                    Mileage: 204457 km
                    Date: 2017.12.05
                    Time: 10:36:33
                    Engine speed: 900.00 /min
                    Transmission input speed: 1 /min
                    Transmission output speed: 1 /min
                    Engine torque: -4 Nm
                    Transmission fluid temperature: 10 °C
                    Accelerator position: 0.0 %
                    Clutch status: 13
                    Unlearning counter according OBD: 24
                    Occurrence_counter_over_length_of_life: 1
   Part No SW: 4G0 907 379     HW: 4G0 907 379
   Component: ESP PREMIUM   H08 0190
   Coding: 07A18700E085E100CB00
   ASAM Dataset: EV_ESPPremiAU57X 003013
   ROD: EV_ESPPremiAU57X_003.rod
   VCID: 6E86C4CC901CF687B8D-803A
0629 - Tire Pressure Warning
          C102D 00 [008] -  -
                    Reset counter: 37
                    Mileage: 203233 km
                    Date: 2017.11.04
                    Time: 12:03:28
                    VzRef: 56
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 26
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: 30
                    Uz: BE
0630 - Tire Pressure Warning
          C102D 00 [008] -  -
                    Reset counter: 47
                    Mileage: 204185 km
                    Date: 2017.11.29
                    Time: 09:43:04
                    VzRef: 48
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 26
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: 31
                    Uz: BD
   Part No SW: 4H0 907 064 AG    HW: 4H0 907 064 AG
   Component: BCM2 2.0      H24 0217
   Coding: 01B83000000000000000
   VCID: 6E86C4CC909CF687B8D-803A
   Serial number: 2311000103513008
00447 - Function Limitation due to Over-Voltage
                    Fault Status: 00100001
                    Reset counter: 65
                    Mileage: 203925 km
                    Date: 2017.11.19
                    Time: 09:55:42
                    Fault Status: 00101101
                    Reset counter: 44
                    Mileage: 204041 km
                    Date: 2017.11.19
                    Time: 14:24:18
   Part No SW: 4G0 820 043 G    HW: 4G0 820 043 G
   Component: KLIMA 2 ZONEN H10 0056
   Serial number: 24051100040400
   Coding: 3621000820
   ASAM Dataset: EV_AirCondiBasisUDS 002033
   VCID: 2310E5F80B5E0BEF673-8076
   Part No SW: 4H0 907 063 H    HW: 4H0 907 063 A
   Component: BCM1 2.0      H12 0092
   Revision: 12012002    Serial number: 00000001052498
   Coding: 690000108034A7E00105008000005F5F0F9DC20827080101000004402000
   VCID: 2D0403C05D1ACD9FC17-8078
   Component: WWS57X 110404  H35 0051
   Serial number:         110430101450
   Coding: 0045F7
   Component: RLS  H04 0003
   Serial number: 11444793
   Coding: 02512B
   Subsystem 3 - Part No SW: 4G0 941 531     HW: 4G0 941 531
   Component: E1 - LDS  H07 0044
   Serial number: 18 05 2011  00000468
   Component: Humidity_Sens  H02 0002
   Serial number: 750889A5000000000001
   Part No SW: 4H0 919 475 H    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H07 0030
   Revision: 11001001    Serial number: 55901113402288
   Coding: 100305
   ASAM Dataset: EV_EPHVA18AU57X0000 001002
   ROD: EV_EPHVA18AU57X0000_001.rod
   VCID: 372821A8AFC6774FABB-8062
Address 15: Airbags (J234)       Labels:| 4H0-959-655.clb
   Component: Airbag10.43   H40 0040
   Revision: --------    Serial number: 003JG002H7DY
   Coding: 30323436313330303537554A305234473053
   VCID: 36362CACA8CC8E47B0D-8062
   Serial number: 3575HRB404R0IRE0GH1V
   Serial number: 3585HRB40610IDFS8OV9
   Serial number: 3515JRB404V0I4AGH0NQ
   Serial number: 3525JRB405V0I4AGBPVC
   Serial number: 3554VRB405B0I70GLOU7
   Serial number: 3564VRB40590I70G58RE
   Revision: 00000000    Serial number: 20110522000012
   Coding: 000034
   VCID: 303A1AB44A28A077EA1-8064
   Subsystem 1 - Part No SW: 4G0 951 528 E    HW: 4G0 951 528 E
   Component: E221 - MFL  H07 0009
Address 17: Instruments (J285)       Labels:| 4H0-920-xxx-17.clb
   Part No SW: 4G8 920 950 D    HW: 4G8 920 950 D
   Component: MDieGb        H29 0086
   Revision: 18420081    Serial number: 658030511592011
   Coding: 33A6080003012600010000
   ASAM Dataset: EV_RBC7KMID 004040
   ROD: EV_RBC7KMID.rod
   VCID: 303A1AB44AA8A077EA1-8064
   Part No SW: 4G0 907 468 B    HW: 4G0 907 468
   Component: J533--Gateway H08 0204
   Revision: --------    Serial number: 00000000147318
   Coding: 00CD077D00
   ROD: EV_GatewUDS_AU57.rod
   VCID: 2F3819C85796BF8FF3B-807A
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650479206
   Voltage stabilizer:
   Part No SW: 4G0 907 637     HW: 4G0 907 637
   Component: SARA 3D       H02 0004
   Revision: --------    Serial number: EJ1BPA3200743D0
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA_006.rod
   VCID: 6B80CDD8A30E03AF9F3-803E
   Part No SW: 4G8 959 793 C    HW: 4G8 959 793 A
   Component: TSG FA        H04 0210
   Coding: 011C06204001620002080002
   Shop #: WSC 02312 785 00200
   VCID: 40DA4A74FA8830F71A1-8014
   Part No SW: 4G0 909 144 M    HW: 4G0 909 144 G
   Component: RCEPS         H41 0011
   Revision: 00001000    Serial number: 0010969408
   Coding: 101000010000
   Shop #: WSC 54730 001 1048576
   ASAM Dataset: EV_RCEPS 009010
   ROD: EV_RCEPS_009.rod
   VCID: 333015B8BBBE9B6F973-8066
   Revision: 00002001    Serial number: 0149819083
   Coding: 011B062200B9040083200804000100000000000000000000000000000000
00532 - Supply Voltage B+
                    Reset counter: 65
                    Mileage: 204041 km
                    Date: 2017.11.19
                    Time: 14:24:18
02615 - Fuel Tank Cap; Lock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 116
                    Mileage: 194649 km
                    Date: 2017.04.25
                    Time: 13:20:32
02616 - Fuel Tank Cap; Unlock
                    Reset counter: 116
                    Mileage: 194649 km
                    Date: 2017.04.25
                    Time: 13:20:54
   Part No SW: 4G8 959 792 C    HW: 4G8 959 792 A
   Component: TSG BF        H04 0210
   VCID: 3FD8498887764F0F63B-806A
   Revision: --------    Serial number: 00000000076511
   ROD: EV_ParkiBrake_AU57.rod
   VCID: 2A0E08DC6C74DAA7245-807E
   Part No SW: 4G0 035 193 G    HW: 4G0 035 192 A
   Component: RMC Cnct Nav  H43 0802
   Coding: 0101000001415B47002B060301010000010000
   VCID: 2708F1E87FE6E7CF3BB-8072
   Subsystem 1 - Part No: 8X0 919 884 C
   Component: P11-50-10.06  1006
   Subsystem 2 - Part No SW: 4G0 919 603     HW: 4G0 919 603
   Component: DU6 Basic  H42 0084
   Serial number: 9464DO0B0035066
   Subsystem 3 - Part No SW: 4G2 919 610 B    HW: 4G2 919 612 K
   Component: E380 BDT C7  H08 0204
   Serial number: 90349KEG0002C
   Part No SW: 4G8 959 795 C    HW: 4G8 959 795 A
   Component: TSG HL        H03 0210
   Coding: 010804204001620002080002
   VCID: 42DE407CF48422E70C5-8016
   Component: TSG HR        H03 0210
End----------(Elapsed Time: 01:33, VBatt start/end: 13.4V/14.3V)-----------
Any help much appreciated!
piehole1983
C?ID=295335
This is what I tried without success, taken from another post:
30. Disable/memorize/invert Start & Stop:
- module 09-Cent. Elec.
- enter Security Code (20113)
- Adaptation on Channel 34:
subtract 4 to the value --> Start&Stop always disabled
add 32 to the value --> memorize last status (the Start & Stop status at engine startup will be the one at last engine shutdown)
- test & save
In addition of these values, if you add 64 to the value, the Start & Stop button light will be reversed: off if Start & Stop is disabled, and on if Start & Stop is enabled
hadez16
C?ID=289891
It might depend on your BCM software version but I'm not sure
piehole1983
C?ID=295335
Possibly, I’ve only seen posts and videos showing people with it working. I think their cars were older though.
GlynH
C?ID=75902
I only done this today on my 2014 A8 Facelift 4.2TDi
I had to enter the security access code of 20113 to access the module.
My default coding was 28 not 20 as mentioned above.
All I done was add 32 to 28 to give 60 and that done the trick!
Not sure how much difference there might be between A6 and A8 when it comes to VCDS though...
-=Glyn=-
